06-IP Multicast Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S6805 & S6825 & S6850 & S9850 Command References-Release 671x-6W10006-IP Multicast Command Reference
10-IPv6 PIM snooping commands
10-IPv6 PIM snooping commands 84.06 KB
display ipv6 pim-snooping neighbor
Use display ipv6 pim-snooping neighbor to display IPv6 PIM snooping neighbor information.
display ipv6 pim-snooping neighbor [ vlan vlan-id | vsi vsi-name ] [ slot slot-number ] [ verbose ]
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays IPv6 PIM snooping neighbor information for all VLANs.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays IPv6 PIM snooping neighbor information for all VSIs.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays IPv6 PIM snooping neighbor information for the master device.
verbose: Displays detailed information about IPv6 PIM snooping neighbors. If you do not specify this keyword, the command displays brief information about IPv6 PIM snooping neighbors.
# Display detailed information about IPv6 PIM snooping neighbors for VLAN 2.
<Sysname> display ipv6 pim-snooping neighbor vlan 2 verbose
Total 2 neighbors.
VLAN 2: Total 2 neighbors.
  FE80::6401:101
    Slots (0 in total):
    Ports (1 in total):
      WGE1/0/1                              (02:02:23)    LAN Prune Delay(T)
  FE80::C801:101
    Slots (0 in total):
    Ports (1 in total):
      WGE1/0/2                              (02:02:25)
# Display brief information about IPv6 PIM snooping neighbors for VSI aaa.
<Sysname> display ipv6 pim-snooping neighbor vsi aaa
Total 3 neighbors.
VSI aaa: Total 3 neighbors.
  FE80::1
    Ports (1 in total):
      WGE1/0/3 (Link ID 0)                 (00:02:04)
  FE80::2
    Ports (1 in total):
      NPW (Link ID 8)                     (00:02:04)
  FE80::3
    Ports (1 in total):
      UPW (Link ID 9)                     (00:02:13)
# Display brief information about IPv6 PIM snooping neighbors for VSI bbb.
<Sysname> display ipv6 pim-snooping neighbor vsi bbb
Total 2 neighbors.
VSI bbb: Total 2 neighbors.
  FE80::1
    Ports (1 in total):
  FE80::4
    Ports (1 in total):
      Tun0 (VXLAN ID 0)                   (00:02:13)
Total 2 neighbors
Total number of IPv6 PIM snooping neighbors.
Total number of IPv6 PIM snooping neighbors in VLAN 2.
VSI aaa: Total 2 neighbors
Total number of IPv6 PIM snooping neighbors in VSI aaa.
FE80::6401:101
IPv6 address of the IPv6 PIM snooping neighbor.
Slots (0 in total)
Member IDs and total number of the member devices that have the neighbor, except for the specified member device or the master device when no member device is specified.
Ports (1 in total)
Ports where IPv6 PIM snooping neighbors reside, and the total number of the ports.
(02:02:23)
Remaining aging time for an IPv6 PIM snooping neighbor on the port.
This field is always displayed for a global port (such as Layer 2 aggregate interfaces).
For a non-global port, this field is displayed when one of the following conditions exists:
·     The port is on the specified member device.
·     The port is on the master device and no member device is specified.
LAN Prune Delay
IPv6 PIM hello message sent by the IPv6 PIM snooping neighbor has the LAN_Prune_Delay option.
(T)
The join report suppression feature has been disabled for the IPv6 PIM snooping neighbor.
AC and its link ID.
NPW (Link ID 8)
N-PW and its link ID.
UPW (Link ID 9)
U-PW and its link ID.
Tun0 (VXLAN ID 0)
VXLAN tunnel and its VXLAN ID.
display ipv6 pim-snooping router-port
Use display ipv6 pim-snooping router-port to display IPv6 PIM snooping router port information.
display ipv6 pim-snooping router-port [ vlan vlan-id | vsi vsi-name ] [ slot slot-number ] [ verbose ]
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays IPv6 PIM snooping router port information for all VLANs.
verbose: Displays detailed information about IPv6 PIM snooping router ports. If you do not specify this keyword, the command displays brief information about IPv6 PIM snooping router ports.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays IPv6 PIM snooping router port information for all VSIs.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays IPv6 PIM snooping router port information for the master device.
# Display brief information about IPv6 PIM snooping router ports for VLAN 2.
<Sysname> display ipv6 pim-snooping router-port vlan 2
VLAN 2:
  Router ports (2 in total):
    WGE1/0/1                              (00:01:30)
    WGE1/0/2                              (00:01:32)
# Display detailed information about IPv6 PIM snooping router ports for VLAN 2.
<Sysname> display ipv6 pim-snooping router-port vlan 2 verbose
VLAN 2:
  Router slots (0 in total):
    WGE1/0/1                             (00:01:30)
    WGE1/0/2                             (00:01:32)
# Display brief information about IPv6 PIM snooping router ports for VSI aaa.
<Sysname> display ipv6 pim-snooping router-port vsi aaa
VSI aaa:
  Router ports (3 in total):
    WGE1/0/3 (Link ID 0)                 (00:02:43)
    NPW (Link ID 8)                     (00:02:52)
    UPW (Link ID 9)                     (00:02:52)
# Display detailed information about IPv6 PIM snooping router ports for VSI bbb.
<Sysname> display ipv6 pim-snooping router-port vsi bbb verbose
VSI bbb:
    Tun0 (VXLAN ID 0)                   (00:02:52)
VLAN 2
VLAN ID.
VSI aaa
VSI name.
Member IDs and total number of the member devices that have router ports, except for the specified member device or the master device when no member device is specified.
Router ports and total number of router ports.
(00:01:30)
Remaining aging time for the router port.
For a global port, this field is always displayed.
AC and its link ID.
NPW (Link ID 8)
UPW (Link ID 9)
Tun0 (VXLAN ID 0)
display ipv6 pim-snooping routing-table
Use display ipv6 pim-snooping routing-table to display IPv6 PIM snooping routing entries.
display ipv6 pim-snooping routing-table [ vlan vlan-id | vsi vsi-name ] [slot slot-number ] [ verbose ]
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays IPv6 PIM snooping routing entries for all VLANs.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays IPv6 PIM snooping routing entries for all VSIs.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays IPv6 PIM snooping routing entries for the master device.
verbose: Displays detailed information about IPv6 PIM snooping routing entries. If you do not specify this keyword, the command displays brief information about IPv6 PIM snooping routing entries.
# Display detailed information about IPv6 PIM snooping routing entries for VLAN 2.
<Sysname> display ipv6 pim-snooping routing-table vlan 2 verbose
Total 1 entries.
FSM Flag: NI-no info, J-join, PP-prune pending
VLAN 2: Total 1 entries.
  (2000::1, FF1E::1)
    FSM information: dummy
    Upstream neighbor: FE80::101
      Upstream Slots (0 in total):
      Upstream Ports (1 in total):
        WGE1/0/1
      Downstream Slots (0 in total):
      Downstream Ports (2 in total):
        WGE1/0/2
          Expires: 00:03:01, FSM: J
          Downstream Neighbors (2 in total):
            1001::1
              Expires: 00:59:19, FSM: J
            1001::2
              Expires: 00:59:20, FSM: J
        WGE1/0/3
          Expires: 00:02:21, FSM: PP
Total 1 entries
Total number of (S, G) and (*, G) entries.
State machine flag of the downstream port:
·     NI—Initial state.
·     J—Join.
·     PP—Prune pending.
Total number of (S, G) entries in VLAN 2.
VSI aaa: Total 1 entries
Total number of (S, G) entries in VSI aaa.
(2000::1, FF1E::1)
(S, G) entry.
FSM information
Finite state machine information for the entry:
·     delete—The entry attributes have been deleted.
·     dummy—The entry is a new temporary entry.
·     no info—The entry does not exist.
·     normal—The entry is a correct entry.
Upstream neighbor
Upstream neighbor of the (S, G) or (*, G) entry.
Member IDs and total number of the member devices that have the upstream neighbor, except for the specified member device or the master device when no member device is specified.
Upstream ports, and the total number of the ports.
This field is displayed when one of the following conditions exists:
Member IDs and total number of the member devices that have downstream ports, except for the specified member device or the master device when no member device is specified.
Downstream ports of the upstream neighbor, and the total number of the ports.
Downstream neighbors of the downstream port, and the total number of the neighbors.
Remaining aging time for the downstream port or downstream neighbor, and the finite sate machine information.
AC and its link ID.
NPW (Link ID 8)
UPW (Link ID 9)
Tun0 (VXLAN ID 0)
display ipv6 pim-snooping statistics
Use display ipv6 pim-snooping statistics to display statistics for the IPv6 PIM messages learned through IPv6 PIM snooping.
# Display statistics for the IPv6 PIM messages learned through IPv6 PIM snooping.
<Sysname> display ipv6 pim-snooping statistics
Received IPv6 PIM message:
  IPv6 PIM hello:  0
    M-LAG: 0
  IPv6 PIM join/prune:  0
    M-LAG: 0
  IPv6 PIM error:  0
    M-LAG: 0
Received IPv6 PIM messages in total:  200
IPv6 PIM hello
Number of received IPv6 PIM hello messages.
M-LAG
Number of IPv6 PIM messages received on M-LAG peer-link interfaces.
IPv6 PIM join/prune
Number of received IPv6 PIM join/prune messages.
IPv6 PIM error
Number of received IPv6 PIM messages with errors.
Total number of received IPv6 PIM messages.
reset ipv6 pim-snooping statistics
ipv6 pim-snooping enable
Use ipv6 pim-snooping enable to enable IPv6 PIM snooping for a VLAN or VSI.
Use undo ipv6 pim-snooping enable to disable IPv6 PIM snooping for a VLAN or VSI.
IPv6 PIM snooping is disabled for a VLAN or VSI.
VLAN view
VSI view
IPv6 PIM snooping does not take effect on sub-VLANs of IPv6 multicast VLANs.
You must enable the MLD snooping feature and enable MLD snooping for a VLAN or VSI before you execute this command.
# Enable the MLD snooping feature, and then enable MLD snooping and IPv6 PIM snooping for VLAN 2.
[Sysname] mld-snooping
[Sysname-mld-snooping] quit
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping enable
[Sysname-vlan2] ipv6 pim-snooping enable
# Enable the MLD snooping feature, and then enable MLD snooping and IPv6 PIM snooping for VSI aaa.
[Sysname] vsi aaa
[Sysname-vsi-aaa] mld-snooping enable
[Sysname-vsi-aaa] ipv6 pim-snooping enable
mld-snooping
mld-snooping enable
ipv6 pim-snooping graceful-restart join-aging-time
Use ipv6 pim-snooping graceful-restart join-aging-time to set the aging time for global downstream ports and global router ports on the new master device after a master/subordinate switchover.
Use undo ipv6 pim-snooping graceful-restart join-aging-time to restore the default.
ipv6 pim-snooping graceful-restart join-aging-time seconds
The aging time is 210 seconds for global downstream ports and global router ports on the new master device after a master/subordinate switchover.
VLAN view
VSI view
seconds: Specifies an aging time in the range of 210 to 18000 seconds.
You must enable IPv6 PIM snooping for a VLAN or VSI before you execute this command.
Global ports include Layer 2 aggregate interfaces. A global downstream port or a global router port is a global port that acts as a downstream port or router port, respectively.
# In VLAN 2, set the aging time to 300 seconds for global downstream ports and global router ports on the new master device after a master/subordinate switchover.
[Sysname] vlan 2
[Sysname-vlan2] ipv6 pim-snooping graceful-restart join-aging-time 300
# In VSI aaa, set the aging time to 600 seconds for global downstream ports and global router ports on the new master device after a master/subordinate switchover.
[Sysname] vsi aaa
[Sysname-vsi-aaa] ipv6 pim-snooping graceful-restart join-aging-time 600
ipv6 pim-snooping graceful-restart neighbor-aging-time
Use ipv6 pim-snooping graceful-restart neighbor-aging-time to set the aging time for global neighbor ports on the new master device after a master/subordinate switchover.
Use undo ipv6 pim-snooping graceful-restart neighbor-aging-time to restore the default.
ipv6 pim-snooping graceful-restart neighbor-aging-time seconds
The aging time is 105 seconds for global neighbor ports on the new master device after a master/subordinate switchover.
VLAN view
VSI view
seconds: Specifies an aging time in the range of 105 to 18000 seconds.
Global ports include Layer 2 aggregate interfaces. A global neighbor port is a global port that acts as a neighbor port.
# In VLAN 2, set the aging time to 300 seconds for global neighbor ports on the new master device after a master/subordinate switchover.
[Sysname] vlan 2
[Sysname-vlan2] ipv6 pim-snooping graceful-restart neighbor-aging-time 300
# In VSI aaa, set the aging time to 300 seconds for global neighbor ports on the new master device after a master/subordinate switchover.
[Sysname] vsi aaa
[Sysname-vsi-aaa] ipv6 pim-snooping graceful-restart neighbor-aging-time 300
Use reset ipv6 pim-snooping statistics to clear statistics for the IPv6 PIM messages learned through IPv6 PIM snooping.
# Clear statistics for the IPv6 PIM messages learned through IPv6 PIM snooping.
<Sysname> reset ipv6 pim-snooping statistics
