- 03-Layer 3-IP Services Command Reference
- 01-ARP commands
- 02-IP addressing commands
- 03-DHCP commands
- 04-DNS commands
- 05-IP forwarding basics commands
- 06-Fast forwarding commands
- 07-IRDP commands
- 08-IP performance optimization commands
- 09-UDP helper commands
- 10-IPv6 basics commands
- 11-DHCPv6 commands
- 12-IPv6 fast forwarding commands
- 13-HTTP redirect commands
| 05-IP forwarding basics commands | 81.46 KB |
Basic IP forwarding commands
display fib
Use display fib to display FIB entries.
display fib [ ip-address [ mask | mask-length ] ]
ip-address: Displays the FIB entry that matches the specified destination IP address.
mask: Specifies the mask for the IP address.
mask-length: Specifies the mask length for the IP address. The value range is 0 to 32.
If you specify an IP address without a mask or mask length, this command displays the longest matching FIB entry.
If you specify an IP address and a mask or mask length, this command displays the exactly matching FIB entry.
# Display all FIB entries of the public network.
<Sysname> display fib
Destination count: 5 FIB entry count: 5
Flag:
U:Usable G:Gateway H:Host B:Blackhole D:Dynamic S:Static
R:Relay F:FRR
Destination/Mask Nexthop Flag OutInterface/Token Label
0.0.0.0/32 127.0.0.1 UH InLoop0 Null
1.1.1.0/24 192.168.126.1 USGF M-GE0/0/0 Null
127.0.0.0/8 127.0.0.1 U InLoop0 Null
127.0.0.0/32 127.0.0.1 UH InLoop0 Null
127.0.0.1/32 127.0.0.1 UH InLoop0 Null
# Display the FIB entries matching the destination IP address 10.2.1.1.
<Sysname> display fib 10.2.1.1
Flag:
R:Relay F:FRR
10.2.1.1/32 127.0.0.1 UH InLoop0 Null
Destination count |
Total number of destination addresses. |
FIB entry count |
Total number of FIB entries. |
Destination/Mask |
Destination address and the mask length. |
Nexthop |
Next hop address. |
Flag |
Flags of routes: · U—Usable route. · G—Gateway route. · H—Host route. · B—Blackhole route. · D—Dynamic route. · S—Static route. · R—Relay route. · F—Fast reroute. |
OutInterface/Token |
Output interface/LSP index number. |
Label |
Inner label. |
display fib usage
Use display fib usage to display the FIB table usage.
display fib usage
You can view the FIB table usage in the most recent hour.
The FIB entries that are deployed by ARP host routes are not counted in the FIB table usage.
The device counts multiple FIB entries as one FIB entry if they are deployed by equal-cost routes that have the same destination IP address and different next hops.
# Display the FIB table usage.
<Sysname> display fib usage
FIB table upper limit: 65000
Time FIB count Usage
Current 52000 80%
1 min ago 51351 79%
2 min ago 50711 78%
3 min ago 47748 77%
59 min ago 13656 21%
60 min ago 13007 20%
FIB table upper limit |
Maximum number of entries supported by the FIB table. |
Time |
Time when the FIB table usage was recorded. |
FIB count |
Number of FIB entries. |
Usage |
FIB table usage, which is the ratio of the real-time FIB entry count to the FIB table upper limit. |
forwarding split-horizon
Use forwarding split-horizon to enable split horizon forwarding.
Use undo forwarding split-horizon to disable split horizon forwarding.
Split horizon forwarding is disabled.
This feature prevents IPv4 and IPv6 packets from being forwarded out of the physical interface on which they were received, avoiding network loops.
# Enable split horizon forwarding globally.
[Sysname] forwarding split-horizon
ip forwarding-table save
Use ip forwarding-table save to save the IP forwarding entries to a file.
ip forwarding-table save filename filename
filename filename: Specifies the name of a file, a string of 1 to 255 characters. For information about the filename argument, see file system management in Fundamentals Configuration Guide.
The command automatically creates the file if you specify a nonexistent file. If the file already exists, this command overwrites the file content.
To automatically save the IP forwarding entries periodically, configure a schedule for the device to automatically run the ip forwarding-table save command. For information about scheduling a task, see Fundamentals Configuration Guide.
# Save the IP forwarding entries to the fib.txt file.
<Sysname> ip forwarding-table save filename fib.txt
snmp-agent trap enable fib
Use snmp-agent trap enable fib to enable SNMP notifications for FIB events.
Use undo snmp-agent trap enable fib to disable SNMP notifications for FIB events.
SNMP notifications for FIB events are enabled.
This feature enables the FIB module to generate SNMP notifications for critical FIB events. The SNMP notifications are sent to the SNMP module. For the SNMP notifications to be sent correctly, you must also configure SNMP. For more information about SNMP configuration, see Network Management and Monitoring Configuration Guide.
# Disable SNMP notifications for FIB events.
[Sysname] undo snmp-agent trap enable fib
Load sharing commands
display ip load-sharing mode
Use display ip load-sharing mode to display the load sharing mode in use.
display ip load-sharing mode slot slot-number
slot slot-number: Specifies the slot number of the device, which is fixed at 1.
# Display the load sharing mode in use.
<Sysname> display ip load-sharing mode slot 1
Load-sharing mode: per-flow
Load-sharing options: dest-ip | src-ip | ip-pro | dest-port | src-port | ingress-port
Load-sharing algorithm: 1
Load-sharing mode |
The load sharing mode in use: · per-packet—Per-packet load sharing. · per-flow—Per-flow load sharing. |
Load-sharing options |
Options configured for load sharing: · dest-ip—Identifies flows by packet's destination IP address. · src-ip—Identifies flows by packet's source IP address. · ip-pro—Identifies flows by packet's IP protocol. · dest-port—Identifies flows by packet's destination port number. · src-port—Identifies flows by packet's source port number. · ingress-port—Identifies flows by packet's ingress port. |
Load-sharing algorithm |
Algorithm used by load sharing. |
display ip load-sharing path
Use display ip load-sharing path to display the load sharing path selected for a flow.
display ip load-sharing path ingress-port interface-type interface-number packet-format { ipv4oe dest-ip ip-address [ src-ip ip-address ] | ipv6oe dest-ipv6 ipv6-address [ src-ipv6 ipv6-address ] } [ dest-port port-id | ip-pro protocol-id | src-port port-id ] *
ingress-port interface-type interface-number: Specifies an ingress port by its type and number.
packet-format { ipv4oe dest-ip ip-address [src-ip ip-address ] | ipv6oe dest-ipv6 ipv6-address [ src-ipv6 ipv6-address ] }: Specifies the packet encapsulation format.
ipv4oe: Specifies the format of IPv4 over Ethernet.
dest-ip ip-address: Specifies the destination IPv4 address in dotted decimal notation. If you do not specify this argument, the calculation uses 0.0.0.0 for path selection.
src-ip ip-address: Specifies the source IPv4 address in dotted decimal notation. If you do not specify this argument, the calculation uses 0.0.0.0 for path selection.
ipv6oe: Specifies the format of IPv6 over Ethernet.
dest-ipv6 ipv6-address: Specifies the destination IPv6 address. If you do not specify this option, the calculation uses 0:0:0:0:0:0:0:0 for path selection.
src-ipv6 ipv6-address: Specifies the source IPv6 address. If you do not specify this option, the calculation uses 0:0:0:0:0:0:0:0 for path selection.
flow-label flow-label: Specifies the IPv6 flow label in the range of 0 to 1048575. If you do not specify an IPv6 flow label, the device uses 0 for ECMP route selection.
dest-port port-id: Specifies a destination port number in the range of 1 to 65535. If you do not specify this option, the calculation uses 0 for path selection.
ip-pro protocol-id: Specifies an IP protocol by its number in the range of 1 to 65535. If you do not specify this option, the calculation uses 0 for path selection.
source-port port-id: Specifies a source port number in the range of 1 to 65535. If you do not specify this option, the calculation uses 0 for path selection.
The option settings in this command must match both the options displayed in the display ip load-sharing mode command and the field values in load shared packets. If the option settings do not meet the requirement, the path displayed by this command might be different from the real path for load sharing.
# Display the load sharing path selected for the flow with the following attributes: ingress port Twenty-FiveGigE 1/0/3, destination IP address 10.110.0.2, source IP address 10.100.0.2, IP protocol number 153, destination port number 2000, source port number 2000.
<Sysname> display ip load-sharing path ingress-port twenty-fivegige 1/0/3 packet-format ipv4oe dest-ip 10.110.0.2 src-ip 10.100.0.2 ip-pro 153 dest-port 2000 src-port 2000
Load-sharing algorithm: 0
Load-sharing parameters:
Missing configured are set to 0.
ingress-port: Twenty-FiveGigE1/0/3
packet-format: IPv4oE
dest-ip: 10.110.0.2
src-ip: 10.100.0.2
ip-pro: 153
dest-port: 2000
src-port: 2000
Path selected: 20.0.0.2(interface Twenty-FiveGigE1/0/3)
Load sharing algorithm ID. |
Load sharing options specified by the ip load-sharing mode command. |
Load-sharing parameters |
Load sharing parameters that you specify for the display ip load-sharing path command. |
Missing configured are set to 0. |
Values of the unconfigured parameters are set to 0. |
ingress-port |
Ingress port of the packet. |
packet-format |
Packet encapsulation format. |
dest-ip |
Destination IP address of the packet. |
src-ip |
Source IP address of the packet. |
ip-pro |
IP protocol number. |
dest-port |
Destination port number. |
src-port: |
Source port number. |
Path selected |
Selected path information, including the IPv4 or IPv6 address of the next hop and the egress port. |
Use ip load-sharing mode to configure the load sharing mode.
Use undo ip load-sharing mode to restore the default.
ip load-sharing mode { per-flow [ algorithm algorithm-number [ seed seed-number ] [ shift shift-number ] | [ dest-ip | dest-port | ingress-port | ip-pro | src-ip | src-port ] ] | per-packet } { global | slot slot-number }
undo ip load-sharing mode [ per-flow { algorithm | tunnel } ] { global | slot slot-number }
The device performs per-flow load sharing based on the following criteria: source IP address, destination IP address, source port number, destination port number, IP protocol number, and ingress port.
algorithm algorithm-number: Specifies an algorithm for per-flow load sharing. The value range for the algorithm-number argument is 0 to 13. If you do not specify an algorithm, the algorithm value is 8. If you specify an algorithm and then execute the undo ip load-sharing mode command, the algorithm value is set to 0.
seed seed-number: Specifies the seed value for the algorithm. The value range is 0 to ffffffff, and the default value is 0.
shift shift-number: Specifies the shift value for the hash algorithm result. The value range is 0 to 63, and the default value is 0.
per-flow: Implements per-flow load sharing. If you specify none of the dest-ip, dest-port, ingress-port, ip-pro, src-ip, and src-port keywords, the device performs per-flow load sharing based on the destination IP addresses and source IP addresses of packets.
dest-ip: Identifies flows by destination IP address.
dest-port: Identifies flows by destination port.
ingress-port: Identifies flows by ingress port.
ip-pro: Identifies flows by protocol number.
src-ip: Identifies flows by source IP address.
src-port: Identifies flows by source port.
global: Configures the load sharing mode globally.
per-packet: Implements per-packet load sharing.
If traffic is not shared equally, you can use the seed seed-number option and the shift shift-number option to adjust the algorithm result.
The load-sharing mode configured for a slot takes precedence over the global load-sharing mode. The global mode takes effect only on slots not configured with a load-sharing mode.
# Configure per-flow load sharing for slot 1.
[Sysname] ip load-sharing mode per-flow slot 1
# Configure per-flow load sharing based on the destination IP addresses and source IP addresses of packets for slot 1.
[Sysname] ip load-sharing mode per-flow dest-ip src-ip slot 1
# Configure per-flow load sharing based on algorithm 1 for slot 1.
[Sysname] ip load-sharing mode per-flow algorithm 1 slot 1
ip load-sharing symmetric enable
Use ip load-sharing symmetric enable to enable symmetric load sharing.
Use undo ip load-sharing symmetric enable to disable symmetric load sharing.
Symmetric load sharing is disabled.
Symmetric load sharing ensures that bidirectional traffic specific to a particular source and destination address pair flow along the same path.
# Enable symmetric load sharing.
[Sysname] ip load-sharing symmetric enable
