H3C ICG Information Communication Gateways Interface Module Guide (Comware 7)-6W100
HomeSupportICGICG 2000 Gateway SeriesProduct LiteratureHardware Information & SpecificationsH3C ICG Information Communication Gateways Interface Module Guide (Comware 7)-6W100
01-Text
01-Text 6.03 MB
1 SICs/DSICs· 1
Ethernet switching modules· 1
SIC-4FSW/SIC-4FSWP/DSIC-9FSW/DSIC-9FSWP· 1
SIC-4GSW·· 3
SIC-4GSWF· 4
Ethernet interface modules· 5
SIC-1FEA· 5
SIC-1FEF· 6
SIC-1GEC-V2· 7
E1/T1 interface modules· 8
SIC-E1-F· 9
SIC-2E1-F· 10
SIC-1EPRI 11
SIC-T1-F· 12
Serial interface modules· 13
SIC-8AS· 13
SIC-16AS· 14
SIC-1SAE/SIC-2SAE/SIC-4SAE· 15
Analog modem interface modules· 16
SIC-1AM·· 16
XDSL interface modules· 17
SIC-1ADSL· 18
SIC-1ADSL-I 19
ISDN BRI interface modules· 20
SIC-1BS/SIC-2BS· 20
Voice interface modules· 21
SIC-1FXS/SIC-1FXO/SIC-2FXS/SIC-2FXO·· 22
SIC-2FXS1FXO·· 23
DSIC-4FXS1FXO·· 24
SIC-1BSV/SIC-2BSV· 25
SIC-1VE1· 27
SIC-1VT1· 28
SIC-1VE1T1· 29
WLAN interface modules· 30
SIC-AP320· 30
3G interface modules· 31
SIC-3G-CDMA· 32
SIC-3G-TD·· 33
SIC-3G-HSPA· 34
4G interface modules· 36
SIC-4G-LTE-M·· 36
SIC-4G-CNDE· 38
SIC-D4G-CNDE· 40
5G interface modules· 43
RT-SIC-5G·· 43
Network data encryption modules· 45
SIC-CNDE· 46
SIC-CNDE-SJK· 46
SIC-4G-CNDE-SJK· 47
SIC-D4G-CNDE-SJK· 49
2 HMIMs/DHMIMs· 52
Ethernet switching modules· 52
HMIM-8GSW/HMIM-24GSW/HMIM-24GSW-PoE· 52
HMIM-8GSWF· 53
Ethernet interface modules· 54
HMIM-2GEE/HMIM-4GEE/HMIM-8GEE· 55
HMIM-2GEF/HMIM-4GEF/HMIM-8GEF· 56
RT-HMIM-4XP· 57
ATM interface modules· 58
HMIM-1ATM-OC3· 58
POS (SDH/SONET) interface modules· 59
HMIM-1POS· 59
CPOS (SDH/SONET) interface modules· 60
HMIM-1CPOS/HMIM-2CPOS· 60
E1/T1 interface modules· 62
HMIM-1E1/HMIM-2E1/HMIM-4E1/HMIM-1E1-F/HMIM-2E1-F/HMIM-4E1-F· 62
HMIM-8E1/HMIM-8E1-F· 64
HMIM-2T1/HMIM-4T1-F· 65
HMIM-2E1T1/HMIM-4E1T1/HMIM-8E1T1/HMIM-2E1T1-F/HMIM-4E1T1-F/HMIM-8E1T1-F· 67
E3/T3 interface modules· 69
HMIM-1CE3· 69
Serial interface modules· 70
HMIM-2SAE/HMIM-4SAE/HMIM-8SAE· 71
HMIM-8ASE/HMIM-16ASE· 72
POS terminal access interface modules· 73
HMIM-1E1POS· 73
DHMIM-1E1POS1DM·· 75
Digital modem interface modules· 77
DHMIM-1DM·· 77
Voice interface modules· 78
HMIM-16FXS· 78
HMIM-8FXS8FXO·· 79
HMIM-2VE1· 80
HMIM-2VT1· 81
HMIM-1VE1· 82
HMIM-1VT1· 83
HMIM-4FXS/HMIM-4FXO·· 84
HMIM-4E&M·· 85
Analog modem modules· 86
HMIM-6AM·· 86
HMIM-6FCM·· 87
3 VPMs· 89
Voice co-processing modules/Voice processing modules· 89
VPM purchase guide· 89
Introduction· 89
Interface specifications· 89
Installing and removing a VPM·· 89
4 Cables and the connection methods· 90
Ethernet interface· 90
Fiber port 91
E1 interface· 92
T1 interface· 99
E3/T3 interface· 100
Synchronous/asynchronous serial ports· 100
Asynchronous serial ports· 102
ADSL/BS/FXS/FXO/AM/FCM interface· 106
E&M interface· 107
BSV/BSE interface· 108
GPS interface· 110
WLAN interface· 111
3G interface· 112
4G interface· 113
5G interface· 115
5 Link mode of interfaces on Ethernet switching modules and interface modules  118
1 SICs/DSICs
H3C ICG information communication gateways use modular design and support a wide range of optional smart interface cards (SICs) and double smart interface cards (DSICs). A SIC occupies one SIC slot and a DSIC occupies two SIC slots. The SIC/DSIC series interface modules provide abundant interfaces, including synchronous/asynchronous serial interface, Ethernet interface, E1/T1, ISDN BRI/PRI, ADSL, audio interface, and Layer 2 switching interface.
·     SIC-4FSW
·     SIC-4FSWP
·     DSIC-9FSW
·     DSIC-9FSWP
·     SIC-4GSW
·     SIC-4GSWF
Introduction
The SIC-4FSW/SIC-4FSWP and DSIC-9FSW/DSIC-9FSWP interface modules are 4/9-port 10/100 Mbps Ethernet Layer 2 SIC interface modules that can be used on H3C ICG information communication gateways. They provide up to 4/9 10/100BASE-Tx Ethernet ports for Layer 2 and Layer 3 switching. An ICG installed with SIC-4FSW/SIC-4FSWP and DSIC-9FSW/DSIC-9FSWP modules can work as a switching/routing integrated device on a small-sized enterprise network to connect PCs and network devices inside the network directly. SIC-4FSWP/DSIC-9FSWP interface modules can supply power to powered devices (PDs) through power over Ethernet (PoE).
Functions supported by interface modules are as follows:
·     Effective transmission distance of 100 m (328.08 ft) with category-5 twisted pair cables (both crossover and straight-through)
·     Effective transmission distance of 100 m (328.08 ft) between any interfaces with category-5 twisted pair cables (both crossover and straight-through)
·     Operating speeds of both 10 Mbps and 100 Mbps and autosensing
·     Both full duplex (in common use) and half-duplex operating modes
Table1-1 describes the interface specifications of the SIC-4FSW, SIC-4FSWP, DSIC-9FSW, and DSIC-9FSWP interface modules. For information about link mode of the interfaces, see "Link mode of interfaces on Ethernet switching modules and interface modules."
Table1-1 Interface specifications
Item
SIC-4FSW/SIC-4FSWP
Connector
RJ-45
Interface type
MDI/MDIX
Number of connectors
4
9
Cable
Standard (straight-through)/cross-over Ethernet cable
Operation mode
10/100 Mbps autosensing, full/half duplex
Ethernet interfaces on network adapters are usually medium dependent interfaces (MDIs). Medium dependent interfaces crossover (MDIXs) are another type of Ethernet interfaces, which are usually used on hubs and LAN switches.
Interface LEDs
Figure1-1 SIC-4FSW panel
SIC-4FSW
Figure1-2 SIC-4FSWP panel
SIC-4FSW-POE
Figure1-3 DSIC-9FSW panel
DSIC-9FSW+口
Figure1-4 DSIC-9FSWP panel
DSIC-9FSW-POE+口
On the panel, each port corresponds to one green LED. The following table describes the LEDs on the panel.
Table1-2 LED description
Status
Steady on
A link is present, but no data is being transmitted or received.
Off
No link is present.
Flashing
A link is present and data is being transmitted and received (ACT).
In addition, there is a PoE LED on each module, which is provided for the corresponding modules (SIC-4FSWP and DSIC-9FSWP) with the PoE function.
Interface cables and the connection methods
For more information about Ethernet interface cables and the connection methods, see "Ethernet interface."
SIC-4GSW
Introduction
The SIC-4GSW interface module is a 4-port 1000 Mbps Ethernet Layer 2 SIC interface module. The SIC-4GSW provides four 1000 Mbps RJ-45 ports. An ICG installed with SIC-4GSW modules can operate as a switching/routing integrated device on a small-sized enterprise network to connect PCs and network devices inside the network directly.
·     Effective transmission distance of 100 m (328.08 ft) over category-5 twisted pair cables (both crossover and straight-through)
·     Line rate of 1000 Mbps between any interfaces over category-5 twisted pair cables (both crossover and straight-through)
·     Autosensing operating speeds of 10 Mbps, 100 Mbps, and 1000 Mbps
·     Both full duplex (typically used) and half-duplex operating modes
Table1-3 describes the interface specifications of the SIC-4GSW interface module. For information about link mode of the interfaces, see "Link mode of interfaces on Ethernet switching modules and interface modules."
Table1-3 Interface specifications
Item
Connector
RJ-45
Interface type
MDI/MDIX
4
Cable
Operation mode
10/100/1000 Mbps autosensing
Interface LEDs
Figure1-5 SIC-4GSW panel
The SIC-4GSW interface module provides a double-color (green/yellow) LED for each port to indicate the operating status of the port.
Table1-4 LED description
Status
Off
No link is present.
Steady green
A 1000 Mbps link is present.
Flashing green
The port is sending and receiving data at 1000 Mbps.
Steady yellow
A 10/100 Mbps link is present.
Flashing yellow
The port is sending and receiving data at 10/100 Mbps.
For information about Ethernet interface cables and the connection methods, see "Ethernet interface."
SIC-4GSWF
Introduction
The 4-port 100/1000 Mbps Ethernet Layer 2/Layer 3 SIC interface module SIC-4GSWF provides four fiber ports. It is designed for switching/routing integrated devices on a small-sized enterprise network. You can use it to connect network devices inside the network.
The interface module has the following features:
·     Support for multiple 100/1000 Mbps transceiver modules.
·     1000/100 Mbps interface rate.
·     Full duplex operating mode.
Table1-5 describes the interface specifications of the SIC-4GSWF interface modules. For information about link mode of the interfaces, see "Link mode of interfaces on Ethernet switching modules and interface modules."
Table1-5 Interface specifications
Item
Number of interfaces
4
Connector
SFP/LC
Standard
802.3/802.3u/802.3ab
Operating mode
100/1000 Mbps, full duplex
Interface LEDs
Figure1-6 SIC-4GSWF panel
Table1-6 LED description
Status
Off
No link is present.
Steady green
A link is present on the port and the port is operating at 1000 Mbps.
Flashing green
Steady yellow
A link is present on the port and the port is operating at 100 Mbps.
Flashing yellow
The port is sending and receiving data at 100 Mbps.
Transceiver modules, optical fibers, and connection methods
For more information about transceiver modules, optical fibers, and connection methods, see "Fiber port."
·     SIC-1FEA
·     SIC-1FEF
·     SIC-1GEC-V2
SIC-1FEA
Introduction
The 1-port 10BASE-T/100BASE-TX Ethernet interface module (SIC-1FEA) is used for communication between the ICG and LAN. It supports:
Table1-7 describes the interface specifications of the SIC-1FEA interface module. For information about link mode of the interfaces, see "Link mode of interfaces on Ethernet switching modules and interface modules."
Table1-7 Interface specifications
Item
Connector type
RJ-45
Interface type
MDI
1
Cable type
Straight-through Ethernet cable
Operating mode
Full duplex/half duplex
Interface LEDs
Figure1-7 SIC-1FEA panel
SIC-1FEA
Table1-8 LED description
LED
LINK
·     Off: No link is present.
·     On: A link is present.
ACT
·     Off: No data is being transmitted or received.
·     Flashing: Data is being received or/and transmitted.
For more information about the Ethernet interface cables and the connection methods, see "Ethernet interface".
SIC-1FEF
Introduction
The 1-port 100 Mbps fiber Ethernet interface module (SIC-1FEF) is used for the communication between the ICG and LAN.
SIC-1FEF supports:
·     Various types of transceiver modules.
·     100 Mbps interface rate.
·     Full duplex.
Table1-9 describes the interface specifications of the SIC-1FEF interface module. For information about link mode of the interfaces, see "Link mode of interfaces on Ethernet switching modules and interface modules."
Table1-9 Interface specifications
Item
1
Connector
SFP/LC
Interface standard
802.3, 802.3u, and 802.3ab
Operating mode
100 Mbps
Full duplex
Interface LEDs
Figure1-8 SIC-1FEF panel
SIC-1FEF
Table1-10 LED description
LED
Status
LINK/ACT
Off
No link is present.
Steady green
The transceiver module has established a 100 Mbps link.
Flashing green
Data is being received and transmitted.
Steady yellow
Information detection failed.
SIC-1GEC-V2
Introduction
The 1-port 10/100/1000 Mbps electrical and fiber Ethernet interface SIC module (SIC-1GEC-V2) has the following functions:
·     Receipt, transmission and processing of GE data stream
·     CE electrical and fiber port access
·     10/100/1000 Mbps on copper port
·     1000 Mbps on fiber port
Table1-11 describes the interface specifications of the SIC-1GEC-V2 interface module. For information about link mode of the interfaces, see "Link mode of interfaces on Ethernet switching modules and interface modules."
Table1-11 Interface specifications
Item
Connector
RJ-45
Interface type
MDI
Frame format
·     Ethernet_II
·     Ethernet_SNAP
·     IEEE 802.2
·     IEEE 802.3
Operation mode
Full/half duplex
The SIC-1GEC-V2 provides combo interfaces. The fiber and copper ports of a combo interface cannot be used simultaneously. By default, the copper port is available. To use the fiber port, execute the related command.
Interface LEDs
Figure1-9 SIC-1GEC-V2 panel
Table1-12 LED description for the copper port on the SIC-1GEC-V2 panel
LED
LINK
·     On: A carrier signal is received.
·     Off: No carrier signal is received.
·     Green: Data is being received and transmitted at 1000 Mbps.
·     Yellow: Data is being received and transmitted at 10/100 Mbps.
ACT
·     Off: No data is being received or transmitted.
·     Flashing: Data is being received and transmitted.
Table1-13 LED description for the fiber port on the SIC-1GEC-V2 panel
LED
LINK
·     Yellow: Fault.
ACT
For information about transceiver modules, optical fibers, and the connection methods, see "Fiber port."
·     SIC-E1-F
·     SIC-2E1-F
·     SIC-1EPRI
·     SIC-T1-F
SIC-E1-F
Introduction
The 1-port fractional E1 interface module (SIC-E1-F) supports:
·     Transmission/Receiving and handling of E1 data streams
·     CE1 (channelized E1) access
·     Remote loopback and local loopback functions, facilitating fault test and location.
The timeslots on an interface in FE1 mode on the SIC-E1-F can be bundled to form one interface (namely, can be bundled into one channel, and the rate of the interface is n No 64 kbps, where n ranges from 1 to 31.)
The SIC-E1-F does not support the PRI mode.
Table1-14 Interface specifications
Item
Connector type
DB15
1
Interface standard
·     G.703
·     G.704
Interface rate
2.048 Mbps
Cable type
75-ohm unbalanced coaxial cable (DB15 to BNC)
Operating modes
·     E1
·     CE1
Supported services
·     Backup
·     Terminal access
Interface LEDs
Figure1-10 SIC-E1-F panel
Table1-15 LED description
LED
LINK/ACT
·     Flashing: Data is being transmitted or received.
LP/AL
·     On: The interface is in loopback mode.
·     Flashing: An alarm indication signal (AIS), loss of frame alignment (LFA), or remote alarm indication (RAI) alarm has occurred.
·     Off: Neither loopback nor alarm is present.
For more information about E1 interface cables and the connection methods, see "E1 interface."
SIC-2E1-F
Introduction
The 2-port fractional E1 interface module (SIC-2E1-F), where F indicates fractional, supports:
Table1-16 Interface specifications
Item
Connector type
DB15
1
Interface standard
·     G.703
·     G.704
Interface rate
2.048 Mbps
Cable type
Operating modes
·     E1
·     CE1
Supported services
·     Backup
·     Terminal access
Interface LEDs
Figure1-11 SIC-2E1-F panel
Table1-17 LED description
LED
LINK/ACT
LP/AL (left)
·     Flashing: An AIS, LFA, or RAI alarm has occurred.
·     Off: Neither loopback nor alarm is present on the interface.
For more information about E1 interface cables and the connections methods, see "E1 interface."
SIC-1EPRI
Introduction
The SIC-1EPRI is a 1-port E1/CE1/PRI SIC interface module that provides the following features:
·     Transmission/Receiving and handling of E1 data streams.
·     CE1 (channelized E1) access.
·     ISDN PRI function.
You can use the module for multiple purposes through different configurations.
Table1-18 Interface specifications
Item
Connector type
DB15
1
Interface standard
·     G.703
·     G.704
Interface rate
2.048 Mbps
Cable type
·     75-ohm unbalanced coaxial cable (DB15 to BNC)
·     Coaxial connector, network interface connector, and 75-ohm to 120-ohm adapter
The default resister for the interface on the SIC-1EPRI is 75 ohm. A 75-ohm to 120-ohm adapter must be used when a 120-ohm cable is connected to the SIC-1EPRI.
Operating mode
·     E1
·     CE1
·     ISDN PRI
Supported service
·     Backup
·     Terminal access
·     ISDN
Interface LEDs
Figure1-12 SIC-1EPRI panel
Table1-19 LED description
LED
LINK/ACT
LP/AL
SIC-T1-F
Introduction
1-port Fractional T1 interface card (SIC-T1-F) has the following features:
·     The timeslots on an interface in FT1 mode on the SIC-T1-F can be bundled to form one interface (namely, can be bundled into one channel, and the rate of the interface is n No 56 kbps, where n ranges from 1 to 24.).
·     The SIC-T1-F does not support the PRI mode.
Table1-20 Interface specifications
Item
Connector type
RJ-45
1
Interface standard
·     G.703/T1.102
·     G.704
·     ANSI T1.403
Interface rate
1.544 Mbps
Cable type
T1 cable (100-ohm standard shielded network cable)
Operating mode
FT1
Supported service
·     Backup
·     Terminal access
Interface LEDs
Figure1-13 SIC-T1-F panel
SIC-1T1-F
Table1-21 LED description
LED
LINK/ACT
·     Flashing: Data is being transmitted or/and received.
LP/AL
·     Off: No loopback or alarm is present.
For more information about T1 interface cables and the connection methods, see "T1 interface."
·     SIC-8AS
·     SIC-16AS
·     SIC-1SAE
·     SIC-2SAE
·     SIC-4SAE
SIC-8AS
Introduction
The 8-port asynchronous serial interface module (SIC-8AS) mainly transmits and processes asynchronous data streams.
SIC-8AS has these features:
·     Each asynchronous serial port provides a rate up to 115.2 kbps.
·     Supports the terminal access service and asynchronous leased line.
·     Serves as the small-/medium-sized ISP dial-up access server when an asynchronous serial port is used for dial-up.
Table1-22 Interface specifications
Item
Connector
DB60
1
Interface cable
Customized cable with 8-port RJ-45 connector
Interface standard
RS-232
Minimum baud rate
300 bps
Maximum baud rate
115.2 kbps
Supported services
·     Modem dial-up
·     Backup
·     Terminal access service
·     Asynchronous leased line
Interface LEDs
Figure1-14 SIC-8AS front panel
SIC-8AS+口
Table1-23 LED description
LED
LINK/ACT
For more information about asynchronous serial port cables and the connection methods, see "Asynchronous serial ports."
SIC-16AS
Introduction
The 16-port asynchronous serial interface module (SIC-16AS) mainly transmits and processes asynchronous data streams.
SIC-16AS features the following:
·     Each asynchronous serial port provides a rate of up to 115.2 kbps.
Table1-24 Interface specifications
Item
Connector
D28 (male)
1
Interface cable
Customized cable with 16-port RJ-45 connector (female)
Interface standard
RS-232
Minimum baud rate
300 bps
Maximum baud rate
115.2 kbps
Supported services
·     Modem dial-up
·     Backup
Interface LEDs
Figure1-15 SIC-16AS panel
SIC-16AS
Table1-25 LED description
LED
LINK/ACT
Introduction
The SIC-1SAE/SIC-2SAE/SIC-4SAE is a 1-port/2-port/4-port enhanced high-speed synchronous/asynchronous serial interface module.
Table1-26 Interface specifications
Item
Synchronous
Asynchronous
Connector
D28
·     1 (SIC-1SAE)
·     2 (SIC-2SAE)
·     4 (SIC-4SAE)
Interface standard and operating mode
V.24
·     V.35
·     RS449
·     X.21
·     RS-530
RS-232
·     DTE
·     DCE
·     DTE
·     DCE
Minimum baud rate
(bps)
1200
1200
300
Maximum baud rate
(bps)
64000
2048000
115200
Cable
·     V.24 DTE cable
·     V.24 DCE cable
·     V.35 DTE cable
·     V.35 DCE cable
·     X.21 DTE cable
·     X.21 DCE cable
·     RS449 DTE cable
·     RS449 DCE cable
·     RS530 DTE cable
·     RS530 DCE cable
Supported service
·     DDN leased line
·     Dialup through modems
·     Backup
·     Terminal access
Interface LEDs
Figure1-16 SIC-1SAE panel
SIC-1SAE+口
Figure1-17 SIC-2SAE panel
Figure1-18 SIC-4SAE panel
Table1-27 LED description
LED
LINK
ACT
For more information about synchronous/asynchronous serial port cables and the connection methods, see "Synchronous/asynchronous serial ports."
·     SIC-1AM
SIC-1AM
Introduction
The 1-port analog modem interface module (SIC-1AM) integrates the functions of asynchronous interface and external modem, that is, allowing one channel of remote modem subscribers to directly access the ICG. They support:
·     Data rate of 56 kbps.
·     Accessing and handling analog signals and transmitting the processed data to the ICG host through the serial interface bus. And also, processing the data received from the host and then transmitting them to the PSTN via the telephone port.
Table1-28 Interface specifications
Item
Connector type
RJ-11
1 (SIC-1AM)
Cable type
Telephone cable with ferrite core
Maximum speed
56 kbps
Supported standard
·     ITU-T V.90
·     K56flex
·     V.34 (33.6 kbps)
·     V.FC
·     V.32 bis
·     V.32
·     V.22 bis
·     V.22A/B
·     V.23
·     V.21
·     Bell 212A a
·     Bell 103
Supported service
Modem dial-up
Interface LEDs
Figure1-19 SIC-1AM panel
Table1-29 LED description
LED
LINK
·     Off: The link is idle.
·     On: The connection has been established.
·     Flashing: The connection is being set up.
ACT
For more information about the Ethernet interface cables and the connection methods, see "ADSL/BS/FXS/FXO/AM/FCM interface."
·     SIC-1ADSL
·     SIC-1ADSL-I
SIC-1ADSL
Introduction
The 1-port ADSL over PSTN interface module (SIC-1ADSL) provides an RJ-11 interface that can work as a WAN interface. It allows a LAN subscriber to connect to the digital subscriber's loop access multiplexer (DSLAM) at the central office over a regular analog subscriber line or telephone line. Thus, the subscriber can access the ATM/IP backbone or the Internet to enjoy services such as high-speed data communication and video on demand (VoD).
ADSL transmits data in the high frequency band above 26 kHz. Therefore, it can provide services without interfering with the voice service being provided in the low frequency band (0 to 4 kHz) on the same line. It provides downlink rates in the range 32 kbps to 8 Mbps and uplink rates in the range 32 kbps to 1 Mbps.
The SIC-1ADSL delivers these features:
·     Manual ADSL line activation and deactivation, providing a convenient fault location means.
·     Interface standards of G. DMT, G. Lite, and T1.413, autosensing.
·     Trellis coding (except for G. Lite) on ADSL interfaces, enhancing the stability of ADSL connection.
Table1-30 Interface specifications
Item
Connector
RJ-11
1
Interface rate
·     In ADSL full rate mode (ITU-T 992.1 G.DMT/ANSI T1.413):
¡     8 Mbps (downlink rate)
¡     1024 kbps (uplink rate)
·     In ADSL Lite mode (ITU-T 992.2 G.Lite):
¡     64 kbps to 1 Mbps (downlink rate)
¡     64 kbps to 512 kbps (uplink rate)
·     In ADSL2+ full rate mode (ITU-T 992.5):
¡     24 Mbps (downlink rate)
Interface standard
·     ITU-T 992.1 G.DMT
·     ITU-T 992.2 G.Lite
·     ANSI T1.413 Issue 2
·     ITU-T 992.3
·     ITU-T 992.5
Cable
Telephone cable
Supported service
ADSL over the regular telephone line
Maximum received and sent frame
1700 bytes
Interface LEDs
Figure1-20 SIC-1ADSL panel
SIC-1ADSL
Table1-31 LED description
LED
LINK
·     Off: The loop is inactive.
·     On: The loop has been activated and has entered the data mode
·     Flashing: The loop is being activated.
ACT
For more information about ADSL interface cables and the connection methods, see "ADSL/BS/FXS/FXO/AM/FCM interface."
SIC-1ADSL-I
Introduction
The 1-port ADSL over ISDN interface module (SIC-1ADSL-I) uses the RJ-11 connector for the WAN interface. It allows a LAN subscriber to connect to the DSLAM at the central office over a regular analog subscriber line or telephone line. Thus, the subscriber can access the ATM/IP backbone or the Internet to enjoy services such as high-speed data communication and video on demand (VoD).
The module transmits data in the high frequency band above 138 kHz. Therefore, it can provide services on the same line without interfering with the ISDN service being provided on the same line. It provides downlink rates in the range 32 kbps to 8 Mbps and uplink rates in the range 32 kbps to 1 Mbps.
The SIC-1ADSL-I interface module delivers these features:
·     A G.992.1-compliant interface, autosensing
·     Trellis coding on ADSL interfaces, enhancing the stability of ADSL connection
Table1-32 Interface specifications
Item
Connector
RJ-11
1
Interface rate
Interface standard
·     ITU-T 992.1 G.DMT
·     ITU-T 992.3
·     ITU-T 992.5
Interface rate
·     Downlink: 8 Mbps
·     Uplink: 1024 kbps
Interface cable
Regular telephone cable
Supported services
ADSL over ISDN
1700 bytes
Interface LEDs
Figure1-21 SIC-1ADSL-I panel
SIC-1ADSL-I-新+口
Table1-33 LED description
LED
LINK
ACT
·     SIC-1BS
·     SIC-2BS
SIC-1BS/SIC-2BS
Introduction
The 1/2-port ISDN BRI S/T interface module (SIC-1BS/SIC-2BS) is mainly used to transmit, receive, and process ISDN BRI S/T traffic flows.
The SIC-1BS/SIC-2BS has two operating modes: dial-up and leased line.
Table1-34 Interface specifications
Item
Connector
RJ-45 (SIC-1BS/SIC-2BS)
·     1 (SIC-1BS)
·     2 (SIC-2BS)
Cable type
Interface standard
·     ITU-T I.430
·     Q.921
·     Q.931
Operating mode
·     ISDN dial-up
·     ISDN leased line
Supported services
·     ISDN
·     ISDN supplementary services
·     Multi-subscriber number
·     Sub-address
·     Backup
Interface LEDs
Figure1-22 SIC-1BS panel
Figure1-23 SIC-2BS panel
Table1-35 LED description
LED
B1
·     Off: The B1 channel is idle.
·     Flashing: The B1 channel is being used for data communication.
B2
·     Off: The B2 channel is idle.
ACT
·     Off: The inactive state.
·     Steady on: The active state.
ON
·     Off: The interface module is powered off.
·     On: The interface module is powered on.
For more information about BS interface cables and the connection methods, see "ADSL/BS/FXS/FXO/AM/FCM interface."
·     SIC-1FXS
·     SIC-1FXO
·     SIC-2FXS
·     SIC-2FXO
·     SIC-2FXS1FXO
·     DSIC-4FXS1FXO
·     SIC-1BSV
·     SIC-2BSV
·     SIC-1VE1
·     SIC-1VT1
·     SIC-1VE1T1
Introduction
The 1/2-port voice subscriber circuit interface module (SIC-1FXS/SIC-2FXS) and 1/2-port voice AT0 analog trunk interface module (SIC-1FXO/SIC-2FXO) serve to access and handle 1/2 channel(s) of analog voice signals over data communication networks. The differences between SIC-FXS and SIC-FXO are listed below:
·     SIC-FXS modules are analog subscriber line modules that provide ordinary analog telephone and fax access and also can connect AT0 loop trunks of exchanges.
·     SIC-FXO modules are loop trunk modules that provide access of common subscriber lines of exchanges.
Table1-36 Interface specifications
Item
Connector type
RJ-11
·     1 (SIC-1FXS/SIC-1FXO)
·     2 (SIC-2FXS/SIC-2FXO)
Interface standard
·     Subscriber circuit interface (SIC-1FXS/SIC-2FXS) compliant with ITU Q.512.
·     Loop trunk interface (SIC-1FXO/SIC-2FXO) compliant with ITU Q.552.
·     Over-current and over-voltage protection compliant with ITU K.20
Cable type
Telephone cable with ferrite core.
Dialing mode
Supports DTMF, not supports pulse dial-up.
Bandwidth
300 Hz to 3400 Hz
Interface LEDs
Figure1-24 SIC-1FXS panel
SIC-1FXS
Figure1-25 SIC-1FXO panel
SIC-1FXO
Figure1-26 SIC-2FXS panel
SIC-2FXS
Figure1-27 SIC-2FXO panel
SIC-2FXO
Table1-37 LED description
LED
LINK
·     On: The link is being occupied for call connection.
ACT
·     On: The link is being occupied for communication.
·     Flashing: If the ACT LED flashes during startup of the ICG, the module hardware is faulty. Please replace the module.
For more information about FXS/FXO interface cables and the connection methods, see "ADSL/BS/FXS/FXO/AM/FCM interface."
SIC-2FXS1FXO
Introduction
The 2-port analog subscriber circuit interface module and 1-port voice AT0 loop trunk interface module (SIC-2FXS1FXO) serve to access and handle three channels of analog voice signals over data communication networks. Two FXS interfaces and one FXO interface are available on a SIC-2FXS1FXO module:
·     FXS interfaces are analog subscriber line interfaces that provide ordinary analog telephone and fax access and also can connect AT0 loop trunks of exchanges.
·     FXO interfaces are loop trunk interfaces that provide access of common subscriber lines of exchanges.
Table1-38 Interface specifications
Item
Connector type
RJ-11
2 FXS interfaces
1 FXO interface
Interface standard
·     Supports subscriber circuit interface (FXS), compliant with ITU Q.512
·     Supports loop trunk interface (FXO), compliant with ITU Q.552
Cable type
Dial-up mode
Supports DTMF, compliant with GB3378, but does not support pulse dial-up.
Bandwidth
300 Hz to 3400 Hz
Interface LEDs
Figure1-28 SIC-2FXS1FXO panel
SIC-2FXS1FXO+口
Table1-39 LED description
LED
LINK/ACT
·     Steady green: The link is being occupied for call connection.
·     Flashing yellow: The link is being occupied for communication.
DSIC-4FXS1FXO
Introduction
The 4-port analog subscriber circuit interface module and 1-port voice AT0 loop trunk interface module (DSIC-4FXS1FXO) serve to access and handle five channels of analog voice signals over data communication networks.
Table1-40 Interface specifications
Item
Connector type
RJ-11
4 FXS interfaces
1 FXO interface
Interface standard
Cable type
Dial-up mode
Bandwidth
300 Hz to 3400 Hz
Interface LEDs
Figure1-29 DSIC-4FXS1FXO panel
DSIC-4FXS1FXO+口
Table1-41 LED description
LED
LINK/ACT
SIC-1BSV/SIC-2BSV
Introduction
The 1/2-port ISDN BRI S/T voice interface module (SIC-1BSV/SIC-2BSV) is mainly used to process (receive/transmit and compress/decompress) the ISDN interface voice traffic. The interface(s) on the SIC-1BSV/SIC-2BSV module is (are) ITU-T I.430-compliant, adopting pseudo-ternary coding, providing 192 kbps interface rate, and allowing the maximum transmission distance of 1 km (0.6 miles) in point-to-point mode. In the upstream direction, the SIC-1BSV/SIC-2BSV module can be connected to a user interface on an ISDN switch to receive and decompress, compress and transmit ISDN BRI digital voice traffic. In the downstream direction, the module can be connected to a TE device to forward the voice packets from the TE device to the Internet through a WAN interface on the ICG, thus implementing VoIP. The module has the following features.
·     A BSV interface supports two modes: user and network, respectively for connecting an ISDN network and a TE device.
·     When a BSV interface works in network mode, traffic is processed as follows: The digital voice traffic received on the BSV interface is compressed and forwarded through the CPU on the main control board to a WAN interface. The IP voice traffic received on a WAN interface is forwarded through the CPU on the main control board to SIC-1BSV/SIC-2BSV, where the traffic is decompressed and sent to the TE device.
·     When a BSV interface works in user mode, traffic is processed as follows: The digital voice traffic received from the B channels on the BSV interface is decompressed and forwarded through the CPU on the main control board to a local FXS or FXO analog voice interface. The voice signals received on the local FXS or FXO analog voice interface are processed by VoIP and forwarded through the CPU on the main control board to SIC-1BSV/SIC-2BSV, where the traffic is compressed and sent out of the BSV interface to the ISDN switch.
·     Working in conjunction with the FXS or FXO analog voice interface modules, SIC-2BSV provides flexibility in voice call routing.
·     The ISDN BRI D channel signaling is processed separately on CPU.
·     A BSV interface supports remote power supply and thus can be connected directly to an ISDN phone, saving extra power supply device.
·     The SIC-1BSV/SIC-2BSV is dedicated to voice applications, which is different from the BS interface modules where BRI data applications are supported.
Table1-42 Interface specifications
Item
SIC-1BSV
SIC-2BSV/
Connector
RJ-45
1
2
Interface standard
·     ITU-T I.430
·     Q.921
·     Q.931
Interface rate
192 kbps
Cable
ISDN S interface cable
Supported service
Voice access over ISDN S interface cable
Interface LEDs
Figure1-30 SIC-1BSV panel
SIC-1BSV
Figure1-31 SIC-2BSV panel
SIC-2BSV
Table1-43 LED description
LED
B1
Green
Flashing indicates data is being transmitted or received on B1 channel.
B2
Green
Flashing indicates data is being transmitted or received on B2 channel.
ACT
Yellow
·     Flashing indicates the link is being activated.
·     Steady on indicates the link is active.
ON
Green, power LED.
Steady on indicates the module is powered on.
For more information about BSV interface cables and the connection methods, see "BSV/BSE interface."
SIC-1VE1
Introduction
The 1-port E1 voice interface module (SIC-1VE1) can handle dense voice signals in VoIP system. It provides a CE1/PRI/R2 port, allowing the access of 30 channels of voice signals.
Table1-44 Interface specifications
Item
Connector
DB15
Number of connector
1
Interface standard
G.703, G.704
Interface rate
2.048 Mbps
Cable type
·     120-ohm balanced twisted pair cable
·     Coaxial connector, network interface connector and 75-ohm to 120-ohm adapter (with BNC connector)
Operation mode
CE1
ISDN PRI (only supported by SIC-1VE1)
R2
Services
·     Backup
·     Terminal access
·     ISDN (only supported by SIC-1VE1)
Interface LEDs
Figure1-32 SIC-1VE1 panel
SIC-1VE1面板
Table1-45 LED description
LED
LINK
ACT
SIC-1VT1
Introduction
The 1-port T1 voice interface module (SIC-1VT1) can handle dense voice signals in VoIP system. It provides a CT1/PRI/R2 port, allowing the access of 23 channels of voice signals.
Table1-46 Interface specifications
Item
Connector
RJ-45
Number of connector
1
Interface standard
·     G.703/T1.102
·     G.704
·     AT & T TR 54016
·     AT & T TR 62411
·     ANSI T1.403
Interface rate
1.544 Mbps
Cable type
T1 cable (100-ohm standard shielded cable)
Operation mode
CT1
ISDN PRI
Services
Backup
Terminal access
ISDN
Interface LEDs
Figure1-33 SIC-1VT1 panel
SIC-1VT1面板
Table1-47 LED description
LED
LINK
ACT
SIC-1VE1T1
Introduction
The 1-port E1/T1 voice interface module SIC-1VE1T1 handles dense voice signals in VoIP and FoIP systems. The E1 module transmits, receives, and processes E1 voice signals. It allows the interface to operate in CE1 mode or ISDN PRI mode to process a maximum of 30 channels of voice signals. The T1 module transmits, receives, and processes T1 voice signals. It allows the interface to operate in CT1 mode or ISDN PRI mode to process a maximum of 23 channels of voice signals.
You can use command lines and a jumper to configure the interface as a 75-ohm E1 interface, 100-ohm T1 interface, or 120-ohm E1 interface. By default, the interface is a 75-ohm E1 interface.
·     To configure the interface as a 75-ohm E1 interface, connect the jumper to pins 1 and 2, pins 7 and 8, pins 11 and 12, and pins 13 and 14.
·     To configure the interface as a 100-ohm T1 or 120-ohm E1 interface, connect the jumper to pins 1 to 3, pins 5 to 7, pins 9 and 10, and pins 11 to 13.
Figure1-34 Jumper connecting methods
Table1-48 Interface specifications
Item
Specification
Connector
RJ-45
Number of connector
1
Interface standard
·     G.703
·     G.704
Interface rate
·     E1 interface: 2.048 Mbps
·     T1 interface: 1.544 Mbps
Cable type
·     E1 75-ohm coaxial cable
·     E1 120-ohm twisted pair cable: 2 m (6.56 ft), 15 m (49.21 ft), or 30 m (98.43 ft)
·     T1 100-ohm standard shielded cable
·     Coaxial connector, network interface connector, or 75-to-120-ohm adapter (with BNC connector)
Operating mode
·     E1
·     T1
·     CE1T1
·     ISDN PRI
Services
Backup
Terminal access
ISDN PRI
Interface LEDs
Figure1-35 SIC-1VE1T1 panel
Table1-49 LED description
LED
LINK/ACT
·     Steady green: Carrier signal has been received.
·     Flashing green at 4 Hz: Data is being transmitted or received.
·     Off: No carrier signals have been received.
LP/AL
·     Steady yellow: The interface is in loopback mode.
·     Flashing yellow at 0.5 Hz: An AIS, LFA, or RAI alarm has occurred.
Interface cables and connection methods
·     SIC-AP320
SIC-AP320
CAUTION
CAUTION:
Do not hot swap the SIC-AP320 WLAN interface module.
Introduction
The SIC-AP320 WLAN interface module receives and sends wireless data. Two external antennas can be installed on the module. The module supports the 802.11a/b/g/n/ac standard and can operate on both the 2.4 G and 5G frequency bands.
Table1-50 Interface specifications
Item
Connector
1 RJ-45 connector for the console port
Interface standard
Console port: RS/EIA-232
Radio interface: Radio 1 operates on the 5 GHz frequency band and supports the 2×2 MIMO technology. Radio 2 operates on the 2.4 GHz frequency band and support the 1×1 MIMO technology.
Cable type
Console cable for the console port
Interface LEDs
Figure1-36 SIC-AP320 panel
Table1-51 LED description
LED
SYS
·     Steady amber: The module is starting up.
·     Flashing green: Only the 2.4G radio has associated clients.
·     Flashing amber: Only the 5G radio has associated clients.
·     Flashing alternatively between amber and green: Both the 2.4G and 5G radios have associated clients.
For more information about WLAN interface cables and the connection methods, see "WLAN interface."
·     SIC-3G-CDMA
·     SIC-3G-TD
·     SIC-3G-HSPA
SIC-3G-CDMA
Introduction
The SIC-3G-CDMA module is used to access 3G WLANs. It supports:
·     CDMA 2000 1x RTT
·     1x EV-DO Rev.0
·     1x EV-DO Rev.A
Table1-52 Interface specifications
Item
Connector type
·     TNC RF: Antenna for accessing WLANs.
·     RJ-45: For connecting to a third-party WLAN debugging and testing software such as CAIT of Qualcomm.
·     2 × TNC RF
·     1 × RJ-45
Interface standard
·     TNC RF: Omni antenna, supporting CDMA 2000 1 No RTT, 1 No EV-DO Rev.0, 1 No EV-DO Rev.A.
·     RJ-45: RS-232
Cable type
·     TNC RF: None
·     RJ-45: AUX cable
Rates
Network standards:
·     1 No EV-DO Rev.A (Downlink: 3.1 Mbps, uplink: 1.8 Mbps)
·     1 No EV-DO Rev.0 (Downlink: 2.4 Mbps, uplink: 153.6 kbps)
·     1 No RTT (Downlink: 153.6 kbps, uplink: 153.6 kbps)
Services
·     CDMA 2000 1x RTT
·     1 No EV-DO Rev.0
·     1 No EV-DO Rev.A
Interface LEDs
Figure1-37 SIC-3G-CDMA panel
Table1-53 LED description
LED
WWAN
·     Steady green: A link is present.
·     Flashing green: Data is being transmitted or received.
RSSI
·     Steady green: Strong signal.
·     Flashing green: Middle or low signal.
·     Off: Weak signal or no signal.
1xRTT
·     Steady yellow: The service is valid.
·     Off: No service.
EVDO
·     Off: No service.
Antennas, interface cables, and the connection methods
For more information about SIC-3G-CDMA antennas, interface cables, and the connection methods, see "3G interface."
Installing a SIM card
CAUTION
CAUTION:
Make sure the beveled corner of the SIM card fits into the beveled corner of the SIM socket.
To installing a SIM card:
1.     Open the SIM card socket in the direction marked OPEN so the holder projects upwards.
2.     Insert the SIM card into the SIM card socket along the guide rails.
3.     Close the SIM card socket in the direction marked LOCK to lock the card in position.
4.     Execute the display cellular [ interface-number ] command after the ICG is started. When "SIM Status = OK" appears in the output information, the SIM card is identified.
SIC-3G-TD
Introduction
The SIC-3G-TD module provides access to 3 G WLANs. It supports the following features:
·     GPRS
·     EDGE
·     TD-SCDMA
·     HSDPA
Table1-54 Interface specifications
Item
Connector type
TNC RF: For connecting an antenna and accessing WLANs.
1 × TNC RF
1 × RJ-45
Interface standard
TNC RF: Omni antenna, supporting GPRS/EDGE/TD-SCDMA//HSDPA
RJ-45: RS-232
Cable type
TNC RF: None
RJ-45: AUX cable
Rates
·     HSDPA (downlink: 2.8 Mbps, uplink: 384 kbps)
·     TD-SCDMA (downlink: 384 kbps, uplink: 384 kbps)
·     EDGE (downlink: 236.8 kbps, uplink: 236.8 kbps)
·     GPRS (downlink: 85.6 kbps, uplink: 85.6 kbps)
Services
GPRS/EDGE/TD-SCDMA/HSDPA
Interface LEDs
Figure1-38 SIC-3G-TD panel
rtvm1std
Table1-55 LED description
LED
WWAN
RSSI
TD
·     Off: No service.
HSDPA
·     Off: No service.
For more information about SIC-3G-GSM antennas, interface cables, and the connection methods, see "3G interface."
CAUTION
CAUTION:
To install a SIM card:
SIC-3G-HSPA
Introduction
The SIC-3G-HSPA module serves to access 3G networks. It supports:
·     GPRS
·     EDGE
·     UMTS
·     HSDPA
·     HSUPA
Table1-56 Interface specifications
Item
Connector type
2 × TNC RF
1 × RJ-45
Interface standard
TNC RF: Omni antenna, supporting GPRS/EDGE/UMTS/HSDPA.
RJ-45: RS-232
Cable type
TNC RF: None
RJ-45: AUX cable
Rates
·     HSDPA (downlink: 7.2 Mbps)
·     HSUPA (uplink: 5.76 Mbps)
·     UMTS (downlink: 384 kbps, uplink: 384 kbps)
Services
GPRS/EDGE/UMTS/HSDPA/HSUPA
Supported wireless band
850/900/1900/2100 MHz WCDMA/HSDPA/HSUPA
850/900/1800/1900 MHz GPRS/EDGE
Interface LEDs
Figure1-39 SIC-3G-HSPA panel
SIC-3G-HSPA
Table1-57 LED description
LED
WWAN
RSSI
UMTS
·     Off: No service.
HSDPA
·     Off: No service.
CAUTION
CAUTION:
The 3G antenna provided with the SIC-3G-HSPA must be installed on the antenna port that has a MAIN mark.
For more information about SIC-3G-HSPA antennas, interface cables, and the connection methods, see "3G interface."
CAUTION
CAUTION:
·     SIC-4G-LTE-M
·     SIC-4G-CNDE
·     SIC-D4G-CNDE
SIC-4G-LTE-M
Introduction
The SIC-4G-LTE-M module provides 4G WLAN access and supports the following features:
·     LTE
·     UMTS
·     HSPA+
·     TD-SCDMA
·     CDMA2000 1xRTT
·     CDMA2000 1x-Ev-Do
·     Quad-Band EDGE
·     GPRS
·     GSM
Table1-58 Interface specifications
Item
Connector type
·     TNCFor accessing WLANs.
·     SMA—For accessing GPS.
·     Mini USB Type ABFor connecting to third-party WLAN debugging and testing software such as CAIT of Qualcomm.
·     2 × TNCs
·     1 × SMA
·     1 × Mini USB Type AB
Interface standard
·     TNCSupports LTE, UMTS, HSPA+, CDMA 1x, EV-DO Rev A, Quad-Band EDGE, GPRS, and GSM
·     SMAGPS
·     Mini USB Type ABRS-232
Cable type
·     SMAFlexible 174 sized cable
·     TNCNone
·     Mini USB Type ABUSB console cable
Services
·     LTE
·     UMTS
·     HSPA+
·     TD-SCDMA
·     CDMA2000 1xRTT
·     CDMA2000 1x-Ev-Do
·     Quad-Band EDGE
·     GPRS
·     GSM
Interface LEDs
Figure1-40 SIC-4G-LTE-M panel
Table1-59 LED description
LED
WWAN
·     Fast flashing green: Data is being transmitted or received.
·     Slowly flashing green: The module is searching for wireless networks.
RSSI
·     Steady green: Strong signal (RSSI ≥ –69 dBm).
·     Fast flashing green: Middle signal (–89 dBm ≤ RSSI < –69 dBm).
·     Slowly flashing green: Low signal (–99 dBm ≤ RSSI < –89 dBm).
·     Off: Weak signal or no signal (RSSI < –99 dBm).
HSPA+
·     Steady green: The HSPA+ service or HSDPA service is valid.
·     Flashing green: The EVDO service is valid.
·     Off: No service.
LTE
·     Steady green: The LTE service is valid.
·     Off: No LTE service.
GPS
·     Steady green: The GPS service is valid.
·     Off: No GPS service.
For more information about SIC-4G-LTE-M interface module antennas, interface cables, and the connection methods, see "4G interface."
CAUTION
CAUTION:
SIC-4G-CNDE
Introduction
The SIC-4G-CNDE module provides 4G WLAN access and supports the following technologies:
·     LTE-TDD
·     LTE-FDD
·     TD-SCDMA
·     UMTS
·     GSM
·     EVDO
·     CDMA1x
Table1-60 Interface specifications
Item
Connectors
3 × SMA connectors
Supported antenna types
·     GPS
·     Omnidirectional antenna, support for FDD-LTE/TDD-LTE/TD-SCDMA/UMTS/EDGE/GPRS/GSM/EVDO/CDMA
Technologies and supported frequency bands
·     LTE-TDD band 38/39/40/41
·     LTE-FDD band 1/3/5/7/8
·     TD-SCDMA band 34/39
·     UMTS band 1/8
·     GSM band 2/3/5/8
·     EVDO band BC0
·     CDMA1x band BC0
Interface LEDs
Figure1-41 SIC-4G-CNDE panel
Table1-61 LED description
LED
WWAN
RSSI
·     Steady yellow is reserved for future use.
LTE
·     Steady green: The 4G-LTE service is valid.
·     Flashing green (8 Hz): The high-speed 3G service such as DC-HSPA+, HSPA+, HSDPA, HSUPA, or EVDO is valid.
·     Steady yellow: The 2G or low-speed 3G service such as UMTS, TD-SCDMA, CDMA2000-1xRTT, EDGE, GPRS, or GSM is valid.
·     Flashing yellow is reserved for future use.
GPS
CNDE
·     Steady green: The module is operating correctly and is not sending or receiving data.
·     Flashing green: The module is operating correctly and is sending or receiving data.
·     Steady yellow: The module is faulty.
·     Off: No module is present.
For more information about SIC-4G-CNDE interface module antennas, interface cables, and the connection methods, see "4G interface" and "GPS interface."
Installing Micro SIM card
CAUTION
CAUTION:
Make sure the beveled corner of the Micro SIM card is oriented as indicated by the Micro SIM card icon.
The SIC-4G-CNDE interface module supports Micro SIM cards.
The SIC-4G-CNDE has two Micro SIM card slots, but only one is active at a time. If you install SIM cards in both slots, the SIM1 slot 1 is active, the SIM2 slot is in standby state by default. To perform an active/standby switchover, execute the sim switch-to command. For more information about the command, see H3C ICG Series Information Communication Gateways Comware 7 Layer 2—WAN Access Command Reference.
To install a Micro SIM card:
1.     Use a Phillips screwdriver to remove the two screws on the SIM card retainer cover.
2.     Lift the cover up and away from the retainer.
3.     Insert SIM cards into the SIM card slots on the retainer.
4.     Reattach the retainer cover and use the two screws to secure the cover.
5.     Execute the display cellular [ interface-number ] command after the ICG is started. If "SIM Status = OK" is displayed in the output information, the Micro SIM card is identified.
Figure1-42 Installing Micro SIM cards
SIC-D4G-CNDE
Introduction
The SIC-D4G-CNDE module provides 4G WLAN access and supports the following technologies:
·     LTE-TDD
·     LTE-FDD
·     TD-SCDMA
·     UMTS
·     GSM
·     EVDO
·     CDMA1x
Table1-62 Interface specifications
Item
Connectors
5 × SMA connectors
·     GPS
·     UMTS band 1/8
·     GSM band 2/3/5/8
·     EVDO band BC0
·     CDMA1x band BC0
Interface LEDs
Figure1-43 SIC-D4G-CNDE panel
Table1-63 LED description
LED
WWAN
RSSI
LTE
GPS
CNDE
For more information about SIC-D4G-CNDE interface module antennas, interface cables, and the connection methods, see "4G interface" and "GPS interface."
CAUTION
CAUTION:
The SIC-D4G-CNDE interface module supports Micro SIM cards.
The SIC-D4G-CNDE has two Micro SIM card slots. The two slots can operate simultaneously. The SIM1 slot uses M0 and M1 antenna ports. M0 is the primary antenna port and M1 is the auxiliary antenna port. The SIM2 slot uses M2 and M3 antenna ports. M2 is the primary antenna port and M3 is the auxiliary antenna port. You must connect an antenna to the primary antenna port. An auxiliary antenna only cannot guarantee reliable connectivity. If the primary antenna fails, replace it immediately.
On the SIC-D4G-CNDE interface module, the space between adjacent antenna ports is insufficient for two antennas. To install 4G antennas for two adjacent ports, use a 4G antenna extension cable to connect one of the antennas.
Figure1-44 Installing Micro SIM cards
·     RT-SIC-5G
RT-SIC-5G
CAUTION
CAUTION:
Before removing an RT-SIC-5G module, execute the remove command or press and hold the remove button for more than 3 seconds and wait for the remove LED to turn off. The device might reboot unexpectedly if you remove a SIC-5G module with its remove LED on.
Introduction
The RT-SIC-5G module provides 5G WLAN access and supports the following technologies:
·     5G NR
·     LTE-A
·     WCDMA
·     FDD-LTE
·     TDD-LTE
Table1-64 Interface specifications
Item
Connectors
4 × SMA connectors
Standard and working mode
·     GNSS: GPS/GLONASS/BeiDou/Galileo
·     Omnidirectional antenna, support for WCDMA/FDD-LTE/TDD-LTE/5G NR
Supported service
·     5G/4G/3G networking
·     5G and LTE-A full coverage
·     NSA and SA modes
·     Integrating multi-constellation GNSS receiver for fast and precise positioning in different environments
Interface LEDs
Figure1-45 RT-SIC-5G panel
Table1-65 LED description
LED
WWAN
·     Steady green: A WWAN link is present.
·     Fast flashing green: Data is being transmitted or received on the WWAN link.
·     Slow flashing green: WWAN searching and building.
·     Off: No WWAN link is present.
5G
·     Steady green in SA mode: Strong 5G signal (RSRP ≥ –85 dBm).
·     Fast flashing green in SA mode: Middle 5G signal (–100 dBm ≤ RSSI < –85 dBm).
·     Slow flashing green in SA mode: Low 5G signal (–115 dBm ≤ RSSI < –100 dBm).
·     Steady yellow in NSA mode: Strong 5G signal (RSRP ≥ –85 dBm).
·     Fast flashing yellow in NSA mode: Middle 5G signal (–100 dBm ≤ RSSI < –85 dBm).
·     Slow flashing yellow in NSA mode: Low 5G signal (–115 dBm ≤ RSSI < –100 dBm).
·     Off: No 5G signal.
LTE
·     Steady green: Working in 4G mode with strong signal (RSSI ≥ –70 dBm).
·     Fast flashing green: Working in 4G mode with middle signal (–100 dBm ≤ RSSI < –70 dBm).
·     Slow flashing green: Working in 4G mode with low signal (–125 dBm ≤ RSSI < –100 dBm).
·     Steady yellow: Working in 3G mode with strong signal (RSSI ≥ –70 dBm).
·     Fast flashing yellow: Working in 3G mode with middle signal (–100 dBm ≤ RSSI < –70 dBm).
·     Slow flashing yellow: Working in 3G mode with low signal (–125 dBm ≤ RSSI < –100 dBm)
·     Off: No 3G or 4G service.
SIM
·     Steady green: SIM card 1 is operating.
·     Steady yellow: SIM card 2 is operating.
·     Off: No SIM card is available.
GNSS
·     Steady green: The GNSS service is valid.
·     Off: No GNSS service.
REMOVE
·     Steady green: The SIC-5G module is operating normally and can be hot swapped.
·     Flashing green: The SIC-5G module is being initialized and cannot be hot swapped.
·     Off: You can remove the SIC-5G module if other LEDs are off.
For more information about RT-SIC-5G interface module antennas, interface cables, and the connection methods, see "5G interface."
Installing an RT-5G SIM card
CAUTION
CAUTION:
To avoid damage to a SIM card or the 5G interface module, insert the SIM card into the slot with the cut corner oriented as shown in the illustration.
The RT-SIC-5G interface module provides two SIM card slots. You can install one or two SIM cards as required. SIM card 1 is operating by default when two SIM cards are installed on the SIC-5G interface module. In Figure1-46, two SIM cards are installed.
To install an RT-5G SIM card:
1.     Use a screwdriver to remove the two screws on the SIM card retainer cover.
2.     Lift the cover up and away from the retainer, as shown by callout 2 in Figure1-46.
3.     Orient the SIM card with the cut corner as shown in the illustration.
4.     Insert the SIM card into the SIM card slot along the guide rails.
5.     Slightly push SIM card edge to secure it into the slot.
6.     Reattach the retainer cover and use the two screws to secure the cover.
7.     Execute the display cellular [ interface-number ] command after the ICG is started. If "SIM Status = OK" is displayed in the output information, the SIM card is identified.
Figure1-46 Installing 5G SIM cards
·     SIC-CNDE
·     SIC-CNDE-SJK
·     SIC-4G-CNDE-SJK
·     SIC-D4G-CNDE-SJK
SIC-CNDE
Introduction
The SIC-CNDE is a China Network Data Encryption (CNDE) module. The SIC-CNDE provides high performance and reliable data encryption features for ICGs by using the SM1 mechanism.
Insert SIC-CNDE module in the SIC slot. The main board forwards IP packets and implements VPN with the encryption feature, where SM1 encryption and decryption is implemented by the encryption module.
Table1-66 Interface specifications
Item
Hardware algorithm
Key algorithm:
·     SM1-128
·     SM1-256
Interface LEDs
Figure1-47 SIC-CNDE panel
Table1-67 LED description
LED
ACT
·     Flashing: Data is being transmitted or received between the module and the host.
·     Steady green: No data is being transmitted or received.
SIC-CNDE-SJK
Introduction
The SIC-CNDE-SJK (CNDE is the acronym of China Network Data Encryption) supports SM1, SM2, and SM4 encryption algorithms and provides high performance and reliable data encryption features for ICGs.
LEDs
Figure1-48 SIC-CNDE-SJK panel
Table1-68 LED description
LED
CNDE
SIC-4G-CNDE-SJK
Introduction
The SIC-4G-CNDE-SJK (CNDE is the acronym of China Network Data Encryption) supports SM1, SM2, and SM4 encryption algorithms and provides high performance and reliable data encryption features for ICGs. The SIC-4G-CNDE-SJK module provides 4G WLAN access and supports the following technologies:
·     LTE-TDD
·     LTE-FDD
·     TD-SCDMA
·     UMTS
·     GSM
·     EVDO
·     CDMA1x
Table1-69 Interface specifications
Item
Connectors
3 × SMA connectors
·     GPS antenna
·     UMTS band 1/8
·     GSM band 2/3/5/8
·     EVDO band BC0
·     CDMA1x band BC0
Interface LEDs
Figure1-49 SIC-4G-CNDE-SJK panel
Table1-70 LED description
LED
WWAN
·     Fast flashing: Data is being transmitted or received.
·     Slowly flashing: The module is searching for wireless networks.
RSSI
·     Steady green: Strong signal strength (RSSI ≥ –69 dBm).
·     Fast flashing: Middle signal strength (–89 dBm ≤ RSSI < –69 dBm).
·     Slowly flashing green: Low signal strength (–99 dBm ≤ RSSI < –89 dBm).
·     Off: Weak or no signal strength (RSSI < –99 dBm).
LTE
·     Steady green: The 4G-LTE service is running.
·     Flashing green (8 Hz): The high-speed 3G service such as DC-HSPA+, HSPA+, HSDPA, HSUPA, or EVDO is running.
·     Steady yellow: The 2G or low-speed 3G service such as UMTS, TD-SCDMA, CDMA2000-1xRTT, EDGE, GPRS, or GSM is running.
GPS
·     Steady green: The GPS service is running.
CNDE
For more information about SIC-4G-CNDE-SJK interface module antennas, interface cables, and the connection methods, see "4G interface" and "GPS interface."
Installing a Micro SIM card
CAUTION
CAUTION:
The SIC-4G-CNDE-SJK interface module supports Micro SIM cards.
The SIC-4G-CNDE-SJK has two Micro SIM card slots, but only one is active at a time. If you install SIM cards in both slots, the SIM1 slot 1 is active, the SIM2 slot is in standby state by default. To perform an active/standby switchover, execute the sim switch-to command. For more information about the command, see H3C ICG Series Information Communication Gateways Comware 7 Layer 2—WAN Access Command Reference.
Figure1-50 Installing Micro SIM cards
SIC-D4G-CNDE-SJK
Introduction
The SIC-D4G-CNDE-SJK (D4G indicates that the module supports two SIM cards that can operate simultaneously; CNDE is the acronym of China Network Data Encryption) supports SM1, SM2, and SM4 encryption algorithms and provides high performance and reliable data encryption features for ICGs. The SIC-D4G-CNDE-SJK module provides 4G WLAN access and supports the following technologies:
·     LTE-TDD
·     LTE-FDD
·     TD-SCDMA
·     UMTS
·     GSM
·     EVDO
·     CDMA1x
Table1-71 Interface specifications
Item
Connectors
5 × SMA connectors
·     GPS antenna
·     UMTS band 1/8
·     GSM band 2/3/5/8
·     EVDO band BC0
·     CDMA1x band BC0
Interface LEDs
Figure1-51 SIC-D4G-CNDE-SJK panel
Table1-72 LED description
LED
WWAN
RSSI
·     Fast flashing green: Middle signal strength (–89 dBm ≤ RSSI < –69 dBm).
LTE
·     Off: No LTE service is running.
GPS
·     Off: No GPS service is running.
CNDE
For more information about SIC-D4G-CNDE-SJK interface module antennas, interface cables, and the connection methods, see "4G interface" and "GPS interface."
CAUTION
CAUTION:
The SIC-D4G-CNDE-SJK has two Micro SIM card slots. The two slots can operate simultaneously. The SIM1 slot uses M0 and M1 antenna ports. M0 is the primary antenna port and M1 is the auxiliary antenna port. The SIM2 slot uses M2 and M3 antenna ports. M2 is the primary antenna port and M3 is the auxiliary antenna port. You must connect an antenna to the primary antenna port. An auxiliary antenna only cannot guarantee reliable connectivity. If the primary antenna fails, replace it immediately.
On the SIC-D4G-CNDE-SJK interface module, the space between adjacent antenna ports is insufficient for two antennas. To install 4G antennas for two adjacent ports, use a 4G antenna extension cable to connect one of the antennas.
Figure1-52 Installing Micro SIM cards
2 HMIMs/DHMIMs
For the modular ICGs, a wide range of optional high-performance multiplex interface modules (HMIMs) and double high-performance multiplex interface modules (DHMIMs) are available, which provide abundant interfaces, including synchronous/asynchronous serial interface, Ethernet interface, E1/T1, ISDN BRI/PRI, audio interface, and Layer 2 switching interface.
·     HMIM-8GSW
·     HMIM-24GSW
·     HMIM-24GSW-PoE
·     HMIM-8GSWF
Introduction
The HMIM-8GSW/HMIM-24GSW/HMIM-24GSW-PoE module is an 8/24/24 1000 Mbps Ethernet Layer 2 switching HMIM interface module. Each HMIM-8GSW/HMIM-24GSW module provides 8/24 1000 Mbps RJ-45 ports. HMIM-8GSW/HMIM-24GSW modules are suitable for a small enterprise network to act as a switching and routing device, which can be directly connected to PCs and network devices of the enterprise. The HMIM-24GSW-PoE can supply power to remote PDs.
The HMIM-8GSW/HMIM-24GSW/HMIM-24GSW-PoE supports the following functions:
·     A transmission distance of 100 m (328.08 ft) over a category-5 twisted pair cable (crossover or straight-through cable).
·     1000 Mbps wire-speed forwarding between any two ports connected with a category-5 twisted pair cable (crossover or straight-through cable).
·     Autosensing at a rate of 10 Mbps, 100 Mbps, or 1000 Mbps.
·     Full duplex (typically used) and half duplex operating modes.
Table2-1 describes the interface specifications of the HMIM-8GSW, HMIM-24GSW, and HMIM-24GSW-PoE interface modules. For information about link mode of the interfaces, see "Link mode of interfaces on Ethernet switching modules and interface modules."
Table2-1 Interface specifications
Item
Connector type
RJ-45
Interface type
MDI/MDIX
·     8 (HMIM-8GSW)
·     24 (HMIM-24GSW and HMIM-24GSW-PoE)
Cable type
Standard (straight-through) Ethernet cable/crossover Ethernet cable
Operation mode
Autosensing 10/100/1000 Mbps, full duplex/half duplex
Ethernet interfaces on network adapters are usually medium dependent interfaces (MDIs). Cross medium dependent interfaces (MDIXs) are another type of Ethernet interfaces, which are usually used on hubs and LAN Switches.
Interface LEDs
Figure2-1 HMIM-8GSW panel
Figure2-2 HMIM-24GSW panel
Figure2-3 HMIM-24GSW-PoE panel
Each 1000 Mbps Ethernet interface on the panel has one LED.
Table2-2 LED description
LED status
Off
No link is present.
Steady green
Flashing green
Steady yellow
Flashing yellow
For more information about the Ethernet interface cables and the connection methods, see "Ethernet interface."
HMIM-8GSWF
Introduction
The 8-port 100/1000 Mbps Ethernet Layer 2/Layer 3 HMIM interface module HMIM-8GSWF provides four SFP fiber ports and four combo interfaces. It is designed for a switching/routing integrated device on a small-sized enterprise network. You can connect it to network devices inside the network.
·     Operating speeds of 100 Mbps and 1000 Mbps.
Table2-3 describes the interface specifications of the HMIM-8GSWF interface module. For information about link mode of the interfaces, see "Link mode of interfaces on Ethernet switching modules and interface modules."
Table2-3 Interface specifications
Item
Number of ports
8
Connector type
SFP/LC/RJ-45
Interface standard
·     802.3
·     802.3u
·     802.3ab
Operation mode
Interface LEDs
Figure2-4 HMIM-8GSWF panel
Table2-4 LED description
LED status
Off
No link is present.
Steady green
Flashing green
Steady yellow
A 100 Mbps link is present.
Flashing yellow
For more information about transceiver modules, optical fibers, and the connection methods, see "Fiber port."
·     HMIM-2GEE
·     HMIM-4GEE
·     HMIM-8GEE
·     HMIM-2GEF
·     HMIM-4GEF
·     HMIM-8GEF
·     RT-HMIM-4XP
Introduction
The HMIM-GEE module is used to complete the communication between an ICG and a LAN, which includes the following types:
·     HMIM-2GEE2-port 10BASE-T/100BASE-TX/1000BASE-T Ethernet copper interface module
·     HMIM-4GEE4-port 10BASE-T/100BASE-TX/1000BASE-T Ethernet copper interface module
·     HMIM-8GEE8-port 10BASE-T/100BASE-TX/1000BASE-T Ethernet copper interface module
The HMIM-2GEE/HMIM-4GEE/HMIM-8GEE supports:
·     100 m (328.08 ft) of transmission distance over a category-5 twisted-pair cable.
·     Operation at 10/100/1000 Mbps and autosensing.
·     Full duplex and half-duplex, autonegotiation.
Table2-5 describes the interface specifications of the HMIM-2GEE, HMIM-4GEE, and HMIM-8GEE interface modules. For information about link mode of the interfaces, see "Link mode of interfaces on Ethernet switching modules and interface modules."
Table2-5 Interface specifications
Item
HMIM-2GEE
HMIM-4GEE
HMIM-8GEE
Connector type
RJ-45
2
4
8
Interface type
MDI/MDIX
Interface standard
·     802.3
·     802.3u
·     802.3ab
Supported cable
Ethernet cable
Operating mode
·     10/100/1000 Mbps, autosensing
·     Full duplex/half-duplex, autonegotiation
Interface LEDs
Figure2-5 HMIM-2GEE panel
Figure2-6 HMIM-4GEE panel
Figure2-7 HMIM-8GEE panel
Table2-6 LED description
LED
Green LED
·     On: A 1000 Mbps link is present.
·     Flashing: The port is sending and receiving data at 1000 Mbps.
Yellow LED
·     On: A 10/100 Mbps link is present.
·     Flashing: The port is sending and receiving data at 10/100 Mbps.
Introduction
The HMIM-GEF module is used to complete the communication between an ICG and a LAN, which includes the following types:
·     HMIM-2GEF2-port 1000BASE-SX/1000BASE-LX Ethernet fiber interface module
·     HMIM-4GEF4-port 1000BASE-SX/1000BASE-LX Ethernet fiber interface module
·     HMIM-8GEF8-port 1000BASE-SX/1000BASE-LX Ethernet fiber interface module
The HMIM-2GEF/HMIM-4GEF/HMIM-8GEF supports:
·     Operation at 1000 Mbps.
·     Full duplex.
Table2-7 describes the interface specifications of the HMIM-2GEF, HMIM-4GEF, and HMIM-8GEF interface modules. For information about link mode of the interfaces, see "Link mode of interfaces on Ethernet switching modules and interface modules."
Table2-7 Interface specifications
Item
HMIM-2GEF
HMIM-4GEF
HMIM-8GEF
2
4
8
Connector type
SFP/LC
Interface standard
·     802.3
·     802.3u
·     802.3ab
Operating mode
·     1000 Mbps
·     Full duplex
Interface LEDs
Figure2-8 HMIM-2GEF panel
Figure2-9 HMIM-4GEF panel
Figure2-10 HMIM-8GEF panel
Table2-8 LED description
Status
LINK
ACT
RT-HMIM-4XP
CAUTION
CAUTION:
The RT-HMIM-4XP interface module is hot swappable. To remove it, first press and hold the remove button until the RUN LED is off.
Introduction
The RT-HMIM-4XP is a 10GBASE-R Ethernet interface module that provides four SFP+ ports. Each port is a Layer 3 service port. The RT-HMIM-4XP module supports SFP transceiver modules and 10 Gbps SFP+ transceiver modules.
Table2-9 describes the interface specifications of the RT-HMIM-4XP interface module. For information about link mode of the interfaces, see "Link mode of interfaces on Ethernet switching modules and interface modules."
Table2-9 Interface specifications
Item
4
Connector
SFP+/LC
Interface standard
10GBASE-R
Interface rate and duplex mode
1000 Mbps/10 Gbps autosensing, full duplex
Interface LEDs
Figure2-11 RT-HMIM-4XP panel
Table2-10 LED description
LED
Status
RUN
Steady green
The interface module is operating correctly.
Off
The interface module is not recognized.
LINK/ACT
Steady green
A 10 Gbps link is present on the port.
Flashing green (12 Hz)
Data is being transmitted and/or received at 10 Gbps on the port.
Steady yellow
A 1000 Mbps link is present on the port.
Flashing yellow (12 Hz)
Data is being transmitted and/or received at 1000 Mbps on the port.
Off
No link is present on the port.
ATM interface modules
·     HMIM-1ATM-OC3
HMIM-1ATM-OC3
Introduction
The 1-port ATM (Asynchronous Transfer Mode) 155 Mbps optical interface module (HMIM-1ATM-OC3) provides ATM interfaces for ICGs and supports the following features:
·     Two frame formats: SDH STM-1 and SONET OC-3
·     Scrambling in data transmission
·     Both line clock (when working as DTE interface), and internal clock (when working as DCE interface)
·     Three types of test measures: local cell loopback, local payload loopback, and remote loopback.
Table2-11 Interface specifications
Item
1
Connector
SFP/LC
Interface standard
·     SONET OC-3
·     SDH STM-1
Operating mode
155 Mbps
Interface LEDs
Figure2-12 HMIM-1ATM-OC3 panel
Table2-12 LED description
LED
LINK/ACT
LP/AL
POS (SDH/SONET) interface modules
·     HMIM-1POS
HMIM-1POS
Introduction
The 1-port SDH/SONET interface module (HMIM-1POS) supports interface rates up to 155.52 Mbps (STM-1/OC-3).
The HMIM-1POS can use the protocols such as PPP, Frame Relay, and HDLC at the data link layer and IP at the network layer. It allows direct transmission of packets over SONET/SDH.
The HMIM-1POS provides 155.52 Mbps fractional interface and supports various types of transceiver modules.
Table2-13 Interface specifications
Item
Interface standard
SONET OC-3/SDH STM-1
1
Connector type
SFP/LC
Interface rate
155.52 Mbps
Interface LEDs
Figure2-13 HMIM-1POS front panel
Table2-14 LED description
LED
LINK/ACT
LP/AL
CPOS (SDH/SONET) interface modules
·     HMIM-1CPOS
·     HMIM-2CPOS
HMIM-1CPOS/HMIM-2CPOS
Introduction
The HMIM-1CPOS/HMIM-2CPOS is a 1-port/2-port channelized SDH/SONET interface module. C stands for channelized, and POS for Packet over SDH/SONET. The HMIM-1CPOS/HMIM-2CPOS provides one/two STM-1/OC3-compliant multi-channel interfaces and supports communication speeds up to 155.52 Mbps.
HMIM-1CPOS/HMIM-2CPOS can change between the E1 system and T1 system.
HMIM-1CPOS is inserted in an HMIM slot of a modular ICG and communicates with the CPU through the PCI interface to receive and transmit data on STM-1 channelized POS interface. It supports:
·     Clear channel (unframed) E1 or T1
·     Fractional (framed) E1 or T1
·     Up to 256 64 kbps logical channels
Table2-15 Interface specifications
Item
Connector
SFP/LC
Number of Connectors
1
Interface standard
Interface rate
155.52 Mbps
IMPORTANT
IMPORTANT:
If the interface receives signal over a long-haul optical fiber, make sure the transmission distance is longer than 25 km (15.53 miles). If the transmission distance is shorter than 25 km (15.53 miles), use an optical attenuator to reduce the optical power.
Interface LEDs
Figure2-14 HMIM-1CPOS front panel
Figure2-15 HMIM-2CPOS front panel
Table2-16 LED description
LED
LINK/ACT
LP/AL
Interface mode switchover
You can switch the HMIM-1CPOS/HMIM-2CPOS to operate in E1 and T1 interface modes at the command line interface (CLI).
To switch the interface mode:
1.     Insert the HMIM-1CPOS/HMIM-2CPOS into the HMIM slot of the ICG and then power on the ICG.
2.     Use the card-mode command in system view to set the interface mode. The HMIM-1CPOS/HMIM-2CPOS module is inserted in slot 4 of the ICG in the following example.
# Enter system view.
# Set the HMIM-1CPOS/HMIM-2CPOS to operate in E1 interface mode.
[Sysname] card-mode slot 4 e1
# Set the HMIM-1CPOS/HMIM-2CPOS to operate in T1 interface mode.
[Sysname] card-mode slot 4 t1
E1/T1 interface modules
·     HMIM-1E1
·     HMIM-2E1
·     HMIM-4E1
·     HMIM-1E1-F
·     HMIM-2E1-F
·     HMIM-4E1-F
·     HMIM-8E1
·     HMIM-8E1-F
·     HMIM-2T1
·     HMIM-4T1-F
·     HMIM-2E1T1
·     HMIM-4E1T1
·     HMIM-8E1T1
·     HMIM-2E1T1-F
·     HMIM-4E1T1-F
·     HMIM-8E1T1-F
HMIM-1E1/HMIM-2E1/HMIM-4E1/HMIM-1E1-F/HMIM-2E1-F/HMIM-4E1-F
Introduction
The 1-port channelized E1/PRI interface module (HMIM-1E1), 2-port channelized E1/PRI interface module ( HMIM-2E1), and 4-port channelized E1/PRI interface module (HMIM-4E1) transmit, receive, and process E1 data traffic. In addition, you can use these modules for other purposes, such as CE1 access and the ISDN PRI function.
The HMIM-1E1-F/HMIM-2E1-F/HMIM-4E1-F module is different from the HMIM-1E1/HMIM-2E1/HMIM-4E1 module in the sense that:
·     The FE1 operating mode supported by the E1-F modules allows only one n No 64 kbps bundle to be formed on each interface, where the value range of n is 1 to 31. However, an E1 module allows arbitrary grouping of 31 channels and multiple bundles.
·     The E1-F modules do not support PRI mode.
Table2-17 Interface specifications
Item
HMIM-1E1/HMIM-1E1-F
HMIM-2E1/HMIM-2E1-F
HMIM-4E1/HMIM-4E1-F
Connector type
DB15
DB15
DB25
Number of connectors
1
2
1
Interface standard
G.703 and G.704
Interface rate
2.048 Mbps
Cable type
·     E1 75-ohm unbalanced coaxial cable
·     E1 120-ohm balanced twisted pair cable
·     120-ohm 4E1 conversion cable (only supported by the HMIM-4E1/HMIM-4E1-F)
·     75-ohm 4E1 conversion cable (only supported by the HMIM-4E1/HMIM-4E1-F)
·     Coaxial connector, network interface connector, and 75-ohm to 120-ohm adapter (with BNC connector)
Operating mode
·     E1, CE1, ISDN PRI (only supported by the HMIM-1E1/HMIM-2E1/HMIM-4E1)
·     FE1 (only supported by the HMIM-1E1-F/HMIM-2E1-F/HMIM-4E1-F)
Supported services
·     Backup
·     ISDN PRI (only supported by the HMIM-1E1/HMIM-2E1/HMIM-4E1)
Interface LEDs
Figure2-16 HMIM-E1 panel
Figure2-17 HMIM-E1-F panel
Figure2-18 HMIM-2E1 panel
Figure2-19 HMIM-2E1-F panel
Figure2-20 HMIM-4E1 panel
Figure2-21 HMIM-4E1-F panel
Table2-18 LED description
LED
LINK/ACT
LP/AL
LINK
ACTIVE
Interface cables and the connection methods
HMIM-8E1/HMIM-8E1-F
Introduction
The 8-port channelized E1/PRI interface module (HMIM-8E1) transmits, receives, and processes eight channels of E1 data traffic. In addition, you can use the module for other purposes, such as CE1 access and the ISDN PRI function.
The 8-port fractional E1 interface module (HMIM-8E1-F) is different from the HMIM-8E1 module in the sense that:
·     The FE1 operating mode supported by the HMIM-8E1-F module allows only one n No 64 kbps bundle to be formed on each interface, where the value range of n is 1 to 31. However, an HMIM-8E1 module allows arbitrary grouping of 31 channels and therefore multiple bundles.
·     The HMIM-8E1-F module does not support PRI mode.
For an HMIM-8E1 module, the system automatically creates a serial interface for each timeslot bundle formed on a controller E1 interface.
Table2-19 Interface specifications
Item
Connector type
D68
1
Interface standard
G.703
Interface rate
2.048 Mbps
Cable type
75-ohm 8E1 conversion cable
Cable characteristic impedance
75 ohm
Operating mode
·     E1, CE1, ISDN PRI (only supported by the HMIM-8E1)
·     FE1 (only supported by the HMIM-8E1-F)
Supported services
·     Backup
·     ISDN PRI (only supported by the HMIM-8E1)
Interface LEDs
Figure2-22 HMIM-8E1 (75-ohm) panel
Figure2-23 HMIM-8E1-F (75-ohm) panel
Table2-20 LED description
LED
LINK/ACT
LP/AL
HMIM-2T1/HMIM-4T1-F
Introduction
The 2-port channelized CT1/PRI interface module (HMIM-2T1) serves to transmit/receive and handle T1 data streams, provide CT1 access, and fulfill the function of ISDN PRI. Thereby, one module can be used for multiple purposes.
The 4-port fractional T1 interface module (HMIM-4T1-F) is different from the HMIM-CT1 module in the sense that:
·     FT1 operating mode supported by T1-F modules allows only one bundle. In other words, the time slots can only be bundled into one n x 64 kbps/56 kbps channel, where the value range of n is 1 to 24. However, a CT1 module allows of arbitrary grouping of the 24 channels.
·     T1-F does not support PRI mode.
For a T1 module, the system automatically creates a serial interface for each timeslot bundle formed on a controller T1 interface.
Table2-21 Interface specifications
Item
Connector type
RJ-45
·     2 (HMIM-2T1)
·     4 (HMIM-4T1-F)
Interface standard
·     G.703/T1 102
·     G.704
·     AT & T TR 54016
·     AT & T TR 62411
·     ANSI T1.403
Interface rate
1.544 Mbps
cable type
T1 cable (100-ohm shielding network cable)
Operating mode
CT1, ISDN PRI (only supported by the HMIM-2T1)
FT1 (only supported by the HMIM-4T1-F)
Supported services
·     Backup
·     ISDN PRI (only supported by the HMIM-2T1)
Interface LEDs
Figure2-24 HMIM-2T1 panel
Figure2-25 HMIM-4T1-F panel
Table2-22 LED description
LEDs
LINK/ACT
LP/AL
HMIM-2E1T1/HMIM-4E1T1/HMIM-8E1T1/HMIM-2E1T1-F/HMIM-4E1T1-F/HMIM-8E1T1-F
Introduction
·     HMIM-2E1T1/HMIM-4E1T1/HMIM-8E1T1 module
The 2/4/8-port channelized E1/CE1/T1/CT1/PRI interface module transmits/receives and handles T1 data streams, provides CT1 access, and supports ISDN PRI. The module allows arbitrary grouping of 31 channels.
·     HMIM-2E1T1-F/HMIM-4E1T1-F/HMIM-8E1T1-F module
The 2/4/8-port fractional T1 interface module allows only one bundle. The time slots can only be bundled into one n x 64 kbps/56 kbps channel, where the value range of n is 1 to 31. The module does not support PRI mode.
·     HMIM-2E1T1/HMIM-4E1T1/HMIM-8E1T1(-F) jumper settings
You can use command lines and a jumper to configure an interface on the interface module as a 75-ohm E1 interface, 100-ohm T1 interface, or 120-ohm E1 interface. By default, an interface is a 75-ohm E1 interface.
¡     To configure an interface on the interface module as a 75-ohm E1 interface, connect the jumper to pins 1 and 2, pins 7 and 8, pins 11 and 12, and pins 13 and 14.
¡     To configure an interface on the interface module as a 100-ohm T1 or 120-ohm E1 interface, connect the jumper to pins 1 to 3, pins 5 to 7, pins 9 and 10, and pins 11 to 13.
Figure2-26 Jumper connecting methods
·     An interface corresponds to a jumper connector. Pin settings for the jumper connectors are the same.
·     Each interface comes with four jumper caps.
·     All interfaces must operate in the same mode.
Table2-23 Interface specifications
Item
HMIM-2E1T1/HMIM-2E1T1-F
HMIM-4E1T1/HMIM-4E1T1-F
HMIM-8E1T1/HMIM-8E1T1-F
Connector type
RJ-45
RJ-45
RJ-45
2
4
8
Interface standard
·     G.703/G.704
·     T1 102
·     AT&T TR 54016
·     AT&T TR 62411
·     ANSI T1.403
Interface rate
·     1.544 Mbps
·     2.048 Mbps
Supported cable
·     E1 75-ohm unbalanced twisted pair cable
·     T1 cable (100-ohm shielding network cable)
·     Coaxial connector, network connector, 75-to-120-ohm adapter (with BNC connector)
Operating mode
·     E1/T1/CE1T1/ISDN PRI (only supported by the HMIM-2E1T1/HMIM-4E1T1/HMIM-8E1T1 module)
·     FE1T1 (only supported by the HMIM-2E1T1-F/HMIM-4E1T1-F/HMIM-8E1T1-F module)
Supported services
·     Backup
·     ISDN PRI (only supported by the HMIM-2E1T1/HMIM-4E1T1/HMIM-8E1T1 module)
Interface LEDs
Figure2-27 HMIM-2E1T1 panel
Figure2-28 HMIM-2E1T1-F panel
Figure2-29 HMIM-4E1T1 panel
Figure2-30 HMIM-4E1T1-F panel
Figure2-31 HMIM-8E1T1 panel
Figure2-32 HMIM-8E1T1-F panel
Table2-24 LED description
LED
LINK/ACT
·     On: A carrier signal is received.
·     Off: No carrier signal is received.
LP/AL
E3/T3 interface modules
·     HMIM-1CE3
HMIM-1CE3
Introduction
The 1-port channelized E3 interface module (HMIM-1CE3) serves to:
·     Transmit/receive and handle one channel of E3 fast traffic, as well as provide the accessing of E3 traffic when operating in E3 mode.
·     Provide the low-speed accessing service at the speed of n No 64 kbps, where "n" is smaller than or equal to 128, when operating in CE3 mode.
E3 represents the tertiary group rate of E system in the TDM system, that is, 34.368 Mbps. An E3 channel can be channelized into 16 E1 lines through the demultiplexing processes of E23 and E12, each E1 line supporting both the operating modes of E1 and CE1. E23 is used to indicate either E2-to-E3 multiplex or E3-to-E2 demultiplex, and E12 to indicate E1-to-E2 multiplex or E2-to-E1 demultiplex. "E23" and "E12" discussed here represent the demultiplex process.
Table2-25 Interface specifications
Item
Connector type
SMB
2
Interface standard
G.703, G.704, and G.751
Interface rate
34.368 Mbps
Cable type
E3 cable (75-ohm coaxial cable)
Operating mode
·     E3
·     CE3
Supported services
E3 leased line
Interface LEDs
Figure2-33 HMIM-1CE3 panel
Table2-26 LED description
LED
LINK/ACT
·     Flashing: Data is being received or/and transmitted.
LP/AL
·     On: The interface is in loopback mode.
For more information about E3 interface cables and the connection methods, see "E3/T3 interface."
Serial interface modules
·     HMIM-2SAE
·     HMIM-4SAE
·     HMIM-8SAE
·     HMIM-8ASE
·     HMIM-16ASE
HMIM-2SAE/HMIM-4SAE/HMIM-8SAE
Introduction
The 2-port SAE module (HMIM-2SAE), 4-port SAE module (HMIM-4SAE), and 8-port SAE module (HMIM-8SAE) are enhanced high-speed synchronous/asynchronous serial interface modules. In terms of function, SAE modules are the same as SA modules except that SAE modules support more protocols, for example, RS449, X.21, and RS530.
Table2-27 Interface specifications
Item
Synchronous
Asynchronous
Connector type
D28
2 (HMIM-2SAE)
4 (HMIM-4SAE)
8 (HMIM-8SAE)
V.24
V.35, RS449, X.21, and RS530
RS-232
DTE and DCE
DTE and DCE
Minimum baud rate (bps)
1200
1200
300
Maximum baud rate (bps)
64000
2048000
115200
cable type
V.24 DTE cable
V.24 DCE cable
V.35 DTE cable
V.35 DCE cable
X.21 DTE cable
X.21 DCE cable
RS449 DTE cable
RS449 DCE cable
RS530 DTE cable
RS530 DCE cable
Supported services
·     DDN leased line
·     Backup
·     Terminal access
Interface LEDs
Figure2-34 HMIM-2SAE panel
Figure2-35 HMIM-4SAE panel
Table2-28 LED description
LED
LINK
·     Off: No link is present.
·     On: A link is present.
ACT
·     Off: No data is being transmitted or received.
Figure2-36 HMIM-8SAE panel
On the HMIM-8SAE module, each link corresponds to a LED. The LED state indicates the link state as follows:
·     OnA link is present.
·     Flashing—Data is being transmitted or received.
·     Off—No link is present.
HMIM-8ASE/HMIM-16ASE
Introduction
The 8-port ASE module (HMIM-8ASE) and the 16-port ASE module (HMIM-16ASE) are enhanced asynchronous serial interface modules that are used to transmit, receive, and handle asynchronous serial interface data streams. ASE modules use RJ-45 connectors and AUX cables.
Table2-29 Interface specifications
Item
HMIM-8ASE
HMIM-16ASE
Connector type
RJ-45
8 (HMIM-8ASE)
16 (HMIM-16ASE)
RS-232
cable type
·     AUX cable
·     Standard (straight-through) Ethernet cable
·     HMIM-8ASE/HMIM-16ASE dumb terminal cable
300
115.2 k
Supported services
·     Dialup through a modem
·     Backup
·     Asynchronous leased line service
Interface LEDs
Figure2-37 HMIM-8ASE panel
Figure2-38 HMIM-16ASE panel
Each channel on HMIM-8ASE/HMIM-16ASE has only one LED. The LED state indicates the link state as follows:
·     On—A link is present.
POS terminal access interface modules
·     HMIM-1E1POS
·     DHMIM-1E1POS1DM
HMIM-1E1POS
Introduction
The HMIM-1E1POS is a 1-port channelized E1 high-density POS access interface module. Each E1 port can deal with incoming calls from 30 POS terminals at the same time. The HMIM-1E1POS is applicable to the bank data transaction center for smart card accounting management.
The POS access service is a type of smart card service widely used in places such as shopping malls and gasoline service stations. It links a POS terminal device located in a shopping mall or a gasoline service station to a bank card accounting system to provide services.
·     The HMIM-1E1POS uses the PRI voice protocol, but cannot be used for regular voice calling. The voice subscriber lines that the HMIM-1E1POS generates cannot be used as regular voice interfaces, and cannot be bound to the voice entities.
·     The PRI interface is used for transmitting service data. The interfaces Diag Port0 and Diag Port1 are used only for device debugging.
Table2-30 Interface specifications
Item
Connector
RJ-45
1
Cable
120-ohm standard non-shield cable
Operating mode
PRI
Supported protocols
Synchronous mode:
·     ITU-T-V.22 (PSK/QPSK)
·     V.22 BIS (QAM)
Supported services
POS call in PRI mode
Interface LEDs
Figure2-39 HMIM-1E1POS panel
Table2-31 LED description
LED
LINK/ACT
·     Steady green: A carrier signal is detected.
·     Flashing green: Data is being received or transmitted.
·     Off: No carrier signals are detected.
LP/AL
·     Steady yellow: The interface is in loopback.
·     Flashing yellow: An alarm has occurred.
·     Off: No loopback or alarm is present.
Interface cable
The HMIM-1E1POS uses the 120-ohm unshielded E1 cable with RJ-45 connecters at both ends.
Figure2-40 HMIM-1E1POS interface cable
标准网线
The HMIM-1E1POS does not come with the interface cable. You need to order for the E1 cable.
Connecting the interface cable
CAUTION
CAUTION:
·     Before connecting a port, read its label carefully. A wrong connection can cause damages to the interface module and even the device.
·     As a best practice, add a lightning arrester between an interface cable and interface module for better lightning protection when the cable is routed outdoors.
To connect the interface cable:
1.     Connect one end of the interface cable to the RJ-45 port on the HMIM-1E1POS.
2.     Connect the other end of the interface cable to the peer device.
3.     Examine the status of the LINK LED on the HMIM-1E1POS. If the LINK LED is off, examine the cable connection and cable condition.
DHMIM-1E1POS1DM
Introduction
The DHMIM-1E1POS1DM is a 1-port channelized E1 high-density POS access interface module. Each E1 port can deal with incoming calls from 30 POS terminals at the same time. The DHMIM-1E1POS1DM is applicable to the bank data transaction center for smart card accounting management.
The DHMIM-1E1POS1DM can operate as the HMIM-1E1POS or the DHMIM-1DM. When the E1 port of the DHMIM-1E1POS1DM operates in asynchronous mode, you can upgrade the POS device remotely.
Table2-32 Interface specifications
Item
Connector
RJ-45
1
Cable
120-ohm standard non-shielded cable
Operation mode
PRI
Supported protocols
·     Synchronous mode:
¡     ITU-T-V.22 (PSK/QPSK)
¡     V.22 BIS (QAM)
·     Asynchronous mode:
¡     ITU-T V.92
¡     V.90
¡     V.34
¡     V.32 bis
¡     V.32
¡     V.23
¡     V.22 bis
¡     V.22
¡     V.21
¡     Bell 212a
¡     Bell 103
Supported services
Interface LEDS
Figure2-41 DHMIM-1E1POS1DM panel
Table2-33 LED description
LED
LINK/ACT
·     Steady green: The carrier signal is detected.
·     Flashing green (8 Hz): Data is being received or transmitted.
LP/AL
·     Flashing yellow (1 Hz): An alarm has occurred.
CAUTION
CAUTION:
·     Before connecting a port, read its label carefully. A wrong connection might cause damages to the interface module and even the device.
If the interface module has been properly installed, follow these steps to connect the cable:
1.     Connect one end of the interface cable to the RJ-45 port on the DHMIM-1E1POS1DM.
3.     Examine the status of the LINK LED on the DHMIM-1E1POS1DM. If the LINK LED is off, examine the cable connection and cable condition.
Digital modem interface modules
·     DHMIM-1DM
DHMIM-1DM
Introduction
The DHMIM-1DM is a 1-port channelized E1 high-density digital modem interface module. You can upgrade a POS device remotely through the module.
Table2-34 Interface specifications
Item
Connector
RJ-45
1
Cable
Operation mode
PRI
Supported protocols
Asynchronous mode:
·     ITU-T V.92
·     V.90
·     V.34
·     V.32 bis
·     V.32
·     V.23
·     V.22 bis
·     V.22
·     V.21
·     Bell 212a
·     Bell 103
Supported services
Interface LEDs
Figure2-42 DHMIM-1DM panel
Table2-35 LED description
LED
LINK/ACT
LP/AL
CAUTION
CAUTION:
1.     Connect one end of the interface cable to the RJ-45 port on the DHMIM-1DM.
3.     Examine the status of the LINK LED on the DHMIM-1DM. If the LINK LED is off, examine the cable connection and cable condition.
Voice interface modules
·     HMIM-16FXS
·     HMIM-8FXS8FXO
·     HMIM-2VE1
·     HMIM-2VT1
·     HMIM-1VE1
·     HMIM-1VT1
·     HMIM-4FXS
·     HMIM-4FXO
·     HMIM-4E&M
HMIM-16FXS
Introduction
The 16-port loop trunk interface module (HMIM-16FXS) serves to access and handle 16 channels of analog voice signals over data communication networks. The module provides 16 FXS interfaces.
Table2-36 Interface specifications
Item
Connector type
RJ-11
16 (FXS interfaces)
Interface standard
·     ITU Q.512-compliant subscriber circuit interface (FXS)
·     ITU K.20-compliant over-current and over-voltage protection
Cable type
Dial-up mode
DTMF, compliant with GB3378 (Pulse dial-up is not available.)
Bandwidth
300 to 3400 Hz
Interface LEDs
Figure2-43 HMIM-16FXS front panel
Table2-37 LED description
LED
LINK/ACT
·     Off: The link is idle.
·     Steady green: The link is being occupied for a call connection.
For more information about FXS interface cables and the connection methods, see "ADSL/BS/FXS/FXO/AM/FCM interface."
HMIM-8FXS8FXO
Introduction
The 8-port analog subscriber circuit interface module and 8-port voice AT0 loop trunk interface module (HMIM-8FXS8FXO) serve to access and handle 16 channels of analog voice signals over data communication networks. Eight FXS interfaces and eight FXO interfaces are available on an HMIM-8FXS8FXO module:
When you use the HMIM-8FXS8FXO module in a device, make sure the device has been connected to the IP network or other WAN.
Table2-38 Interface specifications
Item
Connector type
RJ-11
·     8 FXS interfaces
·     8 FXO interfaces
Interface standard
·     ITU Q.552-compliant loop trunk interface (FXO)
Cable type
Dial-up mode
Bandwidth
300 Hz to 3400 Hz
Interface LEDs
Figure2-44 HMIM-8FXS8FXO front panel
Table2-39 LED description
LED
LINK/ACT
HMIM-2VE1
Introduction
The 2-port E1 voice interface module (HMIM-2VE1) can handle dense voice signals in VoIP system. It provides two CE1/PRI/R2 ports, allowing the access of 60 channels of voice signals.
Table2-40 Interface specifications
Item
Connector
DB15
2
Operating mode
·     CE1
·     ISDN PRI
·     R2
Interface rate
2.048 Mbps
Cable type
·     Coaxial connector, network interface connector, and 75-to-120-ohm adapter (with BNC connector)
Supported service
·     R2 signaling
·     DSS1 signaling
·     IP Fax
·     General VoIP features in Comware
Interface LEDs
Figure2-45 HMIM-2VE1 panel
Table2-41 LED description
LED
LINK/ACT
·     Flashing: Data is being received and/or transmitted.
LP/AL
·     Flashing: An AIS, LFA, or RAI alarm has occurred.
For more information about E1 interface cables and the connection methods, see "E1 interface."
HMIM-2VT1
Introduction
The 2-port T1 voice interface module (HMIM-2VT1) can handle dense voice signals in a VoIP system. It provides two CT1/PRI ports, allowing access of 48 voice signal channels.
Table2-42 Interface specifications
Item
Connector
RJ-45
Number of connector
2
Interface standard
·     G.703/T1.102
·     G.704
·     AT & T TR 54016
·     AT & T TR 62411
·     ANSI T1.403
Interface rate
1.544 Mbps
Cable type
Operation mode
·     CT1
·     ISDN PRI
Services
·     Backup
·     Terminal access
·     ISDN
Interface LEDs
Figure2-46 HMIM-2VT1 panel
Table2-43 LED description
LED
LINK/ACT
LP/AL
For more information about T1 interface cables and the connection methods, see "T1 interface."
HMIM-1VE1
Introduction
The 1-port E1 voice interface module (HMIM-1VE1) can handle dense voice signals in VoIP system. It provides a CE1/PRI/R2 port, allowing the access of 30 channels of voice signals.
Table2-44 Interface specifications
Item
Connector
DB15
1
Operating mode
·     CE1
·     ISDN PRI
·     R2
Interface rate
2.048 Mbps
Cable
·     Coaxial connector, network interface connector, and 75ohm-to-120ohm adapter (with BNC connector)
Supported service
·     R2 signaling
·     DSS1 signaling
·     IP Fax
Interface LEDs
Figure2-47 HMIM-1VE1 panel
Table2-45 LED description
LED
LINK/ACT
LP/AL
HMIM-1VT1
Introduction
The 1-port T1 voice interface module (HMIM-1VT1) can handle dense voice signals in VoIP system. It provides a CT1/PRI port, allowing the access of 24 channels of voice signals.
Table2-46 Interface specifications
Item
Connector
RJ-45
Number of connector
1
Interface standard
·     G.703/T1.102
·     G.704
·     AT & T TR 54016
·     AT & T TR 62411
·     ANSI T1.403
Interface rate
1.544 Mbps
Cable type
Operation mode
·     CT1
·     ISDN PRI
Services
·     Backup
·     Terminal access
·     ISDN
Interface LEDs
Figure2-48 HMIM-1VT1 panel
Table2-47 LED description
LED
LINK/ACT
LP/AL
HMIM-4FXS/HMIM-4FXO
Introduction
The 4-port voice subscriber circuit interface module (HMIM-4FXS) processes and transmits over data communications networks voice signals for 2/4 regular analog phones, faxes, or AT0 loop trunks of telephone exchanges.
The 4-port voice AT0 analog trunk interface module (HMIM-4FXO) processes and transmits over data communications networks voice signals for 2/4 loops of telephone exchanges.
Table2-48 Interface specifications
Item
Connector
RJ-45
4
Cable
·     Telephone cable with ferrite core
·     E&M trunk cable (only for E&M modules, made on site)
Interface standard
·     ITU Q.512-compliant subscriber circuit interface (HMIM-4FXS)
·     ITU Q.552-compliant loop trunk interface (HMIM-4FXO)
Dial-up mode
Bandwidth
300 Hz to 3400 Hz
Interface LEDs
Figure2-49 HMIM-4FXS panel
Figure2-50 HMIM-4FXO panel
Table2-49 LED description
LED
LINK
ACT
·     On: There is call activity.
·     Off: The channel is idle.
For more information about FXS/FXO interface cables and the connection methods, see "ADSL/BS/FXS/FXO/AM/FCM interface."
HMIM-4E&M
Introduction
The 4-port voice E&M analog trunk interface module (HMIM-4E&M) provides and transmits over data communications networks voice signals for four E&M analog trunks.
Table2-50 Interface specifications
Item
Connector
RJ-45
4 (HMIM-4E&M)
Cable type
Interface standard
·     G.712-compliant E&M trunk interface (HMIM-4E&M), E&M interface (supporting Bell type I, II, III, V, and support 2-wire and 4-wire)
Dial-up mode
Bandwidth
300 Hz to 3400 Hz
Interface LEDs
Figure2-51 HMIM-4E&M panel
Table2-51 LED description
LED
LINK
ACT
For more information about E&M interface cables and the connection methods, see "E&M interface."
Analog modem modules
·     HMIM-6AM
·     HMIM-6FCM
HMIM-6AM
Introduction
The 6-port analog modem interface module (HMIM-6AM) provides six channels of user dial-in and dial-out, and provides a connection speed of 56 kbps when ITU-T V.90 is applied. Working with the ICGs, it provides medium-density RAS functions.
Table2-52 Interface specifications
Item
Connector
RJ-45
6
Cable
Telephone cable
Interface rate
56 kbps
Interface standard
ITU-T V.90, K56flex, V.34 (33.6 kbps), V.FC, V.32 bis, V.32, V.22 bis, V.22A/B, V.23, V.21, Bell 212A a, and Bell 103
Supported service
Dialup through modem
Interface LEDs
Figure2-52 HMIM-6AM panel
Table2-53 LED description
LED
LINK
·     Flashing: A link is being established.
ACT
·     Flashing: Data is being transmitted and/or received.
For more information about AM interface cables and the connection methods, see "ADSL/BS/FXS/FXO/AM/FCM interface."
HMIM-6FCM
Introduction
The 6-port fast connect modem interface module (HMIM-6FCM) provides POS terminal devices to fast dial up to a bank card accounting system.
The POS access service refers to a type of smart card service widely used in places such as shopping malls and gasoline service stations. It links a POS terminal device located in a shopping mall or a gasoline service station to a bank card accounting system to provide services.
Table2-54 Interface specifications
Item
Connector
RJ-45
6
Cable
Supported protocols
ITU-T V.22
Interface LEDs
Figure2-53 HMIM-6FCM panel
Table2-55 LED description
LED
CD
·     On: A carrier signal is detected.
ACT
·     Flashing: Data is being received or transmitted.
·     Off: No data is being received or transmitted.
For more information about FCM interface cables and the connection methods, see "ADSL/BS/FXS/FXO/AM/FCM interface."
3 VPMs
Voice co-processing modules/Voice processing modules
·     VPM
VPM purchase guide
·     The SIC-1VE1/SIC-1VT1 module does not provide any VPM slot, and can only use the VPMs installed on the main board of an ICG.
·     Because the initiator of a three-party conference is responsible for audio mixing, so when using an ICG as the initiator of a three-party conference, the main board of the ICG must have VPM installed.
Introduction
The voice processing module (VPM) functions encoding/decoding, echo cancellation (EC) and comfortable noise generation (CNG) of voices.
Table3-1 Interface specifications
Item
Number of calls supported
·     8
·     16
·     24
·     32
·     128
·     256
·     512
Installing and removing a VPM
For how to install and remove a VPM, see the installation guides for the ICGs.
4 Cables and the connection methods
Ethernet interface
Ethernet cable appearance and applicable models
Table4-1 Ethernet cable appearance and applicable models
Appearance
Applicable models
1 × RJ-45 < ---- > 1 × RJ-45
SIC-4FSW
SIC-4FSWP
SIC-4GSW
DSIC-9FSW
DSIC-9FSWP
SIC-1FEA
SIC-1GEC-V2
HMIM-8GSW
HMIM-24GSW
HMIM-24GSW-PoE
HMIM-2GEE
HMIM-4GEE
HMIM-8GEE
HMIM-1E1POS
DHMIM-1DM
DHMIM-1E1POS1DM
10/100 Mbps Ethernet uses category-5 twisted pair cables, and 1000 Mbps Ethernet uses category-5 enhanced or category-6 twisted pair cables. Twisted pair cables include straight-through cables and crossover cables.
Category-5 cables provide a transmission frequency of 100 MHz for voice and data transmission; they are mainly used in 100BASE-T and 10BASE-T networks. Category-5 cables are common Ethernet cables, which can also be used to transmit 1000 Mbps Ethernet data.
Category-5 enhanced cables feature low attenuation and crosstalk, providing higher attenuation to crosstalk ratio (ACR), less delay error and higher performance than category-5 cables. Category-5 enhanced cables are mainly used in 1000 Mbps Ethernet networks.
Category-6 cables provide a transmission frequency of 1 MHz to 250 MHz, and improve the performance on crosstalk and return loss. A fine better return loss performance is extremely important for new-generation full-duplex high-speed networks. Category-6 cables have sufficient power sum ACR (PS-ACR) when working at 200 MHz. They provide a bandwidth two times than that of category-5 enhanced cables, thus featuring a higher transmission performance. Therefore, category-6 cables are suitable for applications requiring a transmission speed of more than 1 Gbps.
The 10/100 Mbps Ethernet uses two pairs of cables, orange/white, orange, green/white and green cables, to transmit and receive data, while the 1000 Mbps Ethernet uses four pairs of cables to transmit and receive data.
For the pinouts of common twisted pair cables, see the following tables. (A and B represent the two ends of a cable respectively.)
Table4-2 Straight-through cable pinouts
Pinout No.
A
B
1
Orange/white
Orange/white
2
Orange
Orange
3
Green/white
Green/white
4
Blue
Blue
5
Blue/white
Blue/white
6
Green
Green
7
Brown/white
Brown/white
8
Brown
Brown
Table4-3 Crossover cable pinouts
Pinout No.
A
B
1
Orange/white
Green/white
2
Orange
Green
3
Green/white
Orange/white
4
Blue
Blue
5
Blue/white
Blue/white
6
Green
Orange
7
Brown/white
Brown/white
8
Brown
Brown
Strictly follow the pinouts in the above tables when identifying or making the two types of Ethernet cables; otherwise, the communication quality may be affected.
Connecting an Ethernet cable
1.     Connect one end of an Ethernet cable to an Ethernet interface on the module and the other end to the Ethernet interface on the peer device. Because the Ethernet interface of the module supports MDI/MDIX autosensing, you can use a straight-through cable or crossover cable to connect the interface.
2.     Check the status of the LED of the Ethernet interface after power-on. For the status of the LED, see the relevant part in this manual.
Fiber port
Appearances and applicable models of transceiver modules and optical fibers
Optical interfaces must work with SFP or SFP+ transceiver modules and optical fibers with LC connectors. For more information about interface module and transceiver module compatibility, see H3C ICG Series Information Communication Gateways Transceiver Module Compatibility Matrix.
Connecting an optical fiber
CAUTION
CAUTION:
·     Never stare into an open optical Ethernet interface, because invisible rays may be emitted from the optical Ethernet interface.
·     Cover the dust cover if no optical fiber connector is connected to the optical Ethernet interface.
To connect an optical fiber:
1.     Insert the transceiver module to the interface on the interface module or service module.
2.     Identify the Rx and Tx ports on the transceiver module. Plug the LC connector at one end of one fiber cable into the Rx port of the ICG and the LC connector at the other end into the Tx port of the peer device. Plug the LC connector at one end of another fiber cable into the Tx port of the ICG and the LC connector at the other end to the Rx port of the peer device.
3.     View the LINK LED after connection.
¡     If the LED is on, the optical fiber link is present.
¡     If the LED is off, no link is present. This may be because the TX and Rx port of the optical fiber are not connected correctly. In this case, connect the optical fiber again.
E1 interface
E1 cable appearance and applicable models
Table4-4 E1 cable appearance and applicable models
Cable
Appearance
Applicable models
1-port E1 75-ohm cable
图一 1端口E1 75欧姆电缆
1 × DB15 < ---- > 2 × BNC
SIC-E1-F
SIC-1EPRI
HMIM-1E1
HMIM-1E1-F
HMIM-2E1
HMIM-2E1-F
SIC-1VE1
HMIM-1VE1
HMIM-2VE1
1-port E1 120-ohm cable
图二   1端口E1 120欧姆电缆
1 × DB15 < ---- > 1 × RJ-45
HMIM-1E1
HMIM-1E1-F
HMIM-2E1
HMIM-2E1-F
SIC-1VE1
HMIM-1VE1
HMIM-2VE1
1-port E1 120-ohm cable (2 m, 15 m, 30 m)-RJ-45
HMIM-2E1T1
HMIM-4E1T1
HMIM-8E1T1
HMIM-2E1T1-F
HMIM-4E1T1-F
HMIM-8E1T1-F
SIC-1VE1T1
2-port E1 75-ohm cable
图三  2端口E1 75欧姆电缆
1 × DB15 < ---- > 4 × BNC
SIC-2E1-F
4-port E1 75-ohm cable
图四  4端口E1 75欧姆电缆
1 × DB25 < ---- > 4 × DB15
HMIM-4E1
HMIM-4E1-F
4-port E1 120-ohm cable
图五  4端口E1 120欧姆电缆
HMIM-4E1
HMIM-4E1-F
8-port E1 75-ohm cable
1 × D68 < ---- > 16 × BNC
HMIM-8E1
HMIM-8E1-F
1-port E1 75-ohm cable-RJ-45
HMIM-2E1T1
HMIM-4E1T1
HMIM-8E1T1
HMIM-2E1T1-F
HMIM-4E1T1-F
HMIM-8E1T1-F
SIC-1VE1T1
75-ohm adapter cable
图六  75欧姆中继电缆
1 × BNC < ---- > 1 × BNC
Use as needed
Coaxial connector
图七  同轴连接器
Use as needed
Impedance converter
图八 阻抗转换器
2 × BNC < ---- > 1 × RJ-45
Use as needed
Dual inline package switch
The E1/E1-F/VE1 interface module provides a dual inline package (DIP) switch. The DIP switch setting defines the interface impedance and the grounding method.
Table4-5 DIP switch-to-interface map
DIP switch
E1 interface
Applicable models
S1
Interface 0
HMIM-1E1
HMIM-1E1-F
HMIM-2E1
HMIM-2E1-F
HMIM-4E1
HMIM-4E1-F
SIC-1VE1
HMIM-1VE1
HMIM-2VE1
S2
Interface1
HMIM-1E1
HMIM-1E1-F
HMIM-2E1
HMIM-2E1-F
HMIM-4E1
HMIM-4E1-F
HMIM-2VE1
S3
Interface2
HMIM-4E1
HMIM-4E1-F
S4
Interface3
HMIM-4E1
HMIM-4E1-F
By default, all DIP switches are ON, and the E1 interface impedance is 75 ohms, as shown in the following figure:
Figure4-1 Default DIP switch settings
As a best practice, use the DIP switch as follows: When the interface is connected to a 75-ohm cable, turn on switches BIT1 through 8; when the interface is connected to a 120-ohm cable, turn off switches BIT1 through 8. Description for DIP switch settings is shown in the following table:
Table4-6 Description for DIP switch settings
DIP
Configuration of 75-ohm impedance
Configuration of 120-ohm impedance
1BIT
75-ohm/120-ohm selection switch
ON
OFF
2BIT
ON
OFF
3BIT
ON
OFF
4BIT
ON
OFF
5BIT
ON
OFF
6BIT
RxRing grounding mode selection switch
OFF: RxRing is grounded via capacitance.
ON: RxRing is grounded directly.
N/A
7BIT
RxShield grounding mode selection switch
N/A
ON: RxShield is grounded.
OFF: RxShield is not grounded.
8BIT
SxShield grounding mode selection switch
N/A
OFF: RxShield is grounded via capacitance
ON: RxShield is grounded directly.
Connecting a 1/2/4/8-port E1 75-ohm cable (DB15 <----> BNC)
CAUTION
CAUTION:
Make sure you insert the cable into the right interface so as to avoid damages to the interface module or the chassis.
·     If you do not need to extend the cable, you can directly connect the BNC connectors of the E1 75-ohm cable to the remote network device as follows:
a.     Connect the DB15 connector of the E1 75-ohm cable to the DB15 interface of the interface module and fasten the bolts to fix the cable.
b.     The other end of the cable provides one pair or multiple pairs of 75-ohm BNC connectors. Connect the TX connectors and the RX connectors on this end to the RX connectors and the TX connectors on the remote device respectively.
Figure4-2 Connect an E1 75-ohm cable
·     If you want to extend the cable, connect each BNC connector of the E1 75-ohm cable to one end of a coaxial connector, and connect the remote device to the other end of the coaxial connector through an E1 75-ohm adapter cable.
Figure4-3 Connect an E1 75-ohm cable
·     If the impedance of the E1 interface on the remote device is 120 ohms, you must use an impedance converter to adapt the impedance.
Figure4-4 Connect an impedance converter
Connecting a 4-port E1 75-ohm cable (DB25 <----> DB15)
1.     Connect the DB25 connector of the 4-port E1 75-ohm cable to the DB25 interface of the interface module and fasten the bolts to fix the cable.
2.     The other end of the cable provides four DB15 connectors. Connect them to the DB15 interfaces on the remote device as needed.
Figure4-5 Connect an 4-port E1 75-ohm cable
Connecting a 1-port E1 120-ohm cable (DB15 <----> RJ-45)
1.     Connect the DB15 connector of the E1 120-ohm cable to the DB15 interface on the interface module and fasten the bolts to fix the cable.
2.     The other end of the cable provides one or multiple RJ-45 connectors. Connect them to the RJ-45 interface on the remote device as needed.
Figure4-6 Connecting an E1 120-ohm cable
Table4-7 DB15 to BNC/RJ-45 pinouts
DB15
BNC (75 W coaxial cable)
RJ-45 (120 W twisted pair cable)
9
Tx Tip
Tx Tip
4
Tx Tip
2
Tx Ring
Tx Ring
5
Tx Ring
10
Tx Shield
N/A
6
Tx Shield
8
Rx Tip
Rx Tip
1
Rx Tip
15
Rx Ring
Rx Ring
2
Rx Ring
7
Rx Shield
N/A
3
Rx Shield
Connecting a 4-port E1 120-ohm cable (DB25 <----> DB15)
1.     Connect the DB25 connector of the 4-port E1 120-ohm cable to the DB25 interface on the interface module and fasten the bolts to fix the cable.
2.     The other end of the cable provides four DB15 connectors. Connect them to the DB15 interface on the remote device as needed.
Figure4-7 Connecting a 4-port E1 120-ohm cable
T1 interface
CAUTION
CAUTION:
To avoid damages to the interface module or the chassis, make sure you insert the cable into the right interface.
T1 cable appearance and applicable models
Table4-8 T1 cable appearance and applicable models
Cable
Appearance
Applicable models
1-port T1 cable (100-ohm standard shielded cable)
SIC-T1-F
HMIM-2T1
HMIM-4T1-F
SIC-1VT1
SIC-1VE1T1
HMIM-1VT1
HMIM-2VT1
HMIM-2E1T1
HMIM-4E1T1
HMIM-8E1T1
HMIM-2E1T1-F
HMIM-4E1T1-F
HMIM-8E1T1-F
RJ-45 connector
图十八 RJ45连接器
Use as needed
Connecting a 1-port T1 cable
The two ends of the 1-port T1 cable are RJ-45 connectors. Connect one end of the cable to the T1 connector (RJ-45) of the interface module and the other end of the cable to the T1 connector (RJ-45) on the remote device.
E3/T3 interface
E3/T3 cable appearance and applicable models
Table4-9 E3/T3 cable appearance and applicable models
Cable
Appearance
Applicable models
E3/T3 interface cable
1 × BNS < ---- > 1 × SMB
HMIM-1CE3
Connecting the cable
1.     Connect the SMB connector of an E3/T3 cable to the Tx port on the interface module and the other end to the Rx port on the device to be connected.
2.     Connect the SMB connector of another E3/T3 cable to the Rx port of interface module and the other end to the Tx port on the device to be connected.
Synchronous/asynchronous serial ports
Appearance and applicable models of synchronous/asynchronous serial port cables
Table4-10 Appearance and applicable models of synchronous/asynchronous serial port cables
Cable
Appearance
Applicable models
V.24 DTE cable
1 × DB25 (male) < ---- > 1 × D28
SIC-1SAE
SIC-2SAE
SIC-4SAE
HMIM-2SAE
HMIM-4SAE
HMIM-8SAE
V.24 DCE cable
1 × DB25 (female) < ---- > 1 × D28
V.35 DTE cable
1 × D28 < ---- > 1 × D34 (male)
V.35 DCE cable
1 × D28 < ---- > 1 × D34 (female)
X.21 DTE cable
1 × DB15 (male) < ---- > 1 × D28
X.21 DCE cable
1 × DB15 (female) < ---- > 1 × D28
RS-449 DTE cable
1 × D28 < ---- > 1 × D37 (male)
RS-449 DCE cable
1 × D28 < ---- > 1 × D37 (female)
RS-530 DTE cable
RS-530 DCE cable
1.     Check port type of the peer device and choose the synchronous serial interface cable of correct type.
2.     Plug the D28 end of the synchronous serial interface cable into the D28 interface of the SAE interface module.
3.     If the WAN uses DDN line, connect the cable to the port of CSU/DSU.
4.     Check the LINK LED on the SAE panel.
¡     If the LED is on, a link is present.
¡     If the LED is off, a fault has occurred on the link and signal is out of synchronization. In this case, check the link.
Asynchronous serial ports
Appearance and applicable models of asynchronous serial port cables
Table4-11 Appearance and applicable models of asynchronous serial port cables
Cable
Appearance
Applicable models
8-port asynchronous serial port adapter cable
图九 8端口异步串口转接电缆
1 × DB60 < ---- > 8 × RJ-45 (female)
SIC-8AS
4-port asynchronous serial port adapter cable
图十  4端口异步串口转接电缆
1 × D28 < ---- > 4 × RJ-45 (female)
SIC-16AS
Home-made cable
HMIM-8ASE
HMIM-16ASE
Dumb terminal adapter cable
图十一  哑终端转接电缆
1 × RJ-45 (female) < ---- > 1 × RJ-45 (male)
HMIM-8ASE
HMIM-16ASE
AUX cable
图十二  AUX电缆
1 × DB25 & 1 × D9 < ---- > 1 × RJ-45
HMIM-8ASE
HMIM-16ASE
图十九 哑终端转接器
1 × DB25 < ---- > 1 × RJ-45
HMIM-8ASE
HMIM-16ASE
Console cable
1 × DB-9 < ---- > 1 × RJ-45
SIC-AP320
Connecting a SIC-8AS/SIC-16AS interface module
To connect the SIC-8AS interface module, connect the DB60 connector of the 8-port asynchronous serial port adapter cable to the SIC-8AS interface module.
To connect the SIC-16AS interface module, connect the D28 connector of the 4-port asynchronous serial port adapter cable to the SIC-16AS interface module, which allows up to four such cables.
Choose the cable connection type according to the remote device type:
·     If the remote device is a telecom device with an RJ-45 port, connect the RJ-45 port to the RJ-45 interface of the asynchronous serial port adapter cable by using a straight-through cable. The sequence is shown in the following figure:
Figure4-8 Connecting a telecom device
·     If the remote device is a bank dumb terminal device, connect the RJ-45 connector (male) on one end of the dumb terminal cable to the RJ-45 interface on the asynchronous serial port adapter cable. Connect the RJ-45 connector (female) on the other end of the dumb terminal cable to the RJ-45 interface on one end of the dumb terminal adapter by a straight-through cable. The other end of the dumb terminal adapter is a DB25 interface and can be connected to the bank dumb terminal device. The sequence is shown in the following figure:
Figure4-9 Connecting the dumb terminal device
·     If the interface of the remote device, usually a modem, is a DB25/D9 interface, use the AUX cable to connect the asynchronous serial port adapter cable to the interface:
Figure4-10 Connecting a modem
Connecting a HMIM-8ASE/HMIM-16ASE interface module
CAUTION
CAUTION:
If the remote device is a telecom device with an RJ-45 port, connect the RJ-45 port to the RJ-45 interface of the interface module by using a straight-through cable. The sequence is shown in the following figure:
Figure4-11 Connecting a telecom device
Connecting a SIC-AP320 WLAN interface module
To connect the interface module to a configuration terminal (for example, a PC) through the serial console cable:
1.     Connect the DB-9 female connector of the console cable to the serial port of the PC
2.     Connect the RJ-45 connector to the console port on the module.
To disconnect the console cable, remove the RJ-45 connector end first.
Appearance and applicable models of the magnetic-core telephone cable
Table4-12 Appearance and applicable models of magnetic-core telephone cable
Cable
Appearance
Applicable models
Magnetic-core telephone cable
图十三  带磁环的电话线
1 × RJ-11 < ---- > 1 × RJ-11
SIC-1ADSL
SIC-1ADSL-I
SIC-1BS
SIC-2BS
SIC-1FXS
SIC-1FXO
SIC-2FXS
SIC-2FXO
SIC-2FXS1FXO
DSIC-4FXS1FXO
SIC-1AM
HMIM-4FXS
HMIM-4FXO
HMIM-16FXS
HMIM-8FXS8FXO
HMIM-6AM
HMIM-6FCM
Connecting an ADSL/FXS/FXO/AM/FCM interface module
1.     Connect one end of the magnetic-core telephone cable to the RJ-11 or RJ-45 interface of the interface module.
2.     Connect the other end of the magnetic-core telephone cable to the remote device interface.
Connecting a BS/BU interface module cable
1.     If the service provider provides an ISDN U interface cable, you must use an NT1 device for adaptation. Connect one end of the magnetic-core telephone cable to the RJ-45 interface of the SIC-1BS interface module. Connect the other end of the magnetic-core telephone cable to the S/T interface of the NT1 device. Connect the ISDN U interface cable to the U interface on the NT1 device.
Figure4-12 Connecting the U interface cable to the SIC-1BS interface module
2.     If the service provider provides an ISDN S/T interface cable, directly connect the cable to the RJ-45 interface of the SIC-1BS interface module.
Figure4-13 Connecting the S/T interface cable to the SIC-1BS interface module
E&M interface
E&M interface appearance and the applicable model
E&M modules support Bell I, II, III, V switches, and 2-wire & 4-wire voice signals.
As a best practice, use Bell V 4-wire voice signal to communicate with the ICG in practice.
The sequence of E&M RJ-45 pins is shown in the following figure, numbered 1 to 8 from left to right:
Figure4-14 Sequence of RJ-45 pins
Table4-13 Pinouts of E&M interface cable (Bell V 4-wire)
E&M interface
RJ-45 Pin
Signal
Signal direction
1
2
E
IN
3
RING0
IN
4
RING1
OUT
5
TIP1
OUT
6
TIP0
IN
7
M
OUT
8
SG
Ground
Because the 4E&M modules cannot determine the interface types (Bell I/II/III/V), cable types (2-wire or 4-wire), and pinouts (E/M/Tx/Rx) of the peer switch, you must prepare the interface cables of the 4E&M modules according to the on-site conditions. To ensure the EMC of the ICG, install a ferrite core near the connector of the E&M module interface cable at the ICG side.
The connection method
BSV/BSE interface
BSV/BSE interface cable appearance and applicable models
Table4-14 BSV/BSE interface cable appearance and applicable models
Cable
Appearance
Applicable models
ISDN S/T interface standard cable
SIC-1BSV
SIC-2BSV
ISDN S/T interface crossover cable
图十一  哑终端转接电缆
SIC-1BSV
SIC-2BSV
Connecting a SIC-1BSV/SIC-2BSV interface module cable
BSV interface supports the User and Network operating modes. The BSV interface works in User mode when connecting to an ISDN network, or works in Network mode when connecting to TE devices such as the digital telephones or the BSV interfaces working in User mode.
Choose the cable connection type according to the operating mode:
·     When the BSV interface works in User mode, choose the connection method according to the type of the cable provided by the service provider:
¡     If the service provider provides an ISDN U interface cable, you must use an NT1 device for adaptation. Connect one end of the standard ISDN S/T interface cable to the RJ-45 interface of the BSV interface module. Connect the other end of the standard ISDN S/T interface cable to the S/T interface of the NT1 device. Connect the ISDN U interface cable to the U interface on the NT1 device.
Figure4-15 Connecting a service provider U interface cable to a BSV interface module
¡     If the service provider provides an ISDN S/T interface cable, directly connect the service provider cable to the BSV interface.
Figure4-16 Connecting a service provider S/T interface cable to a BSV interface module
·     When the BSV interface works in Network mode, you must use an ISDN S/T interface crossover cable to connect the BSV interface to a TE device such as a digital telephone or a BSV interface working in User mode:
Connect the RJ-45 connector (male) of the ISDN S/T interface crossover cable to the RJ-45 interface on the BSV interface module. Connect the RJ-45 interface (female) of the standard ISDN S/T interface cable to one end of the standard ISDN S/T interface cable. Connect the S/T interface on the TE device to the other end of the standard ISDN S/T interface cable.
Figure4-17 Connecting a TE device to a BSV interface module
GPS interface
Appearance and applicable models of the SIC-4G-CNDE/SIC-D4G-CNDE/SIC-4G-CNDE-SJK/SIC-D4G-CNDE-SJK interface module GPS antenna
Table4-15 Appearance and applicable models of the 4G interface module GPS antenna
Appearance
Applicable models
SIC-4G-CNDE
SIC-D4G-CNDE
SIC-4G-CNDE-SJK
SIC-D4G-CNDE-SJK
Table4-16 Antenna specifications
Item
Specification
Frequency scope
1575.42 ± 3 MHz
Voltage standing wave ratio
≤ 1.92
Input impedance
50 ohms
Gain
1.5 dBic Typ
Echo return loss
10 dB Min
SMA (male)
Extension cable length
5 m (16.40 ft)
Extension cable type
RG-174 coaxial cable
Color
Black
Operating temperature
–30°C to +80°C (–22°F to +176°F)
Connecting an antenna extension cable
1.     Fasten the SMA male connector onto the GPS antenna port on the module.
2.     Put the other end of the extension cable outdoor to achieve better signal coverage.
WLAN interface
Appearance and applicable models of the WLAN interface module antenna
Table4-17 Appearance and applicable models of the WLAN interface module antenna
Antenna
Appearance
Applicable models
天线渲染图
SIC-AP320
Connecting a WLAN interface module antenna
1.     To install an antenna, adjust the angle of the antenna to 180º.
2.     Fasten the antenna onto the antenna port on the interface module. To avoid damage, do not over-tighten the antenna. Make sure the antenna is vertical to the ground or ceiling to achieve optimal coverage.
3G interface
Appearance and applicable models of the SIC-3G-CDMA/SIC-3G-TD/SIC-3G-HSPA interface module antenna
Table4-18 Appearance and applicable models of the SIC-3G-CDMA/SIC-3G-TD/SIC-3G-HSPA interface module antenna
Cable
Appearance
Applicable models
TZD-EW618-04_页面_1_图像_0003
SIC-3G-CDMA
SIC-3G-TD
SIC-3G-HSPA
AUX cable
图十二  AUX电缆
Table4-19 The detailed specifications for the SIC-3G-CDMA/SIC-3G-TD/SIC-3G-HSPA interface module antenna
Item
Frequency scope
824-960 MHz / 1710-2170 MHz
≤ 2
Input impedance
50 ohms
Gain
1.5 dBi
Polarization type
Vertical
Maximum input power
10 W
TNC-Male
Lightning protection
Direct current grounding
Height
153 mm (6.02 in)
Weight
26 g (0.92 oz)
Length
None
Color
Black
–30 °C to +60 °C (–22°F to +140°F)
Connecting a SIC-3G-CDMA/SIC-3G-TD/SIC-3G-HSPA interface module antenna
2.     Fasten the antenna onto the antenna port that has a MAIN mark. To avoid damage, do not over-tighten the antenna. Make sure the antenna is vertical to the ground or ceiling to achieve the optimal coverage.
Connecting a SIC-3G-CDMA/SIC-3G-TD/SIC-3G-HSPA interface debug antenna
To debug and test the SIC-3G-CDMA/SIC-3G-TD/SIC-3G-HSPA, connect the RJ-45 interface of the AUX cable to the Diag Port interface and connect the DB25/D9 connector to a peer device, which is usually a PC.
4G interface
Appearance and applicable models of 4G antennas and extension cables
Table4-20 Appearance and applicable models of the 4G antennas and extension cables
Appearance
Applicable models
SIC-4G-LTE-M
Table4-21 Antenna specifications
Item
Specification
SIC-4G-LTE-M
Frequency scope
698 to 960 MHz
1.71 to 2.7 GHz
791 to 960 MHz
1710 to 2690 MHz
2.5
≤ 3.5
Input impedance
50 ohms
50 ohms
Gain
2 dBi
791 to 960 MHz @ 3.1 dBi
1710 to 2690 MHz @ 7.2dBi
Polarization type
Vertical
Vertical
Maximum input power
5 W
1 W
TNC
SMA
Height
21.4 cm (8.43 in)
16.6 cm (6.54 in)
Weight
50.5 g (1.78 oz)
> 22 g (0.78 oz)
Color
Black
Black
–40°C to +85°C (–40°F to +185°F)
–10°C to +60°C (14°F to 140°F)
Table4-22 4G antenna extension cable specifications for the SIC-4G-CNDE/SIC-D4G-CNDE/SIC-4G-CNDE-SJK/SIC-D4G-CNDE-SJK module
Item
Specification
Frequency scope
698 to 960 MHz
1710 to 2700 MHz
≤ 2.0
Input impedance
50 ohms
Gain
2.0 dBi
Polarization type
Vertical
SMA
Height
16.4 ± 0.2 cm (6.46 ± 0.08 in)
Weight
134 ± 5 g (4.73 ± 0.18 oz)
Color
Black
Cable length
200 ± 2 cm (78.74 ± 0.79 in)
–40°C to +60°C (–40°F to +140°F)
Installing a 4G antenna for the SIC-4G-LTE-M, SIC-4G-CNDE, SIC-D4G-CNDE, SIC-4G-CNDE-SJK, or SIC-D4G-CNDE-SJK module
2.     Fasten the antenna onto the antenna port. To avoid damage, do not over-tighten the antenna.
Connecting a 4G antenna extension cable for the SIC-4G-LTE-M, SIC-4G-CNDE, SIC-D4G-CNDE, SIC-4G-CNDE-SJK, or SIC-D4G-CNDE-SJK module
1.     Fasten the SMA male connector onto the antenna port on the module.
2.     Attach the magnetic cradle on the other end of the extension cable to the rack.
Installing a 4G interface debugging antenna
A 4G interface module has a Mini USB port to connect to the peer device through the USB console cable for third-party software to debug the 4G interface module. When the interface module is operating correctly, you do not need to connect the USB console cable.
To debug a 4G interface module, connect the port at one end of the USB console cable to the peer device (PC), and connect the other end to the Mini USB port on the interface module.
5G interface
Appearance and applicable models of 5G antennas and extension cables
Table4-23 Appearance and applicable models of the 5G antennas and extension cables
Appearance
Applicable models
cid:image004.jpg@01D68CDF.2C973130
RT-SIC-5G
cid:image005.jpg@01D68CDF.2C973130
RT-SIC-5G
Table4-24 5G antenna specifications
Item
Frequency range
698 to 960 MHz
1710 to 2170 MHz
2300 to 2700 MHz
3300 to 3800 MHz
4400 to 5000 MHz
5150 to 5850 MHz
≤ 4
Input impedance
50 ohms
Gain
617 MHz to 960 MHz, 0.59 dBi
1710 MHz to 2170 MHz, 3.74 dBi
2300 MHz to 2700 MHz, 3.51 dBi
3300 MHz to 3800 MHz, 3.7 dBi
4400 MHz to 5000 MHz, 4.0 dBi
5150 MHz to 5850 MHz, 4.87 dBi
Polarization type
Vertical
Maximum input power
1 W
SMA male
Height
20.3 cm (7.99 in)
Weight
19.63 g (0.69 oz)
Color
Black
–20 °C to +65 °C (–4°F to +149°F)
Table4-25 5G antenna extension cable specifications
Item
Specification
Frequency range
DC to 6 GHz
≤ 5
Input impedance
50 ohms
Cable type
RG-174
Max input power
1 W
SMA
Cable length
3000 mm (118.11 in)
Weight
65.3 g (2.30 oz)
Color
Black
5 Link mode of interfaces on Ethernet switching modules and interface modules
An interface can operate in bridge or route link mode. You can use the port link-mode command to change the link mode of an interface. Interfaces that operate in bridge mode are called Layer 2 interfaces. Interfaces that operate in route mode are called Layer 3 interfaces.
Some interfaces on Ethernet switching modules and interface modules can operate only as Layer 3 interfaces, as shown in Table5-1. Some interfaces operate as Layer 2 interfaces by default but can be changed to Layer 3 interfaces by using the port link-mode command, as shown in Table5-2.
IMPORTANT
IMPORTANT:
·     By default, the nine Ethernet interfaces on the DSIC-9FSW and DSIC-9FSWP interface modules operate in bridge mode. You can execute the port link-mode command to change the operating mode of any four interfaces to route. The remaining five interfaces can operate only in bridge mode.
·     When you install an SIC-4FSW, SIC-4FSWP, DSIC-9FSW, or DSIC-9FSWP interface module on the ICG, you can change the operating mode of any four interfaces to route. The remaining interfaces can operate only in bridge mode.
·     For the interface module compatibility with ICG models, see "Appendix B  Purchase guide."
Table5-1 Ethernet interfaces that can operate only as Layer 3 interfaces
Ethernet switching module/Ethernet interface module
Interfaces that can operate only as Layer 3 interfaces
SIC-4FSW
N/A
SIC-4FSWP
N/A
DSIC-9FSW
N/A
DSIC-9FSWP
N/A
SIC-4GSW
N/A
SIC-4GSWF
N/A
SIC-1FEA
FE0
SIC-1FEF
SFP0
SIC-1GEC-V2
Combo 0 (GE0, SFP0)
HMIM-8GSW
N/A
HMIM-24GSW
N/A
HMIM-24GSW-PoE
N/A
HMIM-8GSWF
N/A
HMIM-2GEE
GE0 and GE1
HMIM-4GEE
GE0 to GE3
HMIM-8GEE
GE0 to GE7
HMIM-2GEF
SFP0 and SFP1
HMIM-4GEF
SFP0 to SFP3
HMIM-8GEF
SFP0 to SFP7
RT-HMIM-4XP
SFP+0 to SFP+3
Table5-2 Ethernet interfaces that operate as Layer 2 interfaces by default and can be changed to Layer 3 interfaces
Interfaces that operate as Layer 2 interfaces by default and can be changed to Layer 3 interfaces
SIC-4FSW
FE0 to FE3
SIC-4FSWP
FE0 to FE3
DSIC-9FSW
Any four interfaces
DSIC-9FSWP
Any four interfaces
SIC-4GSW
GE0 to GE3
SIC-4GSWF
SFP0 to SFP3
SIC-1FEA
N/A
SIC-1FEF
N/A
SIC-1GEC-V2
N/A
HMIM-8GSW
GE0 to GE5, Combo 6 (GE6, SFP6), Combo 7 (GE7, SFP7)
HMIM-24GSW
GE0 to GE23
HMIM-24GSW-PoE
GE0 to GE23
HMIM-8GSWF
SFP0 to SFP3, Combo 4 (GE4, SFP4), Combo 5 (GE5, SFP5), Combo 6 (GE6, SFP6), Combo 7 (GE7, SFP7)
HMIM-2GEE
N/A
HMIM-4GEE
N/A
HMIM-8GEE
N/A
HMIM-2GEF
N/A
HMIM-4GEF
N/A
HMIM-8GEF
N/A
RT-HMIM-4XP
N/A
