18-OAA Command Reference
HomeSupportReference GuidesCommand ReferencesH3C MSR Router Series Comware 7 Command References-R0615-6W20318-OAA Command Reference
Table of Contents
Related Documents
01-Text
01-Text 46.92 KB
OAP module commands
The following matrix shows the feature and hardware compatibility:
Hardware
OAP module compatibility
MSR810/810-W/810-W-DB/810-LM/810-W-LM/810-10-PoE/810-LM-HK/810-W-LM-HK/810-LMS/810-LUS
No
MSR2600-6-X1/2600-10-X1
No
MSR 2630
No
MSR3600-28/3600-51
No
MSR3600-28-SI/3600-51-SI
No
MSR3610-X1/3610-X1-DP/3610-X1-DC/3610-X1-DP-DC
No
MSR 3610/3620/3620-DP/3640/3660
Yes
MSR5620/5660/5680
Yes
This feature is supported only on the HMIM-OAP module.
Commands and descriptions for centralized devices apply to the following routers:
·     MSR810/810-W/810-W-DB/810-LM/810-W-LM/810-10-PoE/810-LM-HK/810-W-LM-HK/810-LMS/810-LUS.
·     MSR2600-6-X1/2600-10-X1.
·     MSR 2630.
·     MSR3600-28/3600-51.
·     MSR3600-28-SI/3600-51-SI.
·     MSR3610-X1/3610-X1-DP/3610-X1-DC/3610-X1-DP-DC.
·     MSR 3610/3620/3620-DP/3640/3660.
Commands and descriptions for distributed devices apply to the following routers:
·     MSR5620.
·     MSR 5660.
·     MSR 5680.
oap connect
Use oap connect to log in to the CLI of an OAP module from the device.
Distributed devices in standalone mode/centralized devices in standalone or IRF mode:
oap connect slot slot-number system system-name
Distributed devices in IRF mode:
oap connect chassis chassis-number slot slot-number system system-name
slot slot-number: Specifies an OAP module by its slot number. (Distributed devices in standalone mode.)
slot slot-number: Specifies an IRF member device by its member ID. (Centralized devices in IRF mode.)
chassis chassis-number slot slot-number: Specifies an OAP module in a member device by the member ID and slot number. (Distributed devices in IRF mode.)
system system-name: Specifies an OAP module by its device name or by its subslot number.
To return to the CLI of the hosting device from the OAP module, press Ctrl+K.
# (Distributed devices in standalone mode/centralized devices in standalone or IRF mode.) Log in to the CLI of the OAP module in slot 3.
<Sysname> oap connect slot 3 system 6
Press CTRL+K to quit.
Connected to OAP.
# (Distributed devices in IRF mode.) Log in to the CLI of the OAP module that resides in subslot 6 on the card in slot 5 of member device 2.
<Sysname> oap connect chassis 2 slot 5 system 6
Connected to OAP.
oap reboot
Use oap reboot to reboot an OAP module.
oap reboot slot slot-number system system-name
oap reboot chassis chassis-number slot slot-number system system-name
# (Distributed devices in standalone mode/centralized devices in standalone or IRF mode.) Reboot the OAP module in subslot 6.
<Sysname> oap reboot slot 3 system 6
This command might cause data loss on the hard disk if the card is not been shut down.
Continue? [Y/N]:y
Rebooting the OAP card by command…
# (Distributed devices in IRF mode.) Reboot the OAP module that resides in subslot 6 of the card in slot 2 of member device 1.
<Sysname> oap reboot chassis 1 slot 2 system 6
Continue? [Y/N]:y
