00-Preface | 102.25 KB |
Preface
This configuration guide describes network management and monitoring configuration procedures. It describes how to manage and monitor the network, view system information, collect traffic statistics, analyze network quality, synchronize system clocks for network devices, and use the ping, tracert, and debugging commands to examine and debug network connectivity.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the S6880 and S9820-8M switch series.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
