- 05-Layer 2 - LAN Switching
- 01-BRIDGE-MIB
- 02-EtherLike-MIB
- 03-HH3C-LAG-MIB
- 04-HH3C-LPBKDT-MIB
- 05-HH3C-LswMAM-MIB
- 06-HH3C-LswMSTP-MIB
- 07-HH3C-MAC-INFORMATION-MIB
- 08-HH3C-PVST-MIB
- 09-HH3C-VLANGROUP-MIB
- 10-HH3C-VOICE-VLAN-MIB
- 11-HH3C-LswVLAN-MIB
- 12-IEEE8021-CFM-MIB
- 13-IEEE8021-CFM-V2-MIB
- 14-IEEE8023-LAG-MIB
- 15-LLDP-EXT-MED-MIB
- 16-LLDP-EXT-DOT3-V2-MIB
- 17-LLDP-EXT-DOT1-EVB-EXTENSIONS-MIB
- 18-LLDP-EXT-DOT1-MIB
- 19-LLDP-EXT-DOT1-V2-MIB
- 20-LLDP-EXT-DOT3-MIB
- 21-LLDP-MIB
- 22-LLDP-V2-MIB
- 23-MAU-MIB
- 24-P-BRIDGE-MIB
- 25-Q-BRIDGE-MIB
- 26-RBRIDGE-MIB
| 23-MAU-MIB | 58.98 KB |
MAU-MIB
About this MIB
This MIB is defined in RFC 3636 and contains interface media attachment unit (MAU) information.
MIB file name
rfc3636-mau.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).snmpDot3MauMgt(26)
Tabular objects
ifMauTable
About this table
Use this table to obtain the interface MAU state.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are ifMauIfIndex and ifMauIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ifMauIfIndex (1.3.6.1.2.1.26.2.1.1.1) |
read-only |
InterfaceIndex |
Standard MIB values. |
Index of the interface in this entry. |
As per the MIB. |
ifMauIndex (1.3.6.1.2.1.26.2.1.1.2) |
read-only |
Integer32 |
Integer32 (1..2147483647) |
Interface MAU index. |
As per the MIB. |
ifMauType (1.3.6.1.2.1.26.2.1.1.3) |
read-only |
AutonomousType |
Interface MAU operation type. The value (1) indicates autonegotiation. The value (2) indicates autonegotiation is not enabled or applied on an interface. |
As per the MIB. |
ifMauStatus (1.3.6.1.2.1.26.2.1.1.4) |
read-write |
INTEGER |
other(1), unknown(2), operational(3), standby(4), shutdown(5), reset(6) |
Current state of the interface MAU. |
The object can only be read. |
ifMauMediaAvailable (1.3.6.1.2.1.26.2.1.1.5) |
read-only |
INTEGER |
other(1), unknown(2), available(3), notAvailable(4), remoteFault(5), invalidSignal(6), remoteJabber(7), remoteLinkLoss(8), remoteTest(9), offline(10), autoNegError(11), pmdLinkFault(12), wisFrameLoss(13), wisSignalLoss(14), pcsLinkFault(15), excessiveBER(16), dxsLinkFault(17), pxsLinkFault(18) |
Current availability state of the interface MAU. |
As per the MIB. |
ifMauMediaAvailableStateExits (1.3.6.1.2.1.26.2.1.1.6) |
read-only |
Counter32 |
Number of switchovers from state available(3) to another state on an interface MAU. |
As per the MIB. |
ifMauJabberState (1.3.6.1.2.1.26.2.1.1.7) |
read-only |
INTEGER |
other(1), unknown(2), noJabber(3), jabbering(4) |
Jabber state of an interface MAU. |
As per the MIB. |
ifMauJabberingStateEnters (1.3.6.1.2.1.26.2.1.1.8) |
read-only |
Counter32 |
Number of the jabber state switchovers to the jabbering(4) state on an interface MAU. |
As per the MIB. |
ifMauFalseCarriers (1.3.6.1.2.1.26.2.1.1.9) |
read-only |
Counter32 |
Number of false carrier events on an interface MAU. |
As per the MIB. |
ifMauTypeList (1.3.6.1.2.1.26.2.1.1.10) |
read-only |
Integer32 |
Interface MAU type list (as a best practice, do not use this object). |
As per the MIB. |
ifMauDefaultType (1.3.6.1.2.1.26.2.1.1.11) |
read-write |
AutonomousType |
Default interface MAU type. |
ifMauAutoNegSupported (1.3.6.1.2.1.26.2.1.1.12) |
read-only |
TruthValue |
true(1), false(2) |
Whether an interface MAU supports autonegotiation. |
As per the MIB. |
ifMauTypeListBits (1.3.6.1.2.1.26.2.1.1.13) |
read-only |
BITS |
bOther(0), bAUI(1), b10base5(2), bFoirl(3), b10base2(4), b10baseT(5), b10baseFP(6), b10baseFB(7), b10baseFL(8), b10broad36(9), b10baseTHD(10), b10baseTFD(11), b10baseFLHD(12), b10baseFLFD(13), b100baseT4(14), b100baseTXHD(15), b100baseTXFD(16), b100baseFXHD(17), b100baseFXFD(18), b100baseT2HD(19), b100baseT2FD(20), b1000baseXHD(21), b1000baseXFD(22), b1000baseLXHD(23), b1000baseLXFD(24), b1000baseSXHD(25), b1000baseSXFD(26), b1000baseCXHD(27), b1000baseCXFD(28), b1000baseTHD(29), b1000baseTFD(30), b10GbaseX(31), b10GbaseLX4(32), b10GbaseR(33), b10GbaseER(34), b10GbaseLR(35), b10GbaseSR(36), b10GbaseW(37), b10GbaseEW(38), b10GbaseLW(39), b10GbaseSW(40), |
Set of possible IEEE 802.3 types that the MAU could be. |
As per the MIB. |
ifMauHCFalseCarriers (1.3.6.1.2.1.26.2.1.1.14) |
read-only |
Counter64 |
Number of false carrier events on an interface MAU. A 64-bit counter is used to avoid counter rollover. |
As per the MIB. |
ifJackTable
About this table
Use this table to obtain the external jack information of an interface MAU.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are ifMauIfIndex, ifMauIndex, and ifJackIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ifJackIndex (1.3.6.1.2.1.26.2.2.1.1) |
not-accessible |
Integer32 |
Index of the external jack of an interface MAU. |
As per the MIB. |
ifJackType (1.3.6.1.2.1.26.2.2.1.2) |
read-only |
JackType |
Type of the external jack of an interface MAU. |
As per the MIB. |
ifMauAutoNegTable
About this table
Use this table to obtain the autonegotiation information of an interface MAU.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ifMauAutoNegAdminStatus (1.3.6.1.2.1.26.5.1.1.1) |
read-write |
INTEGER |
enabled(1), disabled(2) |
Autonegotiation enabling state of an interface MAU. |
ifMauAutoNegRemoteSignaling (1.3.6.1.2.1.26.5.1.1.2) |
read-only |
INTEGER |
detected(1), notdetected(2) |
Whether the remote end of the link is using autonegotiation signaling. |
As per the MIB. |
ifMauAutoNegConfig (1.3.6.1.2.1.26.5.1.1.4) |
read-only |
INTEGER |
other(1), configuring(2), complete(3), disabled(4), parallelDetectFail(5) |
Current autonegotiation state of an interface MAU. |
As per the MIB. |
ifMauAutoNegCapability (1.3.6.1.2.1.26.5.1.1.5) |
read-only |
Integer32 |
Autonegotiation type list of an interface MAU. |
As per the MIB. |
ifMauAutoNegCapAdvertised (1.3.6.1.2.1.26.5.1.1.6) |
read-write |
Integer32 |
Autonegotiation type list advertised by an interface MAU. |
ifMauAutoNegCapReceived (1.3.6.1.2.1.26.5.1.1.7) |
read-only |
Integer32 |
Received autonegotiation type list from a remote autonegotiation entity. |
As per the MIB. |
ifMauAutoNegRestart (1.3.6.1.2.1.26.5.1.1.8) |
read-write |
INTEGER |
restart(1), norestart(2) |
Whether autonegotiation will be restarted on an interface MAU. |
ifMauAutoNegCapabilityBits (1.3.6.1.2.1.26.5.1.1.9) |
read-only |
BITS |
bOther(0), b10baseT(1), b10baseTFD(2), b100baseT4(3), b100baseTX(4), b100baseTXFD(5), b100baseT2(6), b100baseT2FD(7), bfdxPause(8), bfdxAPause(9), bfdxSPause(10), bfdxBPause(11), b1000baseX(12), b1000baseXFD(13), b1000baseT(14), b1000baseTFD(15) |
Set of capabilities of the local autonegotiation entity. |
As per the MIB. |
ifMauAutoNegCapAdvertisedBits (1.3.6.1.2.1.26.5.1.1.10) |
read-write |
BITS |
bOther(0), b10baseT(1), b10baseTFD(2), b100baseT4(3), b100baseTX(4), b100baseTXFD(5), b100baseT2(6), b100baseT2FD(7), bFdxPause(8), bFdxAPause(9), bFdxSPause(10), bFdxBPause(11), b1000baseX(12), b1000baseXFD(13), b1000baseT(14), b1000baseTFD(15) |
Set of capabilities advertised by the local autonegotiation entity. |
ifMauAutoNegCapReceivedBits (1.3.6.1.2.1.26.5.1.1.11) |
read-only |
BITS |
Set of capabilities received from the remote autonegotiation entity. |
As per the MIB. |
ifMauAutoNegRemoteFaultAdvertised (1.3.6.1.2.1.26.5.1.1.12) |
read-write |
INTEGER |
noError(1), offline(2), linkFailure(3), autoNegError(4) |
Local fault indications that this MAU has detected and will advertise at the next autonegotiation interaction. |
ifMauAutoNegRemoteFaultReceived (1.3.6.1.2.1.26.5.1.1.13) |
read-only |
INTEGER |
Fault indications received by the local end from the far end. |
As per the MIB. |
