08-ACL and QoS
HomeSupportReference GuidesMIB CompanionH3C Security Products MIB Reference(Comware 7)-6W10008-ACL and QoS
02-HH3C-CBQOS2-MIB
02-HH3C-CBQOS2-MIB 254.14 KB
HH3C-CBQOS2-MIB· 1
About this MIB· 1
MIB file name· 1
Root object 1
Scalar objects· 1
hh3cCBQoSClassifierIndexNext 1
hh3cCBQoSBehaviorIndexNext 1
hh3cCBQoSPolicyIndexNext 1
hh3cCBQoSApplyingStatus· 2
Tabular objects· 2
hh3cCBQoSClassifierCfgInfoTable· 2
hh3cCBQoSMatchRuleCfgInfoTable· 3
hh3cCBQoSMatchCpProtoCfgTable (not supported) 5
hh3cCBQoSMatchCpGroupCfgTable (not supported) 6
hh3cCBQoSBehaviorCfgInfoTable· 7
hh3cCBQoSCarCfgInfoTable· 8
hh3cCBQoSGtsCfgInfoTable (not supported) 9
hh3cCBQoSRemarkCfgInfoTable· 10
hh3cCBQoSQueueCfgInfoTable· 11
hh3cCBQoSFirewallCfgInfoTable· 12
hh3cCBQoSAccountCfgInfoTable· 13
hh3cCBQoSRedirectCfgInfoTable· 13
hh3cCBQoSMirrorCfgInfoTable (not supported) 15
hh3cCBQoSNestCfgInfoTable (not supported) 15
hh3cCBQoSNestPolicyCfgInfoTable (not supported) 16
hh3cCBQoSMirrorIfCfgInfoTable· 17
hh3cCBQoSColoredRemarkCfgTable (not supported) 18
hh3cCBQoSPrimapCfgInfoTable (not supported) 18
hh3cCBQoSColorMapDpCfgInfoTable (not supported) 20
hh3cCBQoSPolicyCfgInfoTable· 21
hh3cCBQoSPolicyClassCfgInfoTable· 22
hh3cCBQoSIfApplyPolicyTable· 23
hh3cCBQoSVlanApplyPolicyTable (not supported) 24
hh3cCBQoSGlobalApplyTable· 25
hh3cCBQoSCpApplyPolicyTable· 26
hh3cCBQoSApplyObjectTable· 27
hh3cCBQoSIntApplyObjectTable· 28
hh3cCBQoSVlanApplyObjectTable (not supported) 28
hh3cCBQoSNestPolicyApplyObjectTable· 29
hh3cCBQoSCpApplyObjectTable· 30
hh3cCBQoSCbqRunInfoTable (not supported) 30
hh3cCBQoSClassMatchRunInfoTable· 32
hh3cCBQoSCarRunInfoTable (not supported) 33
hh3cCBQoSRemarkRunInfoTable (not supported) 34
hh3cCBQoSQueueRunInfoTable (not supported) 34
hh3cCBQoSAccountingRunInfoTable (not supported) 35
hh3cCBQoSPolicyAccRunInfoTable (not supported) 36
HH3C-CBQOS2-MIB
About this MIB
Use this MIB to configure class-based QoS (CBQoS).
CBQoS applies different service quality levels to different classes of packets, enabling multiple service support on the network.
MIB file name
hh3c-cbqos2.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cQos2(65)
Scalar objects
Object (OID)
Access
Value range
Implementation
hh3cCBQoSClassifierIndexNext (1.3.6.1.4.1.25506.2.65.2.1.1.1)
read-only
Integer32
Standard MIB values.
Index of the next available traffic class.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cCBQoSBehaviorIndexNext (1.3.6.1.4.1.25506.2.65.2.1.2.1)
read-only
Integer32
Index of the next available traffic behavior.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cCBQoSPolicyIndexNext (1.3.6.1.4.1.25506.2.65.2.1.3.1)
read-only
Integer32
Index of the next available QoS policy.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cCBQoSApplyingStatus (1.3.6.1.4.1.25506.2.65.2.1.6.1)
read-only
INTEGER
·     idle(1)
·     busy(2)
QoS policy application status.
As per the MIB.
Tabular objects
About this table
This table configures a traffic class.
Support for operations
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table index is hh3cCBQoSClassifierIndex.
Object (OID)
Access
Value range
Implementation
hh3cCBQoSClassifierIndex (1.3.6.1.4.1.25506.2.65.2.1.1.2.1.1)
not-accessible
Integer32
Traffic class index.
As per the MIB.
hh3cCBQoSClassifierName (1.3.6.1.4.1.25506.2.65.2.1.1.2.1.2)
read-create
OCTET STRING
SIZE (1..31)
Traffic class name.
As per the MIB.
hh3cCBQoSClassifierRuleCount (1.3.6.1.4.1.25506.2.65.2.1.1.2.1.3)
read-only
Integer32
Number of match criteria.
As per the MIB.
hh3cCBQoSClassifierOperator (1.3.6.1.4.1.25506.2.65.2.1.1.2.1.4)
read-create
INTEGER
·     and(1)
·     or(2)
Relationship among match criteria.
As per the MIB.
hh3cCBQoSClassifierLayer (1.3.6.1.4.1.25506.2.65.2.1.1.2.1.5)
read-create
INTEGER
·     unavailable(1)
·     l2(2)
·     l3(3)
·     both(4)
Protocol layer for the traffic class.
This object is not configurable and is fixed at unavailable(1).
hh3cCBQoSClassifierType (1.3.6.1.4.1.25506.2.65.2.1.1.2.1.6)
read-only
INTEGER
·     systemDefined(1)
·     userDefined(2)
Traffic class type.
As per the MIB.
hh3cCBQosClassifierMatchRuleNextIndex (1.3.6.1.4.1.25506.2.65.2.1.1.2.1.7)
read-only
Integer32
Index used to create a match criterion.
If the value is 2147483647, the a match criterion cannot be created.
hh3cCBQoSClassifierRowStatus (1.3.6.1.4.1.25506.2.65.2.1.1.2.1.8)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
About this table
This table configures match criteria for a traffic class.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table indexes are hh3cCBQoSClassifierIndex and hh3cCBQoSMatchRuleIndex.
Object (OID)
Access
Value range
Implementation
hh3cCBQoSMatchRuleIndex (1.3.6.1.4.1.25506.2.65.2.1.1.3.1.1)
not-accessible
Integer32
Match criterion index.
As per the MIB.
hh3cCBQoSMatchRuleIfNot (1.3.6.1.4.1.25506.2.65.2.1.1.3.1.2)
read-create
INTEGER
·     match(1)
·     matchNot (2)
Match attribute.
As per the MIB.
hh3cCBQoSMatchRuleType (1.3.6.1.4.1.25506.2.65.2.1.1.3.1.3)
read-create
MatchRuleType
Match criterion type.
As per the MIB.
hh3cCBQoSMatchRuleStringValue (1.3.6.1.4.1.25506.2.65.2.1.1.3.1.4)
read-create
OCTET STRING
SIZE (1..255)
Match criterion type string value. The corresponding match criterion types include:
·     IPv4acl
·     MACACL
·     UserACL
·     IPv6acl
·     Source-MAC
·     Destination-MAC
·     Classifier
·     Inbound-interface
·     VlanID
·     SourceIp
·     MplsLabel
·     SecondMplsLabel
As per the MIB.
hh3cCBQoSMatchRuleIntValue1 (1.3.6.1.4.1.25506.2.65.2.1.1.3.1.5)
read-create
Unsigned32
Match criterion type integer value. The corresponding match criterion types include:
·     IPv4acl
·     MACACL
·     UserACL
·     IPv6acl
·     Software QoS
·     Hardware Qos
·     RtpPort
·     IpPrec
·     Dscp
·     Vlan8021p
·     Mplsexp
·     SourceIp
·     QosLocalID
·     AtmClp
·     FrDe
·     LocalPrecedence
·     DropPriority
·     ServiceDot1p
·     SecondMplsExp
·     PacketLength
·     ForwardingLayer
As per the MIB.
hh3cCBQoSMatchRuleIntValue2 (1.3.6.1.4.1.25506.2.65.2.1.1.3.1.6)
read-create
Unsigned32
·     RTP-PORT
·     DSCP
·     PacketLength
As per the MIB.
hh3cCBQoSMatchIpAddressType (1.3.6.1.4.1.25506.2.65.2.1.1.3.1.7)
read-create
InetAddressType
Match criterion type integer value. The corresponding match criterion type is SourceIP.
Not supported.
The value is fixed at unknown(0).
hh3cCBQoSMatchIpAddress (1.3.6.1.4.1.25506.2.65.2.1.1.3.1.8)
read-create
InetAddress
Match criterion type integer value. The corresponding integer value is a source IP address.
Not supported.
The value is fixed at zero length.
hh3cCBQoSMatchRuleRowStatus (1.3.6.1.4.1.25506.2.65.2.1.1.3.1.9)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
About this table
This table configures a match criterion to match protocol traffic to a control plane.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSMatchCpProtoIfNot (1.3.6.1.4.1.25506.2.65.2.1.1.4.1.1)
read-create
INTEGER
·     match(1)
·     matchNot(2)
Match attribute.
Not supported.
hh3cCBQoSMatchCpProtoValue (1.3.6.1.4.1.25506.2.65.2.1.1.4.1.2)
read-create
OCTET STRING
SIZE (0..255)
Control plane protocol.
Not supported.
hh3cCBQoSMatchCpProtoRowStatus (1.3.6.1.4.1.25506.2.65.2.1.1.4.1.3)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
About this table
This table configures a match criterion to match protocol group traffic to a control plane.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSMatchCpGroupIfNot (1.3.6.1.4.1.25506.2.65.2.1.1.5.1.1)
read-create
INTEGER
·     match(1)
·     matchNot(2)
Match attribute.
Not supported.
hh3cCBQoSMatchCpGroupValue (1.3.6.1.4.1.25506.2.65.2.1.1.5.1.2)
read-create
INTEGER
·     critical(1)
·     important(2)
·     management(3)
·     normal(4)
·     redirect(5)
·     monitor(6)
·     exception(7)
Control plane protocol group.
Not supported.
hh3cCBQoSMatchCpGroupRowStatus (1.3.6.1.4.1.25506.2.65.2.1.1.5.1.3)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
About this table
This table configures match criteria for a traffic behavior.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table index is hh3cCBQoSBehaviorIndex.
Object (OID)
Access
Value range
Implementation
hh3cCBQoSBehaviorIndex (1.3.6.1.4.1.25506.2.65.2.1.2.2.1.1)
not-accessible
Integer32
Traffic behavior index.
As per the MIB.
hh3cCBQoSBehaviorName (1.3.6.1.4.1.25506.2.65.2.1.2.2.1.2)
read-create
OCTET STRING
SIZE (1..31)
Traffic behavior name.
As per the MIB.
hh3cCBQoSBehaviorType (1.3.6.1.4.1.25506.2.65.2.1.2.2.1.3)
read-only
INTEGER
·     systemDefined(1)
·     userDefined(2)
Traffic behavior type.
As per the MIB.
hh3cCBQoSBehaviorRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.2.1.4)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
About this table
This table configures a CAR action for a traffic behavior.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSCarCir (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.1)
read-create
Unsigned32
CIR.
As per the MIB.
hh3cCBQoSCarCbs (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.2)
read-create
Unsigned32
CBS.
As per the MIB.
hh3cCBQoSCarEbs (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.3)
read-create
Unsigned32
EBS.
As per the MIB.
hh3cCBQoSCarPir (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.4)
read-create
Unsigned32
PIR.
As per the MIB.
hh3cCBQoSCarPbs (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.5)
read-create
Unsigned32
PBS.
Not supported.
The value is fixed at 4294967295.
hh3cCBQoSCarGreenAction (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.6)
read-create
CarAction
Action to take on green packets.
As per the MIB.
hh3cCBQoSCarGreenRemarkValue (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.7)
read-create
Integer32
·     0..63
·     255
Value to mark for green packets.
As per the MIB.
hh3cCBQoSCarYellowAction (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.8)
read-create
CarAction
Action to take on yellow packets.
As per the MIB.
hh3cCBQoSCarYellowRemarkValue (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.9)
read-create
Integer32
·     0..63
·     255
Value to mark for yellow packets.
As per the MIB.
hh3cCBQoSCarRedAction (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.10)
read-create
CarAction
·     For VRP: Action to take on packets exceeding the CIR.
·     For 10G: Action to take on packets exceeding the PIR.
As per the MIB.
hh3cCBQoSCarRedRemarkValue (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.11)
read-create
Integer32
·     0..63
·     255
Value to mark for red packets.
As per the MIB.
hh3cCBQoSCarPolicedPriorityMapType (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.12)
read-create
INTEGER
·     none (0)
·     policed-service-map (1)
·     local-precedence-dot1p-map (2)
·     drop-precedence-map (3)
Priority map type.
Not supported. The value is fixed at none(0).
hh3cCBQoSCarRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.3.1.13)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
About this table
This table contains GTS configuration information.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSGtsCir (1.3.6.1.4.1.25506.2.65.2.1.2.5.1.1)
read-create
Unsigned32
CIR.
Not supported.
hh3cCBQoSGtsCbs (1.3.6.1.4.1.25506.2.65.2.1.2.5.1.2)
read-create
Unsigned32
CBS.
Not supported.
hh3cCBQoSGtsEbs (1.3.6.1.4.1.25506.2.65.2.1.2.5.1.3)
read-create
Unsigned32
EBS.
Not supported.
hh3cCBQoSGtsQueueLength (1.3.6.1.4.1.25506.2.65.2.1.2.5.1.4)
read-create
Integer32
1..1024
Queue length.
As per the MIB.
hh3cCBQoSGtsRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.5.1.5)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
hh3cCBQoSGtsPir (1.3.6.1.4.1.25506.2.65.2.1.2.5.1.6)
read-create
Unsigned32
PIR.
Not supported.
About this table
This table contains marking configuration information.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table indexes are hh3cCBQoSBehaviorIndex and hh3cCBQoSRemarkType.
Object (OID)
Access
Value range
Implementation
hh3cCBQoSRemarkType (1.3.6.1.4.1.25506.2.65.2.1.2.6.1.1)
not-accessible
RemarkType
Marking type.
As per the MIB.
hh3cCBQoSRemarkValue (1.3.6.1.4.1.25506.2.65.2.1.2.6.1.2)
read-create
Integer32
0..4095
As per the MIB.
hh3cCBQoSRemarkRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.6.1.3)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
About this table
This table contains queuing configuration information.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSQueueType (1.3.6.1.4.1.25506.2.65.2.1.2.7.1.1)
read-create
QueueType
Queuing type.
As per the MIB.
hh3cCBQoSQueueDropType (1.3.6.1.4.1.25506.2.65.2.1.2.7.1.2)
read-create
INTEGER
·     unavailable(0)
·     tail-drop(1)
·     wred(2)
Packet drop type.
Not supported.
hh3cCBQoSQueueLength (1.3.6.1.4.1.25506.2.65.2.1.2.7.1.3)
read-create
Integer32
1..2147483647
Queue length.
16..4096
hh3cCBQoSQueueBandwidthUnit (1.3.6.1.4.1.25506.2.65.2.1.2.7.1.4)
read-create
QueueBandwidthUnit
Bandwidth unit.
As per the MIB.
hh3cCBQoSQueueBandwidthValue (1.3.6.1.4.1.25506.2.65.2.1.2.7.1.5)
read-create
Integer32
·     1..100000000
·     2147483647
Bandwidth value.
·     8..10000000
·     2147483647 (default)
hh3cCBQoSQueueCbs (1.3.6.1.4.1.25506.2.65.2.1.2.7.1.6)
read-create
Integer32
·     32..1000000000
·     2147483647
CBS.
·     32..1000000000
hh3cCBQoSQueueQueueNumber (1.3.6.1.4.1.25506.2.65.2.1.2.7.1.7)
read-create
INTEGER
·     unavailable(0)
·     a16(16)
·     a32(32)
·     a64(64)
·     a128(128)
·     a256(256)
·     a512(512)
·     a1024(1024)
·     a2048(2048)
·     a4096(4096)
Maximum number of queues.
a256(256)
hh3cCBQoSQueueCbsRatio (1.3.6.1.4.1.25506.2.65.2.1.2.7.1.8)
read-create
Integer32
·     25..500
·     2147483647
Allowed burst ratio.
·     25..500
hh3cCBQoSQueueRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.7.1.9)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
About this table
This table contains firewall configuration information.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSFirewallAction (1.3.6.1.4.1.25506.2.65.2.1.2.12.1.1)
read-create
INTEGER
·     permit(1)
·     deny(2)
Firewall behavior.
As per the MIB.
hh3cCBQoSFirewallRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.12.1.2)
read-create
RowStatus
Row status.
As per the MIB.
About this table
This table contains accounting configuration information.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSAccounting (1.3.6.1.4.1.25506.2.65.2.1.2.14.1.1)
read-create
INTEGER
·     true(1)
·     false(2)
Accounting.
As per the MIB.
hh3cCBQoSAccountRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.14.1.2)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
hh3cCBQoSAccountingMode (1.3.6.1.4.1.25506.2.65.2.1.2.14.1.3)
read-create
INTEGER
·     auto(1)
·     packet(2)
·     byte(3)
·     both(4)
Accounting mode.
·     packet(2)
·     byte(3)
About this table
This table configures a redirecting action for a traffic behavior.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSRedirectType (1.3.6.1.4.1.25506.2.65.2.1.2.15.1.1)
read-create
INTEGER
·     cpu(1)
·     interface(2)
·     nextHop(3)
Redirecting destination.
interface(2).
hh3cCBQoSRedirectIfIndex (1.3.6.1.4.1.25506.2.65.2.1.2.15.1.2)
read-create
Integer32
Interface index.
As per the MIB.
hh3cCBQoSRedirectIpAddressType
read-create
InetAddressType
Next-hop address type.
Not supported. The value is fixed at unknown(0).
hh3cCBQoSRedirectIpAddress1
read-create
InetAddress
First next-hop address.
Not supported. The value is fixed at zero-length.
hh3cCBQoSRedirectIpAddress2
read-create
InetAddress
Second next-hop address.
hh3cCBQoSRedirectRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.15.1.6)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
hh3cCBQoSRedirectIpv6Interface1
read-create
Integer32
Outgoing interface for the first next-hop IPv6 address.
Not supported. The value is fixed at 0.
hh3cCBQoSRedirectIpv6Interface2
read-create
Integer32
Outgoing interface for the second next-hop IPv6 address.
hh3cCBQoSRedirectIfVlanID (1.3.6.1.4.1.25506.2.65.2.1.2.15.1.9)
read-create
Integer32
0..4094|65535
VLAN ID.
Not supported.
About this table
This table contains flow mirroring configuration information.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSMirrorType (1.3.6.1.4.1.25506.2.65.2.1.2.17.1.1)
read-create
INTEGER
·     interface(1)
·     cpu(2)
·     vlan(3)
Mirroring destination.
Not supported.
hh3cCBQoSMirrorIfIndex (1.3.6.1.4.1.25506.2.65.2.1.2.17.1.2)
read-create
OCTET STRING
SIZE (1..255)
Destination interface index.
hh3cCBQoSMirrorVlanID (1.3.6.1.4.1.25506.2.65.2.1.2.17.1.3)
read-create
Integer32
0..4094
Destination VLAN ID.
Not supported.
hh3cCBQoSMirrorRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.17.1.4)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
About this table
This table configures nesting for VLAN mapping.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSNestServiceVlanID (1.3.6.1.4.1.25506.2.65.2.1.2.18.1.1)
read-create
Integer32
·     1..4094
·     65535
Service provider VLAN ID.
As per the MIB.
hh3cCBQoSNestServiceDot1pValue (1.3.6.1.4.1.25506.2.65.2.1.2.18.1.2)
read-create
Integer32
·     0..7
·     65535
Outer 802.1p priority value.
Not supported.
hh3cCBQoSNestCustomerVlanID
read-create
Integer32
·     1..4094
·     65535
Customer VLAN ID.
Not supported. The value is fixed at 65535.
hh3cCBQoSNestCustomerDot1pValue
read-create
Integer32
·     0..7
·     65535
Inner 802.1p priority value.
hh3cCBQoSNestRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.18.1.5)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
About this table
This table nests a QoS policy.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSNestPolicyName (1.3.6.1.4.1.25506.2.65.2.1.2.19.1.1)
read-create
OCTET STRING
SIZE (1..31)
Nested policy name.
As per the MIB.
hh3cCBQoSNestPolicyRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.19.1.2)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
About this table
This table contains information about flow mirroring to an interface.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSMirrorIfMainIfIndex (1.3.6.1.4.1.25506.2.65.2.1.2.20.1.1)
not-accessible
Integer32
As per the MIB.
hh3cCBQoSMirrorIfMainIfStatus (1.3.6.1.4.1.25506.2.65.2.1.2.20.1.2)
read-only
INTEGER
·     inactive(1)
·     active(2)
Destination interface status.
As per the MIB.
hh3cCBQoSMirrorIfBackupIfIndex (1.3.6.1.4.1.25506.2.65.2.1.2.20.1.3)
read-create
Integer32
Backup destination interface index.
As per the MIB.
hh3cCBQoSMirrorIfBackupIfStatus (1.3.6.1.4.1.25506.2.65.2.1.2.20.1.4)
read-only
INTEGER
·     inactive(1)
·     active(2)
Backup destination interface status.
As per the MIB.
hh3cCBQoSMirrorIfRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.20.1.5)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
About this table
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table indexes are hh3cCBQoSBehaviorIndex, hh3cCBQoSColoredRemarkType, and hh3cCBQoSColoredRemarkColor.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.65.2.1.2.21.1.1)
not-accessible
RemarkType
Marking type.
Not supported.
hh3cCBQoSColoredRemarkColor (1.3.6.1.4.1.25506.2.65.2.1.2.21.1.2)
not-accessible
INTEGER
·     green(1)
·     yellow(2)
·     red(3)
Marking color.
Not supported.
hh3cCBQoSColoredRemarkValue (1.3.6.1.4.1.25506.2.65.2.1.2.21.1.3)
read-create
Integer32
0..4095
Value to mark for packets.
As per the MIB.
hh3cCBQoSColoredRemarkRowStatus
(1.3.6.1.4.1.25506.2.65.2.1.2.21.1.4)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
About this table
This table contains information about predefined priority maps. The system modifies the priority of matching packets according to the predefined priority map.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSPrimapColorType (1.3.6.1.4.1.25506.2.65.2.1.2.22.1.1)
not-accessible
INTEGER
·     noColorMap(1)
·     colorMap(2)
Predefined priority map color attribute.
Not supported.
hh3cCBQoSPrePriMapTableType (1.3.6.1.4.1.25506.2.65.2.1.2.22.1.2)
not-accessible
INTEGER
·     invalid(0)
·     dot1pToLp(1)
·     dot1pToDp(2)
·     expToLp(3)
·     dscpToLp(4)
·     expToDp(5)
·     dscpToDp(6)
·     dscpToDot1p(7)
·     dot1pToDscp(8)
·     dscpToDscp(9)
·     dscpToExp(10)
·     expToDscp(11)
·     expToDot1p(12)
·     expToExp(13)
·     lpToDot1p(14)
·     dot1pToRpr(15)
·     dscpToRpr(16)
·     expToRpr(17)
·     ippreToRpr(18)
·     upToDot1p(19)
·     upToDscp(20)
·     upToExp(21)
·     upToDp(22)
·     upToLp(23)
·     upToRpr(24)
·     upToFc(25)
·     lpTodscp(26)
·     dot11eToLp(27)
·     lpToDot11e(28)
·     lpToLp(29)
·     dot1pToExp(30)
·     lpToExp(31)
·     lpToDp(32)
·     upToUp(33)
·     dot1pToDot1p(34)
Predefined priority map type.
Not supported.
hh3cCBQoSPrimapRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.22.1.3)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
About this table
This table contains information about packet color-to-drop priority mappings. The system assigns drop priority to packets according to the packet color.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSColorMapDpEnable (1.3.6.1.4.1.25506.2.65.2.1.2.23.1.1)
read-create
INTEGER
·     true(1)
·     false(2)
Color-to-drop priority mapping enable status.
As per the MIB.
hh3cCBQoSColorMapDpRowStatus (1.3.6.1.4.1.25506.2.65.2.1.2.23.1.2)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
About this table
This table configures a QoS policy.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSPolicyIndex (1.3.6.1.4.1.25506.2.65.2.1.3.2.1.1)
not-accessible
Integer32
Policy index.
As per the MIB.
hh3cCBQoSPolicyName (1.3.6.1.4.1.25506.2.65.2.1.3.2.1.2)
read-create
OCTET STRING
SIZE (1..31)
Policy name.
As per the MIB.
hh3cCBQoSPolicyClassCount (1.3.6.1.4.1.25506.2.65.2.1.3.2.1.3)
read-only
Integer32
Number of traffic classes in the QoS policy.
As per the MIB.
hh3cCBQoSPolicyConfigMode (1.3.6.1.4.1.25506.2.65.2.1.3.2.1.4)
read-create
INTEGER
·     unavailable(0)
·     config(1)
·     auto(2)
Policy mode.
Not supported. The value is fixed at unavailable(0).
hh3cCBQoSPolicyType (1.3.6.1.4.1.25506.2.65.2.1.3.2.1.5)
read-only
INTEGER
·     systemDefined(1)
·     userDefined(2)
Policy type.
As per the MIB.
hh3cCBQoSPolicyClassNextIndex (1.3.6.1.4.1.25506.2.65.2.1.3.2.1.6)
read-only
Integer32
Traffic class index used to create a traffic class.
If the value is 2147483647, no traffic class can be created for hh3cCBQoSPolicyClassCfgInfoTable.
hh3cCBQoSPolicyRowStatus (1.3.6.1.4.1.25506.2.65.2.1.3.2.1.7)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
About this table
This table describes CB association information for a QoS policy.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table indexes are hh3cCBQoSPolicyIndex and hh3cCBQoSPolicyClassIndex.
Object (OID)
Access
Value range
Implementation
hh3cCBQoSPolicyClassIndex (1.3.6.1.4.1.25506.2.65.2.1.3.3.1.1)
not-accessible
Integer32
As per the MIB.
hh3cCBQoSPolicyClassClassifierIndex (1.3.6.1.4.1.25506.2.65.2.1.3.3.1.2)
read-create
Integer32
As per the MIB.
hh3cCBQoSPolicyClassClassifierName (1.3.6.1.4.1.25506.2.65.2.1.3.3.1.3)
read-only
OCTET STRING
SIZE (1..31)
Traffic class name.
As per the MIB.
hh3cCBQoSPolicyClassBehaviorIndex (1.3.6.1.4.1.25506.2.65.2.1.3.3.1.4)
read-create
Integer32
As per the MIB.
hh3cCBQoSPolicyClassBehaviorName (1.3.6.1.4.1.25506.2.65.2.1.3.3.1.5)
read-only
OCTET STRING
SIZE (1..31)
As per the MIB.
hh3cCBQoSPolicyClassPrecedence (1.3.6.1.4.1.25506.2.65.2.1.3.3.1.6)
read-create
Integer32
·     0..16383
·     2147483647
Traffic class priority.
Not supported. The value is fixed at 2147483647.
hh3cCBQoSPolicyClassRowStatus (1.3.6.1.4.1.25506.2.65.2.1.3.3.1.7)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
hh3cCBQoSPolicyClassMode (1.3.6.1.4.1.25506.2.65.2.1.3.3.1.8)
read-create
INTEGER
·     modeNo(1)
·     modeDot1q(2)
·     modeQppb(3)
·     modeIpSourceGuard(4)
·     modeVoiceVlan(5)
·     modeDcbx(6)
CB association mode.
modeNo(1)
hh3cCBQoSPolicyClassCfgOrder (1.3.6.1.4.1.25506.2.65.2.1.3.3.1.9)
read-only
Integer32
CB association configuration order.
Not supported
About this table
.This table applies a QoS policy to an interface.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table indexes are hh3cCBQoSIfApplyPolicyIfIndex and hh3cCBQoSIfApplyPolicyDirection.
Object (OID)
Access
Value range
Implementation
hh3cCBQoSIfApplyPolicyIfIndex (1.3.6.1.4.1.25506.2.65.2.1.4.1.1.1)
accessible-for-notify
Integer32
Index of the interface to which a QoS policy is applied.
As per the MIB.
hh3cCBQoSIfApplyPolicyDirection (1.3.6.1.4.1.25506.2.65.2.1.4.1.1.2)
DirectionType
Application direction.
As per the MIB.
hh3cCBQoSIfApplyPolicyName (1.3.6.1.4.1.25506.2.65.2.1.4.1.1.3)
read-create
OCTET STRING
SIZE (1..31)
Policy name.
As per the MIB.
hh3cCBQoSIfApplyPolicyEnableDynamic (1.3.6.1.4.1.25506.2.65.2.1.4.1.1.4)
read-create
INTEGER
·     unavailable(1)
·     true(2)
·     false(3)
Dynamic QoS
Not supported. The value is fixed at unavailable(1).
hh3cCBQoSIfApplyPolicyRowStatus (1.3.6.1.4.1.25506.2.65.2.1.4.1.1.5)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
hh3cCBQoSIfApplyPolicyStatus (1.3.6.1.4.1.25506.2.65.2.1.4.1.1.6)
read-only
INTEGER
·     processing (0)
·     success (1)
·     partialItemFailed (2)
Application status.
As per the MIB.
About this table
This table applies a QoS policy to a VLAN interface.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table indexes are hh3cCBQoSVlanApplyPolicyVlanid and hh3cCBQoSVlanApplyPolicyDirection.
Object (OID)
Access
Value range
Implementation
hh3cCBQoSVlanApplyPolicyVlanid (1.3.6.1.4.1.25506.2.65.2.1.4.3.1.1)
Integer32
VLAN ID.
As per the MIB.
hh3cCBQoSVlanApplyPolicyDirection (1.3.6.1.4.1.25506.2.65.2.1.4.3.1.2)
DirectionType
As per the MIB.
hh3cCBQoSVlanApplyPolicyName (1.3.6.1.4.1.25506.2.65.2.1.4.3.1.3)
read-create
OCTET STRING
SIZE (1..31)
Policy name.
As per the MIB.
hh3cCBQoSVlanApplyPriority (1.3.6.1.4.1.25506.2.65.2.1.4.3.1.4)
read-create
Integer32
0..4095
Policy priority.
hh3cCBQoSVlanApplyPolicyRowStatus (1.3.6.1.4.1.25506.2.65.2.1.4.3.1.5)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
hh3cCBQoSVlanApplyPolicyStatus (1.3.6.1.4.1.25506.2.65.2.1.4.3.1.6)
read-create
INTEGER
·     processing (1)
·     success (2)
·     partialItemFailed (3)
Application status.
As per the MIB.
About this table
This table applies a QoS policy globally.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table index is hh3cCBQoSGlobalApplyDirection.
Object (OID)
Access
Value range
Implementation
hh3cCBQoSGlobalApplyDirection (1.3.6.1.4.1.25506.2.65.2.1.4.6.1.1)
not-accessible
DirectionType
As per the MIB.
hh3cCBQoSGlobalApplyName (1.3.6.1.4.1.25506.2.65.2.1.4.6.1.2)
read-create
OCTET STRING
SIZE (1..31)
Policy name.
As per the MIB.
hh3cCBQoSGlobalApplyRowStatus (1.3.6.1.4.1.25506.2.65.2.1.4.6.1.3)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
hh3cCBQoSGlobalApplyStatus (1.3.6.1.4.1.25506.2.65.2.1.4.6.1.4)
read-only
INTEGER
·     processing (1)
·     success (2)
Application status.
As per the MIB.
About this table
This table describes application information for a QoS policy applied to a control plane.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table indexes are hh3cCBQoSCpApplyPolicyChassis, hh3cCBQoSCpApplyPolicySlot, and hh3cCBQoSCpApplyPolicyDirection.
Object (OID)
Access
Value range
Implementation
hh3cCBQoSCpApplyPolicyChassis (1.3.6.1.4.1.25506.2.65.2.1.4.7.1.1)
not-accessible
Unsigned32
Chassis number for the control plane.
As per the MIB.
(1.3.6.1.4.1.25506.2.65.2.1.4.7.1.2)
not-accessible
Unsigned32
Slot number for the control plane.
As per the MIB.
hh3cCBQoSCpApplyPolicyDirection (1.3.6.1.4.1.25506.2.65.2.1.4.7.1.3)
not-accessible
DirectionType
As per the MIB.
hh3cCBQoSCpApplyPolicyName (1.3.6.1.4.1.25506.2.65.2.1.4.7.1.4)
read-create
OCTET STRING
SIZE (1..31)
Policy name.
As per the MIB.
hh3cCBQoSCpApplyPolicyStatus
(1.3.6.1.4.1.25506.2.65.2.1.4.7.1.5)
read-only
INTEGER
·     processing (0)
·     success (1)
Application status.
As per the MIB.
hh3cCBQoSCpApplyRowStatus (1.3.6.1.4.1.25506.2.65.2.1.4.7.1.6)
read-create
RowStatus
Row status.
·     active(1)
·     createAndGo(4)
·     destroy(6)
About this table
This table obtains the application entity information for a QoS policy.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table index is hh3cCBQoSApplyObjectIndex.
Object (OID)
Access
Value range
Implementation
hh3cCBQoSApplyObjectIndex (1.3.6.1.4.1.25506.2.65.2.1.5.5.1.1.1)
not-accessible
Unsigned32
Application entity index.
As per the MIB.
hh3cCBQoSApplyObjectType (1.3.6.1.4.1.25506.2.65.2.1.5.5.1.1.2)
read-only
ApplyObjectType
Application entity type.
·     interface(1)
·     vlan(2)
·     controlPlane(5)
hh3cCBQoSApplyObjectDirection (1.3.6.1.4.1.25506.2.65.2.1.5.5.1.1.3)
read-only
DirectionType
Application entity direction.
As per the MIB.
hh3cCBQoSApplyObjectMainSite (1.3.6.1.4.1.25506.2.65.2.1.5.5.1.1.4)
read-only
Unsigned32
Main index of the application entity.
As per the MIB.
hh3cCBQoSApplyObjectSubChannel (1.3.6.1.4.1.25506.2.65.2.1.5.5.1.1.5)
read-only
Unsigned32
Subchannel ID of the application entity.
As per the MIB.
hh3cCBQoSApplyObjectSubClass (1.3.6.1.4.1.25506.2.65.2.1.5.5.1.1.6)
read-only
Unsigned32
Level-1 subclass number for level-2 nesting.
As per the MIB.
hh3cCBQoSApplyObjectSubClassSec (1.3.6.1.4.1.25506.2.65.2.1.5.5.1.1.7)
read-only
Unsigned32
Level-2 subclass number for level-3 nesting.
As per the MIB.
About this table
This table obtains the application entity index for a QoS policy applied to an interface.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table indexes are hh3cCBQoSIntApplyObjectIfIndex and hh3cCBQoSApplyObjectDirection.
Object (OID)
Access
Value range
Implementation
hh3cCBQoSIntApplyObjectIfIndex (1.3.6.1.4.1.25506.2.65.2.1.5.5.2.1.1)
not-accessible
Unsigned32
As per the MIB.
hh3cCBQoSIntApplyObjectIndex (1.3.6.1.4.1.25506.2.65.2.1.5.5.2.1.2)
read-only
Unsigned32
As per the MIB.
About this table
This table obtains the application entity index for a QoS policy applied to a VLAN or globally.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are hh3cCBQoSVlanApplyObjectVlanID and hh3cCBQoSApplyObjectDirection.
Object (OID)
Access
Value range
Implementation
hh3cCBQoSVlanApplyObjectVlanID (1.3.6.1.4.1.25506.2.65.2.1.5.5.3.1.1)
not-accessible
Unsigned32
0..4094
ID of the VLAN to which a QoS policy is applied.
When the value is 0, the QoS policy is applied globally.
hh3cCBQoSVlanApplyObjectIndex (1.3.6.1.4.1.25506.2.65.2.1.5.5.3.1.2)
read-only
Unsigned32
As per the MIB.
About this table
This table obtains the application entity index for a child QoS policy.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are hh3cCBQoSApplyObjectIndex and hh3cCBQoSNestPolicyClassIndex.
Object (OID)
Access
Value range
Implementation
hh3cCBQoSNestPolicyClassIndex (1.3.6.1.4.1.25506.2.65.2.1.5.5.5.1.1)
not-accessible
Unsigned32
Policy class index.
As per the MIB.
hh3cCBQoSNestPolicyApplyObjectIndex (1.3.6.1.4.1.25506.2.65.2.1.5.5.5.1.2)
read-only
Unsigned32
As per the MIB.
About this table
This table obtains QoS policy application information for a control plane.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are hh3cCBQoSCpApplyObjectChassis, hh3cCBQoSCpApplyObjectSlot, and hh3cCBQoSApplyObjectDirection.
Object (OID)
Access
Value range
Implementation
hh3cCBQoSCpApplyObjectChassis (1.3.6.1.4.1.25506.2.65.2.1.5.5.6.1.1)
not-accessible
Unsigned32
As per the MIB.
hh3cCBQoSCpApplyObjectSlot (1.3.6.1.4.1.25506.2.65.2.1.5.5.6.1.2)
not-accessible
Unsigned32
As per the MIB.
hh3cCBQoSCpApplyObjectIndex (1.3.6.1.4.1.25506.2.65.2.1.5.5.6.1.3)
read-only
Unsigned32
As per the MIB.
About this table
This table obtains CBQ queue statistics.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSCbqQueueSize (1.3.6.1.4.1.25506.2.65.2.1.5.6.1.1.1)
read-only
Integer32
Current CBQ queue size.
As per the MIB.
hh3cCBQoSCbqDiscard (1.3.6.1.4.1.25506.2.65.2.1.5.6.1.1.2)
read-only
Counter64
Number of packets dropped by the CBQ queue.
As per the MIB.
hh3cCBQoSCbqEfQueueSize (1.3.6.1.4.1.25506.2.65.2.1.5.6.1.1.3)
read-only
Integer32
EF queue size.
As per the MIB.
hh3cCBQoSCbqAfQueueSize (1.3.6.1.4.1.25506.2.65.2.1.5.6.1.1.4)
read-only
Integer32
AF queue size.
As per the MIB.
hh3cCBQoSCbqBeQueueSize (1.3.6.1.4.1.25506.2.65.2.1.5.6.1.1.5)
read-only
Integer32
BE queue size.
As per the MIB.
hh3cCBQoSCbqBeActiveQueueNum (1.3.6.1.4.1.25506.2.65.2.1.5.6.1.1.6)
read-only
Integer32
Number of active BE queues.
As per the MIB.
hh3cCBQoSCbqBeMaxActiveQueueNum (1.3.6.1.4.1.25506.2.65.2.1.5.6.1.1.7)
read-only
Integer32
Maximum number of active BE queues that have existed.
As per the MIB.
hh3cCBQoSCbqBeTotalQueueNum (1.3.6.1.4.1.25506.2.65.2.1.5.6.1.1.8)
read-only
Integer32
Total number of BE queues.
As per the MIB.
hh3cCBQoSCbqAfAllocatedQueueNum (1.3.6.1.4.1.25506.2.65.2.1.5.6.1.1.9)
read-only
Integer32
Number of AF queues that have been allocated.
As per the MIB.
About this table
This table obtains matching statistics about a traffic class.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are hh3cCBQoSApplyObjectIndex and hh3cCBQoSPolicyClassIndex.
Object (OID)
Access
Value range
Implementation
hh3cCBQoSClassMatchedPackets (1.3.6.1.4.1.25506.2.65.2.1.5.6.2.1.1)
read-only
Counter64
Number of matching packets.
As per the MIB.
hh3cCBQoSClassMatchedBytes (1.3.6.1.4.1.25506.2.65.2.1.5.6.2.1.2)
read-only
Counter64
Number of matching bytes.
As per the MIB.
hh3cCBQoSClassFwdPktpps (1.3.6.1.4.1.25506.2.65.2.1.5.6.2.1.3)
read-only
Unsigned32
Number of packets sent per second during the last collection interval.
Not supported
hh3cCBQoSClassFwdPktbps (1.3.6.1.4.1.25506.2.65.2.1.5.6.2.1.4)
read-only
Unsigned32
Number of bits sent per second during the last collection interval.
Not supported
hh3cCBQoSClassDropPktpps (1.3.6.1.4.1.25506.2.65.2.1.5.6.2.1.5)
read-only
Unsigned32
Number of packets dropped per second during the last collection interval.
Not supported
hh3cCBQoSClassDropPktbps (1.3.6.1.4.1.25506.2.65.2.1.5.6.2.1.6)
read-only
Unsigned32
Number of bits dropped per second during the last collection interval.
Not supported
hh3cCBQoSClassFlowStatInterval (1.3.6.1.4.1.25506.2.65.2.1.5.6.2.1.7)
read-only
Unsigned32
Statistics collection interval.
Not supported
hh3cCBQoSClassBehaviorStatus (1.3.6.1.4.1.25506.2.65.2.1.5.6.2.1.8)
read-only
INTEGER
·     success(1)
·     failure(2)
·     partialSuccess(3)
CB association application status.
As per the MIB.
About this table
This table obtains CAR statistics.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSCarGreenPackets (1.3.6.1.4.1.25506.2.65.2.1.5.6.3.1.1)
read-only
Counter64
Number of packets matching the CAR configuration
As per the MIB.
hh3cCBQoSCarGreenBytes (1.3.6.1.4.1.25506.2.65.2.1.5.6.3.1.2)
read-only
Counter64
Number of bytes matching the CAR configuration
As per the MIB.
hh3cCBQoSCarRedPackets (1.3.6.1.4.1.25506.2.65.2.1.5.6.3.1.3)
read-only
Counter64
Number of red packets.
As per the MIB.
hh3cCBQoSCarRedBytes (1.3.6.1.4.1.25506.2.65.2.1.5.6.3.1.4)
read-only
Counter64
Number of red bytes.
As per the MIB.
hh3cCBQoSCarYellowPackets (1.3.6.1.4.1.25506.2.65.2.1.5.6.3.1.5)
read-only
Counter64
Number of yellow packets.
As per the MIB.
hh3cCBQoSCarYellowBytes (1.3.6.1.4.1.25506.2.65.2.1.5.6.3.1.6)
read-only
Counter64
Number of yellow bytes.
As per the MIB.
About this table
This table obtains marking statistics.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSRemarkedPackets (1.3.6.1.4.1.25506.2.65.2.1.5.6.5.1.1)
read-only
Counter64
Number of packets marked.
As per the MIB.
About this table
.This table obtains queue-related traffic statistics.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSQueueMatchedPackets (1.3.6.1.4.1.25506.2.65.2.1.5.6.6.1.1)
read-only
Counter64
Number of packets matching a queue.
As per the MIB.
hh3cCBQoSQueueMatchedBytes (1.3.6.1.4.1.25506.2.65.2.1.5.6.6.1.2)
read-only
Counter64
Number of bytes matching the queue.
As per the MIB.
hh3cCBQoSQueueEnqueuedPackets (1.3.6.1.4.1.25506.2.65.2.1.5.6.6.1.3)
read-only
Counter64
Number of packets enqueued.
As per the MIB.
hh3cCBQoSQueueEnqueuedBytes (1.3.6.1.4.1.25506.2.65.2.1.5.6.6.1.4)
read-only
Counter64
Number of bytes enqueued.
As per the MIB.
hh3cCBQoSQueueDiscardedPackets (1.3.6.1.4.1.25506.2.65.2.1.5.6.6.1.5)
read-only
Counter64
Number of packets dropped by the queue.
As per the MIB.
hh3cCBQoSQueueDiscardedBytes (1.3.6.1.4.1.25506.2.65.2.1.5.6.6.1.6)
read-only
Counter64
Number of bytes dropped by the queue.
As per the MIB.
About this table
This table obtains traffic statistics.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSAccountingPackets (1.3.6.1.4.1.25506.2.65.2.1.5.6.8.1.1)
read-only
Counter64
Number of packets.
As per the MIB.
hh3cCBQoSAccountingBytes (1.3.6.1.4.1.25506.2.65.2.1.5.6.8.1.2)
read-only
Counter64
Number of bytes.
As per the MIB.
About this table
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cCBQoSPolicyAccPackets
read-only
Counter64
Number of packets.
As per the MIB.
hh3cCBQoSPolicyAccBytes
read-only
Counter64
Number of bytes.
As per the MIB.
