03-Layer 2-LAN Switching Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S6805 & S6825 & S6850 & S9850 Command References-Release 671x-6W10003-Layer 2-LAN Switching Command Reference
17-Layer 2 forwarding commands
17-Layer 2 forwarding commands 33.88 KB
Cut-through Layer 2 forwarding commands
cut-through enable
Use cut-through enable to enable cut-through forwarding.
Use undo cut-through enable to disable cut-through forwarding.
cut-through enable
Cut-through forwarding is disabled.
A cut-through forwarding-enabled device forwards a frame after it receives the first 64 bytes of the frame. This feature reduces the transmission time of a frame within the device and enhances forwarding performance.
A frame is forwarded before its CRC field is received, and thus CRC-error frames are forwarded instead of being dropped.
The cut-through forwarding does not take effect for traffic from multiple ingress ports to the same destination port or traffic from one ingress port to multiple destination ports.
This command does not take effect on the two SFP ports on the back panel of an S6850-56HF or S9850-4C switch.
# Enable cut-through forwarding on the device.
[Sysname] cut-through enable
