06-Layer 3—IP Routing Command Reference
HomeSupportSwitchesH3C S7500X Switch SeriesReference GuidesCommand ReferencesH3C S7500X Switch Series Command References-Release7634Pxx-6W10006-Layer 3—IP Routing Command Reference
11-IPv6 policy-based routing commands
11-IPv6 policy-based routing commands 138.33 KB
apply default-next-hop
Use apply default-next-hop to set default next hops.
Use undo apply default-next-hop to remove default next hops.
apply default-next-hop [ vpn-instance vpn-instance-name ] { ipv6-address [ direct ] [ track track-entry-number ] [ service-chain path-id service-path-id [ path-index service-path-index ] ] }&<1-8>
undo apply default-next-hop [ [ vpn-instance vpn-instance-name ] ipv6-address&<1-8> ]
No default next hop is set.
IPv6 policy node view
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. The specified VPN instance must already exist.
ipv6-address: Specifies the IPv6 address of the default next hop. If you do not specify the vpn-instance vpn-instance-name option, the default next hop belongs to the public network.
direct: Specifies a directly connected default next hop.
track track-entry-number: Specifies a track entry by its number in the range of 1 to 1024.
service-chain path-id service-path-id: Specifies a service chain by its path ID. A path ID uniquely identifies a service chain, and its value range is 1 to 16777215.
path-index service-path-index: Specifies a node in the service chain as a default next hop by its index in the range of 1 to 255.
&<1-8>: Indicates that the argument before it can be entered up to eight times.
You can specify multiple default next hops for backup or load sharing in one command line or by executing this command multiple times.
With a default next hop specified, the undo apply default-next-hop command removes the default next hop.
Without any default next hop specified, the undo apply default-next-hop command removes all default next hops.
To set multiple default next hops and specify their service chain parameters (service chain path ID and node index), follow these guidelines:
·     If the next hops are used in different service chains, use the apply default-next-hop command to specify the service chain parameters.
·     If the next hops are used in the same service chain, use the apply service-chain command to specify the service chain parameters as a best practice.
·     On an IPv6 policy node, you cannot configure both the apply default-next-hop command with the service chain parameters and the apply service-chain command.
Before executing this command, make sure the default route is configured.
Service modules operating in IPv6 mode do not support this command. For more information about the operating modes of service modules, see device management configuration in Fundamentals Command Reference.
If you configure both the apply default-next-hop and if-match service-chain commands on an IPv6 policy node, you cannot specify the policy for IPv6 interface PBR on a Layer 3 interface.
If you specify service chain parameters for this command, the apply loadshare { default-next-hop | next-hop } command does not take effect.
# Set a directly-connected default next hop of 1:1::1:1.
[Sysname] ipv6 policy-based-route aa permit node 11
[Sysname-pbr6-aa-11] apply default-next-hop 1:1::1:1 direct
apply loadshare
apply service-chain
apply default-output-interface
Use apply default-output-interface to set default output interfaces.
Use undo apply default-output-interface to remove default output interfaces.
apply default-output-interface null 0 [ track track-entry-number ]
undo apply default-output-interface [ null 0 ]
No default output interface is set.
null 0: Specifies interface Null 0.
You can specify only Null 0 as the default output interface.
# Specify Null 0 as the default output interface for IPv6 packets.
[Sysname-pbr6-aa-11] apply default-output-interface null 0
apply loadshare
Use apply loadshare to enable load sharing among multiple next hopsor default next hops.
Use undo apply loadshare to restore the default.
apply loadshare { default-next-hop | next-hop}
undo apply loadshare { default-next-hop | next-hop }
Multiple next hops or default next hops operate in primary/backup mode.
default-next-hop: Enables load sharing among multiple default next hops.
next-hop: Enables load sharing among multiple next hops.
Multiple next hop or default next hops options operate in either primary/backup or load sharing mode.
·     Primary/backup mode—One option is selected from all options in configuration order for packet forwarding, with all remaining options as backups. For example, if multiple next hops are configured, the first configured next hop is selected. When the selected next hop fails, the next available next hop takes over.
·     Load sharing mode—Matching traffic is distributed across the available options. Multiple next hops load share traffic in round robin manner, starting from the first configured option. They perform per-packet load sharing for traffic that does not match any fast forwarding entry, and perform per-flow load sharing for traffic that matches a fast forwarding entry.
If you configure both the apply service-chain and apply loadshare { default-next-hop | next-hop } commands, the apply loadshare { default-next-hop | next-hop } command does not take effect.
If you specify service chain parameters for the apply next-hop or apply default-next-hop command, the apply loadshare { default-next-hop | next-hop } command does not take effect.
Multiple default next hops implement load sharing in the same way as multiple next hops.
# Enable load sharing among multiple next hops.
[Sysname-pbr6-aa-11] apply next-hop 1::1 2::2
[Sysname-pbr6-aa-11] apply loadshare next-hop
# Enable load sharing among multiple default next hops.
[Sysname-pbr6-aa-11] apply default-next-hop 1::1 2::2
[Sysname-pbr6-aa-11] apply loadshare default-next-hop
apply next-hop
apply next-hop
Use apply next-hop to set next hops.
Use undo apply next-hop to remove next hops.
apply next-hop [ vpn-instance vpn-instance-name ] { ipv6-address [ direct ] [ track track-entry-number ] [ service-chain path-id service-path-id [ path-index service-path-index ] ] } &<1-8>
undo apply next-hop [ [ vpn-instance vpn-instance-name ] ipv6-address&<1-8> ]
No next hops are set.
ipv6-address: Specifies the IPv6 address of the next hop. If you do not specify the vpn-instance vpn-instance-name option, the next hop belongs to the public network.
direct: Specifies that the next hop must be directly connected to take effect.
path-index service-path-index: Specifies a node in the service chain as a next hop by its index in the range of 1 to 255.
You can specify multiple next hops for backup or load sharing in one command line or by executing this command multiple times.
With a next hop specified, the undo apply next-hop command removes the next hop.
Without any next hop specified, the undo apply next-hop command removes all next hops.
To set multiple next hops and specify their service chain parameters (service chain path ID and node index), follow these guidelines:
·     If the next hops are used in different service chains, use the apply next-hop command to specify the service chain parameters.
·     On an IPv6 policy node, you cannot configure both the apply next-hop command with the service chain parameters and the apply service-chain command.
If you specify service chain parameters for the apply next-hop command, the apply loadshare { default-next-hop | next-hop } command does not take effect.
# Set a directly-connected next hop of 1::1.
apply loadshare
apply service-chain
apply output-interface
Use apply output-interface to set output interfaces.
Use undo apply output-interface to remove output interfaces.
apply output-interface null 0 [ track track-entry-number ]
undo apply output-interface [ null 0 ]
No output interface is set.
null 0: Specifies Null 0 as the output interface.
You can specify only Null 0 as the output interface.
# Specify Null 0 as the output interface for IPv6 packets.
[Sysname-pbr6-aa-11] apply output-interface null 0
apply precedence
Use apply precedence to set a precedence for IPv6 packets.
Use undo apply precedence to restore the default.
No precedence is set for IPv6 packets.
type: Specifies the precedence type for IPv6 packets.
value: Specifies the precedence for IPv6 packets. Eight precedence values (0 to 7) are available. Each precedence value corresponds to a precedence type, as shown in Table 1. You can set either a precedence value or a precedence type for IPv6 packets.
Table 1 IP precedences and the corresponding types
Precedence value
Precedence type
0
routine
1
priority
2
immediate
3
flash
4
flash-override
5
critical
6
internet
7
network
# Set the precedence to 5 (critical) for IPv6 packets.
[Sysname]ipv6 policy-based-route aa permit node 11
[Sysname-pbr6-aa-11] apply precedence critical
apply service-chain
Use apply service-chain to set service chain information.
Use undo apply service-chain to restore the default.
apply service-chain path-id service-path-id [ path-index service-path-index ]
No service chain information is set.
path-id service-path-id: Specifies a service chain by its path ID in the range of 1 to 16777215. The path ID uniquely identifies a service chain.
path-index service-path-index: Specifies the path index of the node to which you are sending the matching packets. The value range for path indexes is 1 to 255. Specify this option if the destination node might receive packets from different nodes in the service chain. If the destination node receives packets only from the device, you do not need to specify this option.
If you configure both the apply service-chain and apply loadshare { default-next-hop | next-hop } commands, the apply loadshare command does not take effect.
# Set service chain path ID 1 and node index 10.
[Sysname] ipv6 policy-based-route aa permit node 5
[Sysname-pbr6-aa-5] apply service-chain path-id 1 path-index 10
apply statistics
Use apply statistics to enable counting successful matches on a policy node.
Use undo apply statistics to restore the default.
apply statistics
Counting successful policy node matches is disabled.
To include the number of successful matches on an IPv6 policy node in the statistics displayed by a display command, execute this command. As a best practice to conserve hardware resources, disable this counting function.
This apply clause is always executed for the IPv6 policy node.
# Enable counting successful matches on IPv6 policy node 1.
[Sysname] ipv6 policy-based-route 1 permit node 1
[Sysname-pbr6-1-1] apply statistics
description
Use description to configure a description for an IPv6 policy node.
No description is configured for an IPv6 policy node.
text: Specifies a description, a case-sensitive string of 1 to 127 characters.
# Configure the description as Officeuse for IPv6 policy node 1.
[Sysname-pbr6-1-1] description Officeuse
display ipv6 policy-based-route
Use display ipv6 policy-based-route to display IPv6 PBR policy information.
policy policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. If you do not specify a policy, this command displays information for all IPv6 PBR policies.
# Display all IPv6 policy information.
<Sysname> display ipv6 policy-based-route
Policy name: aaa
  node 1 permit:
    if-match acl 2000
    apply next-hop 1000::1
node 1 permit
The match mode of Node 1 is permit.
if-match acl
Compares IPv6 packets with IPv6 ACL.
apply next-hop
Specifies a next hop for permitted IPv6 packets.
ipv6 policy-based-route (system view)
display ipv6 policy-based-route global
Use display ipv6 policy-based-route global to display information about IPv6 global PBR, including its configuration and statistics.
In standalone mode:
display ipv6 policy-based-route global [ slot slot-number ]
In IRF mode:
display ipv6 policy-based-route global [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays information about IPv6 global PBR on the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays information about IPv6 global PBR on the global active MPU. (In IRF mode.)
# Display information about IPv6 global PBR.
<Sysname> display ipv6 policy-based-route global
Global policy-based routing information:
Policy name: aaa
  node 0 deny:
  Matches: 0, bytes: 0
  node 1 permit:
    if-match acl 3999
  node 2 permit:
    if-match acl 2000
    apply next-hop 1::1
  node 5 permit:
    if-match acl 3101
    apply next-hop 2::2
Total matches: 0, total bytes: 0
IPv6 global PBR configuration and statistics.
This field displays failed in brackets if none of the nodes in the policy has been successfully issued to the driver. To successfully issue the policy, you must remove the policy and then apply it again.
node 0 deny
node 2 permit
Match mode of the node, permit or deny.
If a node fails to be issued to the driver, the command displays the cause in brackets, which include:
·     not support—The device does not support the match criteria configured on the node.
·     no resource—No sufficient resources (for example, ACLs) are available for the node.
if-match acl
Compares packets with the ACL.
apply next-hop
Specifies a next hop for permitted packets.
apply output-interface track 1
Specifies an output interface for permitted packets.
This field displays the interface status in brackets.
·     down—The interface is down at the network layer.
·     inactive—The card that hosts the interface is not in position.
Matches
Number of successful matches on the node.
If the device does not support counting successful matches on a node, this field displays N/A.
If match counting is disabled on the node, this field is not displayed.
If the device does not have sufficient resources to count matches, this field displays no statistics resource in brackets.
bytes
Number of matching bytes on the node.
This field displays N/A if the device does not support counting matching bytes on a node.
This field is not displayed if match counting is disabled on the node.
Total matches
Total number of successful matches on all nodes.
This field displays N/A if the device does not support counting successful matches on a node.
This field is not displayed if match counting is disabled on all nodes.
total bytes
Total number of matching bytes on all nodes.
ipv6 global policy-based-route
display ipv6 policy-based-route interface
Use display ipv6 policy-based-route interface to display IPv6 interface PBR configuration and statistics.
In standalone mode:
display ipv6 policy-based-route interface interface-type interface-number [ slot slot-number ]
In IRF mode:
display ipv6 policy-based-route interface interface-type interface-number [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays IPv6 interface PBR configuration and statistics for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays IPv6 interface PBR configuration and statistics for the global active MPU. (In IRF mode.)
# Display IPv6 PBR configuration and statistics on VLAN-interface 2.
<Sysname> display ipv6 policy-based-route interface vlan-interface 2
Policy based routing information for interface Vlan-inerface2(failed):
Policy name: aaa
  node 0 deny:
  node 1 permit:
    if-match acl 3999
  node 2 permit:
    if-match acl 2000
  node 5 permit:
    if-match acl 3101
Policy based routing information for interface XXXX
IPv6 PBR configuration and statistics on the interface.
This field displays failed in brackets if none of the nodes in the policy has been successfully issued to the driver. To successfully issue the policy, you must remove the policy from the interface and then apply it on the interface again.
The failed status is available on a per-slot basis. To obtain this information, you must specify a slot number when you execute the command.
·     For a global interface (for example, a VLAN interface), which might have member physical interfaces on multiple slots, specify a slot that contains its member interfaces.
·     For a physical interface, specify its slot number.
node 0 deny
node 2 permit
The cause is available only on a per-slot basis. To obtain this information, you must specify a slot number when you execute the command.
if-match acl
Compares IPv6 packets with the IPv6 ACL.
apply next-hop
Matches
The statistics collection failure cause is available only on a per-slot basis. To obtain this information, you must specify a slot number when you execute the command.
bytes
Total matches
total bytes
ipv6 policy-based-route (interface view)
display ipv6 policy-based-route local
Use display ipv6 policy-based-route local to display IPv6 local PBR configuration and statistics.
In standalone mode:
display ipv6 policy-based-route local [ slot slot-number ]
In IRF mode:
display ipv6 policy-based-route local [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays IPv6 local PBR configuration and statistics for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays IPv6 local PBR configuration and statistics for the global active MPU. (In IRF mode.)
# Display IPv6 local PBR configuration and statistics.
<Sysname> display ipv6 policy-based-route local
Policy based routing information for local:
Policy name: aaa
  node 0 deny:
  node 1 permit:
    if-match acl 3999
  node 2 permit:
    if-match acl 2000
    apply next-hop 1::1
  node 5 permit:
    if-match acl 3101
    apply next-hop 2::2
Table 5 Command output
node 0 deny/node 2 permit
if-match acl
apply next-hop
Matches
bytes
Total matches
total bytes
ipv6 local policy-based-route
display ipv6 policy-based-route setup
Use display ipv6 policy-based-route setup to display IPv6 PBR configuration.
# Display IPv6 PBR configuration.
<Sysname> display ipv6 policy-based-route setup
Policy name              Type               Interface
pr01                     Forward            Vlan-interface 2
pr02                     Local              N/A
pr03                     Global             N/A
Table 6 Command output
Policy name
Policy name.
Type of the PBR:
·     Forward—Interface PBR.
·     Local—Local PBR.
·     Global—Global PBR.
Interface where the policy is applied.
This field displays N/A for IPv6 local PBR and IPv6 global PBR.
if-match acl
Use if-match acl to set an ACL match criterion.
Use undo if-match acl to restore the default.
undo if-match acl
No ACL match criterion is set.
ipv6-acl-number: Specifies an IPv6 ACL by its number in the range of 2000 to 3999. The value range of a basic ACL is 2000 to 2999 and that of an advanced ACL is 3000 to 3999.
name ipv6-acl-name: Specifies an IPv6 ACL by its name, a case-insensitive string of 1 to 63 characters starting with a letter. The ACL name cannot be all. For the command to take effect, make sure the specified IPv6 ACL is a basic or advanced ACL.
If the specified ACL does not exist or has no rules configured, no packets will match the ACL.
If the vpn-instance keyword is not specified for an ACL rule, the following situations will occur:
·     In an IPv6 interface or global PBR policy, the rule applies to both public network and VPN packets.
·     In an IPv6 local PBR policy, the rule applies to only public network packets.
# Configure Node 10 of policy aa to permit the packets matching ACL 2000.
[Sysname] ipv6 policy-based-route aa permit node 10
[Sysname-pbr6-aa-10] if-match acl 2000
# Configure Node 10 of policy aa to permit the packets matching ACL aaa.
[Sysname-pbr6-aa-10] if-match acl name aaa
if-match qos-local-id
Use if-match qos-local-id to set a local QoS ID match criterion.
Use undo if-match qos-local-id to restore the default.
if-match qos-local-id local-id-value qppb-manipulation
No local QoS ID match criterion is set.
local-id-value: Specifies a local QoS ID in the range of 1 to 4095. The device supports configuring only the values 1, 2, and 3 in the current software version.
# Match packets with local QoS ID 2.
[Sysname-pbr6-aa-11] if-match qos-local-id 2 qppb-manipulation
Use if-match service-chain to set a service chain match criterion.
Use undo if-match service-chain to restore the default.
if-match service-chain path-id service-path-id [ path-index service-path-index ]
undo if-match service-chain [ path-id service-path-id ]
No service chain match criteria are set.
path-index service-path-index: Specifies a node in the service chain by its index to match packets sent from that node. The value range for path indexes is 1 to 255. Specify this option if the device might receive packets from different nodes in the service chain. If only one node in the service chain sends packets to the device, you do not need to specify this option.
# Set a service chain match criterion to match packets with service chain path ID 1 and node index 10.
[Sysname-pbr6-aa-5] if-match service-chain path-id 1 path-index 10
apply service-chain
Use ipv6 global policy-based-route to specify a PBR policy as the IPv6 global PBR policy.
Use undo ipv6 global policy-based-route to restore the default.
ipv6 global policy-based-route policy-name
No policy is specified for IPv6 global PBR.
policy-name: Specifies a PBR policy by its name, a case-sensitive string of 1 to 19 characters. The specified policy must already exist.
IPv6 global PBR guides the forwarding of packets on all interfaces of the device.
You can specify only one policy for IPv6 global PBR on the device. Before you apply a new policy, you must first remove the current policy.
IPv6 interface PBR takes precedence over IPv6 global PBR on an interface. When they are both configured and packets fail to match the IPv6 interface PBR policy, IPv6 global PBR applies.
# Specify PBR policy aaa for IPv6 global PBR.
[Sysname] ipv6 global policy-based-route aaa
Use ipv6 local policy-based-route to configure IPv6 local PBR based on a specified policy.
Use undo ipv6 local policy-based-route to restore the default.
No policy is specified for IPv6 local PBR.
policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. The specified IPv6 policy must already exist.
You can apply only one policy locally. Before you apply a new policy, you must first remove the current policy.
IPv6 local PBR is used to route locally generated packets except the packets destined for the sender. This feature might affect local services. Do not configure IPv6 local PBR unless doing so is required.
# Configure IPv6 local PBR based on policy aaa.
[Sysname] ipv6 local policy-based-route aaa
Use ipv6 policy-based-route to configure IPv6 interface PBR by applying an IPv6 policy to an interface.
Use undo ipv6 policy-based-route to restore the default.
ipv6 policy-based-route policy-name
No IPv6 policy is applied to an interface.
Interface view
policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. The specified policy must already exist.
You cannot use this command on both a Layer 3 aggregate interface and its member ports.
# Apply policy aaa to VLAN-interface 2.
[Sysname-Vlan-interface2] ipv6 policy-based-route aaa
Use ipv6 policy-based-route to create an IPv6 policy node and enter its view, or enter the view of an existing IPv6 policy node.
Use undo ipv6 policy-based-route to delete an IPv6 policy or IPv6 policy node.
undo ipv6 policy-based-route policy-name [ deny | node node-number | permit ]
No IPv6 policy nodes exist.
policy-name: Specifies a policy name, a case-sensitive string of 1 to 19 characters.
deny: Specifies the match mode for the policy node as deny.
permit: Specifies the match mode for the policy node as permit (default mode).
node node-number: Specifies the number of the IPv6 policy node. A smaller number has a higher priority. The value range for the node-number argument is 0 to 65535.
To delete an IPv6 policy that has already applied to an interface, you must delete the policy from the interface first.
If a policy node is specified, the undo ipv6 policy-based-route command deletes the specified policy node. If a match mode is specified, the command deletes all nodes configured with the match mode. If no node is specified, the command deletes the whole policy.
# Create permit-mode Node 10 for IPv6 policy aaa and enter its view.
[Sysname] ipv6 policy-based-route aaa permit node 10
[Sysname-pbr6-aaa-10]
reset ipv6 policy-based-route statistics
Use reset ipv6 policy-based-route statistics to clear IPv6 PBR statistics.
policy policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. If you do not specify a policy, this command clears IPv6 PBR statistics for all policies.
# Clear all IPv6 PBR statistics.
<Sysname> reset ipv6 policy-based-route statistics
