- 03-Layer 2-LAN Switching Command Reference
- 01-MAC address table commands
- 02-Bulk interface commands
- 03-Ethernet interface commands
- 04-Ethernet link aggregation commands
- 05-M-LAG commands
- 06-Port isolation commands
- 07-VLAN commands
- 08-MVRP commands
- 09-Loopback, null, and inloopback interface commands
- 10-QinQ commands
- 11-VLAN mapping commands
- 12-Loop detection commands
- 13-Spanning tree commands
- 14-LLDP commands
- 15-L2PT commands
- 16-Service loopback group commands
- 17-Layer 2 forwarding commands
| 03-Ethernet interface commands | 410.19 KB |
Common Ethernet interface commands
display link-state-change statistics interface
reset link-state-change statistics interface
shutdown all-physical-interface
snmp-agent trap enable ifmonitor
Layer 2 Ethernet interface commands
Layer 3 Ethernet interface or subinterface commands
bandwidth
Use bandwidth to set the expected bandwidth of an interface.
bandwidth bandwidth-value
undo bandwidth
Ethernet interface view
Ethernet subinterface view
# Set the expected bandwidth of Twenty-FiveGigE 1/0/1 to 1000 kbps.
[Sysname] interface twenty-fivegige 1/0/1
[Sysname-Twenty-FiveGigE1/0/1] bandwidth 1000
# Set the expected bandwidth of Twenty-FiveGigE 1/0/1.1 to 1000 kbps.
[Sysname] interface twenty-fivegige 1/0/1.1
[Sysname-Twenty-FiveGigE1/0/1.1] bandwidth 1000
speed
broadcast-suppression
Use broadcast-suppression to enable broadcast suppression and set the broadcast suppression threshold.
Use undo broadcast-suppression to disable broadcast suppression.
Ethernet interfaces do not suppress broadcast traffic.
ratio: Sets the broadcast suppression threshold as a percentage of the interface bandwidth. The value range for this argument is 0 to 100. A smaller value means that less broadcast traffic is allowed to pass through.
pps max-pps: Specifies the maximum number of broadcast packets that the interface can forward per second. The value range for the max-pps argument (in pps) is 0 to 1.4881 × the interface bandwidth.
kbps max-kbps: Specifies the maximum number of kilobits of broadcast traffic that the Ethernet interface can forward per second. The value range for this argument (in kbps) is 0 to the interface bandwidth.
The broadcast storm suppression features limits the size of broadcast traffic to a threshold on an interface. When the broadcast traffic on the interface exceeds this threshold, the system drops packets until the traffic drops below this threshold.
Both the storm-constrain command and the broadcast-suppression command can suppress broadcast storms on a port. The broadcast-suppression command uses the chip to physically suppress broadcast traffic. It has less influence on the device performance than the storm-constrain command, which uses software to suppress broadcast traffic.
For the traffic suppression result to be determined, do not configure both the storm-constrain broadcast command and the broadcast-suppression command on an interface.
When you configure the suppression threshold in kbps, the actual suppression threshold might be different from the configured one as follows:
· If the configured value is smaller than 64, the value of 64 takes effect.
· If the configured value is greater than 64 but not an integer multiple of 64, the integer multiple of 64 that is greater than and closest to the configured value takes effect.
To determine the suppression threshold that takes effect, see the prompts on the switch.
Set the same type of thresholds for each interface, that is, set the ratio argument, the pps max-pps option, or the kbps max-kbps option for the interface.
# Set the broadcast suppression threshold to 10000 kbps on Twenty-FiveGigE 1/0/1.
[Sysname-Twenty-FiveGigE1/0/1] broadcast-suppression kbps 10000
The actual value is 10048 on port Twenty-FiveGigE1/0/1 currently.
The output shows that the value that takes effect is 10048 kbps (157 times of 64), because the chip only supports step 64.
multicast-suppression
unicast-suppression
dampening
Use dampening to enable the device to dampen an interface when the interface is flapping.
Use undo dampening to restore the default.
undo dampening
Interface dampening is disabled on Ethernet interfaces.
half-life: Specifies the amount of time after which a penalty is decreased, in the range of 1 to 120 seconds. The default value is 54 seconds.
reuse: Specifies the reuse threshold in the range of 200 to 20000. The default value is 750. The reuse threshold must be less than the suppression threshold.
suppress: Specifies the suppression threshold in the range of 200 to 20000. The default value is 2000.
max-suppress-time: Specifies the maximum amount of time the interface can be dampened, in the range of 1 to 255 seconds. The default value is 162 seconds (three times the half-life timer).
When configuring the dampening command, follow these rules to set the values mentioned above:
· The ceiling is equal to 2 (Max-suppress-time/Decay) × reuse-limits. It is not user configurable.
· The configured suppress limit is lower than or equal to the ceiling.
· The ceiling is lower than or equal to the maximum suppress limit supported.
This command, the link-delay command, and the port link-flap protect enable command are mutually exclusive on an interface.
This command does not take effect on the administratively down events. When you execute the shutdown command, the penalty restores to 0, and the interface reports the down event to the higher layer protocols.
Do not enable the dampening function on an interface with RRPP, MSTP, or Smart Link enabled.
After an interface in down state is dampened, the interface state displayed through the display interface command is always down.
# Enable interface dampening on Twenty-FiveGigE 1/0/1.
[Sysname-Twenty-FiveGigE1/0/1] dampening
# Enable interface dampening on Twenty-FiveGigE 1/0/1, and set the following parameters:
· Half life time to 2 seconds.
· Reuse value to 800.
· Suppression threshold to 3000.
· Maximum suppression interval to 5 seconds.
[Sysname-Twenty-FiveGigE1/0/1] dampening 2 800 3000 5
display interface
link-delay
default
Use default to restore the default settings for an interface.
default
CAUTION: The default command might interrupt ongoing network services. Make sure you are fully aware of the impacts of this command when you use it in a live network. |
This command might fail to restore the default settings for some commands because of command dependencies or system restrictions. You can use the display this command in interface view to identify these commands, and use their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message instructions to solve the problem.
# Restore the default settings for Twenty-FiveGigE 1/0/1.
[Sysname-Twenty-FiveGigE1/0/1] default
# Restore the default settings for Twenty-FiveGigE 1/0/1.1.
[Sysname-Twenty-FiveGigE1/0/1.1] default
description
The description of an interface is the interface name plus Interface (for example, Twenty-FiveGigE1/0/1 Interface).
text: Specifies the interface description, a case-sensitive string of 1 to 255 characters.
# Set the description of Twenty-FiveGigE 1/0/1 to lan-interface.
[Sysname-Twenty-FiveGigE1/0/1] description lan-interface
# Set the description of Twenty-FiveGigE 1/0/1.1 to subinterface1/0/1.1.
[Sysname-Twenty-FiveGigE1/0/1.1] description subinterface1/0/1.1
display counters
Use display counters to display interface traffic statistics.
display counters { inbound | outbound } interface [ interface-type [ interface-number ] ]
inbound: Displays inbound traffic statistics.
outbound: Displays outbound traffic statistics.
To clear the Ethernet interface traffic statistics, use the reset counters interface command.
If you do not specify an interface type, this command displays traffic statistics for all interfaces that have traffic counters.
If you specify an interface type but do not specify an interface number, this command displays traffic statistics for all interfaces of the specified type.
If you specify an interface type and number, this command displays traffic statistics for the specified interface.
# Display inbound traffic statistics for all interfaces.
<Sysname> display counters inbound interface
Interface Total (pkts) Broadcast (pkts) Multicast (pkts) Err (pkts)
WGE1/0/1 100 100 0 0
WGE1/0/2 Overflow Overflow Overflow Overflow
Overflow: More than 14 digits (7 digits for column "Err").
--: Not supported.
Abbreviated interface name. |
Total (pkts) |
Total number of packets received or sent through the interface. |
Broadcast (pkts) |
Total number of broadcast packets received or sent through the interface. |
Multicast (pkts) |
Total number of multicast packets received or sent through the interface. |
Err (pkts) |
Total number of error packets received or sent through the interface. |
Overflow: More than 14 digits (7 digits for column "Err") |
The command displays Overflow when any of the following conditions exist: · The data length of an Err field value is greater than 7 decimal digits. · The data length of a non-Err field value is greater than 14 decimal digits. |
--: Not supported |
The statistical item is not supported. |
display counters rate
Use display counters rate to display traffic rate statistics for interfaces in up state for the most recent statistics polling interval.
display counters rate { inbound | outbound } interface [ interface-type [ interface-number ] ]
inbound: Displays inbound traffic rate statistics.
outbound: Displays outbound traffic rate statistics.
If you do not specify an interface type, this command displays traffic rate statistics for all up interfaces that have traffic counters.
If you specify an interface type but do not specify an interface number, this command displays traffic rate statistics for all up interfaces of the specified type.
If you specify an interface type and an interface, this command displays traffic rate statistics for the specified interface.
If an interface that you specify is always down for the most recent statistics polling interval, the system prompts that the interface does not support the command.
To set the statistics polling interval, use the flow-interval command.
# Display the inbound traffic rate statistics for all interfaces.
<Sysname> display counters rate inbound interface
Usage: Bandwidth utilization in percentage
Interface Usage (%) Total (pps) Broadcast (pps) Multicast (pps)
WGE1/0/1 0 0 -- --
Overflow: More than 14 digits.
--: Not supported.
Usage (%) |
Bandwidth usage (in percentage) of the interface for the last statistics polling interval. |
Total (pps) |
Average receiving or sending rate (in pps) for unicast packets for the last statistics polling interval. |
Broadcast (pps) |
Average receiving or sending rate (in pps) for broadcast packets for the last statistics polling interval. |
Multicast (pps) |
Average receiving or sending rate (in pps) for multicast packets for the last statistics polling interval. . |
Overflow: more than 14 decimal digits |
The command displays Overflow if the data length of a statistical item is greater than 14 decimal digits. |
--: not supported |
flow-interval
display ethernet statistics
Use display ethernet statistics to display the Ethernet module statistics.
display ethernet statistics slot slot-number
slot slot-number: Specifies an IRF member device by its member ID.
# Display the Ethernet module statistics for the specified slot.
<Sysname> display ethernet statistics slot 1
ETH receive packet statistics:
Totalnum : 10447 ETHIINum : 4459
SNAPNum : 0 RAWNum : 0
LLCNum : 0 UnknownNum : 0
ForwardNum : 4459 ARP : 0
MPLS : 0 ISIS : 0
ISIS2 : 0 IP : 0
IPV6 : 0
ETH receive error statistics:
NullPoint : 0 ErrIfindex : 0
ErrIfcb : 0 IfShut : 0
ErrAnalyse : 5988 ErrSrcMAC : 5988
ErrHdrLen : 0
ETH send packet statistics:
L3OutNum : 211 VLANOutNum : 0
FastOutNum : 155 L2OutNum : 0
ETH send error statistics:
MbufRelayNum : 0 NullMbuf : 0
ErrAdjFwd : 0 ErrPrepend : 0
ErrHdrLen : 0 ErrPad : 0
ErrQoSTrs : 0 ErrVLANTrs : 0
ErrEncap : 0 ErrTagVLAN : 0
IfShut : 0 IfErr : 0
Table 3 Output description
ETH receive packet statistics |
Statistics about the Ethernet packets received by the Ethernet module: · Totalnum—Total number of received packets. · ETHIINum—Number of packets encapsulated by using Ethernet II. · SNAPNum—Number of packets encapsulated by using SNAP. · RAWNum—Number of packets encapsulated by using RAW. · LLCNum—Number of packets encapsulated by using LLC. · UnknownNum—Number of packets encapsulated by using unknown methods. · ForwardNum—Number of packets forwarded at Layer 2 or sent to the CPU. · ARP—Number of ARP packets. · MPLS—Number of MPLS packets. · ISIS—Number of IS-IS packets. · ISIS2—Number of large 802.3/802.2 frames encapsulated by using IS-IS. · IP—Number of IP packets. · IPv6—Number of IPv6 packets. |
ETH receive error statistics |
Statistics about the error Ethernet packets in the inbound direction on the Ethernet module. Errors might be included in packets or occur during the receiving process. The items include: · NullPoint—Number of packets that include null pointers. · ErrIfindex—Number of packets that include incorrect interface indexes. · ErrIfcb—Number of packets that include incorrect interface control blocks. · IfShut—Number of packets that are being received when the interface is shut down. · ErrAnalyse—Number of packets that include packet parsing errors. · ErrSrcMAC—Number of packets that include incorrect source MAC addresses. · ErrHdrLen—Number of packets that include header length errors. |
ETH send packet statistics |
Statistics about the Ethernet packets sent by the Ethernet module: · L3OutNum—Number of packets sent out of Layer 3 Ethernet interfaces. · VLANOutNum—Number of packets sent out of VLAN interfaces. · FastOutNum—Number of packets fast forwarded. · L2OutNum—Number of packets sent out of Layer 2 Ethernet interfaces. |
ETH send error statistics |
Statistics about the error Ethernet packets in the outbound direction on the Ethernet module: · MbufRelayNum—Number of packets transparently sent. · NullMbuf—Number of packets with null pointers. · ErrAdjFwd—Number of packets with adjacency table errors. · ErrPrepend—Number of packets with extension errors. · ErrHdrLen—Number of packets with header length errors. · ErrPad—Number of packets with padding errors. · ErrQoSTrs—Number of packets that failed to be sent by QoS. · ErrVLANTrs—Number of packets that failed to be sent in VLANs. · ErrEncap—Number of packets that failed to be sent due to link header encapsulation failures. · ErrTagVLAN—Number of packets that failed to be sent due to VLAN tag encapsulation failures. · IfShut—Number of packets that are being sent when the interface is shut down. · IfErr—Number of packets with incorrect outgoing interfaces. |
reset ethernet statistics
display interface
Use display interface to display interface information.
display interface [ interface-type [ interface-number | interface-number.subnumber ] ] [ brief [ description | down ] ]
interface-number.subnumber: Specifies a subinterface number. The interface-number argument is an interface number. The subnumber argument is the number of a subinterface created under the interface. The value range for the subnumber argument is 1 to 4094.
description: Displays complete interface descriptions. If you do not specify this keyword, the command displays only the first 25 characters of each interface description.
down: Displays information about interfaces in down state and the causes. If you do not specify this keyword, the command displays information about interfaces in all states.
If you do not specify an interface type, this command displays information about all interfaces.
If you specify an interface type but do not specify an interface number, this command displays information about all interfaces of the specified type.
# Display information about Layer 3 interface Twenty-FiveGigE 1/0/1.
<Sysname> display interface twenty-fivegige 1/0/1
Line protocol state: DOWN
Description: Twenty-FiveGigE1/0/1 Interface
Bandwidth: 25000000 kbps
Allow jumbo frames to pass
Broadcast max-ratio: 100%
Multicast max-ratio: 100%
Unicast max-ratio: 100%
Known-unicast max-ratio: 100%
IP packet frame type: Ethernet II, hardware address: e0fd-0079-5051
IPv6 packet frame type: Ethernet II, hardware address: e0fd-0079-5051
Loopback is not set
Media type is not sure, port hardware type is No connector
Ethernet port mode: LAN
Port priority: 0
Flow-control is not enabled
The maximum frame length is 9416
Last link flapping: Never
Current system time:2001-01-01 06:39:15
Last time when physical state changed to up:-
Last time when physical state changed to down:2001-01-01 06:39:12
Peak input rate: 0 bytes/sec, at 2001-01-01 06:39:15
Peak output rate: 0 bytes/sec, at 2001-01-01 06:39:15
Last 300 seconds input: 0 packets/sec 0 bytes/sec -%
Last 300 seconds output: 0 packets/sec 0 bytes/sec -%
Input (total): 0 packets, 0 bytes
Input (normal): 0 packets, - bytes
Input: 0 input errors, 0 runts, 0 giants, 0 throttles
0 CRC, 0 frame, - overruns, 0 aborts
- ignored, - parity errors
Output (normal): 0 packets, - bytes
Output: 0 output errors, - underruns, 0 buffer failures
0 lost carrier, - no carrier
IPv4 traffic statistics:
Last 300 seconds input rate: 0 packets/sec, 0 bytes/sec
Last 300 seconds output rate: 0 packets/sec, 0 bytes/sec
Input: 0 packets, 0 bytes
Output: 0 packets, 0 bytes
IPv6 traffic statistics:
# Display detailed information about Layer 2 interface Twenty-FiveGigE 1/0/1.
Current state: DOWN
IP packet frame type: Ethernet II, hardware address: e0fd-0079-505c
Loopback is not set
Maximum frame length: 9416
PVID: 1
MDI type: Automdix
Port link-type: Access
Tagged VLANs: None
Untagged VLANs: 1
Port priority: 0
Current system time:2001-01-01 06:41:17
Last time when physical state changed to down:2001-01-01 06:41:15
Peak input rate: 0 bytes/sec, at 00-00-00 00:00:00
Peak output rate: 0 bytes/sec, at 00-00-00 00:00:00
Current state |
Physical link state of the interface: · Administratively DOWN—The interface has been shut down by using the shutdown command. · Administratively DOWN(Global)—The interface has been shut down by using the shutdown all-physical-interfaces command in system view. · DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed). · DOWN ( Link-Aggregation interface down )—The aggregate interface to which the interface belongs has been shut down by using the shutdown command. · DOWN (Monitor-Link uplink down )—The interface has been shut down by Monitor Link. · Link-Flap DOWN—The interface has been shut down by the link flapping protection feature. · mac-address moving down—The interface has been shut down by the MAC address move suppression feature. · MAD ShutDown—The interface has been shut down by IRF MAD. This state occurs if the interface is on an IRF fabric placed in Recovery state after an IRF split. · OFP DOWN—The interface has been shut down by OpenFlow. · Storm-Constrain—The interface has been shut down because the storm control feature detected that unknown unicast traffic, multicast traffic, or broadcast traffic exceeded the upper threshold. · STP DOWN—The interface has been shut down by the BPDU guard feature. · M-LAG MAD Shutdown—The interface was set to the M-LAG MAD DOWN state when the M-LAG system split. · UP—The interface is both administratively and physically up. |
Line protocol state |
Data link layer state of the interface. The state is determined through automatic parameter negotiation at the data link layer. · UP—The data link layer protocol is up. · UP (spoofing)—The data link layer protocol is up, but the link is an on-demand link or does not exist. This attribute is typical of null interfaces and loopback interfaces. · DOWN—The data link layer protocol is down. · DOWN (protocols)—The data link layer has been shut down by protocols included in the parentheses. Available protocols include: ¡ DLDP—Shuts down the data link layer when it detects that the link is unidirectional. ¡ OAM—Shuts down the data link layer when it detects a remote link failure. ¡ LAGG—Shuts down the data link layer when it detects that the aggregate interface does not have Selected ports. ¡ BFD—Shuts down the data link layer when it detects a link failure. ¡ MACSEC—Shuts down the data link layer when it fails to negotiate the encryption parameters. |
Bandwidth |
Expected bandwidth of the interface. |
Maximum transmission unit |
MTU of the interface. |
Internet protocol processing: Disabled |
The interface is not assigned an IP address and cannot process IP packets. |
Internet address |
IP address of the interface. The primary attribute indicates that the address is the primary IP address. |
Internet address: ip-address/mask-length (Type) |
IP address of the interface and type of the address in parentheses. Possible IP address types include: · Primary—Manually configured primary IP address. · Sub—Manually configured secondary IP address. If the interface has both primary and secondary IP addresses, the primary IP address is displayed. If the interface has only secondary IP addresses, the lowest secondary IP address is displayed. · DHCP-allocated—DHCP allocated IP address. For more information, see DHCP client configuration in Layer 3—IP Services Configuration Guide. · Unnumbered—IP address borrowed from another interface. |
IP packet frame type |
IPv4 packet framing format. |
hardware address |
MAC address of the interface. |
IPv6 packet frame type |
IPv6 packet framing format. |
Port priority |
Port priority of the interface. |
Loopback is set internal |
An internal loopback test is running on the interface. This field depends on your configuration. |
Loopback is set external |
An external loopback test is running on the interface. This field depends on your configuration. |
Loopback is not set |
No loopback test is running on the interface. This field depends on your configuration. |
10Mbps-speed mode |
The interface is operating at 10 Mbps. This field depends on your configuration and the link parameter negotiation result. |
100Mbps-speed mode |
The interface is operating at 100 Mbps. This field depends on your configuration and the link parameter negotiation result. |
1000Mbps-speed mode |
The interface is operating at 1000 Mbps. This field depends on your configuration and the link parameter negotiation result. |
10Gbps-speed mode |
The interface is operating at 10 Gbps. This field depends on your configuration and the link parameter negotiation result. |
25Gbps-speed mode |
The interface is operating at 25 Gbps. This field depends on your configuration and the link parameter negotiation result. |
40Gbps-speed mode |
The interface is operating at 40 Gbps. This field depends on your configuration and the link parameter negotiation result. |
100Gbps-speed mode |
The interface is operating at 100 Gbps. This field depends on your configuration and the link parameter negotiation result. |
Unknown-speed mode |
The speed of the interface is unknown because the speed negotiation fails or the interface is physically disconnected. |
half-duplex mode |
The interface is operating in half duplex mode. This field depends on your configuration and the link parameter negotiation result. |
full-duplex mode |
The interface is operating in full duplex mode. This field depends on your configuration and the link parameter negotiation result. |
unknown-duplex mode |
The duplex mode of the interface is unknown because the duplex mode negotiation fails or the interface is physically disconnected. |
Link speed type is autonegotiation |
The interface is configured with the speed auto command. |
Link speed type is force link |
The interface is manually configured with a speed (for example, 1000 Mbps) by using the speed command. |
link duplex type is autonegotiation |
The interface is configured with the duplex auto command. |
link duplex type is force link |
The interface is manually configured with a duplex mode (for example, half or full) by using the duplex command. |
Flow-control is not enabled |
Generic flow control is disabled on the interface. This field depends on your configuration and the link parameter negotiation result. |
Maximum frame length |
Maximum length of Ethernet frames allowed to pass through the interface. |
Allow jumbo frame to pass |
The interface allows jumbo frames to pass through. |
Broadcast max- |
Broadcast storm suppression threshold. |
Multicast max- |
Multicast storm suppression threshold. |
Unicast max- |
Unknown unicast storm suppression threshold. |
PVID |
Port VLAN ID (PVID) of the interface. |
MDI type |
MDIX mode of the interface: · automdix. · mdi. · mdix. |
Dampening enabled |
Damping is enabled on the interface. |
Penalty |
Penalty value. |
Ceiling |
The penalty stops increasing when it reaches the ceiling. |
Reuse |
Reuse threshold. |
Suppress |
Suppression threshold. |
Half-life |
Amount of time after which a penalty is decreased, in seconds. |
Max-suppress-time |
Maximum amount of time the interface can be dampened, in seconds. |
Flap count |
Number of flaps (up/down events) on the interface. |
Port link-type |
Link type of the interface: · access. · trunk. · hybrid. |
Tagged VLANs |
VLANs for which the interface sends packets without removing VLAN tags. |
Untagged VLANs |
VLANs for which the interface sends packets after removing VLAN tags. |
VLAN Passing |
VLANs whose packets can be forwarded by the port. The VLANs must have been created. |
VLAN permitted |
VLANs whose packets are permitted by the port. |
Trunk port encapsulation |
Encapsulation protocol type for the trunk port. |
Last link flapping |
The amount of time that has elapsed since the most recent physical state change of the interface. This field displays Never if the interface has been physically down since device startup. |
Last clearing of counters |
Time when the reset counters interface command was last used to clear the interface statistics. This field displays Never if the reset counters interface command has never been used on the interface since device startup. |
Current system time |
Current system time in the YYYY/MM/DD HH:MM:SS format. If the time zone is configured, this field is in the YYYY/MM/DD HH:MM:SS zone-name±HH:MM:SS format, where the zone-name argument is the local time zone. |
Last time when physical state changed to up |
Last time when the physical state of the interface changed to up. If the time zone is configured, this field is in the YYYY/MM/DD HH:MM:SS zone-name±HH:MM:SS format, where the zone-name argument is the local time zone. A hyphen (-) indicates that the physical state of the interface has never changed. |
Last time when physical state changed to down |
Last time when the physical state of the interface changed to down. If the time zone is configured, this field is in the YYYY/MM/DD HH:MM:SS zone-name±HH:MM:SS format, where the zone-name argument is the local time zone. A hyphen (-) indicates that the physical state of the interface has never changed. |
Last interval seconds input: 0 packets/sec 0 bytes/sec 0% Last interval seconds output: 0 packets/sec 0 bytes/sec 0% |
Average inbound or outbound traffic rate (in pps and Bps) in the last statistics polling interval, and the ratio of the actual rate to the interface bandwidth. To set the statistics polling interval (interval), use the flow-interval command. A hyphen (-) indicates that the statistical item is not supported. |
Input(total): 0 packets, 0 bytes 0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses |
The two fields on the first line represent the inbound traffic statistics (in packets and bytes) for the interface. All inbound normal packets, abnormal packets, and normal pause frames were counted. The four fields on the second line represent: · Number of inbound unicast packets. · Number of inbound broadcasts. · Number of inbound multicasts. · Number of inbound pause frames. A hyphen (-) indicates that the statistical item is not supported. |
Input(normal): 0 packets, 0 bytes 0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses |
The two fields on the first line represent the inbound normal traffic and pause frame statistics (in packets and bytes) for the interface. The four fields on the second line represent: · Number of inbound normal unicast packets. · Number of inbound normal broadcasts. · Number of inbound normal multicasts. · Number of inbound normal pause frames. A hyphen (-) indicates that the statistical item is not supported. |
input errors |
Statistics of incoming error packets. |
runts |
Number of inbound frames meeting the following conditions: · Shorter than 64 bytes. · In correct format. · Containing valid CRCs. |
giants |
Number of inbound giants. Giants refer to frames larger than the maximum frame length supported on the interface. For an Ethernet interface that does not permit jumbo frames, the maximum frame length is as follows: · 1532 bytes (without VLAN tags). · 1536 bytes (with VLAN tags). For an Ethernet interface that permits jumbo frames, the maximum Ethernet frame length is set when you configure jumbo frame support on the interface. |
throttles |
Number of inbound frames that had a non-integer number of bytes. |
CRC |
Total number of inbound frames that had a normal length, but contained CRC errors. |
frame |
Total number of inbound frames that contained CRC errors and a non-integer number of bytes. |
overruns |
Number of packets dropped because the input rate of the port exceeded the queuing capability. |
aborts |
Total number of illegal inbound packets: · Fragment frames—CRC error frames shorter than 64 bytes. The length (in bytes) can be an integral or non-integral value. · Jabber frames—CRC error frames greater than the maximum frame length supported on the Ethernet interface (with an integral or non-integral length). ¡ For an Ethernet interface that does not permit jumbo frames, the maximum frame length is 1532 bytes (without VLAN tags) or 1536 bytes (with VLAN tags). ¡ For an Ethernet interface that permits jumbo frames, the maximum Ethernet frame length is set when you configure jumbo frame support on the interface. · Symbol error frames—Frames that contained a minimum of one undefined symbol. · Unknown operation code frames—Non-pause MAC control frames. · Length error frames—Frames whose 802.3 length fields did not match the actual frame length (46 to 1500 bytes). |
ignored |
Number of inbound frames dropped because the receiving buffer of the port ran low. |
parity errors |
Total number of frames with parity errors. |
Output(total): 0 packets, 0 bytes 0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses |
The two fields on the first line represent the outbound traffic statistics (in packets and bytes) for the interface. All outbound normal packets, abnormal packets, and normal pause frames were counted. The four fields on the second line represent: · Number of outbound unicast packets. · Number of outbound broadcasts. · Number of outbound multicasts. · Number of outbound pause frames. A hyphen (-) indicates that the statistical item is not supported. |
Output(normal): 0 packets, 0 bytes 0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses |
The two fields on the first line represent the outbound normal traffic and pause frame statistics (in packets and bytes) for the interface. The four fields on the second line represent: · Number of outbound normal unicast packets. · Number of outbound normal broadcasts. · Number of outbound normal multicasts. · Number of outbound normal pause frames. A hyphen (-) indicates that the statistical item is not supported. |
output errors |
Number of outbound packets with errors. |
underruns |
Number of packets dropped because the output rate of the interface exceeded the output queuing capability. This is a low-probability hardware anomaly. |
buffer failures |
Number of packets dropped because the transmitting buffer of the interface ran low. |
aborts |
Number of packets that failed to be transmitted, for example, because of Ethernet collisions. |
deferred |
Number of frames that the interface deferred to transmit because of detected collisions. |
collisions |
Number of frames that the interface stopped transmitting because Ethernet collisions were detected during transmission. |
late collisions |
Number of frames that the interface deferred to transmit after transmitting their first 512 bits because of detected collisions. |
lost carrier |
Number of carrier losses during transmission. This counter increases by one when a carrier is lost, and applies to serial WAN interfaces. |
no carrier |
Number of times that the port failed to detect the carrier when attempting to send frames. This counter increases by one when a port failed to detect the carrier, and applies to serial WAN interfaces. |
Peak input rate |
Peak rate of inbound traffic in Bps, and the time when the peak inbound traffic rate occurred. |
Peak output rate |
Peak rate of outbound traffic in Bps, and the time when the peak outbound traffic rate occurred. |
IPv4 traffic statistics |
IPv4 packet statistics. |
IPv6 traffic statistics |
IPv6 packet statistics. |
Last 300 seconds input rate: 0 packets/sec, 0 bytes/sec |
Average inbound traffic rate (in pps and Bps) in the last 300 seconds. A hyphen (-) indicates that the statistical item is not supported. |
Last 300 seconds output rate: 0 packets/sec, 0 bytes/sec |
Average outbound traffic rate (in pps and Bps) in the last 300 seconds. A hyphen (-) indicates that the statistical item is not supported. |
Input: 0 packets, 0 bytes |
Inbound traffic statistics (in packets and bytes) for the interface. A hyphen (-) indicates that the statistical item is not supported. |
Output: 0 packets, 0 bytes |
Outbound traffic statistics (in packets and bytes) for the interface. A hyphen (-) indicates that the statistical item is not supported. |
# Display brief information about all interfaces.
Protocol: (s) – spoofing
WGE1/0/1 DOWN DOWN --
Loop0 UP UP(s) 2.2.2.9
NULL0 UP UP(s) --
Vlan1 UP UP --
Vlan999 UP UP 192.168.1.42
Speed: (a) - auto
Interface Link Speed Duplex Type PVID Description
WGE1/0/2 DOWN auto A A 1
WGE1/0/3 UP 1G(a) F(a) A 1 aaaaaaaaaaaaaaaaaaaaaaaaa
# Display brief information about Twenty-FiveGigE 1/0/3, including the complete description of the interface.
<Sysname> display interface twenty-fivegige 1/0/3 brief description
Speed: (a) - auto
WGE1/0/3 UP 1G(a) F(a) A 1 aaaaaaaaaaaaaaaaaaaaaaaaaaa
aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
# Display information about interfaces in DOWN state and the causes.
Interface Link Cause
WGE1/0/1 DOWN Not connected
Vlan2 DOWN Not connected
WGE1/0/2 DOWN Not connected
Brief information on interfaces in route mode: |
Brief information about Layer 3 interfaces. |
Interface name. |
Link |
Physical link state of the interface: · UP—The interface is physically up. · DOWN—The interface is physically down. · ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command. · Stby—The interface is a backup interface in standby state. |
Protocol |
Data link layer protocol state of the interface: · UP—The data link layer protocol of the interface is up. · DOWN—The data link layer protocol of the interface is down. · UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. This value is typical of null interfaces and loopback interfaces. |
Primary IP |
Primary IP address of the interface. This field displays two hyphens (--) if the interface does not have an IP address. |
Description of the interface. |
Brief information of interfaces in bridge mode: |
Brief information about Layer 2 interfaces. |
Type: A - access; T - trunk; H – hybrid |
Link type options for interfaces. |
Speed |
Speed of the interface, in bps. This field displays the (a) flag next to the speed if the speed is automatically negotiated. This field displays auto if the interface is configured to autonegotiate its speed but the autonegotiation has not started. |
Duplex |
Duplex mode of the interface: · A—Autonegotiation. The interface is configured to autonegotiate its duplex mode but the autonegotiation has not started. · F—Full duplex. · F(a)—Autonegotiated full duplex. · H—Half duplex. · H(a)—Autonegotiated half duplex. |
Type |
Link type of the interface: · A—Access. · H—Hybrid. · T—Trunk. |
PVID |
Port VLAN ID. |
Cause |
Cause for the physical link state of an interface to be DOWN: · Administratively—The interface has been manually shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command. · DOWN ( Link-Aggregation interface down )—The interface is a member port of an aggregate interface, and the aggregate interface is down. · DOWN (Loopback detection down)—The loopback detection module has detected loops. · DOWN ( Monitor-Link uplink down )—The monitor link module has detected that the uplink is down. · MAD ShutDown—The interface is on an IRF fabric placed by IRF MAD in Recovery state after an IRF split. · Not connected—No physical connection exists (possibly because the network cable is disconnected or faulty). · Storm-Constrain—The storm control feature has detected that unknown unicast traffic, multicast traffic, or broadcast traffic exceeded the upper threshold. · STP DOWN—The interface has been shut down by the BPDU guard feature. · OFP DOWN—The interface has been shut down by OpenFlow. |
flow-interval
display interface link-info
Use display interface link-info to display the status and packet statistics of interfaces.
display interface link-info [ main ]
main: Specifies all interfaces except subinterfaces. If you do not specify this keyword, this command displays status and packet statistics of all interfaces.
# Display status and statistics of all interfaces.
<Sysname> display interface link-info
Protocol: (s) - spoofing
Interface Link Protocol InUsage OutUsage InErrs OutErrs
WGE1/0/1 UP UP 10% 0% 0 0
NULL0 UP UP(s) 0% 0% 0 0
Overflow: More than 7 digits.
--: Not supported.
Table 6 Command output
Link: ADM - administratively down; Stby - standby |
Physical link state of the interface: · ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command. · Stby—The interface is a backup interface in standby state. |
Protocol: (s) – spoofing |
The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. This value is typical of null interfaces, loopback interfaces, and InLoopback interfaces. |
Link |
Protocol |
Data link layer protocol state of the interface: · UP—The data link layer protocol of the interface is up. · DOWN—The data link layer protocol of the interface is down. · UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. This value is typical of null interfaces, loopback interfaces, and InLoopback interfaces. |
InUsage |
Inbound bandwidth usage within the most recent statistics polling interval. It is calculated by this formula: Average inbound speed of the interface within the most recent statistics polling interval/interface bandwidth. To set the statistics polling interval, use the flow-interval command. |
OutUsage |
Outbound bandwidth usage within the most recent statistics polling interval. It is calculated by this formula: Average outbound speed of the interface within the most recent statistics polling interval/interface bandwidth. To set the statistics polling interval, use the flow-interval command. |
InErrs |
Number of error packets received. |
OutErrs |
Number of error packets sent. |
Overflow: More than 7 digits. |
The data length of a statistical item value is greater than 7 decimal digits. |
--: Not supported. |
A hyphen (-) indicates that the corresponding statistical item is not supported. |
flow-interval
display interface main
Use display interface main to display operating status and information of all interfaces except subinterfaces.
display interface [ interface-type ] [ brief [ description | down ] ] main
interface-type: Specifies an interface type. If you do not specify this argument, the command displays information about interfaces of all types.
# Display operating status and information of all interfaces except subinterfaces.
<Sysname> display interface main
IP packet frame type: Ethernet II, hardware address: e0fd-0079-5052
Loopback is not set
PVID: 1
MDI type: Automdix
Tagged VLANs: None
Untagged VLANs: 1
Port priority: 0
Current system time:2001-01-01 06:47:06
Last time when physical state changed to down:2001-01-01 00:07:15
Peak input rate: 0 bytes/sec, at 2001-01-01 06:41:17
Peak output rate: 0 bytes/sec, at 2001-01-01 06:41:17
# Display brief information of all interfaces except subinterfaces.
<Sysname> display interface brief main
NULL0 UP UP(s) --
Vlan1 UP DOWN --
Speed: (a) - auto
# Display brief information about all interfaces except subinterfaces, including the complete interface descriptions.
<Sysname> display interface brief description main
Speed: (a) - auto
WGE1/0/3 UP auto F(a) A 1 aaaaaaaaaaaaaaaaaaaaaaaaaaaaa
# Display information about interfaces except subinterfaces in DOWN state and the causes.
<Sysname> display interface brief down main
For description on the display interface main command output, see Table 4 and Table 5.
display link-flap protection
Use display link-flap protection to display information about link flapping protection on an interface.
display link-flap protection [ interface interface-type [ interface-number ] ]
interface-type: Specifies an interface type. If you do not specify an interface type, the command displays information about link flapping protection on all interfaces.
interface-number: Specifies an interface number. If you do not specify an interface number, the command displays information about link flapping protection on all interfaces of the specified type.
# Display information about link flapping protection on all interfaces.
<Sysname> display link-flap protection
Link-flap protection: Enabled
Interface Link-flap Status Interval(L1/L2) Threshold(L1/L2)
WGE1/0/1 Enabled Down 10/5 5/60
WGE1/0/2 Disabled N/A --/-- --/--
Link-flap protection |
Status of global link flapping protection: · Enabled—Link flapping protection is enabled globally. · Disabled—Link flapping protection is disabled globally. |
Link-flap |
Status of link flapping protection on an interface: · Enabled—Link flapping protection is enabled on an interface. · Disabled—Link flapping protection is disabled on an interface. |
Status |
Status of an interface: · Down—The interface has been shut down by the link flapping protection feature. · N/A—The interface status is not affected by the link flapping protection feature. |
Interval(L1/L2) |
Level-1/Level-2 link flapping detection interval for an interface. |
Threshold(L1/L2) |
Level-1/Level-2 link flapping detection threshold for an interface. |
Use display link-state-change statistics interface to display the physical link state change statistics of interfaces.
display link-state-change statistics interface [ interface-type [ interface-number ] ]
If you do not specify an interface type, this command displays the link state change statistics for all interfaces.
If you specify an interface type but do not specify an interface number, this command displays the link state change statistics for all interfaces of the specified type.
# Display the link state change statistics of all interfaces.
<Sysname> display link-state-change statistics interface
Interface Change-times Last-change-time Reset link-state time
Link-flap-begin Link-flap-end
WGE1/0/1 0 Never Never
Never Never
Table 8 Command output
Change-times |
Number of physical state changes. |
Last-change-time |
Last time when the physical state changed. |
Reset link-state time |
Time when the physical link state change statistics were cleared. |
Link-flap-begin |
Last time when a physical link state flapping began. If no link state flapping has occurred, this field displays Never. |
Link-flap-end |
Last time when a physical link state flapping ended. If no link state flapping has occurred, this field displays Never. |
display packet-drop
Use display packet-drop to display information about packets dropped on an interface.
display packet-drop { interface [ interface-type [ interface-number ] ] | summary }
summary: Displays the summary of dropped packets on only interfaces that support this command.
If you do not specify an interface type, this command displays information about dropped packets on only interfaces that support this command on the device.
If you specify an interface type but do not specify an interface number, this command displays information about dropped packets on only interfaces of the specified type that support this command.
# Display information about dropped packets on Twenty-FiveGigE 1/0/1.
<Sysname> display packet-drop interface twenty-fivegige 1/0/1
Twenty-FiveGigE1/0/1:
Packets dropped due to Egress Filter Processor (EFP): 0
Packets dropped due to Fast Filter Processor (FFP): 261
Packets dropped due to STP non-forwarding state: 0
Packets dropped due to insufficient data buffer. Input dropped: 0 Output dropped:0
Packets of ECN marked: 0
Packets of WRED dropped: 0
# Display the summary of dropped packets on only interfaces that support this command.
<Sysname> display packet-drop summary
All interfaces:
Table 9 Command output
Packets dropped due to Fast Filter Processor (FFP) |
Packets that are filtered out. |
Packets dropped due to Egress Filter Processor (EFP) |
Packets that are dropped due to EFP in the outbound direction. |
Packets dropped due to STP non-forwarding state |
Packets that are dropped because STP is in the non-forwarding state. |
Packets dropped due to insufficient data buffer. Input dropped: 0 Output dropped:0 |
Inbound and outbound packets that are dropped due to insufficient data buffer. This field is not supported on the two 1-Gbps SFP interfaces on the rear panel of an S9850-4C, S9850-32H, or S6850-56HF switch. |
Packets of ECN marked |
Packets with the ECN field set to 11 because WRED queue thresholds are reached. For more information about WRED and ECN, see ACL and QoS Configuration Guide. This field is not supported on the two 1-Gbps SFP interfaces on the rear panel of an S9850-4C, S9850-32H, or S6850-56HF switch. |
Packets of WRED dropped |
Packets that are dropped because the WRED queue thresholds are reached. This field is not supported on the two 1-Gbps SFP interfaces on the rear panel of an S9850-4C, S9850-32H, or S6850-56HF switch. |
duplex
Use duplex to set the duplex mode for an Ethernet interface.
Use undo duplex to restore the default.
duplex { auto | full | half }
undo duplex
Ethernet interfaces operate in autonegotiation mode.
auto: Configures the interface to autonegotiate the duplex mode with the peer.
full: Configures the interface to operate in full duplex mode. In this mode, the interface can receive and transmit packets simultaneously.
half: Configures the interface to operate in half duplex mode. In this mode, the interface can only receive or transmit packets at a given time. Copper ports operating at 1000 Mbps or 10000 Mbps and fiber ports do not support this keyword.
# Configure Twenty-FiveGigE 1/0/1 to operate in full duplex mode.
[Sysname-Twenty-FiveGigE1/0/1] duplex full
eee enable
IMPORTANT: Fiber ports do not support this command. |
Use eee enable to enable Energy Efficient Ethernet (EEE) on an interface.
Use undo eee enable to disable EEE on an interface.
eee enable
undo eee enable
EEE is disabled.
With EEE enabled, a link-up interface enters low power state if it has not received any packet for a period of time. The time period depends on the chip specifications and is not configurable. When a packet arrives later, the interface restores to the normal state.
EEE and MACsec are mutually exclusive on an interface. For more information about MACsec, see Security Configuration Guide.
# Enable EEE on Twenty-FiveGigE 1/0/1.
[Sysname-Twenty-FiveGigE1/0/1] eee enable
flow-control
Use flow-control to enable TxRx-mode generic flow control on an Ethernet interface.
Use undo flow-control to disable TxRx-mode generic flow control on the Ethernet interface.
flow-control
undo flow-control
TxRx-mode generic flow control is disabled on an Ethernet interface.
With TxRx-mode generic flow control configured, an interface can both send and receive flow control frames:
· When congested, the interface sends a flow control frame to its peer.
· Upon receiving a flow control frame from the peer, the interface suspends sending packets.
To implement flow control, configure flow control on each interface that the traffic passes through.
This command and the priority-flow-control no-drop dot1p command are mutually exclusive.
# Enable TxRx-mode generic flow control on Twenty-FiveGigE 1/0/1.
[Sysname-Twenty-FiveGigE1/0/1] flow-control
flow-control receive enable
Use flow-control receive enable to enable Rx-mode generic flow control on an Ethernet port.
Use undo flow-control to disable Rx-mode generic flow control on an Ethernet port.
undo flow-control
Rx-mode generic flow control is disabled on Ethernet interfaces.
With Rx-mode flow control enabled, an interface can receive but cannot send flow control frames.
· When the interface receives a flow control frame from its peer, it suspends sending packets to the peer.
· When traffic congestion occurs on the interface, it cannot send flow control frames to the peer.
To handle unidirectional traffic congestion on a link, configure the flow-control receive enable command at one end, and the flow-control command at the other. To enable both ends of the link to handle traffic congestion, configure the flow-control command at both ends.
This command, the priority-flow-control command, and the priority-flow-control no-drop dot1p command are mutually exclusive.
# Enable Rx-mode generic flow control on Twenty-FiveGigE 1/0/1.
[Sysname-twenty-fivegige 1/0/1] flow-control receive enable
flow-control
flow-interval
Use flow-interval to set the statistics polling interval.
Use undo flow-interval to restore the default.
flow-interval interval
undo flow-interval
The statistics polling interval is 300 seconds.
interval: Sets the statistics polling interval in seconds. The interval is in the range of 5 to 300 and must be a multiple of 5.
# Set the statistics polling interval to 100 seconds on Twenty-FiveGigE 1/0/1.
[Sysname-Twenty-FiveGigE1/0/1] flow-interval 100
ifmonitor crc-error
Use ifmonitor crc-error to configure global CRC error packet alarm parameters.
Use undo ifmonitor crc-error to restore the default.
ifmonitor crc-error slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
undo ifmonitor crc-error slot slot-number
The upper threshold is 1000, the lower threshold is 100, and the statistics collection and comparison interval is 10 seconds for CRC error packet alarms.
high-threshold high-value: Specifies the upper threshold for CRC error packet alarms, in the range of 1 to 4294967295 packets.
low-threshold low-value: Specifies the lower threshold for CRC error packet alarms, in the range of 1 to 4294967295 packets.
interval interval: Specifies the statistics collection and comparison interval for CRC error packets, in the range of 1 to 65535 seconds.
shutdown: Shuts down an interface when the number of incoming CRC error packets on the interface exceeds the upper threshold. Then, the interface stops forwarding all packets. To recover the interface, execute the undo shutdown command on the interface. If you do not specify this keyword, an upper threshold exceeding alarm is generated and the interface enters the alarm state when the number of incoming CRC error packets exceeds the upper threshold on the interface, but the interface will not be shut down. If you specify this keyword when the upper threshold has been exceeded on an interface, the interface will be shut down.
With the CRC error packet alarm function enabled, when the number of incoming CRC error packets on an interface in normal state within the specified interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters the alarm state. When the number of incoming CRC error packets on an interface in the alarm state within the specified interval drops below the lower threshold, the interface generates a recovery alarm and restores to the normal state.
You can configure the CRC error packet alarm parameters in system view and interface view.
· The configuration in system view takes effect on all interfaces of the specified slot. The configuration in interface view takes effect only on the current interface.
· For an interface, the configuration in interface view takes priority, and the configuration in system view is used only when no configuration is made in interface view.
When you execute this command multiple times, the most recent configuration takes effect.
# Set the upper threshold to 5000, lower threshold to 400, and statistics collection and comparison interval to 6 seconds for CRC error packet alarms.
[Sysname] ifmonitor crc-error slot 1 high-threshold 5000 low-threshold 400 interval 6
ifmonitor input-error
Use ifmonitor input-error to configure global input error packet alarm parameters.
Use undo ifmonitor input-error to restore the default.
ifmonitor input-error slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
undo ifmonitor input-error slot slot-number
The upper threshold is 1000, the lower threshold is 100, and the statistics collection and comparison interval is 10 seconds for input error packet alarms.
high-threshold high-value: Specifies the upper threshold for input error packet alarms, in the range of 1 to 4294967295 packets.
low-threshold low-value: Specifies the lower threshold for input error packet alarms, in the range of 1 to 4294967295 packets.
interval interval: Specifies the statistics collection and comparison interval for input error packets, in the range of 1 to 65535 seconds.
shutdown: Shuts down an interface when the number of input error packets on the interface exceeds the upper threshold. Then, the interface stops forwarding all packets. To recover the interface, execute the undo shutdown command on the interface. If you do not specify this keyword, an upper threshold exceeding alarm is generated and the interface enters the alarm state when the number of input error packets exceeds the upper threshold on the interface, but the interface will not be shut down. If you specify this keyword when the upper threshold has been exceeded on an interface, the interface will be shut down.
With the input error packet alarm function enabled, when the number of input error packets on an interface in normal state within the specified interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters the alarm state. When the number of input error packets on an interface in the alarm state within the specified interval drops below the lower threshold, the interface generates a recovery alarm and restores to the normal state.
You can configure the input error packet alarm parameters in system view and interface view.
# Set the upper threshold to 5000, lower threshold to 400, and statistics collection and comparison interval to 6 seconds for input error packet alarms.
[Sysname] ifmonitor input-error slot 1 high-threshold 5000 low-threshold 400 interval 6
ifmonitor input-usage
Use ifmonitor input-usage to configure global input bandwidth usage alarm parameters.
Use undo ifmonitor input-usage to restore the default.
ifmonitor input-usage slot slot-number high-threshold high-value low-threshold low-value
undo ifmonitor input-usage slot slot-number
The upper threshold is 90, and the lower threshold is 80.
high-threshold high-value: Specifies the upper threshold for input bandwidth usage alarms, in the range of 1 to 100.
low-threshold low-value: Specifies the lower threshold for input bandwidth usage alarms, in the range of 1 to 100.
With the input bandwidth usage alarm function enabled, when the input bandwidth usage on an interface in normal state within the most recent statistics polling interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters the alarm state. When the input bandwidth usage on an interface in the alarm state within the most recent statistics polling interval drops below the lower threshold, the interface generates a recovery alarm and restores to the normal state.
You can use the flow-interval command to set the statistics polling interval.
You can configure the input bandwidth usage alarm parameters in system view and interface view.
For this command to take effect, you must use the snmp-agent trap enable ifmonitor command to enable the input bandwidth usage alarm function.
# Set the upper threshold to 95 and lower threshold to 80 for input bandwidth usage alarms.
[Sysname] ifmonitor input-usage slot 1 high-threshold 95 low-threshold 80
flow-interval
ifmonitor output-error
Use ifmonitor output-error to configure global output error packet alarm parameters.
Use undo ifmonitor output-error to restore the default.
ifmonitor output-error slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
undo ifmonitor output-error slot slot-number
The upper threshold is 1000, the lower threshold is 100, and the statistics collection and comparison interval is 10 seconds for output error packet alarms.
high-threshold high-value: Specifies the upper threshold for output error packet alarms, in the range of 1 to 4294967295 packets.
low-threshold low-value: Specifies the lower threshold for output error packet alarms, in the range of 1 to 4294967295 packets.
interval interval: Specifies the statistics collection and comparison interval for output error packets, in the range of 1 to 65535 seconds.
shutdown: Shuts down an interface when the number of output error packets on the interface exceeds the upper threshold. Then, the interface stops forwarding all packets. To recover the interface, execute the undo shutdown command on the interface. If you do not specify this keyword, an upper threshold exceeding alarm is generated and the interface enters the alarm state when the number of output error packets exceeds the upper threshold on the interface, but the interface will not be shut down. If you specify this keyword when the upper threshold has been exceeded on an interface, the interface will be shut down.
With the output error packet alarm function enabled, when the number of output error packets on an interface in normal state within the specified interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters the alarm state. When the number of output error packets on an interface in the alarm state within the specified interval drops below the lower threshold, the interface generates a recovery alarm and restores to the normal state.
You can configure the output error packet alarm parameters in system view and interface view.
# Set the upper threshold to 5000, lower threshold to 400, and statistics collection and comparison interval to 6 seconds for output error packet alarms.
[Sysname] ifmonitor output-error slot 1 high-threshold 5000 low-threshold 400 interval 6
ifmonitor output-usage
Use ifmonitor output-usage to configure global output bandwidth usage alarm parameters.
Use undo ifmonitor output-usage to restore the default.
ifmonitor output-usage slot slot-number high-threshold high-value low-threshold low-value
undo ifmonitor output-usage slot slot-number
high-threshold high-value: Specifies the upper threshold for output bandwidth usage alarms, in the range of 1 to 100.
low-threshold low-value: Specifies the lower threshold for output bandwidth usage alarms, in the range of 1 to 100.
With the output bandwidth usage alarm function enabled, when the output bandwidth usage on an interface in normal state within the most recent statistics polling interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters the alarm state. When the output bandwidth usage on an interface in the alarm state within the most recent statistics polling interval drops below the lower threshold, the interface generates a recovery alarm and restores to the normal state.
You can configure the output bandwidth usage alarm parameters in system view and interface view.
For this command to take effect, you must use the snmp-agent trap enable ifmonitor command to enable the output bandwidth usage alarm function.
# Set the upper threshold to 80 and lower threshold to 60 for output bandwidth usage alarms.
[Sysname] ifmonitor output-usage slot 1 high-threshold 80 low-threshold 60
flow-interval
ifmonitor rx-pause
Use ifmonitor rx-pause to configure global received pause frame alarm parameters.
Use undo ifmonitor rx-pause to restore the default.
ifmonitor rx-pause slot slot-number high-threshold high-value low-threshold low-value interval interval
undo ifmonitor rx-pause slot slot-number
The upper threshold is 500, the lower threshold is 100, and the statistics collection and comparison interval is 10 seconds for received pause frame alarms.
high-threshold high-value: Specifies the upper threshold for received pause frame alarms, in the range of 1 to 4294967295 packets.
low-threshold low-value: Specifies the lower threshold for received pause frame alarms, in the range of 1 to 4294967295 packets.
interval interval: Specifies the statistics collection and comparison interval for received pause frames, in the range of 1 to 65535 seconds.
With the received pause frame alarm function enabled, when the number of received pause frames on an interface in normal state within the specified interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters the alarm state. When the number of received pause frames on an interface in the alarm state within the specified interval drops below the lower threshold, the interface generates a recovery alarm and restores to the normal state.
You can configure the received pause frame alarm parameters in system view and interface view.
For this command to take effect, you must use the snmp-agent trap enable ifmonitor command to enable the received pause frame alarm function.
# Set the upper threshold to 30, lower threshold to 20, and statistics collection and comparison interval to 4 seconds for received pause frame alarms.
[Sysname] ifmonitor rx-pause slot 1 high-threshold 30 low-threshold 20 interval 4
ifmonitor tx-pause
Use ifmonitor tx-pause to configure global sent pause frame alarm parameters.
Use undo ifmonitor tx-pause to restore the default.
ifmonitor tx-pause slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
undo ifmonitor tx-pause slot slot-number
The upper threshold is 500, the lower threshold is 100, and the statistics collection and comparison interval is 10 seconds for sent pause frame alarms.
high-threshold high-value: Specifies the upper threshold for sent pause frame alarms, in the range of 1 to 4294967295 packets.
low-threshold low-value: Specifies the lower threshold for sent pause frame alarms, in the range of 1 to 4294967295 packets.
interval interval: Specifies the statistics collection and comparison interval for sent pause frames, in the range of 1 to 65535 seconds.
shutdown: Shuts down an interface when the number of sent pause frames on the interface exceeds the upper threshold. Then, the interface stops forwarding all packets. To recover the interface, execute the undo shutdown command on the interface. If you do not specify this keyword, an upper threshold exceeding alarm is generated and the interface enters the alarm state when the number of sent pause frames exceeds the upper threshold on the interface, but the interface will not be shut down. If you specify this keyword when the upper threshold has been exceeded on an interface, the interface will be shut down.
With the sent pause frame alarm function enabled, when the number of sent pause frames on an interface in normal state within the specified interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters the alarm state. When the number of sent pause frames on an interface in the alarm state within the specified interval drops below the lower threshold, the interface generates a recovery alarm and restores to the normal state.
You can configure the sent pause frame alarm parameters in system view and interface view.
For this command to take effect, you must use the snmp-agent trap enable ifmonitor command to enable the sent pause frame alarm function.
# Set the upper threshold to 20, lower threshold to 10, and statistics collection and comparison interval to 5 seconds for sent pause frame alarms.
[Sysname] ifmonitor tx-pause slot 1 high-threshold 20 low-threshold 10 interval 5
interface
Use interface to enter interface view, create a subinterface and enter its view, or enter the view of an existing subinterface.
# Enter the view of Twenty-FiveGigE 1/0/1.
[Sysname] interface twenty-fivegige 1/0/1
# Create Ethernet subinterface Twenty-FiveGigE 1/0/1.1 and enter its view.
[Sysname] interface twenty-fivegige 1/0/1.1
[Sysname-Twenty-FiveGigE1/0/1.1]
jumboframe enable
Use jumboframe enable to allow jumbo frames within the specified length to pass through.
Use undo jumboframe enable to prevent jumbo frames from passing through.
Use undo jumboframe enable size to restore the default.
jumboframe enable [ size ]
The device allows jumbo frames within 9416 bytes to pass through.
size: Sets the maximum length (in bytes) of Ethernet frames that are allowed to pass through. The value range for this argument is 1536 to 9416.
# Allow jumbo frames to pass through Twenty-FiveGigE 1/0/1.
[Sysname-Twenty-FiveGigE1/0/1] jumboframe enable
link-delay
Use link-delay to set the physical state change suppression interval on an Ethernet interface.
Use undo link-delay to restore the default.
undo link-delay { down | up }
Each time the physical link of a port goes up or comes down, the interface immediately reports the change to the CPU.
down: Suppresses link-down events.
up: Suppresses link-up events.
msec: Enables the physical state change suppression interval to be accurate to milliseconds. If you do not specify this keyword, the suppression interval is accurate to seconds.
delay-time: Sets the physical state change suppression interval on the Ethernet interface. A value of 0 means that physical state changes are immediately reported to the CPU and are not suppressed.
· If you do not specify the msec keyword, the value range is 0 to 300 seconds.
· If you specify the msec keyword, the value range is 0 to 10000 milliseconds, and the value must be a multiple of 100.
You can configure this feature to suppress only link-down events, only link-up events, or both. If an event of the specified type still exists when the suppression interval expires, the system reports the event.
When you configure this feature, follow these guidelines:
· To suppress link-down events, execute the link-delay down command.
· To suppress link-up events, execute the link-delay up command.
On an interface, you can configure different suppression intervals for link-up and link-down events. If you execute the link-delay command multiple times on an interface, the following rules apply:
· You can configure the suppression intervals for link-up and link-down events separately.
· If you configure the suppression interval multiple times for link-up or link-down events, the most recent configuration takes effect.
Do not execute this command on an interface that has RRPP, spanning tree protocols, or Smart Link enabled.
This command, the dampening command, and the port link-flap protect enable command are mutually exclusive on an Ethernet interface.
# Set the link-down event suppression interval to 8 seconds on Twenty-FiveGigE 1/0/1.
[Sysname-Twenty-FiveGigE1/0/1] link-delay down 8
# Set the link-up event suppression interval to 800 milliseconds on Twenty-FiveGigE 1/0/1.
[Sysname-Twenty-FiveGigE1/0/1] link-delay up msec 800
dampening
Use link-flap protect enable to enable link flapping protection globally.
Use undo link-flap protect enable to disable link flapping protection globally.
Link flapping on any interface changes network topology and increases the system overhead. For example, in an active/standby link scenario, when the interface status on the active link changes between UP and DOWN, traffic switches between active and standby links. To solve this problem, execute this command.
With link flapping protection enabled on an interface, when the interface goes down, the system enables link flapping detection on the interface. During the link flapping detection interval, if the number of detected flaps reaches or exceeds the link flapping detection threshold, the system shuts down the interface.
Link flapping protection takes effect only when it is enabled in both system view and interface view.
# Enable link flapping protection globally.
[Sysname] link-flap protect enable
loopback
Use loopback to enable loopback testing on an Ethernet interface.
loopback internal
Loopback testing is disabled on an Ethernet interface.
internal: Enables internal loopback testing on the Ethernet interface.
After you enable loopback testing on an Ethernet interface, the Ethernet interface switches to full duplex mode. After you disable loopback testing, the Ethernet interface restores to its duplex setting.
An Ethernet interface in a loopback test cannot correctly forward data packets.
You cannot perform a loopback test on the following Ethernet interfaces:
· Ethernet interfaces manually brought down (displayed as in ADM or Administratively DOWN state).
· Ethernet interfaces with the port up-mode command executed.
The speed, duplex, and shutdown commands cannot be executed on an Ethernet interface in a loopback test.
# Enable internal loopback testing on Twenty-FiveGigE 1/0/1.
[Sysname-Twenty-FiveGigE1/0/1] loopback internal
multicast-suppression
Use multicast-suppression to enable multicast storm suppression and set the multicast storm suppression threshold.
Use undo multicast-suppression to disable multicast storm suppression.
multicast-suppression { ratio | pps max-pps | kbps max-kbps } [ unknown ]
Ethernet interfaces do not suppress multicast traffic.
ratio: Sets the multicast suppression threshold as a percentage of the interface bandwidth. The value range for this argument (in percentage) is 0 to 100. A smaller value means that less multicast traffic is allowed to pass through.
pps max-pps: Specifies the maximum number of multicast packets that the interface can forward per second. The value range for the max-pps argument (in pps) is 0 to 1.4881 × the interface bandwidth.
kbps max-kbps: Specifies the maximum number of kilobits of multicast traffic that the Ethernet interface can forward per second. The value range for this argument (in kbps) is 0 to the interface bandwidth.
unknown: Enables multicast storm suppression only on unknown packets. If you do not specify this keyword, this command suppresses all the multicast packets that the interface can forward.
The multicast storm suppression feature limits the size of multicast traffic to a threshold on an interface. When the multicast traffic on the interface exceeds this threshold, the system drops packets until the traffic drops below this threshold.
Both the storm-constrain command and the multicast-suppression command can suppress multicast storms on a port. The multicast-suppression command uses the chip to physically suppress multicast traffic. It has less influence on the device performance than the storm-constrain command, which uses software to suppress multicast traffic.
For the traffic suppression result to be determined, do not execute both the storm-constrain multicast command and the multicast-suppression command on an interface.
When you configure the suppression threshold in kbps, the actual suppression threshold might be different from the configured one as follows:
· If the configured value is smaller than 64, the value of 64 takes effect.
· If the configured value is greater than 64 but not an integer multiple of 64, the integer multiple of 64 that is greater than and closest to the configured value takes effect.
To determine the suppression threshold that takes effect, see the prompts on the switch.
Set the same type of thresholds for each interface, that is, set the ratio argument, the pps max-pps option, or the kbps max-kbps option for the interface.
# Set the multicast storm suppression threshold to 10000 kbps on Twenty-FiveGigE 1/0/1.
[Sysname-Twenty-FiveGigE1/0/1] multicast-suppression kbps 10000
The actual value is 10048 on port Twenty-FiveGigE1/0/1 currently.
The output shows that the value that takes effect is 10048 kbps (157 times of 64), because the chip only supports step 64.
broadcast-suppression
unicast-suppression
port fec bypass enable
Use port fec bypass enable to enable FEC bypass.
Use undo port fec bypass enable to disable FEC bypass.
FEC bypass is disabled.
This command is supported only on 25-GE, 40-GE, and 100-GE interfaces.
By default, when an interface continuously receives three or more packets that it cannot process, the device will shut down and then bring up the interface to fix the interface. However, there are many possible packet error reasons. If you are sure that the interface is not faulty, you do not need to fix the interface. To avoid service interruption in this case, you can enable this feature on the interface to prevent the device from shutting down and bringing up the interface.
# Enable FEC bypass.
[Sysname-HundredGigE1/0/1] port fec bypass enable
port fec mode
Use port fec mode to set the forward error correction (FEC) mode of an interface.
Use undo port fec mode to restore the default.
port fec mode { auto | base-r | none | rs-fec }
undo port fec mode
The FEC mode of an interface is autonegotiation.
25-GE interface view
100-GE interface view
auto: Specifies the FEC autonegotiation mode.
base-r: Specifies the BASE-R FEC mode. 100-GE interfaces do not support this keyword.
none: Performs no FEC.
rs-fec: Specifies the RS-FEC mode.
The FEC feature corrects packet errors to improve transmission quality. It attaches correction information to a packet at the sending end, and corrects error codes generated during transmission at the receiving end based on the correction information. You can set the FEC mode as needed.
Make sure you set the same FEC mode for both interfaces of a link.
This feature is supported only on 25-GE interfaces operating at 25 Gbps.
This feature is supported only on 100-GE interfaces operating at 100 Gbps.
On a 100-GE interface installed with a QSFP-100G-LR4-WDM1300 transceiver module, manual FEC configuration does not take effect. However, the interface will go down and then come up upon the configuration.
# Set the FEC mode of Twenty-FiveGigE 1/0/1 to autonegotiation.
[Sysname-Twenty-FiveGigE1/0/1] port fec mode auto
# Set the FEC mode of HundredGigE 1/0/1 to autonegotiation.
[Sysname-HundredGigE1/0/1] port fec mode auto
port ifmonitor crc-error
Use port ifmonitor crc-error to configure CRC error packet alarm parameters for an interface.
Use undo port ifmonitor crc-error to restore the default.
An interface uses the global CRC error packet alarm parameters.
ratio: Specifies the alarm thresholds in percentage. If you do not specify this keyword, you configure the alarm thresholds in absolute value.
high-threshold high-value: Specifies the upper threshold for CRC error packet alarms. If you specify the ratio keyword, the value range is 1 to 100. If you do not specify the ratio keyword, the value range is 1 to 4294967295 packets.
low-threshold low-value: Specifies the lower threshold for CRC error packet alarms. If you specify the ratio keyword, the value range is 1 to 100. If you do not specify the ratio keyword, the value range is 1 to 4294967295 packets.
# Set the upper threshold to 5000, lower threshold to 400, and statistics collection and comparison interval to 6 seconds for CRC error packet alarms on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] port ifmonitor crc-error high-threshold 5000 low-threshold 400 interval 6
port ifmonitor input-error
Use port ifmonitor input-error to configure input error packet alarm parameters for an interface.
Use undo port ifmonitor input-error to restore the default.
An interface uses the global input error packet alarm parameters.
# Set the upper threshold to 5000, lower threshold to 400, and statistics collection and comparison interval to 6 seconds for input error packet alarms on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] port ifmonitor input-error high-threshold 5000 low-threshold 400 interval 6
port ifmonitor input-usage
Use port ifmonitor input-usage to configure input bandwidth usage alarm parameters.
Use undo port ifmonitor input-usage to restore the default.
An interface uses the global input bandwidth usage alarm parameters.
Interface view
# Set the upper threshold to 80 and lower threshold to 60 for input bandwidth usage alarms on Twenty-FiveGigE 1/0/1.
[Sysname-Twenty-FiveGigE1/0/1] port ifmonitor input-usage high-threshold 80 low-threshold 60
flow-interval
port ifmonitor output-error
Use port ifmonitor output-error to configure output error packet alarm parameters for an interface.
Use undo port ifmonitor output-error to restore the default.
An interface uses the global output error packet alarm parameters.
# Set the upper threshold to 5000, lower threshold to 400, and statistics collection and comparison interval to 6 seconds for output error packet alarms on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] port ifmonitor output-error high-threshold 5000 low-threshold 400 interval 6
port ifmonitor output-usage
Use port ifmonitor output-usage to configure output bandwidth usage alarm parameters.
Use undo port ifmonitor output-usage to restore the default.
An interface uses the global output bandwidth usage alarm parameters.
Interface view
# Set the upper threshold to 9 and lower threshold to 7 for output bandwidth usage alarms on Twenty-FiveGigE 1/0/1.
[Sysname-Twenty-FiveGigE1/0/1] port ifmonitor output-usage high-threshold 9 low-threshold 7
flow-interval
port ifmonitor rx-pause
Use port ifmonitor rx-pause to configure received pause frame alarm parameters for an interface.
Use undo port ifmonitor rx-pause to restore the default.
port ifmonitor rx-pause high-threshold high-value low-threshold low-value interval interval
An interface uses the global received pause frame alarm parameters.
high-threshold high-value: Specifies the upper threshold for received pause frame alarms, in the range of 1 to 4294967295.
low-threshold low-value: Specifies the lower threshold for received pause frame alarms, in the range of 1 to 4294967295.
interval interval: Specifies the statistics collection and comparison interval for received pause frame packets, in the range of 1 to 65535 seconds.
With the received pause frame alarm function enabled, when the number of received pause frame packets on an interface in normal state within the specified interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters the alarm state. When the number of received pause frame packets on an interface in the alarm state within the specified interval drops below the lower threshold, the interface generates a recovery alarm and restores to the normal state.
# Set the upper threshold to 90, lower threshold to 50, and statistics collection and comparison interval to 5 seconds for received pause frame alarms on Twenty-FiveGigE 1/0/1.
[Sysname-Twenty-FiveGigE1/0/1] port ifmonitor rx-pause high-threshold 90 low-threshold 50 interval 5
port ifmonitor tx-pause
Use port ifmonitor tx-pause to configure sent pause frame alarm parameters for an interface.
Use undo port ifmonitor tx-pause to restore the default.
port ifmonitor tx-pause high-threshold high-value low-threshold low-value interval interval [ shutdown ]
An interface uses the global sent pause frame alarm parameters.
high-threshold high-value: Specifies the upper threshold for sent pause frame alarms, in the range of 1 to 4294967295.
low-threshold low-value: Specifies the lower threshold for sent pause frame alarms, in the range of 1 to 4294967295.
interval interval: Specifies the statistics collection and comparison interval for sent pause frame packets, in the range of 1 to 65535 seconds.
With the sent pause frame alarm function enabled, when the number of sent pause frame packets on an interface in normal state within the specified interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters the alarm state. When the number of sent pause frame packets on an interface in the alarm state within the specified interval drops below the lower threshold, the interface generates a recovery alarm and restores to the normal state.
# Set the upper threshold to 50, lower threshold to 40, and statistics collection and comparison interval to 8 seconds for sent pause frame alarms on Twenty-FiveGigE 1/0/1.
[Sysname-Twenty-FiveGigE1/0/1] port ifmonitor tx-pause high-threshold 50 low-threshold 40 interval 8
Use port link-flap protect enable to enable link flapping protection on an interface.
Use undo port link-flap protect enable to disable link flapping protection on an interface.
port link-flap protect enable [ interval interval | threshold threshold ] * [ second-interval second-interval second-threshold second-threshold ]
undo port link-flap protect enable [ interval | threshold ]
interval interval: Specifies the level-1 link flapping detection interval in seconds. The value range for this argument is 5 to 86400. The default value for this argument is 10.
threshold threshold: Specifies the level-1 link flapping detection threshold in the range of 2 to 1200. The default value for this argument is 5.
second-interval interval: Specifies the level-2 link flapping detection interval in seconds. The value range for this argument is 5 to 86400.
second-threshold threshold: Specifies the level-2 link flapping detection threshold in the range of 2 to 1200.
If you do not specify the interval interval or threshold threshold option, the command uses the default level-1 link flapping protection settings. If you do not specify the second-interval interval or second-threshold threshold option, the command uses only the level-1 link flapping protection settings.
If you specify the interval or threshold keyword when you execute the undo port link-flap protect enable command, the command restores the default setting for the keyword.
With link flapping protection enabled on an interface, when the interface goes down, the system enables link flapping detection on the interface. During a link flapping detection interval, if the number of detected flaps reaches or exceeds the corresponding link flapping detection threshold, the system shuts down the interface. If you specify both level-1 and level-2 link flapping protection settings, link flapping protection will be triggered and the interface will be shut down when either of level-1 and level-2 link flapping protection conditions are met.
To bring up an interface that has been shut down by link flapping protection, execute the undo shutdown command.
This command, the dampening command, and the link-delay command are mutually exclusive on an Ethernet interface.
# Enable link flapping protection on an interface. Set the link flapping detection interval to 10 seconds, and set the link flapping detection threshold to 5.
[Sysname-Twenty-FiveGigE 1/0/1] port link-flap protect enable interval 10 threshold 5
dampening
link-delay
port link-mode
Use port link-mode to change the link mode of an Ethernet interface.
Use undo port link-mode to restore the default.
undo port link-mode
Interfaces operate in bridge mode.
bridge: Specifies the Layer 2 mode.
route: Specifies the Layer 3 mode.
CAUTION: Changing the link mode of an Ethernet interface also restores all commands (except description, duplex, jumboframe enable, speed, shutdown) on the Ethernet interface to their defaults in the new link mode. |
Interfaces on the device can operate either as Layer 2 or Layer 3 Ethernet interfaces.
You can use commands to set the link mode to bridge or route.
# Configure Twenty-FiveGigE 1/0/1 to operate in Layer 2 mode.
[Sysname-Twenty-FiveGigE1/0/1] port link-mode bridge
The configuration of the interface will be restored to the default. Continue? [Y/N]:y
port media-type
IMPORTANT: The S6805 switch series does not support this command. |
Use port media-type to configure the media type for an Ethernet interface.
Use undo port media-type to restore the default.
port media-type { copper | fiber }
The media type is fiber.
copper: Specifies the media type as copper.
fiber: Specifies the media type as fiber.
For an interface to operate properly, configure the correct media type for the interface.
This command is supported on the 25-GE interfaces of the LSWM124TG2H interface module. The media type must be the same for interfaces in the same group. When you set the media type for an interface in a group, the setting is automatically synchronized to the other interfaces in the group.
When you execute this command for an interface through the preprovisioning feature, the configuration on the interface is not automatically synchronized to the other interfaces in the same group. For more information about preprovisioning, see preprovisioning configuration in Fundamentals Configuration Guide.
The default command cannot restore the media type to the default.
# Configure the media type as fiber for Twenty-FiveGigE 1/0/1.
[Sysname] interface twenty-fiveGigE 1/0/1
[Sysname-Twenty-FiveGigE1/0/1] port media-type fiber
port training
Use port training to configure link compensation on an interface.
Use undo port training to restore the default.
NOTE: The S6805 switch series does not support this command. |
port training { disable | enable }
undo port training
Link compensation is disabled on an interface.
disable: Disables link compensation.
enable: Enables link compensation.
Link compensation enables the sending and receiving ends to exchange pre-emphasis and equalization parameters through frames. This feature improves the performance of pre-emphasis and equalization.
Only 25-GE Ethernet interfaces connected through copper cables support this command. For 25-GE interfaces connected through copper cables to operate properly, you must enable link compensation.
You must enable or disable link compensation on both interfaces of a link.
Typically, the link compensation status is controlled by the software, and do not adjust the link compensation status as a best practice. Use this command to adjust the link compensation status only when the interface cannot come up.
# Enable link compensation on Twenty-FiveGigE 1/0/1.
[Sysname-Twenty-FiveGigE1/0/1] port training enable
port up-mode
Use port up-mode to forcibly bring up a fiber Ethernet port.
Use undo port up-mode to restore the default.
port up-mode
undo port up-mode
A fiber Ethernet port is not forcibly brought up. The physical state of a fiber port depends on the physical state of the fibers.
This command forcibly brings up a fiber Ethernet port and enables the port to forward packets unidirectionally over a single link. In this way, transmission links are well utilized.
The following operations on a fiber port will cause link updown events before the port finally stays up:
· Configure both the port up-mode command and the speed or duplex command.
· Install or remove fiber links or transceiver modules after you forcibly bring up the fiber port.
Copper ports do not support this command.
The shutdown and port up-mode commands are mutually exclusive.
A fiber Ethernet port does not support this command if the port is shut down by a protocol or by using the shutdown command.
A GE fiber port forcibly brought up cannot correctly forward traffic if it is installed with a fiber-to-copper converter, 100/1000-Mbps transceiver module, or 100-Mbps transceiver module. To solve the problem, use the undo port up-mode command on the fiber port.
# Forcibly bring up fiber port Twenty-FiveGigE 1/0/1.
[Sysname-Twenty-FiveGigE1/0/1] port up-mode
reset counters interface
Use reset counters interface to clear the interface statistics.
reset counters interface [ interface-type [ interface-number | interface-number.subnumber ] ]
interface-number.subnumber: Specifies a subinterface number. The interface-number argument is an interface number. The subnumber argument is the number of a subinterface created under the interface. The value range for the subnumber argument is 1 to 4094.
Use this command to clear history statistics if you want to collect traffic statistics for a specific time period.
If you do not specify an interface type, this command clears statistics for all interfaces.
If you specify an interface type but do not specify an interface number, this command clears statistics for all interfaces of the specified type.
# Clear the statistics for Twenty-FiveGigE 1/0/1.
<Sysname> reset counters interface twenty-fivegige 1/0/1
display counters interface
display counters rate interface
display interface
reset ethernet statistics
Use reset ethernet statistics to clear the Ethernet module statistics.
reset ethernet statistics [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command clears statistics for all IRF member devices.
# Clear the Ethernet module statistics for the specified slot.
<Sysname> reset ethernet statistics slot 1
display ethernet statistics
reset link-state-change statistics interface
Use reset link-state-change statistics interface to clear link state change statistics of interfaces.
reset link-state-change statistics interface [ interface-type [ interface-number ] ]
Link state change statistics of an interface are not cleared.
If you do not specify an interface type, this command clears the link state change statistics for all interfaces.
If you specify an interface type but do not specify an interface number, this command clears the link state change statistics for all interfaces of the specified type.
# Clear the link state change statistics of Twenty-FiveGigE 1/0/1.
<Sysname> reset link-state-change statistics interface twenty-fivegige 1/0/1
reset packet-drop interface
Use reset packet-drop interface to clear the dropped packet statistics for an interface.
reset packet-drop interface [ interface-type [ interface-number ] ]
interface-type: Specify an interface type.
interface-number: Specify an interface number.
If you do not specify an interface type, this command clears dropped packet statistics for all interfaces on the device.
If you specify an interface type but do not specify an interface number, the command clears dropped packet statistics for all interfaces of the specified type.
# Clear dropped packet statistics for Twenty-FiveGigE 1/0/1.
<Sysname> reset packet-drop interface twenty-fivegige 1/0/1
# Clear dropped packet statistics for all interfaces.
display packet-drop
shutdown
Use shutdown to shut down an Ethernet interface or subinterface.
Use undo shutdown to bring up an Ethernet interface or subinterface.
shutdown
Ethernet interfaces and subinterfaces are in up state.
Ethernet subinterface view
CAUTION: Executing the shutdown command on an interface will disconnect the link of the interface and interrupt communication. Use this command with caution. |
Some interface configurations might require an interface restart before taking effect.
The shutdown command cannot be configured on an interface in a loopback test.
# Shut down and then bring up Twenty-FiveGigE 1/0/1.
[Sysname-Twenty-FiveGigE1/0/1] shutdown
[Sysname-Twenty-FiveGigE1/0/1] undo shutdown
# Shut down and then bring up Twenty-FiveGigE 1/0/1.1.
[Sysname-Twenty-FiveGigE1/0/1.1] shutdown
[Sysname-Twenty-FiveGigE1/0/1.1] undo shutdown
shutdown all-physical-interface
Use shutdown all-physical-interfaces to shut down all physical interfaces except management Ethernet interfaces.
Use undo shutdown all-physical-interfaces to bring up all physical interfaces except management Ethernet interfaces.
shutdown all-physical-interfaces [ include irf-physical-interface ]
Physical interfaces are up.
include irf-physical-interface: Shuts down all physical interfaces including the IRF physical interfaces. If you do not specify this keyword, this command does not shut down IRF physical interfaces.
With the shutdown all-physical-interfaces command, you can shut down all physical interfaces except the management Ethernet interfaces on the device. Physical interfaces shut down by using this command are in ADM state.
This command does not take effect on a physical interface that has joined a service loopback group.
To shut down all physical interfaces or the specified interface, execute the shutdown all-physical-interfaces command in system view or execute the shutdown command in interface view.
To bring up interfaces shut down by using the shutdown all-physical-interfaces command, execute its undo form in system view. To bring up an interface shut down by using the shutdown command, execute its undo form in interface view.
If you execute this command with the include irf-physical-interface keyword multiple times, this command shuts down all physical interfaces except the management Ethernet interfaces on the device.
# Shut down all physical interfaces except management Ethernet interfaces and IRF physical interfaces.
[Sysname] shutdown all-physical-interfaces
shutdown
Use snmp-agent trap enable ifmonitor to enable interface alarm functions.
Use undo snmp-agent trap enable ifmonitor to disable interface alarm functions.
snmp-agent trap enable ifmonitor [ crc-error | input-error | input-usage | output-error | output-usage | rx-pause | tx-pause ] *
undo snmp-agent trap enable ifmonitor [ crc-error | input-error | input-usage | output-error | output-usage | rx-pause | tx-pause ] *
Interface alarm functions are enabled.
crc-error: Enables the CRC error packet alarm function for interfaces.
input-error: Enables the input error packet alarm function for interfaces.
input-usage: Enables the input bandwidth usage alarm function for interfaces.
output-error: Enables the output error packet alarm function for interfaces.
output-usage: Enables the output bandwidth usage alarm function for interfaces.
rx-pause: Enables the received pause frame alarm function for interfaces.
tx-pause: Enables the sent pause frame alarm function for interfaces.
# Enable the CRC error packet alarm function for interfaces.
[Sysname] snmp-agent trap enable ifmonitor crc-error
speed
Use speed to set the speed of an Ethernet interface.
Use undo speed to restore the default.
speed { 10 | 100 | 1000 | 10000 | 25000 | 40000 | 100000 | auto }
undo speed
An Ethernet interface negotiates a speed with its peer.
10: Sets the interface speed to 10 Mbps.
100: Sets the interface speed to 100 Mbps.
1000: Sets the interface speed to 1000 Mbps.
10000: Sets the interface speed to 10000 Mbps.
25000: Sets the interface speed to 25000 Mbps.
40000: Sets the interface speed to 40000 Mbps.
100000: Sets the interface speed to 100000 Mbps.
auto: Enables the interface to negotiate a speed with its peer.
For an Ethernet copper port, use the speed command to set its speed to match the speed of the peer interface. Support of copper ports for keywords of this command varies by copper port type. For more information, use the speed ? command in interface view. If the system does not prompt that operation failed when you configure a speed for a copper port, the copper port supports this speed. Otherwise, the copper port does not support this speed.
For a fiber port, use the speed command to set its speed to match the rate of a transceiver module. Support of fiber ports for keywords of this command varies by fiber port type. For more information, use the speed ? command in interface view. If the system does not prompt that operation failed when you configure a speed for a fiber port, the fiber port supports this speed. Otherwise, the fiber port does not support this speed.
Additionally, you must select a speed for a fiber port according to the transceiver module installed to ensure that the transceiver module can be used properly. If the transceiver module installed in a fiber port does not support the speed for the fiber port, the transceiver module cannot be used. For example, if the transceiver module installed in an SFP+ fiber port is an SFP GE transceiver module and the speed 10000 command is executed on the fiber port or the transceiver module installed in an SFP+ fiber port is a 10-GE transceiver module and the speed 1000 command is executed on the fiber port, the transceiver module cannot be used.
When an SFP-GE-T or SFP-GE-T-D transceiver module is installed in a fixed SFP port of the device, you can use the speed command to set the speed to 1000 Mbps or use the speed auto command to configure the port to autonegotiate the speed to 1000 Mbps.
For more information, see Layer 2—LAN Switching Configuration Guide.
# Configure Twenty-FiveGigE 1/0/1 to autonegotiate the speed.
[Sysname-Twenty-FiveGigE1/0/1] speed auto
unicast-suppression
Use unicast-suppression to enable unknown unicast storm suppression and set the unknown unicast storm suppression threshold.
Use undo unicast-suppression to disable unknown unicast storm suppression.
Ethernet interfaces do not suppress unknown unicast traffic.
ratio: Sets the unknown unicast suppression threshold as a percentage of the interface bandwidth. The value range for this argument (in percentage) is 0 to 100. A smaller value means that less unknown unicast traffic is allowed to pass through.
pps max-pps: Specifies the maximum number of unknown unicast packets that the interface can forward per second. The value range for the max-pps argument (in pps) is 0 to 1.4881 × the interface bandwidth.
kbps max-kbps: Specifies the maximum number of kilobits of unknown unicast traffic that the Ethernet interface can forward per second. The value range for this argument (in kbps) is 0 to the interface bandwidth.
The unknown unicast storm suppression feature limits the size of unknown unicast traffic to a threshold on an interface. When the unknown unicast traffic on the interface exceeds this threshold, the system discards packets until the unknown unicast traffic drops below this threshold.
Both the storm-constrain command and the unicast-suppression command can suppress unknown unicast storms on a port. The unicast-suppression command uses the chip to physically suppress unknown unicast traffic. It has less influence on the device performance than the storm-constrain command, which uses software to suppress unknown unicast traffic.
For the unknown unicast traffic suppression result to be determined, do not configure both the storm-constrain unicast command and the unicast-suppression command on an interface.
For the suppression threshold that takes effect, see the prompt on the device.
# Set the unknown unicast storm suppression threshold to 10000 kbps on Twenty-FiveGigE 1/0/1.
[Sysname-Twenty-FiveGigE1/0/1] unicast-suppression kbps 10000
using fiftygige
Use using fiftygige to split a 100-GE interface to two 50-GE breakout interfaces.
IMPORTANT: This feature is supported only on the S9850-32H switches. |
using fiftygige
A 100-GE interface is not split into 50-GE breakout interface.
The interface numbered 31 on an S9850-32H switch cannot be split by default. To split this interface, first enable the hardware resource flex mode for the device by using the hardware-resource flex-mode enable command. For more information about the hardware resource flex mode, see Fundamentals Configuration Guide.
To improve port density, reduce costs, and improve network flexibility, you can split a 100-GE interface into two 50-GE breakout interfaces. For example, you can split 100-GE interface HundredGigE 1/0/1 into two 50-GE breakout interfaces FiftyGigE 1/0/1:1 and FiftyGigE 1/0/1:2.
After this feature is configured, you do not need to reboot the device. To view the breakout interfaces, execute the display interface brief command.
An interface with any of the following configurations cannot be split:
· IRF physical interface.
· Service loopback group member.
· Reflector port for mirroring.
· Forcibly bringing up a fiber port.
# Split HundredGigE 1/0/1 into two 50-GE breakout interfaces.
<System> system-view
[System] interface hundredgige 1/0/1
[System-HundredGigE1/0/1] using fiftygige
The interface HundredGigE1/0/1 will be deleted. Continue? [Y/N]:y
using hundredgige
using fortygige
Use using fortygige to combine 10-GE breakout interfaces split from a 40-GE interface into a 40-GE interface.
IMPORTANT: This command is not supported on the S6805 and S6825 switch series. |
using fortygige
The 10-GE breakout interfaces are not combined and operate as single interfaces.
10-GE breakout interface view
If you need higher bandwidth on a single interface, you can combine four 10-GE breakout interfaces split from a 40-GE interface into a 40-GE interface. To do so, execute this command on any of these 10-GE breakout interfaces.
After executing this command, you do not need to reboot the device. To view information about the 40-GE interface, execute the display interface brief command.
# Combine Ten-GigabitEthernet 1/0/1:1 through Ten-GigabitEthernet 1/0/1:4 into a 40-GE interface.
[System] interface ten-gigabitethernet1/0/1:1
[System-Ten-GigabitEthernet1/0/1:1] using fortygige
The interfaces Ten-GigabitEthernet1/0/1:1 through Ten-GigabitEthernet1/0/1:4 will be deleted. Continue? [Y/N]:y
using tengige
using hundredgige
Use using hundredgige to combine breakout interfaces split from a 100-GE interface into a 100-GE interface.
Use undo using hundredgige to cancel the operation of combing breakout interfaces.
using hundredgige
The breakout interfaces are not combined and operate as single interfaces.
25-GE breakout interface view
50-GE breakout interface view
If you need higher bandwidth on a single interface, perform the following tasks as needed:
· After a 100-GE interface has a split-capable 40-GE transceiver module or cable installed, you can combine the four 10-GE breakout interfaces into a 100-GE interface. To do so, execute this command on any of these 10-GE breakout interfaces.
· You can combine four 25-GE breakout interfaces split from a 100-GE interface into a 100-GE interface. To do so, execute this command on any of these 25-GE breakout interfaces.
· You can combine two 50-GE breakout interfaces split from a 100-GE interface into a 100-GE interface. To do so, execute this command on any of these 50-GE breakout interfaces. This feature is supported only on the S9850-32H switches.
Device reboot is not required for this command to take effect. You can view the split or combined interface by using the display interface brief command.
# Combine Ten-GigabitEthernet 1/0/26:1 through Ten-GigabitEthernet 1/0/26:4 into an interface.
[Sysname] interface ten-gigabitethernet 1/0/26:1
[Sysname-Ten-GigabitEthernet1/0/26:1]using hundredgige
The interfaces Ten-GigabitEthernet1/0/26:1 through Ten-GigabitEthernet1/0/26:4 will be deleted. Continue? [Y/N]:y
# Combine Twenty-FiveGigE 1/0/26:1 through Twenty-FiveGigE 1/0/26:4 into a 100-GE interface.
[Sysname] interface twenty-fivegige 1/0/26:1
[Sysname-Twenty-FiveGigE1/0/26:1] using hundredgige
The interfaces Twenty-FiveGigE 1/0/26:1 through Twenty-FiveGigE 1/0/26:4 will be deleted. Continue? [Y/N]:y
# Combine FiftyGigE 1/0/1:1 and FiftyGigE 1/0/1:2 into a 100-GE interface.
[Sysname] interface fiftygige 1/0/1:1
[Sysname-FiftyGigE1/0/1:1] using hundredgige
The interfaces FiftyGigE1/0/1:1 and FiftyGigE1/0/1:2 will be deleted. Continue? [Y/N]:y
using tengige
using twenty-fivegige
using tengige
Use using tengige to split a high bandwidth interface into multiple 10-GE breakout interfaces.
using tengige
A high bandwidth interface is not split and operates as a single interface.
40-GE interface view
To improve port density, reduce costs, and improve network flexibility, you can split a high bandwidth interface into multiple 10-GE breakout interfaces. For example:
· Split a 40-GE interface FortyGigE 1/0/1 into four 10-GE breakout interfaces Ten-GigabitEthernet 1/0/1:1 through Ten-GigabitEthernet 1/0/1:4.
· Split a 100-GE interface HundredGigE 1/0/26 with a split-capable 40-GE transceiver module or cable installed into four 10-GE breakout interfaces Ten-GigabitEthernet 1/0/26:1 through Ten-GigabitEthernet 1/0/26:4.
The 10-GE breakout interfaces support the same configuration and attributes as common 10-GE interfaces, except that they are numbered in a different way.
After executing this command, you do not need to reboot the device. To view information about the 10-GE breakout interfaces, execute the display interface brief command.
On an S6805-54HT device, interfaces 51 and 52 can be split into 10-GE or 25-GE breakout interfaces. On an S6805-54HF device, interfaces 27 and 28 can be split into 10-GE or 25-GE breakout interfaces.
On an S6825-54HF device, interfaces 27 and 28 can be split into 10-GE or 25-GE breakout interfaces.
The interface numbered 31 on the S6850-56HF switch cannot be split.
When the LSWM18CQ or LSWM18CQMSEC interface module is installed in the slot 2 on the S9850-4C switch, the interface numbered 7 on the interface module cannot be split. This restriction does not apply when the LSWM18CQ or LSWM18CQMSEC interface module is installed in any other slot.
When the LSWM18QC interface module is installed in the slot 2 on the S9850-4C switch, the interface numbered 8 on the interface module cannot be split. This restriction does not apply when the LSWM18QC interface module is installed in any other slot.
When the LSWM124TG2H, LSWM124XG2Q, LSWM124XGT2Q, LSWM124XG2QFC, or LSWM124XG2QL interface module is installed in the slot 2 on the S9850-4C switch, the interface numbered 25 on the interface module cannot be split. This restriction does not apply when the LSWM124TG2H, LSWM124XG2Q, LSWM124XGT2Q, LSWM124XG2QFC, or LSWM124XG2QL interface module is installed in any other slot.
All interfaces on the LSWM116Q interface module cannot be split.
# Split HundredGigE 1/0/26 into 10-GE breakout interfaces.
[Sysname] interface hundredgige 1/0/26
[Sysname-HundredGigE1/0/26] using tengige
The interface HundredGigE1/0/26 will be deleted. Continue? [Y/N]:y
# Split FortyGigE 1/0/1 into four 10-GE breakout interfaces.
[System] interface fortygige 1/0/1
[System-FortyGigE1/0/1] using tengige
The interface FortyGigE1/0/1 will be deleted. Continue? [Y/N]:y
using fortygige
using hundredgige
Use using twenty-fivegige to split a 100-GE interface into four 25-GE breakout interfaces.
A 100-GE interface is not split and operates as a single interface.
To improve port density, reduce costs, and improve network flexibility, you can split a 100-GE interface into four 25-GE breakout interfaces. For example, you can split the 100-GE interface HundredGigE 1/0/1 into four 25-GE breakout interfaces Twenty-FiveGigE 1/0/1:1 through Twenty-FiveGigE 1/0/1:4.
After executing this command, you do not need to reboot the device. To view information about the 25-GE breakout interfaces, execute the display interface brief command.
When the LSWM124TG2H interface module is installed in the slot 2 on the S9850-4C switch, the interface numbered 25 on the interface module cannot be split. This restriction does not apply when the LSWM124TG2H interface module is installed in any other slot.
# Split HundredGigE 1/0/26 into four 25-GE breakout interfaces.
[Sysname-HundredGigE1/0/26] using twenty-fivegige
using hundredgige
Layer 2 Ethernet interface commands
display storm-constrain
Use display storm-constrain to display storm control settings and statistics.
display storm-constrain [ broadcast | multicast | unicast ] [ interface interface-type interface-number ]
broadcast: Displays broadcast storm control settings and statistics.
multicast: Displays multicast storm control settings and statistics.
unicast: Displays unknown unicast storm control settings and statistics.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify this option, the command displays storm control settings and statistics for all storm control-enabled interfaces.
If you do not specify any keywords, this command displays all storm control settings on all storm control-enabled interfaces.
# Display the storm control settings on all storm control-enabled ports.
<Sysname> display storm-constrain
Abbreviation: BC - broadcast; MC - multicast; UC - unknown unicast;
FW - forwarding
Flow Statistic Interval: 5 (in seconds)
Port Type Lower Upper Unit Mode Status Trap Log StateChg
WGE1/0/1 MC 100 200 kbps shutdown shutdown off on 10
Table 10 Command output
Flow Statistic Interval |
Traffic polling interval (in seconds) of the storm control module. |
Port |
Abbreviated interface name. |
Type |
Type of traffic subjected to storm control: · BC—Broadcast packets. · MC—Multicast packets. · UC—Unknown unicast packets. · KNUC—Known unicast packets. This field is not supported in the current software version. |
Lower |
Lower storm control threshold, in pps, kbps, or percentage. |
Upper |
Upper storm control threshold, in pps, kbps, or percentage. |
Unit |
Storm control threshold unit: · pps. · kbps. · percentage. |
Mode |
Action (block or shutdown) taken on the interface when the upper threshold is reached. N/A indicates that no action is configured. |
Status |
Packet forwarding status: · FW—The port is forwarding traffic correctly. · shutdown—The port has been shut down. · block—The port drops the type of traffic. |
Trap |
Status of the storm control threshold event trap switch: · on—The port sends threshold event traps. · off—The port does not send threshold event traps. |
Log |
Status of the storm control threshold event log switch: · on—The port sends threshold event log messages. · off—The port does not send threshold event log messages. |
StateChg |
Number of forwarding state changes of the interface. When the StateChg field reaches 65535, it resets automatically. |
port bridge enable
Use port bridge enable to enable bridging on an Ethernet interface.
Use undo port bridge enable to disable bridging on an Ethernet interface.
port bridge enable
Bridging is disabled on an Ethernet interface.
By default, the device drops packets whose outgoing interface and incoming interface are the same.
To enable the device to forward such packets rather than drop them, configure this command in Ethernet interface view. After the device receives a broadcast or unknown unicast packet, the device forwards the packet through all interfaces in the VLAN to which the incoming interface of the packet belongs.
Do not add interfaces configured with this command to an aggregation group.
Bridging and Ethernet service instance configuration are mutually exclusive on an interface.
# Enable bridging on Twenty-FiveGigE 1/0/1.
[Sysname-Twenty-FiveGigE1/0/1] port bridge enable
port-type
Use port-type to switch the interface type between Layer 2 Ethernet and FC.
In Layer 2 Ethernet interface view:
port-type fc
In FC interface view:
port-type ethernet
NOTE: · The S6805 and S6825 switch series does not support this command. · Only interfaces on LSWM124XG2QFC or LSWM116FC cards support this command. |
The interface type is Layer 2 Ethernet.
FC interface view
ethernet: Changes the type of the interface to Layer 2 Ethernet.
fc: Changes the type of the interface to FC.
CAUTION: After the type of an interface is changed, the system deletes the original interface and creates a new interface that is numbered the same as the original interface. All the other commands are restored to the default on the new interface. |
Some Layer 2 Ethernet interfaces can be changed to FC interfaces. To change such a Layer 2 Ethernet interface to a FC interface, enter the Layer 2 Ethernet interface view and execute the port-type fc command. To change the FC interface to a Layer 2 Ethernet interface, enter the FC interface view and execute the port-type ethernet command.
After the type of an interface is changed, the system creates a new interface that is numbered the same as the original interface.
An LSWM116FC interface expansion card has 16 interfaces, and every two neighboring interfaces belong to one port group. If you change an Ethernet interface to an FC interface by using the port-type fc command, the other interface in the same port group is also changed to an FC interface. If you change an FC interface to an Ethernet interface by using the port-type ethernet command, the other interface in the same port group is also changed to an Ethernet interface. An Ethernet interface on the card operates at 25 Gbps in full duplex and cannot perform speed autonegotiation.
# Change Layer 2 Ethernet interface Twenty-FiveGigE 1/0/1 into an FC interface.
[Sysname-Twenty-FiveGigE1/0/1] port-type fc
[Sysname-Fc1/0/1]
storm-constrain
Use storm-constrain to enable storm control and set thresholds for broadcast, multicast, or unknown unicast packets on an Ethernet interface.
Use undo storm-constrain to disable storm control for broadcast, multicast, unknown unicast, or all types of traffic.
storm-constrain { broadcast | multicast | unicast } { pps | kbps | ratio } upperlimit lowerlimit
undo storm-constrain { all | broadcast | multicast | unicast }
Traffic storm control is disabled.
all: Disables storm control for all types of traffic: broadcast, multicast, and unknown unicast.
broadcast: Enables or disables broadcast storm control.
multicast: Enables or disables multicast storm control.
unicast: Enables or disables unknown unicast storm control.
pps: Sets storm control thresholds in pps.
kbps: Sets storm control thresholds in kbps.
ratio: Sets storm control thresholds as a percentage of the transmission capacity of the interface.
upperlimit: Sets the upper threshold, in pps, kbps, or percentage.
· If you specify the pps keyword, the value range for the upperlimit argument is 1 to 1.4881 × the interface bandwidth.
· If you specify the kbps keyword, the value range for the upperlimit argument is 1 to the interface bandwidth.
· If you specify the ratio keyword, the value range for the upperlimit argument is 1 to 100.
lowerlimit: Sets the lower threshold, in pps, kbps, or percentage.
· If you specify the pps keyword, the value range for the lowerlimit argument is 1 to 1.4881 × the interface bandwidth.
· If you specify the kbps keyword, the value range for the lowerlimit argument is 1 to the interface bandwidth.
· If you specify the ratio keyword, the value range for the lowerlimit argument is 1 to 100.
After you configure storm control for a type of traffic, the device collects the statistics for the type of traffic at the interval configured by using the storm-constrain interval command. When the type of traffic exceeds its upper threshold, the interface takes an action configured by using the storm-constrain control command.
The storm-constrain, broadcast-suppression, multicast-suppression, and unicast-suppression commands can suppress storms on an interface. The broadcast-suppression, multicast-suppression, and unicast-suppression commands use the chip to physically suppress traffic. They have less influence on the device performance than the storm-constrain command, which uses software to suppress traffic.
For the traffic suppression result to be determined, do not configure both storm control and storm suppression for the same type of traffic.
When configuring this command, make sure upperlimit is greater than lowerlimit.
# Enable unknown unicast storm control on Twenty-FiveGigE 1/0/1 and set the upper and lower thresholds to 200 pps and 150 pps, respectively.
[Sysname-Twenty-FiveGigE1/0/1] storm-constrain unicast pps 200 150
# Enable broadcast storm control on Twenty-FiveGigE 1/0/2, and set the upper and lower thresholds to 2000 kbps and 1500 kbps, respectively.
[Sysname-Twenty-FiveGigE1/0/2] storm-constrain broadcast kbps 2000 1500
# Enable multicast storm control on Twenty-FiveGigE 1/0/3, and set the upper and lower thresholds to 80% and 15%, respectively.
[Sysname] interface twenty-fivegige 1/0/3
[Sysname-Twenty-FiveGigE1/0/3] storm-constrain multicast ratio 80 15
Use storm-constrain control to set the action to take on an Ethernet interface when a type of traffic (unknown unicast, multicast, or broadcast) exceeds the upper storm control threshold.
Use undo storm-constrain control to restore the default.
No action is taken on an Ethernet interface when a type of traffic exceeds the upper storm control threshold.
block: Blocks this type of traffic and forwards other types of traffic. Even though the interface does not forward the blocked traffic, it still counts the traffic. When the blocked traffic drops below the lower threshold, the port begins to forward the traffic.
shutdown: Goes down automatically. The interface goes down automatically and stops forwarding any traffic. When the blocked traffic drops below the lower threshold, the interface does not forward the traffic. To bring up the interface, use the undo shutdown command or disable storm control on the interface.
# Configure Twenty-FiveGigE 1/0/1 to block a specific type of traffic when the type of traffic exceeds the upper storm control threshold.
[Sysname-Twenty-FiveGigE1/0/1] storm-constrain control block
storm-constrain
storm-constrain enable log
Use storm-constrain enable log to enable an Ethernet interface to output log messages when it detects storm control threshold events.
Use undo storm-constrain enable log to disable an Ethernet interface from outputting log messages for storm control threshold events.
An Ethernet interface outputs log messages when monitored traffic exceeds the upper threshold or drops below the lower threshold from a value above the upper threshold.
# Enable Twenty-FiveGigE 1/0/1 to output log messages when it detects storm control threshold events.
[Sysname-Twenty-FiveGigE1/0/1] storm-constrain enable log
storm-constrain enable trap
Use storm-constrain enable trap to enable an Ethernet interface to send storm control threshold event traps.
Use undo storm-constrain enable trap to disable an Ethernet interface from sending storm control threshold event traps.
An interface sends out storm control threshold event traps when monitored traffic exceeds the upper threshold or drops below the lower threshold from a value above the upper threshold.
# Enable Twenty-FiveGigE 1/0/1 to send traps when it detects storm control threshold events.
[Sysname-Twenty-FiveGigE1/0/1] storm-constrain enable trap
Use storm-constrain interval to set the traffic polling interval of the storm control module.
Use undo storm-constrain interval to restore the default.
storm-constrain interval interval
The storm control module polls traffic statistics every 10 seconds.
interval: Sets the traffic polling interval of the storm control module. The value range is 1 to 300 seconds. To ensure network stability, as a best practice, do not use a traffic polling interval shorter than 10 seconds.
The traffic polling interval set by using the storm-constrain interval command is specific to storm control. To set the statistics polling interval of an interface, use the flow-interval command.
# Set the traffic statistics polling interval of the storm control module to 60 seconds.
[Sysname] storm-constrain interval 60
storm-constrain
Layer 3 Ethernet interface or subinterface commands
mac-address
Use mac-address to set the MAC address of an Ethernet interface.
Use undo mac-address to restore the default.
mac-address mac-address
undo mac-address
No MAC address is set for a Layer 3 Ethernet interface.
mac-address: Specifies a MAC address in the format of H-H-H.
When you set a MAC address for a Layer 3 Ethernet subinterface, select a MAC address different from that of the main interface.
Do not set a VRRP-reserved MAC address for a Layer 3 Ethernet subinterface.
# Set the MAC address of Twenty-FiveGigE 1/0/1 to 0001-0001-0001.
[Sysname-Twenty-FiveGigE1/0/1] mac-address 1-1-1
mtu
Use mtu to set the MTU for an Ethernet interface or subinterface.
mtu size
undo mtu
The MTU of an Ethernet interface or subinterface is 1500 bytes.
size: Sets the MTU in bytes. The value range for this argument is 128 to 9216.
The MTU configured on an interface takes effect only on packets sent to the CPU for software forwarding. Configure the MTU as appropriate for interfaces in the network to avoid fragmentation.
If an interface supports both the mtu and ip mtu commands, the device fragments an IPv4 packet based on the MTU set by using the ip mtu command. For more information about the ip mtu command, see Layer 3—IP Services Command Reference.
# Set the MTU to 1430 bytes for Twenty-FiveGigE 1/0/1.
[Sysname] interface twenty-fivegige 1/0/1
[Sysname-Twenty-FiveGigE1/0/1] mtu 1430
# Set the MTU to 1430 bytes for Twenty-FiveGigE 1/0/1.1.
[Sysname] interface twenty-fivegige 1/0/1.1
[Sysname-Twenty-FiveGigE1/0/1.1] mtu 1430
