06-Layer 3—IP Routing Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C S9820-8M[S6880] Configuration Guides-R1116Pxx-6W10006-Layer 3—IP Routing Configuration Guide
08-Policy-based routing configuration
08-Policy-based routing configuration 131.11 KB
Configuring PBR
About PBR
Policy-based routing (PBR) uses user-defined policies to route packets. A policy can specify parameters for packets that match specific criteria such as ACLs. The parameters include the next hop.
Packet forwarding process
When the device receives a packet, the device searches the PBR policy for a matching node to forward that packet.
·     If a matching node is found and its match mode is permit, the device performs the following operations:
a.     Uses the next hops specified on the node to forward the packet.
b.     Searches the routing table for a route to forward the packet if one of the following conditions exists:
-     No next hops are specified on the node.
-     Forwarding failed based on the next hops.
·     The device performs routing table lookup to forward the packet in either of the following conditions:
¡     No matching node is found.
¡     A matching node is found, but its match mode is deny.
PBR types
PBR includes the following types:
·     Local PBR—Guides the forwarding of locally generated packets, such as ICMP packets generated by using the ping command.
·     Interface PBR—Guides the forwarding of packets received on an interface.
Policy
A policy includes match criteria and actions to be taken on the matching packets. A policy can have one or multiple nodes as follows:
·     Each node is identified by a node number. A smaller node number has a higher priority.
·     A node contains if-match and apply clauses. An if-match clause specifies a match criterion, and an apply clause specifies an action.
·     A node has a match mode of permit or deny.
A policy compares packets with nodes in priority order. If a packet matches the criteria on a node, it is processed by the action on the node. If the packet does not match any criteria on the node, it goes to the next node for a match. If the packet does not match the criteria on any node, the device performs a routing table lookup.
Relationship between if-match clauses
Only the if-match acl clause is supported. On a node, you can specify only one if-match acl clause.
Relationship between apply clauses
You can specify multiple apply clauses for a node, but some of them might not be executed. For more information about relationship between apply clauses, see "Configuring actions for a node."
Relationship between the match mode and clauses on the node
Does a packet match all the if-match clauses on the node?
Match mode
Permit
Deny
Yes.
·     If the node contains apply clauses, PBR executes the apply clauses on the node.
¡     If PBR-based forwarding succeeds, PBR does not compare the packet with the next node.
¡     If PBR-based forwarding fails, PBR does not compare the packet with the next node.
·     If the node does not contain apply clauses, the device performs a routing table lookup for the packet.
The device performs a routing table lookup for the packet.
No.
PBR compares the packet with the next node.
A node that has no if-match clauses matches any packet.
PBR and Track
PBR can work with the Track feature to dynamically adapt the availability status of an apply clause to the link status of a tracked object. The tracked object can be a next hop.
·     When the track entry associated with an object changes to Negative, the apply clause is invalid.
·     When the track entry changes to Positive or NotReady, the apply clause is valid.
For more information about Track-PBR collaboration, see High Availability Configuration Guide.
Restrictions and guidelines: PBR configuration
If a packet destined for the local device matches a PBR policy, PBR will execute the apply clauses in the policy, including the clause for forwarding. When you configure a PBR policy, be careful to avoid this situation.
PBR tasks at a glance
To configure PBR, perform the following tasks:
1.     Configuring a policy
a.     Creating a node
b.     Setting match criteria for a node
c.     Configuring actions for a node
2.     Specifying a policy for PBR
¡     Specifying a policy for local PBR
¡     Specifying a policy for interface PBR
¡     Specifying a policy for global PBR
3.     (Optional.) Enabling the PBR logging feature
Creating a node
2.     Create a node for a policy, and enter its view.
3.     (Optional.) Configure a description for the policy node.
By default, no description is configured for a policy node.
2.     Enter policy node view.
3.     Set match criteria.
¡     Set an ACL match criterion.
By default, no ACL match criterion is set.
The ACL match criterion cannot match Layer 2 information.
When using the ACL to match packets, interface PBR ignores the action (permit or deny) in the ACL.
For packets matching the deny statement in the ACL, local PBR does not execute the apply clause configured on the node. Instead, it compares the packets with the next node.
The apply clauses allow you to specify the actions to be taken on matching packets on a node.
The following apply clauses determine the packet forwarding paths in a descending order:
·     apply next-hop
·     apply output-interface
PBR supports the types of apply clauses shown in Table 1.
Table 1 Priorities and meanings of apply clauses
Clause
Meaning
Priority
apply loadshare next-hop
Enables load sharing among multiple next hops.
Multiple next hop options operate in either primary/backup or load sharing mode.
·     Primary/backup mode—A next hop is selected from all next hops in configuration order for packet forwarding, with all remaining next hops as backups. When the selected next hop fails, the next available next hop takes over.
·     Load sharing mode—Matching traffic is distributed across the available next hops. If the traffic does not match any fast forwarding entries, per-packet load sharing is performed. If the traffic matches a fast forwarding entry, per-flow load sharing is performed.
By default, the primary/backup mode applies.
For the load sharing mode to take effect, make sure multiple next hops are set in the policy.
apply next-hop and apply output-interface
Sets next hops  and output interfaces.
If multiple clauses are configured, only the clause with the highest priority is executed.
apply statistics
Counts successful matches and matching bytes on the policy node.
To include the number of successful matches and matching bytes on a policy node in the statistics displayed by a display command, execute this command.
This clause is always executed for matching packets.
If you specify a next hop or default next hop, PBR periodically performs a lookup in the FIB table to determine its availability. Temporary service interruption might occur if PBR does not update the route immediately after its availability status changes.
Configuring actions to direct packet forwarding
3.     Configure actions.
¡     Set next hops.
apply next-hop [ vpn-instance vpn-instance-name ] { ip-address [ direct ] [ track track-entry-number ] }&<1-2>
By default, no next hops are specified.
On a node, you can specify a maximum of two next hops for backup or load sharing in one command line or by executing this command multiple times.
If multiple next hops on the same subnet are specified for backup, the device first uses the subnet route for the next hops to forward packets when the primary next hop fails. If the subnet route is not available, the device selects a backup next hop.
¡     Enable load sharing among multiple next hops.
By default, the next hops operate in primary/backup mode.
¡     Set output interfaces.
apply output-interface NULL 0
By default, no output interfaces are specified.
Collecting policy node statistics
3.     Count successful matches and matching bytes on the policy node.
apply statistics
By default, match counting is disabled on a policy node.
Perform this task to specify a policy for local PBR to guide the forwarding of locally generated packets.
You can specify only one policy for local PBR and must make sure the specified policy already exists. Before you apply a new policy, you must first remove the current policy.
Local PBR might affect local services such as ping and Telnet. When you use local PBR, make sure you fully understand its impact on local services of the device.
2.     Specify a policy for local PBR.
ip local policy-based-route policy-name
By default, local PBR is not enabled.
Perform this task to apply a policy to an interface to guide the forwarding of packets received on the interface.
You can apply only one policy to an interface and must make sure the specified policy already exists. Before you can apply a new interface PBR policy to an interface, you must first remove the current policy from the interface.
You can apply a policy to multiple interfaces.
2.     Enter interface view.
3.     Specify a policy for interface PBR.
ip policy-based-route policy-name
By default, no interface policy is applied to an interface.
Perform this task to apply a policy to all interfaces on the device to guide the forwarding of packets received on the interfaces.
You can apply only one policy for global PBR and the specified policy must already exist. Before you can apply a new policy, you must first remove the current policy.
Interface PBR takes precedence over global PBR on an interface. When they are both configured and packets fail to match the interface PBR policy, global PBR applies.
2.     Specify a policy for global PBR.
ip global policy-based-route policy-name
By default, no policy is specified for global PBR.
The PBR logging feature helps the administrator locate and fix faults. The feature logs PBR events and sends the logs to the information center. The information center processes the logs according to output rules. For more information about the information center, see System Management Configuration Guide.
2.     Enable the PBR logging feature.
ip policy-based-route-log enable
By default, the PBR logging feature is disabled.
Verifying and maintaining PBR
Verifying PBR policy configuration
To display PBR policy information, execute the following command in any view:
display ip policy-based-route [ policy policy-name ]
Displaying PBR configuration and statistics
·     Display PBR configuration.
display ip policy-based-route setup
·     Display local PBR configuration and statistics.
display ip policy-based-route local [ slot slot-number ]
·     Display global PBR configuration and statistics
display ip policy-based-route global [ slot slot-number ]
·     Display interface PBR configuration and statistics.
display ip policy-based-route interface interface-type interface-number [ slot slot-number ]
Clearing PBR statistics
To clear PBR statistics, execute the following command in user view:
reset ip policy-based-route statistics [ policy policy-name ]
PBR configuration examples
Example: Configuring packet type-based local PBR
As shown in Figure 1, Switch B and Switch C do not have a route to reach each other.
Configure PBR on Switch A to forward all TCP packets to the next hop 1.1.2.2 (Switch B).
Figure 1 Network diagram
1.     Configure Switch A:
# Create VLAN 10 and VLAN 20.
[SwitchA] vlan 10
[SwitchA-vlan10] quit
[SwitchA] vlan 20
[SwitchA-vlan20] quit
# Configure the IP addresses of VLAN-interface 10 and VLAN-interface 20.
[SwitchA-Vlan-interface10] ip address 1.1.2.1 24
[SwitchA-Vlan-interface20] ip address 1.1.3.1 24
# Configure ACL 3101 to match TCP packets.
[SwitchA] acl advanced 3101
[SwitchA-acl-ipv4-adv-3101] rule permit tcp
[SwitchA-acl-ipv4-adv-3101] quit
# Configure Node 5 for the policy aaa to forward TCP packets to next hop 1.1.2.2.
[SwitchA] policy-based-route aaa permit node 5
[SwitchA-pbr-aaa-5] if-match acl 3101
[SwitchA-pbr-aaa-5] apply next-hop 1.1.2.2
[SwitchA-pbr-aaa-5] quit
# Configure local PBR by applying the policy aaa to Switch A.
[SwitchA] ip local policy-based-route aaa
2.     Configure Switch B:
# Create VLAN 10.
[SwitchB] vlan 10
[SwitchB-vlan10] quit
# Configure the IP address of VLAN-interface 10.
[SwitchB-Vlan-interface10] ip address 1.1.2.2 24
3.     Configure Switch C:
# Create VLAN 20.
[SwitchC] vlan 20
[SwitchC-vlan20] quit
# Configure the IP address of VLAN-interface 20.
[SwitchC] interface vlan-interface 20
[SwitchC-Vlan-interface20] ip address 1.1.3.2 24
1.     Perform telnet operations to verify that local PBR on Switch A operates as configured to forward the matching TCP packets to the next hop 1.1.2.2 (Switch B), as follows:
# Verify that you can telnet to Switch B from Switch A successfully. (Details not shown.)
# Verify that you cannot telnet to Switch C from Switch A. (Details not shown.)
2.     Verify that Switch A forwards packets other than TCP packets through VLAN-interface 20. For example, verify that you can ping Switch C from Switch A. (Details not shown.)
Example: Configuring packet type-based interface PBR
As shown in Figure 2, Switch B and Switch C do not have a route to reach each other.
Configure PBR on Switch A to forward all TCP packets received on VLAN-interface 11 to the next hop 1.1.2.2 (Switch B).
Figure 2 Network diagram
1.     Configure IP addresses and unicast routing protocol settings to make sure Switch B and Switch C can reach Host A. (Details not shown.)
2.     Configure Switch A:
# Configure interface PBR by applying the policy aaa to VLAN-interface 11.
[SwitchA-Vlan-interface11] ip policy-based-route aaa
1.     Perform telnet operations to verify that interface PBR on Switch A operates as configured to forward the matching TCP packets to the next hop 1.1.2.2 (Switch B), as follows:
# Verify that you can telnet to Switch B from Host A successfully. (Details not shown.)
# Verify that you cannot telnet to Switch C from Host A. (Details not shown.)
2.     Verify that Switch A forwards packets other than TCP packets through VLAN-interface 20. For example, verify that you can ping Switch C from Host A. (Details not shown.)
