00-About the H3C Firewall Products Web Configuration Guide
HomeSupportSecurityH3C SecPath F5000 FirewallConfigure & DeployConfiguration GuidesH3C Firewall Products Comware 7 Web Configuration Guide(E1196 E8371)-6W70000-About the H3C Firewall Products Web Configuration Guide
02-About the H3C Firewall Products Web Configuration Guide
The H3C firewall products Comware 7 Web configuration guide describes the software features for the H3C firewall products. This guide also provides Web configuration examples to help you apply the software features to different network scenarios.
To obtain software version information for a device, use the display version command in any view on the device. The configuration guides use the XXXXP13 versions as examples to illustrate feature configuration. For information about feature changes in other software versions, see the release notes for your device.
The following matrix shows the hardware and software versions to which this configuration guide is applicable:
Hardware
Software version
F5000-AI160F5000-E
E8371
vFW1000vFW2000
E1196
