01-Fundamentals
HomeSupportReference GuidesMIB CompanionH3C S6800 & S6860 Switch Series MIB Companion-Release 671x-6W10001-Fundamentals
05-HH3C-UI-MAN-MIB
05-HH3C-UI-MAN-MIB 67.21 KB
HH3C-UI-MAN-MIB
About this MIB
Use this MIB to define alarms on user authentication. This MIB also contains notifications about user login changes.
MIB file name
hh3c-ui-man.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cUIMgt(2)
Scalar objects
hh3cTerminalUserName
Object (OID)
Access
Value range
Implementation
hh3cTerminalUserName (1.3.6.1.4.1.25506.2.2.1.1.2.1)
accessible-for-notify
DisplayString
Standard MIB values.
Name of a login user.
As per the MIB.
hh3cTerminalSource
Object (OID)
Access
Value range
Implementation
hh3cTerminalSource (1.3.6.1.4.1.25506.2.2.1.1.2.2)
DisplayString
Login method, including Console, AUX, TTY, and VTY.
As per the MIB.
hh3cTerminalUserAuthFailureReason
Object (OID)
Access
Value range
Implementation
hh3cTerminalUserAuthFailureReason (1.3.6.1.4.1.25506.2.2.1.1.2.3)
INTEGER
exceedRetries(1)
authTimeout(2)
otherReason(3)
Failure reason for user authentication.
As per the MIB.
hh3cVtyCurrentVty
Object (OID)
Access
Value range
Implementation
hh3cVtyCurrentVty (1.3.6.1.4.1.25506.2.2.1.1.2.4)
Unsigned32
Number of used VTY lines.
As per the MIB.
hh3cVtyMaxVty
Object (OID)
Access
Value range
Implementation
hh3cVtyMaxVty (1.3.6.1.4.1.25506.2.2.1.1.2.5)
Unsigned32
Maximum number of VTY lines that the system allows users to log in to concurrently.
As per the MIB.
hh3cVtyThreshold
Object (OID)
Access
Value range
Implementation
hh3cVtyThreshold (1.3.6.1.4.1.25506.2.2.1.1.2.6)
Unsigned32
VTY usage alarm threshold.
As per the MIB.
Notifications
The following information describes the notifications included in the HH3C-UI-MAN-MIB module.
hh3cLogIn
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.2.1.1.3.0.1
User login
Informational
ON
This notification is generated when a user logs in to the system.
Status control
This alarm cannot be cleared.
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.2.1.1.2.1 (hh3cTerminalUserName)
Username.
No
DisplayString
OCTET STRING (SIZE (0..255))
1.3.6.1.4.1.25506.2.2.1.1.2.2 (hh3cTerminalSource)
User line, including console, AUX, TTY, and VTY.
No
DisplayString
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
No action is required.
hh3cLogOut
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.2.1.1.3.0.2
User logout
Informational
ON
This notification is generated when a user logs out of the system.
Status control
Objects
OID (object name)
Index
Value range
Username.
No
DisplayString
User line, including AUX, TTY, and VTY.
No
DisplayString
Recommended action
hh3cLogInAuthenFailure
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.2.1.1.3.0.3
User authentication failed
Informational
ON
This notification is generated when a user failed to log in to the system.
Status control
Objects
OID (object name)
Index
Value range
Username.
No
DisplayString
No
DisplayString
1.3.6.1.4.1.25506.2.2.1.1.2.3 (hh3cTerminalUserAuthFailureReason)
No
INTEGER
exceedRetries(1)
authTimeout(2)
otherReason(3)
Recommended action
hh3cVtyUsageExceed
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.2.1.1.3.0.4
The number of used VTY lines reached or exceeded the alarm threshold.
Informational
ON
This notification is generated when the number of used VTY lines reaches or exceeds the alarm threshold.
Status control
This alarm cannot be disabled.
Objects
OID (object name)
Index
Value range
(hh3cVtyCurrentVty)
No
Integer
(hh3cVtyMaxVty)
No
Integer
(hh3cVtyThreshold)
No
Integer
Recommended action
Release user lines.
hh3cVtyUsageResume
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.2.1.1.3.0.5
VTY usage alarm was cleared.
Informational
ON
This notification is generated when the number of used VTY lines drops below the VTY usage alarm threshold.
Status control
Objects
OID (object name)
Index
Value range
(hh3cVtyCurrentVty)
No
Integer
(hh3cVtyMaxVty)
No
Integer
(hh3cVtyThreshold)
No
Integer
Recommended action
