05-RFC1213-MIB | 64.65 KB |
RFC1213-MIB
About this MIB
The protocol-related objects and tables defined in this MIB are redefined and replaced by protocol-specific MIBs as follows:
· For information about interfaces, see the IF-MIB MIB document.
· For information about IP and ICMP, see the IP-MIB MIB document.
· For information about TCP, see the TCP-MIB MIB document.
· For information about UDP, see the UDP-MIB MIB document.
· For information about SNMP, see the SNMPv2-MIB MIB document.
MIB file name
rfc1213.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).system(1)
Scalar objects
sysDescr
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
sysDescr (1.3.6.1.2.1.1.1) |
read-only |
DisplayString |
OCTET STRING (0..255) |
A textual description of the entity. |
Implementation varies by product. |
sysObjectID
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
sysObjectID (1.3.6.1.2.1.1.2) |
read-only |
OBJECT IDENTIFIER |
Standard MIB values. |
The vendor's authoritative identification of the network management subsystem contained in the entity. |
sysUpTime
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
sysUpTime (1.3.6.1.2.1.1.3) |
read-only |
TimeTicks |
The time (in hundredths of a second) since the network management portion of the system was last re-initialized. |
As per the MIB. |
sysContact
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
sysContact (1.3.6.1.2.1.1.4) |
read-write |
DisplayString |
The textual identification of the contact person for this managed node, together with information how to contact this person. |
Implementation varies by product. Restores the default value by setting a zero-length string. |
sysName
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
sysName (1.3.6.1.2.1.1.5) |
read-write |
DisplayString |
An administratively-assigned name for this managed node. |
Implementation varies by product. A valid name is a string of 1 to 64 characters. |
sysLocation
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
sysLocation (1.3.6.1.2.1.1.6) |
read-write |
DisplayString |
The physical location of this device. |
sysServices
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
sysServices (1.3.6.1.2.1.1.7) |
read-only |
Integer32 |
INTEGER (0..127) |
A value which indicates the set of services that this entity primarily offers. |
The value is calculated as follows: 78 (2^ (2-1) + 2^ (3-1) + 2^ (4-1) + 2^ (7-1)) Layer functionality: · 2—Datalink/subnetwork (such as bridges) · 3—Internet (such as IP gateways). · 4—End-to-end (such as TCP). · 7—Applications (such as SMTP). |
Tabular objects
atTable
About this table
This table contains information about ARP entries.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are atIfIndex and atNetAddress.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
atIfIndex (1.3.6.1.2.1.3.1.1.1) |
read-write |
INTEGER |
The interface on which this entry's equivalence is effective. |
Supports only the read operation. |
atPhysAddress (1.3.6.1.2.1.3.1.1.2) |
read-write |
PhysAddress |
The media-dependent physical address. |
atNetAddress (1.3.6.1.2.1.3.1.1.3) |
read-write |
NetworkAddress |
The network address (for example, the IP address) corresponding to the media-dependent physical address. |
ipRouteTable
About this table
This table contains information about IP routes.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is ipRouteDest.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ipRouteDest(1.3.6.1.2.1.4.21.1.1) |
read-write |
IpAddress |
OCTET STRING (4) |
The destination IP address of this route. |
ipRouteIfIndex(1.3.6.1.2.1.4.21.1.2) |
read-write |
INTEGER |
The index value which uniquely identifies the local interface through which the next hop of this route should be reached. |
ipRouteMetric1(1.3.6.1.2.1.4.21.1.3) |
read-write |
INTEGER |
The primary routing metric for this route. |
ipRouteMetric2(1.3.6.1.2.1.4.21.1.4) |
read-write |
INTEGER |
An alternate routing metric for this route. |
ipRouteMetric3(1.3.6.1.2.1.4.21.1.5) |
read-write |
INTEGER |
ipRouteMetric4(1.3.6.1.2.1.4.21.1.6) |
read-write |
INTEGER |
ipRouteNextHop(1.3.6.1.2.1.4.21.1.7) |
read-write |
IpAddress |
OCTET STRING (4) |
The IP address of the next hop of this route. |
ipRouteType(1.3.6.1.2.1.4.21.1.8) |
read-write |
INTEGER |
INTEGER {other(1), invalid(2), direct(3), indirect(4)} |
The type of route. |
ipRouteProto(1.3.6.1.2.1.4.21.1.9) |
read-only |
INTEGER |
INTEGER {other(1), local(2), netmgmt(3), icmp(4), egp(5), ggp(6), hello(7), rip(8), is-is(9), es-is(10), ciscoIgrp(11), bbnSpfIgp(12), ospf(13), bgp(14)} |
The routing mechanism via which this route was learned. |
As per the MIB. |
ipRouteAge(1.3.6.1.2.1.4.21.1.10) |
read-write |
INTEGER |
The number of seconds since this route was last updated or otherwise determined to be correct. |
ipRouteMask(1.3.6.1.2.1.4.21.1.11) |
read-write |
IpAddress |
OCTET STRING (4) |
Indicates the mask to be logical-ANDed with the destination address before being compared to the value for the ipRouteDest object. |
ipRouteMetric5(1.3.6.1.2.1.4.21.1.12) |
read-write |
INTEGER |
ipRouteInfo(1.3.6.1.2.1.4.21.1.13) |
read-only |
OBJECT IDENTIFIER |
A reference to MIB definitions specific to the particular routing protocol which is responsible for this route, as determined by the value specified in the route's ipRouteProto value. |
As per the MIB. |
