| 05-MPLS L3VPN commands | 286.02 KB |
address-family ipv4 (public instance view)
address-family ipv4 (VPN instance view)
description (VPN instance view)
display bgp routing-table ipv4 unicast inlabel
display bgp routing-table ipv4 unicast outlabel
display bgp routing-table vpnv4
display bgp routing-table vpnv4 inlabel
display bgp routing-table vpnv4 outlabel
ext-community-type (OSPF view)
route-distinguisher (VPN instance view)
route-replicate (public instance IPv4 address family view)
route-replicate (VPN instance IPv4 address family view)
rr-filter (BGP VPNv4 address family view)
MPLS L3VPN commands
Use address-family ipv4 to enter public instance IPv4 address family view.
Use undo address-family ipv4 to remove all configurations from public instance IPv4 address family view.
address-family ipv4
Public instance view
# Enter public instance IPv4 address family view.
[Sysname] ip public-instance
[Sysname-public-instance] address-family ipv4
[Sysname-public-instance-ipv4]
Use address-family ipv4 to enter VPN instance IPv4 address family view.
Use undo address-family ipv4 to remove all configurations from VPN instance IPv4 address family view.
address-family ipv4
VPN instance view
In VPN instance IPv4 address family view, you can configure IPv4 VPN parameters such as inbound and outbound routing policies.
# Enter VPN instance IPv4 address family view.
[Sysname-vpn-instance-vpn1] address-family ipv4
[Sysname-vpn-ipv4-vpn1]
advertise route-reoriginate
Use advertise route-reoriginate to re-originate the BGP unicast routes from other VPN instances.
Use undo advertise route-reoriginate to restore the default.
advertise route-reoriginate [ route-policy route-policy-name ] [ replace-rt ]
A VPN instance cannot re-originate the BGP unicast routes from other VPN instances.
BGP-VPN IPv4 unicast address family view
route-policy route-policy-name: Specifies a routing policy to filter the routes to be re-originated. The route-policy-name argument represents the name of the routing policy, a case-sensitive string of 1 to 63 characters.
replace-rt: Changes the route target attribute of re-originated routes to that of the current VPN instance. If you do not specify this keyword, re-originated routes use their original route target attributes.
By default, BGP routes in different VPN instances are isolated. In some networks, a device might need to advertise routes across VPN instances or advertise the routes in a VPN instance through other VPN instances to hide the routing information of the VPN instance.
After you configure this feature, the current VPN instance will re-originate the BGP unicast routes from other VPN instances that have the same route target as the current VPN instance. Locally redistributed routes (such as the IGP routes redistributed by using the import-route command) will not be re-originated. The re-originated routes can be advertised to BGP peers. You can also select whether to change the route target attributes of re-originated routes.
This command re-originates IPv4 unicast routes.
A route received from an IBGP peer will not be advertised to other IBGP peers after being re-originated. To advertise the route to IBGP peers, you must execute the peer advertise vpn-reoriginate ibgp command.
Both the advertise route-reoriginate and route-replicate enable commands can implement BGP route redistribution between different VPN instances. The differences are as follows:
· The advertise route-reoriginate command only re-originates BGP routes in VPN instances. The route-replicate enable command can replicate BGP routes in the public network to a VPN instance.
· After you execute the route-replicate enable command to replicate a route received from an IBGP peer to a VPN instance, the route cannot be advertised to other IBGP peers. You can execute the advertise route-reoriginate and peer advertise vpn-reoriginate ibgp commands together to re-originate the routes received from an IBGP peer and then advertise the re-originated routes to other IBGP peers.
You can execute the advertise route-reoriginate and route-replicate enable commands together to redistribute BGP routes in the public network to a VPN instance, re-originate the redistributed routes, and advertise the re-originated routes to any BGP peer.
# In VPN instance vpn1, re-originate the BGP unicast routes from other VPN instances.
[Sysname] bgp 100
[Sysname-bgp-default-vpn1] address-family ipv4
[Sysname-bgp-default-ipv4-vpn1] advertise route-reoriginate
peer advertise vpn-reoriginate ibgp (EVPN Command Reference)
dampening ibgp
Use dampening ibgp to configure BGP VPNv4 route dampening.
Use undo dampening ibgp to restore the default.
dampening ibgp [ half-life-reachable half-life-unreachable reuse suppress ceiling | route-policy route-policy-name ] *
undo dampening ibgp
BGP VPNv4 route dampening is not configured.
half-life-reachable: Specifies a half-life for active routes, in the range of 1 to 45 minutes. By default, the value is 15 minutes.
half-life-unreachable: Specifies a half-life for suppressed routes, in the range of 1 to 45 minutes. By default, the value is 15 minutes.
reuse: Specifies a reuse threshold value for suppressed routes, in the range of 1 to 20000. The default value is 750. A suppressed route whose penalty value decreases under the value is reused. The reuse threshold must be smaller than the suppression threshold.
suppress: Specifies a suppression threshold in the range of 1 to 20000. The default value is 2000. A route with a penalty value greater than this threshold is suppressed.
ceiling: Specifies a ceiling penalty value in the range of 1001 to 20000. The default value is 16000. The value must be greater than the suppression threshold.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters.
This command applies only to IBGP routes.
If an IBGP peer goes down after you configure this feature, VPNv4 routes coming from the peer are dampened but not deleted.
# In BGP VPNv4 address family view, configure BGP route dampening. Set the half-life for both active and suppressed routes to 10 minutes, the reuse threshold to 1000, the suppression threshold to 2000, and the ceiling penalty to 10000.
[Sysname] bgp 100
[Sysname-bgp-default-vpnv4] dampening ibgp 10 10 1000 2000 10000
display bgp dampening parameter (Layer 3—IP Routing Command Reference)
Use address-family vpnv4 in BGP view to create the BGP VPNv4 address family and enter its view, or enter the view of the existing BGP VPNv4 address family.
Use address-family vpnv4 in BGP-VPN instance view to create the BGP-VPN VPNv4 address family and enter its view, or enter the view of the existing BGP-VPN VPNv4 address family.
Use undo address-family vpnv4 to remove the BGP VPNv4 address family or BGP-VPN VPNv4 address family, and all settings in address family view.
The BGP VPNv4 address family or BGP-VPN VPNv4 address family does not exist.
BGP instance view
A VPNv4 address consists of an RD and an IPv4 prefix. VPNv4 routes are routes that carry VPNv4 addresses.
For a PE to exchange BGP VPNv4 routes with a BGP peer, enable that peer by executing the peer enable command in BGP VPNv4 or BGP-VPN VPNv4 address family view.
In BGP VPNv4 address family view, you can configure the following settings:
· BGP VPNv4 route attributes, such as the preferred value.
· Whether to allow the local AS number to appear in the AS_PATH attribute of received route updates.
The settings in BGP VPNv4 address family view control VPNv4 route exchange between PEs.
The settings in BGP-VPN VPNv4 address family view control VPNv4 route exchange between provider PE and provider CE in nested MPLS L3VPN.
# Create the BGP VPNv4 address family and enter its view.
[Sysname] bgp 100
Use description to configure a description for a VPN instance.
No description is configured for a VPN instance.
VPN instance view
text: Specifies a description, a case-sensitive string of 1 to 79 characters.
# Configure a description of This is vpn1 for VPN instance vpn1.
[Sysname-vpn-instance-vpn1] description This is vpn1
Use display bgp routing-table ipv4 unicast inlabel to display incoming labels for BGP IPv4 unicast routes.
display bgp [ instance instance-name ] routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] inlabel
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a BGP instance, this command displays incoming labels for BGP IPv4 unicast routes in the default BGP instance.
vpn-instance vpn-instance-name: Specifies a VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays incoming labels for BGP IPv4 unicast routes on the public network.
This command displays incoming labels for BGP IPv4 unicast routes regardless of whether the unicast keyword is specified or not.
# Display incoming labels for all BGP IPv4 unicast routes on the public network.
<Sysname> display bgp routing-table ipv4 inlabel
Total number of routes: 1
BGP local router ID is 3.3.3.9
a – additional-path
Network NextHop OutLabel InLabel
* > 2.2.2.9/32 1.1.1.2 1151 1279
BGP local router ID |
Router ID of the local BGP router. |
Status codes |
Route status codes: · * - valid—Valid route. · > - best—Common optimal route. · d – damped—Route damped for route flap. · h - history—History route. · i - internal—Internal route. · e - external—External route. · s - suppressed—Suppressed route. · S - Stale—Stale route. · a – additional-path—Add-Path optimal route. |
Origin |
Route origin: · i - IGP—Originated in the AS. The origin of routes advertised by the network command is IGP. · e - EGP—Learned through EGP. · ? - incomplete—Redistributed from IGP protocols. |
OutLabel |
Outgoing label. |
InLabel |
Incoming label. |
Use display bgp routing-table ipv4 unicast outlabel to display outgoing labels for BGP IPv4 unicast routes.
display bgp [ instance instance-name ] routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] outlabel
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a BGP instance, this command displays outgoing labels for BGP IPv4 unicast routes in the default BGP instance.
vpn-instance vpn-instance-name: Specifies a VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays outgoing labels for BGP IPv4 unicast routes on the public network.
This command displays outgoing labels for BGP IPv4 unicast routes regardless of whether the unicast keyword is specified or not.
# Display outgoing labels for all public BGP IPv4 unicast routes in the default BGP instance.
<Sysname> display bgp routing-table ipv4 outlabel
a – additional-path
Status codes |
Origin |
OutLabel |
Outgoing label. |
Use display bgp routing-table vpnv4 to display BGP VPNv4 routing information.
display bgp [ instance instance-name ] routing-table vpnv4 [ [ route-distinguisher route-distinguisher ] [ ipv4-address [ { mask-length | mask } [ longest-match ] ] | ipv4-address [ mask-length | mask ] advertise-info | ipv4-address [ mask-length | mask ] { as-path | cluster-list | community | ext-community } | [ vpn-instance vpn-instance-name ] peer ipv4-address { advertised-routes | received-routes } [ ipv4-address [ mask-length | mask ] | statistics ] | statistics ]
display bgp [ instance instance-name ] routing-table vpnv4 [ route-distinguisher route-distinguisher ] as-path-acl { as-path-acl-number | as-path-acl-name }
display bgp [ instance instance-name ] routing-table vpnv4 [ route-distinguisher route-distinguisher ] [ statistics ] community [ community-number&<1-32> | aa:nn&<1-32> ] [ internet | no-advertise | no-export | no-export-subconfed ] [ whole-match ]
display bgp [ instance instance-name ] routing-table vpnv4 [ route-distinguisher route-distinguisher ] [ statistics ] community-list basic-community-list-number | adv-community-list-number | comm-list-name } [ whole-match ]
display bgp [ instance instance-name ] routing-table vpnv4 [ route-distinguisher route-distinguisher ] [ statistics ] ext-community [ rt route-target | soo site-of-origin ]&<1-32> [ whole-match ]
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a BGP instance, this command displays BGP VPNv4 routes in the default BGP instance.
route-distinguisher route-distinguisher: Specifies an RD, a string of 3 to 21 characters in one of the following formats:
· 16-bit AS number:32-bit user-defined number. For example, 101:3.
· 32-bit IP address:16-bit user-defined number. For example, 192.168.122.15:1.
· 32-bit AS number:16-bit user-defined number, where the minimum value of the AS number is 65536. For example, 65536:1.
ipv4-address: Specifies the destination IPv4 address.
mask-length: Specifies the length of the network mask, in the range of 0 to 32.
mask: Specifies the network mask, in dotted decimal notation.
longest-match: Displays the longest matching BGP VPNv4 route. The longest matching BGP VPNv4 route is selected through the following steps:
1. ANDs the specified network address with the mask of each route.
2. Matches a route if the AND result is the same as the network address of the route and the mask of the route is shorter than or equal to the specified mask.
3. Selects the route with the longest mask among the matching routes.
advertise-info: Displays advertisement information for BGP VPNv4 routes.
as-path: Displays AS_PATH attribute information for the specified BGP VPNv4 unicast route.
cluster-list: Displays CLUSTER_LIST attribute information for the specified BGP VPNv4 unicast route.
community: Displays COMMUNITY attribute information for the specified BGP VPNv4 unicast route, or displays BGP VPNv4 unicast routes that match the specified community attribute.
ext-community: Displays extended community attribute information for the specified BGP VPNv4 unicast route, or displays BGP VPNv4 unicast routes that match the specified extended community attribute.
vpn-instance vpn-instance-name: Specifies a VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays BGP VPNv4 routes advertised to or received from the specified peer on the public network.
peer: Displays BGP VPNv4 routing information advertised to or received from a peer.
ipv4-address: Specifies the peer IPv4 address.
advertised-routes: Displays BGP VPNv4 routing information advertised to the specified peer.
received-routes: Displays BGP VPNv4 routing information received from the specified peer.
statistics: Displays BGP VPNv4 routing statistics.
as-path-acl as-path-acl-number: Displays BGP VPNv4 routes that match the AS path list specified by its number in the range of 1 to 256.
as-path-acl as-path-acl-name: Displays BGP VPNv4 routes that match the AS path list specified by its name, a case-sensitive string of 1 to 51 characters. The name cannot contain only digits.
community-number&<1-32>: Specifies a community sequence number. The value range for the community-number argument is 1 to 4294967295. &<1-32> indicates that a maximum of 32 numbers can be specified.
aa:nn&<1-32>: Specifies a community number. Both aa and nn are in the range of 0 to 65535. &<1-32> indicates that a maximum of 32 numbers can be specified.
internet: Displays BGP VPNv4 routes that have the INTERNET community attribute. Routes with this attribute can be advertised to all BGP peers. By default, all routes have this attribute.
no-advertise: Displays BGP VPNv4 routes that have the NO_ADVERTISE community attribute. Routes with this attribute cannot be advertised to any peers.
no-export: Displays BGP VPNv4 routes that have the NO_EXPORT community attribute. Routes with this attribute cannot be advertised outside the local AS or confederation, but can be advertised to other sub-ASs in the confederation.
no-export-subconfed: Displays BGP VPNv4 routes that have the NO_EXPORT_SUBCONFED community attribute. Routes with this attribute cannot be advertised outside the local AS or to other sub-ASs in the confederation.
whole-match: Displays BGP VPNv4 routes exactly matching the specified community list, community attribute, or extended community attribute. If you do not specify this keyword, the command displays BGP VPNv4 routes whose COMMUNITY attributes include the specified community list, community attribute, or extended community attribute.
community-list: Displays BGP VPNv4 routes that match a BGP community list.
basic-community-list-number: Specifies a basic community list by its number in the range of 1 to 99.
comm-list-name: Specifies a community list by its name, a case-sensitive string of 1 to 63 characters.
adv-community-list-number: Specifies an advanced community list by its number in the range of 100 to 199.
rt route-target: Specifies the Route Target (RT) extended community attribute. An RT is a string of 3 to 24 characters.
soo site-of-origin: Specifies the Site of Origin (SoS) extended community attribute. An SoO is a string of 3 to 24 characters.
An RT or SoS can be in one of the following formats:
· 16-bit AS number:32-bit user-defined number, for example, 101:3. The value range for the AS number is 0 to 65535. The value range for the user-defined number is 0 to 4294967295.
· 32-bit IP address:16-bit user-defined number, for example, 192.168.122.15:1. The value range for the user-defined number is 0 to 65535.
· 32-bit AS number:16-bit user-defined number, for example, 70000:3. The value range for the AS number is 65536 to 4294967295. The value range for the user-defined number is 0 to 65535.
· 32-bit IP address/IPv4 mask:16-bit user-defined number, for example, 192.168.122.15/24:1.
· 32-bit AS number in dotted notation:16-bit user-defined number, for example, 65535.65535:1.
&<1-32> indicates that a maximum of 32 extended community attribute values can be specified.
If you do not specify any parameters, this command displays brief information about all BGP VPNv4 routes.
If you specify ipv4-address mask or ipv4-address mask-length, this command displays detailed information about the BGP VPNv4 route that exactly matches the specified address and mask.
If you specify only ipv4-address, the system ANDs the network address with the mask of a route. If the result matches the network address of the route, this command displays detailed information about the BGP VPNv4 route.
If you do not specify the community-number, aa:nn, internet, no-advertise, no-export, and no-export-subconfed parameters, this command displays BGP VPNv4 routes that carry any community attributes regardless of whether the whole-match keyword is specified or not.
If you do not specify the color and rt parameters, this command displays BGP VPNv6 routes that carry any extended community attributes regardless of whether the whole-match keyword is specified or not.
# Display brief information about all BGP VPNv4 routes in the default BGP instance.
<Sysname> display bgp routing-table vpnv4
BGP local router ID is 1.1.1.9
a – additional-path
Total number of routes from all PEs: 8
Route distinguisher: 100:1(vpn1)
Total number of routes: 6
* > 10.1.1.0/24 10.1.1.2 0 32768 ?
* e 10.1.1.1 0 0 65410?
* > 10.1.1.2/32 127.0.0.1 0 32768 ?
* >i 10.3.1.0/24 3.3.3.9 0 100 0 ?
* >e 192.168.1.0 10.1.1.1 0 0 65410?
* i 3.3.3.9 0 100 0 65420?
Route distinguisher: 200:1
Total number of routes: 2
* >i 192.168.1.0 3.3.3.9 0 100 0 65420?
# Display brief information about BGP VPNv4 routes with RD 100:1 in the default BGP instance.
<Sysname> display bgp routing-table vpnv4 route-distinguisher 100:1
a – additional-path
# Display information about BGP VPNv4 routes matching AS_PATH list 1 in the default BGP instance.
<Sysname> display bgp routing-table vpnv4 as-path-acl 1
a – additional-path
# Display information about BGP VPNv4 routes matching BGP community list 100 in the default BGP instance.
<Sysname> display bgp routing-table vpnv4 community-list 100
a – additional-path
Network NextHop MED LocPrf PrefVal Path/Ogn Community
* > 10.1.1.0/24 10.1.1.2 0 32768 ? <1:2>
* e 10.1.1.1 0 0 65410? <1:2>
* > 10.1.1.2/32 127.0.0.1 0 32768 ? <1:2>
* >i 10.3.1.0/24 3.3.3.9 0 100 0 ? <1:2>
* >e 192.168.1.0 10.1.1.1 0 0 65410? <1:2>
* i 3.3.3.9 0 100 0 65420? <1:2>
* >i 192.168.1.0 3.3.3.9 0 100 0 65420? <1:2>
# Display information about public BGP VPNv4 routes advertised to peer 3.3.3.9 in the default BGP instance.
<Sysname> display bgp routing-table vpnv4 peer 3.3.3.9 advertised-routes
a – additional-path
Network NextHop MED LocPrf Path/Ogn
* > 10.1.1.0/24 10.1.1.2 0 ?
* >e 192.168.1.0 10.1.1.1 0 65410?
# Display information about public BGP VPNv4 routes received from peer 3.3.3.9 in the default BGP instance.
<Sysname> display bgp routing-table vpnv4 peer 3.3.3.9 received-routes
a – additional-path
# Display all BGP VPNv4 routes with a COMMUNITY attirbute.
a – additional-path
Total number of VPN routes: 2
Total number of routes from all PEs: 2
Network NextHop MED LocPrf PrefVal Community
* >i 10.3.1.0/24 3.3.3.9 0 100 0 <1:1>
# Display all BGP VPNv4 routes with an extended community attirbute.
<Sysname> display bgp routing-table vpnv4 ext-community
a – additional-path
Network NextHop MED LocPrf PrefVal Ext-Community
* >i 10.3.1.0/24 3.3.3.9 0 100 0 <RT 1:1>
Status codes |
Origin |
Total number of routes from all PEs |
Total number of VPNv4 routes from all PEs. |
Network |
Network address. |
NextHop |
Next hop address. |
MED |
MULTI_EXIT_DISC attribute. |
LocPrf |
Local preference value. |
PrefVal |
Preferred value. |
Path/Ogn |
AS_PATH and Origin attributes. |
Community |
COMMUNITY attribute. |
Ext-Community |
Extended community attribute. |
# Display detailed information about BGP VPNv4 routes to 10.3.1.0/24 in the default BGP instance.
<Sysname> display bgp routing-table vpnv4 10.3.1.0 24
BGP local router ID: 1.1.1.9
Local AS number: 100
Paths: 1 available, 1 best
Rely nexthop : 172.1.1.2
Original nexthop: 3.3.3.9
OutLabel : 1279
Ext-Community : <RT: 111:1>
RxPathID : 0x0
TxPathID : 0x0
AS-path : (null)
Origin : incomplete
State : valid, internal, best, remoteredist
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
Tunnel policy : NULL
Rely tunnel IDs : N/A
OutLabel : 1279
RxPathID : 0x0
TxPathID : 0x0
AS-path : (null)
Origin : incomplete
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
# Display detailed information about the BGP VPNv4 route to 10.3.1.0/24 and with RD 100:1 in the default BGP instance.
<Sysname> display bgp routing-table vpnv4 route-distinguisher 100:1 10.3.1.0 24
OutLabel : 1279
RxPathID : 0x0
TxPathID : 0x0
AS-path : (null)
Origin : incomplete
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
Connector : Type 1, Value 100:1:11.1.1.1
# Display COMMUNITY attribute information of the BGP VPNv4 routes in subnet 10.3.1.0/24.
<Sysname> display bgp routing-table vpnv4 10.3.1.0 24 community
Community: no-export
# Display extended community attribute information of the BGP VPNv4 routes in subnet 10.3.1.0/24.
<Sysname> display bgp routing-table vpnv4 10.3.1.0 24 ext-community
Ext-Community: <RT: 1:1>
# Display AS_PATH attribute information of the BGP VPNv4 routes in subnet 10.3.1.0/24.
<Sysname> display bgp routing-table vpnv4 10.3.1.0 24 as-path
As-path: 100
# Display CLUSTER_LIST attribute information of the BGP VPNv4 routes in subnet 10.3.1.0/24.
<Sysname> display bgp routing-table vpnv4 10.3.1.0 24 cluster-list
Cluster list: 80
Rely Nexthop |
Recursive next hop. If no recursive next hop is found, this field displays not resolved. |
Original nexthop |
Original next hop. If the route is learned from a BGP update, it is the next hop in the update message. |
Ext-Community |
Extended community attribute: · RT—Route Target extended community. · SOO—Site of Origin extended community. · CO-Flag—Color extended community. · Bandwidth—Link bandwdith extended community. |
Received Add-Path ID of the route. |
TxPathID |
Advertised Add-Path ID of the route. |
Origin |
Route origin: · igp—Originated in the AS. The origin of routes advertised by the network command is IGP. · egp—Learned through EGP. · incomplete—Redistributed from IGP protocols. |
Attribute value |
BGP route attribute information: · MED—MED attribute. · localpref—Local preference. · pref-val—Preferred value. · pre—Protocol preference. |
State |
Route status: · valid—Valid route. · internal—Internal route. · external—External route. · local—Locally generated route. · synchronize—Synchronized route. · best—Optimal route. · localredist—Routes replicated from other local VPN instances or the public instance to the current VPN instance. · remoteredist—Routes received from the remote end and then redistributed to the current VPN instance. |
IP precedence |
IP priority of a route, in the range of 0 to 7. N/A indicates that the route does not support this field. |
QoS local ID |
QoS local ID attribute of a route, in the range of 1 to 4095. N/A indicates that the route does not support this field. |
Traffic index |
Index of the traffic, in the range of 1 to 64. N/A indicates that the route does not support this field. |
Connector |
Connector attribute in form of Type 1, Value RD:IPv4 address, where RD represents the router ID and IPv4 address represents the IPv4 address of the source PE. This attribute is used to transmit the source PE address in MDT-based MVPN inter-AS option B. If a route does not contain this attribute, this field is not displayed. |
Tunnel policy |
Tunnel policy that takes effect. NULL indicates that no tunnel policy takes effect. |
Rely Tunnel IDs |
NHLFE IDs for tunnels found through route recursion. This field displays multiple NHLFE IDs if ECMP tunnels exist and displays N/A if route recursion does not occur. |
# Display advertisement information for BGP VPNv4 routes to 10.1.1.0/24 in the default BGP instance.
<Sysname> display bgp routing-table vpnv4 10.1.1.0 24 advertise-info
Paths: 1 best
BGP routing table information of 10.1.1.0/24(TxPathID:0):
3.3.3.9
Inlabel : 1279
Table 5 Command output
Paths |
Number of routes to the specified destination network. |
BGP routing table information of 10.1.1.0/24(TxPathID:0) |
Advertisement information for the BGP route to 10.1.1.0/24. |
Advertised to VPN peers (1 in total) |
VPNv4 peers to which the route is advertised, and the number of peers. |
Inlabel |
Incoming label of the route. |
# Display statistics about public BGP VPNv4 routes advertised to peer 3.3.3.9 in the default BGP instance.
<Sysname> display bgp routing-table vpnv4 peer 3.3.3.9 advertised-routes statistics
Advertised routes total: 2
# Display statistics about public BGP VPNv4 routes received from peer 3.3.3.9 in the default BGP instance.
<Sysname> display bgp routing-table vpnv4 peer 3.3.3.9 received-routes statistics
Received routes total: 2
Table 6 Command output
Advertised routes total |
Total number of routes advertised to the specified peer. |
Received routes total |
Total number of routes received from the specified peer. |
# Display statistics about public BGP VPNv4 routes in the default BGP instance.
<Sysname> display bgp routing-table vpnv4 statistics
# Display statistics about BGP VPNv4 routes matching community list 100.
<Sysname> display bgp routing-table vpnv4 statistics community-list 100
Total number of routes from all PEs: 0
Table 7 Command output
Total number of routes |
Total number of VPNv4 routes with the specified RD. |
ip as-path (Layer 3—IP Routing Command Reference)
Use display bgp routing-table vpnv4 inlabel to display incoming labels for BGP VPNv4 routes.
display bgp [ instance instance-name ] routing-table vpnv4 inlabel
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a BGP instance, this command displays incoming labels for all BGP VPNv4 routes in the default BGP instance.
# Display incoming labels for all BGP VPNv4 routes in the default BGP instance.
<Sysname> display bgp routing-table vpnv4 inlabel
a – additional-path
* > 10.1.1.0/24 10.1.1.2 NULL 1279
* >e 192.168.1.0 10.1.1.1 NULL 1278
Table 8 Command output
Status codes |
Origin |
OutLabel |
Outgoing label. If the peer PE assigns a null label, this field displays NULL. |
InLabel |
Incoming label. |
Use display bgp routing-table vpnv4 outlabel to display outgoing labels for BGP VPNv4 routes.
display bgp [ instance instance-name ] routing-table vpnv4 outlabel
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a BGP instance, this command displays outgoing labels for all BGP VPNv4 routes in the default BGP instance.
# Display outgoing labels for all BGP VPNv4 routes in the default BGP instance.
<Sysname> display bgp routing-table vpnv4 outlabel
a – additional-path
Total number of routes from all PEs: 4
* >i 10.3.1.0/24 3.3.3.9 1279
* i 192.168.1.0 3.3.3.9 1278
* >i 192.168.1.0 3.3.3.9 1278
Table 9 Command output
Status codes |
Origin |
OutLabel |
display ip vpn-instance
Use display ip vpn-instance to display information about VPN instances.
display ip vpn-instance [ instance-name vpn-instance-name ]
instance-name vpn-instance-name: Specifies a VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays brief information about all VPN instances.
# Display brief information about all VPN instances.
<Sysname> display ip vpn-instance
VPN-Instance Name RD Create time
abc 1:1 2019/12/18 10:48:17
Table 10 Command output
VPN-Instance Name |
Name of the VPN instance. |
RD |
RD of the VPN instance. |
Create Time |
Time when the VPN instance was created. |
# Display detailed information about VPN instance vpn1.
<Sysname> display ip vpn-instance instance-name vpn1
VPN-Instance Name and Index : vpn1, 2
Route Distinguisher : 100:1
VPN ID : 1:1
Description : vpn1
Interfaces : Vlan-interface2
Address-family IPv4:
Export VPN Targets :
2:2
Import VPN Targets :
3:3
Export Route Policy : outpolicy
Import Route Policy : inpolicy
Tunnel Policy : tunnel1
Maximum Routes Limit : 500
Threshold Value(%): 50
Table 11 Command output
Route Distinguisher |
Route distinguisher of the VPN instance. |
Interfaces |
Interfaces that are associated with the VPN instance. |
Address-family IPv4 |
IPv4 VPN information. |
Export Route Policy |
Routing policy in the outbound direction. |
Import Route Policy |
Routing policy in the inbound direction. |
Maximum Routes Limit |
Maximum number of routes. |
Threshold Value(%) |
Alarm threshold for number of active routes. |
display ospf sham-link
Use display ospf sham-link to display OSPF sham link information.
display ospf [ process-id ] sham-link [ area area-id ]
process-id: Specifies an OSPF process by its ID. The process ID is in the range of 1 to 65535. If you do not specify a process, this command displays sham link information for all OSPF processes.
area area-id: Specifies an OSPF area by its ID, which is an IP address, or an integer. The integer is in the range of 0 to 4294967295. If you do not specify an area, this command displays sham link information for all OSPF areas.
If you do not specify any processes or areas, this command displays information about all OSPF sham links.
# Display information about all OSPF sham links.
<Sysname> display ospf sham-link
OSPF Process 1 with Router ID 125.1.1.1
Sham link
Area Neighbor ID Source IP Destination IP State Cost
0.0.0.0 95.1.1.1 125.2.1.1 95.2.1.1 P-2-P 1
# Display OSPF sham link information for OSPF area 1.
<Sysname> display ospf sham-link area 1
OSPF Process 100 with Router ID 100.1.1.2
Sham link: 3.3.3.3 --> 5.5.5.5
Neighbor ID: 120.1.1.2 State: Full
Area: 0.0.0.1
Cost: 1 State: P-2-P Type: Sham
Request list: 0 Retransmit list: 0
GTSM: Enabled, maximum number of hops: 2
Cryptographic authentication: Enabled, inherited
The last key is 3.
The rollover is in progress, 1 neighbor(s) left.
Table 12 Command output
State |
Neighbor state for the sham link: Down, Init, 2-way, ExStart, Exchange, Loading, or Full. |
Cost |
Cost of the sham link. |
State |
Sham link state: Down or P-2-P. |
Timers |
Timers for the sham link, in seconds. The timers include Hello timer, Dead timer, Retransmit timer, and Transmit Delay timer. |
GTSM: Enabled, maximum number of hops: 2 |
OSPF GTSM is enabled, and the maximum number of hops is 2. If OSPF GTSM is disabled, this field displays GTSM: Disabled. |
Cryptographic authentication: Enabled |
HMAC-MD5/HMAC-SHA-256/HMAC-SM3/MD5 authentication is enabled. The inherited attribute indicates that the interface uses the authentication mode specified for the area to which the interface belongs. |
The last key |
The most recent HMAC-MD5/HMAC-SHA-256/HMAC-SM3/MD5 key. |
The rollover is in progress, xx neighbor(s) left |
HMAC-MD5/HMAC-SHA-256/HMAC-SM3/MD5 authentication smoothing is in progress. The number of neighbors that do not finish smoothing is xx. |
Simple authentication: Enabled |
Simple authentication is enabled. The inherited attribute indicates that the interface uses the authentication mode specified for the area to which the interface belongs. |
Keychain authentication: Enabled (yy) |
Keychain authentication is enabled. The keychain name is yy. The inherited attribute indicates that the interface uses the authentication mode specified for the area to which the interface belongs. |
No authentication is required |
None authentication is enabled. The sham link does not inherit the authentication configuration of its area. |
domain-id (OSPF view)
Use domain-id to set an OSPF domain ID.
Use undo domain-id to delete an OSPF domain ID.
undo domain-id [ domain-id ]
The OSPF domain ID is 0.
OSPF view
domain-id: Specifies an OSPF domain ID, in one of the following formats:
· Integer, in the range of 0 to 4294967295. For example, 1.
· Dotted decimal notation. For example, 0.0.0.1.
· Dotted decimal notation:16-bit user-defined number in the range of 0 to 65535. For example, 0.0.0.1:512.
secondary: Specifies a secondary domain ID. If you do not specify this keyword, the command specifies a primary domain ID.
When you redistribute OSPF routes into BGP, BGP adds the primary domain ID to the redistributed BGP VPNv4 routes as a BGP extended community attribute. Then, BGP advertises the routes to the peer PE.
When the peer PE receives the routes, it compares the OSPF domain ID in the routes with the locally configured primary and secondary domain IDs. OSPF advertises these routes in Network Summary LSAs (Type 3) if both the following conditions exist:
· The primary or secondary domain ID is the same as the received domain ID.
· The received routes are intra-area or inter-area routes.
Otherwise, OSPF advertises these routes in AS External LSAs (Type 5) or NSSA External LSAs (Type 7).
If you do not specify any parameters, the undo domain-id command restores the default.
# Set the OSPF domain ID to 234.
[Sysname] ospf 100
[Sysname-ospf-100] domain-id 234
export route-policy
Use export route-policy to apply an export routing policy to the public instance or a VPN instance.
Use undo export route-policy to restore the default.
No export routing policy is applied to the public instance or a VPN instance.
VPN instance view
Public instance IPv4 address family view
route-policy: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters.
You can specify an export routing policy to filter advertised routes or modify their route attributes for the public instance or a VPN instance.
An export routing policy specified in VPN instance view or public instance view applies to all address families in the VPN instance or public instance. An export routing policy specified in an address family view applies only to the address family.
An address family prefers the export routing policy specified in the address family view over the one specified in VPN instance view or public instance view.
# Apply export routing policy poly-1 to VPN instance vpn1.
[Sysname-vpn-instance-vpn1] export route-policy poly-1
import route-policy
route-policy (Layer 3—IP Routing Command Reference)
Use ext-community-type to configure the type code of an OSPF extended community attribute.
Use undo ext-community-type to restore the default.
undo ext-community-type [ domain-id | router-id | route-type ]
The type codes for domain ID, router ID, and route type are hex numbers 0005, 0107, and 0306, respectively.
OSPF view
domain-id type-code1: Specifies the type code for domain ID. Valid values are hex numbers 0005, 0105, 0205, and 8005.
router-id type-code2: Specifies the type code for router ID. Valid values are hex numbers 0107 and 8001.
route-type type-code3: Specifies the type code for route type. Valid values are hex numbers 0306 and 8000.
# Configure the type codes of domain ID, router ID, and route type as hex numbers 8005, 8001, and 8000, respectively, for OSPF process 100.
[Sysname] ospf 100
[Sysname-ospf-100] ext-community-type domain-id 8005
[Sysname-ospf-100] ext-community-type router-id 8001
[Sysname-ospf-100] ext-community-type route-type 8000
import route-policy
Use import route-policy to apply an import routing policy to the public instance or a VPN instance.
Use undo import route-policy to restore the default.
All routes matching the import target attribute are accepted.
VPN instance view
You can specify an import routing policy to filter received routes or modify their route attributes for the public instance or a VPN instance.
An import routing policy specified in VPN instance view or public instance view applies to all address families in the VPN instance or public instance. An import routing policy specified in an address family view applies only to the address family.
An address family prefers the import routing policy specified in the address family view over the one specified in VPN instance view or public instance view.
# Apply import routing policy poly-1 to VPN instance vpn1.
[Sysname-vpn-instance-vpn1] import route-policy poly-1
export route-policy
ip binding vpn-instance
Use ip binding vpn-instance to associate an interface with a VPN instance.
Use undo ip binding vpn-instance to restore the default.
An interface is associated with no VPN instance and belongs to the public network.
Interface view
CAUTION: This command or its undo form clears the IP address and routing protocol configuration on the interface. |
Use this command to associate the VPN instance with the interface connected to the CE.
The specified VPN instance must have been created by using the ip vpn-instance command in system view.
To associate a new VPN instance with an interface, first execute the undo ip binding vpn-instance command to remove the existing association.
# Associate VLAN-interface 1 with VPN instance vpn1.
[Sysname-Vlan-interface1] ip binding vpn-instance vpn1
ip vpn-instance (system view)
ip public-instance
Use ip public-instance to create the public instance and enter its view. If the public instance already exists, this command directly enters the public instance view.
Use undo ip public-instance to delete the public instance.
ip public-instance
The public instance does not exist.
The public instance is an instance created for the public network to communicate with private networks.
In an MPLS L3VPN network, for the public network and the VPN network to communicate with each other through route target matching, perform the following tasks:
· Configure matching route targets for the public instance and VPN instance.
· Use the route-replicate enable command in BGP instance view to enable mutual BGP route replication between the public and VPN instances.
# Create the public instance and enter its view.
Use ip vpn-instance to create a VPN instance and enter its view, or enter the view of an existing VPN instance.
Use undo ip vpn-instance to delete a VPN instance.
No VPN instances exist.
vpn-instance-name: Specifies a VPN instance name, a case-sensitive string of 1 to 31 characters.
# Create a VPN instance named vpn1 and enter its view.
route-distinguisher
nesting-vpn
Use nesting-vpn to enable the nested VPN feature.
Use undo nesting-vpn to disable the nested VPN feature.
nesting-vpn
undo nesting-vpn
The nested VPN feature is disabled.
To exchange VPNv4 routes with a peer in nested VPN, enable nested VPN, and then execute the peer enable command to enable that peer in BGP-VPN VPNv4 address family view.
# Enable nested VPN.
[Sysname] bgp 10
[Sysname-bgp-default-vpnv4] nesting-vpn
network
Use network to specify a local network to be advertised in the public instance or a VPN instance.
Use undo network to remove the local network to be advertised in the public instance or a VPN instance.
network ipv4-address [ mask-length | mask ]
undo network ipv4-address [ mask-length | mask ]
No local network in the public instance or a VPN instance will be advertised.
ipv4-address: Specifies a network by its IPv4 address. If you do not specify a mask or mask length, the natural network mask will be used.
mask-length: Specifies a mask length in the range of 0 to 32.
mask: Specifies a mask in dotted decimal notation.
This command specifies a local network of the public instance or a VPN instance. Then, you can configure BGP to redistribute the network (by using the import-route local-aggregate command) and advertise the network.
The specified local network route must exist and be active in the routing table of the public instance or VPN instance.
# Specify the local network to be advertised in VPN instance vpn1 as network 10.0.0.0/16.
[Sysname-vpn-ipv4-vpn1] network 10.0.0.0 255.255.0.0
import-route (Layer 3—IP Routing Command Reference)
peer next-hop-invariable
Use peer next-hop-invariable to configure the device to not change the next hop of routes advertised to peers.
Use undo peer next-hop-invariable to configure the device to use its address as the next hop of routes advertised to peers.
undo peer { group-name | ipv4-address [ mask-length ] } next-hop-invariable
The device uses its address as the next hop of routes advertised to peers.
group-name: Specifies a peer group by its name, a case-sensitive string of 1 to 47 characters.
ipv4-address: Specifies a peer by its IP address.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ip-address and mask-length arguments together to specify a subnet. If you specify a subnet in this command, the device does not change the next hop of routes advertised to the dynamic peers in the subnet.
On an RR in an inter-AS option C scenario, you must use next-hop-invariable to not change the next hop of VPNv4 routes advertised to BGP peers and RR clients.
The next-hop-invariable command is exclusive with the peer next-hop-local command. Follow these restrictions and guidelines when you execute the commands for a peer or peer group:
· You cannot execute both commands for the same peer or peer group.
· After you execute the peer next-hop-invariable command for a peer group, you cannot execute the peer next-hop-local command for a peer in the peer group.
· If you execute the peer next-hop-invariable command for a peer and later execute the peer next-hop-local command for the peer group, the later configuration takes effect on the peer.
# Configure the device to not change the next hop of routes advertised to peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default-vpnv4] peer 1.1.1.1 next-hop-invariable
peer next-hop-local (Layer 3—IP Routing Command Reference)
peer next-hop-vpn
Use peer next-hop-vpn to change the next hop of a BGP VPNv4 route received from a peer or peer group to an IP address in the VPN instance.
Use undo peer next-hop-vpn to restore the default.
peer { group-name | ipv4-address [ mask-length ] } next-hop-vpn
undo peer { group-name | ipv4-address [ mask-length ] } next-hop-vpn
The device does not change the next hop attribute of a received BGP VPNv4 route, and the next hop belongs to the public network.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command changes the next hop of BGP VPNv4 routes received from the dynamic peers in the subnet.
By default, the device does not change the next hop attribute of a received BGP VPNv4 route. The next hop address of a BGP VPNv4 route is a public address. This command changes the next hop address of a BGP VPNv4 route received from a peer or peer group to a VPN instance address. The outgoing label of the VPNv4 route is also changed to an invalid value. For example, the device received a VPNv4 route and its next hop address is 10.1.1.1, which is a public address by default. After this command is executed, the next hop address changes to private address 10.1.1.1.
After this command is executed, the following applies:
· The device re-establishes the BGP sessions to the specified peer or to all peers in the specified peer group.
· The device receives a BGP VPNv4 route only when its RD is the same as a local RD.
· When advertising a BGP VPNv4 route received from the specified peer or peer group, the device does not change the route target attribute of the route.
· If you delete a VPN instance or its RD, BGP VPNv4 routes received from the specified peer or peer group and in the VPN instance will be deleted.
# In BGP VPNv4 address family view, change the next hop of BGP VPNv4 routes received from peer 1.1.1.1 to a VPN instance address.
[Sysname] bgp 100
[Sysname-bgp-default-vpnv4] peer 1.1.1.1 next-hop-vpn
peer upe
Use peer upe to configure BGP peers as HoVPN UPEs.
Use undo peer upe to delete HoVPN UPEs.
peer { group-name | ip-address [ mask-length ] } upe
undo peer { group-name | ip-address [ mask-length ] } upe
No BGP peer is configured as a UPE.
group-name: Specifies a peer group by its name, a case-sensitive string of 1 to 47 characters. The specified peer group must exist.
ip-address: Specifies a peer by its IP address. The specified peer must exist.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ip-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command configures all dynamic peers in the subnet as UPEs.
A UPE is a special VPNv4 peer. It can accept one default route for each related VPN instance and routes permitted by the routing policy on the SPE. An SPE is a common VPN peer.
# Configure peer 1.1.1.1 as a UPE.
[Sysname] bgp 100
[Sysname-bgp-default-vpnv4] peer 1.1.1.1 upe
peer upe route-policy
Use peer upe route-policy to advertise routes permitted by a routing policy to UPEs.
Use undo peer upe route-policy to remove the configuration.
peer { group-name | ip-address [ mask-length ] } upe route-policy route-policy-name export
undo peer { group-name | ip-address [ mask-length ] } upe route-policy [ route-policy-name ] export
No routes are advertised to any peers.
group-name: Specifies a peer group by its name, a case-sensitive string of 1 to 47 characters. The peer group must exist.
ip-address: Specifies a peer by its IP address. The peer must exist.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ip-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command advertises routes permitted by a routing policy to all dynamic peers in the subnet.
export: Applies the filtering policy to routes to be advertised.
This command must be used with the peer upe command.
# Configure peer 1.1.1.1 as a UPE, and advertise routes permitted by routing policy hope to peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default] peer 1.1.1.1 as-number 200
[Sysname-bgp-default-vpnv4] peer 1.1.1.1 enable
[Sysname-bgp-default-vpnv4] peer 1.1.1.1 upe route-policy hope export
peer upe
policy vpn-target
Use policy vpn-target to enable route target filtering of received VPNv4 routes. Only VPNv4 routes whose export route target attribute matches local import route target attribute are added to the routing table.
Use undo policy vpn-target to disable route target filtering, permitting all incoming VPNv4 routes.
policy vpn-target
The route target filtering feature is enabled for received VPNv4 routes.
In an inter-AS option B scenario, an ASBR must save all incoming VPNv4 routes and advertise those routes to the peer ASBR. For this purpose, you must execute the undo policy vpn-target command on the ASBR to disable route target filtering.
# Disable route target filtering of received VPNv4 routes.
[Sysname] bgp 100
[Sysname-bgp-default-vpnv4] undo policy vpn-target
Use route-distinguisher to configure a route distinguisher (RD) for a VPN instance.
Use undo route-distinguisher to restore the default.
No RD is configured for a VPN instance.
VPN instance view
route-distinguisher: Specifies an RD for the VPN instance, a string of 3 to 21 characters in one of the following formats:
RDs enable VPNs to use the same address space. An RD and an IPv4 prefix form a unique VPN-IPv4 prefix.
To guarantee global uniqueness for a VPN-IPv4 address, do not set the AS number or IP address in an RD to any private AS number or private IP address.
To modify an RD, execute the undo route-distinguisher command to remove the RD and then execute the route-distinguisher command.
# Configure RD 22:1 for VPN instance vpn1.
[Sysname-vpn-instance-vpn1] route-distinguisher 22:1
Use route-replicate to replicate routes from a VPN instance to the public network.
Use undo route-replicate to cancel the configuration.
route-replicate from vpn-instance vpn-instance-name protocol { bgp as-number | direct | static | { isis | ospf | rip } process-id | vlink-direct } [ advertise ] [ route-policy route-policy-name ]
undo route-replicate from vpn-instance vpn-instance-name protocol { bgp as-number | direct | static | { isis | ospf | rip } process-id | vlink-direct }
The public network cannot replicate routes from VPN instances.
protocol: Replicates routes of the specified routing protocol.
bgp: Replicates BGP routes.
as-number: Specifies an AS number in the range of 1 to 4294967295.
direct: Replicates direct routes.
static: Replicates static routes.
isis: Replicates IS-IS routes.
ospf: Replicates OSPF routes.
rip: Replicates RIP routes.
process-id: Specifies a process by its ID, in the range of 1 to 65535.
vlink-direct: Replicates VLINK direct routes, which are generated based on ARP entries learned by interfaces.
advertise: Allows the public instance to advertise replicated routes. If you do not specify this keyword, the public instance cannot advertise replicated routes.
route-policy route-policy-name: Applies a routing policy to replicated routes. The route-policy-name argument specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters.
Configure this command to enable the public network to communicate with a VPN instance by replicating routes from the VPN instance.
The route-replicate from vpn-instance protocol direct command replicates VLINK direct routes, but the VLINK direct routes cannot be added to the FIB, causing traffic forwarding failures. To address this issue, you can specify the vlink-direct keyword to replicate VLINK direct routes and add the routes to the FIB.
# Replicates OSPF routes from VPN instance vpn1 to the public network.
[Sysname-public-instance-ipv4] route-replicate from vpn-instance vpn1 protocol ospf
Use route-replicate to enable a VPN instance to replicate routes from the public network or other VPN instances.
route-replicate from { public | vpn-instance vpn-instance-name } protocol { bgp as-number | direct | static | { isis | ospf | rip } process-id | vlink-direct } [ advertise ] [ route-policy route-policy-name ]
undo route-replicate from { public | vpn-instance vpn-instance-name } protocol { bgp as-number | direct | static | { isis | ospf | rip } process-id | vlink-direct }
A VPN instance cannot replicate routes of the public network or other VPN instances.
public: Replicates routes from the public network.
vpn-instance vpn-instance-name: Replicates routes from a VPN instance. The vpn-instance-name argument specifies a VPN instance by its name, a case-sensitive string of 1 to 31 characters.
advertise: Allows the VPN instance to advertise replicated routes. If you do not specify this keyword, the VPN instance cannot advertise replicated routes.
In a BGP/MPLS L3VPN network, only VPN instances that have matching route targets can communicate with each other.
This command allows a VPN instance to communicate with the public network or other VPN instances by replicating routing information of the public network or other VPN instances.
In an intelligent traffic control network, traffic of different tenants is assigned to different VPNs. To enable the tenants to communicate with the public network, configure this command to replicate routes from the public network to the VPN instances.
The route-replicate from vpn-instance protocol direct and route-replicate from public protocol direct commands replicate VLINK direct routes, but the VLINK direct routes cannot be added to the FIB, causing traffic forwarding failures. To address this issue, you can specify the vlink-direct keyword to replicate VLINK direct routes and add the routes to the FIB.
# Replicates OSPF routes from the public network to VPN instance vpn1.
[Sysname]ip vpn-instance vpn1
[Sysname-vpn-ipv4-vpn1] route-replicate from public protocol ospf 1
Use route-replicate enable to enable BGP route replication between public and VPN instances.
Use undo route-replicate enable to disable BGP route replication between public and VPN instances.
BGP route replication between public and VPN instances is disabled.
BGP instance view
In traffic cleaning scenarios, traffic between the public and private networks are filtered by firewalls and traffic of different tenants is assigned to different VPNs. To enable the tenants to communicate with the public network under the protection of firewalls, you can configure BGP route replication between public and VPN instances.
After you configure this feature, the public and VPN instances that have matching route targets replicate all BGP routes including route attributes from each other. This command also enables BGP route replication between VPN instances, so VPNs cannot be isolated. Use this command only in specific scenarios.
# In BGP instance view, enable mutual route replication between public and VPN instances.
[Sysname] bgp 100
[Sysname-bgp-default] route-replicate enable
route-tag (OSPF view)
Use route-tag to configure an external route tag for redistributed VPN routes.
Use undo route-tag to restore the default.
route-tag tag-value
undo route-tag
If BGP runs within an MPLS backbone, and the BGP AS number is not greater than 65535, the first two octets of the external route tag are 0xD000, and the last two octets are the local BGP AS number. For example, if the local BGP AS number is 100, the external route tag value is 3489661028 (100 + the decimal value of 0xD0000000). If the AS number is greater than 65535, the external route tag is 0.
OSPF view
tag-value: Specifies the external route tag for redistributed VPN routes, in the range of 0 to 4294967295.
In a dual-homed scenario where OSPF runs between the CE and the connected PEs (PE-A and PE-B, for example), you can use external route tags to avoid routing loops.
PE-A redistributes BGP routes from the peer PE into OSPF, and advertises these routes in the Type 5 or 7 LSAs to the CE. In these LSAs, PE-A adds the local external route tag.
When PE-B receives the Type 5 or 7 LSAs advertised by the CE, it compares the external route tag in the LSAs with the local external route tag. If the two tags have the same value (including the value of 0), PE-B ignores the LSA in route calculation to avoid routing loops.
The commands used to configure the external route tag (in the descending order of tag priority) are as follows:
· import-route
· route-tag (for PEs) and default tag (for CEs and MCEs)
As a best practice, configure the same external route tag for PEs in the same area.
An external route tag is not transferred in any BGP extended community attribute. It takes effect only on the PEs that receive BGP routes and generate OSPF Type 5 or 7 LSAs.
You can configure the same external route tag for different OSPF processes.
# In OSPF process 100, set the external route tag to 100 for redistributed VPN routes.
[Sysname] ospf 100
[Sysname-ospf-100] route-tag 100
default (Layer 3—IP Routing Command Reference)
routing-table limit
Use routing-table limit to set the maximum number of active routes in a VPN instance.
Use undo routing-table limit to restore the default.
The number of active routes in a VPN instance is not limited.
VPN instance view
number: Specifies the maximum number of active routes. In VPN instance view, the value range is 1 to 131072. In VPN instance IPv4 address family view, the value range is 1 to 393216.
warn-threshold: Specifies a warning threshold in the range of 1 to 100 in percentage. When the percentage of the existing active routes to the maximum active routes exceeds the threshold, the system gives a log message but still allows new active routes. If active routes in the VPN instance reach the maximum, no more active routes are added.
simply-alert: Specifies that when active routes exceed the maximum number, the system still accepts active routes but generates a log message.
Setting the maximum number of active routes for a VPN instance can prevent a PE from learning too many routes.
IPv4 VPN prefers the limit configured in VPN instance IPv4 address family view over the limit configured in VPN instance view.
# Specify that VPN instance vpn1 supports a maximum of 1000 active routes. When active routes exceed this limit, the device can receive new active routes but generates a log message.
[Sysname-vpn-instance-vpn1] routing-table limit 1000 simply-alert
rr-filter (BGP VPNv4 address family view)
Use rr-filter to create a route reflector (RR) reflection policy.
Use undo rr-filter to restore the default.
undo rr-filter
An RR does not filter reflected routes.
ext-comm-list-number: Specifies an extended community list number in the range of 1 to 65535.
After this command is executed, only the VPNv4 routes that are permitted by the specified extended community list are reflected.
By configuring different RR reflection policies on RRs in a cluster, you can implement load balancing among the RRs.
For more information about extended community lists, see Layer 3—IP Routing Configuration Guide.
# Configure the RR to reflect only VPNv4 routes that are permitted by extended community list 10.
[Sysname] bgp 100
[Sysname-bgp-default-vpnv4] rr-filter 10
ip extcommunity-list (Layer 3—IP Routing Command Reference)
sham-link (OSPF area view)
Use sham-link to create an OSPF sham link.
Use undo sham-link to remove an OSPF sham link or restore the defaults of specified parameters for an OSPF sham link.
sham-link source-ip-address destination-ip-address [ cost cost-value | dead dead-interval | hello hello-interval | { authentication-none | { hmac-md5 | hmac-sha-256 | hmac-sm3 | md5 } [ key-id { cipher | plain } string ] | keychain keychain-name | simple [ { cipher | plain } string ] } | retransmit retrans-interval | trans-delay delay | ttl-security hops hop-count ] *
undo sham-link source-ip-address destination-ip-address [ cost | dead | hello | { authentication-none | { hmac-md5 | hmac-sha-256 | hmac-sm3 | md5 } [ key-id ] | keychain | simple } | retransmit | trans-delay | ttl-security ] *
No OSPF sham links exist.
OSPF area view
source-ip-address: Specifies the source IP address of the sham link.
destination-ip-address: Specifies the destination IP address of the sham link.
cost cost-value: Specifies the cost of the sham link, in the range of 1 to 65535. The default cost is 1.
dead dead-interval: Specifies the dead interval in the range of 1 to 32768 seconds. The default is 40 seconds. The dead interval configured on the two ends of the sham link must be identical, and it must be at least four times the hello interval.
hello hello-interval: Specifies the interval for sending hello packets, in the range of 1 to 8192 seconds. The default is 10 seconds. The hello interval configured on the two ends of the sham link must be identical.
authentication-none: Enables None authentication. In this mode, OSPF packets will not be authenticated.
hmac-md5: Enables HMAC-MD5 authentication.
hmac-sha-256: Enables HMAC-SHA-256 authentication.
hmac-sm3: Enables HMAC-SM3 authentication.
md5: Enables MD5 authentication.
key-id: Specifies a key ID in the range of 1 to 255. If you do not specify a key, OSPF packets will be authenticated against a null character string.
plain: Specifies a key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies the key. This argument is case sensitive.
· In simple authentication mode, the plaintext form of the key is a string of 1 to 8 characters. The encrypted form of the key is a string of 33 to 41 characters.
· In HMAC-MD5/HMAC-SHA-256/HMAC-SM3/MD5 authentication mode, the plaintext form of the key is a string of 1 to 255 characters. The encrypted form of the key is a string of 33 to 373 characters.
keychain: Enables keychain authentication.
keychain-name: Specifies a keychain by its name. A keychain name is a case-sensitive string of 1 to 63 characters.
retransmit retrans-interval: Specifies the interval for retransmitting LSAs, in the range of 1 to 3600 seconds. The default is 5 seconds.
simple: Enables simple authentication. If you do not specify a key in this mode, OSPF packets will not be authenticated against a key.
trans-delay delay: Specifies the delay interval before the interface sends an LSA, in the range of 1 to 3600 seconds. The default is 1 second.
ttl-security hops hop-count: Enables OSPF GTSM and specifies the maximum number of hops to the sham link neighbor. The value range for the hop-count argument is 1 to 254. By default, OSPF GTSM is disabled.
When a backdoor link exists between the two sites of a VPN, traffic is forwarded through the backdoor link. To forward VPN traffic over the backbone, you can create a sham link between PEs. A sham link is considered an OSPF intra-area route.
If you execute this command multiple times to specify different authentication modes, the most recent configuration takes effect.
When HMAC-MD5/HMAC-SHA-256/HMAC-SM3/MD5, simple, or keychain authentication is used, interfaces in the same network must use the same authentication mode. If a key is configured, the interfaces must be configured with the same key.
If a sham link is not configured with an authentication mode, the sham link inherits the authentication configuration of its area by default. After you configure the None authentication mode on a sham link, the sham link will not inherit the authentication configuration of its area. If you configure the None authentication mode on the local end, make sure the peer end uses the None authentication mode or is not configured with any authentication modes.
This command can configure HMAC-MD5/HMAC-SHA-256/HMAC-SM3/MD5 or simple authentication for the sham link, but not both. For HMAC-MD5/HMAC-SHA-256/HMAC-SM3/MD5 authentication, you can configure multiple keys by executing this command multiple times, but a key-id can correspond with only one key.
To modify the HMAC-MD5/HMAC-SHA-256/HMAC-SM3/MD5 authentication key of a sham link, perform the following tasks:
1. Configure a new key for the sham link on the local device. If the neighbor on the sham link has not been configured with the new key, this configuration triggers a key rollover process, during which, OSPF advertises both the new and old keys so the neighbor can pass authentication and the neighbor relationship is maintained.
2. Configure the same key for the sham link on the neighbor. After the local device receives a packet carrying the new key from the neighbor, it quits the key rollover process.
3. Execute the undo sham-link command on the local device and the neighbor to remove the old key. This operation can avoid attacks to the sham link that uses the old key and reduce bandwidth consumption by key rollover.
When keychain authentication is configured for an OSPF sham link, OSPF performs the following operations before sending a packet:
1. Obtains a valid send key from the keychain.
OSPF does not send the packet if it fails to obtain a valid send key.
2. Uses the key ID, authentication algorithm, and key string of the send key to authenticate the packet.
If the key ID is greater than 255, OSPF does not send the packet.
When keychain authentication is configured for an OSPF sham link, OSPF performs the following operations before accepting a received a packet:
1. Uses the key ID carried in the packet to obtain a valid accept key from the keychain.
OSPF discards the packet if it fails to obtain a valid accept key.
2. Uses the authentication algorithm and key string of the accept key to authenticate the packet.
If the authentication fails, OSPF discards the packet.
· OSPF supports the MD5, HMAC-MD5, HMAC-SHA-256, and HMAC-SM3 authentication algorithms. The ID of keys used for authentication can only be in the range of 0 to 255.
OSPF GTSM protects the device from being attacked by CPU-utilization attacks. When OSPF GTSM is enabled for a sham link, the device compares the TTL value of an OSPF packet received from the sham link against the valid TTL range. If the TTL value is within the valid TTL range, the packet is accepted. If not, the packet is discarded. The valid TTL range is from "255 – the configured hop count + 1" to 255. For packets sent to the sham link, the device sets the packet TTL value to 255.
You cannot configure a sham link with the same source and destination IP address for multiple OSPF processes in a VPN instance.
For an OSPF neighbor relationship to be successfully established, the sham links configured on the local and remote PEs must be in the same OSPF area.
To use GTSM, you must configure GTSM on both the local and peer devices. You can specify different hop-count values on the devices.
# Create a sham link with the source address 1.1.1.1 and destination address 2.2.2.2.
[Sysname] ospf
[Sysname-ospf-1] area 0
[Sysname-ospf-1-area-0.0.0.0] sham-link 1.1.1.1 2.2.2.2
snmp context-name
Use snmp context-name to configure an SNMP context for a VPN instance.
Use undo snmp context-name to restore the default.
No SNMP context is configured for a VPN instance.
VPN instance view
context-name: Specifies an SNMP context, a case-sensitive string of 1 to 32 characters.
VPN-aware features such as AAA do not know the VPN instance to which a managed MIB node belongs. To resolve this issue, configure different SNMP contexts for different VPN instances.
The device selects a MIB for an SNMP packet according to the context (for SNMPv3) or community name (for SNMPv1/v2c) in the following ways:
· For an SNMPv3 packet:
¡ The device selects the public MIB if the packet does not carry a context.
¡ The device selects the MIB of a VPN instance if the packet meets the following conditions:
- Carries a context that was configured with the snmp-agent context command in system view.
- Matches the context of the VPN instance.
¡ The device does not process any MIBs in other situations.
· For an SNMPv1/v2c packet:
¡ The device selects the public MIB if no SNMP community to SNMP context mapping was configured with the snmp-agent community-map command in system view.
¡ The device selects the MIB of a VPN instance if the SNMP community is mapped to an SNMP context and the context matches the context of the VPN instance.
For more information about SNMP context and community name, see Network Management and Monitoring Configuration Guide.
Do not configure the same SNMP context for different VPN instances.
# Configure SNMP context vpna for VPN instance vpna.
[Sysname] snmp-agent context vpna
[Sysname-vpn-instance-vpna] route-distinguisher 22:33
[Sysname-vpn-instance-vpna] snmp context-name vpna
snmp-agent community-map (Network Management and Monitoring Command Reference)
snmp-agent context (Network Management and Monitoring Command Reference)
snmp-agent trap enable l3vpn
Use snmp-agent trap enable l3vpn to enable SNMP notifications for MPLS L3VPN.
Use undo snmp-agent trap enable l3vpn to disable SNMP notifications for MPLS L3VPN.
snmp-agent trap enable l3vpn [ vrf-down | vrf-up ] *
undo snmp-agent trap enable l3vpn [ vrf-down | vrf-up ] *
SNMP notifications for MPLS L3VPN are enabled.
vrf-down: VPN instance interface down notification. This notification is generated for a VPN instance in the following conditions:
· The physical state of all the interfaces bound to the VPN instance is down.
· All physically up interfaces bound to the VPN instance are unbound from the VPN instance.
vrf-up: VPN instance interface up notification. This notification is generated in the following conditions:
· The physical state of the first interface bound to the VPN instance comes up.
· When the physical state of all interfaces bound to the VPN instance is Down, one or multiple of the interfaces' physical state changes from Down to Up.
To report critical MPLS L3VPN events to an NMS, enable SNMP notifications for MPLS L3VPN. For MPLS L3VPN event notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see Network Management and Monitoring Configuration Guide.
If you do not specify any parameters in this command, this command enables all types of MPLS L3VPN notifications.
# Enable all SNMP notifications for MPLS L3VPN.
[Sysname] snmp-agent trap enable l3vpn
tnl-policy
Use tnl-policy to associate a VPN instance with a tunnel policy.
Use undo tnl-policy to restore the default.
tnl-policy tunnel-policy-name
undo tnl-policy
No tunnel policy is associated with a VPN instance.
VPN instance view
tunnel-policy-name: Specifies a tunnel policy by its name, a case-sensitive string of 1 to 19 characters.
The VPN instance uses the specified tunnel policy to select tunnels for traffic.
If a VPN instance is not associated with any tunnel policies or the associated tunnel policy is not configured, the VPN instance selects tunnels according to the default tunnel policy.The default tunnel policy selects only one tunnel, and an LSP tunnel takes precedence over a CRLSP tunnel.
IPv4 VPN prefers the tunnel policy specified in VPN instance IPv4 address family view over the tunnel policy specified in VPN instance view.
# Associate VPN instance vpn1 with tunnel policy po1.
[Sysname] tunnel-policy po1
[Sysname-tunnel-policy-po1] select-seq lsp load-balance-number 1
[Sysname-tunnel-policy-po1] quit
[Sysname-vpn-instance-vpn1] route-distinguisher 22:33
[Sysname-vpn-instance-vpn1] tnl-policy po1
tunnel-policy
vpn popgo
Use vpn popgo to specify the VPN label processing mode as POPGO forwarding on an egress PE. In POPGO forwarding mode, the egress PE pops the label for each packet and forwards the packet out of the interface corresponding to the label.
Use undo vpn popgo to restore the default.
vpn popgo
undo vpn popgo
The VPN label processing mode is POP forwarding on an egress PE, which will pop the label for each packet and forward the packet through the FIB table.
BGP instance view
After you execute the vpn popgo command, the egress PE disconnects and re-establishes BGP sessions to re-learn VPN routes, and it does not support load sharing among VPN BGP peers.
The vpn popgo and label-allocation-mode per-vrf commands are mutually exclusive. Do not configure both commands in a BGP instance.
# Specify the VPN label processing mode on the egress PE as POPGO forwarding.
[Sysname] bgp 100
[Sysname-bgp-default] vpn popgo
label-allocation-mode (Layer 3—IP Routing Command Reference)
vpn-id
Use vpn-id to configure a VPN ID for a VPN instance.
Use undo vpn-id to restore the default.
vpn-id vpn-id
undo vpn-id
No VPN ID is configured for a VPN instance.
VPN instance view
vpn-id: Specifies a VPN ID for the VPN instance, in the form of OUI:Index. The OUI is a hexadecimal number in the range of 0 to FFFFFF, and the index is a hexadecimal number in the range of 0 to FFFFFFFF.
A VPN ID uniquely identifies a VPN instance. Different VPN instances must have different VPN IDs.
A VPN ID cannot be 0:0.
# Configure VPN ID 20:1 for VPN instance vpn1.
[Sysname-vpn-instance-vpn1] vpn-id 20:1
vpn-route cross multipath
Use vpn-route cross multipath to enable ECMP VPN route redistribution.
Use undo vpn-route cross multipath to disable ECMP VPN route redistribution.
ECMP VPN route redistribution is disabled. If multiple routes have the same prefix and RD, a VPN redistributes only the optimal route to its routing table.
BGP IPv4 unicast address family view
BGP-VPN IPv4 unicast address family view
This feature enables a VPN instance to redistribute multiple routes that have the same prefix and RD into its routing table. Then, you can configure load sharing among the ECMP routes or MPLS L3VPN FRR.
# In BGP-VPN IPv4 unicast address family view, enable ECMP route redistribution.
[Sysname] bgp 100
[Sysname-bgp-default-vpn1] address-family ipv4
[Sysname-bgp-default-ipv4-vpn1] vpn-route cross multipath
vpn-target
Use vpn-target to configure route targets for a VPN instance.
Use undo vpn-target to remove the specified or all route targets of a VPN instance.
No route targets are configured for a VPN instance.
VPN instance view
vpn-target&<1-8>: Specifies a space-separated list of up to eight route targets.
A route target is a string of 3 to 21 characters in one of the following formats:
· 16-bit AS number:32-bit user-defined number. For example, 101:3.
· 32-bit IP address:16-bit user-defined number. For example, 192.168.122.15:1.
· 32-bit AS number:16-bit user-defined number, where the AS number must not be less than 65536. For example, 65536:1.
both: Uses the specified route targets as both import targets and export targets. The both keyword is also used when you do not specify any of the following keywords: both, export-extcommunity, and import-extcommunity.
export-extcommunity: Uses the specified route targets as export targets.
import-extcommunity: Uses the specified route targets as import targets.
all: Removes all route targets.
MPLS L3VPN uses route targets to control the advertisement of VPN routing information. A PE adds the configured export targets into the route target attribute of routes advertised to a peer. The peer uses the local import targets to match the route targets of received routes. If a match is found, the peer adds the routes to the routing table of the VPN instance.
If you repeat this command, all the configured route targets take effect.
IPv4 VPN prefers the route targets configured in VPN instance IPv4 address family view over those configured in VPN instance view.
# Configure route targets for VPN instance vpn1.
[Sysname-vpn-instance-vpn1] vpn-target 3:3 export-extcommunity
[Sysname-vpn-instance-vpn1] vpn-target 4:4 import-extcommunity
[Sysname-vpn-instance-vpn1] vpn-target 5:5 both
