| 03-Appendix B Purchase guide | 89.29 KB |
This appendix describes the interface module compatibility with H3C ICG information communication gateways. In the tables, "Yes" means "Supported" and "No" means "Not supported."
SIC/DSIC purchase guide
IMPORTANT: · Layer 2 communication across slots is not supported between SIC Ethernet switching modules or between SIC Ethernet switching modules and HMIM Ethernet switching modules. · The ICG6000 information communication gateway does not support SICs or DSICs. · The PoE feature of a PoE interface module takes effect only when the PoE interface module is installed on a PoE device. When installed on a non-PoE device, the PoE interface module can only be used as a Layer 2 forwarding interface module. |
Table 1 SIC/DSIC compatibility with H3C ICG information communication gateways (1)
SIC/DSIC model |
ICG2000D |
ICG2000D-EI |
ICG3000F/ICG3000F-DP |
SIC-4FSW |
No |
Yes (supported only in slot 2) |
Yes (supported only in slots 2 and 4) |
SIC-4FSWP |
No |
No |
No |
DSIC-9FSW |
No |
No |
No |
DSIC-9FSWP |
No |
No |
No |
SIC-4GSW |
No |
SIC-4GSWF |
No |
SIC-1FEA |
No |
No |
SIC-1FEF |
No |
No |
No |
SIC-1GEC-V2 |
No |
No |
No |
SIC-E1-F |
No |
Yes |
Yes |
SIC-2E1-F |
Yes |
Yes |
Yes (a maximum number of 2 supported) |
SIC-1EPRI |
No |
No |
No |
SIC-T1-F |
No |
No |
No |
SIC-8AS |
No |
Yes |
Yes |
SIC-16AS |
No |
Yes |
Yes |
SIC-1SAE |
No |
No |
No |
SIC-2SAE |
Yes |
Yes |
SIC-4SAE |
No |
Yes (a maximum number of 1 supported) |
SIC-1AM |
No |
No |
No |
SIC-1ADSL |
No |
No |
No |
SIC-1ADSL-I |
No |
No |
No |
SIC-1BS |
No |
No |
No |
SIC-2BS |
No |
No |
No |
SIC-1FXS |
No |
No |
Yes |
SIC-2FXS |
No |
No |
Yes |
SIC-1FXO |
No |
No |
Yes |
SIC-2FXO |
No |
No |
Yes |
SIC-2FXS1FXO |
No |
No |
Yes |
DSIC-4FXS1FXO |
No |
No |
No |
SIC-1BSV |
No |
No |
No |
SIC-2BSV |
No |
No |
No |
SIC-1VE1 |
No |
No |
No |
SIC-1VT1 |
No |
No |
No |
SIC-1VE1T1 |
No |
No |
No |
SIC-AP320 |
No |
SIC-3G-CDMA |
No |
SIC-3G-TD |
No |
SIC-3G-HSPA |
No |
SIC-4G-LTE-M |
No |
No |
Yes (supported only in slot 1) |
Yes (supported only in slot 3) |
SIC-D4G-CNDE |
No |
RT-SIC-5G |
No |
Yes (supported only in slots 1 and 3) |
SIC-CNDE |
No |
Yes (supported only in slots 2 and 4) (a maximum number of 1 supported) |
SIC-CNDE-SJK |
No |
SIC-4G-CNDE-SJK |
No |
SIC-D4G-CNDE-SJK |
No |
Table 2 SIC/DSIC compatibility with H3C ICG information communication gateways (2)
SIC/DSIC model |
ICG3000G |
ICG 5000G |
ICG 5000T |
SIC-4FSW |
No |
SIC-4FSWP |
No |
No |
DSIC-9FSW |
No |
No |
DSIC-9FSWP |
No |
No |
SIC-4GSW |
SIC-4GSWF |
SIC-1FEA |
No |
SIC-1FEF |
No |
SIC-1GEC-V2 |
No |
SIC-E1-F |
Yes |
Yes |
SIC-2E1-F |
SIC-1EPRI |
No |
Yes |
SIC-T1-F |
No |
Yes |
Yes |
SIC-8AS |
Yes |
Yes |
Yes |
SIC-16AS |
Yes |
Yes |
Yes |
SIC-1SAE |
No |
Yes |
Yes |
SIC-2SAE |
Yes |
Yes |
SIC-4SAE |
Yes |
Yes |
SIC-1AM |
No |
Yes |
Yes |
SIC-1ADSL |
No |
SIC-1ADSL-I |
No |
No |
SIC-1BS |
No |
Yes |
SIC-2BS |
No |
No |
Yes |
SIC-1FXS |
No |
Yes |
Yes |
SIC-2FXS |
No |
Yes |
Yes |
SIC-1FXO |
No |
Yes |
Yes |
SIC-2FXO |
No |
Yes |
Yes |
SIC-2FXS1FXO |
No |
Yes |
Yes |
DSIC-4FXS1FXO |
No |
No |
SIC-1BSV |
No |
Yes |
SIC-2BSV |
No |
No |
Yes |
SIC-1VE1 |
No |
No |
Yes |
SIC-1VT1 |
No |
No |
Yes |
SIC-1VE1T1 |
No |
Yes |
Yes |
SIC-AP320 |
No |
No |
No |
SIC-3G-CDMA |
No |
SIC-3G-TD |
No |
SIC-3G-HSPA |
No |
SIC-4G-LTE-M |
SIC-4G-CNDE |
No |
No |
SIC-D4G-CNDE |
No |
No |
RT-SIC-5G |
No |
No |
SIC-CNDE |
SIC-CNDE-SJK |
No |
No |
SIC-4G-CNDE-SJK |
No |
No |
SIC-D4G-CNDE-SJK |
No |
No |
HMIM/DHMIM purchase guide
IMPORTANT: · Layer 2 communication across slots that reside on the same device is supported only on the ICG 5000T or ICG 6000 information communication gateway installed with multiple HMIM-8GSW, HMIM-8GSWF, HMIM-24GSW, and HMIM-24GSWP Ethernet switching modules. · Only the ICG 5000G, ICG 5000T, and ICG 6000 information communication gateways support HMIM interface modules. · The PoE feature of a PoE interface module takes effect when the PoE interface module is installed on a PoE device. If installed on a non-PoE device, the PoE interface module can only be used as a Layer 2 forwarding interface module. |
Table 3 HMIM/DHMIM compatibility with H3C ICG information communication gateways (1)
HMIM/DHMIM model |
ICG 5000G |
ICG 5000T |
ICG 6000 |
HMIM-8GSW |
Yes |
Yes |
Yes (supported only in slots 1, 2, 5, 6, 7, and 8) |
HMIM-24GSW |
Yes (a maximum number of 6 supported) |
HMIM-24GSW-PoE |
No |
HMIM-2GEE |
Yes |
Yes |
Yes |
HMIM-4GEE |
Yes |
Yes |
Yes |
HMIM-8GEE |
Yes |
Yes |
Yes |
HMIM-2GEF |
Yes |
Yes |
Yes |
HMIM-4GEF |
Yes |
Yes |
Yes |
HMIM-8GEF |
Yes |
Yes |
Yes |
HMIM-8GSWF |
Yes |
Yes |
RT-HMIM-4XP |
No |
Yes |
Yes |
Yes |
Yes |
Yes |
HMIM-1POS |
Yes |
Yes |
Yes |
HMIM-1CPOS |
Yes |
Yes |
Yes |
HMIM-2CPOS |
Yes |
Yes |
Yes |
HMIM-1E1POS |
No |
No |
HMIM-1E1 |
Yes |
Yes |
Yes |
HMIM-2E1 |
Yes |
Yes |
Yes |
HMIM-4E1 |
Yes |
Yes |
Yes |
HMIM-1E1-F |
Yes |
Yes |
Yes |
HMIM-2E1-F |
Yes |
Yes |
Yes |
HMIM-4E1-F |
Yes |
Yes |
Yes |
HMIM-8E1 |
Yes |
Yes |
Yes |
HMIM-8E1-F |
Yes |
Yes |
Yes |
HMIM-2T1 |
Yes |
Yes |
Yes |
HMIM-4T1-F |
Yes |
Yes |
Yes |
HMIM-2E1T1 |
Yes |
Yes |
Yes |
HMIM-4E1T1 |
Yes |
Yes |
Yes |
HMIM-8E1T1 |
Yes |
Yes |
Yes |
HMIM-2E1T1-F |
Yes |
Yes |
Yes |
HMIM-4E1T1-F |
Yes |
Yes |
Yes |
HMIM-8E1T1-F |
Yes |
Yes |
Yes |
HMIM-1CE3 |
Yes |
Yes |
Yes |
HMIM-2SAE |
Yes |
Yes |
Yes |
HMIM-4SAE |
Yes |
Yes |
Yes |
HMIM-8SAE |
Yes |
Yes |
Yes |
HMIM-8ASE |
Yes |
Yes |
Yes |
HMIM-16ASE |
HMIM-16FXS |
HMIM-8FXS8FXO |
HMIM-2VE1 |
HMIM-2VT1 |
HMIM-1VE1 |
HMIM-1VT1 |
HMIM-4FXS |
Yes |
Yes |
Yes |
HMIM-4FXO |
Yes |
Yes |
Yes |
HMIM-4E&M |
Yes |
Yes |
Yes |
HMIM-6AM |
Yes |
Yes |
Yes |
HMIM-6FCM |
Yes |
Yes |
Yes |
DHMIM-1DM |
No |
No |
DHMIM-1E1POS1DM |
No |
No |
VPM purchase guide
Table 4 VPM compatibility with H3C ICG information communication gateways
VPM model |
ICG 5000T |
ICG 6000 |
VPM2 512 |
Yes |
Yes |
VPM2 256 |
Yes |
Yes |
VPM2 128 |
Yes |
Yes |
