18-Network Management and Monitoring
HomeSupportReference GuidesMIB CompanionH3C S6800 & S6860 Switch Series MIB Companion-Release 671x-6W10018-Network Management and Monitoring
05-HH3C-NETCONF-MIB
05-HH3C-NETCONF-MIB 58.10 KB
HH3C-NETCONF-MIB
About this MIB
Use this MIB to notify SNMP NMSs of NETCONF session establishment and disconnection events.
MIB file name
hh3c-netconf.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cNetconf(206)
Scalar objects
hh3cNetconfSessionId
Object (OID)
Access
Value range
Implementation
hh3cNetconfSessionId (1.3.6.1.4.1.25506.2.206.1.1.1)
accessible-for-notify
Integer32
Integer32 (1..2147483647)
NETCONF session ID.
Implementation varies by product.
hh3cNetconfSessionUserName
Object (OID)
Access
Value range
Implementation
hh3cNetconfSessionUserName (1.3.6.1.4.1.25506.2.206.1.1.2)
DisplayString
OCTET STRING (1..80)
NETCONF session username.
As per the MIB.
hh3cNetconfSessionPeerIPAddressType
Object (OID)
Access
Value range
Implementation
hh3cNetconfSessionPeerIPAddress (1.3.6.1.4.1.25506.2.206.1.1.3)
InetAddress
Standard MIB values.
Type of the remote IP address that established the NETCONF session with the device.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cNetconfSessionPeerIPAddress (1.3.6.1.4.1.25506.2.206.1.1.4)
InetAddressType
Remote IP address that established the NETCONF session with the device.
As per the MIB.
hh3cNetconfSessionTerminationReason
Object (OID)
Access
Value range
Implementation
hh3cNetconfSessionTerminationReason (1.3.6.1.4.1.25506.2.206.1.1.5)
INTEGER
other(1),
closed(2),
linkDown(3),
idleTimeout(4),
Reason. for the session to be disconnected by the NETCONF client.
Options:
other(1)—Any other reason than those listed below.
closed(2)—Session was closed.
linkDown(3)—Link went down.
idleTimeout(4)—Session timed out.
Notifications
hh3cNetconfServerSessionStart
Basic information
OID
Event
Severity
Recovery notification
Default status
(1.3.6.1.4.1.25506.2.206.2.0.1)
NETCONF server established a session.
Informational
N/A
N/A
ON
This notification is generated when the NETCONF server established a session with a NETCONF client.
Status control
No action is required.
Objects
OID (object name)
Index
Value range
(hh3cNetconfSessionId)
NETCONF session ID.
No
Integer32
Integer32
(1..2147483647)
(hh3cNetconfSessionUserName)
No
DisplayString
(hh3cNetconfSessionPeerIPAddressType)
No
InetAddressType
(hh3cNetconfSessionPeerIPAddress)
No
InetAddress
Recommended action
hh3cNetconfServerSessionEnd
Basic information
OID
Event
Severity
Default status
(1.3.6.1.4.1.25506.2.206.2.0.2)
NETCONF server ended a session
Error
N/A
N/A
ON
Status control
This notification cannot be disabled.
Objects
OID (object name)
Index
Value range
NETCONF session ID.
No
Integer32
Integer32
(1..2147483647)
No
DisplayString
No
InetAddressType
No
InetAddress
(hh3cNetconfSessionTerminationReason)
Reasons for the session to be disconnected by the NETCONF client:
No
INTEGER
Options:
timeout(3)—Session exception occurred.
Recommended action
·     If the session was closed normally, no action is required.
·     If the session was closed abnormally, check the physical link.
