09-Radio Resources Management Command Reference
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(R5456)-6W10009-Radio Resources Management Command Reference
02-WLAN radio load balancing commands
02-WLAN radio load balancing commands 82.10 KB
The AP models and serial numbers in this document are used only as examples. Support for AP models and serial numbers depends on the AC model.
display wlan radio-load-balance status service-template
Use display wlan radio-load-balance status service-template to display load balancing information for radios that are bound to a service template.
display wlan radio-load-balance status service-template template-name client mac-address
template-name: Specifies a service template by its name, a case-insensitive string of 1 to 63 characters.
client mac-address: Displays information about radios that have detected the specified client. The mac-address argument represents the MAC address of the client and is in H-H-H format.
# Display load balancing information for radios that are bound to service template st1 and that detect the client with MAC address 702d-2249-33bf.
<Sysname> display wlan radio-load-balance status service-template st1 client 702d-2249-33bf
Current radio load balancing mode: session
Threshold: 2
Gap: 1
Band ratio (5 G/2.4 G): 2/1
Total radios: 4
APID    RID    Sessions   Balanced(Y/N)
1       2       10          N
3       1       2           Y
4       1       2           Y
4       2       2           Y
Current radio load-balance mode
Session mode.
Threshold
Session threshold.
Gap
Session gap threshold. (This field is displayed only when the session gap threshold is configured.)
Band ratio (5G/2.4G)
Ratio of clients associated with 5 GHz radios to clients associated with 2.4 GHz radios.
(This field is displayed only when the ratio of clients associated with 5 GHz radios to clients associated with 2.4 GHz radios is configured.)
APID
AP ID.
RID
Radio ID
Session
Number of clients associated with the radio.
Balanced(Y/N)
Load balancing status:
·     Y—The radio has been load balanced.
·     N—The radio has not been load balanced.
wlan radio-load-balance access-denial
Use wlan radio-load-balance access-denial to set the maximum number of denials for association requests.
Use undo wlan radio-load-balance access-denial to restore the default.
wlan radio-load-balance access-denial access-denial
The maximum number of denials is 3 for association requests.
access-denial: Specifies the maximum number of denials for association requests, in the range of 2 to 10.
If the number of times that a radio rejects a client reaches the specified maximum number of denials for association requests, the radio accepts the association request from the client.
# Set the maximum number of denials to 4 for association requests.
[Sysname] wlan radio-load-balance access-denial 4
wlan radio-load-balance enable
Use wlan radio-load-balance enable to enable WLAN radio load balancing.
Use undo wlan radio-load-balance enable to disable WLAN radio load balancing.
wlan radio-load-balance enable [ mode session value [ gap gap-value | band-ratio 5g-proportion 2.4g-proportion ] [ report-time time ] ]
WLAN radio load balancing is disabled.
session value: Specifies the session threshold value in the range of 1 to 120.
gap gap-value: Specifies the session gap threshold value in the range of 1 to 12. The session gap is the difference between weighted client value of a radio where the client comes online and the weighted client value of the radio that has the fewest clients within the same AC. The weighted client value is equivalent to the number of clients multiplied by the radio weight value. The radio weight values of 2.4 GHz and 5 GHz radios are 2 and 1, respectively.
band-ratio 5g-proportion 2.4g-proportion: Specifies the ratio of clients associated with all 5 GHz neighbor radios to clients associated with all 2.4 GHz neighbor radios of a client. The value range is 1 to 5 for both the 5g-proportion and 2.4g-proportion arguments.
report-time time: Specifies the time to wait before an AP reports information about a client for the first time. The value range for the time argument is 500 to 5000 milliseconds and the default value is 1000 milliseconds.
The AC supports session-mode radio load balancing and the following radio load balancing types:
·     Session gap threshold based—The AC performs radio load balancing when the following conditions are met:
¡     The number of clients associated with a radio reaches the session threshold.
¡     The session gap between the radio and the radio that has the fewest clients reaches the session gap threshold.
·     Band ratio based—The AC performs radio load balancing in the following scenarios:
Scenario 1
¡     A client requests to associate with a 5 GHz radio.
¡     The number of online clients associated with the 5 GHz radio reaches the session threshold.
¡     The ratio between the number of clients associated with all 5 GHz neighbor radios multiplied by the radio weight value and the number of clients associated with all 2.4 GHz neighbor radios multiplied by the radio weight value is larger than the band ratio, or the load of the radio is higher than the average load of all radios of the same type.
Scenario 2
¡     A client requests to associate with a 2.4 GHz radio.
¡     The number of online clients associated with the 2.4 GHz radio reaches the session threshold.
¡     The ratio between the number of clients associated with all 5 GHz neighbor radios multiplied by the radio weight value and the number of clients associated with all 2.4 GHz neighbor radios multiplied by the radio weight value is smaller than or equivalent to the band ratio, or the load of the radio is lower than or equivalent to the average load of all radios of the same type.
When an AP receives the probe request from a client for the first time, the AP waits for the specified time period before it sends the client information to the AC. The AC creates a neighbor radio table for a client based on the information received from APs. To ensure data accuracy and save resources, set an appropriate wait time period.
If you do not specify a radio load balancing type, the session gap threshold based type is used. The session threshold is 50, and the session gap threshold 10.
Neighbor radios of a client refer to all radios that receive requests from the client.
# Enable WLAN radio load balancing.
[Sysname] wlan radio-load-balance enable mode session 4 gap 3
wlan radio-load-balance overload-5g ssid-hide
Use wlan radio-load-balance overload-5g ssid-hide enable to enable overloaded 5 GHz radios to hide SSIDs.
Use wlan radio-load-balance overload-5g ssid-hide disable to disable overloaded 5 GHz radios from hiding SSIDs.
Use undo wlan radio-load-balance overload-5g ssid-hide to restore the default.
wlan radio-load-balance overload-5g ssid-hide { disable | enable [ session value [ gap gap-value ] ] } [ force-logoff ]
In AP view, an AP uses the configuration in AP group view.
In AP group view, overloaded 5 GHz radios hide SSIDs.
AP view
AP group view
session value: Specifies the session threshold value in the range of 1 to 120. The default value is 5.
gap gap-value: Specifies the session gap threshold value in the range of 1 to 24. The default value is 4.
force-logoff: Forces half of the clients associated with the target 5 GHz radio to log off when the working channel of the other 5 GHz radio is no longer occupied by radar signals.
After you configure this command, a 5 GHz radio hides its SSID in beacon frames when the following conditions are met:
·     The number of clients associated with the 5 GHz radio reaches the session threshold.
·     The session gap between the 5 GHz radio and another 5 GHz radio on the same AP reaches the session gap threshold.
The 5 GHz radio stops hiding its SSID in beacon frame when either of the following conditions are met:
·     The number of clients associated with the 5 GHz radio falls below the session threshold.
·     The session gap between the 5 GHz radio and another 5 GHz radio on the same AP falls below the session gap threshold.
As a best practice, enable this feature when a large number of clients exist in the network.
This feature takes effect only when an AP has multiple 5 GHz radios.
When radar avoidance occurs on a 5 GHz radio, all clients on the radio will be transferred to the other 5 GHz radio of the same AP. As a result, the 5 GHz radio might be overloaded. To resolve this issue, specify the force-logoff keyword to force half of the clients on the overloaded 5 GHz radio to log off when the working channel of the other 5 GHz radio is no longer occupied by radar signals. Specifying the force-logoff keyword will force clients to log off. As a best practice, specify this keyword only when necessary.
# Enable overloaded 5 GHz radios of AP ap1 to hide SSIDs.
[Sysname] wlan ap ap1 model WA6320
[Sysname-wlan-ap-ap1] wlan radio-load-balance overload-5g ssid-hide enable session 20 gap 5
# Enable overloaded 5 GHz radios of APs in AP group group1 to hide SSIDs.
[Sysname] wlan ap-group group1
[Sysname-wlan-ap-group-group1] wlan radio-load-balance overload-5g ssid-hide enable session 20 gap 5
wlan radio-load-balance rssi-threshold
Use wlan radio-load-balance rssi-threshold to set the received signal strength indicator (RSSI) threshold.
Use undo wlan radio-load-balance rssi-threshold to restore the default.
wlan radio-load-balance rssi-threshold rssi-threshold
The RSSI threshold is 25.
rssi-threshold: Specifies the RSSI threshold in the range of 5 to 100.
If a radio detects that the RSSI of a client is lower than the specified RSSI threshold, the radio ignores the association requests of the client.
# Set the RSSI threshold to 40.
[Sysname] wlan radio-load-balance rssi-threshold 40
radio-load-balance band-navigation association-reject
Use radio-load-balance band-navigation association-reject to specify the maximum number of rejections for 2.4 GHz radios against non-802.11v clients.
Use undo radio-load-balance band-navigation association-reject to restore the default.
radio-load-balance band-navigation association-reject 5g-capability 5g-count unknown-capability unknown-count
In AP group view, a 2.4 GHz radio can reject the association request of a 5 GHz-capable client or unknown client only once.
AP view
AP group view
5g-count: Specifies the maximum number of rejections for 5 GHz-capable non-802.11v clients, in the range of 1 to 10.
unknown-count: Specifies the maximum number of rejections for non-802.11v clients with unknown 5 GHz capability, in the range of 1 to 10.
If the number of rejections has reached the maximum limit for a non-802.11v client, the client can associate with a 2.4 GHz radio. After client association, the rejection counter is reset. If the client goes offline and attempts to come online again from a 2.4 GHz radio, it will be rejected again as configured.
The rejection counter for a client is valid for 10 minutes and will be reset 10 minutes after the most recent rejection of the client.
This feature takes effect only when 2.4 GHz radio association rejection is enabled by using the radio-load-balance band-navigation enable association-reject command.
# Specify the maximum number of rejections as 2 for 5 GHz-capable non-802.11v clients, and 1 for non-802.11v clients with unknown 5 GHz capability for AP ap1.
[Sysname-wlan-ap-ap1] radio-load-balance band-navigation association-reject 5g-capability 2 unknown-capability 1
# Specify the maximum number of rejections as 2 for 5 GHz-capable non-802.11v clients, and 1 for non-802.11v clients with unknown 5 GHz capability for APs in AP group group1.
[Sysname-wlan-ap-group-group1] radio-load-balance band-navigation association-reject 5g-capability 2 unknown-capability 1
Use radio-load-balance band-navigation enable to enable band navigation for radio load balancing.
Use radio-load-balance band-navigation disable to disable band navigation for radio load balancing.
Use undo radio-load-balance band-navigation to restore the default.
radio-load-balance band-navigation { disable | enable [ association-reject ] }
In AP view, the AP group configuration is used.
In AP group view, band navigation for radio load balancing is enabled.
AP view
AP group view
association-reject: Enables association rejection for 2.4 GHz radios against non-802.11v clients. The association feature is disabled by default.
After you enable this feature, the device will send BSS switchover requests to the online 802.11v clients associated with the 2.4 GHz radio. Then, the 802.11v clients can select whether to switch to the 5 GHz radio configured with the 802.11v service.
After you specify the association-reject keyword, the AC rejects 2.4 GHz radio association requests from non-802.11v clients, and navigates the clients to 5 GHz radios. Clients can decide whether to associate with a 5 GHz radio as needed.
To specify the maximum number of rejections, execute the radio-load-balance band-navigation association-reject command. When the number of rejections for a client has reached the maximum limit, the device allows the client to connect to a 2.4 GHz radio.
The association rejection feature does not take effect on roaming clients. For more information about roaming, see WLAN Roaming Configuration Guide.
As a best practice to improve the data transmission performance:
·     Use radio-load-balance band-navigation enable when a large number of 802.11v clients are associated with 2.4 GHz radios.
·     Use radio-load-balance band-navigation enable association-reject when a large number of non-802.11v clients are associated with 2.4 GHz radios.
To view the number of 802.11v and non-802.11v clients associated with 2.4 GHz radios, execute the display wlan client verbose command.
# Enable band navigation for radio load balancing. (AP view)
[Sysname-wlan-ap-ap1] radio-load-balance band-navigation enable
# Enable band navigation for radio load balancing. (AP group view)
[Sysname-wlan-ap-group-group1] radio-load-balance band-navigation enable
bss transition-management enable
