09-Radio Resources Management Command Reference
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(R5456)-6W10009-Radio Resources Management Command Reference
05-Band navigation commands
05-Band navigation commands 53.64 KB
The AP models and serial numbers in this document are used only as examples. Support for AP models and serial numbers depends on the AC model.
band-navigation
Use band-navigation enable to enable band navigation for an AP or AP group.
Use band-navigation disable to disable band navigation for an AP or AP group.
Use undo band-navigation to restore the default.
band-navigation { disable | enable }
In AP view, an AP uses the configuration in AP group view.
In AP group view, band navigation is enabled for an AP group.
AP view
AP group view
Band navigation takes effect on an AP only after you enable band navigation both globally and for the AP.
# Enable band navigation for AP ap1.
[Sysname] wlan ap ap1 model WA6320
[Sysname-wlan-ap-ap1] band-navigation enable
# Enable band navigation for AP group 1.
[Sysname] wlan ap-group 1
[Sysname-wlan-ap-group-1] band-navigation enable
wlan band-navigation enable
wlan band-navigation aging-time
Use wlan band-navigation aging-time to set the client information aging time.
Use undo wlan band-navigation aging-time to restore the default.
wlan band-navigation aging-time aging-time
The client information aging time is 180 seconds.
aging-time: Specifies the client information aging time in the range of 10 to 600 seconds.
When an AP receives an association request from a client, the AP records the client's information and starts the client information aging timer. If the AP receives a probe request or association request from the client before the aging timer expires, the AP refreshes the client information and resets the client information aging timer. If the AP does not receive any probe requests or association requests from the client before the aging timer expires, the AP deletes the client's information.
Configure an appropriate client information aging time to ensure both client association and system resource efficiency.
# Set the client information aging time to 50 seconds.
[Sysname] wlan band-navigation aging-time 50
wlan band-navigation balance access-denial
Use wlan band-navigation balance access-denial to set the maximum number of denials for 5 GHz association requests.
Use undo wlan band-navigation balance access-denial to restore the default.
wlan band-navigation balance access-denial access-denial
The maximum number of denials for 5 GHz association requests is 1.
access-denial: Specifies the maximum number of denials for 5 GHz association requests, in the range of 1 to 10.
If the number of times that a 5 GHz radio rejects a client reaches the specified maximum number, the radio accepts the association request of the client.
# Set the maximum number of denials to 5 for 5 GHz association requests.
[Sysname] wlan band-navigation balance access-denial 5
wlan band-navigation balance session
Use wlan band-navigation balance session to configure load balancing for band navigation.
Use undo wlan band-navigation balance session to restore the default.
wlan band-navigation balance session session [ gap gap ]
Load balancing is disabled for band navigation.
session: Specifies the client number threshold for the 5 GHz radio, in the range of 2 to 255.
gap: Specifies the threshold for the client number gap between the 5 GHz radio and the radio that has the fewest clients. The value range for this argument is 1 to 8 and the default value is 4.
If you enable band navigation but do not enable load balancing, the AC directs dual-band clients to the 5 GHz radio.
The AP rejects the 5 GHz association request of a client when the following conditions are met:
·     The number of clients on the 5 GHz radio reaches the specified threshold.
·     The client number gap between the 5 GHz radio and the radio that has the fewest clients reaches the specified threshold.
# Enable load balancing for band navigation, and set the client number threshold and session gap threshold to 10 and 5, respectively.
[Sysname] wlan band-navigation balance session 10 gap 5
Use wlan band-navigation enable to enable band navigation globally.
Use undo wlan band-navigation enable to restore the default.
Band navigation is disabled globally.
For band navigation to take effect, make sure fast association is disabled for the wireless service that the clients use.
Band navigation takes effect on an AP only when you enable band navigation both globally and for the AP.
# Enable band navigation globally.
[Sysname] wlan band-navigation enable
band-navigation
quick-association enable
wlan band-navigation rssi-threshold
Use wlan band-navigation rssi-threshold to set the received signal strength indicator (RSSI) threshold for band navigation.
Use undo wlan band-navigation rssi-threshold to restore the default.
wlan band-navigation rssi-threshold rssi-threshold
The RSSI threshold for band navigation is 15.
rssi-threshold: Specifies the RSSI threshold for band navigation, in the range of 5 to 100.
A client might be detected by multiple radios. A 5 GHz radio rejects the association request of a client if the client's RSSI is lower than the band navigation RSSI threshold.
# Set the RSSI threshold for band navigation to 40.
[Sysname] wlan band-navigation rssi-threshold 40
