03-Layer 2—LAN Switching Command Reference
HomeSupportSwitchesS5590-EI SeriesReference GuidesCommand ReferencesH3C S5590-HI[S5590-EI][S5500V3-HI] Switch Series Command References-R6010Pxx-6W10003-Layer 2—LAN Switching Command Reference
11-VLAN mapping commands
11-VLAN mapping commands 63.01 KB
display vlan mapping
Use display vlan mapping to display VLAN mapping information.
display vlan mapping [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, the command displays VLAN mapping information on all interfaces.
# Display VLAN mapping information on all interfaces.
<Sysname> display vlan mapping
Interface GigabitEthernet1/0/1:
  Outer VLAN    Inner VLAN    Translated Outer VLAN    Translated Inner VLAN
  10            N/A           120                      N/A
Interface GigabitEthernet1/0/2:
  1024-4094     N/A           100                      N/A
Interface GigabitEthernet1/0/3:
  12            N/A           110                      12
Interface GigabitEthernet1/0/4:
  11            30            130                      40
Outer VLAN
Original outer VLAN.
This field indicates the original VLAN for one-to-one VLAN mapping, many-to-one VLAN mapping, and one-to-two VLAN mapping.
This field displays N/A for zero-to-two VLAN mapping.
Inner VLAN
Original inner VLAN.
This field displays N/A for one-to-one VLAN mapping, many-to-one VLAN mapping, and one-to-two VLAN mapping.
Translated outer VLAN.
This field indicates the translated VLAN for one-to-one VLAN mapping and many-to-one VLAN mapping.
This field indicates the SVLAN to be added for zero-to-two VLAN mapping.
Translated inner VLAN.
This field displays N/A for one-to-one VLAN mapping and many-to-one VLAN mapping.
This field indicates the CVLAN to be added for zero-to-two VLAN mapping.
vlan mapping
vlan mapping
Use vlan mapping to configure VLAN mapping on an interface.
Use undo vlan mapping to cancel the VLAN mapping configuration.
vlan mapping { vlan-id translated-vlan vlan-id | nest single vlan-id-list nested-vlan vlan-id | tunnel outer-vlan-id inner-vlan-id translated-vlan outer-vlan-id inner-vlan-id | uni { range vlan-range-list | single vlan-id-list } translated-vlan vlan-id }
undo vlan mapping { vlan-id translated-vlan vlan-id | all | nest single vlan-id-list nested-vlan vlan-id | tunnel outer-vlan-id inner-vlan-id translated-vlan outer-vlan-id inner-vlan-id | uni { range vlan-range-list | single vlan-id-list } translated-vlan vlan-id }
No VLAN mapping is configured on an interface.
vlan-id translated-vlan vlan-id: Specifies the original VLAN and translated VLAN for a one-to-one VLAN mapping. The value range for the vlan-id argument is 1 to 4094. The original VLAN and the translated VLAN cannot be the same.
uni range vlan-range-list translated-vlan vlan-id: Specifies the original VLAN ranges and the translated VLAN for a many-to-one VLAN mapping on the customer-side port. The vlan-range-list argument specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN ID or a range of VLAN IDs in the form of vlan-id1 to vlan-id2. The value range for VLAN IDs is 1 to 4094. The value for the vlan-id2 argument must be greater than the value for the vlan-id1 argument. The value range for the vlan-id argument is 1 to 4094. Different VLAN ranges cannot overlap. Any of the original VLANs cannot be the same as the translated VLAN.
uni single vlan-id-list translated-vlan vlan-id: Specifies the original VLANs and the translated VLAN for a many-to-one VLAN mapping on the customer-side port. The vlan-id-list argument specifies a space-separated list of up to 10 VLAN IDs, each of which is in the range of 1 to 4094. The value range for the vlan-id argument is 1 to 4094. Any of the original VLANs cannot be the same as the translated VLAN.
nest single vlan-id-list nested-vlan vlan-id: Specifies the CVLANs and the SVLAN for a one-to-two VLAN mapping. The vlan-id-list argument specifies a space-separated list of up to 10 CVLAN IDs, each of which is in the range of 1 to 4094. The vlan-id argument specifies the SVLAN ID in the range of 1 to 4094.
tunnel outer-vlan-id inner-vlan-id translated-vlan outer-vlan-id inner-vlan-id: Specifies the original outer VLAN ID, original inner VLAN ID, translated outer VLAN ID, and translated inner VLAN ID for a two-to-two VLAN mapping. The value ranges for the outer-vlan-id argument and the inner-vlan-id argument are both 1 to 4094.
all: Deletes all VLAN mapping configurations from the interface.
The original and translated VLANs in VLAN mappings on an interface must meet the following requirements:
·     Different types of VLAN mapping entries cannot include the same original VLANs or translated VLANs.
·     Different one-to-one or two-to-two VLAN mapping entries cannot include the same translated VLANs. If you configure multiple one-to-one or two-to-two VLAN mapping entries for the same original VLANs, the most recent configuration takes effect.
You can configure only one many-to-one VLAN mapping on the same interface. To modify the many-to-one VLAN mapping, perform the following tasks:
1.     Execute the undo vlan mapping command to delete the existing many-to-one VLAN mapping.
2.     Configure another many-to-one VLAN mapping.
When you configure many-to-one VLAN mappings, following these restrictions and guidelines:
·     You cannot configure many-to-one VLAN mapping on a Layer 2 aggregate interface.
·     The device supports a maximum of 170 many-to-one VLAN mapping entries.
·     You can configure only one many-to-one VLAN mapping on the same interface. To modify the many-to-one VLAN mapping, perform the following tasks:
a.     Execute the undo vlan mapping command to delete the existing many-to-one VLAN mapping.
b.     Configure another many-to-one VLAN mapping.
·     After you configure an interface as the network-side interface of many-to-one VLAN mapping, do not configure the other types of VLAN mapping on the interface.
·     To ensure correct traffic forwarding from the service provider network to the customer network, do not configure many-to-one VLAN mappings together with uRPF. For more information about uRPF, see Security Configuration Guide.
The configuration restrictions between QinQ and VLAN mappings are as follows:
·     Before you enable or disable QinQ on a port, you must remove all VLAN mappings on the port.
·     You cannot configure two-to-two VLAN mappings on a QinQ-enabled port.
If you use both transparent VLANs and VLAN mappings on an interface, the transparent VLANs cannot be the following VLANs:
·     Original or translated VLANs of one-to-one and one-to-two VLAN mappings.
·     Original or translated outer VLANs of two-to-two VLAN mappings.
The MTU of an interface is 1500 bytes by default. After a VLAN tag is added to a packet, the packet length is added by 4 bytes. As a best practice, set the MTU to a minimum of 1504 bytes for ports on the forwarding path of the packet on the service provider network.
# Configure a one-to-one VLAN mapping on GigabitEthernet 1/0/1 to map VLAN 1 to VLAN 101.
[Sysname-GigabitEthernet1/0/1] vlan mapping 1 translated-vlan 101
# Configure many-to-one VLAN mappings on the customer-side port (GigabitEthernet 1/0/2) to map VLANs 1 through 50 to VLAN 101.
[Sysname-GigabitEthernet1/0/2] vlan mapping uni range 1 to 50 translated-vlan 101
# Configure one-to-two VLAN mappings on GigabitEthernet 1/0/4 to add SVLAN tag 101 to packets carrying VLAN tag 80.
[Sysname] interface gigabitethernet 1/0/4
[Sysname-GigabitEthernet1/0/4] vlan mapping nest single 80 nested-vlan 101
# Configure a two-to-two VLAN mapping on GigabitEthernet 1/0/5 to map SVLAN 101 and CVLAN 1 to SVLAN 201 and CVLAN 10.
[Sysname] interface gigabitethernet 1/0/5
[Sysname-GigabitEthernet1/0/5] vlan mapping tunnel 101 1 translated-vlan 201 10
vlan mapping untagged
Use vlan mapping untagged to configure zero-to-two VLAN mapping on an interface.
Use undo vlan mapping untagged to remove the zero-to-two VLAN mapping configuration.
vlan mapping untagged nested-outer-vlan outer-vlan-id nested-inner-vlan inner-vlan-id
No zero-to-two VLAN mapping is configured on an interface.
nested-outer-vlan outer-vlan-id: Specifies the SVLAN ID in the range of 1 to 4094.
nested-inner-vlan inner-vlan-id: Specifies the CVLAN ID in the range of 1 to 4094.
This command takes effect only on ports that use VLAN 1 as the PVID.
Before you modify a zero-to-two VLAN mapping, first execute the undo vlan mapping untagged command to remove the previous configuration.
As a best practice, set the MTU to a minimum of 1504 bytes for ports on the forwarding path of the double-tagged packet in the service provider network.
# Configure a zero-to-two VLAN mapping on GigabitEthernet 1/0/1 to add SVLAN 200 and CVLAN 100 to untagged packets.
[Sysname-GigabitEthernet1/0/1] vlan mapping untagged nested-outer-vlan 200 nested-inner-vlan 100
