| 00-Preface | 99.94 KB |
Preface
The WX2800X&WSG1800X documentation set describes the software features for H3C access controllers and wireless integrated services gateways. These guides also guide you through the software configuration procedures and provide configuration examples to help you apply the software features to different network scenarios.
The AP and WT Management Configuration Guide describes AP management, WT configurations.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the H3C access controllers.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
