15-User Access and Authentication
HomeSupportReference GuidesMIB CompanionH3C S6805 & S6825 & S6850 & S9850 & S9820-64H MIB Companion-Release 671x-6W10015-User Access and Authentication
01-HH3C-DOMAIN-MIB
01-HH3C-DOMAIN-MIB 59.58 KB
HH3C-DOMAIN-MIB
About this MIB
Use this MIB to manage domains.
MIB file name
hh3c-domain.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cDomain(46)
Scalar objects
hh3cDomainControl
Object (OID)
Access
Value range
Implementation
hh3cDomainDefault (1.3.6.1.4.1.25506.2.46.1.1)
read-write
OCTET STRING
SIZE (1..255)
Name of the default domain.
Default: system.
(Comware 5) Default: 24.
hh3cDomainGlobalStat
Object (OID)
Access
Value range
Implementation
Tabular objects
hh3cDomainInfoTable
About this table
Use this table to configure or obtain ISP domain settings.
Support for operations
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table index is hh3cDomainName.
Object (OID)
Access
Value range
Implementation
hh3cDomainName (1.3.6.1.4.1.25506.2.46.2.1.1.1)
read-only
OCTET STRING
SIZE (0..255)
Name of a domain.
String of 1 to 64 characters.
hh3cDomainState (1.3.6.1.4.1.25506.2.46.2.1.1.2)
read-create
INTEGER
active(1)
block(2)
Status of the domain.
As per the MIB.
hh3cDomainRowStatus (1.3.6.1.4.1.25506.2.46.2.1.1.14)
read-create
RowStatus
Standard MIB values.
Row status.
The following values are supported:
·     active(1).
·     createAndGo(4).
·     destroy(6).
hh3cDomainSchemeTable
About this table
This table contains AAA schemes for a domain. By default, a domain has only a local scheme.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table indexes are hh3cDomainName and hh3cDomainSchemeIndex.
Object (OID)
Access
Value range
Implementation
hh3cDomainSchemeIndex (1.3.6.1.4.1.25506.2.46.2.2.1.1)
not-accessible
Integer32
Index of an AAA scheme.
As per the MIB.
hh3cDomainSchemeMode (1.3.6.1.4.1.25506.2.46.2.2.1.2)
read-create
H3cModeOfDomainScheme
INTEGER{
none(1)
local(2)
radius(3)
tacacs(4)
ldap(5)
Mode of the AAA scheme.
As per the MIB.
hh3cDomainAuthSchemeName (1.3.6.1.4.1.25506.2.46.2.2.1.3)
read-create
OCTET STRING
OCTET STRING (SIZE (0..32))
Name of the authentication scheme.
This object has been replaced by hh3cDomainSchemeAAAName. Its value will be ignored.
hh3cDomainAcctSchemeName (1.3.6.1.4.1.25506.2.46.2.2.1.4)
read-create
OCTET STRING
Name of the accounting scheme.
hh3cDomainSchemeRowStatus (1.3.6.1.4.1.25506.2.46.2.2.1.5)
read-create
RowStatus
Row status.
·     active(1).
·     createAndGo(4).
·     destroy(6).
hh3cDomainSchemeAAAType (1.3.6.1.4.1.25506.2.46.2.2.1.6)
read-create
Hh3cAAATypeDomainScheme
INTEGER{
accounting(1)
authentication(2)
authorization(3)
none(4)
Service type of the server, accounting, authentication, or authorization.
As per the MIB.
hh3cDomainSchemeAAAName (1.3.6.1.4.1.25506.2.46.2.2.1.7)
read-create
OCTET STRING
Scheme name of the domain.
If the hh3cDomainSchemeMode is RADIUS, TACACS, or LDAP scheme mode, you must specify a valid scheme name.
If the hh3cDomainSchemeMode is none or local, the object will be ignored. When read, this object returns a zero-length string.
hh3cDomainSchemeAccessMode (1.3.6.1.4.1.25506.2.46.2.2.1.8)
read-create
Hh3cAccessModeofDomainScheme
INTEGER{
default(1)
login(2)
lanAccess(3)
portal(4)
ppp(5)
gcm(6)
dvpn(7)
dhcp(8)
voice(9)
superauthen(10)
command(11)
reserved(12)
Access mode of the scheme for the domain.
Supports only the value default.
hh3cDomainStatTable
About this table
This table contains statistics for a domain.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cDomainOnlineIPoEUser (1.3.6.1.4.1.25506.2.46.2.4.1.4)
read-only
Unsigned32
Number of online IPoE users in the domain.
As per the MIB.
hh3cDomainOnlinePPPoEUser (1.3.6.1.4.1.25506.2.46.2.4.1.5)
read-only
Unsigned32
Number of online PPPoE users in the domain.
As per the MIB.
hh3cDomainOnlinePPPoAUser (1.3.6.1.4.1.25506.2.46.2.4.1.6)
read-only
Unsigned32
Number of online PPPoA users in the domain.
As per the MIB.
hh3cDomainOnlineLacUser (1.3.6.1.4.1.25506.2.46.2.4.1.8)
read-only
Unsigned32
Number of online LAC users in the domain.
As per the MIB.
hh3cDomainIPPoolStatTable
About this table
This table contains IP pool statistics for a domain.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
