09-High Availability Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C Configuration Guides-R63xx-6W10509-High Availability Configuration Guide
09-BFD configuration
09-BFD configuration 90.10 KB
Configuring BFD
About BFD
Bidirectional forwarding detection (BFD) provides a general-purpose, standard, medium- and protocol-independent fast failure detection mechanism. It can detect and monitor the connectivity of links in IP to detect communication failures quickly so that measures can be taken to ensure service continuity and enhance network availability.
BFD can uniformly and quickly detect the failures of the bidirectional forwarding paths between two devices for upper-layer protocols such as routing protocols. The hello mechanism used by upper-layer protocols needs seconds to detect a link failure, while BFD can provide detection measured in milliseconds.
BFD session establishment and termination
BFD does not provide any neighbor discovery mechanisms. The upper protocol notifies BFD of the routers to which it needs to establish sessions. After establishing a neighborship, the upper protocol notifies BFD of the neighbor information, including destination and source addresses. BFD uses the information to establish a BFD session.
When BFD detects a link failure, it performs the following tasks:
1.     BFD clears the neighbor session and notifies the protocol of the failure.
2.     The protocol terminates the neighborship on the link.
3.     If a backup link is available, the protocol will use it for communication.
Single-hop detection and multihop detection
BFD can be used for single-hop and multihop detections.
·     Single-hop detection—Detects the IP connectivity between two directly connected systems.
·     Multihop detection—Detects any of the paths between two systems. These paths have multiple hops, and might overlap.
BFD session modes
BFD sessions use echo packets and control packets.
Echo packet mode
Echo packets are encapsulated into UDP packets with port number 3785.
The local end of the link sends echo packets to establish BFD sessions and monitor link status. The peer end does not establish BFD sessions and only forwards the packets back to the originating end. If the local end does not receive echo packets from the peer end within the detection time, it considers the session to be down.
In echo packet mode, BFD supports only single-hop detection and the BFD sessions are independent of the operating mode.
Control packet mode
Control packets are encapsulated into UDP packets with port number 3784 for single-hop detection or port number 4784 for multihop detection.
Both ends of the link exchange BFD control packets to monitor link status.
Before a BFD session is established, BFD has two operating modes—active and passive.
·     Active mode—BFD actively sends BFD control packets regardless of whether any BFD control packet is received from the peer.
·     Passive mode—BFD does not send control packets until a BFD control packet is received from the peer.
At least one end must operate in active mode for a BFD session to be established.
After a BFD session is established, the two ends can operate in the following BFD operating modes:
·     Asynchronous mode—The device periodically sends BFD control packets. The device considers that the session is down if it does not receive any BFD control packets within a specific interval.
·     Demand mode—The device periodically sends BFD control packets. If the peer end is operating in Asynchronous mode (default), the peer end stops sending BFD control packets. If the peer end is operating in Demand mode, both ends stop sending BFD control packets. When the connectivity to another system needs to be verified explicitly, a system sends several BFD control packets with the Poll (P) bit set at the negotiated transmit interval. If no response is received within the detection interval, the session is considered down. If the connectivity is found to be up, no more BFD control packets are sent until the next command is issued.
Supported features
Features
Reference
Static routing
OSPF
RIP
IP fast reroute (FRR)
Layer 3—IP Routing Configuration Guide
IPv6 static routing
OSPFv3
PIM
IP Multicast Configuration Guide
Track
"Configuring Track"
Ethernet link aggregation
Layer 2—LAN Switching Configuration Guide
Protocols and standards
·     RFC 5880, Bidirectional Forwarding Detection (BFD)
·     RFC 5881, Bidirectional Forwarding Detection (BFD) for IPv4 and IPv6 (Single Hop)
·     RFC 5882, Generic Application of Bidirectional Forwarding Detection (BFD)
·     RFC 5883, Bidirectional Forwarding Detection (BFD) for Multihop Paths
·     RFC 7130, Bidirectional Forwarding Detection (BFD) on Link Aggregation Group (LAG) Interfaces
Restrictions and guidelines: BFD configuration
·     By default, the device runs BFD version 1 and is compatible with BFD version 0. You cannot change the BFD version to 0 through commands. When the peer device runs BFD version 0, the local device automatically switches to BFD version 0.
·     After a BFD session is established, the two ends negotiate BFD parameters, including minimum sending interval, minimum receiving interval, initialization mode, and packet authentication, by exchanging negotiation packets. They use the negotiated parameters without affecting the session status.
·     BFD session flapping might occur on an aggregate interface with member ports on different IRF member devices. When the master device, which receives and sends BFD packets, is removed or restarted, a subordinate device might not immediately take over. For example, a subordinate device will not take over when the subordinate device has a short detection time or a large number of BFD sessions.
·     In an IRF fabric, if the detection time is smaller than the IRF link down report delay, the BFD session might flap. To prevent this problem, set the IRF link down report delay to be smaller than the detection time. For information about setting the IRF link down report delay, see IRF configuration in Virtual Technologies Configuration Guide.
Configuring echo packet mode
2.     Configure the source IP address of echo packets.
¡     Configure the source IP address of echo packets.
bfd echo-source-ip ip-address
By default, no source IPv4 address is configured for echo packets.
As a best practice, do not configure the source IPv4 address to be on the same network segment as any local interface's IPv4 address. If you configure such a source IPv4 address, a large number of ICMP redirect packets might be sent from the peer, resulting in link congestion.
¡     Configure the source IPv6 address of echo packets.
By default, no source IPv6 address is configured for echo packets.
The source IPv6 address of echo packets can only be a global unicast address.
3.     (Optional.) Set the echo packet mode parameters.
a.     Enter interface view.
b.     Set the minimum interval for receiving BFD echo packets.
The default setting is 400 milliseconds.
c.     Set the detection time multiplier.
bfd detect-multiplier value
The default setting is 5.
Configuring control packet mode
After an upper-layer protocol is configured to support BFD, the device automatically creates BFD sessions in control packet mode. You do not need to perform this task.
BFD version 0 does not support the following commands:
·     bfd session init-mode.
·     bfd authentication-mode.
·     bfd demand enable.
·     bfd echo enable.
Configuring control packet mode for single-hop detection
2.     Specify the mode for establishing a BFD session.
By default, active is specified.
3.     Enter interface view.
4.     (Optional.) Configure the authentication mode for single-hop control packets.
bfd authentication-mode { hmac-md5 | hmac-mmd5 | hmac-msha1 | hmac-sha1 | m-md5 | m-sha1 | md5 | sha1 | simple } key-id { cipher cipher-string | plain plain-string }
By default, single-hop BFD packets are not authenticated.
5.     Enable the Demand BFD session mode.
bfd demand enable
By default, the BFD session is in Asynchronous mode.
6.     (Optional.) Enable the echo packet mode.
By default, the echo packet mode is disabled.
Configure this command for BFD sessions in which control packets are sent. When you enable the echo packet mode for such a session in up state, BFD periodically sends echo packets to detect link connectivity and decrease control packet receive rate.
7.     Set the minimum interval for transmitting and receiving single-hop BFD control packets.
¡     Set the minimum interval for transmitting single-hop BFD control packets.
¡     Set the minimum interval for receiving single-hop BFD control packets.
8.     Set the single-hop detection time multiplier.
9.     (Optional.) Create a BFD session for detecting the local interface state.
bfd detect-interface source-ip ip-address [ discriminator local local-value remote remote-value ] [ template template-name ]
By default, no BFD session is created for detecting the local interface state.
This command implements fast collaboration between interface state and BFD session state. When BFD detects a link fault, it sets the link layer protocol state to DOWN(BFD). This behavior helps applications relying on the link layer protocol state achieve fast convergence.
10.     (Optional.) Configure the timer that delays reporting the first BFD session establishment failure to the data link layer.
bfd detect-interface first-fail-timer seconds
By default, the first BFD session establishment failure is not reported to the data link layer.
11.     (Optional.) Enable special processing for BFD sessions.
bfd detect-interface special-processing [ admin-down | authentication-change | session-up ] *
By default, all types of special processing for BFD sessions are disabled.
Configuring control packet mode for multihop detection
3.     (Optional.) Configure the authentication mode for multihop BFD control packets.
bfd multi-hop authentication-mode { hmac-md5 | hmac-mmd5 | hmac-msha1 | hmac-sha1 | m-md5 | m-sha1 | md5 | sha1 | simple } key-id { cipher cipher-string | plain plain-string }
By default, no authentication is performed.
4.     Configure the destination port number for multihop BFD control packets.
The default setting is 4784.
5.     Set the multihop detection time multiplier.
6.     Set the minimum interval for transmitting and receiving multihop BFD control packets.
¡     Set the minimum interval for transmitting multihop BFD control packets.
¡     Set the minimum interval for receiving multihop BFD control packets.
Configuring a BFD template
About configuring a BFD template
Perform this task to specify BFD parameters in a template for sessions without next hops. You can configure BFD parameters for LSPs and PWs through a BFD template.
You can use a BFD template to adjust session parameters of BFD sessions used for detecting interface states.
2.     Create a BFD template and enter BFD template view.
bfd template template-name
3.     (Optional.) Configure the authentication mode for BFD control packets.
4.     Set the detection time multiplier.
5.     Set the minimum interval for transmitting and receiving BFD control packets.
¡     Set the minimum interval for transmitting BFD control packets.
¡     Set the minimum interval for receiving BFD control packets.
Enabling SNMP notifications for BFD
About SNMP notifications for BFD
To report critical BFD events to an NMS, enable SNMP notifications for BFD. For BFD event notifications to be sent correctly, you must also configure SNMP as described in Network Management and Monitoring Configuration Guide.
2.     Enable SNMP notifications for BFD.
snmp-agent trap enable bfd
By default, SNMP notifications are enabled for BFD.
Display and maintenance commands for BFD
Execute the display command in any view and the reset command in user view.
Display BFD session information.
display bfd session [ discriminator value | verbose ]
Clear BFD session statistics.
reset bfd session statistics
