12-Security
HomeSupportReference GuidesMIB CompanionH3C Security Products MIB Reference(Comware 7)-6W10012-Security
04-HH3C-SESSION-MIB
04-HH3C-SESSION-MIB 115.82 KB
HH3C-SESSION-MIB
About this MIB
Use this table to manage sessions.
MIB file name
hh3c-session.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cSession(149)
Tabular objects
hh3cSessionStatTable
About this table
Use this table to obtain session statistics.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are hh3cSessionStatChassis, hh3cSessionStatSlot, and hh3cSessionStatCPUID.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.149.1.1.1.1)
not-accessible
Unsigned32
0..65534
IRF member ID.
As per the MIB.
hh3cSessionStatSlot
(1.3.6.1.4.1.25506.2.149.1.1.1.2)
not-accessible
Unsigned32
0..65534
Slot number.
As per the MIB.
(1.3.6.1.4.1.25506.2.149.1.1.1.3)
not-accessible
Unsigned32
0..7
CPU ID.
As per the MIB.
hh3cSessionStatCount
(1.3.6.1.4.1.25506.2.149.1.1.1.4)
read-only
Unsigned32
Standard MIB values.
Total number of sessions.
As per the MIB.
hh3cSessionStatCreateRate
(1.3.6.1.4.1.25506.2.149.1.1.1.5)
read-only
Unsigned32
Number of sessions created per second.
As per the MIB.
hh3cSessionStatTCPCount
(1.3.6.1.4.1.25506.2.149.1.1.1.6)
read-only
Unsigned32
Number of TCP sessions.
As per the MIB.
hh3cSessionStatUDPCount
(1.3.6.1.4.1.25506.2.149.1.1.1.7)
read-only
Unsigned32
Number of UDP sessions.
As per the MIB.
hh3cSessionStatOtherCount
(1.3.6.1.4.1.25506.2.149.1.1.1.8)
read-only
Unsigned32
Number of sessions other than TCP and UDP sessions.
As per the MIB.
hh3cSessionStatTCPCreateRate
(1.3.6.1.4.1.25506.2.149.1.1.1.9)
read-only
Unsigned32
Number of TCP sessions created per second.
As per the MIB.
hh3cSessionStatUDPCreateRate
(1.3.6.1.4.1.25506.2.149.1.1.1.10)
read-only
Unsigned32
Number of UDP sessions created per second.
As per the MIB.
hh3cSessionStatOtherCreateRate
(1.3.6.1.4.1.25506.2.149.1.1.1.11)
read-only
Unsigned32
Number of non-TCP and non-UDP sessions created per second.
As per the MIB.
hh3cSessionStatTCPTotal
(1.3.6.1.4.1.25506.2.149.1.1.1.12)
read-only
Counter64
Total number of TCP sessions created till now.
As per the MIB.
hh3cSessionStatUDPTotal
(1.3.6.1.4.1.25506.2.149.1.1.1.13)
read-only
Counter64
Total number of UDP sessions created till now.
As per the MIB.
hh3cSessionStatOtherTotal
(1.3.6.1.4.1.25506.2.149.1.1.1.14)
read-only
Counter64
Total number of non-TCP and non-UDP sessions created till now.
As per the MIB.
hh3cSessionStatDNSCount
(1.3.6.1.4.1.25506.2.149.1.1.1.15)
read-only
Unsigned32
Number of DNS sessions.
As per the MIB.
hh3cSessionStatFTPCount
(1.3.6.1.4.1.25506.2.149.1.1.1.16)
read-only
Unsigned32
Number of FTP sessions.
As per the MIB.
hh3cSessionStatGTPCount
(1.3.6.1.4.1.25506.2.149.1.1.1.17)
read-only
Unsigned32
Number of GTP sessions.
As per the MIB.
hh3cSessionStatH323Count
(1.3.6.1.4.1.25506.2.149.1.1.1.18)
read-only
Unsigned32
Number of H.323 sessions.
As per the MIB.
hh3cSessionStatHTTPCount
(1.3.6.1.4.1.25506.2.149.1.1.1.19)
read-only
Unsigned32
Number of HTTP sessions.
As per the MIB.
hh3cSessionStatILSCount
(1.3.6.1.4.1.25506.2.149.1.1.1.20)
read-only
Unsigned32
Number of ILS sessions.
As per the MIB.
hh3cSessionStatMGCPCount
(1.3.6.1.4.1.25506.2.149.1.1.1.21)
read-only
Unsigned32
Number of MGCP sessions.
As per the MIB.
hh3cSessionStatNBTCount
(1.3.6.1.4.1.25506.2.149.1.1.1.22)
read-only
Unsigned32
Number of NBT sessions.
As per the MIB.
hh3cSessionStatPPTPCount
(1.3.6.1.4.1.25506.2.149.1.1.1.23)
read-only
Unsigned32
Number of PPTP sessions.
As per the MIB.
hh3cSessionStatRSHCount
(1.3.6.1.4.1.25506.2.149.1.1.1.24)
read-only
Unsigned32
Number of RSH sessions.
As per the MIB.
hh3cSessionStatRTSPCount
(1.3.6.1.4.1.25506.2.149.1.1.1.25)
read-only
Unsigned32
Number of RTSP sessions.
As per the MIB.
hh3cSessionStatSCCPCount
(1.3.6.1.4.1.25506.2.149.1.1.1.26)
read-only
Unsigned32
Number of SCCP sessions.
As per the MIB.
hh3cSessionStatSIPCount
(1.3.6.1.4.1.25506.2.149.1.1.1.27)
read-only
Unsigned32
Number of SIP sessions.
As per the MIB.
hh3cSessionStatSMTPCount
(1.3.6.1.4.1.25506.2.149.1.1.1.28)
read-only
Unsigned32
Number of SMTP sessions.
As per the MIB.
hh3cSessionStatSQLNETCount
(1.3.6.1.4.1.25506.2.149.1.1.1.29)
read-only
Unsigned32
Number of SQLNet sessions.
As per the MIB.
hh3cSessionStatSSHCount
(1.3.6.1.4.1.25506.2.149.1.1.1.30)
read-only
Unsigned32
Number of SSH sessions.
As per the MIB.
hh3cSessionStatTELNETCount
(1.3.6.1.4.1.25506.2.149.1.1.1.31)
read-only
Unsigned32
number of Telnet sessions.
As per the MIB.
hh3cSessionStatTFTPCount
(1.3.6.1.4.1.25506.2.149.1.1.1.32)
read-only
Unsigned32
Number of TFTP sessions.
As per the MIB.
hh3cSessionStatXDMCPCount
(1.3.6.1.4.1.25506.2.149.1.1.1.33)
read-only
Unsigned32
Number of XDMCP sessions.
As per the MIB.
hh3cSessionEntTable
About this table
Use this table to obtain statistics about sessions by entity.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cSessionEntIndex.
Object (OID)
Access
Value range
Implementation
hh3cSessionEntIndex
not-accessible
Unsigned32
1..2147483647
Device entity index.
As per the MIB.
hh3cSessionEntCount
(1.3.6.1.4.1.25506.2.149.1.2.1.2)
read-only
Unsigned32
As per the MIB.
hh3cSessionEntCreateRate
(1.3.6.1.4.1.25506.2.149.1.2.1.3)
read-only
Unsigned32
As per the MIB.
hh3cSessionEntTCPCount
(1.3.6.1.4.1.25506.2.149.1.2.1.4)
read-only
Unsigned32
As per the MIB.
hh3cSessionEntUDPCount
(1.3.6.1.4.1.25506.2.149.1.2.1.5)
read-only
Unsigned32
As per the MIB.
hh3cSessionEntOtherCount
(1.3.6.1.4.1.25506.2.149.1.2.1.6)
read-only
Unsigned32
As per the MIB.
hh3cSessionEntTCPCreateRate
(1.3.6.1.4.1.25506.2.149.1.2.1.7)
read-only
Unsigned32
As per the MIB.
hh3cSessionEntUDPCreateRate
(1.3.6.1.4.1.25506.2.149.1.2.1.8)
read-only
Unsigned32
As per the MIB.
hh3cSessionEntOtherCreateRate
(1.3.6.1.4.1.25506.2.149.1.2.1.9)
read-only
Unsigned32
As per the MIB.
hh3cSessionEntTCPTotal
(1.3.6.1.4.1.25506.2.149.1.2.1.10)
read-only
Counter64
As per the MIB.
hh3cSessionEntUDPTotal
(1.3.6.1.4.1.25506.2.149.1.2.1.11)
read-only
Counter64
As per the MIB.
hh3cSessionEntOtherTotal
(1.3.6.1.4.1.25506.2.149.1.2.1.12)
read-only
Counter64
As per the MIB.
