| 00-Preface | 28.26 KB |
Preface
The H3C U-Center O&M Platform User Guide guides users to understand and use the feature modules of U-Center and helps users resolve issues encountered during use.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with H3C U-Center.
Conventions
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Documentation feedback
We appreciate your comments.
