08-ACL and QoS
HomeSupportReference GuidesMIB CompanionH3C Security Products MIB Reference(Comware 7)-6W10008-ACL and QoS
05-IEEE8021-CN-MIB
05-IEEE8021-CN-MIB 94.28 KB
IEEE8021-CN-MIB
About this MIB
Use this MIB to configure QCN to control congestion on a CP, including CND settings and congestion detection settings
MIB file name
ieee8021-cn.mib
Root object
iso(1).org(3).oid_ieee(111).oid_standards-association-numbered-series-standards(2).oid_lan-man-stds(802). oid_ieee802dot1(1).oid_ieee802dot1mibs(1).ieee8021CnMib(18)
Tabular objects
ieee8021CnGlobalTable
About this table
This table configures global QCN settings.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is ieee8021CnGlobalComponentId.
Object (OID)
Access
Value range
Implementation
ieee8021CnGlobalComponentId (1.3.111.2.802.1.1.18.1.1.1.1)
not-accessible
IEEE8021PbbComponentIdentifier
Standard MIB values.
Component ID.
The value is fixed at 1.
ieee8021CnGlobalMasterEnable (1.3.111.2.802.1.1.18.1.1.1.2)
read-write
TruthValue
·     true(1)
·     false(2)
Global QCN state.
As per the MIB.
ieee8021CnGlobalCnmTransmitPriority (1.3.111.2.802.1.1.18.1.1.1.3)
read-write
IEEE8021PriorityValue
Priority of outgoing CNMs.
Not supported..
ieee8021CnGlobalDiscardedFrames (1.3.111.2.802.1.1.18.1.1.1.4)
read-only
Counter64
Number of frames discarded from full CP queues.
Not supported..
ieee8021CnErroredPortTable
About this table
This table obtains the index of the interface on which a CNPV is configured as an alternate priority.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are ieee8021CnEpComponentId, ieee8021CnEpPriority, and ieee8021CnEpIfIndex.
Object (OID)
Access
Value range
Implementation
ieee8021CnEpComponentId (1.3.111.2.802.1.1.18.1.2.1.1)
not-accessible
Component ID.
ieee8021CnEpPriority (1.3.111.2.802.1.1.18.1.2.1.2)
not-accessible
Alternate priority.
As per the MIB.
ieee8021CnEpIfIndex (1.3.111.2.802.1.1.18.1.2.1.3)
read-only
InterfaceIndex
Interface index.
As per the MIB.
ieee8021CnCompntPriTable
About this table
This table configures global CND settings.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table indexes are ieee8021CnComPriComponentId and ieee8021CnComPriPriority.
Object (OID)
Access
Value range
Implementation
ieee8021CnComPriComponentId (1.3.111.2.802.1.1.18.1.3.1.1)
not-accessible
Component ID.
ieee8021CnComPriPriority (1.3.111.2.802.1.1.18.1.3.1.2)
not-accessible
802.1p priority.
As per the MIB.
ieee8021CnComPriDefModeChoice (1.3.111.2.802.1.1.18.1.3.1.3)
read-create
Ieee8021CnControlChoice
Defense mode choosing mode.
As per the MIB.
ieee8021CnComPriAlternatePriority (1.3.111.2.802.1.1.18.1.3.1.4)
read-create
Alternate priority in Admin mode.
As per the MIB.
ieee8021CnComPriAutoAltPri (1.3.111.2.802.1.1.18.1.3.1.5)
read-only
Alternate priority in Auto mode.
As per the MIB.
ieee8021CnComPriAdminDefenseMode (1.3.111.2.802.1.1.18.1.3.1.6)
read-create
Ieee8021CnDefenseMode
Defense mode in Admin mode.
As per the MIB.
ieee8021CnComPriCreation (1.3.111.2.802.1.1.18.1.3.1.7)
read-create
INTEGER
·     cncpAutoEnable(1)
·     cncpAutoDisable(2)
Creation method.
Not supported.
ieee8021CnComPriLldpInstanceChoice (1.3.111.2.802.1.1.18.1.3.1.8)
read-create
Ieee8021CnLldpChoice
LLDP instance choosing mode.
Not supported.
ieee8021CnComPriLldpInstanceSelector (1.3.111.2.802.1.1.18.1.3.1.9)
read-create
LldpV2DestAddressTableIndex
LLDP instance index.
Not supported.
ieee8021CnComPriRowStatus (1.3.111.2.802.1.1.18.1.3.1.10)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
ieee8021CnPortPriTable
About this table
This table configures CND settings on an interface.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are ieee8021CnPortPriComponentId, ieee8021CnPortPriority, and ieee8021CnPortPriIfIndex.
Object (OID)
Access
Value range
Implementation
ieee8021CnPortPriComponentId (1.3.111.2.802.1.1.18.1.4.1.1)
not-accessible
Component ID.
ieee8021CnPortPriority (1.3.111.2.802.1.1.18.1.4.1.2)
not-accessible
802.1p priority.
As per the MIB.
ieee8021CnPortPriIfIndex (1.3.111.2.802.1.1.18.1.4.1.3)
not-accessible
InterfaceIndex
Interface index.
As per the MIB.
ieee8021CnPortPriDefModeChoice (1.3.111.2.802.1.1.18.1.4.1.4)
read-write
Priority value choosing mode.
As per the MIB.
ieee8021CnPortPriAdminDefenseMode (1.3.111.2.802.1.1.18.1.4.1.5)
read-write
As per the MIB.
ieee8021CnPortPriAutoDefenseMode (1.3.111.2.802.1.1.18.1.4.1.6)
read-only
Negotiated defense mode in Auto mode.
As per the MIB.
ieee8021CnPortPriLldpInstanceChoice (1.3.111.2.802.1.1.18.1.4.1.7)
read-write
Not supported.
ieee8021CnPortPriLldpInstanceSelector (1.3.111.2.802.1.1.18.1.4.1.8)
read-write
Selected LLDP instance.
Not supported.
ieee8021CnPortPriAlternatePriority (1.3.111.2.802.1.1.18.1.4.1.9)
read-write
As per the MIB.
ieee8021CnCpTable
About this table
This table obtains congestion detection settings.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are ieee8021CnCpComponentId, ieee8021CnCpIfIndex, and ieee8021CnCpIndex.
Object (OID)
Access
Value range
Implementation
ieee8021CnCpComponentId (1.3.111.2.802.1.1.18.1.5.1.1
not-accessible
Component ID.
ieee8021CnCpIfIndex (1.3.111.2.802.1.1.18.1.5.1.2
not-accessible
InterfaceIndex
Interface index.
As per the MIB.
ieee8021CnCpIndex (1.3.111.2.802.1.1.18.1.5.1.3
not-accessible
Unsigned32
1..4096
CP index.
As per the MIB.
ieee8021CnCpPriority (1.3.111.2.802.1.1.18.1.5.1.4
read-only
802.1p priority.
As per the MIB.
ieee8021CnCpMacAddress (1.3.111.2.802.1.1.18.1.5.1.5
read-only
MacAddress
Source MAC address of outgoing CNMs.
Not supported.
ieee8021CnCpIdentifier (1.3.111.2.802.1.1.18.1.5.1.6
read-only
OCTET STRING
SIZE(8)
CPID in CNMs.
Not supported.
ieee8021CnCpQueueSizeSetPoint (1.3.111.2.802.1.1.18.1.5.1.7
read-write
Unsigned32
100..4294967295
Desired queue length.
Supports only the read operation.
ieee8021CnCpFeedbackWeight (1.3.111.2.802.1.1.18.1.5.1.8)
read-write
Integer32
-10..10
Weight value.
ieee8021CnCpMinSampleBase (1.3.111.2.802.1.1.18.1.5.1.9)
read-write
Unsigned32
10000..4294967295
Minimum number of octets to enqueue in the CP's queue between transmissions of CNMs.
Not supported.
ieee8021CnCpDiscardedFrames (1.3.111.2.802.1.1.18.1.5.1.10)
read-only
Counter64
Number of data frames discarded.
As per the MIB.
ieee8021CnCpTransmittedFrames (1.3.111.2.802.1.1.18.1.5.1.11)
read-only
Counter64
Number of data frames passed on to the queue.
As per the MIB.
ieee8021CnCpTransmittedCnms (1.3.111.2.802.1.1.18.1.5.1.12)
read-only
Counter64
Number of CNMs transmitted.
As per the MIB.
ieee8021CnCpMinHeaderOctets (1.3.111.2.802.1.1.18.1.5.1.13)
read-write
Unsigned32
0..64
Minimum number of octets to be returned in a CNM
Not supported.
