- 03-Layer 3-IP Services Command Reference
- 01-ARP commands
- 02-IP addressing commands
- 03-DHCP commands
- 04-DNS commands
- 05-IP forwarding basics commands
- 06-Fast forwarding commands
- 07-IRDP commands
- 08-IP performance optimization commands
- 09-UDP helper commands
- 10-IPv6 basics commands
- 11-DHCPv6 commands
- 12-IPv6 fast forwarding commands
- 13-HTTP redirect commands
| 12-IPv6 fast forwarding commands | 49.56 KB |
display ipv6 fast-forwarding aging-time
display ipv6 fast-forwarding cache
ipv6 fast-forwarding load-sharing
reset ipv6 fast-forwarding cache
Use display ipv6 fast-forwarding aging-time to display the aging time of IPv6 fast forwarding entries.
# Display the aging time of IPv6 fast forwarding entries.
<Sysname> display ipv6 fast-forwarding aging-time
Aging time: 30s
Aging time |
Aging time of IPv6 fast forwarding entries, in seconds. |
Use display ipv6 fast-forwarding cache to display IPv6 fast forwarding entries.
display ipv6 fast-forwarding cache [ ipv6-address ] [ slot slot-number ]
ipv6-address: Specifies an IPv6 address. If you do not specify an IPv6 address, this command displays all IPv6 fast forwarding entries.
slot slot-number: Specifies the slot number of the device, which is fixed at 1.
# Display all IPv6 fast forwarding entries.
<Sysname> display ipv6 fast-forwarding cache
Total number of IPv6 fast-forwarding items: 2
Src IP: 123::2 Src Port: 1036
Dst IP: 123::1 Dst Port: 32768
Protocol: 58
VPN instance: N/A
Input interface: Vlan2
Output interface: InLoop0
Src IP: 123::1 Src Port: 1036
Dst IP: 123::2 Dst Port: 33024
Protocol: 58
VPN instance: N/A
Input interface: InLoop0
Output interface: Vlan2
Total number of IPv6 fast-forwarding items |
Number of IPv6 fast forwarding entries. |
Src IP |
Source IPv6 address. |
Src port |
Source port number. |
Dst IP |
Destination IPv6 address. |
Dst Port |
Destination port number. |
Protocol |
Protocol number. |
VPN instance |
This field is not supported in the current software version. VPN instance. If the entry does not belong to any VPN instance, this field displays N/A. |
Input interface |
Input interface type and number. If no interface is involved in fast forwarding, this field displays N/A. If the input interface does not exist, this field displays a hyphen (-). |
Output interface |
Output interface type and number. If no interface is involved in fast forwarding, this field displays N/A. If the output interface does not exist, this field displays a hyphen (-). |
Use ipv6 fast-forwarding aging-time to set the aging time for IPv6 fast forwarding entries on the software side.
Use undo ipv6 fast-forwarding aging-time to restore the default.
ipv6 fast-forwarding aging-time aging-time
The aging time is 30 seconds for IPv6 fast forwarding entries on the software side.
aging-time: Sets the aging time in the range of 10 to 300 seconds.
# Set the aging time to 20 seconds for IPv6 fast forwarding entries on the software side.
[Sysname] ipv6 fast-forwarding aging-time 20
Use ipv6 fast-forwarding load-sharing to enable IPv6 fast forwarding load sharing on the software side.
Use undo ipv6 fast-forwarding load-sharing to disable IPv6 fast forwarding load sharing on the software side.
IPv6 fast forwarding load sharing is enabled on the software side.
This feature enables the device to load share packets of the same flow. This feature identifies a data flow by using the packet information.
If this feature is disabled on the software side, the device identifies a data flow by the packet information and the input interface. No load sharing is implemented.
# Enable IPv6 fast forwarding load sharing on the software side.
<Sysname> system-Views
[Sysname] ipv6 fast-forwarding load-sharing
Use reset ipv6 fast-forwarding cache to clear the IPv6 fast forwarding table.
reset ipv6 fast-forwarding cache [ slot slot-number ]
# Clear the IPv6 fast forwarding table.
<Sysname> reset ipv6 fast-forwarding cache
