18-EVPN Command Reference
HomeSupportSwitchesH3C S7500X Switch SeriesReference GuidesCommand ReferencesH3C S7500X Switch Series Command References-Release7634Pxx-6W10018-EVPN Command Reference
02-MVXLAN commands
02-MVXLAN commands 124.00 KB
MVXLAN commands
address-family ipv4
Use address-family ipv4 to create an MVXLAN IPv4 address family and enter its view, or enter the view of the existing MVXLAN IPv4 address family.
Use undo address-family ipv4 to delete the MVXLAN IPv4 address family and all settings in MVXLAN IPv4 address family view.
address-family ipv4
No MVXLAN IPv4 address family exists.
MVXLAN view
# In MVXLAN view of VPN instance vpna, create an MVXLAN IPv4 address family and enter its view.
[Sysname] multicast-vpn vxlan vpn-instance vpna mode mdt
[Sysname-mvxlan-vpn-instance-vpna] address-family ipv4
[Sysname-mvxlan-vpn-instance-vpna-ipv4]
data-delay
Use data-delay to set the data-delay period (delay period before the device switches over from the default MDT to the data MDT).
Use undo data-delay to restore the default.
data-delay delay
undo data-delay
The data-delay period is 3 seconds.
delay: Specifies a data-delay period in the range of 1 to 60 seconds.
# In MVXLAN IPv4 address family view of VPN instance vpna, set the data-delay period to 10 seconds.
[Sysname-mvxlan-vpna] address-family ipv4
[Sysname-mvxlan-vpna-ipv4] data-delay 10
data-group
Use data-group to specify a data group range and optionally configure the criteria for the device to initiate a switchover of the default MDT to a data MDT.
Use undo data-group to restore the default.
data-group group-address { mask-length | mask } [ acl acl-number | name acl-name ]
undo data-group
No data group range exists, and the device never initiates a switchover of the default MDT to a data MDT.
group-address: Specifies a multicast group address in the range of 224.0.1.0 to 239.255.255.255.
mask-length: Specifies a mask length for the multicast group address. The value range for this argument is 22 to 32.
mask: Specifies a subnet mask for the multicast group address, in dotted decimal notation.
acl acl-number: Specifies an advanced ACL by its number in the range of 3000 to 3999.
name acl-name:  Specifies a basic or advanced ACL by its name, a case-insensitive string of 1 to 63 characters. The name must start with a letter and cannot be all.
This command enables the device to initiate a switchover of the default MDT to a data MDT if the multicast data permitted by the specified ACL keeps arriving for a data-delay period.
If you do not specify an ACL or the specified ACL does not contain rules, the data group configuration takes effect on all (S, G) entries.
The specified ACL matches traffic according to the following rules:
·     A basic ACL uses the source keyword in an ACL rule to match multicast traffic by the multicast source address. All optional parameters are ignored, except source, fragment, and time-range.
·     An advanced ACL uses the source and destination keywords in an ACL rule to match multicast traffic by the multicast source address and the multicast group address. All optional parameters are ignored, except source, destination, fragment, and time-range.
·     If the specified basic or advanced ACL contains a rule that has the vpn-instance keyword specified, that rule does not take effect.
On a VTEP, the data group range for an MVXLAN cannot include the default group or data groups of any other MVXLAN.
If you specify an ACL, the multicast data permitted by the ACL can trigger the switchover. If you do not specify an ACL, any multicast data can trigger the switchover.
If you execute this command multiple times in the same MVXLAN IPv4 address family view, the most recent configuration takes effect.
# In MVXLAN IPv4 address family view of VPN instance vpna, specify 239.1.0.0 through 239.1.0.255 as the data group range.
[Sysname-mvxlan-vpna-ipv4] data-group 239.1.0.0 32
dci enable
Use dci enable to enable multicast DCI.
Use undo dci enable to disable multicast DCI.
dci enable
undo dci enable
Multicast DCI is disabled.
This command enables an ED to forward Layer 3 multicast traffic over VXLAN-DCI tunnels to remote EDs.
# Enable multicast DCI in MVXLAN IPv4 address family view of VPN instance vpna.
[Sysname-mvxlan-vpn-instance-vpna-ipv4] dci enable
dci switch-delay
Use dci switch-delay to set the MVXLAN-specific traffic switchback delay on an ED that provides DCI Layer 3 multicast services.
Use undo dci switch-delay to restore the default.
dci switch-delay delay-time
The global traffic switchback delay set by using the multicast-vpn vxlan dci switch-delay command takes effect.
delay-time: Sets the traffic switchback delay in seconds, in the range of 0 to 3600. A value of 0 indicates that traffic switchback is not delayed.
If one of the redundant EDs fails at a multihomed site with DCI Layer 3 multicast configured, traffic of the failed ED is distributed to the other EDs for forwarding. After the failed ED recovers, it will advertise BGP EVPN routes to create multicast forwarding entries. If traffic is switched back before the recovered ED creates multicast forwarding entries, traffic forwarding is interrupted. To avoid traffic interruption, set the traffic switchback delay on all the redundant EDs.
You can set the traffic switchback delay in system view and MVXLAN address family view. The global traffic switchback delay takes effect on all MVXLANs, and the traffic switchback delay set in MVXLAN address family view takes effect on a per-MVXLAN basis. For an MVXLAN, the MVXLAN-specific traffic switchback delay takes precedence over the global one.
# Set the traffic switchback delay to 50 seconds in MVXLAN IPv4 address family view of VPN instance vpna.
[Sysname-mvxlan-vpn-instance-vpna] dci switch-delay 50
default-group
Use default-group to specify a default group.
Use undo default-group to restore the default.
default-group group-address
undo default-group
No default group exists.
group-address: Specifies a default group in the range of 224.0.1.0 to 239.255.255.255.
The default group for an MVXLAN must be different from the default group and the data group used by any other MVXLAN.
# In MVXLAN IPv4 address family view of VPN instance vpna, specify 236.0.0.1 as the default group.
[Sysname-mvxlan-vpn-instance-vpna-ipv4] default-group 236.0.0.1
display multicast-vpn vxlan data-group receive
Use display multicast-vpn vxlan data-group receive to display received data group information in an MVXLAN.
display multicast-vpn vxlan { vpn-instance instance-name | public-instance } data-group receive [ brief | [ active | group group-address | sender source-address | vpn-source-address [ mask { mask-length | mask } ] | vpn-group-address [ mask { mask-length | mask } ] ] * ]
vpn-instance instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters.
public-instance: Specifies the public instance.
brief: Displays brief information. If you do not specify this keyword, the command displays detailed information.
active: Specifies data groups that have joined the data MDT.
group group-address: Specifies a data group by its IP address in the range of 224.0.1.0 to 239.255.255.255.
sender source-address: Specifies an MVXLAN source interface by its IP address.
vpn-source-address: Specifies a multicast source address of the specified VPN instance.
vpn-group-address: Specifies a multicast group address of the specified VPN instance. The value range for this argument is 224.0.1.0 to 239.255.255.255.
mask-length: Specifies a mask length of the specified multicast source address or multicast group address. The value range for this argument is 0 to 32, and the default is 32.
mask: Specifies a subnet mask of the specified multicast source address or multicast group address. The default is 255.255.255.255.
If you do not specify any parameters, this command displays detailed information about all received data groups in the MVXLAN of the specified VPN instance or the public instance.
# Display detailed information about received data groups in the MVXLAN of VPN instance vpna.
<Sysname> display multicast-vpn vxlan vpn-instance vpna data-group receive
VPN instance: vpna
Total 2 data-groups for 8 entries
Total 2 data-groups and 8 entries matched
Data-group: 226.1.1.0  Reference count: 4   Active count: 2
  Sender: 1.1.1.1   Active count: 1
    (192.6.1.5, 239.1.1.1)       Remaining lifetime: 00:03:10 active
    (192.6.1.5, 239.1.1.158)     Remaining lifetime: 00:03:10
  Sender: 181.100.1.1   Active count: 1
    (195.6.1.2, 239.1.2.12)      Remaining lifetime: 00:03:10 active
    (195.6.1.2, 239.1.2.197)     Remaining lifetime: 00:03:10
Data-group: 229.1.1.0   Reference count: 4   Active count: 2
  Sender: 185.100.1.1   Active count: 1
    (198.6.1.5, 239.1.3.62)      Remaining lifetime: 00:03:10 active
    (198.6.1.5, 225.1.1.109)     Remaining lifetime: 00:03:10
  Sender: 190.100.1.1   Active count: 1
    (200.6.1.2, 225.1.4.80)      Remaining lifetime: 00:03:10 active
    (200.6.1.2, 225.1.4.173)     Remaining lifetime: 00:03:10
# Display brief information about received data groups in the MVXLAN of VPN instance vpna.
<Sysname> display multicast-vpn vxlan vpn-instance vpna data-group receive brief
VPN instance: vpna
A total of 2 data groups, associated with 8 (S, G) entries.
A total of 2 matching data groups, associated with 8 (S, G) entries.
Data-group
IP address of the received data group.
Reference count
Number of (S, G) entries that use the data group in the VPN instance.
Active count
Number of active (S, G) entries (entries with active receivers) that use the data group in the VPN instance.
Sender
Address of the VTEP that sent the data group.
Remaining lifetime
Remaining lifetime for the (S, G) entry that uses the data group in the VPN instance.
active
Indicates that the (S, G) entry is active.
display multicast-vpn vxlan data-group send
Use display multicast-vpn vxlan data-group send to display sent data group information in an MVXLAN.
display multicast-vpn vxlan { vpn-instance instance-name | public-instance } data-group send [ group group-address | vpn-source-address [ mask { mask-length | mask } ] | vpn-group-address [ mask { mask-length | mask } ] ] *
vpn-source-address: Specifies a multicast source address of the specified VPN instance. The value range for this argument is 224.0.1.0 to 239.255.255.255.
If you do not specify any parameters, this command displays information about all sent data groups in the MVXLAN of the specified VPN instance or the public instance.
# Display information about all sent data groups in the MVXLAN of VPN instance vpna.
<Sysname> display multicast-vpn vxlan vpn-instance vpna data-group send
VPN instance: vpna
Total 2 data-groups for 6 entries
Total 2 data-groups and 6 entries matched
Data-group: 226.1.1.0   Reference count: 3
  (192.6.1.5, 239.1.1.1)                  Switchover time: 00:00:21
  (192.6.1.5, 239.1.1.158)                Switchover time: 00:00:21
  (192.6.1.5, 239.1.2.50)                 Switchover time: 00:00:05
Data-group: 226.1.1.1   Reference count: 3
  (192.6.1.2, 225.1.1.1)                  Switchover time: 00:00:21
  (192.6.1.2, 225.1.2.50)                 Switchover time: 00:00:05
  (192.6.1.5, 239.1.1.159)                Switchover time: 00:00:21
A total of 2 data groups, associated with 6 (S, G) entries.
A total of 2 matching data groups, associated with 6 (S, G) entries.
Data-group
Data group address.
Reference count
Switchover time
Switchover time of the (S, G) entry that uses the data group in the VPN instance.
display multicast-vpn vxlan default-group
Use display multicast-vpn vxlan default-group to display information about default groups.
display multicast-vpn vxlan [ vpn-instance instance-name | public-instance ] default-group { local | remote }
local: Specifies local default groups.
remote: Specifies remote default groups.
If you do not specify the vpn-instance instance-name option or the public-instance keyword, this command displays default group information for all VPN instances and the public instance.
# Display information about local default groups in all VPN instances and the public instance.
<Sysname> display multicast-vpn vxlan default-group local
MVXLAN local default-group information of VPN instance 50:
 Group address    Source address   Interface
 237.1.0.0        1.1.1.1          MTunnel0
MVXLAN local default-group information of VPN instance vpnc:
 236.0.0.1        1.1.1.1          MTunnel1
MVXLAN local default-group information of VPN instance vpne:
 --               1.1.1.1          MTunnel2
# Display information about remote default groups in all VPN instances and the public instance.
<Sysname> display multicast-vpn vxlan default-group remote
MVXLAN remote default-group information:
 Group address   Source address  Next hop         VPN instance
 239.1.1.1       1.2.0.1         1.2.0.1          a
 239.1.1.1       1.2.0.2         1.2.0.2          a
 239.1.1.1       1.2.0.3         1.2.0.3          a
 239.1.1.2       1.2.0.1         1.2.0.1          b
 239.1.1.2       1.2.0.2         1.2.0.2          b
 239.1.1.3       1.2.0.1         1.2.0.1          c
Group address
IP address of the default group.
Source address
IP address of the MVXLAN source interface.
This field displays two hyphens (--) if no source interface IP address is configured for the MVXLAN.
MVXLAN tunnel outgoing interface.
Next hop
Next hop address.
VPN instance
VPN instance to which the default group belongs.
m-lag local
Use m-lag local to specify the IP addresses of the M-LAG member devices in an M-LAG system.
Use undo m-lag local to restore the default.
m-lag local local-ipv4-address remote remote-ipv4-address
undo m-lag local
The IP addresses of the M-LAG member devices in an M-LAG system are not specified.
local-ipv4-address: Specifies the IPv4 address of the local M-LAG member device.
remote-ipv4-address: Specifies the IPv4 address of the peer M-LAG member device.
Execute this command on the VTEPs or border devices that form an M-LAG system on an MVXLAN network.
When both the peer link and keepalive link go down, an M-LAG member device uses its local IP address as the source address of multicast tunnels. As a best practice, use the public IP address of a loopback interface as the local IP address and make sure downstream devices have Layer 3 connectivity to the local IP address.
The remote IP address is used to identify the SBD-SMET and S-PMSI A-D routes sent by the peer M-LAG member device. Specify an IP address configured on the peer M-LAG member device as the remote IP address.
For an MVXLAN, the following settings are in descending order of priority:
·     The m-lag local setting in MVXLAN address family view. This setting takes effect on a per-MVXLAN basis.
·     The multicast-vpn vxlan m-lag local setting in system view. This setting takes effect on al MVXLANs.
·     The evpn m-lag local setting in system view. This setting takes effect on al MVXLANs.
# Specify the IP addresses of the local and peer M-LAG member devices in the M-LAG system as 2.2.2.2 and 3.3.3.3, respectively.
[Sysname-mvxlan-vpn-instance-vpna-ipv4] m-lag local 2.2.2.2 remote 3.3.3.3
evpn m-lag local
multicast extranet select-rpf
Use multicast extranet select-rpf to configure an IPv4 MVXLAN extranet RPF selection policy.
Use undo multicast extranet select-rpf to delete an IPv4 MVXLAN extranet RPF selection policy.
multicast extranet select-rpf [ l3-vni vxlan-id | vpn-instance vpn-instance-name ] { group group-address { mask | mask-length } | source source-address { mask | mask-length } } *
undo multicast extranet select-rpf [ l3-vni vxlan-id | vpn-instance vpn-instance-name ] { group group-address { mask | mask-length } | source source-address { mask | mask-length } } *
No IPv4 MVXLAN extranet RPF selection policies are configured.
MRIB view
l3-vni vxlan-id: Specifies the L3 VXLAN ID of the VPN instance to which the multicast source belongs. The value range for the vxlan-id argument is 0 to 16777215. If the multicast source belongs to the public network, do not specify this option.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the multicast source belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. The PIM routing entry will select this VPN instance for the upstream RPF neighbor. If the multicast source belongs to the public network, do not specify this option.
group group-address: Specifies a multicast group address in the policy. The address range is 224.0.1.0 to 239.255.255.255. If you do not this option, all multicast traffic that matches the source address in the policy in the source VPN instance will be directed to the receiver VPN instance.
source source-address: Specifies a source address in the policy, which can a multicast source address or the address of the RP designated to multicast groups. If you do not specify this option, all multicast traffic that matches the multicast group in the policy in the source VPN instance will be directed to the receiver VPN instance.
mask-length: Specifies a mask length for the multicast source address or the multicast group address. For a multicast group address, the value range for this argument is 4 to 32. For a multicast source address, the value range for this argument is 0 to 32.
mask: Specifies a subnet mask for the multicast source address or the multicast group address.
MVXLAN extranet RPF routing policies are used for multicast transmission when multicast sources and receivers are located in different VPNs.
MVXLAN extranet RPF selection policies identify the multicast traffic to forward between VPN instances based on the L3 VXLAN ID or VPN instance of traffic.
You cannot specify both an L3 VXLAN ID and an MPLS L3VPN instance for a multicast source address and multicast group address pair.
If the multicast source resides on the public network, do not specify an L3 VXLAN ID or MPLS L3VPN instance.
The PIM mode in the source VPN instance and the receiver VPN instance must be the same. Only PIM-SM and PIM-SSM are supported.
If an MVXLAN extranet RPF selection policy with only the multicast group address specified is configured in the receiver VPN instance, the intra-VPN multicast traffic transmission will be interrupted.
Multicast source addresses in different MVXLAN extranet RPF routing policies cannot be the same, but they can overlap. The same restriction applies to the multicast group addresses in different MVXLAN extranet RPF routing policies. If multiple routing policies exist for an (S, G) entry, the device selects the policy in which the multicast group address has the longest mask. If multiple policies have the same mask length, the device selects the policy in which the multicast source address has the longest mask.
# Configure an IPv4 MVXLAN extranet RPF selection policy to direct multicast traffic from VPN instance vpn-source to VPN instance vpn-receiver.
[Sysname] multicast routing vpn-instance vpn-receiver
[Sysname-mrib-vpn-receiver] multicast extranet select-rpf vpn-instance vpn-source source 192.168.10.0 24
[Sysname-mrib-vpn-receiver] multicast extranet select-rpf vpn-instance vpn-source source 1.1.1.1 24
Use multicast-vpn vxlan dci switch-delay to set the global traffic switchback delay on an ED that provides DCI Layer 3 multicast services.
Use undo multicast-vpn vxlan dci switch-delay to restore the default.
multicast-vpn vxlan dci switch-delay delay-time
The global traffic switchback delay is 10 seconds.
# Set the global traffic switchback delay to 50 seconds in system view.
[Sysname] multicast-vpn vxlan dci switch-delay 50
dci switch-delay
Use multicast-vpn vxlan m-lag local to globally specify the IP addresses of the member devices in an M-LAG system.
Use undo multicast-vpn vxlan m-lag local to restore the default.
multicast-vpn vxlan m-lag local local-ipv4-address remote remote-ipv4-address
The IP addresses of the member devices in an M-LAG system are not specified globally.
local-ipv4-address: Specifies the IPv4 address of the local member device.
remote-ipv4-address: Specifies the IPv4 address of the peer member device.
When you specify the IP addresses of the VTEPs or border devices in an M-LAG system, follow these restrictions and guidelines:
·     IP address of the local member device—Specify the public IP address of a local loopback interface. Make sure the downstream devices have Layer 3 connectivity to this IP address. If both the peer link and keepalive link go down, the local member device will use this IP address to set up multicast tunnels.
·     IP address of the peer member device—Specify an IP address on the peer M-LAG member device. This IP address is used to recognize the SBD-SMET and S-PMSI A-D routes sent by the peer M-LAG member device.
# Specify the IP addresses of the local and peer member devices in an M-LAG system as 2.2.2.2 and 3.3.3.3, respectively.
[Sysname] multicast-vpn vxlan m-lag local 2.2.2.2 remote 3.3.3.3
m-lag local
evpn m-lag local
multicast-vpn vxlan edge remote
Use multicast-vpn vxlan edge remote to specify a peer ED for ED redundancy in the same data center for Layer 3 multicast in DCI multihoming scenarios.
Use undo multicast-vpn vxlan edge remote to remove the peer ED configuration for ED redundancy.
multicast-vpn vxlan edge remote remote-ipv4-address
undo multicast-vpn vxlan edge remote [ remote-ipv4-address ]
No peer ED is specified for ED redundancy in the same data center for Layer 3 multicast in DCI multihoming scenarios.
remote-ipv4-address: Specifies the IPv4 address of a peer ED.
To avoid single point of failure for Layer 3 multicast in DCI scenarios, you can deploy multiple EDs at the edge of a data center. On each ED, specify the IP addresses of the other EDs in the same data center in order to recognize the S-PMSI A-D routes from these EDs. This configuration avoids the local ED from joining the multicast tunnels of the other EDs in the same data center.
Repeat this command to specify the IP addresses of multiple EDs in the same data center.
If you do not specify the remote-ipv4-address argument when executing the undo multicast-vpn vxlan edge remote command, the command removes the IP addresses of all peer EDs from the local ED.
# Specify the peer EDs at 3.3.3.3 and 4.4.4.4 for ED redundancy in the same data center for Layer 3 multicast in DCI multihoming scenarios.
[Sysname] multicast-vpn vxlan edge remote 3.3.3.3
[Sysname] multicast-vpn vxlan edge remote 4.4.4.4
multicast-vpn vxlan public-instance
Use multicast-vpn vxlan public-instance to create an MVXLAN for the public instance and enter its view, or enter the view of the existing public instance MVXLAN.
Use undo multicast-vpn vxlan public-instance to delete the public instance MVXLAN and all settings in public instance MVXLAN view.
multicast-vpn vxlan public-instance mode mdt { ingress-replication | mdt }
No MVXLAN exists in the public instance.
mode: Specifies the MVXLAN mode.
ingress-replication: Sets the mode to ingress replication.
mdt: Sets the mode to MDT.
# Create an MDT-based MVXLAN for the public instance and enter public instance MVXLAN view.
[Sysname] multicast-vpn vxlan public-instance mode mdt
[Sysname—mvxlan-public-instance]
Use multicast-vpn vxlan vpn-instance to create an MVXLAN for a VPN instance and enter its view, or enter the view of an existing VPN instance MVXLAN.
Use undo multicast-vpn vxlan vpn-instance to delete a VPN instance MVXLAN and all settings in its view.
multicast-vpn vxlan vpn-instance instance-name mode { ingress-replication | mdt }
undo multicast-vpn vxlan vpn-instance instance-name
No MVXLAN exists in a VPN instance.
# Create an MDT-based MVXLAN for VPN instance vpna and enter VPN instance MVXLAN view.
[Sysname—mvxlan-vpna]
s-pmsi advertise source-active
Use s-pmsi advertise source-active to enable advertising active multicast sources through S-PMSI routes.
Use undo s-pmsi advertise source-active to restore the default.
The device does not advertise active multicast sources through S-PMSI routes.
This command enables the VTEP to advertise an S-PMSI route for a (S, G) entry after it receives multicast traffic for the entry. The S-PMSI routes carry information about active multicast sources and allow other VTEPs and EDs in the MVXLAN network to be aware of multicast source location changes.
If you execute both the s-pmsi advertise source-active and data-group commands, set the data-delay period to be longer than the frequency of sending the same route update to a peer or peer group. If you fail to do so, BGP might suppress advertisement of the S-PMSI routes for the data group, and traffic will be interrupted during the switchover from the default MDT to the data MDT. To set the data-delay period, use the data-delay command. To set the frequency of sending the same route update to a peer or peer group, use the peer route-update-interval command.
# Enable the device to advertise active multicast sources through S-PMSI routes in MVXLAN IPv4 address family view of VPN instance vpna.
[Sysname-mvxlan-vpn-instance-vpna-ipv4] s-pmsi advertise source-active
peer route-update-interval (Layer 3—IP Routing Command Reference)
source
Use source to specify an MVXLAN source interface.
Use undo source to restore the default.
source interface-type interface-number [ evpn-mlag-group ]
undo source
No MVXLAN source interface is specified.
evpn-mlag-group: Configures the specified interface to provide the virtual IP address for the M-LAG system.
Do not specify the evpn-mlag-group keyword if the device is not an M-LAG member device. For the VTEP to obtain correct routing information, you must specify the interface used for establishing BGP peer relationship as the MVXLAN source interface.
You must specify the evpn-mlag-group keyword if you execute this command on the M-LAG member devices in an M-LAG system. You must assign the same IP address to the MVXLAN source interfaces on them and specify that IP address as the virtual VTEP address. You do not need to use the source interface for establishing BGP peer relationships as the MVXLAN source interface.
In an M-LAG system, each M-LAG member device uses the MVXLAN source interface (virtual IP address of the M-LAG system) to set up multicast MVXLAN tunnels when the M-LAG member devices are operating correctly. When both the peer link and keepalive link go down, each M-LAG member device uses the local IP address specified by using the m-lag local command to set up multicast MVXLAN tunnels.
# In MVXLAN IPv4 address family view of VPN instance vpna, specify Loopback 0 as the MVXLAN source interface. (Loopback 0 is the source interface used for establishing BGP peer relationship.)
[Sysname-mvxlan-vpn-instance-vpna-ipv4] source loopback 0
