| 00-Preface | 100.47 KB |
Preface
This document describes SIC, DSIC, MIM, HMIM, DHMIM, and VPM interface modules available for H3C MSR Router Series, covering overview, interface specifications, LEDs, and cable connection methods for each interface module model.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the MSR router series.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
