02-Ethernet interface configuration | 36.52 KB |
Configuring Ethernet interfaces
About Ethernet interface
The switching module series supports management Ethernet interfaces and Console interfaces. For the interface types and the number of interfaces supported by a model, see the installation guide.
This chapter describes how to configure management Ethernet interfaces.
Configuring a management Ethernet interface
A management interface uses an RJ-45/LC connector. You can connect the interface to a PC for software loading and system debugging, or connect it to a remote NMS for remote system management.
1. Enter system view.
2. Enter management Ethernet interface view.
interface m-gigabitethernet interface-number
3. (Optional.) Set the interface description.
The default setting is M-GigabitEthernet0/0/0 Interface.
4. (Optional.) Set the duplex mode for the management Ethernet interface.
duplex { auto | full }
By default, the duplex mode is auto for a management Ethernet interface.
5. (Optional.) Shut down the interface.
shutdown
By default, the management Ethernet interface is up.
