- 09-Network Management and Monitoring Configuration Guide
- 02-NQA configuration
- 03-NTP configuration
- 04-SNMP configuration
- 05-RMON configuration
- 06-Event MIB configuration
- 07-NETCONF configuration
- 08-Ansible configuration
- 09-Puppet configuration
- 10-Chef configuration
- 11-CWMP configuration
- 12-EAA configuration
- 13-Process monitoring and maintenance configuration
- 14-Mirroring configuration
- 15-Information center configuration
- 16-Packet capture configuration
00-Preface | 100.69 KB |
Preface
This configuration guide describes the network management and monitoring fundamentals and configuration procedures. It describes how to view system information, synchronize time for all devices with clocks in your network, and use the ping, tracert, and debug commands to check and debug the current network connectivity.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the S6826 & S9826 switch series.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
