- 18-Network Management and Monitoring
- 01-DISMAN-EVENT-MIB
- 02-DISMAN-PING-MIB
- 03-DISMAN-TRACEROUTE-MIB
- 04-HH3C-MIRRORGROUP-MIB
- 05-HH3C-NETCONF-MIB
- 06-HH3C-NQA-MIB
- 07-HH3C-NTP-MIB
- 08-HH3C-RMON-EXT2-MIB
- 09-HH3C-SNMP-EXT-MIB
- 10-RMON2-MIB
- 11-RMON-MIB
- 12-SFLOW-MIB
- 13-SNMP-FRAMEWORK-MIB
- 14-SNMP-MPD-MIB
- 15-SNMP-NOTIFICATION-MIB
- 16-SNMP-TARGET-MIB
- 17-SNMP-USER-BASED-SM-MIB
- 18-SNMPv2-MIB
- 19-SNMP-VIEW-BASED-ACM-MIB
| 07-HH3C-NTP-MIB | 122.52 KB |
HH3C-NTP-MIB
About this MIB
Use this MIB to configure NTP of the device.
MIB file name
hh3c-ntp.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cRhw(8).hh3cNTP(22)
Scalar objects
hh3cNTPSysLeap
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNTPSysLeap (1.3.6.1.4.1.25506.8.22.1.1.1) |
read-only |
INTEGER |
noWarning(0), addSecond(1), subtractSecond(2), alarm(3) |
Two-bit system leap indicator. |
As per the MIB. |
hh3cNTPSysStratum
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNTPSysStratum (1.3.6.1.4.1.25506.8.22.1.1.2) |
read-only |
Integer32 |
Integer32 (1..16) |
Stratum level of the local system clock. |
As per the MIB. |
hh3cNTPSysPrecision
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNTPSysPrecision (1.3.6.1.4.1.25506.8.22.1.1.3) |
read-only |
Integer32 |
Integer32 (-20..20) |
Accuracy of the system clock. |
As per the MIB. |
hh3cNTPSysRootdelay
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNTPSysRootdelay (1.3.6.1.4.1.25506.8.22.1.1.4) |
read-only |
OCTET STRING |
OCTET STRING (1..128) |
Round-trip delay from the local device to the primary reference source at the root of the synchronization subnet. |
As per the MIB. |
hh3cNTPSysRootdispersion
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNTPSysRootdispersion (1.3.6.1.4.1.25506.8.22.1.1.5) |
read-only |
OCTET STRING |
Maximum error of the system clock relative to the primary reference source at the root of the synchronization subnet. |
As per the MIB. |
hh3cNTPSysRefid
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNTPSysRefid (1.3.6.1.4.1.25506.8.22.1.1.6) |
read-only |
OCTET STRING |
Reference clock ID of the local clock. |
As per the MIB. |
hh3cNTPSysReftime
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNTPSysReftime (1.3.6.1.4.1.25506.8.22.1.1.7) |
read-only |
OCTET STRING |
Timestamp of the local system clock updated most recently. |
As per the MIB. |
hh3cNTPSysPoll
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNTPSysPoll (1.3.6.1.4.1.25506.8.22.1.1.8) |
read-only |
Integer32 |
System polling interval. |
As per the MIB. |
hh3cNTPSysPeer
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNTPSysPeer (1.3.6.1.4.1.25506.8.22.1.1.9) |
read-only |
Integer32 |
Integer32 (0..2147483647) |
Reference synchronization source specified by the system. |
This object is replaced by hh3cNTPSysSrcPeer. |
hh3cNTPSysState
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNTPSysState (1.3.6.1.4.1.25506.8.22.1.1.10) |
read-only |
INTEGER |
noUpdateClock(0), getfreqInfo(1), clockBySet(2), clockBySetAndNoFreq(3), clockBySyns(4), findError(5) |
Status of the local clock. |
An integer indicates the status of the local clock. Currently, clockBySet(2) is not supported. |
hh3cNTPSysOffset
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNTPSysOffset (1.3.6.1.4.1.25506.8.22.1.1.11) |
read-only |
OCTET STRING |
Offset of the local clock updated most recently. |
As per the MIB. |
hh3cNTPSysDrift
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNTPSysDrift (1.3.6.1.4.1.25506.8.22.1.1.12) |
read-only |
OCTET STRING |
Pre-made clock frequency. |
As per the MIB. |
hh3cNTPSysCompliance
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNTPSysCompliance (1.3.6.1.4.1.25506.8.22.1.1.13) |
read-only |
OCTET STRING |
System error. |
As per the MIB. |
hh3cNTPSysClock
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNTPSysClock (1.3.6.1.4.1.25506.8.22.1.1.14) |
read-only |
OCTET STRING |
System local time. |
As per the MIB. |
hh3cNTPSysStabil
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNTPSysStabil (1.3.6.1.4.1.25506.8.22.1.1.15) |
read-only |
OCTET STRING |
Clock frequency stability. |
As per the MIB. |
hh3cNTPSysAuthenticate
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNTPSysAuthenticate (1.3.6.1.4.1.25506.8.22.1.1.16) |
read-write |
INTEGER |
noAuthenticate(0), authenticate(1) |
An integer indicates that the system supports authentication. |
As per the MIB. |
hh3cNTPSysPollSec
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNTPSysPollSec (1.3.6.1.4.1.25506.8.22.1.1.17) |
read-only |
Integer32 |
Integer32 (2..1048576) |
System polling interval, in seconds. |
As per the MIB. |
hh3cNTPSysClockSec
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNTPSysClockSec (1.3.6.1.4.1.25506.8.22.1.1.18) |
read-only |
Integer32 |
Standard MIB values. |
System local time, in seconds. |
As per the MIB. |
hh3cNTPServerIP
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNTPServerIP (1.3.6.1.4.1.25506.8.22.1.1.19) |
read-write |
IpAddress |
OCTET STRING (4) |
IP address of the NTP server. |
As per the MIB. |
hh3cNTPSysSrcPeer
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNTPSysSrcPeer (1.3.6.1.4.1.25506.8.22.1.1.20) |
read-only |
Unsigned32 |
As per the MIB. |
hh3cNTPSysOldServerIP
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNTPSysOldServerIP (1.3.6.1.4.1.25506.8.22.1.1.21) |
accessible-for-notify |
IpAddress |
OCTET STRING (4) |
IP address of the last NTP server. |
As per the MIB. |
hh3cNTPSysSrcVpnName
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNTPSysSrcVpnName (1.3.6.1.4.1.25506.8.22.1.1.22) |
DisplayString |
OCTET STRING (0..255) |
VPN instance to which the current NTP server belongs. |
As per the MIB. |
hh3cNTPSysOldSrcVpnName
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNTPSysOldSrcVpnName (1.3.6.1.4.1.25506.8.22.1.1.23) |
DisplayString |
VPN instance to which the last NTP server belongs. |
As per the MIB. |
hh3cNTPSysMaxDynamicSessions
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNTPSysMaxDynamicSessions (1.3.6.1.4.1.25506.8.22.1.1.24) |
Integer32 |
Integer32 (0..255) |
Maximum number of dynamic NTP sessions. |
As per the MIB. |
Tabular objects
hh3cNTPPeerTable
About this table
This table provides information about the peers associated with the local NTP server.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Supported. The hh3cNTPPeerRowStatus column supports only value createAndGo. |
Not supported |
Supported |
Supported |
Columns
The table indexes are hh3cNTPPeerRemAdr and hh3cNTPPeerHMode.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNTPPeerConfig (1.3.6.1.4.1.25506.8.22.2.1.1.1.1) |
read-only |
TruthValue |
true(1), false(2) |
A bit indicates the establishment of the association. If a peer is unreachable, the bit is not recoverable. |
As per the MIB. |
hh3cNTPPeerAuthenable (1.3.6.1.4.1.25506.8.22.2.1.1.1.2) |
read-only |
TruthValue |
true(1), false(2) |
A bit indicates that the peer system supports authentication. |
As per the MIB. |
hh3cNTPPeerAuthentic (1.3.6.1.4.1.25506.8.22.2.1.1.1.3) |
read-only |
TruthValue |
true(1), false(2) |
A bit indicates that the authentic message passes authentication. |
As per the MIB. |
hh3cNTPPeerRemAdr (1.3.6.1.4.1.25506.8.22.2.1.1.1.4) |
not-accessible |
IpAddress |
OCTET STRING (4) |
IP address of the peer. Set the object when creating a new association. |
As per the MIB. |
hh3cNTPPeerRemPort (1.3.6.1.4.1.25506.8.22.2.1.1.1.5) |
read-only |
Integer32 |
Integer32 (1..65535) |
The UDP port number on which the peer receives NTP messages. |
As per the MIB. |
hh3cNTPPeerLocAdr (1.3.6.1.4.1.25506.8.22.2.1.1.1.6) |
read-only |
IpAddress |
OCTET STRING (4) |
IP address of the local host. |
As per the MIB. |
hh3cNTPPeerLocPort (1.3.6.1.4.1.25506.8.22.2.1.1.1.7) |
read-only |
Integer32 |
The UDP port number on which the local host receives NTP messages. |
As per the MIB. |
hh3cNTPPeerLeap (1.3.6.1.4.1.25506.8.22.2.1.1.1.8) |
read-only |
INTEGER |
Second leap indicator of the peer. |
As per the MIB. |
hh3cNTPPeerHMode (1.3.6.1.4.1.25506.8.22.2.1.1.1.9) |
not-accessible |
INTEGER |
unspecified (0), symmetricActive (1), symmetricPassive (2), client (3), server(4), broadcast (5), reservedControl (6), reservedPrivate (7), broadcastclient (8), multicastclient (9) |
Host association mode. |
As per the MIB. |
hh3cNTPPeerStratum (1.3.6.1.4.1.25506.8.22.2.1.1.1.10) |
read-only |
Integer32 |
Stratum level of the peer, indicating the clock accuracy. |
As per the MIB. |
hh3cNTPPeerPPoll (1.3.6.1.4.1.25506.8.22.2.1.1.1.11) |
read-only |
Integer32 |
The interval at which the peer polls the local host. |
As per the MIB. |
hh3cNTPPeerHPoll (1.3.6.1.4.1.25506.8.22.2.1.1.1.12) |
read-only |
Integer32 |
The interval at which the local host polls the peer. |
As per the MIB. |
hh3cNTPPeerPrecision (1.3.6.1.4.1.25506.8.22.2.1.1.1.13) |
read-only |
Integer32 |
Precision of the peer clock. |
As per the MIB. |
hh3cNTPPeerRootDelay (1.3.6.1.4.1.25506.8.22.2.1.1.1.14) |
read-only |
OCTET STRING |
Round-trip delay from the peer clock to the local clock. |
As per the MIB. |
hh3cNTPPeerRootDispersion (1.3.6.1.4.1.25506.8.22.2.1.1.1.15) |
read-only |
OCTET STRING |
Clock time difference between the peer clock and the time source. |
As per the MIB. |
hh3cNTPPeerRefId (1.3.6.1.4.1.25506.8.22.2.1.1.1.16) |
read-only |
OCTET STRING |
Reference source ID of the peer clock. |
As per the MIB. |
hh3cNTPPeerRefTime (1.3.6.1.4.1.25506.8.22.2.1.1.1.17) |
read-only |
OCTET STRING |
Timestamp of the peer clock. |
As per the MIB. |
hh3cNTPPeerOrg (1.3.6.1.4.1.25506.8.22.2.1.1.1.18) |
read-only |
OCTET STRING |
Local clock timestamp in the NTP message sent most recently. |
As per the MIB. |
hh3cNTPPeerRec (1.3.6.1.4.1.25506.8.22.2.1.1.1.19) |
read-only |
OCTET STRING |
Local timestamp in the NTP message received most recently from the peer. |
As per the MIB. |
hh3cNTPPeerXmt (1.3.6.1.4.1.25506.8.22.2.1.1.1.20) |
read-only |
OCTET STRING |
Local time after the sending of a NTP message. |
As per the MIB. |
hh3cNTPPeerReach (1.3.6.1.4.1.25506.8.22.2.1.1.1.21) |
read-only |
Integer32 |
Reachability count. A peer is unreachable if the object value is 0. |
As per the MIB. |
hh3cNTPPeerValid (1.3.6.1.4.1.25506.8.22.2.1.1.1.22) |
read-only |
Integer32 |
Valid sampling data. |
As per the MIB. |
hh3cNTPPeerTimer (1.3.6.1.4.1.25506.8.22.2.1.1.1.23) |
read-only |
Integer32 |
The interval of transmitted NTP messages from the host to the peer. |
As per the MIB. |
hh3cNTPPeerDelay (1.3.6.1.4.1.25506.8.22.2.1.1.1.24) |
read-only |
OCTET STRING |
Delay of messages from the host to the peer. |
As per the MIB. |
hh3cNTPPeerOffset (1.3.6.1.4.1.25506.8.22.2.1.1.1.25) |
read-only |
OCTET STRING |
Offset of the peer relative to the local clock. |
As per the MIB. |
hh3cNTPPeerJitter (1.3.6.1.4.1.25506.8.22.2.1.1.1.26) |
read-only |
OCTET STRING |
Sampling data flag. |
As per the MIB. |
hh3cNTPPeerDispersion (1.3.6.1.4.1.25506.8.22.2.1.1.1.27) |
read-only |
OCTET STRING |
Maximum error of the peer relative to the local clock. |
As per the MIB. |
hh3cNTPPeerKeyId (1.3.6.1.4.1.25506.8.22.2.1.1.1.28) |
read-only |
Unsigned32 |
Authentication key ID in NTP messages. |
As per the MIB. |
hh3cNTPPeerFiltDelay (1.3.6.1.4.1.25506.8.22.2.1.1.1.29) |
read-only |
OCTET STRING |
Round-trip delay of the peer relative to the local clock. |
As per the MIB. |
hh3cNTPPeerFiltOffset (1.3.6.1.4.1.25506.8.22.2.1.1.1.30) |
read-only |
OCTET STRING |
As per the MIB. |
hh3cNTPPeerFiltError (1.3.6.1.4.1.25506.8.22.2.1.1.1.31) |
read-only |
OCTET STRING |
As per the MIB. |
hh3cNTPPeerPMode (1.3.6.1.4.1.25506.8.22.2.1.1.1.32) |
read-only |
INTEGER |
Association mode of the peer. |
As per the MIB. |
hh3cNTPPeerReceived (1.3.6.1.4.1.25506.8.22.2.1.1.1.33) |
read-only |
INTEGER(0..4294967295) |
Number of received NTP messages. |
As per the MIB. |
hh3cNTPPeerSent (1.3.6.1.4.1.25506.8.22.2.1.1.1.34) |
read-only |
Number of sent NTP messages. |
As per the MIB. |
hh3cNTPPeerFlash (1.3.6.1.4.1.25506.8.22.2.1.1.1.35) |
read-only |
Hh3cAlarmStatus |
BITS{ recvRepeatMsg(0), recvremanMsg(1), unSynMsg(2), dispBeyond(3), unauthenticate(4), unSynClock(5), straBeyond(6), rootDispBeyond(7), noAuthen(8), refuOperate(9) } |
Message test flag. |
As per the MIB. |
hh3cNTPPeerRowStatus (1.3.6.1.4.1.25506.8.22.2.1.1.1.36) |
read-create |
RowStatus |
Supports only values active, createAndGo, and destroy. |
Row status. |
Supports only values active, createAndGo, and destroy. If the value broadcast, broadcastclient, or multicastclient is used for hh3cNTPPeerHMode, this object supports only the read operation. |
Notifications
This section contains HH3C-NTP-MIB notifications.
hh3cNTPSysStateChangeTrap
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.8.22.1.2.0.1 |
A change occurred on the NTP time synchronization status. |
Informational |
N/A |
N/A |
ON |
This notification is generated when a change occurs on the NTP time synchronization status.
Status control
The notification cannot be disabled.
Objects
This table does not have indexes.
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.8.22.1.1.10 (hh3cNTPSysState) |
Local clock status. |
No |
INTEGER |
1.3.6.1.4.1.25506.8.22.1.1.19 (hh3cNTPServerIP) |
No |
IpAddress |
OCTET STRING (4) |
1.3.6.1.4.1.25506.8.22.1.1.22 (hh3cNTPSysSrcVpnName) |
VPN instance to which the NTP server belongs. |
No |
DisplayString |
OCTET STRING(0..255) |
Recommended action
No action is required.
hh3cNTPSysPeerChangeTrap
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.22.1.2.0.2 |
Change of the NTP server. |
Informational |
N/A |
N/A |
ON |
This notification is generated when the NTP time server changes.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.8.22.1.1.21 (hh3cNTPSysOldServerIP) |
IP address of last NTP server. |
No |
IpAddress |
1.3.6.1.4.1.25506.8.22.1.1.23 (hh3cNTPSysOldSrcVpnName) |
No |
DisplayString |
IP address of the current NTP server. |
No |
IpAddress |
No |
DisplayString |
Recommended action
hh3cNTPDynSessionLimit
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.22.1.2.0.3 |
The number of dynamic NTP sessions reached the threshold. |
Informational |
N/A |
N/A |
ON |
This notification is generated when the number of dynamic NTP sessions reaches the threshold.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.8.22.1.1.24 (hh3cNTPSysMaxDynamicSessions) |
No |
Integer32 |
Recommended action
hh3cNTPDynSessionLimitResume
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.22.1.2.0.4 |
The number of dynamic NTP sessions dropped below the threshold. |
Informational |
N/A |
N/A |
ON |
This notification is generated when the number of dynamic NTP sessions drops below the threshold.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
No |
Integer32 |
Recommended action
