| 02-WLAN IP snooping commands | 48.97 KB |
client ipv4-snooping arp-learning enable
client ipv4-snooping dhcp-learning enable
client ipv4-snooping dhcp-learning timeout
client ipv6-snooping dhcpv6-learning enable
client ipv6-snooping nd-learning enable
display wlan statistics client-ip-conflict
Use client ipv4-snooping arp-learning enable to enable snooping ARP packets.
Use undo client ipv4-snooping arp-learning enable to disable snooping ARP packets.
Snooping ARP packets is enabled.
Service template view
# Disable snooping ARP packets.
[Sysname] wlan service-template service1
[Sysname-wlan-st-service1] undo client ipv4-snooping arp-learning enable
Use client ipv4-snooping dhcp-learning enable to enable snooping DHCPv4 packets.
Use undo client ipv4-snooping dhcp-learning enable to disable snooping DHCPv4 packets.
Snooping DHCPv4 packets is enabled.
# Disable snooping DHCPv4 packets.
[Sysname-wlan-st-service1] undo client ipv4-snooping dhcp-learning enable
Use client ipv4-snooping dhcp-learning timeout to set the timeout for IPv4 address learning through DHCP.
Use undo client ipv4-snooping dhcp-learning timeout to restore the default.
client ipv4-snooping dhcp-learning timeout time
The timeout is 0 and the system does not log off clients that fail to obtain an IPv4 address through DHCP.
time: Specifies the timeout in the range of 1 to 600 seconds.
With the timeout set, the system logs off clients that fail to obtain an IPv4 address through DHCP within the specified period.
Make sure the service template is enabled before you execute this command.
This configuration takes effect only on clients coming online afterwards from the AC.
# Set the timeout to 180 seconds for IPv4 address learning through DHCP.
[Sysname] wlan service-template 1
[Sysname-wlan-st-1] client ipv4-snooping dhcp-learning timeout 180
Use client ipv6-snooping dhcpv6-learning enable to enable snooping DHCPv6 packets.
Use undo client ipv6-snooping dhcpv6-learning enable to disable snooping DHCPv6 packets.
Snooping DHCPv6 packets is disabled.
# Disable snooping DHCPv6 packets.
[Sysname-wlan-st-service1] client ipv6-snooping dhcpv6-learning enable
Use client ipv6-snooping nd-learning enable to enable snooping ND packets.
Use undo client ipv6-snooping nd-learning enable to disable snooping ND packets.
Snooping ND packets is disabled.
# Disable snooping ND packets.
[Sysname-wlan-st-service1] undo client ipv6-snooping nd-learning enable
Use display wlan statistics client-ip-conflict to display statistics about clients with conflict IP addresses.
# Display statistics about clients with conflict IP addresses.
<Sysname> display wlan statistics client-ip-conflict
IP New-MAC/APID Old-MAC/APID Time
192.168.1.1 a4c1-5b79-fa5b/1 1111-e121-ff00/2 03-22 10:00:00
ff03::101 22d3-c5b7-a4b5/2 000d-88f8-0577/1 03-22 10:01:00
IP |
Conflict IP obtained by the client. |
New-MAC/APID |
MAC address of the new client and the ID of the AP from which that client comes online. |
Old-MAC/APID |
MAC address of the old client and the ID of the AP to which the client is associated. |
Time |
Time when the client requested to add the IPCIM after it obtained a conflict IP address. |
