| 03-HH3C-SECP-MIB | 38.62 KB |
HH3C-SECP-MIB
About this MIB
Use this MIB to obtain security policy statistics.
MIB file name
hh3c-secp.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cSecp(166)
Tabular objects
hh3cSecpRunningInfoTable
About this table
This table obtains the number of packets that match each security policy rule and the last match time of each security policy rule.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Not supported |
Columns
The table index is hh3cSecpRunningInfoTable.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSecpIPVersion (1.3.6.1.4.1.25506.2.166.1.1.1.1) |
not-accessible |
INTEGER |
ipv4(1) ipv6(2) |
Security policy type, which can be IPv4 or IPv6. This object is an index. |
As per the MIB. |
hh3cSecpRuleID (1.3.6.1.4.1.25506.2.166.1.1.1.2) |
not-accessible |
Unsigned32 |
0..65535 |
Security policy rule ID. This object is an index. |
As per the MIB. |
hh3cSecpMatchPacketCount (1.3.6.1.4.1.25506.2.166.1.1.1.3) |
read-only |
Counter64 |
Standard MIB values. |
Number of packets that match the security policy rule. |
As per the MIB. |
hh3cSecpLastMatchTime (1.3.6.1.4.1.25506.2.166.1.1.1.4) |
read-only |
Unsigned32 |
Last match time of the security policy rule. |
As per the MIB. |
