- 05-IP Multicast Configuration Guide
- 01-Multicast overview
- 02-IGMP snooping configuration
- 03-Multicast routing and forwarding configuration
- 04-IGMP configuration
- 05-PIM configuration
- 06-MSDP configuration
- 07-MLD snooping configuration
- 08-IPv6 multicast routing and forwarding configuration
- 09-MLD configuration
- 10-IPv6 PIM configuration
00-Preface | 100.78 KB |
Preface
This configuration guide describes IP multicast fundamentals and configuration. It covers the IPv4 multicast configuration and IPv6 multicast configuration. With multicast, you can implement efficient point-to-multipoint data transmission in your network.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the S12500R Switch Router Series.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
