H3C WA6520 Access Point Installation Guide-5W101
HomeSupportWirelessWA6500 Series Access PointsInstall & UpgradeInstallation GuidesH3C WA6520 Access Point Installation Guide-5W101
04-Appendix C Optional transceiver modules
04-Appendix C Optional transceiver modules 72.70 KB
1 Appendix C  Optional transceiver modules
You must use an SFP transceiver module and optical fiber with an LC connector to connect the fiber port on the AP.
Figure1-1 SFP transceiver module
Figure1-2 Optical fibers with LC connectors
(1) LC connector
(2) Optical fiber
Specifications
Table1-1 SFP-2.5G-LX10-SM1310-DR-I transceiver module specifications
Item
Central wavelength
1310 nm
Max transmission distance
10 km (6.21 miles)
Data rate
1228.8 to 2457.6 Mbps
Connector type
LC connector
Fiber mode
SMF
Fiber diameter
9/125 μm
Output power
7 to +2 dBm
