07-System
HomeSupportConfigure & DeployConfiguration GuidesH3C SecPath M9000 Comware 7 Web configuration guide(R9153P38 R9724P38 R9001P38 E9153P38)-6W40107-System
36-Configuration management
36-Configuration management 43.43 KB
This help contains the following topics:
·     Introduction
·     Restrictions and guidelines
·     Manage the running configuration
Introduction
A configuration file contains a set of software feature settings for the device. You can save software feature settings to a configuration file so the configuration can survive a reboot. You can also back up configuration files to a server for future use. For example, import a configuration file to multiple devices that share the same configuration.
Configuration types
Factory defaults
Factory defaults are basic settings that came with the device. The device starts up with the factory defaults if no startup configuration files are available.
Startup configuration
The device uses the startup configuration to configure software features during startup. After the device starts up, you can specify the configuration file to be loaded at the next startup. If no startup configuration files are available, the device starts up with the factory defaults.
Running configuration
The running configuration takes effect while the device is operating. It includes unchanged startup settings and new settings. The running configuration is stored in memory and is cleared at a device reboot or power-off. To use the running configuration after a power cycling or reboot, save it to a configuration file.
Factory default restoration
Use this feature to restore the factory defaults and reboot the device immediately for the feature to take effect. Use this feature with caution, because this feature deletes all user-configured settings from the device. As a best practice, use this feature only when the device fails or the application scenario of the device changes.
This feature is supported only on the default context.
Configuration backup
Use this feature to back up the running configuration on the device to a local configuration file or to a configuration file on an FTP or TFTP server. The device supports immediate backup and periodic backup.
You can use the backup configuration files for configuration rollback.
Configuration rollback
Use this feature to replace the running configuration with the configuration in a configuration file. The configuration file can be saved on the local device or on an FTP or TFTP server. If you use a configuration file on an FTP or TFTP server for configuration rollback, you must specify the rollback time.
Restoring the factory defaults removes all configurations you have made from the device.
If server-based backup or rollback is used, make sure the device can reach the remote FTP or TFTP server.
Back up the running configuration
1.     Click the System tab.
2.     In the navigation pane, select Maintenance > Configuration Management.
3.     Click Back up current configuration.
4.     Configure the configuration backup parameters.
Table 1 Configuration backup configuration items
Item
Backup type
Select a location to save the backup configuration files:
·     Back up to local.
·     Back up to server.
Auto backup interval
Enter the interval for periodic configuration backup.
If you do not configure this parameter, the device does not periodically back up the running configuration.
Max backup files
Enter the maximum number of backup configuration files that can be saved on the device.
After the maximum number is reached, the system deletes the oldest backup file for the new backup file.
Local backup path
Enter the directory where the backup configuration files will be saved on the device.
The directory must already exist on the device.
Prefix name
Enter a file name prefix for backup configuration files.
Backup configuration files are named in the format of prefix_serial number.cfg.
Immediate backup
To back up the running configuration immediately, select this item.
Server type
Select the file transfer protocol. Options include FTP and TFTP.
Address
Enter the IPv4 or IPv6 address of the file server.
VRF
Select the name of the VPN instance to which the file server belongs.
Username
Enter the username for logging in to the file server.
Password
Enter the password for logging in to the file server.
Port
Enter the port number of the file server.
Backup path
Enter the path where the backup configuration files will be saved on the server.
5.     Click OK.
Roll back the configuration
3.     Click Configure rollback.
4.     Select the rollback file location:
¡     To use a configuration file saved on the local storage device, select Local device.
¡     To use a configuration file saved on a remote file server, select Server.
5.     Roll back the configuration or schedule a rollback:
¡     If you are using a local configuration file for rollback, specify a local directory in the Location field, click Access to the file to show configuration files in the directory, identify the configuration file you are using, and then click its Roll Back link to roll back the configuration.
¡     If you are using a configuration file on a remote server for rollback, configure the parameters as shown in Table 2 to schedule a rollback, and then click OK.
Table 2 Configuration items for server-based rollback
Item
Server type
Select the server type. Options include FTP and TFTP.
Address
Enter the IPv4 or IPv6 address of the server.
VRF
Select the name of the VPN instance to which the server belongs.
Username
Enter the username for logging in to the FTP or TFTP server.
Password
Enter the password for logging in to the FTP or TFTP server.
Port
Enter the port number of the FTP or TFTP server.
Rollback file path
Enter the path where the rollback configuration file is saved.
Default rollback file
Enter the name of the default rollback configuration file.
If you do not specify a rollback configuration file, the default rollback configuration file will be used.
Rollback file
Enter the name of the rollback configuration file.
Rollback date
Set the date on which the configuration rollback will be performed.
Rollback time
Set the time when the configuration rollback will be performed.
Setting a rollback time is required.
Cancel scheduled rollback
Select this option to cancel the rollback schedule.
