- 08-ACL and QoS Configuration Examples
- 01-ACL Configuration Examples
- 02-Traffic Filtering Configuration Examples
- 03-Traffic Policing Configuration Examples
- 04-GTS and Rate Limiting Configuration Examples
- 05-Congestion Avoidance and Queue Scheduling Configuration Examples
- 06-Priority Mapping and Queue Scheduling Configuration Examples
- 07-Priority Marking and Queue Scheduling Configuration Examples
- 08-TAP Configuration Examples
| 08-TAP Configuration Examples | 186.72 KB |
Example: Configuring traffic monitoring and backup
Introduction
The test access point (TAP) feature can copy and forward traffic in real time without interrupting the traffic. Specifically, it copies traffic and sends a copy of the traffic to each of multiple monitoring devices for Internet access behavior analysis, abnormal traffic monitoring, and application monitoring
This document provides examples for configuring TAP.
This document assumes that you have basic knowledge of TAP.
As shown in Figure 1, configure TAP on the device to meet the following requirements:
· Add an outer VLAN tag to all traffic.
· Configure basic M:N copying to send each packet to both Server A (for analysis) and Server B (for backup).
Analysis
Configure a TAP policy to add VLAN ID 4094 to all packets and to copy the traffic on the input interfaces to both Server A and Server B.
Hardware |
Software version |
S9850-G switch series |
Not supported |
S6850-G switch series S6805-G switch series |
Not supported |
S6530X switch series |
Release 8108P22 and later |
S5590-HI switch series |
Not supported |
S5590-EI switch series S5500V3-HI switch series |
Not supported |
S6520X-EI-G switch series S6520XP-EI-G switch series |
Release 7748 and later |
S5590XP-HI-G switch series |
Not supported |
S5560-EI-G switch series |
S5130S-EI-G switch series |
S5500-D-G switch series S5100-D-G switch series |
Not supported |
S5130S-HI-G switch series |
Not supported |
S5130S-EI-G switch series (except S5130S-30C-EI-G and S5130S-54C-EI-G switches) |
Not supported |
S5130S-30C-EI-G switch S5130S-54C-EI-G switch |
Procedures
# Create monitoring group 1, and assign GigabitEthernet 1/0/4 and GigabitEthernet 1/0/5 to the monitoring group.
[DeviceB] monitoring-group 1
[DeviceB-monitoring-group-1] monitoring-port gigabitethernet 1/0/4 to gigabitethernet 1/0/5
[DeviceB-monitoring-group-1] quit
# Create a traffic class named classifier_tap, and configure the traffic class to match all packets.
[DeviceB] traffic classifier classifier_tap
[DeviceB-classifier-classifier_tap] if-match any
[DeviceB-classifier-classifier_tap] quit
# Create a traffic behavior named behavior_tap, and configure an action of adding an outer VLAN tag and an action of redirecting packets to monitoring group 1.
[DeviceB] traffic behavior behavior_tap
[DeviceB-behavior-behavior_tap] nest top-most vlan 4094
[DeviceB-behavior-behavior_tap] redirect monitoring-group 1
[DeviceB-behavior-behavior_tap] quit
# Create a TAP policy named policy_tap, and associate the traffic class with the traffic behavior in the TAP policy.
[DeviceB] qos tap policy policy_tap
[DeviceB-qospolicy-policy_tap] classifier classifier_tap behavior behavior_tap
[DeviceB-qospolicy-policy_tap] quit
# Applying the TAP policy to the inbound direction of GigabitEthernet 1/0/1.
[DeviceB-GigabitEthernet1/0/1] qos apply tap policy policy_tap inbound
# Applying the TAP policy to the inbound direction of GigabitEthernet 1/0/2.
[DeviceB-GigabitEthernet1/0/2] qos apply tap policy policy_tap inbound
# Applying the TAP policy to the inbound direction of GigabitEthernet 1/0/3.
[DeviceB] interface gigabitethernet 1/0/3
[DeviceB-GigabitEthernet1/0/3] qos apply tap policy policy_tap inbound
# Display TAP policies applied to interfaces.
[DeviceB] display qos tap policy interface
Direction: Inbound
Tap policy: policy_tap
Classifier: classifier_tap
Operator: AND
Rule(s) :
If-match any
Behavior: behavior_tap
Nesting:
Nest top-most vlan-id 4094
Redirecting:
Redirect to the monitoring group: 1
Direction: Inbound
Operator: AND
Rule(s) :
If-match any
Nesting:
Redirecting:
Interface: GigabitEthernet1/0/3
Direction: Inbound
Operator: AND
Rule(s) :
If-match any
Nesting:
Redirecting:
Configuration files
monitoring-group 1
monitoring-port GigabitEthernet1/0/4
monitoring-port GigabitEthernet1/0/5
traffic classifier classifier_tap operator and
if-match any
As shown in Figure 2, configure TAP on the device to meet the following requirements:
Analysis
Hardware |
Software version |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Procedures
# Create monitoring group 1, and assign Ten-GigabitEthernet 1/0/4 and Ten-GigabitEthernet 1/0/5 to the monitoring group.
[DeviceB-monitoring-group-1] monitoring-port ten-gigabitethernet 1/0/4 to ten-gigabitethernet 1/0/5
# Applying the TAP policy to the inbound direction of Ten-GigabitEthernet 1/0/1.
[DeviceB-Ten-GigabitEthernet1/0/1] qos apply tap policy policy_tap inbound
# Applying the TAP policy to the inbound direction of Ten-GigabitEthernet 1/0/2.
[DeviceB] interface ten-gigabitethernet 1/0/2
[DeviceB-Ten-GigabitEthernet1/0/2] qos apply tap policy policy_tap inbound
[DeviceB-Ten-GigabitEthernet1/0/2] quit
# Applying the TAP policy to the inbound direction of Ten-GigabitEthernet 1/0/3.
[DeviceB] interface ten-gigabitethernet 1/0/3
[DeviceB-Ten-GigabitEthernet1/0/3] qos apply tap policy policy_tap inbound
[DeviceB-Ten-GigabitEthernet1/0/3] quit
Direction: Inbound
Operator: AND
Rule(s) :
If-match any
Nesting:
Redirecting:
Interface: Ten-GigabitEthernet1/0/2
Direction: Inbound
Operator: AND
Rule(s) :
If-match any
Nesting:
Redirecting:
Interface: Ten-GigabitEthernet1/0/3
Direction: Inbound
Operator: AND
Rule(s) :
If-match any
Nesting:
Redirecting:
Configuration files
monitoring-group 1
monitoring-port Ten-GigabitEthernet1/0/4
monitoring-port Ten-GigabitEthernet1/0/5
if-match any
As shown in Figure 3, configure M:N copying and link aggregation load sharing on Device B to meet the following requirements:
· Incoming packets on GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 are redirected to the aggregate interface.
· The aggregate interface load shares packets based on source IP addresses and destination IP addresses.
· The aggregate interface sends incoming packets on GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 to Device D over the same link by using algorithm 1 as the link aggregation load sharing algorithm.
Hardware |
Software version |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Procedures
# Create a Layer 2 aggregate interface named Bridge-Aggregation 1.
[DeviceB] interface Bridge-Aggregation 1
[DeviceB-Bridge-Aggregation1] quit
# Assign GigabitEthernet 1/0/4, GigabitEthernet 1/0/5, and GigabitEthernet 1/0/6 to the aggregation group.
[DeviceB] interface gigabitethernet1/0/4
[DeviceB-GigabitEthernet1/0/4] port link-aggregation group 1
[DeviceB-GigabitEthernet1/0/4] quit
[DeviceB] interface gigabitethernet1/0/5
[DeviceB-GigabitEthernet1/0/5] port link-aggregation group 1
[DeviceB-GigabitEthernet1/0/5] quit
[DeviceB] interface gigabitethernet1/0/6
[DeviceB-GigabitEthernet1/0/6] port link-aggregation group 1
[DeviceB-GigabitEthernet1/0/6] quit
# Create monitoring group 1, and assign the Layer 2 aggregate interface to the monitoring group.
[DeviceB-monitoring-group-1] monitoring-port bridge-aggregation 1
# Create a traffic behavior named behavior_tap, and configure an action of redirecting packets to monitoring group 1.
# Set the global load sharing mode to load share packets based on source IP addresses and destination IP addresses.
[DeviceB] link-aggregation global load-sharing mode source-ip destination-ip
# Specify algorithm 1 as the link aggregation load sharing algorithm.
[DeviceB] link-aggregation global load-sharing algorithm 1
Direction: Inbound
Operator: AND
Rule(s) :
If-match any
Redirecting:
Direction: Inbound
Operator: AND
Rule(s) :
If-match any
Redirecting:
Direction: Inbound
Operator: AND
Rule(s) :
If-match any
Redirecting:
# Display monitoring groups.
[DeviceB] display monitoring-group all
Monitoring group 1:
Monitoring ports: Bridge-Aggregation1
# Display the load sharing mode.
[DeviceB] display link-aggregation load-sharing mode
Link-aggregation load-sharing algorithm:1
Link-aggregation load-sharing mode:
destination-ip address, source-ip address
Configuration files
link-aggregation global load-sharing mode destination-ip source-ip
monitoring-group 1
monitoring-port Bridge-Aggregation1
if-match any
interface Bridge-Aggregation1
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
As shown in Figure 4, configure M:N copying and link aggregation load sharing on Device B to meet the following requirements:
· Incoming packets on Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2 are redirected to the aggregate interface.
· The aggregate interface sends incoming packets on Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2 to Device D over the same link by using algorithm 1 as the link aggregation load sharing algorithm.
Hardware |
Software version |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Procedures
# Assign Ten-GigabitEthernet 1/0/4, Ten-GigabitEthernet 1/0/5, and Ten-GigabitEthernet 1/0/6 to the aggregation group.
[DeviceB] interface ten-gigabitethernet1/0/4
[DeviceB-Ten-GigabitEthernet1/0/4] port link-aggregation group 1
[DeviceB-Ten-GigabitEthernet1/0/4] quit
[DeviceB] interface ten-gigabitethernet1/0/5
[DeviceB-Ten-GigabitEthernet1/0/5] port link-aggregation group 1
[DeviceB-Ten-GigabitEthernet1/0/5] quit
[DeviceB] interface ten-gigabitethernet1/0/6
[DeviceB-Ten-GigabitEthernet1/0/6] port link-aggregation group 1
[DeviceB-Ten-GigabitEthernet1/0/6] quit
Direction: Inbound
Operator: AND
Rule(s) :
If-match any
Redirecting:
Direction: Inbound
Operator: AND
Rule(s) :
If-match any
Redirecting:
Direction: Inbound
Operator: AND
Rule(s) :
If-match any
Redirecting:
Monitoring group 1:
Configuration files
monitoring-group 1
if-match any
interface Ten-GigabitEthernet1/0/4
interface Ten-GigabitEthernet1/0/5
interface Ten-GigabitEthernet1/0/6
