19-Security Command Reference
HomeSupportReference GuidesCommand ReferencesH3C MSR1000[2600][3600] Routers Command Reference(V9)-R9119-6W10019-Security Command Reference
18-mGRE commands
18-mGRE commands 84.04 KB
mGRE commands
display mgre session
Use display mgre session to display mGRE session information.
display mgre session [ interface tunnel interface-number [ peer ipv4-address ] ] [ verbose ]
interface tunnel interface-number: Specifies an mGRE tunnel interface by its number. The value range for the interface-number argument is 0 to 10239. If you do not specify this option, the command displays mGRE session information for all mGRE tunnel interfaces.
peer ipv4-address: Specifies a peer public address. If you do not specify this option, the command displays all mGRE session information for the specified mGRE tunnel interface.
verbose: Displays detailed information about IPv4 mGRE sessions. If you do not specify this keyword, the command displays brief information about mGRE sessions.
If you do not specify any parameters, this command displays brief information about all mGRE sessions on all tunnel interfaces.
# Display brief information about all mGRE sessions.
<Sysname> display mgre session
Interface        : Tunnel1
Number of sessions: 2
Peer NBMA address  Peer protocol address    Type   State         State duration
10.0.0.3           192.168.180.136          C-S    Succeeded     00:30:01
10.0.1.4           192.168.180.137          C-C    Establishing  00:30:02
# Display brief information about the mGRE session with the specified peer address.
<Sysname> display mgre session interface tunnel 1 peer 10.0.0.3
Interface         : Tunnel1
Number of sessions: 1
Name of the mGRE tunnel interface.
Number of sessions
Total number of mGRE sessions on the tunnel interface.
Peer NBMA address
Public address of the peer.
IP address of the peer tunnel interface.
mGRE session type:
·     C-S—The local end is an NHC, and the peer end is the NHS.
·     C-C—Both the local and peer ends are NHCs.
·     UNKNOWN—The local end is an NHC, and the peer end type is unknown.
mGRE session state:
·     Succeeded.
·     Establishing.
State duration
Duration of the current session state, in the format of hh:mm:ss.
# Display detailed information about all mGRE sessions.
<Sysname> display mgre session verbose
Interface         : Tunnel1
Link protocol     : GRE
  Peer NBMA address    : 10.0.1.3
  Peer protocol address: 192.168.180.136
  Session type         : C-S
  State                : Succeeded
  State duration       : 00:30:01
  Input : 2201 packets, 218 data packets, 3 control packets
          2191 multicasts, 0 errors
  Output: 2169 packets, 2168 data packets, 1 control packets
          2163 multicasts, 0 errors
  Peer NBMA address    : 10.0.1.4
  Peer protocol address: 192.168.180.137
  Session type         : C-S
  State                : Succeeded
  State duration       : 00:31:01
  Input : 1 packets, 0 data packets, 1 control packets
          0 multicasts, 0 errors
  Output: 16 packets, 0 data packets, 16 control packets
Interface         : Tunnel2
Link protocol     : IPsec-GRE
  Peer NBMA address     : 20.0.0.3
  Peer protocol address : 192.168.181.137
  Behind NAT            : No
  Session type          : C-C
  SA's SPI              :
      Inbound : 187199087 (0xb286e6f) [ESP]
      Outbound: 3562274487 (0xd453feb7) [ESP]
  State                 : Establishing
  Input : 0 packets, 0 data packets, 0 control packets
  Output: 1 packets, 0 data packets, 1 control packets
Link protocol
Encapsulation protocol used by the mGRE tunnel:
·     GRE.
·     IPsec-GRE.
Number of sessions
Peer NBMA address
SA's SPI
SPI of the inbound and outbound SAs. This field is available when the mGRE tunnel is carried over IPsec.
Behind NAT
Whether the peer NHC has traversed a NAT device.
Session type
mGRE session type:
mGRE session state:
·     Succeeded.
·     Establishing.
State duration
Input
Statistics on received packets:
·     packets—Total number of packets.
·     data packets—Number of data packets.
·     control packets—Number of control packets.
·     multicasts—Number of multicast packets.
·     errors—Number of error packets.
Output
Statistics on sent packets:
reset mgre session
display nhrp map
Use display nhrp map to display information about NHRP mapping entries.
display nhrp map [ interface tunnel interface-number [ peer ipv4-address ] ] [ verbose ]
interface tunnel interface-number: Specifies an mGRE tunnel interface by its number. The value range for the interface-number argument is 0 to 10239. If you do not specify this option, the command displays NHRP mapping table information for all mGRE tunnel interfaces.
peer ipv4-address: Specifies a peer public address. If you do not specify this option, the command displays NHRP mapping entries for all peers.
verbose: Displays detailed information about NHRP mapping entries. If you do not specify this keyword, the command displays brief information about NHRP mapping entries.
If you do not specify any parameters, this command displays brief information about all NHRP mapping entries.
# Display brief information about all NHRP mapping entries.
<Sysname> display nhrp map
Destination/mask   Next hop       NBMA address    Type     Interface
172.16.1.1/32      172.16.1.1     105.112.100.4   cached   Tunnel0
172.16.1.2/32      172.16.1.2     105.112.100.92  cached   Tunnel0
# Display detailed information about all NHRP mapping entries.
<Sysname> display nhrp map verbose
Interface   : Tunnel0
  Destination/mask    : 172.16.1.1/32
  Next hop            : 172.16.1.1
  Creation time       : 00:38:44
  Expiration time     : 01:21:15
  Type                : cached
  Flags               : unique up used
  NBMA address        : 105.112.100.4
Interface   : Tunnel0
  Destination/mask    : 172.16.1.2/32
  Next hop            : 172.16.1.2
  Creation time       : 00:25:53
  Expiration time     : 01:34:06
  Type                : cached
  Flags               : unique up used ipsec
  NBMA address        : 105.112.100.92
Destination/mask
Destination tunnel interface address and mask.
Next hop
Next hop address to reach the destination network.
Creation time
Period of time for which the mapping entry has been created.
Expiration time
Period of time in which the mapping entry will expire.
Mapping entry type:
·     static—The entry is statically configured.
·     cached—The entry is dynamically obtained.
·     Incomplete—The entry is dynamic and incomplete.
Flags
Mapping entry flags:
·     unique—The mapping entry in the registration request cannot be overwritten by a mapping entry that has the same private address and different public addresses. A client can register the new entry with the server only after the mapping entry on the server expires.
·     used—This mapping entry is used for packet forwarding.
·     up—This mapping entry can be used for packet forwarding.
·     ipsec—IPsec negotiation succeeded. Packets will be protected by IPsec.
·     init—Initialization state.
display nhrp statistics
Use display nhrp statistics to display NHRP packet statistics for a tunnel interface.
display nhrp statistics [ interface tunnel interface-number ]
interface tunnel interface-number: Specifies an mGRE tunnel interface by its number. The value range for the interface-number argument is 0 to 10239. If you do not specify this option, the command displays NHRP packet statistics for all tunnel interfaces.
# Display NHRP packet statistics.
<Sysname> display nhrp statistics
Tunnel0:
  NHRP packets sent       : 815
    Resolution requests   : 15
    Resolution replies    : 1
    Registration requests : 0
    Registration replies  : 797
    Purge requests        : 2
    Purge replies         : 0
    Error indications     : 0
    Traffic indications   : 0
  NHRP packets received   : 1453
    Registration requests : 1435
    Registration replies  : 2
    Purge requests        : 0
    Purge replies         : 0
Tunnel1:
  NHRP packets sent       : 3
    Resolution Requests   : 0
    Resolution replies    : 0
    Registration replies  : 3
    Purge requests        : 0
    Purge replies         : 0
  NHRP packets received   : 3
    Resolution requests   : 0
    Registration requests : 3
    Registration replies  : 0
    Purge requests        : 0
    Purge replies         : 0
reset nhrp statistics
nhrp authentication
Use nhrp authentication to configure an NHRP packet authentication key.
Use undo nhrp authentication to restore the default.
nhrp authentication { cipher | simple } string
No NHRP packet authentication key is configured. NHRP nodes do not authenticate NHRP packets received from each other.
mGRE tunnel interface view
cipher: Specifies an authentication key in encrypted form.
simple: Specifies an authentication key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies the key string. Its plaintext form is a case-sensitive string of 1 to 8 characters. Its encrypted form is a case-sensitive string of 1 to 41 characters.
After an NHRP packet authentication key is configured for a tunnel interface, the tunnel interface adds the key in packets sent to the peer. The tunnel interface also uses the key to authenticate NHRP packets it receives. If a packet fails the authentication, the packet will be dropped.
For mGRE tunnels to be established successfully, configure the same NHRP authentication key for all NHCs and NHSs in the same mGRE network.
# On interface Tunnel1, set the NHRP packet authentication key to 123456.
[Sysname] interface tunnel 1 mode mgre
[Sysname-Tunnel1] nhrp authentication simple 123456
nhrp holdtime
Use nhrp holdtime to configure the holdtime for NHRP mapping entries.
Use undo nhrp holdtime to restore the default.
nhrp holdtime seconds
undo nhrp holdtime
The holdtime of NHRP mapping entries is 7200 seconds.
seconds: Specifies the holdtime in the range of 1 to 65535 seconds.
After the holdtime is configured, the local NHRP holdtime carried in outgoing packets is updated to the configured holdtime.
# On interface Tunnel1, set the holdtime of NHRP mapping entries to 600 seconds
[Sysname-Tunnel1] nhrp holdtime 600
interface tunnel (Layer 3—IP Services Command Reference)
nhrp network-id
Use nhrp network-id to configure an NHRP network ID for an mGRE tunnel.
Use undo nhrp network-id to restore the default.
nhrp network-id number
No NHRP network ID is configured for an mGRE tunnel.
number: Specifies an NHRP network ID in the range of 1 to 4294967295.
A network ID is only locally significant. You can configure different NHRP network IDs for different tunnel interfaces on the device. The NHC and NHS can have different NHRP network IDs.
# Set the NHRP network ID to 10 for mGRE tunnel interface Tunnel1.
[Sysname-Tunnel1] nhrp network-id 10
nhrp nhs
Use nhrp nhs to configure an NHS private-to-public address mapping.
Use undo nhrp nhs to delete an NHS private-to-public address mapping.
nhrp nhs nhs-address nbma nbma-address
undo nhrp nhs nhs-address nbma nbma-address
No NHS private-to-public address mappings are configured.
nhs-address: Specifies the private address of an NHS.
nbma-address: Specifies the public address (NBMA address) of the NHS.
You can execute this command multiple times to configure multiple NHSs for redundancy. If multiple NHSs are configured, NHCs register with all the NHSs.
# On interface Tunnel1, configure the NHS private address as 1.1.1.1 and public address as 120.1.1.120.
[Sysname-Tunnel1] nhrp nhs 1.1.1.1 nbma 120.1.1.120
reset mgre session
Use reset mgre session to reset dynamic mGRE sessions.
reset mgre session [ interface tunnel interface-number [ peer ipv4-address ] ]
interface tunnel interface-number: Specifies an mGRE tunnel interface by its number. The value range for the interface-number argument is 0 to 10239. If you do not specify this option, the command resets dynamic mGRE sessions for all mGRE tunnel interfaces.
peer ipv4-address: Specifies a peer public address. If you do not specify this option, the command resets all dynamic mGRE sessions for the specified mGRE tunnel interface.
When an mGRE session is reset, the NHC reregisters with the NHS.
# Reset the mGRE sessions on interface Tunnel1.
<Sysname> reset mgre session interface tunnel 1
# Reset the mGRE session with peer address 202.12.12.12 on interface Tunnel1.
<Sysname> reset mgre session interface tunnel 1 peer 202.12.12.12
reset mgre statistics
Use reset mgre statistics to clear mGRE session statistics.
reset mgre statistics [ interface tunnel interface-number [ peer ipv4-address ] ]
interface tunnel interface-number: Specifies an mGRE tunnel interface by its number. The value range for the interface-number argument is 0 to 10239. If you do not specify this option, the command clears mGRE session statistics for all mGRE tunnel interfaces.
peer ipv4-address: Specifies a peer public address. If you do not specify this option, the command clears statistics about all mGRE sessions on the specified mGRE tunnel interface.
# Clear statistics about mGRE sessions on interface Tunnel1.
<Sysname> reset mgre statistics interface tunnel 1
# Clear statistics about the mGRE session with peer public address 192.168.1.200 on interface Tunnel1.
<Sysname> reset mgre statistics interface tunnel 1 peer 192.168.1.200
Use reset nhrp statistics to clear NHRP packet statistics.
reset nhrp statistics [ interface tunnel interface-number ]
interface tunnel interface-number: Specifies an mGRE tunnel interface by its number. The value range for the interface-number argument is 0 to 10239. If you do not specify this option, the command clears NHRP packet statistics for all mGRE tunnel interfaces.
# Clear NHRP packet statistics for interface Tunnel1.
<Sysname> reset nhrp statistics interface tunnel 1
