08-WLAN Security Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C WX2800X&WSG1800X Configuration Guides(E5611)-5W10108-WLAN Security Configuration Guide
04-WLAN DRS configuration
04-WLAN DRS configuration 67.72 KB
Configuring WLAN DRS
About WLAN DRS
DPI report statistics (DRS) classifies and stores user application and URL session information detected by DPI and sends the information to the cloud platform as configured. For more information about DPI, see DPI Configuration Guide.
WLAN DRS tasks at a glance
To configure WLAN DRS, perform the following tasks:
1.     Enabling DRS
2.     (Optional.) Configuring DRS information reporting to the
Enabling DRS
DRS classifies user application and URL session information detected by DPI, and stores the statistics in file drs.db in the bash directory of the local SQL database.
You can view the statistics on the local database by using SQL database statements or from the Web interface.
2.     Enable DRS.
wlan drs [ ipv6 ] enable
By default, DRS is disabled.
3.     (Optional.) Enable DRS for wired clients.
wlan drs wired-statistics enable
By default, DRS for wired clients is disabled.
Configuring DRS information reporting to the cloud platform
This feature enables the AC to send a specific number of DRS entries to the cloud platform at the specified interval.
2.     Enabling DRS information reporting to the cloud platform.
wlan drs report-oasis enable
By default, the reporting feature is enabled.
3.     Set the DRS information reporting interval and the number of entries to be reported every time.
wlan drs report-oasis { app | url } [ interval interval | number number ] *
By default, the AC reports 10 DRS entries to the cloud platform every 1000 milliseconds.
WLAN DRS configuration examples
Example: Configuring WLAN DRS
As shown in Figure 1, enable DRS for the AC to get user application and URL session information, and enable the AC to report DRS entries to the cloud platform at the specified interval.
Figure 1 Network diagram
1.     Configure a VLAN interface:
# Create VLAN 100 and assign an IP address to VLAN-interface 100.
<AC> system-view
[AC] vlan 100
[AC-vlan100] quit
[AC-Vlan-interface100] ip address 10.1.9.58 16
[AC-Vlan-interface100] quit
2.     Configure wireless services:
# Create service template service1.
[AC] wlan service-template service1
# Set the SSID to drs.
[AC-wlan-st-service1] ssid drs
# Assign clients coming online through the service template to VLAN 100.
[AC-wlan-st-service1] vlan 100
# Enable the service template.
[AC-wlan-st-service1] service-template enable
[AC-wlan-st-service1] quit
3.     Create a manual AP:
# Create manual AP ap1, and specify the AP model and serial ID.
[AC] wlan ap ap1 model WA6320
[AC-wlan-ap-ap1] serial-id 219801A28N819CE0002T
# Bind service template service1 to radio 1.
[AC-wlan-ap-ap1] radio 1
[AC-wlan-ap-ap1-radio-1] service-template service1
[AC-wlan-ap-ap1-radio-1] quit
[AC-wlan-ap-ap1] quit
4.     Configure DRS:
# Enable DRS.
[AC] wlan drs enable
# Set the DRS information reporting interval to 500 seconds, and the number of entries to be reported every time to 20.
[AC] wlan drs report-oasis app interval 500 number 20
[AC] wlan drs report-oasis url interval 500 number 20
# Verify that you can view application and URL session records from the Web interface.
