04-MPLS TE commands | 370.75 KB |
display isis mpls te advertisement
display isis mpls te configured-sub-tlvs
display mpls te link-management bandwidth-allocation
display mpls te pce statistics
display mpls te tunnel-interface
display ospf mpls te advertisement
link-management periodic-flooding timer
mpls te auto-tunnel backup disable
mpls te bandwidth change thresholds
mpls te enable (interface view)
mpls te enable (OSPF area view)
mpls te fast-reroute bypass-tunnel
mpls te max-reservable-bandwidth
mpls te max-reservable-bandwidth mam
mpls te max-reservable-bandwidth rdm
mpls te reoptimization (tunnel interface view)
mpls te reoptimization (user view)
MPLS TE commands
auto-tunnel backup
Use auto-tunnel backup to enable the automatic bypass tunnel setup feature (also called auto FRR) globally, and enter MPLS TE auto FRR view.
Use undo auto-tunnel backup to disable the auto FRR feature globally.
auto-tunnel backup
The auto FRR feature is disabled globally.
MPLS TE view
This feature enables the device to automatically set up two bypass tunnels for each primary CRLSP: one for link protection and the other for node protection. For the tunnels to be set up, you must also use the tunnel-number command to specify a tunnel interface number range.
Execution of the undo auto-tunnel backup command deletes all existing bypass tunnels automatically created for MPLS TE auto FRR.
If the PLR is the penultimate node of a primary CRLSP, the PLR does not create a node-protection bypass tunnel for the primary CRLSP.
# Enable the automatic bypass tunnel setup feature globally, and enter MPLS TE auto FRR view.
[Sysname] mpls te
[Sysname-te] auto-tunnel backup
[Sysname-te-auto-bk]
nhop-only
timers removal unused
tunnel-number
disable (explicit path view)
Use disable to disable an explicit path.
Use undo disable to restore the default.
disable
undo disable
The explicit path is enabled.
Explicit path view
You can use the disable command to prevent an explicit path from being used by a tunnel during explicit path configuration.
# Disable explicit path path1.
[Sysname] explicit-path path1
[Sysname-explicit-path-path1] disable
display explicit-path
Use display explicit-path to display explicit path information.
display explicit-path [ path-name ]
path-name: Displays information about the explicit path specified by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this argument, the command displays information about all explicit paths.
# Display information about all explicit paths.
<Sysname> display explicit-path
Path Name: path1 Hop Count: 3 Path Status: Enabled
Index IP Address/SID Hop Type Hop Attribute/SID Type
1 1.1.1.1 Strict Include
101 2.2.2.2 Loose Include
201 3.3.3.3 - Exclude
Path Name |
Name of the explicit path. |
Hop Count |
Number of nodes specified in the explicit path. |
Path Status |
Explicit path status: · Enabled—The explicit path is available. · Disabled—The explicit path is not available. |
Index |
Index of a node on the explicit path. |
IP Address/SID |
IP address or SID of a node on the explicit path. |
Hop Type |
Node type: · Strict—The node must be connected directly to its previous hop. · Loose—The node can be connected indirectly to its previous hop. |
Hop Attribute/SID Type |
Node attribute or SID type: · Include—The node must be included in the explicit path. · Exclude—The node must not be included in the explicit path. · Adjacency—The node is an adjacency SID node. · Prefix—The node is a prefix SID node. |
Use display isis mpls te advertisement to display link and node information in an IS-IS TEDB.
display isis mpls te advertisement [ [ level-1 | level-2 ] | [ originate-system system-id | local ] | verbose ] * [ process-id ]
level-1: Displays link and node information for Level-1 routers.
level-2: Displays link and node information for Level-2 routers.
originate-system system-id: Displays link and node information advertised by the system specified by its system ID, in the format of XXXX.XXXX.XXXX.
local: Displays link and node information advertised by the local device.
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief information.
process-id: Specifies an IS-IS process by its ID in the range of 1 to 65535. If you do not specify an IS-IS process, this command displays link and node information for all IS-IS processes.
If you do not specify the level-1 or level-2 keyword, this command displays link and node information for both Level-1 and Level-2 routers.
If you do not specify the originate-system system-id option or the local keyword, this command displays link and node information advertised by all systems.
# Display brief link and node information in the IS-IS TEDB for Level-1 routers.
<Sysname> display isis mpls te advertisement level-1
TE information for IS-IS(1)
Level-1 TE node and link information
Node total count : 2
Node index : 0
System ID : 0000.0000.0004
MPLS LSR ID : 4.4.4.4
Node flags : -/-/R/-
Link total count : 1
Link information :
Neighbour Frag ID Link Type Local Address Remote Address
0000.0000.0004.04 0x00 Broadcast 1.1.1.3 --
Node index : 1
System ID : 0000.0000.0001
MPLS LSR ID : 1.1.1.1
Link information :
0000.0000.0004.04 0x00 Broadcast 1.1.1.1 --
# Display detailed link and node information in the IS-IS TEDB for Level-1 routers.
<Sysname> display isis mpls te advertisement level-1 local verbose
Node index : 0
Link information :
Link index : 0
Neighbor : 0000.0000.0004.04 Frag ID : 0x00
Link type : Broadcast Admin group : 0x00000000
IGP metric : 10 TE metric : 10
Link flags : -/-/-
Physical bandwidth: 12500000 bytes/sec
Reservable bandwidth: 0 bytes/sec
Unreserved bandwidth for each TE class:
TE class 0: 0 bytes/sec TE class 1: 0 bytes/sec
TE class 2: 0 bytes/sec TE class 3: 0 bytes/sec
TE class 4: 0 bytes/sec TE class 5: 0 bytes/sec
TE class 6: 0 bytes/sec TE class 7: 0 bytes/sec
TE class 8: 0 bytes/sec TE class 9: 0 bytes/sec
TE class 10: 0 bytes/sec TE class 11: 0 bytes/sec
TE class 12: 0 bytes/sec TE class 13: 0 bytes/sec
TE class 14: 0 bytes/sec TE class 15: 0 bytes/sec
Bandwidth constraint model: Prestandard DS-TE RDM
Bandwidth constraints:
BC[00]: 0 bytes/sec BC[01]: 0 bytes/sec
Local address: 1.1.1.3
Node index : 1
Node flags : -/-/-/-
Link information :
Link index : 0
IGP metric: 10 TE metric : 10
Link flags: -/-/-
Local address: 1.1.1.1
TE information for IS-IS(1) |
TE information for IS-IS process 1. |
Node total count |
Total number of nodes that advertised TE information. |
Node flags |
Node information flags: · A—Already synchronized node information with CSPF. · S—Ready to synchronize node information with CSPF again after the previous synchronization failed. · R—The node is reachable. · O—The node is overloaded. |
Link total count |
Total number of links advertised by the node. |
Link information |
Link information advertised by the node. |
Neighbor |
System ID of the neighbor. |
Frag ID |
LSP fragment number. |
Link type |
Link type: Broadcast or P2P. |
Admin group |
Administrator group attribute of the link. |
Link flags |
Link information flags: · A—Already synchronized link information with CSPF. · U—Ready to update link information with CSPF again after the previous update failed. · D—Ready to delete link information from CSPF again after the previous deletion failed. |
Bandwidth constraint model |
Bandwidth constraint model: · Prestandard DS-TE RDM. · IETF DS-TE RDM. · IETF DS-TE MAM. |
Local address |
Local IP address of the link. |
Remote address |
Remote IP address of the link. |
Use display isis mpls te configured-sub-tlvs to display sub-TLV information for IS-IS TE.
display isis mpls te configured-sub-tlvs [ process-id ]
process-id: Specifies an IS-IS process by its ID in the range of 1 to 65535. If you do not specify an IS-IS process, this command displays sub-TLV information for all IS-IS processes.
# Display sub-TLV information for IS-IS TE.
<Sysname> display isis mpls te configured-sub-tlvs
TE sub-TLV information for IS-IS(1)
Type value of the unreserved sub-pool bandwidth sub-TLV : 251
Type value of the bandwidth constraint sub-TLV : 252
TE Sub-TLV Information for IS-IS(1) |
DS-TE sub-TLV information for IS-IS process 1. |
display isis mpls te network
Use display isis mpls te network to display network information in an IS-IS TEDB.
display isis mpls te network [ [ level-1 | level-2 ] | local | lsp-id lsp-id ] * [ process-id ]
level-1: Displays network information for Level-1 routers.
level-2: Displays network information for Level-2 routers.
local: Displays network information advertised by the local device.
lsp-id lsp-id: Displays network information for an LSP. The lsp-id argument is the LSP ID in the format of SYSID.Pseudonode ID-fragment num. SYSID represents the system ID of the node or pseudonode that generates the LSP. Pseudonode ID represents ID of the pseudonode. fragment num represents the fragment number of the LSP.
process-id: Specifies an IS-IS process by its ID in the range of 1 to 65535. If you do not specify an IS-IS process, this command displays network information for all IS-IS processes.
If you do not specify the level-1 or level-2 keyword, this command displays network information for both Level-1 and Level-2 routers.
If you do not specify the local keyword or the lsp-id lsp-id option, this command displays all TE network information.
# Display network information in IS-IS TEDBs.
<Sysname> display isis mpls te network
Level-1 network information
LAN ID : 0000.0000.0004.04
Frag ID : 0x00
Flags : -/-/-
Attached routers : 0000.0000.0001
0000.0000.0004
Level-2 network information
Frag ID : 0x00
Flags : -/-/-
0000.0000.0004
LAN ID |
Broadcast network ID, in the format of System-ID.Pseudonode-ID. |
Frag ID |
Flags |
State flag for network information: · A—Already synchronizes network information with CSPF. · U—Ready to update network information with CSPF again after the previous update failed. · D—Ready to delete network information from CSPF again after the previous deletion failed. |
display isis mpls te tunnel
Use display isis mpls te tunnel to display MPLS TE tunnel interface information for IS-IS.
display isis mpls te tunnel [ level-1 | level-2 ] [ process-id ]
level-1: Displays tunnel interface information for Level-1 routers.
level-2: Displays tunnel interface information for Level-2 routers.
process-id: Specifies an IS-IS process by its ID in the range of 1 to 65535. If you do not specify an IS-IS process, this command displays tunnel information for all IS-IS processes.
If you do not specify the level-1 or level-2 keyword, this command displays IS-IS tunnel interface information for both IS-IS Level-1 and IS-IS Level-2 routers.
# Display MPLS TE tunnel interface information for IS-IS.
<Sysname> display isis mpls te tunnel
MPLS-TE tunnel information for IS-IS(1)
Level-1 Tunnel Statistics
Tunnel Name Auto Route Destination Metric
Tun0 Advertise 2.2.2.2 Relative 0
Level-2 Tunnel Statistics
Table 5 Command output
MPLS-TE tunnel information for IS-IS(1) |
MPLS TE tunnel interface information for IS-IS process 1. |
Auto Route |
Automatic route advertisement method on the tunnel interface: · Advertise—Forwarding adjacency. · Shortcut—IGP shortcut. |
Destination |
Tunnel destination address. |
Metric |
Metric type and value configured on the tunnel interface: · Relative. · Absolute. |
Use display mpls te link-management bandwidth-allocation to display bandwidth information on MPLS TE-enabled interfaces.
display mpls te link-management bandwidth-allocation [ interface interface-type interface-number ]
interface interface-type interface-number: Displays bandwidth information on the interface specified by its type and number. If you do not specify this option, the command displays bandwidth information on all MPLS TE-enabled interfaces.
# Display bandwidth information on all MPLS TE-enabled interfaces.
<Sysname> display mpls te link-management bandwidth-allocation
Interface: Vlan-interface10
Max Link Bandwidth : 3200000 kbps
Max Reservable Bandwidth of Prestandard RDM : 2000000 kbps
Max Reservable Bandwidth of IETF RDM : 200000 kbps
Max Reservable Bandwidth of IETF MAM : 300000 kbps
Allocated Bandwidth-Item Count : 1
Allocated Bandwidth : 1000 kbps
Physical Link Status : Up
BC Prestandard RDM(kbps) IETF RDM(kbps) IETF MAM(kbps)
0 2000000 200000 2000
1 1000000 150000 2000
2 0 100000 2000
3 0 50000 2000
TE Class Class Type Priority BW Reserved(kbps) BW Available(kbps)
0 0 0 0 2000000
1 0 1 0 2000000
2 0 2 0 2000000
3 0 3 0 2000000
4 0 4 0 2000000
5 0 5 0 2000000
6 0 6 0 2000000
7 0 7 1000 1999000
8 1 0 0 1000000
9 1 1 0 1000000
10 1 2 0 1000000
11 1 3 0 1000000
12 1 4 0 1000000
13 1 5 0 1000000
14 1 6 0 1000000
15 1 7 0 1000000
Table 6 Command output
Interface enabled with MPLS TE. |
Max Link Bandwidth |
Maximum link bandwidth for MPLS TE traffic. |
Allocated Bandwidth-Item Count |
Number of CRLSPs that have successfully obtained bandwidth. |
mpls te max-link-bandwidth
display mpls te pce discovery
Use display mpls te pce discovery to display information about discovered PCEs.
display mpls te pce discovery [ ip-address ] [ verbose ]
ip-address: Specifies a PCE by its IP address. If you do not specify this argument, the command displays information about all discovered PCEs.
# Display brief information about PCE 100.100.100.150.
<Sysname> display mpls te pce discovery 100.100.100.150
Total number of PCEs: 1
Peer address Discovery methods
100.100.100.150 Static, OSPF
# Display brief information about all discovered PCEs.
Total number of PCEs: 3
100.100.100.10 OSPF
100.100.100.160 Static
Table 7 Command output
Peer address |
IP address of the PCE. |
Discovery methods |
PCE discovery methods: · Static—The PCE is specified by command. · OSPF—The PCE is discovered automatically by OSPF. |
# Display detailed information about PCE 2.2.2.9.
<Sysname> display mpls te pce discovery 2.2.2.9 verbose
PCE address: 2.2.2.9
Discovery methods: OSPF
Path scopes:
Path scope Preference
Compute intra-area paths 7
Act as PCE for inter-area TE LSP computation 6
Act as a default PCE for inter-area TE LSP computation 6
Capabilities:
Bidirectional path computation
Support for request prioritization
Support for multiple requests per message
Domains:
OSPF 1 area 0.0.0.0
OSPF 1 area 0.0.0.1
# Display detailed information about all discovered PCEs.
<Sysname> display mpls te pce discovery verbose
Path scopes:
Capabilities:
Domains:
OSPF 1 area 0.0.0.0
OSPF 1 area 0.0.0.1
PCE address: 4.4.4.9
Path scopes:
Capabilities:
Domains:
OSPF 1 area 0.0.0.2
Neighbor domains:
OSPF 1 area 0.0.0.0
Table 8 Command output
Discovery methods |
Path scope |
Scope of PCE path computation: · Compute intra-area paths. · Act as PCE for inter-area TE LSP computation. · Act as a default PCE for inter-area TE LSP computation. · Act as PCE for inter-AS TE LSP. · Act as a default PCE for inter-AS TE LSP. · Act as PCE for inter-layer TE LSP. |
Preference |
Preference of the PCE path scope, in the range of 0 to 7. A higher value represents a higher priority. |
Capabilities |
PCE capability: · Path computation with GMPLS link constraints. · Bidirectional path computation. · Diverse path computation. · Load-balanced path computation. · Synchronized path computation. · Support for multiple objective functions. · Support for additive path constraints. · Support for request prioritization. · Support for multiple requests per message. |
display mpls te pce peer
Use display mpls te pce peer to display PCC and PCE peer information.
display mpls te pce peer [ ip-address ] [ verbose ]
ip-address: Specifies a peer by its IP address. If you do not specify this argument, the command displays information about all peers.
This command displays information about peers that are establishing or have established PCEP sessions to the local device.
# Display brief information about all peers.
<Sysname> display mpls te pce peer
Total number of peers: 1
Peer address Peer type State Mastership Role
100.100.100.100 PCE UP Normal Active
Table 9 Command output
Peer type |
Peer type, PCC or PCE. |
State |
PCEP session state: · Idle—Initial state. · TCPPending—Waiting for the TCP connection to be set up. · OpenWait—Waiting for an Open message from the peer. · KeepWait—Waiting for a Keepalive message from the peer. · UP—The PCEP session is established. |
Mastership |
Peer role: · Normal—Normal PCC or PCE. · Primary—Primary PCE to which the CRLSP is delegated. This role is not supported in the current software version. · Backup—Backup PCE to which the CRLSP is delegated. This role is not supported in the current software version. |
Role |
Role of the local device in the PCEP session: · Active—Initiator of the PCEP session. · Passive—Responder of the PCEP session. |
# Display detailed information about all peers.
<Sysname> display mpls te pce peer verbose
Peer address: 100.100.100.20
TCP Connection : 100.100.100.20:5696 -> 100.100.100.10:4189
Peer type : PCC
Session type : Active stateful
Session state : UP
Mastership : Normal
Role : active
Session up time : 0000 days 01 hours 03 minutes
Session ID : Local 1, Peer 1
Keepalive interval : Local 0 sec, Peer 0 sec
Recommended DeadTimer : Local 0 sec, Peer 0 sec
Tolerance:
Min keepalive interval: 10 sec
Max unknown messages : 10
Request timeout : 50 sec
Delegation timeout : 30 sec
Table 10 Command output
Peer type |
Peer type: PCC or PCE. |
Session type |
PCEP session type: · Stateless. · Passive stateful. This type is not supported in the current software version. · Active stateful. This type is not supported in the current software version. |
Session state |
Mastership |
Role |
Min keepalive interval |
Minimum acceptable keepalive interval in seconds. |
Max unknown messages |
Maximum number of unknown messages allowed in one minute. |
Request timeout |
Request timeout time in seconds. |
Delegation timeout |
This field is not supported in the current software version. Delegation timeout time in seconds. |
Use display mpls te pce statistics to display PCC and PCE statistics.
display mpls te pce statistics [ ip-address ]
ip-address: Specifies a PCC or PCE by its IP address. If you do not specify this argument, the command displays statistics about all PCEs and PCCs.
# Display statistics about all PCCs and PCEs.
<Sysname> display mpls te pce statistics
Keepalive messages sent/received : 70/75
Open messages sent/received : 1/1
PCReq messages sent/received : 0/0
PCRep messages sent/received : 0/0
PCErr messages sent/received : 0/0
PCNtf messages sent/received : 0/0
Session setup failures : 0
Unknown messages received : 0
Unknown requests received : 0
Unknown responses received : 0
Requests sent : 0
Response is pending : 0
Response with ERO received : 0
Response with NO-PATH received : 0
Canceled by peer sending a PCNtf : 0
Canceled by peer sending a PCErr : 0
Canceled by local speaker sending a PCNtf: 0
Implicitly canceled (session down) : 0
Timeout : 0
Requests received : 0
Response with ERO sent : 0
Response with NO-PATH sent : 0
Canceled by local speaker sending a PCErr: 0
Table 11 Command output
Unknown requests received |
Number of unknown requests (the request ID carried in the RP object is 0) received. |
Unknown responses received |
Number of unknown responses (the request ID in the response does not match the one in the request) received. |
Requests sent |
Total number of sent requests. |
Response is pending |
Number of requests that are waiting for responses. |
Response with ERO received |
Number of requests that have received responses with ERO. |
Response with NO-PATH received |
Number of requests that have received responses with NO-PATH. |
Cancelled by peer sending a PCNtf |
Number of requests canceled byPCNtf messages sent by the peer. |
Canceled by peer sending a PCErr |
Number of requests canceled byPCErr messages sent by the peer. |
Canceled by local speaker sending a PCNtf |
Number of requests canceled by PCNtf messages sent by the local device. |
Implicitly canceled(session down) |
Number of requests that became invalid because the PCEP session was down. |
Timeout |
Number of requests that became invalid because of request timeout. |
Requests received |
Total number of received requests. |
Number of requests whose responses are not sent yet. |
Response with ERO sent |
Number of responses sent with ERO. |
Response with NO-PATH sent |
Number of responses sent with NO-PATH. |
Number of PCNtf messages for request cancellation sent by the local device. |
Canceled by local speaker sending a PCErr |
Number of PCErr messages for request cancellation sent by the local device. |
Canceled by peer sending a PCNtf |
Number of PCNtf messages for request cancellation sent by the peer. |
display mpls te tedb
Use display mpls te tedb to display MPLS TE database (TEDB) information.
display mpls te tedb { { isis { level-1 | level-2 } | ospf area area-id } | link ip-address | network | node [ local | mpls-lsr-id ] | summary }
isis: Displays TEDB information for IS-IS.
level-1: Displays TEDB information for Level-1 routers.
level-2: Displays TEDB information for Level-2 routers.
ospf area area-id: Displays TEDB information for an OSPF area. The value range for the OSPF area ID is 0 to 4294967295.
link ip-address: Displays TEDB information for a link. The ip-address argument represents the IP address of the local interface on the link.
network: Displays TEDB information for all broadcast and NBMA networks.
node: Displays TEDB information for the local or specified node. If you do not specify the local keyword or the mpls-lsr-id argument, this command displays TEDB information for all nodes.
local: Displays TEDB information for the local node.
mpls-lsr-id: Displays TEDB information for the node specified by its MPLS LSR ID.
summary: Displays summary TEDB information.
# Display TEDB information for all broadcast and NBMA networks.
<Sysname> display mpls te tedb network
DR MPLS LSR-ID DR-address IGP Process-ID Area/Level Neighbors
8.1.1.2 3.0.0.2 OSPF 100 0 1.1.1.1
2.1.1.1
8.1.1.2
2.1.1.1 3.0.0.3 OSPF 100 0 2.1.1.1
3.1.1.1
2.1.1.2
3.1.1.2 3.0.0.4 OSPF 100 0 3.1.1.1
4.1.1.1
3.1.1.2
4.1.1.2 3.0.0.5 OSPF 100 0 4.1.1.1
5.1.1.1
4.1.1.2
5.1.1.2 3.0.0.6 OSPF 100 0 5.1.1.1
6.1.1.1
5.1.1.2
6.1.1.2 3.0.0.9 OSPF 100 0 6.1.1.1
7.1.1.1
6.1.1.2
7.1.1.1 12.0.0.7 OSPF 100 0 3.1.1.1
7.1.1.1
7.1.1.2
Table 12 Command output
DR MPLS LSR-ID |
MPLS LSR ID of a designated router (DR), in dotted decimal notation. |
DR-address |
Interface address of the DR. |
IGP |
Internal gateway protocol: OSPF or IS-IS. |
Process-ID |
IGP process ID. |
Area/Level |
OSPF area or IS-IS level of the router. |
Neighbors |
Router IDs of the routers that have formed full adjacencies with the DR, and router ID of the DR itself. |
# Display summary TEDB information.
<Sysname> display mpls te tedb summary
MPLS LSR-ID IGP Process-ID Area/Level Links-Count
1.1.1.1 OSPF 100 1001 20
1002 30
1003 40
1004 50
1007 70
1010 80
2.1.1.1 ISIS 100 Level-1 20
Level-1 30
3.1.1.1 OSPF 100 0 4
Table 13 Command output
MPLS LSR-ID |
MPLS LSR ID of a router, in dotted decimal notation. |
IGP |
Process-ID |
IGP process ID. |
Area/Level |
Links-Count |
Number of links in an OSPF area or IS-IS level. |
# Display TEDB information for an OSPF area.
<Sysname> display mpls te tedb ospf area 1
Node information for OSPF area 1:
MPLS LSR-ID IGP Process-ID Area Links-Count
2.2.2.2 OSPF 100 1 1
3.3.3.3 OSPF 100 1 1
Network information for OSPF area 1:
DR MPLS LSR-ID DR-address IGP Process-ID Area Neighbors
3.3.3.3 20.1.1.2 OSPF 100 1 2.2.2.2
3.3.3.3
Table 14 Command output
MPLS LSR-ID |
IGP |
Process-ID |
IGP process ID. |
Area |
OSPF area of the router. |
Links-Count |
Number of links in the OSPF area or IS-IS level. |
DR MPLS LSR-ID |
MPLS LSR ID of a DR. |
DR-address |
Neighbors |
Use display mpls te tunnel-interface to display information about MPLS TE tunnel interfaces.
display mpls te tunnel-interface [ tunnel number ]
tunnel number: Displays information about the tunnel interface specified by its number. The interface must have been created. If you do not specify this option, the command displays information about all MPLS TE tunnel interfaces.
# Display information about all MPLS TE tunnel interfaces.
<Sysname> display mpls te tunnel-interface
Tunnel Name : Tunnel 1
Tunnel State : Up (Main CRLSP up)
Tunnel Attributes :
LSP ID : 1 Tunnel ID : 1
Admin State : Normal
Ingress LSR ID : 1.1.1.1 Egress LSR ID : 3.3.3.3
Signaling : Static Static CRLSP Name : static-cr-lsp-1
Static SRLSP Name : -/-
Resv Style : -
Tunnel mode : -
Reverse-LSP name : -
Class Type : - Tunnel Bandwidth : -
Reserved Bandwidth : -
Setup Priority : 0 Holding Priority : 0
Affinity Attr/Mask : -/-
Explicit Path : -
Backup Explicit Path : -
Metric Type : TE
Record Route : - Record Label : -
FRR Flag : - Bandwidth Protection : Disabled
Backup Bandwidth Flag: Disabled Backup Bandwidth Type: -
Backup Bandwidth : -
Bypass Tunnel : No Auto Created : No
Route Pinning : -
Retry Limit : 10 Retry Interval : 2 sec
Reoptimization : - Reoptimization Freq : -
Backup Type : - Backup LSP ID : -
Auto Bandwidth : Disabled Auto Bandwidth Freq : -
Collected Bandwidth : - Service Class : -
Path Setup Type : -/-
Table 15 Command output
Tunnel Name |
Name of the tunnel interface. |
Tunnel State |
Running state of the tunnel: Down or Up, followed by a brief description of the state in parentheses. The description information includes: · Main CRLSP down. · Main CRLSP up. · Main CRLSP being set up. · Shared-resource CRLSP down. · Shared-resource CRLSP up. · Shared-resource CRLSP being set up. · Shared-resource CRLSP being activated. · Shared-resource CRLSP switching to Main CRLSP. · Backup CRLSP down. · Backup CRLSP up. · Backup CRLSP being set up. · Reverse CRLSP down. · Reverse CRLSP up. · Reverse CRLSP being set up. |
Admin State |
Administrative state of the tunnel interface: · Normal—The interface is not shut down by the shutdown command. · Shutdown—The tunnel interface is shut down by the shutdown command. |
Signaling |
Signaling protocol used to set up the tunnel: RSVP-TE or Static. |
Static CRLSP Name |
Static CRLSP used by the tunnel. |
Static SRLSP Name |
This field is not supported in the current software version. Static SRLSPs used by the tunnel, which are displayed as main static SRLSP name/backup static SRLSP name. This field displays a hyphen (-) for a main or backup static SRLSP if the tunnel does not use the static SRLSP. |
Resv Style |
Resource reservation style used by the tunnel. This field displays FF or SE for an MPLS TE tunnel that uses dynamic CRLSPs, and displays a hyphen (-) for an MPLS TE tunnel that uses static CRLSPs. |
Tunnel Mode |
Tunnel mode of the bidirectional tunnel: · Co-routed, active—The device is the active end of the co-routed bidirectional tunnel. · Co-routed, passive—The device is the passive end of the co-routed bidirectional tunnel. · Associated—The tunnel is an associated bidirectional tunnel. |
Reverse-LSP Name |
Name of the reverse LSP associated with the tunnel. |
Reverse-LSP LSR ID |
LSR ID of the ingress node on the reverse LSP. This field has a value for an associated bidirectional tunnel and for the passive end of a co-routed bidirectional tunnel. In other conditions, this field displays a hyphen (-). |
Reverse-LSP Tunnel ID |
Tunnel ID of the reverse LSP. This field has a value for an associated bidirectional tunnel and for the passive end of a co-routed bidirectional tunnel. In other conditions, this field displays a hyphen (-). |
Class Type |
CT of the tunnel: CT0, CT1, CT2, or CT3. |
Tunnel Bandwidth |
Bandwidth required by the tunnel, in kbps. |
Reserved Bandwidth |
Bandwidth reserved for the tunnel, in kbps. |
Setup Priority |
Tunnel setup priority. |
Holding Priority |
Tunnel holding priority. |
Affinity Attr/Mask |
Tunnel affinity attribute and mask. |
Explicit Path Name |
Name of the explicit path used by the tunnel. If the path used by the tunnel is not an explicit path, this field displays a hyphen (-). |
Backup Explicit Path |
Name of the explicit path used by the backup tunnel. If the path used by the backup tunnel is not an explicit path, this field displays a hyphen (-). |
Metric Type |
Link metric type used for tunnel path selection, TE or IGP. |
Bandwidth Protection |
Whether FRR needs bandwidth protection: Enabled or Disabled. |
Backup Bandwidth Flag |
Whether the bandwidth and the type of CRLSPs that the bypass tunnel can protect have been configured (by using the mpls te backup bandwidth command): · Enabled—Configured. · Disabled—Not configured. |
Backup Bandwidth Type |
Class type of the traffic on the primary tunnel that the bypass tunnel can protect, which can be CT0, CT1, CT2, CT3, or All Class Type. All Class Type means that the bypass tunnel can protect all class types. If no CT is configured, this field displays a hyphen (-). |
Backup Bandwidth |
Bandwidth that the bypass tunnel can protect, in kbps. If the protection bandwidth is unlimited, this field displays Unlimited. If no protection bandwidth is configured, this field displays a hyphen (-). |
Bypass Tunnel |
Whether it is a bypass tunnel: Yes or No. |
Auto Created |
Whether the bypass tunnel is automatically created: Yes or No. |
Retry Limit |
Maximum number of tunnel setup retries. |
Retry Interval |
Tunnel setup retry interval, in seconds. |
Reoptimization Freq |
Tunnel reoptimization frequency, in seconds. |
Backup Type |
CRLSP backup mode: · None—CRLSP backup is disabled. · Hot Standby. · Ordinary. |
Backup LSP ID |
LSP ID of the backup tunnel. |
Auto Bandwidth |
This field is not supported in the current software version. State of the automatic bandwidth adjustment feature. |
Auto Bandwidth Freq |
This field is not supported in the current software version. Automatic bandwidth adjustment interval, in seconds. |
Min Bandwidth |
This field is not supported in the current software version. Minimum bandwidth (in kbps) that can be applied to the tunnel by automatic bandwidth adjustment. |
Max Bandwidth |
This field is not supported in the current software version. Maximum bandwidth (in kbps) that can be applied to the tunnel by automatic bandwidth adjustment. |
Collected Bandwidth |
This field is not supported in the current software version. Current output rate, in kbps. |
Service Class |
This field is not supported in the current software version. Service class value of the tunnel. If no service class value is set for the tunnel, this field displays a hyphen (-). |
Path Setup Type |
This field is not supported in the current software version. Primary SRLSP path computation type/backup SRLSP path computation type. The following path computation types are available: · EXPLICIT—Explicit path. · CSPF—Constraint-based Shortest Path First. · PCE—Path Computation Element. |
Use display ospf mpls te advertisement to display link and node information in an OSPF TEDB.
display ospf [ process-id ] [ area area-id ] mpls te advertisement [ originate-router advertising-router-id | self-originate ]
process-id: Specifies an OSPF process ID in the range of 1 to 65535. If you do not specify this argument, the command displays information about all OSPF processes.
area area-id: Specifies an area by its ID, an IP address or a decimal integer. The integer is in the range of 0 to 4294967295. If you specify an integer, the system will translate the integer into the IP address format. If you do not specify this option, the command displays information about all areas.
originate-router advertising-router-id: Displays information originated from a router specified by its router ID.
self-originate: Displays information generated by the local router.
# Display link and node information for all processes in all areas.
<Sysname> display ospf mpls te advertisement
Traffic Engineering Database
Area: 0.0.0.1
Adv Router ID : 1.1.1.1
Flags : A/S/R
Router Address Count : 1
Router Address Index : 0
Instance ID : 0.0.0.0
Link Count : 1
Link Index : 0
Link Type : Broadcast
Instance ID : 0.0.0.1
Link Flags : -/U/-
Link ID : 197.168.1.1
TE Metric : 1000
IGP Metric : 1000
Maximum Bandwidth : 12500000 bytes/sec
Maximum Reservable BW : 0 bytes/sec
Administrative Group : 0x0
Unreserved Bandwidth for each TE Class:
TE class 0 = 0 bytes/sec
TE class 1 = 0 bytes/sec
TE class 2 = 0 bytes/sec
TE class 3 = 0 bytes/sec
TE class 4 = 0 bytes/sec
TE class 5 = 0 bytes/sec
TE class 6 = 0 bytes/sec
TE class 7 = 0 bytes/sec
TE class 8 = 0 bytes/sec
TE class 9 = 0 bytes/sec
TE class 10 = 0 bytes/sec
TE class 11 = 0 bytes/sec
TE class 12 = 0 bytes/sec
TE class 13 = 0 bytes/sec
TE class 14 = 0 bytes/sec
TE class 15 = 0 bytes/sec
Bandwidth Constraint Model: Prestandard DS-TE RDM
Bandwidth Constraints:
BC [ 0] = 0 bytes/sec
BC [ 1] = 0 bytes/sec
Local Interface Address : 197.168.1.1
Remote Interface Address : 197.168.1.11
Table 16 Command output
Adv Router ID |
ID of the router that advertised TE information. |
MPLS LSR ID |
MPLS LSR ID of the router that advertised TE information. |
Flags |
TE information flags: · A—Already synchronized information with CSPF. · S—Ready to synchronize information with CSPF. · R—The router that advertised information is reachable. |
Router Address Count |
Number of Router TLV messages in TEDB. |
Router Address Index |
Index of the current Router TLV message. |
Instance ID |
LSA instance ID. |
Link Count |
Number of Link TLV messages in TEDB. |
Link Index |
Index of the current Link TLV message. |
Link Type |
Link types: · Point to Point. · Point to Multi Point. · Broadcast. · NBMA. |
Link Flags |
Link information flags: · A—Already synchronized information with CSPF. · U—Ready to update information with CSPF again after the previous update failed. · D—Ready to delete information from CSPF again after the previous deletion failed. |
Link ID |
Link state ID. |
IGP Metric |
OSPF protocol metric. |
Administrative Group |
Link attributes. |
Bandwidth Constraint Model |
Bandwidth constraint model: Prestandard DS-TE RDM, IETF DS-TE RDM, or IETF DS-TE MAM. |
Bandwidth Constraints |
This field takes effect only on DS-TEs. |
BC |
Bandwidth constraint value. The Prestandard mode supports two BCs, and the IETF mode supports four BCs. |
display ospf mpls te network
Use display ospf mpls te network to display network information in an OSPF TEDB.
display ospf [ process-id ] [ area area-id ] mpls te network [ originate-router advertising-router-id | self-originate ]
area area-id: Specifies an area by its ID, an IP address or a decimal integer, in the range of 0 to 4294967295. If you specify an integer, the system will translate the integer into the IP address format. If you do not specify this option, the command displays information about all areas.
# Display network information for all processes in all areas.
<Sysname> display ospf mpls te network
OSPF Process 1 with Router ID 12.1.1.1
Traffic Engineering Network
Area: 0.0.0.0
Designated Router : 197.168.1.1
Flags : -/U/-
Attached router 2.2.2.2
Attached router 1.1.1.1
Table 17 Command output
Adv Router ID |
ID of the router that advertised the TE network information. |
Designated Router |
IP address of the designated router. |
Flag |
Network information flags: · A—Already synchronized information with CSPF. · U—Ready to update information with CSPF again after the previous update failed. · D—Ready to delete information from CSPF again after the previous deletion failed. |
Attached router |
Router ID of the attached router. |
display ospf mpls te pce
Use display ospf mpls te pce to display information about PCEs discovered by OSPF.
display ospf [ process-id ] [ area area-id ] mpls te pce [ originate-router advertising-router-id | self-originate ]
# Display PCE information for all processes in all areas.
<Sysname> display ospf mpls te pce
OSPF Process 1 with Router ID 2.1.1.1
Area: 0.0.0.1
Adv Router ID : 2.1.1.1
PCE Address : 5.6.7.8
Flags : A/-/R/E
PCE Path Scopes:
Path Scope Preference
L (PCE for intra-area) 7
R (PCE for inter-area) 6
PCE Capabilities:
PCE Domain List:
Area 0.0.0.1
Area 0.0.0.3
PCE Neighbor Domain List:
Area 0.0.0.2
Table 18 Command output
Adv Router ID |
ID of the router that advertised the information. |
Flags |
PCE information flag: · A—Already synchronized information with PCEP. · U—Ready to update information with PCEP again after the previous update failed. · D—Ready to delete information from PCEP again after the previous deletion failed. · R—The router that advertised information is reachable. · E—PCE information is valid. |
Path Scope |
PCE path scope: · L (PCE for intra-area). · R (PCE for inter-area). · Rd (Default PCE for inter-area). · S (PCE for inter-AS). · Sd (Default PCE for inter-AS). · Y (PCE for inter-layer). |
Preference |
PCE Capabilities |
PCE Domain List |
List of local domains that support TE on the PCE. |
PCE Neighbor Domain List |
List of neighbor domains that support TE on the PCE. |
Area |
Area that supports TE. |
AS |
AS that supports TE. |
display ospf mpls te tunnel
Use display ospf mpls te tunnel to display MPLS TE tunnel interface information for OSPF.
display ospf [ process-id ] [ area area-id ] mpls te tunnel
# Display MPLS TE tunnel interface information for all OSPF processes in all areas.
<Sysname> display ospf mpls te tunnel
Traffic Engineering Tunnel
Area: 0.0.0.1
Interface: Tunnel1 (12.1.1.2)
State: Inactive
Neighbor ID: 0.0.0.0 Cost: 0
Destination: 125.1.1.1
Auto Route: IGP Shortcut
Metric: Relative 10
Table 19 Command output
Name and IP address of a tunnel interface. |
State |
Tunnel interface states: · Inactive—The tunnel interface is not used to forward packets, because the tunnel route is not the optimal route. · Active—The tunnel interface is used to forward packets, because the tunnel route is the optimal route. |
Neighbor ID |
Router ID for the tunnel destination. |
Cost |
Route cost of the tunnel interface. |
Destination |
LSR ID for the tunnel destination. |
Auto Route |
Automatic route advertisement method: IGP Shortcut or IGP Advertise. |
Metric |
Absolute or relative metric of the MPLS TE tunnel. |
explicit-path
Use explicit-path to create an explicit path and enter its view, or enter the view of an existing explicit path.
Use undo explicit-path to remove an explicit path.
explicit-path path-name
undo explicit-path path-name
No explicit paths exist.
path-name: Specifies a name for the explicit path, a case-sensitive string of 1 to 31 characters.
In explicit path view, you can use the nexthop command to explicitly specify a node or link that a tunnel must or must not traverse.
# Create explicit path path1 and enter its view.
mpls te backup-path
mpls te path
nexthop
fast-reroute timer
Use fast-reroute timer to set the interval for selecting an optimal bypass tunnel.
Use undo fast-reroute timer to restore the default.
fast-reroute timer interval
The optimal bypass tunnel selection interval is 300 seconds.
MPLS TE view
interval: Specifies the interval for selecting an optimal bypass tunnel, in the range of 0 to 604800 seconds. If you set the interval to 0 seconds, RSVP does not periodically select an optimal bypass tunnel.
If you have specified multiple bypass tunnels for a primary CRLSP, MPLS TE selects an optimal bypass tunnel to protect the primary CRLSP. Sometimes, a bypass tunnel might become better than the current optimal bypass tunnel because, for example, the reservable bandwidth changes. Therefore, MPLS TE must poll the bypass tunnels periodically to update the optimal bypass tunnel.
NOTE: After traffic is switched from the primary CRLSP to a bypass tunnel, MPLS TE no longer periodically selects optimal bypass tunnels for the primary CRLSP. |
# Set the optimal bypass tunnel selection interval to 120 seconds.
[Sysname] mpls te
[Sysname-te] fast-reroute timer 120
Use link-management periodic-flooding timer to set the interval at which IGP floods TE information.
Use undo link-management periodic-flooding timer to restore the default.
link-management periodic-flooding timer interval
The IGP floods TE information every 180 seconds.
MPLS TE view
interval: Specifies the interval at which IGP floods TE information, in the range of 0 to 3600 seconds.
When the reservable bandwidth of a link changes, IGP floods the link TE information to notify network devices of the change. You can use the mpls te bandwidth change thresholds command to configure IGP to flood only significant bandwidth changes of a link to prevent excessive IGP flooding. The bandwidth changes that cannot trigger immediate flooding are flooded at the interval configured by the link-management periodic-flooding timer command.
If you set the interval to 0, the periodical flooding feature is disabled. If you set the interval to a value less than 30 seconds (1 to 29 seconds), the device automatically sets the interval to 30 seconds.
After you execute this command, the configured interval takes effect immediately.
# Configure IGP to flood TE information every 100 seconds.
[Sysname] mpls te
[Sysname-te] link-management periodic-flooding timer 100
mpls te
Use mpls te to enable MPLS TE for the local node and enter MPLS TE view.
Use undo mpls te to disable MPLS TE for the local node.
mpls te
undo mpls te
MPLS TE is disabled.
Disabling MPLS TE also deletes all CRLSPs on the device and MPLS TE configurations on all interfaces.
# Enable MPLS TE for the local node and enter MPLS TE view.
[Sysname] mpls lsr-id 1.1.1.9
[Sysname] mpls te
[Sysname-te]
mpls te enable
mpls te affinity-attribute
Use mpls te affinity-attribute to set an affinity for a tunnel.
Use undo mpls te affinity-attribute to restore the default.
mpls te affinity-attribute attribute-value [ mask mask-value ]
The affinity is 0x00000000, and the mask is 0x00000000. That is, a tunnel can use any link.
Tunnel interface view
attribute-value: Specifies the affinity value, a hexadecimal number in the range of 0 to ffffffff. An affinity is a 32-bit binary number. Each bit of the affinity represents an attribute, which takes a value of 0 or 1.
mask mask-value: Specifies the mask of the affinity bits, a hexadecimal number in the range of 0 to ffffffff. A mask is a 32-bit binary number. Each bit of the mask determines whether to check the corresponding bit of the link attribute. If the mask bit is 1, the corresponding link attribute bit must be checked with the affinity bit. The link can be used by the tunnel only when the link attribute bit meets certain requirements. If the mask bit is 0, the corresponding link attribute bit is not checked.
Affinity determines which links a tunnel can use. The affinity attribute and its mask, and the link attribute are all 32-bit long. A link is available for a tunnel if the link attribute meets the following requirements:
· The link attribute bits corresponding to the affinity attribute's 1 bits whose mask bits are 1 must have a minimum of one bit set to 1.
· The link attribute bits corresponding to the affinity attribute's 0 bits whose mask bits are 1 must have no bit set to 1.
The link attribute bits corresponding to the 0 bits in the affinity mask are not checked.
For example, if the affinity is 0xfffffff0 and the mask is 0x0000ffff, a link is available for the tunnel when its attribute bits meet the following requirements:
· The highest 16 bits each can be 0 or 1 (no requirements).
· The 17th through 28th bits must have a minimum of one bit whose value is 1.
· The lowest four bits must be 0.
# Set the tunnel affinity to 0x101 and mask to 0x303. Then, a link is available for the tunnel only when the link attribute bits (from left to right) meet the following requirements:
· The 23rd bit is 0.
· The 31st bit is 0.
· A minimum of one bit from the 24th to 32nd bits must be 1.
[Sysname] interface tunnel 1 mode mpls-te
[Sysname-Tunnel1] mpls te affinity-attribute 101 mask 303
mpls te link-attribute
Use mpls te auto-tunnel backup disable to disable the auto FRR feature on an RSVP-enabled interface.
Use undo mpls te auto-tunnel backup disable to enable the auto FRR feature on an RSVP-enabled interface.
The auto FRR feature is enabled on all RSVP-enabled interfaces after it is enabled globally.
Interface view
The auto FRR feature allows an interface to automatically set up a node-protection bypass tunnel and a link-protection bypass tunnel for each of its primary CRLSPs. The output interface of the primary CRLSPs is the interface itself.
Bypass tunnels are set up before the primary CRLSP fails. Therefore, they use extra bandwidth. To save network bandwidth, configure auto FRR only for key interfaces. On other interfaces, use the mpls te auto-tunnel backup disable command to disable the interfaces from automatically setting up bypass tunnels.
Execution of the mpls te auto-tunnel backup disable command deletes all existing bypass tunnels automatically created on the interface.
# Disable auto FRR on VLAN-interface 10.
[Sysname-Vlan-interface10] mpls te auto-tunnel backup disable
auto-tunnel backup
mpls te backup
Use mpls te backup to enable tunnel backup and specify the backup mode for a tunnel.
Use undo mpls te backup to disable tunnel backup.
mpls te backup { hot-standby | ordinary }
undo mpls te backup
Tunnel backup is disabled.
hot-standby: Enables hot backup for the tunnel. In this mode, a backup CRLSP is established immediately after the primary CRLSP is established. When the primary CRLSP fails, MPLS TE immediately switches traffic to the backup CRLSP.
ordinary: Enables ordinary backup for the tunnel. In this mode, a backup CRLSP is established after the primary CRLSP fails.
After you execute this command for a tunnel, the record route flag is automatically set for the tunnel, regardless of whether the mpls te record-route command is configured.
In the same tunnel interface view, the mpls te backup command is mutually exclusive with the mpls te reoptimization command.
If both the mpls te backup and mpls te bidirectional commands are configured, only the mpls te bidirectional command takes effect.
# Enable hot backup for Tunnel 1.
[Sysname-Tunnel1] mpls te backup hot-standby
mpls te backup-path
Use mpls te backup bandwidth to configure the bandwidth and the CT that the bypass tunnel can protect.
Use undo mpls te backup bandwidth to restore the default.
mpls te backup bandwidth [ ct0 | ct1 | ct2 | ct3 ] { bandwidth | un-limited }
The bandwidth and the CT that the bypass tunnel can protect are not specified.
ct0: Specifies the bypass tunnel to protect only CRLSPs of CT 0.
ct1: Specifies the bypass tunnel to protect only CRLSPs of CT 1.
ct2: Specifies the bypass tunnel to protect only CRLSPs of CT 2.
ct3: Specifies the bypass tunnel to protect only CRLSPs of CT 3.
bandwidth: Specifies the total bandwidth that the bypass tunnel can protect, in the range of 1 to 4294967295, in kbps.
un-limited: Puts no limit on total protected bandwidth. This keyword means the bypass tunnel does not provide bandwidth protection.
If no CT is specified, CRLSPs of all CTs can use the bypass tunnel.
If you specify the un-limited keyword, the bypass tunnel does not provide bandwidth protection. FRR does not guarantee the bandwidth of the protected tunnels. If the sum of traffic of the protected tunnels exceeds the actual bandwidth of the bypass tunnel, traffic of protected tunnels might be lost. The primary CRLSP that does not need bandwidth protection prefers this type of bypass tunnels over other types of bypass tunnels.
If you specify the bandwidth argument, the bypass tunnel provides bandwidth protection. The primary CRLSP that needs bandwidth protection prefers this type of bypass tunnels over other types of bypass tunnels. If you set the value for the bandwidth argument to 0, the bypass tunnel performs best-effort forwarding for the traffic of primary CRLSP, and the occupied bandwidth is not fixed. Therefore, this type of bypass tunnel cannot protect a primary CRLSP with the bandwidth 0 or a primary CRLSP whose bandwidth exceeds the protected bandwidth.
The specified bandwidth value must be less than the actual bandwidth of the bypass tunnel. Otherwise, the bypass tunnel will be overwhelmed after FRR, and the protected tunnel might be torn down.
After an FRR, the primary CRLSP will be down if you modify the bandwidth that the bypass tunnel can protect and your modification results in one of the following:
· The CT type changes.
· The bypass tunnel cannot protect adequate bandwidth as configured.
· FRR protection type (whether or not to provide bandwidth protection for the primary CRLSP) changes.
The bandwidth value specified is used only for calculating and determining the bandwidth protection relationship between a primary CRLSP and a bypass tunnel. The bandwidth is not reserved on the bypass tunnel.
# Configure Tunnel 1 to provide protection for CRLSPs of CT 0 without constraining the protected bandwidth. Configure Tunnel 2 to provide protection for CRLSPs of CT 1 and protect a maximum of 1000 kbps bandwidth.
[Sysname-Tunnel1] mpls te backup bandwidth ct0 un-limited
[Sysname-Tunnel1] quit
[Sysname] interface tunnel 2 mode mpls-te
[Sysname-Tunnel2] mpls te backup bandwidth ct1 1000
mpls te backup-path
Use mpls te backup-path to specify a path for the backup CRLSP and set the preference of the path.
Use undo mpls te backup-path to delete the specified path for the backup CRLSP.
mpls te backup-path preference value { dynamic [ pce [ ip-address ]&<0-8> ] | explicit-path path-name } [ no-cspf ]
undo mpls te backup-path preference value
MPLS TE uses the dynamically calculated path to establish the backup CRLSP.
preference value: Specifies a preference value for a path, in the range of 1 to 10. A smaller value represents a higher preference.
dynamic: Uses the path dynamically calculated by CSPF to establish the backup CRLSP.
pce: Uses the path calculated by PCEs to establish the CRLSP. If you do not specify this keyword, the local LSR uses the path dynamically calculated by CSPF.
[ ip-address ]&<0-8>: Specifies a space-separated list of a maximum of eight PCE addresses. If you do not specify a PCE address, the system automatically selects a PCE from the discovered PCEs. If you specify more than one PCE address, a BRPC calculation will be performed on the specified PCEs in configuration order.
explicit-path path-name: Uses the specified explicit path to establish the backup CRLSP. The path-name argument specifies the name of an explicit path, a case-sensitive string of 1 to 31 characters.
no-cspf: Calculates the path by searching the routing table instead of using the CSPF algorithm.
You can specify a maximum of 10 backup paths for a tunnel interface. The backup paths must have different preferences.
When establishing a backup CRLSP, MPLS TE performs CSPF calculations using the specified paths in the descending order of preference until the backup CRLSP is established successfully. If the CSPF calculations for all paths are failed, the backup CRLSP cannot be established.
This command takes effect only when backup has been enabled for the tunnel by using the mpls te backup command.
If you specify PCE addresses in this command or in the mpls te path command, the local device establishes PCEP sessions to the specified PCEs. If you do not specify a PCE address, the local device establishes PCEP sessions to all discovered PCEs.
# Configure Tunnel 1 to use explicit path path1 and the path calculated by PCEs to establish a backup CRLSP. Set a higher preference for the path calculated by PCEs.
[Sysname-Tunnel1] mpls te backup-path preference 2 explicit-path path1
[Sysname-Tunnel1] mpls te backup-path preference 1 dynamic pce 1.1.1.9 2.2.2.9
mpls te backup
mpls te path
mpls te bandwidth
Use mpls te bandwidth to assign bandwidth to the MPLS TE tunnel and specify a class type (CT) for the tunnel.
Use undo mpls te bandwidth to restore the default.
mpls te bandwidth [ ct0 | ct1 | ct2 | ct3 ] bandwidth
No bandwidth (0 bps) is assigned to an MPLS TE tunnel and the tunnel is available for CT 0.
ct0: Specifies CT 0 for the tunnel.
ct1: Specifies CT 1 for the tunnel.
ct2: Specifies CT 2 for the tunnel.
ct3: Specifies CT 3 for the tunnel.
bandwidth: Specifies the bandwidth required by the MPLS TE tunnel, in the range of 1 to 4294967295, in kbps.
If you do not specify a CT for the tunnel, the tunnel is available for CT 0.
If the bandwidth required by the MPLS TE tunnel is more than 1024 kbps, set the bandwidth to a multiple of 1024 kbps.
This command applies only to the MPLS TE tunnels established by RSVP-TE. The bandwidth and CT of an MPLS TE tunnel established by using a static CRLSP are determined by the static-cr-lsp ingress command.
# Assign 1000 kbps bandwidth to MPLS TE Tunnel 1 and specify the CT of the tunnel as CT 1.
[Sysname-Tunnel1] mpls te bandwidth ct1 1000
Use mpls te bandwidth change thresholds to set the bandwidth up/down threshold for the IGP to flood TE information.
Use undo mpls te bandwidth change thresholds to restore the default.
mpls te bandwidth change thresholds { down | up } percent
undo mpls te bandwidth change thresholds { down | up }
The IGP floods the TE information when the bandwidth increases or decreases by 10% of the link reservable bandwidth.
Interface view
down: Specifies the bandwidth decrease percentage threshold that triggers the IGP to flood TE information. When the percentage of the link reservable-bandwidth decrease to the maximum link reservable bandwidth reaches or exceeds the threshold, the IGP floods the TE information and updates the TEDB.
up: Specifies the bandwidth increase percentage threshold that triggers the IGP to flood TE information. When the percentage of the link reservable-bandwidth increase to the maximum link reservable bandwidth reaches or exceeds the threshold, the IGP floods the TE information and updates the TEDB.
percent: Specifies the IGP flooding threshold in the range of 0% to 100%.
When the reservable bandwidth of a link changes, the IGP floods the link TE information to notify network devices of the change. To avoid frequent TE information flooding from affecting network performance, you can use this command to configure the IGP to flood only significant bandwidth changes of a link.
# On VLAN-interface 10, configure the IGP to flood TE information when the link available bandwidth decreases by 100%.
[Sysname-Vlan-interface10] mpls te bandwidth change thresholds down 100
Use mpls te bidirectional to enable the bidirectional tunnel feature on an MPLS TE tunnel interface.
Use undo mpls te bidirectional to disable the bidirectional tunnel feature on an MPLS TE tunnel interface.
mpls te bidirectional { associated reverse-lsp { lsp-name lsp-name | lsr-id ingress-lsr-id tunnel-id tunnel-id } | co-routed { active | passive reverse-lsp lsr-id ingress-lsr-id tunnel-id tunnel-id } }
The bidirectional tunnel feature is disabled on an MPLS TE tunnel interface. A tunnel established on an MPLS TE tunnel interface is a unidirectional MPLS TE tunnel.
associated reverse-lsp lsp-name lsp-name: Configures an associated bidirectional MPLS TE tunnel, and specifies the associated reverse CRLSP. The lsp-name argument specifies the name of a static CRLSP (the reverse CRLSP), a case-sensitive string of 1 to 15 characters.
associated reverse-lsp lsr-id ingress-lsr-id tunnel-id tunnel-id: Configures an associated bidirectional MPLS TE tunnel, and specifies the associated reverse CRLSP. The ingress-lsr-id argument specifies the LSR ID of the ingress node on the reverse CRLSP and the tunnel-id argument specifies the tunnel ID of the reverse CRLSP. The value range for the tunnel-id argument is 0 to 65535.
co-routed: Configures a co-routed bidirectional MPLS TE tunnel.
active: Specifies the local end as the active end of the co-routed bidirectional MPLS TE tunnel.
passive reverse-lsp lsr-id ingress-lsr-id tunnel-id tunnel-id: Specifies the local end as the passive end of the co-routed bidirectional MPLS TE tunnel, and specifies the associated reverse CRLSP. The ingress-lsr-id argument specifies the LSR ID of the ingress node on the reverse CRLSP and the tunnel-id argument specifies the tunnel ID of the reverse CRLSP. The value range for the tunnel-id argument is 0 to 65535. You must specify a reverse CRLSP on the passive end, so that the CRLSP and the reverse CRLSP are associated to form a bidirectional MPLS TE tunnel.
A bidirectional MPLS TE tunnel can be established in co-routed mode or associated mode.
· Co-routed mode uses the extended RSVP-TE protocol to establish a bidirectional MPLS TE tunnel. To establish a co-routed bidirectional MPLS TE tunnel, you must perform the following tasks:
¡ Specify the signaling protocol as RSVP-TE.
¡ Configure one end of the tunnel as the active end and the other as the passive end.
· In associated mode, you establish a bidirectional MPLS TE tunnel by binding two unidirectional CRLSPs in opposite directions. The two CRLSPs can be established in different modes and use different paths. For example, one CRLSP is established statically and the other CRLSP is established dynamically by RSVP-TE.
To create a bidirectional MPLS TE tunnel, you must disable the PHP feature on both ends of the tunnel to assign non-null labels to the penultimate hop.
If the mpls te bidirectional command is configured together with one of the following commands, only the mpls te bidirectional command takes effect:
· mpls te backup
· mpls te reoptimization
· mpls te fast-reroute
· Configure an MPLS TE bidirectional tunnel between Device A and Device B in co-routed mode:
# Configure Device A as follows:
¡ Enable the MPLS TE bidirectional tunnel feature on tunnel interface Tunnel 1.
¡ Configure Device A as the active end of the co-routed bidirectional tunnel.
[DeviceA] interface tunnel 1 mode mpls-te
[DeviceA-Tunnel1] destination 10.0.0.2
[DeviceA-Tunnel1] mpls te bidirectional co-routed active
# Configure Device B as follows:
¡ Configure Device B as the passive end of the co-routed bidirectional tunnel.
¡ Specify the ingress node's LSR ID of the reverse CRLSP as 10.0.0.1—the LSR ID of Sysname1.
¡ Specify the tunnel ID of the reverse CRLSP as 2—the tunnel ID configured on Device A.
[DeviceB] interface tunnel 1 mode mpls-te
[DeviceB-Tunnel1] destination 10.0.0.1
[DeviceB-Tunnel1] mpls te bidirectional co-routed passive reverse-lsp lsr-id 10.0.0.1 tunnel-id 2
· Configure an MPLS TE bidirectional tunnel between Device A and Device B in associated mode:
¡ Configure the tunnel establishment mode as associated.
¡ Specify the ingress node's LSR ID of the reverse CRLSP as 10.0.0.2—the LSR ID of Device B.
¡ Specify the tunnel ID of the reverse CRLSP as 2—the tunnel ID configured on Device B.
[DeviceA-Tunnel1] mpls te bidirectional associated reverse-lsp lsr-id 10.0.0.2 tunnel-id 2
¡ Specify the ingress node's LSR ID of the reverse CRLSP as 10.0.0.1—the LSR ID of Device A.
¡ Specify the tunnel ID of the reverse CRLSP as 3—the tunnel ID configured on Device A.
[DeviceB-Tunnel1] mpls te bidirectional associated reverse-lsp lsr-id 10.0.0.1 tunnel-id 3
mpls te enable (interface view)
Use mpls te enable to enable MPLS TE on an interface.
Use undo mpls te enable to disable MPLS TE on an interface.
mpls te enable
undo mpls te enable
MPLS TE is disabled on an interface.
Interface view
After you enable MPLS TE on an interface by using the mpls te enable command, the interface can act as part of an MPLS TE tunnel.
After you execute the undo mpls te enable command on an interface, MPLS TE is disabled on the interface and all CRLSPs on the interface are deleted.
# Enable MPLS TE on VLAN-interface 10.
[Sysname-Vlan-interface10] mpls te enable
mpls te
mpls te enable (IS-IS view)
Use mpls te enable to enable MPLS TE for an IS-IS process.
Use undo mpls te enable to disable MPLS TE for an IS-IS process.
mpls te enable [ level-1 | level-2 ]
undo mpls te enable [ level-1 | level-2 ]
MPLS TE is disabled for an IS-IS process.
IS-IS view
level-1: Enables MPLS TE for IS-IS at Level-1.
level-2: Enables MPLS TE for IS-IS at Level-2.
If you do not specify an IS-IS level, this command enables MPLS TE for IS-IS at both Level-1 and Level-2.
IS-IS TE uses a sub-TLV of the extended IS reachability TLV (type 22) to carry TE attributes. Because the extended IS reachability TLV carries wide metrics, specify a wide metric-compatible metric style for the IS-IS process before enabling IS-IS TE. Available metric styles for IS-IS TE include wide, compatible, or wide-compatible. For more information about IS-IS, see Layer 3—IP Routing Configuration Guide.
If you execute this command multiple times, the most recent configuration takes effect. For example, if you execute the mpls te enable command and then the mpls te enable level-1 command, MPLS TE is enabled for Level-1 and disabled for Level-2.
After you enable MPLS TE for both Level-1 and Level-2, executing the undo mpls te enable level-1 command disables MPLS TE for Level-1. MPLS TE is still enabled for Level-2. Similarly, the undo mpls te enable level-2 command only disables MPLS TE for Level-2.
IS-IS messages cannot be fragmented at the IP layer. For IS-IS TE to operate correctly, make sure the following requirements are met:
· The Link State PDU size is large enough so that the Link State PDUs can carry TE information. To set the maximum size of Level-1 and Level-2 Link State PDUs, use the lsp-length originate command.
· The MTU of an IS-IS enabled interface is greater than or equal to the size of IS-IS Link State PDUs with TE information. To set the interface MTU, use the mtu command.
# Enable MPLS TE for IS-IS process 1 at Level-2.
[Sysname] isis 1
[Sysname-isis-1] cost-style compatible
[Sysname-isis-1] mpls te enable level-2
cost-style (Layer 3—IP Routing Command Reference)
mpls te enable (OSPF area view)
Use mpls te enable to enable MPLS TE for an OSPF area.
Use undo mpls te enable to disable MPLS TE for an OSPF area.
mpls te enable
undo mpls te enable
MPLS TE is disabled for an OSPF area.
OSPF area view
OSPF TE uses Type-10 opaque LSAs to carry the TE attributes for a link. Before you configure OSPF TE, you must enable opaque LSA advertisement and reception by using the opaque-capability enable command. For more information about opaque LSA advertisement and reception, see Layer 3—IP Routing Configuration Guide.
# Enable MPLS TE for OSPF process 1 in OSPF area 1.
[Sysname] ospf 1
[Sysname-ospf-1] area 1
[Sysname-ospf-1-area-0.0.0.1] mpls te enable
opaque-capability enable (Layer 3—IP Routing Command Reference)
Use mpls te fast-reroute to enable fast reroute (FRR).
Use undo mpls te fast-reroute to disable FRR.
mpls te fast-reroute [ bandwidth ]
bandwidth: Provides bandwidth protection for the primary CRLSP. If you do not specify this keyword, bandwidth protection is not provided for the primary CRLSP.
FRR provides a quick link or node protection on a CRLSP. FRR traffic switching can happen in as fast as 50 milliseconds, minimizing data loss.
After FRR is enabled for an MPLS TE tunnel, once a link or node fails on the primary CRLSP, the following events occur:
· FRR reroutes the traffic to a bypass tunnel.
· The ingress node attempts to set up a new CRLSP.
After the new CRLSP is set up successfully, traffic is forwarded on the new CRLSP.
When a primary CRLSP does not need bandwidth protection, it prefers to use a bypass tunnel that does not provide bandwidth protection. No bandwidth guarantee is required after FRR.
When a primary CRLSP needs bandwidth protection, it prefers to use the bypass tunnel that can protect bandwidth as much as possible to provide bandwidth guarantee after FRR.
Regardless of whether a primary CRLSP requires bandwidth protection, the following will occur when the primary CRLSP is bound to a bypass tunnel that provides bandwidth protection:
· The bypass tunnel will reserve the protected bandwidth for the primary CRLSP.
· The RRO message of the PLR will carry the bandwidth protection flag.
After FRR is enabled for a tunnel, the label recording feature is automatically enabled for the tunnel, regardless of whether the mpls te record-route label command is configured.
If both the mpls te fast-reroute and mpls te bidirectional commands are configured, only the mpls te bidirectional command takes effect.
# Enable FRR for Tunnel 1.
[Sysname-Tunnel1] mpls te fast-reroute
mpls te fast-reroute bypass-tunnel
Use mpls te fast-reroute bypass-tunnel to specify a bypass tunnel for an interface.
Use undo mpls te fast-reroute bypass-tunnel to delete a bypass tunnel from an interface.
mpls te fast-reroute bypass-tunnel tunnel tunnel-number
undo mpls te fast-reroute bypass-tunnel tunnel tunnel-number
No bypass tunnel is specified for an interface.
Interface view
tunnel tunnel-number: Specifies a bypass tunnel by the tunnel interface number. The value range for the tunnel-number argument is 1 to 4095.The specified bypass tunnel must be established by RSVP, and the protected interface must not be the outgoing interface of a bypass tunnel.
The protected interface (where the command is executed) is the outgoing interface of a primary CRLSP. When the outgoing interface is down or a neighbor failure is detected through the BFD or hello mechanism, traffic of the primary CRLSP is switched to the bypass tunnel.
When you use this command, follow these restrictions and guidelines:
· You can specify a maximum of three bypass tunnels for an interface.
· A bypass tunnel can protect a maximum of three interfaces.
# Configure tunnel interface Tunnel 1 as the bypass tunnel for VLAN-interface 10.
[Sysname-Vlan-interface10] mpls te fast-reroute bypass-tunnel tunnel 1
fast-reroute timer
mpls te igp advertise
Use mpls te igp advertise to enable forwarding adjacency for an MPLS TE tunnel, so IGP advertises the tunnel as a link in the IGP network.
Use undo mpls te igp advertise to disable forwarding adjacency.
mpls te igp advertise [ hold-time value ]
Forwarding adjacency is disabled for an MPLS TE tunnel, and IGP does not advertise the tunnel as a link in the IGP network.
hold-time value: Specifies the period of time that IGP waits to advertise an MPLS TE tunnel up/down state change. The value range is 0 to 4294967295 milliseconds. The default value is 0, which means when the MPLS TE tunnel state changes, IGP immediately advertises the state change.
Only MPLS TE tunnels established by using RSVP-TE support the forwarding adjacency feature.
To make forwarding adjacency take effect, you must establish two MPLS TE tunnels in opposite directions between two nodes, and enable forwarding adjacency on both nodes.
On an interface, if you configure both the mpls te igp advertise command and the mpls te igp shortcut command, the most recent configuration takes effect.
# Enable forwarding adjacency for MPLS TE Tunnel 1, and set the wait time before advertising a tunnel state change to 10000 milliseconds.
[Sysname-Tunnel1] mpls te igp advertise hold-time 10000
mpls te igp metric
mpls te igp metric
Use mpls te igp metric to assign a metric to an MPLS TE tunnel.
Use undo mpls te igp metric to restore the default.
mpls te igp metric { absolute value | relative value }
The metric of an MPLS TE tunnel equals its IGP metric.
absolute value: Specifies an absolute metric, an integer in the range of 1 to 65535.
relative value: Specifies a relative metric, an integer in the range of –10 to +10. A relative metric is the assigned metric value plus the IGP metric.
When IGP shortcut is enabled for an MPLS TE tunnel, the MPLS TE tunnel is included in the IGP route calculation as a link. You can use this command to configure the metric of this link used for IGP route calculation.
# Assign MPLS TE tunnel interface Tunnel 1 a relative metric of –1 for route calculation in IGP shortcut mechanism.
[Sysname-Tunnel1] mpls te igp metric relative -1
Use mpls te igp shortcut to enable IGP shortcut for an MPLS TE tunnel. The tunnel ingress node includes the tunnel in the IGP route calculation as a link.
Use undo mpls te igp shortcut to disable IGP shortcut.
mpls te igp shortcut [ isis | ospf ]
IGP shortcut is disabled for an MPLS TE tunnel. The ingress node does not include the tunnel in the IGP route calculation as a link.
isis: Includes the MPLS TE tunnel in IS-IS route calculation.
ospf: Includes the MPLS TE tunnel in OSPF route calculation.
If you do not specify the IGP in this command, both OSPF and IS-IS will include the MPLS TE tunnel in route calculation.
# Enable IGP shortcut for MPLS TE Tunnel 1, so the tunnel ingress node considers the tunnel as a link in the OSPF and IS-IS route calculation.
[Sysname-Tunnel1] mpls te igp shortcut
mpls te igp metric
Use mpls te link-attribute to set the link attribute.
Use undo mpls te link-attribute to restore the default.
mpls te link-attribute attribute-value
The link attribute value is 0x00000000.
Interface view
attribute-value: Specifies the link attribute value, a hexadecimal number in the range of 0 to ffffffff. A link attribute value is a 32-bit binary number. Each bit represents an attribute with a value of 0 or 1.
The TE information for a link advertised by the IGP includes the link attribute configured by this command. After receiving the link TE information, the ingress node of an MPLS TE tunnel determines whether the link can be used for MPLS TE tunnel establishment according to the following settings:
· The configured tunnel affinity attribute.
· The affinity mask.
· The link attribute.
A link is available for a tunnel if the following requirements are met:
For example, if the affinity is 0xfffffff0 and the mask is 0x0000ffff, a link is available for the tunnel when its link attribute bits meet the following requirements:
# On VLAN-interface 10, set the link attribute to 0x00000101.
[Sysname-Vlan-interface10] mpls te link-attribute 101
mpls te loop-detection
Use mpls te loop-detection to enable loop detection during establishment of an MPLS TE tunnel.
Use undo mpls te loop-detection to disable loop detection for the MPLS TE tunnel.
Loop detection is disabled for an MPLS TE tunnel.
When loop detection is enabled on the ingress node of an MPLS TE tunnel, the route recording feature is automatically enabled for the tunnel, regardless of whether the mpls te record-route command is configured. When establishing the MPLS TE tunnel, each node of the tunnel detects whether a loop has occurred according to the recorded route information.
# Enable loop detection for establishing MPLS TE Tunnel 1.
[Sysname-Tunnel1] mpls te loop-detection
mpls te max-link-bandwidth
Use mpls te max-link-bandwidth to set the maximum bandwidth for MPLS TE traffic on an interface.
Use undo mpls te max-link-bandwidth to restore the default.
mpls te max-link-bandwidth { bandwidth-value| percent percent-bandwidth }
The maximum link bandwidth for MPLS TE traffic is 0 kbps.
Interface view
bandwidth-value: Specifies the maximum link bandwidth in the range of 1 to 4294967295 kbps.
percent percent-bandwidth: Specifies the percentage of the maximum link bandwidth out of the total bandwidth of the interface. The value range is 1 to 100.
The device carries the maximum link bandwidth in advertised IGP routes. The tunnel ingress node can obtain the information and use the information in CSPF calculation to select a path that meets the tunnel bandwidth requirements.
# On VLAN-interface 10, set the maximum link bandwidth for MPLS TE traffic to 1158 kbps.
[Sysname-Vlan-interface10] mpls te max-link-bandwidth 1158
display mpls te link-management bandwidth-allocation
mpls te bandwidth
mpls te max-reservable-bandwidth
mpls te max-reservable-bandwidth mam
mpls te max-reservable-bandwidth rdm
Use mpls te max-reservable-bandwidth to set the maximum reservable bandwidth of the link (BC 0) and BC 1 in prestandard DS-TE RDM model.
Use undo mpls te max-reservable-bandwidth to restore the default.
mpls te max-reservable-bandwidth { bandwidth-value [ bc1 bc1-bandwidth ] | percent percent-bandwidth [ bc1 bc1-percent-bandwidth ] }
The maximum reservable bandwidth of a link is 0 kbps and BC 1 is 0 kbps.
Interface view
bandwidth-value: Specifies the maximum reservable bandwidth of the link (the value of BC 0), in the range of 1 to 4294967295 kbps.
bc1 bc1-bandwidth: Specifies the value of BC 1, in the range of 1 to 4294967295 kbps. The default value is 0.
percent percent-bandwidth: Specifies the percentage of BC 0 out of the maximum link bandwidth. The value range is 1 to 100.
bc1 bc1-percent-bandwidth: Specifies the percentage of BC 1 out of the maximum reservable bandwidth. The value range is 1 to 100. The default value is 0.
The device carries the bandwidth values configured by this command in IGP route advertisements. The tunnel ingress node can obtain the information and use the information in CSPF calculation to select a path that meets the tunnel bandwidth requirements.
The maximum reservable bandwidth of a link (bandwidth-value) cannot be greater than the maximum bandwidth of the link (configured with the mpls te max-link-bandwidth command). The value of BC 1 (bc1-bandwidth) cannot be greater than the maximum reservable bandwidth of the link (bandwidth-value).
The bandwidth values configured by this command are only for MPLS TE traffic.
# Set the link maximum reservable bandwidth to 1158 kbps and BC 1 to 200 kbps for MPLS TE traffic in prestandard DS-TE RDM model.
[Sysname-Vlan-interface10] mpls te max-reservable-bandwidth 1158 bc1 200
mpls te bandwidth
Use mpls te max-reservable-bandwidth mam to set the maximum reservable bandwidth of the link and the BCs in MAM model of the IETF DS-TE.
Use undo mpls te max-reservable-bandwidth mam to restore the default.
mpls te max-reservable-bandwidth mam { bandwidth-value { bc0 bc0-bandwidth | bc1 bc1-bandwidth | bc2 bc2-bandwidth | bc3 bc3-bandwidth } * | percent percent-bandwidth { bc0 bc0-percent-bandwidth | bc1 bc1-percent-bandwidth | bc2 bc2-percent-bandwidth | bc3 bc3-percent-bandwidth } * }
The maximum reservable bandwidth of a link is 0 kbps and each BC is 0 kbps.
Interface view
bandwidth-value: Specifies the maximum reservable bandwidth of the link, in the range of 1 to 4294967295 kbps.
bc0 bc0-bandwidth: Specifies the value of BC 0, in the range of 1 to 4294967295 kbps. By default, BC 0 is 0 kbps.
bc1 bc1-bandwidth: Specifies the value of BC 1, in the range of 1 to 4294967295 kbps. By default, BC 1 is 0 kbps.
bc2 bc2-bandwidth: Specifies the value of BC 2, in the range of 1 to 4294967295 kbps. By default, BC 2 is 0 kbps.
bc3 bc3-bandwidth: Specifies the value of BC 3, in the range of 1 to 4294967295 kbps. By default, BC 3 is 0 kbps.
percent percent-bandwidth: Specifies the percentage of the maximum reservable link bandwidth out of the maximum link bandwidth. The value range is 1 to 100.
bc0 bc0-percent-bandwidth: Specifies the percentage of BC 0 out of the maximum reservable link bandwidth. The value range is 1 to 100. The default value is 0.
bc1 bc1-percent-bandwidth: Specifies the percentage of BC 1 out of the maximum reservable link bandwidth. The value is 1 to 100. The default value is 0.
bc2 bc2-percent-bandwidth: Specifies the percentage of BC 2 out of the maximum reservable link bandwidth. The value range is 1 to 100. The default value is 0.
bc3 bc3-percent-bandwidth: Specifies the percentage of BC 3 out of the maximum reservable link bandwidth. The value range is 1 to 100. The default value is 0.
The maximum reservable bandwidth of a link (bandwidth-value) cannot be greater than the maximum bandwidth of the link (configured with the mpls te max-link-bandwidth command). Each BC (bc0-bandwidth, bc1-bandwidth, bc2-bandwidth and bc3-bandwidth) cannot be greater than the maximum reservable bandwidth of the link (bandwidth-value).
The maximum reservable bandwidth and BCs configured by this command are only for MPLS TE traffic.
# Set the link maximum reservable bandwidth to 1158 kbps and BC 0 through BC 3 to 500 kbps, 300 kbps, 400 kbps, and 100 kbps for MPLS TE traffic in IETF DS-TE MAM model.
[Sysname-Vlan-interface10] mpls te max-reservable-bandwidth mam 1158 bc0 500 bc1 300 bc2 400 bc3 100
mpls te bandwidth
Use mpls te max-reservable-bandwidth rdm to set the BCs in IETF DS-TE RDM model.
Use undo mpls te max-reservable-bandwidth rdm to restore the default.
mpls te max-reservable-bandwidth rdm { bandwidth-value [ bc1 bc1-bandwidth ] [ bc2 bc2-bandwidth ] [ bc3 bc3-bandwidth ] | percent percent-bandwidth [ bc1 bc1-percent-bandwidth ] [ bc2 bc2-percent-bandwidth ] [ bc3 bc3-percent-bandwidth ] }
Each BC is 0 kbps.
Interface view
bandwidth-value: Specifies the maximum reservable bandwidth of the link, or, the value of BC 0, in the range of 1 to 4294967295 kbps.
percent percent-bandwidth: Specifies the percentage of the maximum reservable link bandwidth (BC 0) out of the maximum link bandwidth. The value range is 1 to 100.
bc1 bc1-percent-bandwidth: Specifies the percentage of BC 1 out of the maximum reservable link bandwidth. The value range is 1 to 100. The default value is 0.
BC 0 (bandwidth-value) must be smaller than or equal to the maximum bandwidth of the link (configured with the mpls te max-link-bandwidth command). BC 0 must be greater than or equal to BC 1. BC 1 must be greater than or equal to BC 2. BC 2 must be greater than or equal to BC 3.
The BCs configured by this command are only for MPLS TE traffic.
# Set BC 0 in IETF RDM model to 500 kbps, BC 1 to 400 kbps, BC 2 to 300 kbps, and BC 3 to 100 kbps.
[Sysname-Vlan-interface1] mpls te max-reservable-bandwidth rdm 500 bc1 400 bc2 300 bc3 100
mpls te bandwidth
mpls te metric
Use mpls te metric to assign a TE metric to the link.
Use undo mpls te metric to restore the default.
mpls te metric value
undo mpls te metric
A link uses its IGP metric as its TE metric.
Interface view
value: Specifies a TE metric for the link, in the range of 1 to 4294967295.
The device carries two types of metrics (IGP metric and TE metric) of a link in the advertised IGP routes. You can use this command to configure the TE metric. When the tunnel ingress receives the link metrics, it uses the IGP or TE metric for path selection according to the configuration of the mpls te path-metric-type or path-metric-type command.
# Assign a TE metric of 20 to the link on VLAN-interface 10.
[Sysname-Vlan-interface10] mpls te metric 20
mpls te path metric-type
path metric-type
mpls te path
Use mpls te path to specify a path for the tunnel and set the preference of the path.
Use undo mpls te path to delete the specified path for the tunnel.
mpls te path preference value { dynamic [ pce [ ip-address ]&<0-8> ] | explicit-path path-name } [ no-cspf ]
undo mpls te path preference value
MPLS TE uses the dynamically calculated path to establish a CRLSP.
dynamic: Uses the path dynamically calculated by CSPF to establish the CRLSP.
[ ip-address ]&<0-8>: Specifies a space-separated list of a maximum of eight PCE addresses. If you do not specify a PCE address, the system automatically selects a PCE from discovered PCEs. If you specify more than one PCE address, a BRPC calculation will be performed on the specified PCEs in configuration order.
explicit-path path-name: Uses the specified explicit path to establish the CRLSP. The path-name argument specifies the name of an explicit path, a case-sensitive string of 1 to 31 characters.
You can specify a maximum of 10 paths for a tunnel interface. The paths must have different preferences.
When establishing a CRLSP, MPLS TE performs CSPF calculations according to the specified paths in a descending order of preference until the CRLSP is established successfully. If the CSPF calculations for all paths are failed, the CRLSP cannot be established.
If you specify PCE addresses in this command or in the mpls te backup-path command, the local device establishes PCEP sessions to the specified PCEs. If you do not specify a PCE address, the local device establishes PCEP sessions to all discovered PCEs.
# Configure Tunnel 1 to use explicit path path1 and the path calculated by PCEs for CRLSP establishment. Set a higher preference for the path calculated by PCEs.
[Sysname-Tunnel1] mpls te path preference 2 explicit-path path1
[Sysname-Tunnel1] mpls te path preference 1 dynamic pce 1.1.1.9 2.2.2.9
mpls te backup-path
Use mpls te path-metric-type to specify the link metric type for path selection of a tunnel.
Use undo mpls te path-metric-type to restore the default.
mpls te path-metric-type { igp | te }
No link metric type is specified for path selection of a tunnel.
igp: Uses the IGP metric.
te: Uses the TE metric.
Each MPLS TE link has two metrics: IGP metric and TE metric. By using the two metrics, you can select different tunnels for different classes of traffic. For example, use the IGP metric to represent a link delay (a smaller IGP metric value indicates a lower link delay). Use the TE metric to represent a link bandwidth value (a smaller TE metric value indicates a bigger link bandwidth value).
You can establish two MPLS TE tunnels: Tunnel1 for voice traffic and Tunnel2 for video traffic. Configure Tunnel1 to use IGP metrics for path selection, and configure Tunnel2 to use TE metrics for path selection. As a result, the video traffic travels through the path that has larger bandwidth and the voice service travels through the path that has lower delay.
If you specify a metric type for a tunnel by using this command, the tunnel uses the specified metric type for path selection. If you do not specify a metric type, the tunnel uses the metric type specified by the path-metric-type command in MPLS TE view for path selection.
# Configure Tunnel 1 to use the IGP metric for path selection.
[Sysname-Tunnel1] mpls te path-metric-type igp
display mpls te tunnel-interface
mpls te metric
path-metric-type
mpls te priority
Use mpls te priority to set a setup priority and a holding priority for an MPLS TE tunnel.
Use undo mpls te priority to restore the default.
mpls te priority setup-priority [ hold-priority ]
The setup priority and the holding priority of an MPLS TE tunnel are both 7.
setup-priority: Specifies the setup priority in the range of 0 to 7. A smaller number represents a higher priority.
hold-priority: Specifies the holding priority in the range of 0 to 7. A smaller number represents a higher priority. If you do not specify this argument, the holding priority is the same as the setup priority.
The setup priority and holding priority of an MPLS TE tunnel determines the importance of the tunnel. A tunnel that has a higher setup priority than the holding priority of another tunnel can preempt the resources of the second.
The setup priority and holding priority can be applied to the following scenarios:
· Multiple MPLS TE tunnels use the same path but the path does not have enough bandwidth for all the tunnels. You can configure different setup and holding priorities for different tunnels to make sure important tunnels can be established first.
· Before an important tunnel is established, multiple less-important MPLS TE tunnels have existed on the network, occupying the bandwidth resources and the optimal path. You can assign a higher setup priority to the import tunnel, so the tunnel can preempt the resources of the existing tunnels and use the optimal path.
The setup priority of a tunnel must not be higher than its holding priority. Configure the setup priority value to be equal to or greater than the holding priority value.
# Set both the setup priority and holding priority of Tunnel 1 to 1.
[Sysname-Tunnel1] mpls te priority 1 1
Use mpls te record-route to enable route recording and label recording for a tunnel.
Use undo mpls te record-route to disable route recording and label recording for a tunnel.
mpls te record-route [ label ]
Route recording or label recording is disabled for a tunnel.
label: Enables both route recording and label recording. If you do not specify this keyword, the command enables only route recording.
Route recording records the nodes that an MPLS TE tunnel traverses. Label recording records the label assigned by each node. The recorded information helps you know about the path used by the MPLS TE tunnel and the label distribution information. When the tunnel fails, the recorded information helps you locate the fault.
# Enable route recording for MPLS TE tunnel 1.
[Sysname-Tunnel1] mpls te record-route
mpls te reoptimization (tunnel interface view)
Use mpls te reoptimization to enable tunnel reoptimization.
Use undo mpls te reoptimization to disable tunnel reoptimization.
mpls te reoptimization [ frequency seconds ]
Tunnel reoptimization is disabled.
frequency seconds: Specifies the tunnel reoptimization frequency in the range of 1 to 604800 seconds. The default is 3600 seconds.
MPLS TE uses the tunnel reoptimization feature to implement dynamic CRLSP optimization. For example, if a link on the optimal path does not have enough reservable bandwidth during tunnel setup, MPLS TE sets up the tunnel on another path. When the link has enough bandwidth, tunnel optimization can automatically switch the tunnel to the optimal path.
You can configure the ingress to perform tunnel reoptimization periodically. Or, you can use the mpls te reoptimization command in user view to trigger the ingress to perform a tunnel reoptimization at any time.
On the same tunnel interface, the mpls te reoptimization command is mutually exclusive with the following commands:
· mpls te route-pinning.
· mpls te backup.
If both the mpls te reoptimization and mpls te bidirectional commands are configured, only the mpls te bidirectional command takes effect.
[Sysname-Tunnel1] mpls te reoptimization frequency 43200
mpls te reoptimization (user view)
Use mpls te reoptimization to reoptimize all reoptimization-enabled MPLS TE tunnels.
After this command is executed in tunnel interface view, you can execute it in user view to trigger the ingress node to immediately reselect an optimal path for a tunnel.
# Reoptimize all reoptimization-enabled MPLS TE tunnels.
<Sysname> mpls te reoptimization
mpls te resv-style
Use mpls te resv-style to configure the resource reservation style for the MPLS TE tunnel.
Use undo mpls te resv-style to restore the default.
mpls te resv-style { ff | se }
The resource reservation style is SE.
ff: Specifies the resource reservation style as fixed filter (FF). In FF style, resources are reserved for individual senders and cannot be shared among senders on the same session.
se: Specifies the resource reservation style as shared explicit (SE). In SE style, resources are reserved for senders on the same session and shared among them.
This command applies only to MPLS TE tunnels established by RSVP-TE.
# Use the FF reservation style to establish MPLS TE tunnel 1.
[Sysname-Tunnel1] mpls te resv-style ff
mpls te signaling
mpls te retry
Use mpls te retry to set the maximum number of tunnel setup attempts.
Use undo mpls te retry to restore the default.
mpls te retry retries
undo mpls te retry
The maximum number of tunnel setup attempts is 3.
retries: Specifies the number of tunnel setup attempts, in the range of 1 to 4294967295.
After failing to establish an MPLS TE tunnel, the tunnel ingress node waits for the tunnel setup retry interval (configured by the mpls te timer retry command). Then it tries to set up the tunnel until the tunnel is established successfully. If the tunnel cannot be established when the number of attempts reaches the maximum, the ingress waits for a longer period and then repeats the previous process.
# Set the maximum number of tunnel setup attempts to 20.
[Sysname-Tunnel1] mpls te retry 20
mpls te timer retry
Use mpls te route-pinning to enable route pinning.
Use undo mpls te route-pinning to restore the default.
Route pinning is disabled.
When route pinning is enabled, an established CRLSP does not re-select an optimal path even if the optimal route has changed.
Use this feature to avoid CRLSPs from changing frequently on an unstable network. This feature ensures that the established CRLSPs are not re-established as long as they are available.
In the same tunnel interface view, the mpls te route-pinning command cannot be used together with the mpls te reoptimization command.
# Enable route pinning for Tunnel 1.
[Sysname-Tunnel1] mpls te route-pinning
mpls te signaling
Use mpls te signaling to configure the signaling protocol for an MPLS TE tunnel interface.
Use undo mpls te signaling to restore the default.
mpls te signaling { rsvp-te | static | segment-routing }
MPLS TE uses RSVP-TE to establish tunnels.
rsvp-te: Uses the RSVP-TE signaling protocol to establish a tunnel.
static: Uses a static CRLSP or SRLSP to establish a tunnel.
segment-routing: Uses the Segment Routing protocol to establish a tunnel.
To use RSVP-TE to establish an MPLS TE tunnel, you must enable MPLS TE and RSVP on each node and interface that the MPLS TE tunnel traverses.
To establish an MPLS TE tunnel over a static CRLSP, you must configure the tunnel to use the static CRLSP by using the mpls te static-cr-lsp command.
# Use RSVP-TE to establish MPLS TE tunnel 1.
[Sysname-Tunnel1] mpls te signaling rsvp-te
Use mpls te static-cr-lsp to specify a static CRLSP for a tunnel.
Use undo mpls te static-cr-lsp to remove the configuration.
mpls te static-cr-lsp lsp-name
undo mpls te static-cr-lsp lsp-name
A tunnel does not use any static CRLSP.
lsp-name: Specifies a static CRLSP by its name, a case-sensitive string of 1 to 15 characters.
This command takes effect only when the mpls te signaling static command has been configured in tunnel interface view.
Execute this command on the ingress node. The static CRLSP specified must have been created by using the static-cr-lsp ingress command.
# Configure tunnel 1 to use static CRLSP static-te-3.
[Sysname-Tunnel1] mpls te static-cr-lsp static-te-3
mpls te signaling
static-cr-lsp egress
static-cr-lsp transit
mpls te timer retry
Use mpls te timer retry to set the tunnel setup retry interval.
Use undo mpls te timer retry to restore the default.
mpls te timer retry seconds
The retry interval is 2 seconds.
seconds: Specifies the interval at which MPLS TE tries to re-establish the tunnel, in the range of 1 to 604800 seconds.
After failing to establish an MPLS TE tunnel, the tunnel ingress node waits for the tunnel setup retry interval. Then, it tries to set up the tunnel until the tunnel is established successfully. If the tunnel cannot be established when the number of attempts reaches the maximum (configured by the mpls te retry command), the ingress waits for a longer period. Then, it repeats the previous process.
# Set the setup retry interval to 20 seconds for tunnel 1.
[Sysname-Tunnel1] mpls te timer retry 20
mpls te retry
nexthop
Use nexthop to add or modify a node in an explicit path, and configure the attributes of the node.
Use undo nexthop to delete a node in an explicit path.
nexthop [ index index-number ] ip-address [ exclude | include [ loose | strict ] ]
undo nexthop index index-number
An explicit path does not include any nodes.
Explicit path view
index index-number: Specifies an index for the node in the explicit path, in the range of 1 to 65535. If you do not specify an index, MPLS TE automatically calculates an index for the node, the value of which is the current maximum index value plus 100.
ip-address: Specifies a node by its IP address in dotted decimal notation.
exclude: Excludes the specified node from the explicit path.
include: Includes the specified node on the explicit path.
loose: Specifies the node as a loose node, which means the specified node and its previous hop can be indirectly connected.
strict: Specifies the node as a strict node, which means the node and its previous hop must be directly connected.
The IP address specified in this command can be one of the following:
· Link IP address—IP address of an interface on the device, identifying a link.
· Device LSR ID—Identifies the device.
The address of a strict node must be a link IP address. The address of a loose node can be a link IP address or the device LSR ID.
CSPF excludes the links or devices specified by exclude from path calculation, and uses the links specified by include in ascending order of indexes to establish a CRLSP.
When you execute the nexthop command, follow these guidelines:
· If you specify an existing index, the command modifies the IP address or attribute of the node identified by that index.
· If you specify neither include nor exclude, the include keyword is used by default.
· If you specify neither loose nor strict, the strict keyword is used by default.
# Exclude IP address 10.0.0.125 from MPLS TE explicit path path1.
[Sysname] explicit-path path1
[Sysname-explicit-path-path1] nexthop 10.0.0.125 exclude
display explicit-path
nhop-only
Use nhop-only to configure the PLR to create only link-protection bypass tunnels.
Use undo nhop-only to restore the default.
nhop-only
undo nhop-only
The PLR automatically creates both link-protection and node-protection bypass tunnels.
MPLS TE auto FRR view
Execution of the nhop-only command deletes all existing node-protection bypass tunnels automatically created for MPLS TE auto FRR.
# Configure the device to automatically create only link-protection bypass tunnels.
[Sysname] mpls te
[Sysname-te] auto-tunnel backup
[Sysname-te-auto-bk] nhop-only
auto-tunnel backup
tunnel-number
path-metric-type
Use path-metric-type to specify the link metric type to be used for path selection when a metric type is not explicitly specified for a tunnel.
Use undo path-metric-type to restore the default.
A tunnel uses TE metrics of links for path selection when no metric type is specified for the tunnel.
MPLS TE view
Each MPLS TE link has two metrics: IGP metric and TE metric. By correctly planning the two metrics, you can select different tunnels for different classes of traffic. For example, use the IGP metric to represent a link delay (a smaller IGP metric value indicates a lower link delay). Use the TE metric to represent a link bandwidth value (a smaller TE metric value indicates a bigger link bandwidth value).
You can establish two MPLS TE tunnels: Tunnel1 for voice traffic and Tunnel2 for video traffic. Configure Tunnel1 to use IGP metrics for path selection, and configure Tunnel2 to use TE metrics for path selection. As a result, the video traffic travels through the path that has larger bandwidth and the voice traffic travels through the path that has lower delay.
If you specify a metric type for a tunnel by using the mpls te path-metric-type command, the tunnel uses the specified metric type for path selection. If you do not specify a metric type, the tunnel uses the metric type specified by the path-metric-type command for path selection.
# Configure MPLS TE tunnels that are not explicitly specified with a metric type to use the IGP metric for path selection.
[Sysname] mpls te
[Sysname-te] path-metric-type igp
mpls te metric
pce address
Use pce address to configure an IP address for a PCE.
Use undo pce address to restore the default.
pce address ip-address
undo pce address
No PCE IP address is configured.
MPLS TE view
ip-address: Specifies the PCE IP address.
For the device to act as a PCE, use this command to specify a PCE IP address for the device.
As a best practice, configure the loopback interface address as the PCE address. For a PCE to be discovered, enable OSPF TE on the loopback interface to advertise the PCE address or manually specify the PCE on PCCs.
If no PCE address is configured, the local device can only act as a PCC and use the MPLS LSR ID to communicate with the PCE. A PCC sends a PCEP connection request to a PCE, but it does not accept a request from a PCE.
# Specify the local device as a PCE and configure the IP address for the PCE as 10.10.10.10.
[Sysname] mpls te
[Sysname-te] pce address 10.10.10.10
pce deadtimer
Use pce deadtimer to set the PCEP session deadtimer.
Use undo pce deadtimer to restore the default.
pce deadtimer value
undo pce deadtimer
The PCEP session deadtimer is 120 seconds.
MPLS TE view
value: Specifies the PCEP session deadtimer in the range of 0 to 255 seconds. Value 0 indicates that the PCEP session will never time out.
The local device sends the deadtimer setting to its peer. If the local device does not receive a PCEP message from its peer before the deadtimer expires, it tears down the PCEP session. Then, the local device tries to establish a new PCEP session to its peer.
The deadtimer must be greater than the keepalive interval.
# Set the PCEP session deadtimer to 180 seconds.
[Sysname] mpls te
[Sysname-te] pce deadtimer 180
display mpls te pce peer
pce keepalive
pce keepalive
Use pce keepalive to set the keepalive interval for PCEP sessions.
Use undo pce keepalive to restore the default.
pce keepalive interval
undo pce keepalive
The keepalive interval is 30 seconds.
MPLS TE view
interval: Specifies the keepalive interval in the range of 0 to 255 seconds. Value 0 indicates that no keepalive messages will be sent once the PCEP session is established.
If the keepalive interval for the local device is less than the min-keepalive setting on the peer device, the local device uses the peer's min-keepalive setting as the keepalive interval.
If the keepalive interval is set to 0 on the local device, configure the min-keepalive value as 0 on the peer device to avoid session establishment failure.
For more information about the min-keepalive setting, see the pce tolerance command.
# Set the keepalive interval to 60 seconds.
[Sysname] mpls te
[Sysname-te] pce keepalive 60
pce deadtimer
pce tolerance
pce request-timeout
Use pce request-timeout to set the path calculation request timeout time.
Use undo pce request-timeout to restore the default.
pce request-timeout value
The request timeout time is 10 seconds.
MPLS TE view
value: Specifies the request timeout time in the range of 5 to 100 seconds.
In EPC calculation, if a PCC does not receive a calculation reply within the configured timeout time, it resends calculation requests to the PCE until it receives a reply.
In BRPC calculation, if a PCC does not receive a calculation reply from the PCE within the configured timeout time, the PCC does not resend a request. If a PCE does not receive a calculation reply from its downstream PCE within the timeout time, it sends the local calculation result to its upstream device as a reply. The PCE does not wait for a reply from its downstream PCE.
# Set the request timeout time to 20 seconds.
[Sysname] mpls te
[Sysname-te] pce request-timeout 20
pce static
Use pce static to specify a PCE as a peer on a PCC or PCE.
Use undo pce static to delete the specified PCE peer.
pce static ip-address
undo pce static ip-address
No PCE peers exist.
MPLS TE view
ip-address: Specifies the IP address of a PCE peer.
# Specify the PCE 10.10.10.10 as a peer.
[Sysname] mpls te
[Sysname-te] pce static 10.10.10.10
display mpls te pce discovery
pce tolerance
Use pce tolerance to set the minimum acceptable keepalive interval and the maximum number of allowed unknown messages received from the peer.
Use undo pce tolerance to restore the default.
pce tolerance { min-keepalive value | max-unknown-messages value }
undo pce tolerance { min-keepalive | max-unknown-messages }
The minimum acceptable keepalive interval is 10 seconds, and the maximum number of allowed unknown messages in a minute is 5.
MPLS TE view
min-keepalive value: Specifies the minimum acceptable keepalive interval in the range of 0 to 255 seconds. Value 0 indicates that any keepalive interval is acceptable.
max-unknown-messages value: Limits the maximum number of allowed unknown messages in a minute, in the range of 0 to 16384. Value 0 indicates that no limit is enforced.
If the keepalive interval set on the peer device is less than the min-keepalive setting on the local device, the peer device uses the min-keepalive setting as the keepalive interval.
If the number of unknown messages received from the peer in a minute exceeds the max-unknown-messages setting on the local device, the local device tears down the PCEP session.
# Set the minimum acceptable keepalive interval to 20 seconds and the maximum number of allowed unknown messages to 10.
[Sysname] mpls te
[Sysname-te] pce tolerance min-keepalive 20
[Sysname-te] pce tolerance max-unknown-messages 10
pce keepalive
reset mpls te pce statistics
Use reset mpls te pce statistics to clear PCC and PCE statistics.
reset mpls te pce statistics [ ip-address ]
ip-address: Specifies a PCC or PCE by its IP address. If you do not specify this argument, the command clears statistics about all PCEs and PCCs.
# Clear statistics about PCE 10.10.10.10.
<Sysname> reset mpls te pce statistics 10.10.10.10
display mpls te pce statistics
snmp-agent trap enable te
Use snmp-agent trap enable te to enable SNMP notifications for MPLS TE.
Use undo snmp-agent trap enable te to disable SNMP notifications for MPLS TE.
SNMP notifications for MPLS TE are disabled.
This command enables generating SNMP notifications for MPLS TE upon MPLS TE tunnel status changes, as defined in RFC 3812. For MPLS TE event notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see the network management and monitoring configuration guide for the device.
# Enable SNMP notifications for MPLS TE.
[Sysname] snmp-agent trap enable te
te-subtlv
Use te-subtlv to specify the types of the sub-TLVs for carrying DS-TE parameters.
Use undo te-subtlv to restore the default.
te-subtlv { bw-constraint value | unreserved-subpool-bw value } *
undo te-subtlv { bw-constraint | unreserved-subpool-bw } *
The bw-constraint parameter is carried in sub-TLV 252, and the unreserved-subpool-bw parameter is carried in sub-TLV 251.
IS-IS view
bw-constraint value: Specifies the type value of the sub-TLV that carries the bandwidth constraints, in the range of 23 to 254.
unreserved-subpool-bw value: Specifies the type value of the sub-TLV that carries the unreserved subpool bandwidth, in the range of 23 to 254.
In prestandard mode, no standard sub-TLV type values are defined to carry DS-TE parameters. Different vendors might use different type values. To communicate with devices from other vendors, use this command to specify the sub-TLV type values.
This command takes effect when the DS-TE mode is prestandard. It does not take effect when the DE-TE mode is IETF.
# For IS-IS process 1, specify the sub-TLV type value 200 for bw-constraint, and 202 for unreserved-subpool-bw.
[Sysname] isis 1
[Sysname-isis-1] te-subtlv bw-constraint 200 unreserved-subpool-bw 202
display isis mpls te configured-sub-tlvs
timers removal unused
Use timers removal unused to set a removal timer for unused bypass tunnels.
Use undo timers removal unused to restore the default.
timers removal unused seconds
A bypass tunnel is removed after it is unused for 3600 seconds.
seconds: Specifies the period of time after which an unused bypass tunnel is removed, in the range of 300 to 604800 seconds. You can also set this argument to 0, which means not to remove unused bypass tunnels.
An automatically created bypass tunnel can protect multiple primary CRLSPs. A bypass tunnel is unused when the bypass tunnel is not bound to any primary CRLSP. When a bypass tunnel is unused for the period of time configured by this command, MPLS TE removes the bypass tunnel to release the occupied bandwidth and tunnel interface number.
Configure a removal timer according to your network conditions, with the following considerations:
· Save resources—If the timer value is too big, unused bypass tunnels occupy bandwidth and interface numbers for a long time.
· Keep network stability—If the timer value is too small, bypass tunnels might be set up and removed frequently.
# Set the removal timer to 60000 seconds (100 minutes) for unused bypass tunnels.
[Sysname] mpls te
[Sysname-te-auto-bk] timers removal unused 60000
auto-tunnel backup
tunnel-number
tunnel-number
Use tunnel-number to specify an interface number range for automatically created bypass tunnels.
Use undo tunnel-number to restore the default.
tunnel-number min min-number max max-number
undo tunnel-number
No interface number range is specified, and the PLR cannot set up a bypass tunnel automatically.
min min-number max max-number: Specifies a range of interface numbers for automatically created bypass tunnels. The value range is 1 to 4095 for both the min-number and max-number arguments. The min-number must be smaller than or equal to the max-number, and the specified interface number range must include no more than 1000 interface numbers.
To enable the PLR to automatically create bypass tunnels, you must perform the following tasks:
1. Enable auto FRR globally by using the auto-tunnel backup command.
2. Specify the interface number range for bypass tunnels by using the tunnel-number command.
The PLR uses the interface numbers in the specified range in ascending order for the bypass tunnels.
When you use the tunnel-number command, follow these restrictions and guidelines:
· If you execute this command multiple times, the most recent configuration takes effect.
· If bypass tunnels are already created automatically, make sure the min-number is not greater than the minimum interface number used by the existing bypass tunnels. The max-number is not smaller than the maximum interface number used by the existing bypass tunnels.
· The interface number range specified by this command can include the interface numbers used by the tunnel interfaces created by the interface tunnel command. However, those interface numbers cannot be used for bypass tunnels, unless they are released by the undo interface tunnel command.
# Specify interface numbers 100 to 120 for automatically created bypass tunnels.
[Sysname] mpls te
[Sysname-te-auto-bk] tunnel-number min 100 max 120
auto-tunnel backup
