H3C UniServer B5700 G5 Blade Server User Guide-6W100
HomeSupportServersBlade ServerH3C UniServer B16000H3C UniServer B5700 G5Install & UpgradeInstallation GuidesH3C UniServer B5700 G5 Blade Server User Guide-6W100
02-Appendix
02-Appendix 69.37 KB
Appendix A  Part specifications
Query all the parts supported by the server and their details through the official website Server-compatible Part Query Tool.
Operating ambient temperature specification
Table 1 Operating ambient temperature specification
Temperature
CPU mode
Maximum temperature
35°C
40°C
45°C
Common mode
The CPU with 165 W ≤ TDP ≤ 235 W is supported, and:
·     When the PCIe card of the front panel outlet port is configured, only the CPU models 6314U, 6330, 6330N, 6338N, and 8351N are supported
When CPU models 6348 and 6354 are configured, the maximum operating temperature drops to about 30°C if a single fan fails
The CPU with TDP ≤ 225 W is supported, where the CPU models 6346, 6354, 8352S, and 8352Y are not supported, and:
·     When the PCIe card of the front panel outlet port is configured, only the CPU models 6314U and 6330N are supported
·     The PMem 200 DIMM is not supported
When the CPU models 6338, 6346, and 8352V are configured, the maximum operating temperature drops to about 35°C if a single fan fails
The CPU models 6314U, 6330N, 6338N, and 8351N are supported, and:
·     When CPU models 6338N and 8351N are configured, the maximum operating temperature drops to about 40°C if a single fan fails
·     The NVMe drive is not supported
·     The SATA M.2 SSD module is not supported
SST mode
The CPU with TDP ≤ 225 W is supported, where the CPU models 6354, 8352S, and 8352Y are not supported, and:
When the PCIe card of the front panel outlet port is configured, only the CPU models 6314U, 6330N, and 6338N are supported
·     The CPU models 6314U, 6330N, 6338N, and 8351N are supported, and:
·     When the PCIe card at the front panel outlet port is configured, only the 6330N CPU is supported. When a single fan fails, the maximum operating temperature drops to about 35°C
·     When CPU model 8351N is configured, the maximum operating temperature drops to about 35°C if a single fan fails
The CPU model 6330N is supported, and:
·     The PCIe card at the front panel outlet port is not supported, e.g., the PCIe network card
The maximum operating temperature drops to about 40°C if a single fan fails
Appendix B  Technical support
If you encounter any complicated problems during daily maintenance or troubleshooting, contact H3C Support.
Collecting server information
Before contacting H3C Support, collect the following server information to facilitate troubleshooting:
·     Log and sensor information.
·     Product serial number.
·     Product model and name.
·     Snapshots of error messages and descriptions.
·     Hardware change history, including installation, replacement, insertion, and removal of hardware.
·     Third-party software installed on the server.
·     Operating system type and version.
Preparing debugging tools
Prepare the following possible tools to facilitate troubleshooting:
·     T-25 Torx star screwdriver: Used to remove and install the radiator
·     T-15 Torx star screwdriver: Used to replace the main board
·     Display terminal (such as PC)
·     ESD wrist strap/ESD gloves/ESD clothing
Appendix C  Product recycling
New H3C Technologies Co., Ltd. provides product recycling services for its customers to ensure that hardware at the end of its life is recycled. Vendors with product recycling qualification are contracted to New H3C to process the recycled hardware in an environmentally responsible way.
For product recycling services, contact New H3C at
·     Tel: 400-810-0504
·     E-mail: [email protected]
·     Website: http://www.h3c.com
Appendix D  Glossary
Table 2 Glossary
Item
B
BIOS
Basic input/output system is non-volatile firmware pre-installed in a ROM chip on a server's management module. The BIOS stores basic input/output, power-on self-test, and auto startup programs to provide the most basic hardware initialization, setup and control functionality.
G
GPU card
Graphics processing unit module converts digital signals to analog signals for output to a display device and assists processors with image processing to improve overall system performance.
H
HDM
Hardware Device Management is the server management control unit with which administrators can configure server settings, view component information, monitor server health status, and remotely manage the server.
K
KVM device
KVM is a management method that allows remote users to use their local video display, keyboard, and mouse to monitor and control the server.
N
NVMe VROCmodule
A module that works with Intel VMD to provide RAID capability for the server to virtualize storage resources of NVMe drives.
R
RAID
Redundant array of independent disks (RAID) is a data storage virtualization technology that combines multiple physical hard drives into a single logical unit to improve storage and security performance.
Hot swapping
A module that supports hot swapping (a hot-swappable module) can be installed or removed while the server is running without affecting the system operation.
Redundancy
A mechanism that ensures high availability and business continuity by providing backup modules. In redundancy mode, a backup or standby module takes over when the primary module fails.
W
Network card
The network card is a network part operating on the data link layer. It not only realizes the physical connection and electrical signal matching with the LAN transmission media, but also provides the functions of frame sending and receiving, frame encapsulation and decapsulation, media access control, data encoding and decoding, and data caching.
Appendix E  Acronyms
Table 3 Acronyms
Acronym
Full name
B
BIOS
Basic Input Output System
C
CPU
Central Processing Unit
D
DDR
Double Data Rate
DIMM
Dual Inline Memory Module
DRAM
Dynamic Random Access Memory
G
GPU
Graphics Processing Unit
H
HBA
Host Bus Adapter
HDD
Hard Disk Drive
HDM
I
ICM
Interconnect Module
L
LFF
Large Form Factor
LRDIMM
Load Reduced Dual Inline Memory Module
N
NVMe
Non-Volatile Memory Express
O
OM
Onboard Management
P
PCIe
Peripheral Component Interconnect Express
R
RAID
Redundant Arrays of Independent Disks
RDIMM
Registered Dual Inline Memory Module
S
SAS
Serial Attached Small Computer System Interface
SATA
Serial ATA
SFF
Small Form Factor
SSD
Solid State Drive
SST
Speed Select Technology
T
TCM
Trusted Cryptography Module
TDP
Thermal Design Power
TPM
Trusted Platform Module
U
UID
Unit Identification
UPI
Ultra Path Interconnect
USB
Universal Serial Bus
V
VROC
Virtual RAID on CPU
VMD
Volume Management Device
