05-IP Multicast Command Reference
HomeSupportSwitchesS12500R SeriesReference GuidesCommand ReferencesH3C S12500R Switch Router Series Command References(R36xx)-6W10105-IP Multicast Command Reference
03-IGMP commands
03-IGMP commands 221.29 KB
IGMP commands
display igmp group
Use display igmp group to display information about IGMP multicast groups (multicast groups that hosts have joined through IGMP).
display igmp group [ group-address | interface interface-type interface-number ] [ static | verbose ]
group-address: Specifies a multicast group by its IP address in the range of 224.0.1.0 to 239.255.255.255. If you do not specify a multicast group, this command displays information about all IGMP multicast groups.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays information about IGMP multicast groups for all interfaces.
static: Specifies IGMP multicast groups that hosts have joined statically. If you do not specify this keyword, the command displays information about IGMP multicast groups that hosts have joined dynamically.
verbose: Displays detailed information.
# Display information about IGMP multicast groups that hosts have dynamically joined on the public network.
<Sysname> display igmp group
IGMP groups in total: 3
 HundredGigE1/0/1(10.10.1.20):
  IGMP groups reported in total: 3
   Group address   Last reporter   Uptime      Expires
   225.1.1.1       10.10.1.10      00:02:04    00:01:15
   225.1.1.2       10.10.1.10      00:02:04    00:01:15
   225.1.1.3       10.10.1.10      00:02:04    00:01:15
Total number of IGMP multicast groups.
Total number of IGMP multicast groups that hosts attached to the interface have joined dynamically.
Group address
Multicast group address.
Last reporter
Address of the last host that reported its membership to the multicast group.
Uptime
Length of time since the multicast group was reported.
Expire
Remaining lifetime for the multicast group. This field displays Off if the timer is disabled.
# Display detailed information about IGMP multicast group 232.1.1.1 that hosts have dynamically joined on the public network. In this example, the router is configured with IGMPv3.
<Sysname> display igmp group 232.1.1.1 verbose
   Group: 232.1.1.1
     Uptime: 00:00:34
     Exclude expires: 00:04:16
     Mapping expires: 00:02:16
     Last reporter: 10.10.1.10
     Last-member-query-counter: 0
     Last-member-query-timer-expiry: Off
     Mapping last-member-query-counter: 0
     Mapping last-member-query-timer-expiry: Off
     Group mode: Exclude
     Version1-host-present-timer-expiry: Off
     Version2-host-present-timer-expiry: 00:02:11
     Mapping version1-host-present-timer-expiry: Off
     Source list (sources in total: 1):
       Source: 10.1.1.1
          Uptime: 00:00:03
          V3 expires: 00:04:16
Group
Uptime
Exclude expires
Remaining lifetime for the multicast group in Exclude mode. This field displays Off if the timer is disabled.
Mapping expires
Remaining time for the multicast group specified in IGMP SSM mappings.
This field is displayed only when the device is configured with IGMP SSM mappings.
Last reporter
Address of the last host that reported its membership to this multicast group.
Number of IGMP group-specific queries or IGMP source-and-group-specific queries sent for the multicast group.
Remaining time for the last member query timer for the multicast group. This field displays Off if the timer is disabled.
Number of IGMP group-specific queries or IGMP source-and-group-specific queries sent for the multicast group specified in IGMP SSM mappings.
Remaining time for the last member query timer of the multicast group specified in IGMP SSM mappings.
Group mode
Multicast source filtering mode:
·     Include—Include mode.
·     Exclude—Exclude mode.
For a device that runs IGMPv1 or IGMPv2:
·     If IGMP SSM mappings are not configured, this field displays Exclude.
·     If IGMP SSM mappings are configured, this field displays Include or Exclude depending on the SSM mappings and the multicast groups that the host joins.
Remaining time for the IGMPv1 host present timer.
This field is displayed only when the device runs IGMPv2 or IGMPv3.
Remaining time for the IGMPv2 host present timer.
This field is displayed only when the device runs IGMPv3.
Remaining time for the IGMPv1 host present timer when the device is configured with IGMP SSM mappings.
Source list (sources in total)
List of multicast sources and total number of multicast sources.
This field is displayed only when the device runs IGMPv3 or when the device is configured with IGMP SSM mappings.
Source
Multicast source address.
Uptime
Length of time since the multicast source was reported.
V3 expires
Remaining time for the multicast source when the device runs IGMPv3.
This field displays Off if the timer is disabled and displays three hyphens (---) if the multicast source is specified in IGMP SSM mappings.
Mapping expires
Remaining time for the multicast source specified in IGMP SSM mappings.
Number of IGMP group-specific queries or IGMP group-and-source-specific queries sent for the multicast source and group.
This field is displayed only when the device runs IGMPv3 or is configured with IGMP SSM mappings.
Remaining time for the last member query timer for the multicast source and group.
# Display information about IGMP multicast groups that hosts have statically joined on the public network.
<Sysname> display igmp group static
 Entries in total: 2
   Group address   Source address  Interface           Expires
   225.1.1.1       0.0.0.0         HGE1/0/1            Never
   225.2.2.2       1.1.1.1         HGE1/0/1            Never
Entries in total
Total number of the multicast groups that hosts have joined statically.
Group address
Source address
Interface name.
Expires
Remaining lifetime for the multicast group. This field always displays Never because the multicast group never expires.
reset igmp group
display igmp host-tracking
Use display igmp host-tracking to display IGMP host tracking information.
display igmp host-tracking [ interface interface-type interface-number ] [ group group-address ] [ source source-address ] [ active ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays IGMP host tracking information for all interfaces.
group group-address: Specifies a multicast group by its IP address in the range of 224.0.1.0 to 239.255.255.255. If you do not specify this option, the command displays IGMP host tracking information for all multicast groups.
source source-address: Specifies a multicast source by its IP address. If you do not specify this option, the command displays IGMP host tracking information for all multicast sources.
active: Specifies active hosts. If you do not specify this keyword, the command displays IGMP host tracking information for all hosts.
# Display IGMP tracking information for all hosts.
<Sysname> display igmp host-tracking
IGMP hosts in total: 4
 HundredGigE1/0/1(192.168.1.1):
  IGMP hosts reported in total: 2
   (0.0.0.0,224.1.1.1)
    Host                            Uptime          Expires
    192.168.1.1                     00:02:20        00:00:40
    192.168.1.2                     00:02:21        00:00:39
 HundredGigE1/0/2(192.168.2.1):
   (1.1.1.1,224.1.1.1)
    Host                            Uptime          Expires       Type
    192.168.2.1                     00:03:20        Expired       G
    192.168.2.2                     00:02:20        00:00:39      G
# Display IGMP tracking information for hosts that have joined multicast group 232.1.1.1 on HundredGigE1/0/1.
<Sysname> display igmp host-tracking interface hundredgige 1/0/1 group 232.1.1.1
  IGMP hosts reported in total: 5
   (1.1.1.1,232.1.1.1)
    192.168.1.1                     00:02:20        00:00:40      M
    192.168.1.2                     00:02:21        00:00:39      M
   (2.2.2.2,232.1.1.1)
    192.168.1.1                     00:02:20        00:00:40      G/M
    192.168.1.2                     00:02:21        00:00:39      G/M
    192.168.1.3                     00:02:21        00:00:39      G/M
# Display IGMP tracking information for active hosts on HundredGigE1/0/1.
<Sysname> display igmp host-tracking interface hundredgige 1/0/1 active
   (1.1.1.1, 224.1.1.1)
   (1.1.1.1, 225.1.1.1)
IGMP hosts in total
Tracked hosts in total.
Interface name and IP address.
Number of tracked hosts on the interface.
(0.0.0.0, 224.1.1.1)
(S, G) entry. Value 0.0.0.0 in the S position indicates all multicast sources.
Host
IP address of the host.
Uptime
Length of time elapsed since the host joined the multicast group.
Expires
Remaining timeout time for the host. The host timeout time is the same as the aging timer for the port. The timer is reset when the port receives an IGMP report from the host.
This field displays Expired if the host timed out.
IGMP version:
·     G—The IGMP version is IGMPv3 and the host joins the multicast group normally.
·     M—The IGMP version is IGMPv1 or IGMPv2, and the host joins the multicast group through the SSM mapping.
·     G/M—Both of the above conditions exist at the same time.
This field is not displayed if the IGMP version is IGMPv1 or IGMPv2, and the host joins the multicast group without the SSM mapping.
host-tracking enable
igmp host-tracking { disable | enable }
display igmp interface
Use display igmp interface to display IGMP information for interfaces.
display igmp interface[ interface-type interface-number ] [ host | proxy ] [ verbose ]
host: Displays information about the interfaces enabled with the IGMP host feature. For more information about the IGMP host feature, see VXLAN Configuration Guide.
proxy: Displays the IGMP proxy interface information.
verbose: Displays detailed IGMP information.
If you do not specify any parameters, this command displays IGMP information for all interfaces.
# Display detailed IGMP information for HundredGigE 1/0/1.3 (non-proxy interface) on the public network.
<Sysname> display igmp interface hundredgige 1/0/1.3 verbose
 HundredGigE1/0/1.3(10.10.1.20):
   IGMP is enabled.
   IGMP version: 2
   Query interval for IGMP: 125s
   Other querier present time for IGMP: 255s
   Maximum query response time for IGMP: 10s
   Last member query interval: 1s
   Last member query count: 2
   Startup query interval: 31s
   Startup query count: 2
   General query timer expiry (hh:mm:ss): 00:00:54
   Querier for IGMP: 10.10.1.20 (This router)
   IGMP activity: 1 join(s), 0 leave(s)
   Multicast routing on this interface: Enabled
   Robustness: 2
   Require-router-alert: Disabled
   Fast-leave: Disabled
   Startup-query: Off
   Other-querier-present-timer-expiry (hh:mm:ss): Off
  IGMP groups reported in total: 1
# Display detailed IGMP information for all IGMP proxy interfaces on the public network.
<Sysname> display igmp interface proxy verbose
 HundredGigE1/0/2(20.10.1.20):
   IGMP proxy is enabled.
   IGMP version: 2
   Version1-querier-present-timer-expiry (hh:mm:ss): Off
# Display detailed IGMP information for all interfaces enabled with the IGMP host feature on the public network.
<Sysname> display igmp interface host verbose
 HundredGigE1/0/3(30.10.1.20):
   IGMP host is enabled.
   IGMP version: 2
Table 5 Command output
Interface and its IP address.
IGMP is enabled
IGMP is enabled on the interface.
IGMP version
Version of IGMP that the interface runs.
IGMP general query interval, in seconds.
IGMP other querier present interval, in seconds.
Maximum response time for IGMP general queries, in seconds.
Interval for sending IGMP group-specific queries or IGMP group-and-source-specific queries, in seconds.
Number of IGMP group-specific queries or IGMP group-and-source-specific queries sent for the multicast group.
Interval for sending IGMP general queries on startup, in seconds.
Startup query count
Number of IGMP general queries that the device sends on startup.
Remaining time for the IGMP general query timer. This field displays Off if the timer is disabled.
Querier for IGMP
IP address of the IGMP querier.
This field is not displayed when the device runs IGMPv1 and the device is not the IGMP querier.
In IGMPv1, the PIM DR acts as the IGMP querier. You can use the display pim interface command to display PIM information.
No querier elected
No IGMP querier election is performed.
This field is displayed when the device runs IGMPv1 and is not the IGMP querier.
Statistics of IGMP activities:
·     join(s)—Total number of multicast groups that this interface has joined.
·     leave(s)—Total number of multicast groups that this interface has left.
Whether IP multicast routing is enabled: Enabled or Disabled.
Robustness
Robustness variable of the IGMP querier.
Whether the feature of dropping IGMP messages without Router-Alert is enabled: Enabled or Disabled,
Fast-leave
Whether the fast-leave processing feature is enabled: Enabled or Disabled.
Startup-query
Whether the IGMP querier sends IGMP general queries at the startup query interval on startup:
·     OnThe IGMP querier performs the above action.
·     OffThe IGMP querier does not perform the above action.
Remaining time for the other querier present timer. This field displays Off if the timer is disabled.
Total number of multicast groups that the interface has joined dynamically.
This field is not displayed if the interface does not join multicast groups.
IGMP proxying is enabled on the interface.
The IGMP host feature is enabled on the interface.
Remaining time for the IGMPv1 querier present timer. This field displays Off if the timer is disabled.
display igmp proxy group
Use display igmp proxy group to display information about multicast groups maintained by the IGMP proxy.
display igmp proxy group [ group-address | interface interface-type interface-number ] [ verbose ]
group-address: Specifies a multicast group by its IP address in the range of 224.0.1.0 to 239.255.255.255. If you do not specify a multicast group, this command displays information about all multicast groups maintained by the IGMP proxy.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays information about multicast groups maintained by the IGMP proxy for all interfaces.
# Display information about multicast groups maintained by the IGMP proxy on the public network.
<Sysname> display igmp proxy group
IGMP proxy group records in total: 2
 HundredGigE1/0/1(1.1.1.20):
   Group address      Member state      Expires
   225.1.1.1          Delay             00:00:02
   225.1.1.2          Idle              Off
# Display detailed information about multicast group 225.1.1.1 maintained by the IGMP proxy on the public network.
<Sysname> display igmp proxy group 225.1.1.1 verbose
   Group: 225.1.1.1
     Group mode: Include
     Member state: Delay
     Expires: 00:00:02
       1.1.1.1
Table 6 Command output
IGMP groups records in total
Total number of multicast groups maintained by the IGMP proxy.
IGMP proxy interface and its IP address.
Pending proxy group
Pending multicast groups maintained by the IGMP proxy.
Group address/Group
Member state
Member host states:
·     Delay—The member host has joined a group and started a delay timer.
·     Idle—The member host has joined a group, but didn't start a delay timer.
Expires
Remaining delay time for the member host to send a responding report. This field displays Off if the timer is disabled.
Group mode
Multicast source filtering mode: Include or Exclude.
Source list
Multicast source list for the multicast group maintained by the IGMP proxy.
sources in total
Total number of multicast sources.
display igmp proxy routing-table
Use display igmp proxy routing-table to display multicast routing entries maintained by the IGMP proxy.
display igmp proxy routing-table [ source-address [ mask { mask-length | mask } ] | group-address [ mask { mask-length | mask } ] ] * [ verbose ]
source-address: Specifies a multicast source by its IP address. If you do not specify a multicast source, this command displays multicast routing entries for all multicast sources maintained by the IGMP proxy.
group-address: Specifies a multicast group address by its IP address in the range of 224.0.1.0 to 239.255.255.255. If you do not specify a multicast group, this command displays multicast routing entries for all multicast groups maintained by the IGMP proxy.
mask-length: Specifies a mask length of the multicast group address or multicast source address. For a multicast source address, the value range for this argument is 0 to 32. For a multicast group address, the value range for this argument is 4 to 32. The default value is 32 in both cases.
mask: Specifies a mask of the multicast group address or multicast source address. The default value is 255.255.255.255.
verbose: Displays detailed information about multicast routing entries maintained by the IGMP proxy.
# Display multicast routing entries maintained by the IGMP proxy on the public network.
<Sysname> display igmp proxy routing-table
 Total 1 (*, G) entries, 2 (S, G) entries.
 (172.168.0.12, 227.0.0.1)
     Upstream interface: HundredGigE1/0/1
     Downstream interfaces (1 in total):
         1: HundredGigE1/0/2
             Protocol: IGMP
(*, 225.1.1.1)
         1: HundredGigE1/0/2
             Protocol: STATIC
  (2.2.2.2, 225.1.1.1)
     Downstream interfaces (2 in total):
         1: LoopBack1
             Protocol: STATIC
         2: HundredGigE1/0/2
             Protocol: PROXY
# Display detailed information about multicast routing entries maintained by the IGMP proxy on the public network.
<Sysname> display igmp proxy routing-table verbose
         1: HundredGigE1/0/2
             Protocol: IGMP
             Querier state: Querier
             Join/Prune state:Join
     Non-downstream interfaces: None
 (*, 225.1.1.1)
         1: HundredGigE1/0/2
             Protocol: STATIC
     Non-downstream interfaces (1 in total):
         1: HundredGigE1/0/2
             Protocol: IGMP
             Querier state: Non-querier
         1: LoopBack1
             Protocol: STATIC
             Join/Prune state: Join
         2: HundredGigE1/0/2
             Protocol: PROXY
Table 7 Command output
Total number of (*, G) entries, and the total number of (S, G) entries.
(S, G) entry.
Upstream interface
Incoming interface of the (S, G) entry.
Outgoing interfaces of the (S, G) entry, and the total number of outgoing interfaces.
Non-outgoing interfaces of the (S, G) entry, and the total number of non-outgoing interfaces.
1: HundredGigE1/0/2
Index of an interface, and the interface.
Protocol
Protocol type:
·     IGMP—Dynamic IGMP.
·     PROXY—IGMP proxy.
·     STATIC—Static IGMP.
Querier state
Querier state:
·     Querier.
·     Non-querier.
Join/Prune state
Joined or pruned state of the interface:
·     NI—Default state.
·     Join—Joined state.
·     Prune—Pruned state.
display igmp ssm-mapping
Use display igmp ssm-mapping to display IGMP SSM mappings.
display igmp ssm-mapping group-address
# Display IGMP SSM mappings for multicast group 232.1.1.1 on the public network.
<Sysname> display igmp ssm-mapping 232.1.1.1
 Group: 232.1.1.1
 Source list:
        1.2.3.4
        5.5.5.5
        10.1.1.1
        100.1.1.10
Table 8 Command output
Group
Source list
List of multicast source addresses.
Use host-tracking enable to enable IGMP host tracking globally.
Use undo host-tracking enable to disable IGMP host tracking globally.
IGMP host tracking is disabled globally.
IGMP view
This feature allows the device to record IP addresses, running time, timeout time, and other information about receiver hosts. You can monitor and manage receiver hosts based on the recorded information.
You can enable IGMP host tracking globally for all interfaces, or use the igmp host-tracking enable command in interface view to enable host tracking for an interface. For an interface, the interface-specific configuration has higher priority than the global configuration.
# Enable IGMP host tracking globally on the public network.
[Sysname] igmp
[Sysname-igmp] host-tracking enable
igmp host-tracking enable { disable | enable }
igmp
Use igmp to enter IGMP view.
Use undo igmp to delete the configurations in IGMP view.
igmp
undo igmp
# Enter IGMP view for the public network.
[Sysname] igmp
[Sysname-igmp]
igmp enable
Use igmp enable to enable IGMP on an interface.
Use undo igmp enable to disable IGMP on an interface.
igmp enable
undo igmp enable
IGMP is disabled on an interface.
Interface view
This command takes effect only when IP multicast routing is enabled on the public network or for the VPN instance to which the interface belongs.
Other IGMP configurations on the interface take effects only when IGMP is enabled on the interface.
# Enable IP multicast routing on the public network, and enable IGMP on HundredGigE 1/0/1.
[Sysname] multicast routing
[Sysname-mrib] quit
[Sysname-HundredGigE1/0/1] igmp enable
multicast routing
igmp fast-leave
Use igmp fast-leave to enable fast-leave processing on an interface.
Use undo igmp fast-leave to disable fast-leave processing on an interface.
igmp fast-leave [ group-policy ipv4-acl-number ]
Fast-leave processing is disabled. The IGMP querier sends IGMP group-specific or group-and-source-specific queries after receiving a leave message.
Interface view
ipv4-acl-number: Specifies an IPv4 basic ACL by its number in the range of 2000 to 2999. If you specify an ACL, the fast-leave processing feature takes effect only on the multicast groups that the ACL permits. The feature takes effect on all multicast groups when one of the following conditions exists:
·     You do not specify an ACL.
·     The specified ACL does not exist.
·     The specified ACL does not have valid rules.
The fast-leave processing feature enables an IGMP querier to suppress IGMP group-specific or group-and-source-specific queries upon receiving IGMP leave messages permitted by the ACL.
When you configure a rule in the IPv4 basic ACL, follow these restrictions and guidelines:
·     The source source-address source-wildcard option specifies a multicast group address.
·     Among the other optional parameters, only the fragment keyword and the time-range time-range-name option take effect.
# Enable fast-leave processing on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] igmp fast-leave
igmp group-policy
Use igmp group-policy to configure a multicast group policy on an interface to control the multicast groups that hosts attached to the interface can join.
Use undo igmp group-policy to delete the multicast group policy on an interface.
igmp group-policy ipv4-acl-number [ version-number ]
No multicast group policy exists on an interface. Hosts attached to the interface can join any multicast groups.
Interface view
ipv4-acl-number: Specifies an IPv4 basic or advanced ACL by its number in the range of 2000 to 3999. Hosts can join only the multicast groups that the ACL permits. If the ACL does not exist or does not have valid rules, hosts cannot join any multicast groups.
version-number: Specifies an IGMP version in the range of 1 to 3. By default, this command takes effect on IGMP reports of all versions.
A multicast group policy filters IGMP reports to control the multicast groups that the hosts can join.
This command does not take effect on static member interfaces because static member interfaces do not send IGMP reports.
When you configure a rule in the IPv4 ACL, follow these restrictions and guidelines:
·     In a basic ACL, the source source-address source-wildcard option specifies a multicast group address.
·     In an advanced ACL, the source source-address source-wildcard option specifies a multicast source address. The destination dest-address dest-wildcard option specifies a multicast group address.
To match the following IGMP reports, set the source source-address source-wildcard option to 0.0.0.0:
¡     IGMPv1 and IGMPv2 reports.
¡     IGMPv3 IS_EX and IGMPv3 TO_EX reports that do not carry multicast source addresses.
# Configure a multicast group policy on HundredGigE 1/0/1 so that hosts attached to the interface can join only multicast group 225.1.1.1.
[Sysname] acl basic 2005
[Sysname-acl-ipv4-basic-2005] rule permit source 225.1.1.1 0
[Sysname-acl-ipv4-basic-2005] quit
[Sysname-HundredGigE1/0/1] igmp group-policy 2005
Use igmp host-tracking enable to enable IGMP host tracking on an interface.
Use igmp host-tracking disable to disable IGMP host tracking on an interface.
Use undo igmp host-tracking to restore the default.
The interface-specific IGMP host tracking status is consistent with the global IGMP host tracking status.
Interface view
You can enable IGMP host tracking on an interface, or use the host-tracking enable command in IGMP view to enable IGMP host tracking for all interfaces. For an interface, the interface-specific configuration has higher priority than the global configuration.
# Enable IGMP host tracking on HundredGigE1/0/1.
[Sysname-HundredGigE1/0/1] igmp host-tracking enable
host-tracking enable (IGMP view)
igmp host-tracking limit
Use igmp host-tracking limit to set the maximum number of hosts that can be tracked on an interface.
Use undo igmp host-tracking limit to restore the default.
igmp host-tracking limit limit
An interface can track a maximum of 4096 hosts.
Interface view
limit: Specifies the maximum number of hosts that can be tracked on an interface, in the range of 1 to 65535.
If you execute this command multiple times, the most recent configuration takes effect. When the maximum number is reached, new host records overwrite old ones.
# Set the maximum number to 2000 for hosts that can be tracked on HundredGigE1/0/1.
[Sysname-HundredGigE1/0/1] igmp host-tracking limit 2000
igmp last-member-query-count
Use igmp last-member-query-count to set the IGMP last member query count on an interface.
Use undo igmp last-member-query-count to restore the default.
igmp last-member-query-count count
The IGMP last member query count equals the IGMP querier's robustness variable.
Interface view
count: Specifies an IGMP last member query count in the range of 1 to 255.
You can set the IGMP last member query count for an interface in interface view or globally for all interfaces in IGMP view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the IGMP last member query count to 6 on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] igmp last-member-query-count 6
last-member-query-count (IGMP view)
igmp last-member-query-interval
Use igmp last-member-query-interval to set the IGMP last member query interval on an interface.
Use undo igmp last-member-query-interval to restore the default.
igmp last-member-query-interval interval
The IGMP last member query interval is 1 second.
Interface view
interval: Specifies an IGMP last member query interval in the range of 1 to 25 seconds.
You can set the IGMP last member query interval for an interface in interface view or globally for all interfaces in IGMP view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the IGMP last member query interval to 6 seconds on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] igmp last-member-query-interval 6
last-member-query-interval (IGMP view)
igmp max-response-time
Use igmp max-response-time to set the maximum response time for IGMP general queries on an interface.
Use undo igmp max-response-time to restore the default.
igmp max-response-time time
The maximum response time for IGMP general queries is 10 seconds.
Interface view
time: Specifies the maximum response time for IGMP general queries, in the range of 1 to 3174 seconds.
You can set the maximum response time for an interface in interface view or globally for all interfaces in IGMP view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the maximum response time for IGMP general queries to 25 seconds on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] igmp max-response-time 25
max-response-time (IGMP view)
igmp non-stop-routing
Use igmp non-stop-routing to enable IGMP NSR.
Use undo igmp non-stop-routing to disable IGMP NSR.
IGMP NSR is disabled.
# Enable IGMP NSR.
[Sysname] igmp non-stop-routing
igmp other-querier-present-interval
Use igmp other-querier-present-interval to set the IGMP other querier present timer on an interface.
Use undo igmp other-querier-present-interval to restore the default.
igmp other-querier-present-interval interval
The IGMP other querier present timer is calculated by using the following formula:
[ IGMP general query interval ] × [ IGMP querier's robustness variable ] + [ maximum response time for IGMP general queries ] / 2.
Interface view
interval: Specifies an IGMP other querier present timer in the range of 1 to 31744 seconds.
You can set the IGMP other querier present timer for an interface in interface view or globally for all interfaces in IGMP view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the IGMP other querier present timer to 125 seconds on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] igmp other-querier-present-interval 125
other-querier-present-interval (IGMP view)
igmp proxy enable
Use igmp proxy enable to enable IGMP proxying on an interface.
Use to undo igmp proxy enable to disable IGMP proxying on an interface.
igmp proxy enable
IGMP proxying is disabled on an interface.
Interface view
This command takes effect only when IP multicast routing is enabled on the public network.
# Enable IP multicast routing on the public network, and enable IGMP proxying on HundredGigE 1/0/1.
[Sysname] multicast routing-enable
[Sysname-HundredGigE1/0/1] igmp proxy enable
multicast routing
igmp proxy forwarding
Use igmp proxy forwarding to enable multicast forwarding on a non-querier interface.
Use undo igmp proxy forwarding to disable multicast forwarding on a non-querier interface.
Multicast forwarding is disabled for a non-querier interface.
Interface view
Typically, only IGMP queriers can forward multicast traffic but non-queriers cannot. This mechanism prevents multicast data from being repeatedly forwarded. If a router interface on the IGMP proxy failed the querier election, enable multicast forwarding on the interface to forward multicast data to attached receivers.
# Enable multicast forwarding on HundredGigE 1/0/1. (HundredGigE 1/0/1 is a non-querier interface on the IGMP proxy device.)
[Sysname-HundredGigE1/0/1] igmp proxy forwarding
igmp query-interval
Use igmp query-interval to set the IGMP general query interval on an interface.
Use undo igmp query-interval to restore the default.
igmp query-interval interval
The IGMP general query interval is 125 seconds.
Interface view
interval: Specifies an IGMP general query interval in the range of 1 to 31744 seconds.
You can set the IGMP general query interval for an interface in interface view or globally for all interfaces in IGMP view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the IGMP general query interval to 60 seconds on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] igmp query-interval 60
igmp robust-count
Use igmp robust-count to set the IGMP querier's robustness variable on an interface.
Use undo igmp robust-count to restore the default.
igmp robust-count count
The IGMP querier's robustness variable is 2.
Interface view
count: Specifies an IGMP querier's robustness variable in the range of 1 to 255.
The IGMP querier's robustness variable defines the number of times to retransmit queries if packet loss occurs. A higher robustness variable makes the IGMP querier more robust, but it increases timeout time for multicast groups.
You can set the IGMP querier's robustness variable for an interface in interface view or globally for all interfaces in IGMP view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the IGMP querier's robustness variable to 5 on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] igmp robust-count 5
robust-count (IGMP view)
igmp startup-query-count
Use igmp startup-query-count to set the IGMP startup query count on an interface.
Use undo igmp startup-query-count to restore the default.
igmp startup-query-count count
The IGMP startup query count equals the IGMP querier's robustness variable.
Interface view
count: Specifies an IGMP startup query count in the range of 1 to 255.
You can set the IGMP startup query count for an interface in interface view or globally for all interfaces in IGMP view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the IGMP startup query count to 5 on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] igmp startup-query-count 5
startup-query-count (IGMP view)
igmp startup-query-interval
Use igmp startup-query-interval to set the IGMP startup query interval on an interface.
Use undo igmp startup-query-interval to restore the default.
igmp startup-query-interval interval
The IGMP startup query interval equals one quarter of the IGMP general query interval.
Interface view
interval: Specifies an IGMP startup query interval in the range of 1 to 31744 seconds.
You can set the IGMP startup query interval for an interface in interface view or globally for all interfaces in IGMP view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the IGMP startup query interval to 100 seconds on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] igmp startup-query-interval 100
startup-query-interval (IGMP view)
igmp static-group
Use igmp static-group to configure an interface as a static group member of a multicast group.
Use undo igmp static-group to restore the default.
igmp static-group group-address [ source source-address ]
undo igmp static-group { all | group-address [ source source-address ]}
An interface is not a static group member of multicast groups.
Interface view
source-address: Specifies a multicast source by its IP address. If you do not specify a multicast source, this command configures an interface as a static member of the multicast groups with all multicast source addresses.
dot1q vid vlan-id second-dot1q vlan-list: Specifies the outer and inner VLAN IDs. The vlan-id argument specifies the outer VLAN ID in the range of 1 to 4094. The vlan-list argument specifies a space-separated list of up to 10 inner VLAN ID items. Each item specifies an inner VLAN ID or a range of inner VLAN IDs in the form of start-vlan-id to end-vlan-id. The value range for VLAN IDs is 1 to 4094. If you specify this option, the command configures an interface as a double-VLAN-tagged static member interface for a multicast group. This option is supported in Layer 3 Ethernet subinterface view and Layer 3 aggregate subinterface view.
all: Specifies all multicast groups that the interface has statically joined.
For multicast routing entries to be created, you must specify a multicast source if the specified multicast group is in the SSM group range.
# Configure HundredGigE 1/0/1 as a static group member of multicast group 224.1.1.1.
[Sysname-HundredGigE1/0/1] igmp static-group 224.1.1.1
# Configure HundredGigE 1/0/1 as a static group member of multicast source and group (192.168.1.1, 232.1.1.1).
[Sysname-HundredGigE1/0/1] igmp static-group 232.1.1.1 source 192.168.1.1
igmp version
Use igmp version to specify an IGMP version on an interface.
Use undo igmp version to restore the default.
igmp version version-number
undo igmp version
The IGMP version on an interface is 2.
Interface view
CAUTION
CAUTION:
For IGMP to operate correctly, specify the same IGMP version for all routers on the same subnet.
# Specify IGMP version 1 on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] igmp version 1
Use last-member-query-count to set the IGMP last member query count globally.
Use undo last-member-query-count to restore the default.
IGMP view
You can set the IGMP last member query count globally for all interfaces in IGMP view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the global IGMP last member query count to 6 on the public network.
[Sysname] igmp
[Sysname-igmp] last-member-query-count 6
Use last-member-query-interval to set the IGMP last member query interval globally.
Use undo last-member-query-interval to restore the default.
IGMP view
You can set the IGMP last member query interval globally for all interfaces in IGMP view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the global IGMP last member query interval to 6 seconds on the public network.
[Sysname] igmp
[Sysname-igmp] last-member-query-interval 6
Use max-response-time to set the maximum response time for IGMP general queries globally.
Use undo max-response-time to restore the default.
IGMP view
time: Specifies the maximum response time for IGMP general queries in the range of 1 to 3174 seconds.
You can set the maximum response time globally for all interfaces in IGMP view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
#Set the global maximum response time for IGMP general queries to 25 seconds on the public network.
[Sysname] igmp
[Sysname-igmp] max-response-time 25
Use other-querier-present-interval to set the IGMP other querier present timer globally.
Use undo other-querier-present-interval to restore the default.
IGMP view
You can set the IGMP other querier present timer globally for all interfaces in IGMP view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the global IGMP other querier present timer to 125 seconds on the public network.
[Sysname] igmp
[Sysname-igmp] other-querier-present-interval 125
proxy multipath (IGMP view)
Use proxy multipath to enable load splitting on an IGMP proxy device.
Use undo proxy multipath to disable load splitting on an IGMP proxy device.
proxy multipath
The load splitting feature is disabled on the IGMP proxy device.
IGMP view
Use this feature when the IGMP proxy device has multiple proxy interfaces. All proxy interfaces on the IGMP proxy device share multicast traffic on a per-group basis. If you do not enable this feature, only the proxy interface with the highest IP address forwards multicast data.
# Enable load splitting on the IGMP proxy device on the public network.
[Sysname] igmp
[Sysname-igmp] proxy multipath
Use query-interval to set the IGMP general query interval globally.
Use undo query-interval to restore the default.
undo query-interval
IGMP view
You can set the IGMP general query interval globally for all interfaces in IGMP view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the global IGMP general query interval to 60 seconds on the public network.
[Sysname] igmp
[Sysname-igmp] query-interval 60
igmp query-interval
reset igmp group
Use reset igmp group to clear dynamic IGMP multicast group entries.
reset igmp group { all | interface interface-type interface-number { all | group-address [ mask { mask | mask-length } ] [ source-address [ mask { mask | mask-length } ] ] } }
all: Specifies all interfaces (the first all keyword), or all IGMP multicast groups (the second all keyword).
source-address: Specifies a multicast source address. If you do not specify a multicast source, this command clears dynamic IGMP multicast group entries for all multicast source addresses.
mask: Specifies an address mask. The default is 255.255.255.255.
mask-length: Specifies an address mask length. The default is 32. For a multicast group address, the value range for this argument is 4 to 32. For a multicast source address, the value range for this argument is 0 to 32.
CAUTION
CAUTION:
This command might cause multicast data transmission failures.
# Clear dynamic IGMP multicast group entries for all interfaces on the public network.
<Sysname> reset igmp group all
# Clear all dynamic IGMP multicast group entries for HundredGigE 1/0/1 on the public network.
<Sysname> reset igmp group interface hundredgige 1/0/1 all
# Clear the dynamic IGMP multicast group entry of group 225.0.0.1 for HundredGigE 1/0/1 on the public network.
<Sysname> reset igmp group interface hundredgige 1/0/1 225.0.0.1
display igmp group
Use robust-count to set the IGMP querier's robustness variable globally.
Use undo robust-count to restore the default.
robust-count count
undo robust-count
IGMP view
The IGMP querier's robustness variable defines the number of times to retransmit queries if packet loss occurs. A higher robustness variable makes the IGMP querier more robust, but it increases the timeout time for multicast groups.
You can set the IGMP querier's robustness variable globally for all interfaces in IGMP view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the global IGMP querier's robustness variable to 5 on the public network.
[Sysname] igmp
[Sysname-igmp] robust-count 5
igmp robust-count
ssm-mapping (IGMP view)
Use ssm-mapping to configure an IGMP SSM mapping.
Use undo ssm-mapping to delete IGMP SSM mappings.
ssm-mapping source-address ipv4-acl-number
undo ssm-mapping { source-address | all }
No IGMP SSM mappings exist.
IGMP view
ipv4-acl-number: Specifies a basic ACL number in the range of 2000 to 2999. Multicast groups in IGMP reports permitted by the ACL are associated with the IPv6 multicast source. If the ACL does not exist or does not have valid rules, no multicast groups are associated with the IPv6 multicast source.
all: Specifies all IGMP SSM mappings.
# Configure an IGMP SSM mapping with multicast source 125.1.1.1 and multicast group range 232.1.1.0/24 on the public network.
[Sysname] acl basic 2001
[Sysname-acl-ipv4-basic-2001] rule permit source 232.1.1.1 0.0.0.255
[Sysname] igmp
[Sysname-igmp] ssm-mapping 125.1.1.1 2001
Use startup-query-count to set the IGMP startup query count globally.
Use undo startup-query-count to restore the default.
IGMP view
You can set the IGMP startup query count globally for all interfaces in IGMP view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the global IGMP startup query count to 5 on the public network.
[Sysname] igmp
[Sysname-igmp] startup-query-count 5
Use startup-query-interval to set the IGMP startup query interval globally.
Use undo startup-query-interval to restore the default.
IGMP view
You can set the IGMP startup query interval globally for all interfaces in IGMP view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the global IGMP startup query interval to 100 seconds on the public network.
[Sysname] igmp
[Sysname-igmp] startup-query-interval 100
