- 05-Network Connectivity Command Reference
- 01-MAC address table commands
- 02-Ethernet link aggregation commands
- 03-Port isolation commands
- 04-VLAN commands
- 05-Loop detection commands
- 06-Spanning tree commands
- 07-LLDP commands
- 08-Layer 2 forwarding commands
- 09-VLAN termination commands
- 10-PPP commands
- 11-L2TP commands
- 12-ARP commands
- 13-IP addressing commands
- 14-DHCP commands
- 15-DHCPv6 commands
- 16-DNS commands
- 17-NAT commands
- 18-IP performance optimization commands
- 19-IPv6 basics commands
- 20-Policy-based routing commands
- 21-IPv6 policy-based routing commands
- 22-GRE commands
- 23-Tunneling commands
- 24-ADVPN commands
- 25-Basic IP routing commands
- 26-IP forwarding basics commands
- 27-Static routing commands
- 28-IPv6 static routing commands
- 29-RIP commands
- 30-RIPng commands
- 31-IGMP snooping commands
- 32-MLD snooping commands
- 33-Modem management commands
- 34-3G and 4G modem management commands
| 10-PPP commands | 371.79 KB |
ppp compression iphc rtp-connections
ppp compression iphc tcp-connections
remote address dhcp client-identifier
display pppoe-server session packet
display pppoe-server session summary
display pppoe-server throttled-mac
pppoe-server access-line-id bas-info
pppoe-server access-line-id circuit-id parse-mode
pppoe-server access-line-id circuit-id trans-format
pppoe-server access-line-id content
pppoe-server access-line-id remote-id trans-format
pppoe-server access-line-id trust
pppoe-server session-limit per-mac
pppoe-server session-limit per-vlan
pppoe-server session-limit total
pppoe-server tag ppp-max-payload
pppoe-server virtual-template va-pool
display pppoe-client session packet
display pppoe-client session summary
reset pppoe-client session packet
PPP commands
The WX1800H series, WX2500H series, MAK series, and WX3000H series access controllers do not support parameters or commands that are available only in IRF mode.
PPP commands
The following compatibility matrix shows the support of hardware platforms for PPP:
Hardware series |
Model |
Product code |
PPP compatibility |
WX1800H series |
WX1804H-PWR |
EWP-WX1804H-PWR-CN |
Yes |
WX2500H series |
WX2508H-PWR-LTE WX2510H-PWR WX2510H-F-PWR WX2540H WX2540H-F WX2560H |
EWP-WX2508H-PWR-LTE EWP-WX2510H-PWR EWP-WX2510H-F-PWR EWP-WX2540H EWP-WX2540H-F EWP-WX2560H |
Yes |
MAK series |
MAK204 MAK206 |
EWP-MAK204 EWP-MAK206 |
Yes |
WX3000H series |
WX3010H WX3010H-X-PWR WX3010H-L-PWR WX3024H WX3024H-L-PWR WX3024H-F |
EWP-WX3010H EWP-WX3010H-X-PWR EWP-WX3010H-L-PWR EWP-WX3024H EWP-WX3024H-L-PWR EWP-WX3024H-F |
Yes: · WX3010H · WX3010H-X-PWR · WX3024H · WX3024H-F No: · WX3010H-L-PWR · WX3024H-L-PWR |
WX3500H series |
WX3508H WX3508H WX3510H WX3510H WX3520H WX3520H-F WX3540H WX3540H |
EWP-WX3508H EWP-WX3508H-F EWP-WX3510H EWP-WX3510H-F EWP-WX3520H EWP-WX3520H-F EWP-WX3540H EWP-WX3540H-F |
Yes |
WX5500E series |
WX5510E WX5540E |
EWP-WX5510E EWP-WX5540E |
Yes |
WX5500H series |
WX5540H WX5560H WX5580H |
EWP-WX5540H EWP-WX5560H EWP-WX5580H |
Yes |
Access controller modules |
LSUM1WCME0 EWPXM1WCME0 LSQM1WCMX20 LSUM1WCMX20RT LSQM1WCMX40 LSUM1WCMX40RT EWPXM2WCMD0F EWPXM1MAC0F |
Yes |
Hardware series |
Model |
Product code |
PPP compatibility |
WX1800H series |
WX1804H-PWR WX1810H-PWR WX1820H WX1840H |
EWP-WX1804H-PWR EWP-WX1810H-PWR EWP-WX1820H EWP-WX1840H-GL |
Yes |
WX3800H series |
WX3820H WX3840H |
EWP-WX3820H-GL EWP-WX3840H-GL |
Yes |
WX5800H series |
WX5860H |
EWP-WX5860H-GL |
Yes |
display ip pool
Use display ip pool to display PPP address pools.
display ip pool [ pool-name | group group-name ]
pool-name: Specifies a PPP address pool by its name, a case-sensitive string of 1 to 31 characters.
group group-name: Displays PPP address pools in a group specified by its name, a case-sensitive string of 1 to 31 characters.
If you do not specify any parameters, the command displays brief information about all PPP address pools.
If you specify an address pool, the command displays detailed information about the specified PPP address pool.
# Display brief information about all PPP address pools.
<Sysname> display ip pool
Group name: a
Pool name Start IP address End IP address Free In use
aaa1 1.1.1.1 1.1.1.5 5 0
aaa2 1.1.1.6 1.1.1.10 5 0
Group name: b
bbb 1.1.2.1 1.1.2.5 4 1
2.2.2.1 2.2.2.5 5 0
# Display brief information about the PPP address pools in group a.
<Sysname> display ip pool group a
Group name: a
# Display detailed information about PPP address pool bbb.
<Sysname> display ip pool bbb
Group name: b
2.2.2.1 2.2.2.5 5 0
In use IP addresses:
IP address Interface
1.1.2.1 Virtual-Template1
Free |
Number of free IP addresses. |
In use |
Number of IP addresses that have been assigned. |
In use IP addresses |
Information about the IP addresses that have been assigned. |
Local interface that requests the IP address for the peer interface. |
ip pool
display ppp access-user
Use display ppp access-user to display PPP user information.
display ppp access-user { interface interface-type interface-number [ count ] | ip-address ipv4-address | ipv6-address ipv6-address| username user-name | user-type { lac | lns | pppoe } [ count ] }
interface interface-type interface-number: Displays brief information about PPP users on the specified interface.
ip-address ipv4-address: Displays detailed information about the PPP user specified by its IPv4 address.
ipv6-address ipv6-address: Displays detailed information about the PPP user specified by its IPv6 address.
username user-name: Displays detailed information about the PPP user specified by its username, a case-sensitive string of 1 to 80 characters.
user-type: Displays brief information about online users of the specified type.
lac: Displays brief information about L2TP users for an LAC.
lns: Displays brief information about L2TP users for an LNS.
pppoe: Displays brief information about PPPoE users.
count: Displays the total number of PPP users matching the specified criterion.
Brief information about a PPP user includes the following:
· Brief name of the VA interface.
· Username.
· MAC address.
· IPv4 address, IPv6 address, or IPv6 prefix of the PPP user.
Detailed information about a PPP user includes the following:
· User ID.
· Username.
· Authentication information.
· Uplink and downlink traffic.
· Access start time of the PPP user.
In an L2TP network, this command is supported on an LAC only if a remote system dials in to the LAC through a PPPoE network. For more information about L2TP, see L2TP configuration in Network Connectivity Configuration Guide.
# Display brief information about PPP users on GigabitEthernet 1/0/1.
<Sysname> display ppp access-user interface gigabitethernet 1/0/1
Interface Username MAC address IP address IPv6 address IPv6 PDPrefix
VA0 user1@dm1 0001-0101-9101 192.168.100.173 - -
VA1 user2@dm2 0001-0101-9101 192.168.80.173 2000::1 -
# Display the total number of PPP users on GigabitEthernet 1/0/1.
<Sysname> display ppp access-user interface gigabitethernet 1/0/1 count
Total users: 2
Name of the VA interface corresponding to the user. |
Username of the user. A hyphen (-) means that the user does not need authentication. |
MAC address |
MAC address of the user. A hyphen (-) means that the user is not a PPPoE user. |
IP address |
IP address of the user. A hyphen (-) means that no IP address is assigned to the user. |
IPv6 address |
IPv6 address of the user. A hyphen (-) means that no IPv6 address is assigned to the user. |
IPv6 PD prefix |
IPv6 prefix of the user. A hyphen (-) means that no IPv6 prefix is assigned to the user. |
Total users |
Total number of PPP users. |
# Display detailed information about the PPP user whose IP address is 50.50.50.3.
<Sysname> display ppp access-user ip-address 50.50.50.3
Basic:
Interface: VA0
User ID: 0x28000002
Username: user1@hrss
Domain: hrss
Access interface: RAGG2
Service-VLAN/Customer-VLAN: -/-
MAC address: 0000-0000-0001
IP address: 50.50.50.3
IPv6 address: -
IPv6 PD prefix: -
VPN instance: 123
Access type: PPPoE
Authentication type: CHAP
AAA:
Authentication state: Authenticated
Authorization state: Authorized
Realtime accounting switch: Open
Realtime accounting interval: 60s
Login time: 2013-1-19 2:42:3:358
Accounting start time: 2013-1-19 2:42:3:382
Online time(hh:mm:ss): 0:7:34
Accounting state: Accounting
Idle cut: 0 sec 0 byte
Session timeout: 12000 s
Time remained: 8000 s
Byte remained: 20971520 bytes
Redirect WebURL: http://6.6.6.6
ACL&QoS:
User profile: profile123 (active)
User group profile: -
Inbound CAR: CIR 64000bps PIR 640000bps CBS 500bit
Outbound CAR: CIR 64000bps PIR 640000bps CBS 500bit
NAT:
Global IP address: 111.8.0.200
Port block: 28744-28748
Flow Statistic:
IPv4 uplink packets/bytes: 7/546
IPv4 downlink packets/bytes: 0/0
IPv6 uplink packets/bytes: 0/0
IPv6 downlink packets/bytes: 0/0
ITA:
Level-1 uplink packets/bytes: 100/128000
downlink packets/bytes: 200/256000
Level-2 uplink packets/bytes: 100/128000
Basic |
Basic information. |
Brief name of the VA interface that corresponds to the user. |
Username |
Domain |
ISP domain name for authentication. A hyphen (-) means that no ISP domain is specified for authentication. |
Access interface |
Name of the access interface of the user. |
Service-VLAN/Customer-VLAN |
Service provider VLAN and customer VLAN information of the user. A hyphen (-) means that no VLAN information is available. |
IP address |
IPv6 address |
IPv6 PD prefix |
Delegated IPv6 prefix of the user. A hyphen (-) means that no delegated IPv6 prefix is assigned to the user. |
VPN instance |
This field is not supported in the current software version.VPN instance to which the user belongs. A hyphen (-) means that the user is not bound to any VPN instance. |
Access type |
Access type of the user: · PPPoE. · L2TP. |
Authentication type |
Authentication type of the user: PAP or CHAP. |
Authentication state |
Authentication state of the user: · Idle—The user has not been authenticated. · Authenticating—The user is being authenticated. · Authenticated—The user has been authenticated. |
Authorization state |
Authorization state of the user: · Idle—The user has not been authorized. · Authorizing—The user is being authorized. · Authorized—The user has been authorized. |
Realtime accounting switch |
· Open—The switch is on. · Closed—The switch is off. |
Realtime accounting interval |
Realtime accounting interval in seconds. A hyphen (-) means that no real-time accounting interval is authorized. |
Login time |
Time when the user accessed the device through PPP. |
Accounting start time |
Time when accounting started. A hyphen (-) means that no accounting is performed on the user. |
Online time(hh:mm:ss) |
Online duration of the current login. |
Accounting state |
Accounting state of the user: · Accounting—Accounting is on. · Stop—Accounting stops. |
Idle cut |
Traffic threshold for logging off the user in idle state. If the traffic is less than the threshold within the specified period, the user is forcibly logged off. |
Session timeout |
Authorization time for the user, in seconds. A hyphen (-) means that no authorization time is specified for the user. |
Time remained |
Remaining time for the user to stay online, in seconds. A hyphen (-) means that no authorization time is specified for the user. |
Byte remained |
Remaining traffic for the user. A hyphen (-) means that no authorization traffic is specified for the user. |
Redirect WebURL |
Redirect Web URL address for the user. A hyphen (-) means that no redirect Web URL address is specified for the user. |
User profile |
Name of the authorized user profile. The hyphen (-) means that no user profile is authorized. The user profile has two states: · active—The authorized user profile is successfully issued. · inactive—The authorized user profile fails to be issued. |
User group profile |
Name of the authorized user group profile. The hyphen (-) means that no user group profile is authorized. The user group profile has two states: · active—The authorized user group profile is successfully issued. · inactive—The authorized user group profile fails to be issued. |
Inbound CAR |
Authorized inbound CAR parameters, which contain the CIR (in bps), the PIR (in bps), and the CBS (in bits). |
Outbound CAR |
Authorized outbound CAR parameters, which contain the CIR (in bps), the PIR (in bps), and the CBS (in bits). |
Global IP address |
Global IP address of the user. This field is displayed if NAT444 is used. For information about NAT444, see Network Connectivity Configuration Guide. |
Port block |
Port block of the user, from the start port to the end port. This field is displayed if NAT444 is used. |
IPv4 uplink packets/bytes |
Number of packets and bytes for IPv4 uplink traffic. |
IPv4 downlink packets/bytes |
Number of packets and bytes for IPv4 downlink traffic. |
IPv6 uplink packets/bytes |
Number of packets and bytes for IPv6 uplink traffic. |
IPv6 downlink packets/bytes |
Number of packets and bytes for IPv6 downlink traffic. |
ITA |
ITA statistics. ITA statistics are displayed after ITA is enabled. If the traffic-separate enable command is configured, ITA statistics are not included in flow statistics. For information about ITA and the traffic-separate enable command, see User Access and Authentication Configuration Guide. |
Level-n uplink packets/bytes downlink packets/bytes |
Number of packets and bytes for uplink traffic at accounting level n. The value for n depends on the traffic level command, and its value range is 1 to 8. |
reset ppp access-user
display ppp compression iphc
Use display ppp compression iphc to display IP header compression (IPHC) statistics.
display ppp compression iphc { rtp | tcp } [ interface interface-type interface-number ]
rtp: Displays IPHC RTP header compression statistics.
tcp: Displays IPHC TCP header compression statistics.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify this option, the command displays IPHC statistics on all interfaces.
When IPHC applies to a normal PPP link, the physical interface performs IPHC. You can view the compression information on the physical interface.
# (In standalone mode.) Display IPHC RTP header compression statistics.
<Sysname> display ppp compression iphc rtp
Interface: Virtual-Access0
Received:
Compressed/Error/Total: 0/0/0 packets
Sent:
Compressed/Total: 0/0 packets
Sent/Saved/Total: 0/0/0 bytes
Packet-based compression ratio: 0%
Byte-based compression ratio: 0%
Connections:
Rx/Tx: 16/16
Five-Minute-Miss: 0 (Misses/5Mins)
Max-Miss: 0
# (In standalone mode.) Display IPHC TCP header compression statistics.
<Sysname> display ppp compression iphc tcp
Received:
Sent:
Connections:
Rx/Tx: 16/16
Max-Miss: 0
# (In IRF mode.) Display IPHC RTP header compression statistics.
----------------------Slot1----------------------
Received:
Sent:
Connections:
Rx/Tx: 16/16
Max-Miss: 0
----------------------Slot2----------------------
Received:
Compressed/Error/Total: 20/5/40 packets
Sent:
Compressed/Total: 34/40 packets
Sent/Saved/Total: 1131/1210/2341 bytes
Packet-based compression ratio: 85%
Byte-based compression ratio: 51%
Connections:
Rx/Tx: 16/16
Max-Miss: 0
# (In IRF mode.) Display IPHC TCP header compression statistics.
<Sysname>display ppp compression iphc tcp
Received:
Sent:
Connections:
Rx/Tx: 16/16
Max-Miss: 0
Received:
Sent:
Connections:
Rx/Tx: 16/16
Max-Miss: 0
Received: Compressed/Error/Total |
Statistics for received packets: · Compressed—Number of compressed packets. · Error—Number of error packets. · Total—Total number of received packets. |
Sent: Compressed/Total Sent/Saved/Total Packet-based compression ratio Byte-based compression ratio |
Statistics for sent packets: · Compressed—Number of compressed packets. · Total—Total number of sent packets. · Sent—Bytes of sent packets. · Saved—Bytes of saved packets. · Total—Total bytes to be sent if packets are not compressed. · Packet-based compression ratio—Ratio of compressed packets to the total sent packets. · Byte-based compression ratio—Ratio of saved bytes to the total sent bytes. |
Connections: Rx/Tx Five-Minute-Miss Max-Miss |
Number of connections. · Rx—Number of connections that the receiver can decompress. · Tx—Number of connections that the sender can compress. · Five-Minute-Miss—Number of search failures within the last 5 minutes. · Max-Miss—Maximum number of search failures within 5 minutes. |
ppp compression iphc enable
reset ppp compression iphc
ip address ppp-negotiate
Use ip address ppp-negotiate to enable IP address negotiation on an interface, so that the interface can accept the IP address allocated by the server.
Use undo ip address ppp-negotiate to restore the default.
IP address negotiation is disabled on an interface.
Interface view
If you execute the ip address ppp-negotiate and ip address commands multiple times, the most recent configuration takes effect.
# Enable IP address negotiation on Virtual-Template 1.
[Sysname] interface virtual-template 1
[Sysname-Virtual-Template1] ip address ppp-negotiate
ip address (Network Connectivity Command Reference)
remote address
ip pool
Use ip pool to configure a PPP address pool.
Use undo ip pool to remove a PPP address pool or an IP address range of the PPP address pool.
ip pool pool-name start-ip-address [ end-ip-address ] [ group group-name ]
undo ip pool pool-name [ start-ip-address [ end-ip-address ] ]
No PPP address pool is configured.
pool-name: Specifies a name for the PPP address pool to be created, a case-sensitive string of 1 to 31 characters.
start-ip-address [ end-ip-address ]: Specifies an IP address range. If you do not specify the end-ip-address argument, the PPP address pool has only the start IP address.
group group-name: Specifies a group by its name to which the PPP address pool belongs. The group name is a case-sensitive string of 1 to 31 characters. If you do not specify this option, the group name is default (the default group).
Each address space is represented by a group. One group can contain multiple PPP address pools, but one PPP address pool can belong to only one group.
One PPP address pool can contain multiple IP address ranges. You can execute this command multiple times to specify multiple IP address ranges for a PPP address pool. A PPP address pool can contain a maximum of 65535 IP addresses, and so can an IP address range.
IP address ranges in different groups can be overlapping, but those in the same group cannot.
Changes to a PPP address pool do not affect assigned IP addresses. For example, if you delete a PPP address pool from which an IP address has been assigned, the IP address can still be used.
When assigning IP address to users through a PPP address pool, make sure the PPP address pool excludes the gateway IP address of the PPP address pool.
# Configure PPP address pool aaa that contains IP addresses 129.102.0.1 through 129.102.0.10 for group a.
[Sysname] ip pool aaa 129.102.0.1 129.102.0.10 group a
display ip pool
ip pool gateway
Use ip pool gateway to configure a gateway address for a PPP address pool.
Use undo ip pool gateway to remove the gateway address for the specified PPP address pool.
ip pool pool-name gateway ip-address
undo ip pool pool-name gateway
A PPP address pool is not configured with a gateway address.
pool-name: Specifies an existing PPP address pool by its name, a case-sensitive string of 1 to 31 characters.
ip-address: Specifies a gateway address for the PPP address pool.
An interface on a BRAS must have an IP address before it can assign an IP address from a PPP or DHCP address pool to a client. This command enables interfaces that have no IP address to use a gateway address for IPCP negotiation and address allocation.
When you configure a gateway address for a PPP address pool, follow these restrictions and guidelines:
· If you also specify an IP address for an interface, the interface uses its own IP address to perform IPCP negotiation.
· You can specify any gateway address for a PPP address pool.
# Specify gateway address 1.1.1.1 for PPP address pool aaa.
[Sysname] ip pool aaa gateway 1.1.1.1
ip pool
nas-port-type
Use nas-port-type to configure the NAS-Port-Type attribute on a VT interface.
Use undo nas-port-type to restore the default.
nas-port-type { ethernet | virtual }
undo nas-port-type
The NAS-Port-Type attribute is determined by the service type and link type of the PPP user, as shown in Table 5.
Table 5 Default NAS-Port-Type attribute
Service type |
Link type |
NAS-Port-Type attribute |
PPPoE |
Any |
ethernet |
L2TP |
Any |
virtual |
VT interface view
ethernet: Specifies Ethernet. The code value is 15.
virtual: Specifies virtual. The code value is 5.
The NAS-Port-Type attribute is used for RADIUS authentication and accounting. For more information about the NAS-Port-Type attribute, see RFC 2865.
This command does not affect existing users.
# Set the NAS-Port-Type attribute to ethernet for Virtual-Template 1.
[Sysname-Virtual-Template1] nas-port-type ethernet
ppp account-statistics enable
Use ppp account-statistics enable to enable PPP accounting on an interface.
Use undo ppp account-statistics enable to disable PPP accounting on an interface.
ppp account-statistics enable [ acl { acl-number | name acl-name } ]
PPP accounting is disabled on an interface.
Interface view
acl: Specifies an ACL to match traffic. If no ACL is specified, the device generates statistics for all PPP traffic.
acl-number: Specifies an ACL by its number in the range of 2000 to 3999, where:
· 2000 to 2999 are numbers for basic IPv4 and IPv6 ACLs.
· 3000 to 3999 are numbers for advanced IPv4 and IPv6 ACLs.
If the specified ACL number corresponds to an IPv4 ACL and an IPv6 ACL, both ACLs take effect.
name acl-name: Specifies an ACL by its name, a case-insensitive string of 1 to 63 characters that start with an alphabetical character. To avoid confusion, do not use all as an ACL name.
# Enable PPP accounting on Virtual-Template 1.
[Sysname-Virtual-Template1] ppp account-statistics enable
ppp authentication-mode
Use ppp authentication-mode to configure PPP authentication on an interface.
Use undo ppp authentication-mode to restore the default.
ppp authentication-mode { chap | pap } * [ [ call-in ] domain { isp-name | default enable isp-name } ]
PPP authentication is disabled on an interface.
Interface view
chap: Uses CHAP authentication.
pap: Uses PAP authentication.
call-in: Authenticates the call-in users only.
domain isp-name: Specifies the ISP domain name for authentication, a case-insensitive string of 1 to 255 characters.
default enable isp-name: Specifies the default ISP domain name for authentication, a case-insensitive string of 1 to 255 characters.
PPP authentication includes the following categories:
· PAP—Two-way handshake authentication. The password is in plain text or cipher text.
· CHAP—Three-way handshake authentication. The password is in plain text or cipher text.
You can configure multiple authentication modes.
In any PPP authentication mode, AAA determines whether a user can pass the authentication through a local authentication database or an AAA server. For more information about AAA authentication, see User Access and Authentication Configuration Guide.
If multiple ISP domains are available, the ISP domains are used in the following order:
1. ISP domain specified by the domain isp-name option in this command.
Associate a PPP address pool with this ISP domain for address allocation if necessary.
2. ISP domain contained in the username.
If the ISP domain does not exist on the local device, the user's access request is denied.
3. ISP domain specified by the domain default enable isp-name option in this command.
4. Default system ISP domain.
You can use the domain default command to configure the default system ISP domain. If no system default ISP domain is configured, ISP domain system is used.
# Configure Virtual-Template 1 to authenticate the peer by using PAP.
[Sysname-Virtual-Template1] ppp authentication-mode pap
# Configure Virtual-Template 1 to authenticate the peer by using PAP and CHAP.
[Sysname-Virtual-Template1] ppp authentication-mode pap chap
domain default (User Access and Authentication Command Reference)
local-user (User Access and Authentication Command Reference)
ppp chap password
ppp chap user
ppp pap local-user
ppp chap password
Use ppp chap password to set the password for CHAP authentication on an interface.
Use undo ppp chap password to restore the default.
ppp chap password { cipher | simple } string
No password is set for CHAP authentication on an interface.
Interface view
string: Specifies the password. Its plaintext form is a case-sensitive string of 1 to 255 characters. Its encrypted form is a case-sensitive string of 1 to 373 characters.
# Set the password for CHAP authentication to plaintext password sysname on Virtual-Template 1.
[Sysname-Virtual-Template1] ppp chap password simple sysname
ppp authentication-mode chap
ppp chap user
Use ppp chap user to set the username for CHAP authentication on an interface.
Use undo ppp chap user to restore the default.
ppp chap user username
undo ppp chap user
The username for CHAP authentication is null on an interface.
Interface view
username: Specifies the username for CHAP authentication, a case-sensitive string of 1 to 80 characters. The username is sent to the peer for the local device to be authenticated.
To pass CHAP authentication, the username/password of one side must be the local username/password on the peer.
# Set the username for CHAP authentication to Root on Virtual-Template 1.
[Sysname-Virtual-Template1] ppp chap user Root
Use ppp compression iphc enable to enable IPHC on an interface.
Use undo ppp compression iphc enable to disable IPHC on an interface.
ppp compression iphc enable [ nonstandard ]
IPHC is disabled on an interface.
Interface view
nonstandard: Specifies the nonstandard encapsulation format. If you do not specify this keyword, packets are encapsulated in standard format. You must specify this keyword when the device communicates with a non-H3C device. If you specify this keyword, this command enables RTP header compression.
IPHC includes RTP header compression and TCP header compression.
Enabling or disabling IPHC enables or disables both RTP header compression and TCP header compression.
To use IPHC, you must enable it on both sides of a PPP link.
When you enable IPHC on a VT or dialer interface, the setting does not immediately take effect. For the setting to take effect, execute the shutdown and then undo shutdown commands on the interface or its bound physical interface.
# Enable IPHC on Virtual-Template 1.
[Sysname-Virtual-Template1] ppp compression iphc enable
Use ppp compression iphc rtp-connections to set the maximum number of connections for which an interface can perform RTP header compression.
Use undo ppp compression iphc rtp-connections to restore the default.
ppp compression iphc rtp-connections number
An interface can perform RTP header compression for a maximum of 16 connections.
Interface view
number: Specifies the maximum number of connections for which an interface can perform RTP header compression. The value range for this argument is 3 to 1000:
· When the number argument is set to a value less than or equal to 256, packets are compressed in the format of COMPRESSED RTP 8.
· When the number argument is set to a value greater than 256, packets are compressed in the format of COMPRESSED RTP 16.
RTP is a connection-oriented protocol. An interface can accommodate multiple RTP connections.
RTP header compression occupies memory resources for maintaining connection information. This command can limit memory resources used by compression. For example, if you set the limit to 3, RTP header compression only applies to a maximum of three RTP connections.
After you execute this command, you must shut down and then bring up the interface to make the command take effect.
You can configure this command only when IPHC is enabled. The configuration is removed after IPHC is disabled.
# Set the maximum number of connections for which Virtual-Template 1 can perform RTP header compression to 10.
[Sysname-Virtual-Template1] ppp compression iphc rtp-connections 10
Use ppp compression iphc tcp-connections to set the maximum number of connections for which an interface can perform TCP header compression.
Use undo ppp compression iphc tcp-connections to restore the default.
ppp compression iphc tcp-connections number
An interface can perform TCP header compression for a maximum of 16 connections.
Interface view
number: Specifies the maximum number of connections for which an interface can perform TCP header compression. The value range for this argument is 3 to 256.
TCP is a connection-oriented protocol. A link can accommodate multiple TCP connections.
TCP header compression occupies memory resources for maintaining connection information. This command can limit memory resources used by compression. For example, if you set the limit to 3, TCP header compression only applies to a maximum of three TCP connections.
You can configure this command only when IPHC is enabled and packets are encapsulated in standard format. The configuration is removed after IPHC is disabled or packets are encapsulated in nonstandard format.
# Set the maximum number of connections for which Virtual-Template 1 can perform TCP header compression to 10.
[Sysname-Virtual-Template1] ppp compression iphc tcp-connections 10
ppp ipcp dns
Use ppp ipcp dns to configure the primary and secondary DNS server IP addresses to be allocated in PPP negotiation on an interface.
Use undo ppp ipcp dns to delete the primary and secondary DNS server IP addresses to be allocated in PPP negotiation on an interface.
ppp ipcp dns primary-dns-address [ secondary-dns-address ]
undo ppp ipcp dns primary-dns-address [ secondary-dns-address ]
The DNS server IP addresses to be allocated in PPP negotiation are not configured on an interface.
Interface view
primary-dns-address: Specifies a primary DNS server IP address.
secondary-dns-address: Specifies a secondary DNS server IP address.
A device can assign DNS server IP addresses to its peer during PPP negotiation when the peer initiates requests.
To check the allocated DNS server IP addresses, execute the winipcfg or ipconfig /all command on the host.
# Set the primary and secondary DNS server IP addresses to 100.1.1.1 and 100.1.1.2 for the peer on Virtual-Template 1.
[Sysname-Virtual-Template1] ppp ipcp dns 100.1.1.1 100.1.1.2
ppp ipcp dns admit-any
Use ppp ipcp dns admit-any to configure an interface to accept the DNS server IP addresses assigned by the peer even though it does not request DNS server IP addresses from the peer.
Use undo ppp ipcp dns admit-any to restore the default.
An interface does not accept the DNS server IP addresses assigned by the peer if it does not request DNS server IP addresses from the peer.
Interface view
You can configure an interface to accept the DNS server IP addresses assigned by the peer, through which domain names can be resolved for the device.
Typically, the server assigns a DNS server address to a client in PPP negotiation only when the client is configured with the ppp ipcp dns request command. Some servers, however, forcibly assign DNS server addresses to clients. You must configure the ppp ipcp dns admit-any command on the client devices to accept the DNS server addresses.
# Configure Virtual-Template 1 to accept DNS server IP addresses allocated by the peer.
[Sysname-Virtual-Template1] ppp ipcp dns admit-any
Use ppp ipcp dns request to enable an interface to actively request the DNS server IP address from its peer.
Use undo ppp ipcp dns request to restore the default.
An interface does not actively request the DNS server IP address from its peer.
Interface view
If a device is connected to a provider's access server through a PPP link, you can use this command. Then, the device can obtain the specified DNS server IP address from the access server during IPCP negotiation.
You can check the DNS server IP addresses by displaying information about the interface.
# Enable Virtual-Template 1 to actively request the DNS server IP address from its peer.
[Sysname-Virtual-Template1] ppp ipcp dns request
ppp ipcp remote-address match
Use ppp ipcp remote-address match to enable the IP segment match feature for PPP IPCP negotiation on an interface.
Use undo ppp ipcp remote-address match to restore the default.
The IP segment match feature is disabled for PPP IPCP negotiation on an interface.
Interface view
This command enables the local interface to check whether its IP address and the IP address of the remote interface are in the same network segment. If they are not, IPCP negotiation fails.
# Enable the IP segment match feature on Dialer 1.
[Sysname] interface dialer 1
[Sysname-Dialer1] ppp ipcp remote-address match
ppp ip-pool route
Use ppp ip-pool route to configure a PPP address pool route.
Use undo ppp ip-pool route to remove a PPP address pool route.
ppp ip-pool route ip-address { mask-length | mask }
undo ppp ip-pool route ip-address { mask-length | mask }
No PPP address pool route is configured.
ip-address: Specifies the destination IP address of the PPP address pool route, in dotted decimal notation.
mask-length: Specifies a mask length for the IP address, in the range of 0 to 32.
mask: Specifies a mask for the IP address, in dotted decimal notation.
The BRAS uses PPP address pool routes to control downlink traffic forwarding.
After you configure a PPP address pool route, the BRAS generates a static blackhole route destined for the specified network. All traffic matching the blackhole route is discarded. When a legal user logs in, the BRAS adds a host route destined for the specified network. In addition, the BRAS uses a dynamic routing protocol to redistribute the PPP address pool route to the upstream device.
Figure 1 Network diagram for the PPP address pool route
Make sure the destination network of the PPP address pool route includes the PPP address pool. You can execute this command multiple times to configure multiple PPP address pool routes.
# Configure the PPP address pool route as 2.2.2.2/24.
[Sysname] ppp ip-pool route 2.2.2.2 24
ppp lcp delay
Use ppp lcp delay to set the LCP negotiation delay timer.
Use undo ppp lcp delay to restore the default.
ppp lcp delay milliseconds
undo ppp lcp delay
PPP starts LCP negotiation immediately after the physical layer comes up.
Interface view
milliseconds: Specifies the LCP negotiation delay timer in the range of 1 to 10000 milliseconds.
If two ends of a PPP link vary greatly in the LCP negotiation packet processing rate, configure this command on the end with a higher processing rate. The LCP negotiation delay timer prevents frequent LCP negotiation packet retransmission. After the physical layer comes up, PPP starts LCP negotiation when the delay timer expires. If PPP receives LCP negotiation packets before the delay timer expires, it starts LCP negotiation immediately.
# Set the LCP negotiation delay timer to 130 milliseconds.
[Sysname-Virtual-Template1] ppp lcp delay 130
ppp pap local-user
Use ppp pap local-user to set the local username and password for PAP authentication on an interface.
Use undo ppp pap local-user to restore the default.
ppp pap local-user username password { cipher | simple } string
The local username and password for PAP authentication are blank on an interface.
Interface view
username: Specifies the username of the local device for PAP authentication, a case-sensitive string of 1 to 80 characters.
For the local device to pass PAP authentication on the peer, make sure the username and password configured for the local device are also configured on the peer. You can configure the peer's username and password by using the local-user username and password { cipher | simple } string commands, respectively.
# Set the local username and password for PAP authentication to user1 and plaintext pass1 on Virtual-Template 1.
[Sysname-Virtual-Template1] ppp pap local-user user1 password simple pass1
password (User Access and Authentication Command Reference)
ppp timer negotiate
Use ppp timer negotiate to set the PPP negotiation timeout time on an interface.
Use undo ppp timer negotiate to restore the default.
ppp timer negotiate seconds
The PPP negotiation timeout time is 3 seconds on an interface.
Interface view
seconds: Specifies the negotiation timeout time in the range of 1 to 10 seconds.
In PPP negotiation, if the local device receives no response from the peer during the timeout time after it sends a packet, the local device sends the last packet again.
# Set the PPP negotiation timeout time to 5 seconds on Virtual-Template 1.
[Sysname-Virtual-Template1] ppp timer negotiate 5
remote address
Use remote address to configure an interface to assign an IP address to the client.
Use undo remote address to restore the default.
remote address { ip-address | pool pool-name }
undo remote address
An interface does not assign an IP address to the client.
Interface view
ip-address: Specifies the IP address to be assigned to the client.
pool pool-name: Specifies a PPP or DHCP address pool by its name from which an IP address is assigned to the client. The pool name is a case-sensitive string of 1 to 31 characters.
This command can be used when the local interface is configured with an IP address, but the peer has no IP address. To enable the peer to accept the IP address assigned by the local interface (server), you must configure the ip address ppp-negotiate command on the peer to make the peer act as a client.
This command enables the local interface to forcibly assign an IP address to the peer. If the peer is not configured with the ip address ppp-negotiate command but configured with an IP address, the peer will not accept the assigned IP address. This results in an IPCP negotiation failure.
PPP supports IP address assignment from a PPP or DHCP address pool, but the PPP address pool takes precedence over the DHCP address pool. For example, if you use a pool name that identifies both a PPP address pool and a DHCP address pool, the system uses only the PPP address pool for address assignment.
To make the configuration of the remote address command take effect, configure this command before the ip address command, which triggers IPCP negotiation. If you configure the remote address command after the ip address command, the server assigns an IP address to the client during the next IPCP negotiation.
After you use the remote address command to assign an IP address to the client, you can configure the remote address command again or the undo remote address command for the peer. However, the new configuration does not take effect until the next IPCP negotiation.
# Specify the IP address to be assigned to the client as 10.0.0.1 on Virtual-Template 1.
[Sysname-Virtual-Template1] remote address 10.0.0.1
# Configure Virtual-Template 1 to assign an IP address from address pool aaa to the client.
[Sysname-Virtual-Template1] remote address pool aaa
ip pool
Use remote address dhcp client-identifier username to use the PPP usernames as the DHCP client IDs.
Use undo remote address dhcp client-identifier to restore the default.
The PPP usernames are not used as the DHCP client IDs.
Interface view
This command uses PPP usernames as DHCP client IDs for DHCP pool address assignment. The DHCP pool can be an AAA-authorized address pool or an address pool configured by using the remote address command.
Configure this command when different users use different PPP usernames to come online and PPP usernames are required to be used as DHCP client IDs.
# Use the PPP usernames as the DHCP client IDs on Virtual-template 1.
[Sysname-Virtual-Template1] remote address dhcp client-identifier username
Use reset ppp access-user to log off a PPP user.
reset ppp access-user { ip-address ipv4-address | ipv6-address ipv6-address | username user-name }
ip-address ipv4-address: Specifies a PPP user by its IPv4 address.
ipv6-address ipv6-address: Specifies a PPP user by its IPv6 address.
username user-name: Specifies a PPP user by username, a case-sensitive string of 1 to 80 characters.
This command takes effect only on the current login for a PPP user. The user can come online after it is logged off.
# Log off the PPP user at 192.168.100.2.
<Sysname> reset ppp access-user ip-address 192.168.100.2
Use reset ppp compression iphc to clear IPHC statistics.
reset ppp compression iphc [ rtp | tcp ] [ interface interface-type interface-number ]
rtp: Clears IPHC RTP header compression statistics.
tcp: Clears IPHC TCP header compression statistics.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify this option, the command clears IPHC statistics on all interfaces.
If neither rtp nor tcp is specified, this command clears both RTP header compression and TCP header compression statistics.
# Clear IPHC statistics on all interfaces.
<Sysname> reset ppp compression iphc
timer-hold
Use timer-hold to set the keepalive interval on an interface.
Use undo timer-hold to restore the default.
timer-hold seconds
undo timer-hold
The keepalive interval is 10 seconds on an interface.
Interface view
seconds: Specifies the interval for sending keepalive packets, in the range of 0 to 32767 seconds. The value 0 disables an interface from sending keepalive packets. In this case, the interface can respond to keepalive packets from the peer.
An interface sends keepalive packets at keepalive intervals to detect the availability of the peer. If the interface receives no response to keepalive packets when the keepalive retry limit is reached, it determines that the link fails and reports a link layer down event.
To set the keepalive retry limit, use the timer-hold retry command.
On a slow link, increase the keepalive interval to prevent false shutdown of the interface. This situation might occur when keepalive packets are delayed because a large packet is being transmitted on the link.
# Set the keepalive interval to 20 seconds on Virtual-Template 1.
[Sysname-Virtual-Template1] timer-hold 20
timer-hold retry
timer-hold retry
Use timer-hold retry to set the keepalive retry limit on an interface.
Use undo timer-hold retry to restore the default.
timer-hold retry retries
The keepalive retry limit is 5 on an interface.
Interface view
retries: Specifies the maximum number of keepalive attempts in the range of 1 to 255.
To set the keepalive interval, use the timer-hold command.
On a slow link, increase the keepalive retry limit to prevent false shutdown of the interface. This situation might occur when keepalive packets are delayed because a large packet is being transmitted on the link.
# Set the keepalive retry limit to 10 for Virtual-Template 1.
[Sysname-Virtual-Template1] timer-hold retry 10
timer-hold
PPPoE commands
PPPoE server commands
The following compatibility matrix shows the support of hardware platforms for PPPoE server:
Hardware series |
Model |
Product code |
PPPoE server compatibility |
WX1800H series |
WX1804H-PWR |
Yes |
WX2500H series |
Yes |
MAK series |
MAK204 MAK206 |
Yes |
WX3000H series |
WX3500H series |
Yes |
WX5500E series |
WX5510E WX5540E |
Yes |
WX5500H series |
Yes |
Yes |
Hardware series |
Model |
Product code |
WX1800H series |
Yes |
WX3800H series |
WX3820H WX3840H |
Yes |
WX5800H series |
WX5860H |
EWP-WX5860H-GL |
Yes |
Use display pppoe-server session packet to display packet statistics for PPPoE sessions.
In standalone mode:
display pppoe-server session packet [ interface interface-type interface-number ]
In IRF mode:
display pppoe-server session packet { slot slot-number | interface interface-type interface-number }
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, the command displays information about blocked users on all interfaces.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, the command displays packet statistics for PPPoE sessions on all member devices. (In IRF mode.)
# (In standalone mode.) Display packet statistics for PPPoE sessions on VLAN-interface 1.
<Sysname> display pppoe-server session packet interface vlan-interface 1
Total PPPoE sessions: 2
Ethernet interface: Vlan1 Session ID: 1
InPackets: 37 OutPackets: 38
InBytes: 390 OutBytes: 406
InDrops: 0 OutDrops: 0
Ethernet interface: Vlan1 Session ID: 2
InPackets: 39 OutPackets: 40
InBytes: 340 OutBytes: 496
InDrops: 1 OutDrops: 2
# (In IRF mode.) Display packet statistics for PPPoE sessions on VLAN-interface 1.
Total PPPoE sessions on slot 3: 1
InPackets: 40 OutPackets: 58
InBytes: 690 OutBytes: 506
InDrops: 3 OutDrops: 1
Total PPPoE sessions on slot 4: 2
InPackets: 43 OutPackets: 59
InBytes: 790 OutBytes: 576
InDrops: 2 OutDrops: 1
InPackets: 35 OutPackets: 36
InBytes: 370 OutBytes: 386
Table 6 Command output
Ethernet interface |
Interface where the PPPoE session is present. |
Session ID |
PPPoE session ID. |
InPackets |
Number of packets received. |
OutPackets |
Number of packets transmitted. |
InBytes |
Number of bytes received. |
OutBytes |
Number of bytes transmitted. |
InDrops |
Number of discarded incoming packets. |
OutDrops |
Number of discarded outgoing packets. |
display interface virtual-access
Use display pppoe-server session summary to display summary PPPoE session information.
In standalone mode:
display pppoe-server session summary [ interface interface-type interface-number ]
In IRF mode:
display pppoe-server session summary { slot slot-number | interface interface-type interface-number }
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, the command displays summary PPPoE session information for all member devices. (In IRF mode.)
Summary PPPoE session information on a physical interface can be displayed only on the card where the interface resides. Summary PPPoE session information on a logical interface can be displayed on all cards.
# (In standalone mode.) Display summary PPPoE session information on VLAN-interface 1.
<Sysname> display pppoe-server session summary interface vlan-interface 1
PPP interface: VA1 State: PADR_RCVD
Remote MAC: 00e0-1500-7100 Local MAC: 00e0-1400-7300
Service VLAN: N/A Customer VLAN: N/A
PPP interface: VA2 State: OPEN
Remote MAC: 00e0-1500-7100 Local MAC: 00e014007400
Service VLAN: 2 Customer VLAN: 1
# (In IRF mode.) Display summary PPPoE session information on VLAN-interface 1.
Total PPPoE sessions on slot 1: 1
Total PPPoE sessions on slot 2: 2
Remote MAC: 00e0-1500-7100 Local MAC: 00e0-1400-7400
Table 7 Command output
Total PPPoE sessions |
Total number of PPPoE sessions on physical interfaces and logical interfaces. |
Local PPPoE sessions |
Total number of PPPoE sessions on physical interfaces. When an interface is specified, this field is not displayed. |
Session ID |
PPPoE session ID. |
PPP interface |
Virtual access interface created for the PPPoE session. |
State |
PPPoE session state: · PADR RCVD—The PPPoE session is being negotiated. · Open—The PPPoE session has been successfully established. |
RemoteMAC |
MAC address of the remote end. |
LocalMAC |
MAC address of the local end. |
Service VLAN |
Service provider VLAN. N/A means no service provider VLAN is available. |
Customer VLAN |
Customer VLAN. N/A means no customer VLAN is available. |
Use display pppoe-server throttled-mac to display information about blocked users.
In standalone mode:
display pppoe-server throttled-mac [ interface interface-type interface-number ]
In IRF mode:
display pppoe-server throttled-mac { slot slot-number | interface interface-type interface-number }
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, the command displays information about blocked users on all member devices. (In IRF mode.)
# (In standalone mode.) Display information about blocked users on VLAN-interface 1.
<Sysname> display pppoe-server throttled-mac interface vlan-interface 1
Total 3 client MACs:
Interface Remote MAC Start time Remaining time(s)
Vlan1 00e0-1500-4100 2010-12-01,12:10:30 55
Vlan1 00e0-1500-4000 2010-12-01,12:10:40 65
Vlan1 00e0-1500-3300 2010-12-01,12:10:50 75
# (In IRF mode.) Display information about blocked users on VLAN-interface 1.
Total 1 client MACs in slot 1:
Total 2 client MACs in slot 2:
Vlan1 00e0-1500-6300 2010-12-01,12:10:30 55
Vlan1 00e0-1500-6000 2010-12-01,12:10:40 65
Vlan1 00e0-1500-6300 2010-12-01,12:10:50 75
Table 8 Command output
Interface at which the user is blocked. |
Remote MAC |
MAC address of the user. |
Start time |
Time to start blocking users. |
Remaining time(s) |
Time left for blocking users, in seconds. |
pppoe-server throttle per-mac
display pppoe-server va-pool
Use display pppoe-server va-pool to display information about VA pools.
# (In standalone mode.) Display information about VA pools.
<Sysname> display pppoe-server va-pool
VT interface Size Unused/State
Virtual-Template1 1000 900
Virtual-Template2 1000 Creating
# (In IRF mode.) Display information about VA pools.
Location VT interface Size Unused/State
0/cpu1 Virtual-Template2 1000 1000
Table 9 Command output
Location |
IRF member device, card, and CPU where the VA pool resides. When the field displays a hyphen (-), it indicates a global VA pool. If the device cannot display the CPU, an asterisks (*) is displayed, for example, 1/0/*. |
VT interface |
Virtual-Template interface that uses the VA pool. |
Unused/State |
VA pool capacity available for PPP users/current state of the VA pool. · Creating—The VA pool is being created. · Destroying—The VA pool is being removed. |
ppp lcp echo mru verify
Use ppp lcp echo mru verify to enable maximum receive unit (MRU) verification for PPPoE on a VT interface.
Use undo ppp lcp echo mru verify to disable MRU verification for PPPoE.
ppp lcp echo mru verify [minimum value ]
MRU verification for PPPoE is disabled on a VT interface.
VT interface view
minimum value: Specifies the minimum MRU in the range of 64 to 1500 bytes.
To support an MTU larger than 1492, PPPoE adds the PPP-Max-Payload option during PPPoE negotiation. This option identifies the MTU for the current PPPoE session. If the MTU is larger than 1492, PPP uses the MTU as the MRU during LCP negotiation, and reports the MTU after negotiation.
MRU verification prevents the negotiated MRU from exceeding the receiving and sending capabilities of the interface. If the negotiated MRU is larger than 1492, the PPPoE server sends an echo request that has the same size as the negotiated MRU. If the PPPoE server receives a reply, it uses the MRU as the MTU. If the PPPoE server fails to receive a reply, the following situations occur:
· If the minimum MRU is configured, the PPPoE server sends a packet that has the same size as the minimum MRU.
· If the minimum MRU is not configured, the PPPoE server sends a packet that has the same size as the negotiated MRU.
If the second verification still fails, the PPPoE server tears down the link.
NCP negotiation starts after the MRU verification succeeds.
# Enable MRU verification for PPPoE and set the minimum MRU to 1200 bytes on Virtual-Template 10.
[Sysname] interface virtual-template 10
[Sysname-Virtual-Template10] ppp lcp echo mru verify minimum 1200
pppoe-server access-delay
Use pppoe-server access-delay to set the response delay time on an interface.
Use undo pppoe-server access-delay to restore the default.
pppoe-server access-delay delay-time
No response delay time is set on an interface.
Layer 3 Ethernet interface/subinterface view
VLAN interface view
delay-time: Specifies the response delay time, in the range of 10 to 25500 milliseconds.
The system responds to the first packet of a PPP connection on the interface after the configured delay time elapses.
# Set the response delay time to 100 milliseconds on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] pppoe-server access-delay 100
Use pppoe-server access-line-id bas-info to configure the NAS-Port-ID attribute to automatically include BAS information on an interface.
Use undo pppoe-server access-line-id bas-info to restore the default.
pppoe-server access-line-id bas-info [ cn-163 ]
The NAS-Port-ID attribute does not automatically include BAS information on an interface.
VLAN interface view
cn-163: Specifies the China Telecom 163 format for the BAS information. If you do not specify this keyword, BAS information in the China Telecom format is included.
he bas-info formats include China Telecom and China Telecom 163.
The China Telecom format is { eth|trunk} NAS_slot/NAS_subslot/NAS_port:XPI.XCI. The format refers to the user access interface information on the BAS device, including upstream interface, VLAN, and VPI/VCI information. When Ethernet/DSL is used, XPI.XCI refers to VLAN information.
For example, eth 1/0/1:4096.2345 includes the following user access interface information:
· The type of the upstream interface is Ethernet interface.
· The interface is located at slot 1, subslot 0, and port 1.
· The outer VLAN ID is 4096 (which means an invalid VLAN), and the inner VLAN ID is 2345.
Table 10 shows the China Telecom 163 format, where:
· NAS_slot, NAS_subslot, and NAS_port refer to the numbering information of the PPPoE user access interface on the BAS device.
· vpi and vci refer to VPI and VCI information.
· vlanid and vlanid2 refer to inner VLAN and outer VLAN, respectively. The value for the vlanid of the primary interface is fixed at 0.
Table 10 BAS information in China Telecom 163 format
Interface type |
Format |
Primary interface or interface that does not carry inner VLAN or outer VLAN information. |
slot=NAS_slot;subslot=NAS_subslot;port=NAS_port;vlanid=VLAN id; |
Interface that carries inner VLAN and outer VLAN information. |
slot=NAS_slot;subslot=NAS_subslot;port=NAS_port;vlanid=VLAN id;vlanid2=VLAN id2; |
This command determines the content of the NAS-Port-ID attribute that the PPPoE server delivers to the RADIUS server.
· If the cn-163 keyword is specified, the PPPoE server automatically inserts the corresponding BAS information before the parsed circuit-id. Then it sends the combination of the bas-info and circuit-id as the NAS-Port-ID attribute to the RADIUS server.
· If the cn-163 keyword is not specified, the PPPoE server creates a new circuit-id in China Telecom format. Then it sends the new circuit-id as the NAS-Port-ID attribute to the RADIUS server. The new circuit-id contains the corresponding BAS information and the DSLAM user access information in the original circuit-id.
If this command is not executed, the NAS-Port-ID attribute that the PPPoE server delivers to the RADIUS server is determined by the pppoe-server access-line-id content command.
The RADIUS server cannot correctly parse a NAS-Port-ID attribute that includes the remote-id and BAS information. When you configure this command together with the pppoe-server access-line-id trust command, make sure the NAS-Port-ID attribute sent to the RADIUS sever does not include the remote-id.
# Configure the NAS-Port-ID attribute to automatically include BAS information on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] pppoe-server access-line-id bas-info
Use pppoe-server access-line-id circuit-id parse-mode to configure the format that an interface uses to parse the circuit-id in the access line ID.
Use undo pppoe-server access-line-id circuit-id parse-mode to restore the default.
pppoe-server access-line-id circuit-id parse-mode { cn-telecom | tr-101 }
An interface uses the TR-101 format to parse the circuit-id.
VLAN interface view
cn-telecom: Specifies China Telecom format.
tr-101: Specifies TR-101 format.
The circuit-id formats include TR-101 and China Telecom.
The TR-101 format is Access-Node-Identifier eth slot/port[:vlan-id] for Ethernet/DSL. The entire ID refers to the user access information on the DSLAM, where
· Access-Node-Identifier refers to the identifier of the DSLAM.
· The remainder refers to information about the user access interface on the DSLAM.
The China Telecom format is AccessNodeIdentifier/ANI_rack/ANI_frame/ANI_slot/ANI_subslot/ANI_port[:ANI_XPI.ANI_XCI]. The format refers to user access information on the DSLAM, including DSLAM identifier and user access interface.
For example, the circuit-id guangzhou001/1/31/63/31/127 includes the following information:
· The identifier of the access node DSLAM is guangzhou001.
· The rack number of the DSLAM is 1.
· The user access interface is located at port 127, subslot 31, slot 63, and frame 31.
# Configure GigabitEthernet 1/0/1 to use China Telecom format to parse the circuit-id.
[Sysname-GigabitEthernet1/0/1] pppoe-server access-line-id circuit-id parse-mode cn-telecom
Use pppoe-server access-line-id circuit-id trans-format to configure the transmission format for the circuit-id in access line ID on an interface.
Use undo pppoe-server access-line-id circuit-id trans-format to restore the default.
pppoe-server access-line-id circuit-id trans-format { ascii | hex }
The transmission format for the circuit-id in access line ID is a string of characters on an interface.
VLAN interface view
ascii: Specifies the character string format. For example, the circuit-id 00010002 is transmitted in the form of 01 08 30 30 30 31 30 30 30 32.
hex: Specifies the hexadecimal format. For example, the circuit-id 00010002 is transmitted in the form of 01 04 00 01 00 02.
# Configure GigabitEthernet 1/0/1 to use the hexadecimal format to transmit the circuit-id.
[Sysname-GigabitEthernet1/0/1] pppoe-server access-line-id circuit-id trans-format hex
Use pppoe-server access-line-id content to configure the content of the NAS-Port-ID attribute delivered to the RADIUS server on an interface.
Use undo pppoe-server access-line-id content to restore the default.
pppoe-server access-line-id content { all [ separator ] | circuit-id | remote-id }
The NAS-Port-ID attribute contains only the circuit-id on an interface.
VLAN interface view
all: Sends both the circuit-id and remote-id.
separator: Specifies a separator that is one character long. By default, the value is a blank space. The circuit-id and remote-id are connected by the separator.
circuit-id: Sends only the circuit-id.
remote-id: Sends only the remote-id.
The PPPoE server on a BAS device uses the RADIUS NAS-Port-ID attribute to send the access line ID received from a DSLAM device to the RADIUS server. The access line ID contains the circuit-id and remote-id. The RADIUS server compares the received NAS-Port-ID attribute with the local line ID information to verify the location of the user.
For more information about the circuit-id, see the pppoe-server access-line-id circuit-id parse-mode command.
For more information about the remote-id, see pppoe-server access-line-id remote-id trans-format the command.
Do not use a character that exists in the circuit-id or remote-id as the separator. Otherwise, the RADIUS server might fail to parse the ID information.
This command determines the content of the NAS-Port-ID attribute only when the pppoe-server access-line-id bas-info command is not configured. Otherwise, the pppoe-server access-line-id bas-info command determines the content of the NAS-Port-ID attribute.
# Configure GigabitEthernet 1/0/1 to deliver only the circuit-id to the RADIUS server.
[Sysname-GigabitEthernet1/0/1] pppoe-server access-line-id content circuit-id
Use pppoe-server access-line-id remote-id trans-format to configure the transmission format for the remote-id in the access line ID on an interface.
Use undo pppoe-server access-line-id remote-id trans-format to restore the default.
pppoe-server access-line-id remote-id trans-format { ascii | hex }
The transmission format for the remote-id is a string of characters on an interface.
VLAN interface view
The remote-id is the system MAC address of a PPPoE relay device (for example, DSLAM). It can be transmitted in character strings or hexadecimal format.
# Configure GigabitEthernet 1/0/1 to use the hexadecimal format to transmit the remote-id.
[Sysname-GigabitEthernet1/0/1] pppoe-server access-line-id remote-id trans-format hex
Use pppoe-server access-line-id trust to configure the PPPoE server to trust the access line ID in received packets on an interface.
Use undo pppoe-server access-line-id trust to restore the default.
The PPPoE server does not trust the access line ID in received packets on an interface.
VLAN interface view
This command enables the PPPoE server to parse the circuit-id and remote-id in a received packet, and creates a new circuit-id and remote-id. If the PPPoE server fails to parse the circuit-id or remote-id in a PADR packet, it discards the packet and does not return a PADS packet.
If this command is not executed, the PPPoE server does not parse the circuit-id and remote-id in a received packet. The contents of both the new circuit-id and the remote-id are null.
# Configure GigabitEthernet 1/0/1 to trust the access line ID in received packets.
[Sysname-GigabitEthernet1/0/1] pppoe-server access-line-id trust
pppoe-server bind
Use pppoe-server bind to enable the PPPoE server on an interface and bind the interface to a VT interface.
Use undo pppoe-server bind to disable the PPPoE server on an interface.
pppoe-server bind virtual-template number
The PPPoE server is disabled on an interface.
VLAN interface view
virtual template number: Specifies a VT interface by its number. The value range for the number argument is 0 to 1023.
A PPPoE server-enabled interface can be bound to a nonexistent VT interface.
If the interface has been bound to a VT interface, you cannot use this command to bind the interface to another VT interface. To do that, disable the PPPoE server on the interface first.
If both the PPPoE client and PPPoE server are enabled on an interface, the PPPoE client feature does not take effect.
# Enable the PPPoE server on GigabitEthernet 1/0/1 and bind the interface to Virtual-Template 1.
[Sysname-GigabitEthernet1/0/1] pppoe-server bind virtual-template 1
pppoe-server session-limit
Use pppoe-server session-limit to set the maximum number of PPPoE sessions on an interface.
Use undo pppoe-server session-limit to restore the default.
pppoe-server session-limit number
The number of PPPoE sessions on an interface is not limited.
VLAN interface view
number: Specifies the maximum number of PPPoE sessions on an interface, in the range of 1 to 65534.
PPPoE can establish a session when none of the following limits are reached:
· Limit for a user on an interface.
· Limit for a VLAN on an interface.
· Limit on an interface.
· Limit on an IRF member device. (In IRF mode.)
· Limit on a device.
New maximum number settings only apply to subsequently established PPPoE sessions.
# Set the maximum number of PPPoE sessions on GigabitEthernet 1/0/1 to 50.
[Sysname-GigabitEthernet1/0/1] pppoe-server session-limit 50
pppoe-server session-limit per-mac
pppoe-server session-limit per-vlan
pppoe-server session-limit total
Use pppoe-server session-limit per-mac to set the maximum number of PPPoE sessions for a user on an interface.
Use undo pppoe-server session-limit per-mac to restore the default.
pppoe-server session-limit per-mac number
A user can create a maximum of 100 PPPoE sessions on an interface.
VLAN interface view
number: Specifies the maximum number of PPPoE sessions for a user, in the range of 1 to 65534.
A user is identified by a MAC address.
# Set the maximum number of PPPoE sessions for a user on GigabitEthernet 1/0/1 to 50.
[Sysname-GigabitEthernet1/0/1] pppoe-server session-limit per-mac 50
Use pppoe-server session-limit per-vlan to set the maximum number of PPPoE sessions for a VLAN on an interface.
Use undo pppoe-server session-limit per-vlan to restore the default.
pppoe-server session-limit per-vlan number
The number of PPPoE sessions for a VLAN on an interface is not limited.
number: Specifies the maximum number of PPPoE sessions for a VLAN, in the range of 1 to 65534.
# Set the maximum number of PPPoE sessions for a VLAN on GigabitEthernet 1/0/1.1 to 50.
[Sysname] interface gigabitethernet 1/0/1.1
[Sysname-GigabitEthernet1/0/1.1] pppoe-server session-limit per-vlan 50
pppoe-server sessions limit
pppoe-server sessions limit per-mac
pppoe-server sessions limit total
Use pppoe-server session-limit total to set the maximum number of PPPoE sessions on a device.
Use undo pppoe-server session-limit total to restore the default.
In standalone mode:
pppoe-server session-limit total number
In IRF mode:
pppoe-server session-limit slot slot-number total number
undo pppoe-server session-limit slot slot-number total
The number of PPPoE sessions on a device is not limited. (In standalone mode.)
The number of PPPoE sessions on an IRF member device is not limited. (In IRF mode.)
number: Specifies the maximum number of PPPoE sessions on a device, in the range of 1 to 65534.
slot slot-number: Specifies an IRF member device by its member ID. (In IRF mode.)
The maximum number of PPPoE sessions on a device or on a card is also limited by the device specification. If the configured number is larger than the device specification, the device specification applies.
# (In standalone mode.) Set the maximum number of PPPoE sessions on a device to 3000.
[Sysname] pppoe-server session-limit total 3000
# (In IRF mode.) Set the maximum number of PPPoE sessions for slot 2 to 3000.
[Sysname] pppoe-server session-limit slot 2 total 3000
pppoe-server tag ac-name
Use pppoe-server tag ac-name to set the access concentrator (AC) name for the PPPoE server on an interface.
Use undo pppoe-server tag ac-name to restore the default.
pppoe-server tag ac-name name
The AC name for the PPPoE server is the device name on an interface.
VLAN interface view
name: Specifies an AC name, a case-sensitive string of 1 to 64 characters.
The PPPoE server sends its AC name in PADO packets. PPPoE clients choose a PPPoE server by AC name. The PPPoE clients on H3C devices cannot identify PPPoE servers by AC name.
The device does not support an AC name comprised of all blank spaces.
# Specify the AC name for the PPPoE server on GigabitEthernet 1/0/1 as pppoes.
[Sysname-GigabitEthernet1/0/1] pppoe-server tag ac-name pppoes
pppoe-server tag ppp-max-payload
Use pppoe-server tag ppp-max-payload to enable the PPPoE server to support the ppp-max-payload tag and set a range for the tag on an interface.
Use undo pppoe-server tag ppp-max-payload to restore the default.
pppoe-server tag ppp-max-payload [ minimum min-number maximum max-number ]
The PPPoE server does not support ppp-max-payload tag on an interface. The PPPoE server ignores the ppp-max-payload tag in PADI or PADS packets from clients, and returns a PADO or PADS packets without the ppp-max-payload tag.
VLAN interface view
minimum min-number: Specifies the minimum value for the PPP maximum payload, in the range of 64 to 4470 bytes. The default value is 1492 bytes.
maximum max-number: Specifies the maximum value for the PPP maximum payload, in the range of 64 to 4470 bytes. The default value is 1500 bytes. The max-number argument must be equal or greater than the min-number argument.
This command enables the PPPoE server to forward large PPP packets with a payload larger than 1492 bytes and reduces fragmentation. If the ppp-max-payload tag sent by the PPPoE client is within the tag range, the PPPoE server returns a PADO or PADS packet that includes the tag. If not, the PPPoE server considers the received packets invalid, and it does not return a PADO or PADS packet.
The jumboframe enable command can change the size of jumbo frames supported by the interface. The maximum size of the jumbo frames configured by the jumboframe enable command should be larger than the maximum value configured by the pppoe-server tag ppp-max-payload command.
# Enable the PPPoE server to support the ppp-max-payload tag and set the value for the PPP maximum payload to be in the range of 1494 to 1580 bytes on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] pppoe-server tag ppp-max-payload minimum 1494 maximum 1508
jumboframe enable (Interface Command References)
pppoe-server tag service-name
Use pppoe-server tag service-name to set a service name for a PPPoE server on an interface.
Use undo pppoe-server tag service-name to restore the default.
pppoe-server tag service-name name
A PPPoE server does not have a service name.
VLAN interface view
name: Specifies a service name, a case-sensitive string of 1 to 64 characters.
Service names identify the traffic destined for PPPoE servers when multiple PPPoE servers are providing services on the network. A PPPoE client establishes a session with the target PPPoE server by using the following process:
1. The client broadcasts a PADI packet.
2. The server compares its service name with the service-name tag field of the PADI packet. The server sends a PADO packet to the client if either of the following conditions exists:
¡ The field matches the service name.
¡ No service name is configured.
3. The client sends a PADR packet to the server.
4. The server compares its service name with the service-name tag field of the PADR packet. The server sends a PADS packet and sets up a session with the client if either of the following conditions exists:
# Set the service name to pppoes for the PPPoE server on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] pppoe-server tag service-name pppoes
Use pppoe-server throttle per-mac to set the PPPoE access limit on an interface.
Use undo pppoe-server throttle per-mac to restore the default.
pppoe-server throttle per-mac session-requests session-request-period blocking-period
The PPPoE access rate is not limited on an interface.
VLAN interface view
session-requests: Specifies the maximum number of PPPoE session requests from a user within the monitoring time. The value range is 1 to 100000.
session-request-period: Specifies the monitoring time in the range of 1 to 3600 seconds.
blocking-period: Specifies the blocking time in the range of 1 to 3600 seconds.
This command limits the rate at which a user (identified by MAC address) can create PPPoE sessions on an interface. If the number of PPPoE requests within the monitoring time exceeds the configured threshold, the device discards the excessive requests, and outputs log messages. If the blocking time is set to 0, the device does not block any requests, and it only outputs log messages.
The device uses a monitoring table and a blocking table to control PPP access rates.
· Monitoring table—Stores a maximum of 8000 monitoring entries. Each entry records the number of PPPoE sessions created by a user within the monitoring time. When the monitoring entries reach the maximum, the system stops monitoring and blocking session requests from new users. The aging time of monitoring entries is determined by the session-request-period argument. When the timer expires, the system starts a new round of monitoring for the user.
· Blocking table—Stores a maximum of 8000 blocking entries. The system creates a blocking entry if the access rate of a user reaches the threshold, and blocks requests from that user. When the blocking entries reach the maximum, the system stops blocking session requests from new users and it only outputs log messages. The aging time of the blocking entries is determined by the blocking-period argument. When the timer expires, the system starts a new round of monitoring for the user.
If the access rate setting is changed, the system removes all monitoring and blocking entries, and uses the new settings to limit PPPoE access rates.
# Limit the rate at which a user can create PPPoE sessions on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] pppoe-server throttle per-mac 100 100 5
pppoe-server virtual-template va-pool
Use pppoe-server virtual-template va-pool to configure a VA pool.
Use undo pppoe-server virtual-template va-pool to remove a VA pool.
In standalone mode:
pppoe-server virtual-template template-number va-pool va-volume
undo pppoe-server virtual-template template-number va-pool
In IRF mode:
pppoe-server virtual-template template-number [ slot slot-number ] va-pool va-volume
undo pppoe-server virtual-template template-number [ slot slot-number ] va-pool
No VA pool is configured.
virtual-template template-number: Specifies an existing VT interface to use the VA pool.
va-pool va-volume: Specifies the maximum number of VA interfaces contained in the VA pool, in the range of 1 to 65534.
slot slot-number: Specifies an IRF member device by its IRF member ID. If you do not specify a member device, a global VA pool is created. (In IRF mode.)
The PPPoE server creates a VA interface for a PPPoE session to transmit packets between PPPoE and PPP, and removes the VA interface when the user goes offline. Creating and removing VA interfaces take time.
You can configure VA pools to improve the performance of PPPoE session establishment and termination. A VA pool contains a group of automatically numbered VA interfaces. The PPPoE server selects a VA interface from the pool for a requesting user and release the VA interface when the user goes offline. When a VA pool is exhausted, the system creates VA interfaces for new PPPoE sessions, and removes those VA interfaces when the users go offline.
On a VT interface, you can create one global VA pool and one regional VA pool per member device for interfaces bound with the VT interface.
· The global VA pool contains VA interfaces for logical interfaces that might span multiple devices, such as Ethernet aggregate interfaces.
· The regional VA pool contains VA interfaces for interfaces that do not span multiple devices, such as Ethernet interfaces.
When you configure a VA pool, follow these guidelines:
· To change the capacity of a VA pool, you must delete the previous configuration, and reconfigure the VA pool.
· Creating or removing a VA pool takes time. During the process of creating or removing a VA pool, users can go online or offline, but the VA pool does not take effect.
· If the system fails to create a VA pool because of insufficient resources, you can view the available resources by using the display pppoe-server va-pool command.
· VA pools are memory intensive. Set their capacity depending on your network requirements.
· Deleting a VA pool does not log off the users who are using VA interfaces in the VA pool.
# Create a VA pool with a capacity of 1000 VA interfaces on Virtual-Template 2.
[Sysname] pppoe-server virtual-template 2 va-pool 1000
reset pppoe-server
Use reset pppoe-server to clear PPPoE sessions on the PPPoE server.
reset pppoe-server { all | interface interface-type interface-number | virtual-template number }
all: Clears all PPPoE sessions.
virtual-template number: Specifies a VT interface by its number.
# Clear established sessions on Virtual-template 1 on the PPPoE server.
<Sysname> reset pppoe-server virtual-template 1
PPPoE client commands
The following compatibility matrix shows the support of hardware platforms for PPPoE client:
Hardware series |
Model |
Product code |
PPPoE client compatibility |
WX1800H series |
WX1804H-PWR |
EWP-WX1804H-PWR-CN |
Yes |
WX2500H series |
WX2508H-PWR-LTE WX2510H-PWR WX2510H-F-PWR WX2540H WX2540H-F WX2560H |
EWP-WX2508H-PWR-LTE EWP-WX2510H-PWR EWP-WX2510H-F-PWR EWP-WX2540H EWP-WX2540H-F EWP-WX2560H |
Yes |
MAK series |
MAK204 MAK206 |
EWP-MAK204 EWP-MAK206 |
Yes |
WX3000H series |
WX3010H WX3010H-X-PWR WX3010H-L-PWR WX3024H WX3024H-L-PWR WX3024H-F |
EWP-WX3010H EWP-WX3010H-X-PWR EWP-WX3010H-L-PWR EWP-WX3024H EWP-WX3024H-L-PWR EWP-WX3024H-F |
Yes: · WX3010H · WX3010H-X-PWR · WX3024H · WX3024H-F No: · WX3010H-L-PWR · WX3024H-L-PWR |
WX3500H series |
WX3508H WX3508H WX3510H WX3510H WX3520H WX3520H-F WX3540H WX3540H |
EWP-WX3508H EWP-WX3508H-F EWP-WX3510H EWP-WX3510H-F EWP-WX3520H EWP-WX3520H-F EWP-WX3540H EWP-WX3540H-F |
No |
WX5500E series |
WX5510E WX5540E |
EWP-WX5510E EWP-WX5540E |
No |
WX5500H series |
WX5540H WX5560H WX5580H |
EWP-WX5540H EWP-WX5560H EWP-WX5580H |
No |
Access controller modules |
LSUM1WCME0 EWPXM1WCME0 LSQM1WCMX20 LSUM1WCMX20RT LSQM1WCMX40 LSUM1WCMX40RT EWPXM2WCMD0F EWPXM1MAC0F |
No |
Hardware series |
Model |
Product code |
WX1800H series |
WX1804H-PWR WX1810H-PWR WX1820H WX1840H |
EWP-WX1804H-PWR EWP-WX1810H-PWR EWP-WX1820H EWP-WX1840H-GL |
Yes |
WX3800H series |
WX3820H WX3840H |
EWP-WX3820H-GL EWP-WX3840H-GL |
No |
WX5800H series |
WX5860H |
EWP-WX5860H-GL |
No |
dialer bundle enable
Use dialer bundle enable to enable bundle DDR on a dialer interface.
Use undo dialer bundle enable to disable bundle DDR on a dialer interface.
Bundle DDR is disabled on a dialer interface.
Dialer interface view
DDR includes traditional DDR and bundle DDR.
Before using bundle DDR, use this command to enable bundle DDR on a dialer interface. Then assign physical interfaces to the corresponding dialer bundle by using the dialer bundle-member command. To enable bundle DDR to receive calls, configure the dialer peer-name command on the dialer interface.
After you configure this command on a dialer interface already enabled with traditional DDR, the system clears the original traditional DDR settings.
The undo dialer bundle enable command clears all bundle DDR settings on the dialer interface.
# Enable bundle DDR on Dialer 1.
[Sysname-Dialer1] dialer bundle enable
dialer diagnose
Use dialer diagnose to configure DDR to operate in diagnostic mode.
Use undo dialer diagnose to restore the default.
dialer diagnose [ interval interval ]
DDR operates in non-diagnostic mode.
interval: Specifies the diagnostic interval in the range of 5 to 65535 seconds. The default is 120 seconds.
This command takes effect only when a dialer interface is used with PPPoE client applications.
In diagnostic mode, the device performs the following operations:
· Dials a PPPoE connection immediately after the device configurations are complete.
· Automatically terminates the connection.
· Starts the auto-dial timer after a configurable diagnostic interval.
· Redials a connection when the auto-dial timer expires.
By establishing and terminating PPPoE sessions periodically, you can monitor the operating status of the PPPoE link.
In diagnostic mode, the link idle-timeout timer is ignored.
# Configure Dialer 1 to operate in diagnostic mode, with a diagnostic interval of 300 seconds.
[Sysname-Dialer1] dialer diagnose interval 300
dialer timer autodial
dialer timer idle
Use dialer timer autodial to set the auto-dial timer.
Use undo dialer timer autodial to restore the default.
dialer timer autodial autodial-interval
The auto-dial timer is 300 seconds.
Dialup interface view
autodial-interval: Specifies the interval between auto-dial attempts, in the range of 1 to 604800 seconds.
This command takes effect only when the autodial keyword is specified in the dialer number or dialer route command. DDR automatically dials the dial string at the specified interval until a connection is established. In the auto-dial method, dial attempts are not traffic triggered. Once a connection is established, it will not disconnect based on the idle timer mechanism.
# Set the auto-dial timer to 60 seconds on Dialer 1.
[Sysname-Dialer1] dialer timer autodial 60
dialer timer idle
Use dialer timer idle to set the link idle-timeout timer.
Use undo dialer timer idle to restore the default.
dialer timer idle idle [ in | in-out ]
The link idle-timeout timer is 120 seconds, and only outgoing interesting packets reset this timer.
idle: Specifies the link idle-timeout timer value in the range of 0 to 65535 seconds.
in: Allows only incoming interesting packets to reset the timer.
in-out: Allows both incoming and outgoing interesting packets to reset the timer.
The link idle-timeout timer starts when a link is established. If no interesting packets arrive before the timer expires, DDR disconnects the link.
If you do not specify the in or in-out keyword, only outgoing interesting packets reset the timer.
If the timer is set to 0, DDR will never disconnect the link. For a PPPoE client application, if the timer is set to 0, a dialup connection is created automatically and remains active permanently.
# Set the link idle-timeout timer to 50 seconds on Dialer 1.
[Sysname-Dialer1] dialer timer idle 50
dialer-group
Use dialer-group to assign a dialup interface to a dialer group.
Use undo dialer-group to restore the default.
dialer-group group-number
undo dialer-group
A dialup interface does not belong to any dialer group.
group-number: Specifies a dialer group by its number in the range of 1 to 255. Before the assignment, you must create the dialer group by using the dialer-group rule command.
A dialup interface can belong to only one dialer group. If you configure this command multiple times, the most recent configuration takes effect.
You must configure this command for DDR to send packets.
# Assign Dialer 1 to dialer group 1.
[Sysname] dialer-group 1 rule acl 3101
[Sysname-Dialer1] dialer-group 1
dialer-group rule
dialer-group rule
Use dialer-group rule to create a dialer group and configure a dial rule for it.
Use undo dialer-group rule to delete a dialer group.
dialer-group group-number rule { ip | ipv6 } { deny | permit | acl { acl-number | name acl-name } }
undo dialer-group group-number rule [ ip | ipv6 ]
No dialer group exists.
group-number: Specifies the number of the dialer group to be created, in the range of 1 to 255.
ip: Specifies the IPv4 protocol.
ipv6: Specifies the IPv6 protocol.
deny: Denies packets of the specified protocol.
permit: Permits packets of the specified protocol.
acl acl-number: Specifies an ACL by its number in the range of 2000 to 3999.
name acl-name: Specifies an ACL by its name.
A dial rule determines when an interface initiates DDR calls. You need to configure dial rules only on the initiator of DDR calls.
You can configure a dial rule to match only IP packets or use an ACL to match packets.
Permitted protocol packets or packets that match a permit statement of an ACL are interesting packets. When receiving an interesting packet, DDR performs one of the following operations:
· Sends it out and resets the idle-timeout timer if a link is present.
· Originates a new call to establish a link if no link is present.
Denied protocol packets or packets that match a deny statement of an ACL are uninteresting packets. When receiving an uninteresting packet, DDR performs one of the following operations:
· Sends it out without resetting the idle-timeout timer if a link is present.
· Drops it if no link is present.
For DDR to forward packets correctly, you must configure a dial rule and associate it with the dialup interface by using the dialer-group command.
# Create dialer group 1 and configure DDR to place calls for IPv4 packets. Associate Dialer 1 with dialer group 1.
[Sysname] dialer-group 1 rule ip permit
[Sysname-Dialer] dialer-group 1
# Create dialer group 1 and configure DDR to place calls for IPv6 packets. Associate Dialer 1 with dialer group 1.
[Sysname] dialer-group 1 rule ipv6 permit
display pppoe-client session packet
Use display pppoe-client session packet to display the protocol packet statistics for a PPPoE session.
display pppoe-client session packet [ dial-bundle-number number ]
dial-bundle-number number: Specifies the dialer bundle number corresponding to a PPPoE session. The value range for the number argument is 0 to 1023. If you do not specify this option, the command displays the protocol packet statistics for all PPPoE sessions.
To display the data packet statistics for a PPPoE session, use the display interface virtual-access command to display information about the specified VA interface.
# Display the protocol packet statistics for all PPPoE sessions.
<Sysname> display pppoe-client session packet
Bundle: 1 Interface: GE1/0/1
InPackets: 19 OutPackets: 19
InBytes: 816 OutBytes: 816
Bundle: 2 Interface: GE1/0/1
InPackets: 18 OutPackets: 18
InBytes: 730 OutBytes: 730
Table 11 Command output
Bundle |
Dialer bundle to which a PPPoE session belongs. |
Ethernet interface where the PPPoE session is present. |
InPackets |
OutPackets |
InBytes |
OutBytes |
InDrops |
OutDrops |
reset pppoe-client session packet
display pppoe-client session summary
Use display pppoe-client session summary to display summary PPPoE session information.
display pppoe-client session summary [ dial-bundle-number number ]
dial-bundle-number number: Specifies the dialer bundle number corresponding to a PPPoE session. The value range for the number argument is 0 to 1023. If you do not specify this option, the command displays summary information for all PPPoE sessions.
# Display summary information for all PPPoE sessions.
<Sysname> display pppoe-client session summary
Bundle ID Interface VA RemoteMAC LocalMAC State
1 1 GE1/0/1 VA0 00e0-1400-4300 00e0-1500-4100 SESSION
2 1 GE1/0/2 VA1 00e0-1500-4300 00e0-1600-4100 SESSION
Table 12 Command output
Bundle |
Dialer bundle to which the PPPoE session belongs. |
VA |
RemoteMAC |
LocalMAC |
State |
PPPoE session state: · IDLE—Initialization state. · PADI SENT—A PPPoE Active Discovery Initiation (PADI) packet has been sent, and a PPPoE Active Discovery Offer (PADO) packet is being expected. · PADR SENT—A PPPoE Active Discovery Request (PADR) packet has been sent, and a PPPoE Active Discovery Session-confirmation (PADS) packet is being expected. · SESSION—The PPPoE session has been successfully established. |
mtu
Use mtu to set the maximum transmission unit (MTU) of a dialer interface.
mtu size
undo mtu
The MTU of dialer interfaces is 1500 bytes.
size: Specifies the MTU in bytes. The value range for this argument is 128 to 1500.
The MTU setting of a dialer interface affects the fragmentation and reassembly of IP packets.
# Set the MTU of Dialer 1 to 1200 bytes.
[Sysname-Dialer1] mtu 1200
pppoe-client
Use pppoe-client to establish a PPPoE session and specify the dialer bundle corresponding to the session.
Use undo pppoe-client to remove a PPPoE session.
pppoe-client dial-bundle-number number [ no-hostuniq ]
undo pppoe-client dial-bundle-number number
No PPPoE session is established.
VLAN interface view
dial-bundle-number number: Specifies the dialer bundle number corresponding to a PPPoE session. A dialer bundle number uniquely identifies a PPPoE session. It can also be used as a PPPoE session ID. The value range for the number argument is 0 to 1023.
no-hostuniq: Configures the client not to carry the Host-Uniq field in discovery packets. If you do not specify this keyword, the client carries the Host-Unique field. The Host-Unique field uniquely identifies a PPPoE client when an interface is configured with multiple PPPoE sessions. When the PPPoE server receives a packet with this field, it must include this field unmodified in the response packet. The device identifies the PPPoE client where the response packet belongs based on the Host-Unique field in the response packet.
On a fit AP, do not use both a VLAN interface and a dialer interface as uplink interfaces. If you do that, the AP might fail to come online.
# Establish a PPPoE session on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] pppoe-client dial-bundle-number 1
# Establish a PPPoE session on VLAN-Interface 1.
[Sysname-Vlan-interface1] pppoe-client dial-bundle-number 1
reset pppoe-client
Use reset pppoe-client to reset a PPPoE session corresponding to a dialer bundle.
reset pppoe-client { all | dial-bundle-number number }
all: Resets all the PPPoE sessions.
dial-bundle-number number: Specifies a dialer bundle by its number. The value range for the number argument is 0 to 1023.
A PPPoE session in permanent mode and terminated by this command will be established again when the auto dial timer expires.
A PPPoE session in on-demand mode and terminated by this command will be established again only when there is a need for data transmission.
# Reset all PPPoE sessions.
<Sysname> reset pppoe-client all
Use reset pppoe-client session packet to reset the protocol packet statistics for a PPPoE session.
reset pppoe-client session packet [ dial-bundle-number number ]
dial-bundle-number number: Specifies the dialer bundle number corresponding to a PPPoE session. The value range for the number argument is 0 to 1023. If you do not specify this option, the command resets the protocol packet statistics for all PPPoE sessions.
# Reset the protocol packet statistics for all PPPoE sessions.
<Sysname> reset pppoe-client session packet
