- 08-Radio Resources Management Configuration Guide
- 01-Radio management configuration
- 02-WLAN radio load balancing configuration
- 03-WLAN load balancing configuration
- 04-WLAN radio resource measurement configuration
- 05-WLAN RRM configuration
- 06-Band navigation configuration
- 07-Channel scanning configuration
- 08-Spectrum management configuration
07-Channel scanning configuration | 84.85 KB |
Channel scanning tasks at a glance
Setting the maximum service period
Setting the service idle timeout timer
Configuring the channel scanning blacklist or whitelist
Scanning only the working channel
Channel scanning configuration examples
Example: Configuring relative forwarding preferred channel scanning
Example: Configuring absolute forwarding preferred channel scanning
Configuring channel scanning
About channel scanning
Channel scanning enables APs to scan channels and capture wireless packets. The device analyzes the captured wireless packets to obtain wireless service information, including interferences, error bit rate, and wireless signal strength. Channel scanning provides data for WLAN RRM and WIPS, and enhances wireless service quality.
Basic concepts
· Scanning period—In this period, an AP only scans a channel and does not provide wireless services.
· Service period—In this period, an AP scans its working channel and provides wireless services simultaneously for a time period that is the same as the scanning period. After that, the AP only provides wireless services.
Work mechanism
An AP scans each channel on the channel scanning list in turn regardless of whether the AP provides wireless services, and each channel is scanned for a scanning period. If the AP does not provide wireless services, it starts scanning periods consecutively. If the AP provides wireless services, it starts service periods and scanning periods alternatively.
For example, Figure 1 shows the channel scanning mechanism for an AP when the AP works on channel 6 and the channel scanning list contains channels 1, 6, and 11.
Figure 1 Channel scanning mechanism
To configure channel scanning, perform the following tasks:
· Setting the maximum service period
· Setting the service idle timeout timer
· (Optional.) Configuring the channel scanning blacklist or whitelist
· (Optional.) Scanning only the working channel
Setting the scanning period
The scanning period defines the time period in which an AP scans a channel. In a service period, an AP scans its working channel and provides wireless services simultaneously for a time period that is the same as the scanning period.
The scanning period cannot be greater than the maximum service period.
1. Enter system view.
2. Enter radio interface view.
interface wlan-radio interface-number
3. Set the scanning period.
scan scan-time scan-time
By default, the scanning period is 100 milliseconds.
To ensure both scanning and service quality, you can set the maximum service period. When the maximum service period is reached, the AP starts a scanning period regardless of whether it has traffic to forward. To ensure wireless service quality, you can configure the AP to not limit the service period. The AP does not start a scanning period unless the service idle timeout timer expires.
3. Set the maximum service period.
scan max-service-time { max-service-time | no-limit }
By default, the maximum service period is not limited. An AP does not start a scanning period unless the service idle timeout timer expires.
During a service period, an AP does not begin a new scanning period until the current service period exceeds the scanning period even if the specified service idle timeout timer expires.
The service idle timeout timer cannot be greater than the maximum service period.
3. Set the service idle timeout timer.
scan idle-time idle-time
By default, the service idle timeout timer is 100 milliseconds.
If you configure the blacklist for an AP, the AP will not scan non-working channels in the blacklist. If you configure the whitelist for an AP, the AP will scan only channels in the whitelist and the working channel.
You cannot configure both the channel scanning blacklist and whitelist for the same AP.
3. Choose one option as needed:
¡ Configure the channel scanning blacklist.
scan channel blacklist channel-list
¡ Configure the channel scanning whitelist.
scan channel whitelist channel-list
By default, no channel scanning blacklist or whitelist is configured.
Enable this feature to enable an AP to scan only the working channel.
3. Enable the radio to scan only the working channel.
scan work-channel-only { disable | enable }
By default, a radio scans all supported channels in turn.
To ensure both channel scanning and wireless service quality, configure channel scanning and set the maximum service period for the AP, as shown in Figure 2.
# Enter interface view of Radio 1/0/2.
<AP> system-view
[AP] interface wlan-radio 1/0/2
# Set the scanning period to 200 milliseconds.
[AP-WLAN-Radio1/0/2] scan scan-time 200
# Set the maximum service period to 5000 milliseconds.
[AP-WLAN-Radio1/0/2] scan max-service-time 5000
# Set the service idle timeout timer to 100 milliseconds.
[AP-WLAN-Radio1/0/2] scan idle-time 100
To ensure wireless service quality, configure channel scanning and configure the AP to not limit the service period, as shown in Figure 3.
<AP> system-view
# Set the scanning period to 100 milliseconds.
[AP-WLAN-Radio1/0/2] scan scan-time 100
# Configure the radio to not limit the service period.
[AP-WLAN-Radio1/0/2] scan max-service-time no-limit
