02-HH3C-FLASH-MAN-MIB | 57.80 KB |
HH3C-FLASH-MAN-MIB
About this MIB
Use this MIB to obtain information about storage media, partitions, and files as well as manage files on the storage media.
MIB file name
hh3c-flash-man.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cFlash(5)
Scalar objects
hh3cFlhSupportNum
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFlhSupportNum (1.3.6.1.4.1.25506.2.5.1.1.1) |
read-only |
Integer32 |
Standard MIB values. |
Maximum number of storage media supported by the system. |
As per the MIB. |
hh3cFlhUsageRate
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFlhUsageRate (1.3.6.1.4.1.25506.2.5.1.4.1) |
accessible-for-notify |
Integer32 |
Current disk usage. |
As per the MIB. |
hh3cFlhUsageRateThreshold
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFlhUsageRateThreshold (1.3.6.1.4.1.25506.2.5.1.4.2) |
Integer32 |
Usage threshold. |
As per the MIB. |
hh3cFlhNameForTrap
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFlhNameForTrap (1.3.6.1.4.1.25506.2.5.1.4.3) |
DisplayString |
Disk name. |
As per the MIB. |
Tabular objects
hh3cFlashTable
About this table
Use this table to obtain information about storage media.
Notifications
The following information describes the notifications included in the HH3C-FLASH-MAN-MIB module.
hh3cFlhOperNotification
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.5.1.3.1 |
A file operation completed. |
Informational |
N/A |
N/A |
ON |
This notification is generated when a file operation completes if the value of hh3cFlhOperEndNotification is true.
The parameters included in this notification vary by file operation. For more information, see the online help for the NMS.
Status control
ON
MIB: Set hh3cFlhOperEndNotification to true(1).
OFF
MIB: Set hh3cFlhOperEndNotification to false(2).
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.5.1.2.1.1.9 (hh3cFlhOperStatus) |
File operation status. |
No |
Hh3cFlashOperationStatus |
opInProgress(1) opSuccess(2) opInvalid(3) opInvalidProtocol(4) opInvalidSourceName(5) opInvalidDestName(6) opInvalidServerAddress(7) opDeviceBusy(8) opDeviceOpenError(9) opDeviceError(10) opDeviceNotProgrammable(11) opDeviceFull(12) opFileOpenError(13) opFileTransferError(14) opFileChecksumError(15) opNoMemory(16) opAuthFail(17) opTimeout(18) opUnknownFailure(19) opDeleteFileOpenError(20) opDeleteInvalidDevice(21) opDeleteInvalidFunction(22) opDeleteOperationError(23) opDeleteInvalidFileName(24) opDeleteDeviceBusy(25) opDeleteParaError(26) opDeleteInvalidPath(27) opDeleteFileNotExistInSlave(28) opDeleteFileFailedInSlave(29) opSlaveFull(30) opCopyToSlaveFailure(31) |
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
Handle the issue according to the file operation result.
hh3cFlhUsageOverThreshold
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.5.1.4.0.1 |
The disk usage exceeded the threshold. |
Informational |
N/A |
N/A |
ON |
This notification is generated when the disk usage exceeds the alarm threshold.
Status control
None.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.5.1.5.1 (hh3cFlhUsageRate) |
No |
Integer32 |
1.3.6.1.4.1.25506.2.5.1.5.2 (hh3cFlhUsageRateThreshold) |
Disk usage threshold. |
No |
Integer32 |
1.3.6.1.4.1.25506.2.5.1.5.3 (hh3cFlhNameForTrap) |
Disk name. |
No |
DisplayString |
Recommended action
Verify that the disk space is insufficient and clear unnecessary files as needed.
hh3cFlhUsageResume
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.5.1.4.0.2 |
The disk usage dropped below the threshold. |
Informational |
N/A |
N/A |
ON |
This notification is generated when the disk usage drops below the alarm threshold.
Status control
None.
Objects
OID (object name) |
Index |
Type |
Value range |
No |
Integer32 |
No |
Integer32 |
Disk name. |
No |
DisplayString |
Recommended action
No action is required.
