- 05-Network Connectivity Command Reference
- 01-MAC address table commands
- 02-Ethernet link aggregation commands
- 03-Port isolation commands
- 04-VLAN commands
- 05-Loop detection commands
- 06-Spanning tree commands
- 07-LLDP commands
- 08-Layer 2 forwarding commands
- 09-VLAN termination commands
- 10-PPP commands
- 11-L2TP commands
- 12-ARP commands
- 13-IP addressing commands
- 14-DHCP commands
- 15-DHCPv6 commands
- 16-DNS commands
- 17-NAT commands
- 18-IP performance optimization commands
- 19-IPv6 basics commands
- 20-Policy-based routing commands
- 21-IPv6 policy-based routing commands
- 22-GRE commands
- 23-Tunneling commands
- 24-ADVPN commands
- 25-Basic IP routing commands
- 26-IP forwarding basics commands
- 27-Static routing commands
- 28-IPv6 static routing commands
- 29-RIP commands
- 30-RIPng commands
- 31-IGMP snooping commands
- 32-MLD snooping commands
- 33-Modem management commands
- 34-3G and 4G modem management commands
| 00-Preface | 99.13 KB |
Preface
This command reference describes the network connectivity configuration commands.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the H3C access controllers.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
