11-Security
HomeSupportReference GuidesMIB CompanionH3C S6826 & S9826 Switch Series MIB Companion-Release 671x-6W10011-Security
04-HH3C-SSH-MIB
04-HH3C-SSH-MIB 90.35 KB
HH3C-SSH-MIB
About this MIB
Secure Shell (SSH) is a network security protocol. Using encryption and authentication, SSH can implement secure remote access and file transfer over an insecure network.
SSH uses the typical client-server model to establish a channel for secure data transfer based on TCP.
SSH includes two versions: SSH1.x and SSH2.0 (hereinafter referred to as SSH1 and SSH2), which are not compatible. SSH2 is better than SSH1 in performance and security.
Use this MIB to configure the SSH service.
MIB file name
hh3c-ssh.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cSSH(22)
Scalar objects
hh3cSSHServerVersion
Object (OID)
Access
Value range
Implementation
hh3cSSHServerVersion (1.3.6.1.4.1.25506.2.22.1.1.1.1)
read-only
DisplayString
Standard MIB values.
The SSH protocol version of the SSH server.
The default value is 2.00. It is not compatible with SSH 1.x versions.
hh3cSSHServerCompatibleSSH1x
Object (OID)
Access
Value range
Implementation
hh3cSSHServerCompatibleSSH1x (1.3.6.1.4.1.25506.2.22.1.1.1.2)
read-write
INTEGER
enableCompatibleSSH1x(1),
disableCompatibleSSH1x(2)
Compatibility with SSH  1.x versions.
The default value is disableCompatibleSSH1x(2).
hh3cSSHServerRekeyInterval
Object (OID)
Access
Value range
Implementation
hh3cSSHServerRekeyInterval (1.3.6.1.4.1.25506.2.22.1.1.1.3)
read-write
Integer32
Time interval at which the SSH server key is regenerated.
Value range: 0 to 24.
The default value is 0, meaning that the key will not be refreshed.
hh3cSSHServerAuthRetries
Object (OID)
Access
Value range
Implementation
hh3cSSHServerAuthRetries (1.3.6.1.4.1.25506.2.22.1.1.1.4)
read-write
Integer32
Maximum number of SSH server authentication retries.
Range from 1 to 5.
The default value is 3.
hh3cSSHServerAuthTimeout
Object (OID)
Access
Value range
Implementation
hh3cSSHServerAuthTimeout (1.3.6.1.4.1.25506.2.22.1.1.1.5)
read-write
Integer32
SSH server authentication timeout time.
Range from 1 to 120.
The default value is 60.
hh3cSFTPServerIdleTimeout
Object (OID)
Access
Value range
Implementation
hh3cSFTPServerIdleTimeout (1.3.6.1.4.1.25506.2.22.1.1.1.6)
read-write
Integer32
SFTP connection idle timeout time.
Range from 1 to 35791.
The default value is 10.
hh3cSSHServerEnable
Object (OID)
Access
Value range
Implementation
hh3cSSHServerEnable (1.3.6.1.4.1.25506.2.22.1.1.1.7)
read-write
INTEGER
enableSSHServer(1),
disableSSHServer(2)
Enable or disable the SSH server.
The default value is disableSSHServer(2).
hh3cSFTPServerEnable
Object (OID)
Access
Value range
Implementation
hh3cSFTPServerEnable (1.3.6.1.4.1.25506.2.22.1.1.1.8)
read-write
INTEGER
enableSFTPService(1),
disableSFTPService(2)
Enable or disable the SFTP server.
The default value is disableSFTPService(2).
hh3cSTelnetServerEnable
Object (OID)
Access
Value range
Implementation
hh3cSTelnetServerEnable (1.3.6.1.4.1.25506.2.22.1.1.1.1.9)
read-write
INTEGER
enableSTelnetService(1),
disableSTelnetService(2)
Enable or disable Stelnet server.
As per the MIB.
hh3cSCPServerEnable
Object (OID)
Access
Value range
Implementation
hh3cSCPServerEnable (1.3.6.1.4.1.25506.2.22.1.1.1.1.10)
read-write
INTEGER
enableSCPServer(1),
disableSCPServer(2)
Enable or disable SCP server.
As per the MIB.
hh3cSSHAttemptUserName
Object (OID)
Access
Value range
Implementation
hh3cSSHAttemptUserName (1.3.6.1.4.1.25506.2.22.1.2.1)
accessible-for-notify
DisplayString
Name of the user who failed to connect to the server.
Length: 1 to 255 characters.
hh3cSSHAttemptIpAddrType
Object (OID)
Access
Value range
Implementation
hh3cSSHAttemptIpAddrType (1.3.6.1.4.1.25506.2.22.1.2.2)
InetAddressType
INTEGER{
unknown(0),
ipv4(1),
ipv6(2),
dns(16)
Address type of the user who failed to connect to the server.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cSSHAttemptIpAddr (1.3.6.1.4.1.25506.2.22.1.2.3)
InetAddress
OCTET STRING (0..255)
Address of user who failed to connect to the server.
As per the MIB.
hh3cSSHUserAuthFailureReason
Object (OID)
Access
Value range
Implementation
hh3cSSHUserAuthFailureReason (1.3.6.1.4.1.25506.2.22.1.2.4)
INTEGER
exceedRetries(1),
authTimeout(2),
otherReason(3)
Reason for the connection failure.
As per the MIB.
Tabular objects
hh3cSSHUserConfigTable
About this table
Use this table to configure or obtain SSH user information.
Support for operations
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table index is hh3cSSHUserName.
Object (OID)
Access
Value range
Implementation
hh3cSSHUserName (1.3.6.1.4.1.25506.2.22.1.1.2.1.1.1)
not-accessible
DisplayString
Name of an SSH user.
hh3cSSHUserServiceType (1.3.6.1.4.1.25506.2.22.1.1.2.1.1.2)
read-create
INTEGER
invalid(1),
all(2),
stelnet(3),
sftp(4),
scp(5),
netconf(6)
Service type of the SSH user.
The default value is invalid(1).
hh3cSSHUserAuthType (1.3.6.1.4.1.25506.2.22.1.1.2.1.1.3)
read-create
INTEGER
invalid(1),
password(2),
publicKey(3),
any(4),
publicKeyPassword(5),
keyboardInteractive(6)
Authentication type for the SSH user.
If the value is password, the user must pass password authentication of AAA.
If the value is publicKey, the user must pass the public key authentication of PKEY module.
If the value is any, the user must pass password or public key authentication.
If the value is publicKeyPassword, the user must pass both public key authentication and password authentication.
hh3cSSHUserPublicKeyName (1.3.6.1.4.1.25506.2.22.1.1.2.1.1.4)
read-create
DisplayString
Name of the public key used for authentication of the SSH user.
Length: 1 to 64 characters.
The default value is a zero-length string.
The value for this object is obtained from the public key generated in the PKEY module.
hh3cSSHUserWorkDirectory (1.3.6.1.4.1.25506.2.22.1.1.2.1.1.5)
read-create
DisplayString
Work directory of the SSH user.
Not supported.
hh3cSSHUserRowStatus (1.3.6.1.4.1.25506.2.22.1.1.2.1.1.6)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
When the hh3cSSHUserRowStatus is set to active(1), no objects in the conceptual row can be modified.
In particular, a newly created user row which uses public key authentication cannot be made active(1) until the corresponding instance of `hh3cSSHUserAuthType' is 'publicKey' or 'publicKeyPassword', and the 'hh3cSSHUserPublicKeyName' or at least one of the 'hh3cSSHUserPublicKeyName[2-6]' is configured appropriately.
hh3cSSHUserPublicKeyName2
(1.3.6.1.4.1.25506.2.22.1.1.2.1.1.7)
read-create
DisplayString
hh3cSSHUserPublicKeyName3 (1.3.6.1.4.1.25506.2.22.1.1.2.1.1.8)
read-create
DisplayString
hh3cSSHUserPublicKeyName4 (1.3.6.1.4.1.25506.2.22.1.1.2.1.1.9)
read-create
DisplayString
hh3cSSHUserPublicKeyName5 (1.3.6.1.4.1.25506.2.22.1.1.2.1.1.10)
read-create
DisplayString
hh3cSSHUserPublicKeyName6 (1.3.6.1.4.1.25506.2.22.1.1.2.1.1.11)
read-create
DisplayString
hh3cSSHSessionInfoTable
About this table
This table contains SSH session information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cSSHSessionID.
Object (OID)
Access
Value range
Implementation
hh3cSSHSessionID (1.3.6.1.4.1.25506.2.22.1.1.3.1.1)
not-accessible
Integer32
VTY number of an SSH session.
As per the MIB.
hh3cSSHSessionUserName (1.3.6.1.4.1.25506.2.22.1.1.3.1.2)
read-only
DisplayString
User name of the SSH session.
hh3cSSHSessionUserIpAddrType (1.3.6.1.4.1.25506.2.22.1.1.3.1.3)
read-only
InetAddressType
INTEGER{
unknown(0),
ipv4(1),
ipv6(2),
dns(16)
User IP address type of the SSH session.
As per the MIB.
hh3cSSHSessionUserIpAddr (1.3.6.1.4.1.25506.2.22.1.1.3.1.4)
read-only
InetAddress
User IP address of the SSH session.
As per the MIB.
hh3cSSHSessionClientVersion (1.3.6.1.4.1.25506.2.22.1.1.3.1.5)
read-only
DisplayString
Client protocol version of the SSH session.
As per the MIB.
hh3cSSHSessionServiceType (1.3.6.1.4.1.25506.2.22.1.1.3.1.6)
read-only
INTEGER
invalid(1),
stelnet(2),
sftp(3),
scp(4),
netconf(5)
Service type of the SSH session.
As per the MIB.
hh3cSSHSessionEncry (1.3.6.1.4.1.25506.2.22.1.1.3.1.7)
read-only
INTEGER
invalid(1),
aes128CBC(2),
desCBC(3),
des3CBC(4),
aes128CTR(5),
aes192CTR(6),
aes256CTR(7),
aes128GCM(8),
aes256GCM(9),
aes256CBC(10),
other(11)
Encryption algorithm of the SSH session.
As per the MIB.
hh3cSSHSessionState (1.3.6.1.4.1.25506.2.22.1.1.3.1.8)
read-only
INTEGER
init(1),
verExchange(2),
keysExchange(3),
authRequest(4),
serviceRequest(5),
established(6),
disconnect(7)
Status of the SSH session.
As per the MIB.
Notifications
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.22.1.3.0.1
User authentication failure
Informational
ON
This notification is generated when a user failed authentication.
Status control
This notification cannot be set to the OFF state.
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.22.1.2.1 (hh3cSSHAttemptUserName)
Name of the invalid user.
No
DisplayString
OCTET STRING(SIZE (0..255))
1.3.6.1.4.1.25506.2.22.1.2.2 (hh3cSSHAttemptIpAddrType)
Address type of the invalid user.
No
InetAddressType
INTEGER{
unknown(0),
ipv4(1),
ipv6(2),
dns(16)
1.3.6.1.4.1.25506.2.22.1.2.3 (hh3cSSHAttemptIpAddr)
Address of the invalid user.
No
InetAddress
OCTET STRING(0..255)
1.3.6.1.4.1.25506.2.22.1.2.4 (hh3cSSHUserAuthFailureReason)
Reason for the authentication failure.
No
INTEGER
exceedRetries(1)
authTimeout(2)
otherReason(3)
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
Make sure there are no invalid users attempt to log in.
hh3cSSHVersionNegotiationFailure
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.22.1.3.0.2
SSH version negotiation failure
Informational
ON
This notification is generated when SSH version negotiation fails.
Status control
Objects
OID (object name)
Index
Value range
No
InetAddressType
INTEGER{
unknown(0),
ipv4(1),
ipv6(2),
dns(16)
No
InetAddress
Recommended action
Make sure the client and server use the same SSH version.
hh3cSSHUserLogin
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.22.1.3.0.3
User login
Informational
ON
This notification is generated when a user successfully logs in.
Status control
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.22.1.1.3.1.2 (hh3cSSHSessionUserName)
No
DisplayString
1.3.6.1.4.1.25506.2.22.1.1.3.1.3 (hh3cSSHSessionUserIpAddrType)
User address type of the SSH session.
No
InetAddressType
INTEGER{
unknown(0),
ipv4(1),
ipv6(2),
dns(16)
1.3.6.1.4.1.25506.2.22.1.1.3.1.4 (hh3cSSHSessionUserIpAddr)
User address of the SSH session.
No
InetAddress
Recommended action
No action is required.
hh3cSSHUserLogoff
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.22.1.3.0.4
User logout
Informational
ON
This notification is generated when a user logs out.
Status control
Objects
OID (object name)
Index
Value range
No
DisplayString
No
InetAddressType
INTEGER{
unknown(0),
ipv4(1),
ipv6(2),
dns(16)
No
InetAddress
Recommended action
Make sure the user is a valid user.
