02-Ethernet interface commands | 39.83 KB |
description
The description of an interface is the interface name plus Interface (for example, Ten-GigabitEthernet1/1/11 Interface).
Ethernet interface view
text: Specifies the interface description, a case-sensitive string of 1 to 255 characters.
# Set the description of the management Ethernet interface to M-interface.
[Sysname] interface m-gigabitethernet 0/0/0
[Sysname-M-GigabitEthernet0/0/0] description M-interface
duplex
Use duplex to set the duplex mode for an Ethernet interface.
Use undo duplex to restore the default.
duplex { auto | full }
undo duplex
Ethernet interfaces operate in autonegotiation mode.
auto: Configures the interface to autonegotiate the duplex mode with the peer.
full: Configures the interface to operate in full duplex mode. In this mode, the interface can receive and transmit packets simultaneously.
# Configure the management Ethernet interface to operate in full duplex mode.
[Sysname-M-GigabitEthernet0/0/0] duplex full
interface
Use interface to enter interface view.
# Enter the view of the management Ethernet interface.
shutdown
Use shutdown to shut down an Ethernet interface.
Use undo shutdown to bring up an Ethernet interface.
shutdown
An Ethernet interface is up.
# Shut down and then bring up the management Ethernet interface.
[Sysname-M-GigabitEthernet0/0/0] shutdown
[Sysname-M-GigabitEthernet0/0/0] undo shutdown
