12-Security Command Reference
HomeSupportRoutersMSR5600 Series(Comware V7)Reference GuidesCommand ReferencesH3C MSR 5600 Routers Command Reference(V7)-R6728-6W10012-Security Command Reference
25-Attack detection and prevention commands
25-Attack detection and prevention commands 756.67 KB
Attack detection and prevention commands· 1
ack-flood action· 1
ack-flood detect 2
ack-flood detect non-specific· 3
ack-flood threshold· 4
ack-flood source-threshold· 5
attack-defense apply policy· 6
attack-defense local apply policy· 7
attack-defense login block-timeout 8
attack-defense login enable· 8
attack-defense login max-attempt 9
attack-defense login reauthentication-delay· 9
attack-defense policy· 10
attack-defense signature log non-aggregate· 11
attack-defense top-attack-statistics enable· 12
blacklist destination-ip· 12
blacklist destination-ipv6· 13
blacklist enable· 14
blacklist global enable· 15
blacklist ip· 15
blacklist ipv6· 16
blacklist logging enable· 17
blacklist object-group· 19
client-verify dns enable· 19
client-verify dns-reply enable· 20
client-verify http enable· 21
client-verify sip enable· 21
client-verify protected ip· 22
client-verify protected ipv6· 23
client-verify tcp enable· 24
display attack-defense flood statistics ip· 26
display attack-defense flood statistics ipv6· 28
display attack-defense http-slow-attack statistics ip· 31
display attack-defense http-slow-attack statistics ipv6· 33
display attack-defense policy· 35
display attack-defense policy ip· 42
display attack-defense policy ipv6· 44
display attack-defense scan attacker ip· 46
display attack-defense scan attacker ipv6· 48
display attack-defense statistics interface· 49
display attack-defense statistics local 54
display attack-defense top-attack-statistics· 58
display blacklist destination-ip· 60
display blacklist destination-ipv6· 61
display blacklist ip· 63
display blacklist ipv6· 64
display client-verify protected ip· 66
display client-verify protected ipv6· 68
display client-verify trusted ip· 69
display client-verify trusted ipv6· 71
display whitelist object-group· 72
dns-flood action· 73
dns-flood detect 74
dns-flood detect non-specific· 76
dns-flood port 77
dns-flood threshold· 78
dns-flood source-threshold· 79
dns-reply-flood action· 79
dns-reply-flood detect 81
dns-reply-flood detect non-specific· 82
dns-reply-flood port 83
dns-reply-flood threshold· 84
dns-reply-flood source-threshold· 85
exempt acl 86
fin-flood action· 87
fin-flood detect 88
fin-flood detect non-specific· 89
fin-flood threshold· 90
fin-flood source-threshold· 91
http-flood action· 92
http-flood detect 93
http-flood detect non-specific· 95
http-flood port 96
http-flood threshold· 96
http-flood source-threshold· 97
http-slow-attack action· 98
http-slow-attack detect 99
http-slow-attack detect non-specific· 101
http-slow-attack period· 102
http-slow-attack port 102
http-slow-attack threshold· 103
icmp-flood action· 104
icmp-flood detect ip· 105
icmp-flood detect non-specific· 107
icmp-flood threshold· 108
icmp-flood source-threshold· 109
icmpv6-flood action· 109
icmpv6-flood detect ipv6· 110
icmpv6-flood detect non-specific· 112
icmpv6-flood threshold· 113
icmpv6-flood source-threshold· 114
reset attack-defense policy flood· 114
reset attack-defense statistics interface· 115
reset attack-defense statistics local 116
reset attack-defense top-attack-statistics· 116
reset blacklist destination-ip· 116
reset blacklist destination-ipv6· 117
reset blacklist ip· 118
reset blacklist ipv6· 118
reset blacklist statistics· 119
reset client-verify protected statistics· 119
reset client-verify trusted· 120
reset whitelist statistics· 121
rst-flood action· 121
rst-flood detect 122
rst-flood detect non-specific· 124
rst-flood threshold· 124
rst-flood source-threshold· 125
scan detect 126
signature { large-icmp | large-icmpv6 } max-length· 128
signature detect 129
signature level action· 133
signature level detect 134
sip-flood action· 135
sip-flood detect 136
sip-flood detect non-specific· 137
sip-flood port 138
sip-flood threshold· 139
sip-flood source-threshold· 140
syn-ack-flood action· 141
syn-ack-flood detect 142
syn-ack-flood detect non-specific· 144
syn-ack-flood threshold· 145
syn-ack-flood source-threshold· 145
syn-flood action· 146
syn-flood detect 147
syn-flood detect non-specific· 149
syn-flood threshold· 150
syn-flood source-threshold· 151
threshold-learn apply· 151
threshold-learn auto-apply enable· 152
threshold-learn duration· 153
threshold-learn enable· 154
threshold-learn interval 154
threshold-learn mode· 155
threshold-learn tolerance-value· 156
udp-flood action· 157
udp-flood detect 158
udp-flood detect non-specific· 159
udp-flood threshold· 160
udp-flood source-threshold· 161
whitelist enable· 162
whitelist global enable· 162
whitelist object-group· 163
The MSR 56-60 and MSR 56-80 routers installed with the MPU-100-G modules do not support parameters or commands that are available only in IRF mode.
ack-flood action
Use ack-flood action to specify global actions against ACK flood attacks.
Use undo ack-flood action to restore the default.
ack-flood action { client-verify | drop | logging } *
No global action is specified for ACK flood attacks.
Attack defense policy view
client-verify: Adds the victim IP addresses to the protected IP list for TCP client verification. If TCP client verification is enabled, the device provides proxy services for protected servers. This keyword does not take effect on source-based flood attack prevention.
drop: Drops subsequent ACK packets destined for the victim IP addresses in destination-based flood attack prevention, or drops subsequent ACK packets originating from the attacker IP addresses in source-based flood attack prevention.
logging: Enables logging for ACK flood attack events. The log messages will be sent to the log system.
For the ACK flood attack detection to collaborate with the TCP client verification, make sure the client-verify keyword is specified and the TCP client verification is enabled. To enable TCP client verification, use the client-verify tcp enable command.
The logging keyword enables the attack detection and prevention module to log ACK flood attack events and send log messages to the information center.
With the information center, you can set log message filtering and output rules, including output destinations.
The information center can output ACK flood attack logs to any destinations except the console and the monitor terminal. If you configure the console or monitor terminal as an output destination, the output destination setting will not take effect.
To view ACK flood attack logs stored on the device, use the display logbuffer command. Make sure you do not disable log output to the log buffer, which is enabled by default.
For more information about configuring the information center, see Network Management and Monitoring Configuration Guide.
# Specify drop as the global action against ACK flood attacks in attack defense policy atk-policy-1.
[Sysname] attack-defense policy atk-policy-1
[Sysname-attack-defense-policy-atk-policy-1] ack-flood action drop
ack-flood detect
ack-flood threshold
ack-flood detect
Use ack-flood detect to configure IP address-specific ACK flood attack detection.
Use undo ack-flood detect to remove IP address-specific ACK flood attack detection configuration.
ack-flood detect { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] [ threshold threshold-value ] [ action { { client-verify | drop | logging } * | none } ]
undo ack-flood detect { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
IP address-specific ACK flood attack detection is not configured.
ip ipv4-address: Specifies the IPv4 address to be protected. The ip-address argument cannot be 255.255.255.255 or 0.0.0.0.
ipv6 ipv6-address: Specifies the IPv6 address to be protected. The IPv6 address cannot be a multicast address or ::.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the protected IP address belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. Do not specify this option if the protected IP address is on the public network.
threshold threshold-value: Specifies the maximum receiving rate in pps for ACK packets that are destined for the protected IP address. The value range is 1 to 1000000.
action: Specifies the actions against a detected ACK flood attack. If no action is specified, the global actions set by the ack-flood action command apply.
drop: Drops subsequent ACK packets destined for the protected IP address.
none: Takes no action.
With ACK flood attack detection configured for an IP address, the device is in attack detection state. When the receiving rate of ACK packets destined for the IP address keeps reaching or exceeding the threshold, the device enters prevention state and takes the specified actions. When the rate drops below the silence threshold (three-fourths of the threshold), the device returns to the attack detection state.
You can configure ACK flood attack detection for multiple IP addresses in one attack defense policy.
# Configure ACK flood attack detection for 192.168.1.2 in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] ack-flood detect ip 192.168.1.2 threshold 2000
ack-flood action
ack-flood threshold
Use ack-flood detect non-specific to enable global ACK flood attack detection.
Use undo ack-flood detect non-specific to disable global ACK flood attack detection.
Global ACK flood attack detection is disabled.
The device supports the following ACK flood attack prevention types:
·     Source-based ACK flood attack prevention—Monitors the receiving rate of ACK packets on a per-source IP basis.
·     Destination-based ACK flood attack prevention—Monitors the receiving rate of ACK packets on a per-destination IP basis.
The global ACK flood attack detection applies to all IP addresses except those specified by the ack-flood detect command. The global detection uses the global trigger threshold set by the ack-flood threshold or ack-flood source-threshold command and global actions specified by the ack-flood action command.
# Enable global ACK flood attack detection in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] ack-flood detect non-specific
ack-flood action
ack-flood detect
ack-flood threshold
ack-flood threshold
Use ack-flood threshold to set the global threshold for triggering destination-based ACK flood attack prevention.
Use undo ack-flood threshold to restore the default.
ack-flood threshold threshold-value
The global threshold is 40000 for triggering destination-based ACK flood attack prevention.
threshold-value: Specifies the maximum receiving rate in pps for ACK packets that are destined for an IP address. The value range is 0 to 1000000. If you set the threshold value to 0, the destination-based ACK flood attack prevention is disabled.
With global ACK flood attack detection configured, the device is in attack detection state. When the receiving rate of ACK packets destined for an IP address keeps reaching or exceeding the threshold, the device enters prevention state and takes the specified actions. When the rate drops below the silence threshold (three-fourths of the threshold), the device returns to the attack detection state.
The global threshold applies to global ACK flood attack detection. Adjust the threshold according to the application scenarios.
·     If the number of ACK packets sent to a protected server, such as an HTTP or FTP server, is normally large, set a high threshold. A low threshold might affect the server services.
·     For a network that is unstable or susceptible to attacks, set a low threshold.
# Set the global threshold to 100 for triggering destination-based ACK flood attack prevention in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] ack-flood threshold 100
ack-flood action
ack-flood detect
Use ack-flood source-threshold to set the global threshold for triggering source-based ACK flood attack prevention.
Use undo ack-flood source-threshold to restore the default.
ack-flood source-threshold threshold-value
The global threshold is 40000 for triggering source-based ACK flood attack prevention.
threshold-value: Specifies the maximum receiving rate in pps for ACK packets that originate from an IP address. The value range is 0 to 1000000. If you set the threshold value to 0, the source-based ACK flood attack prevention is disabled.
With global ACK flood attack detection configured, the device is in attack detection state. When the receiving rate of ACK packets originating from an IP address keeps reaching or exceeding the threshold, the device enters prevention state and takes the specified actions. When the rate drops below the silence threshold (three-fourths of the threshold), the device returns to the attack detection state.
# Set the global threshold to 100 for triggering source-based ACK flood attack prevention in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] ack-flood source-threshold 100
ack-flood action
ack-flood detect
Use attack-defense apply policy to apply an attack defense policy to an interface.
Use undo attack-defense apply policy to restore the default.
attack-defense apply policy policy-name
No attack defense policy is applied to an interface.
Interface view
policy-name: Specifies an attack defense policy by its name. The policy name is a case-insensitive string of 1 to 31 characters. Valid characters include uppercase and lowercase letters, digits, underscores (_), and hyphens (-).
An interface can have only one attack defense policy applied. If you execute this command multiple times, the most recent configuration takes effect.
An attack defense policy can be applied to multiple interfaces.
# Apply attack defense policy atk-policy-1 to GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] attack-defense apply policy atk-policy-1
Use attack-defense local apply policy to apply an attack defense policy to the device.
Use undo attack-defense local apply policy to restore the default.
attack-defense local apply policy policy-name
No attack defense policy is applied to the device.
An attack defense policy applied to the device itself detects packets destined for the device and prevents attacks targeted at the device.
Applying an attack defense policy to the device can improve the efficiency of processing attack packets destined for the device.
Each device can have only one attack defense policy applied. If you execute this command multiple times, the most recent configuration takes effect.
An attack defense policy can be applied to the device itself and to multiple interfaces.
If a device and its interfaces have attack defense policies applied, a packet destined for the device is processed as follows:
1.     The policy applied to the receiving interface processes the packet.
2.     If the packet is not dropped by the receiving interface, the policy applied to the device processes the packet.
# Apply attack defense policy atk-policy-1 to the device.
[Sysname] attack-defense local apply policy atk-policy-1
Use attack-defense login block-timeout to set the block period during which a login attempt is blocked.
Use undo attack-defense login block-timeout to restore the default.
attack-defense login block-timeout minutes
The block period is 60 minutes.
minutes: Specifies the block period in minutes, in the range of 1 to 2880.
After a user fails the maximum number of login attempts, login attack prevention triggers the blacklist module to add the user's IP address to the blacklist. The block period determines how long the user is on the blacklist. During the period, login attempts from the user are blocked.
# Set the block period to 5 minutes.
[Sysname] attack-defense login block-timeout 5
Use attack-defense login enable to enable login attack prevention.
Use undo attack-defense login enable to disable login attack prevention.
Login attack prevention is disabled.
After a user fails the maximum number of login attempts, login attack prevention uses the blacklist to block the user from logging in during the block period.
For login attack prevention to take effect, you must enable the global blacklist feature.
# Enable login attack prevention.
[Sysname] attack-defense login enable
Use attack-defense login max-attempt to set the maximum number of successive login failures for each user.
Use undo attack-defense login max-attempt to restore the default.
attack-defense login max-attempt max-attempt
Login attack prevention detects a login attack if a user fails three successive login attempts.
max-attempt: Specifies the maximum number of login failures. The value range is 1 to 60.
The login failure counter for a user is reset after the user logs in successfully. If the device reboots, all login failure counters are reset.
# Set the maximum number of successive login failures to five.
[Sysname] attack-defense login max-attempt 5
Use attack-defense login reauthentication-delay to enable the login delay feature and set the delay period.
Use undo attack-defense login reauthentication-delay to restore the default.
attack-defense login reauthentication-delay seconds
The login delay feature is disabled. The device does not delay accepting a login request from a user who has failed a login attempt.
seconds: Specifies the delay period in seconds, in the range of 4 to 60.
The login delay feature delays the device to accept a login request from a user after the user fails a login attempt. This feature can slow down login dictionary attacks.
The login delay feature is independent of the login attack prevention feature.
# Enable the login delay feature and set the delay period to 5 seconds.
[Sysname] attack-defense login reauthentication-delay 5
Use attack-defense policy to create an attack defense policy and enter its view, or enter the view of an existing attack defense policy.
Use undo attack-defense policy to delete an attack defense policy.
attack-defense policy policy-name
undo attack-defense policy policy-name
No attack defense policies exist.
policy-name: Assigns a name to the attack defense policy. The policy name is a case-insensitive string of 1 to 31 characters. Valid characters include uppercase and lowercase letters, digits, underscores (_), and hyphens (-).
CAUTION
CAUTION:
The default thresholds for triggering attack prevention might not be appropriate for your network. Set appropriate thresholds according to the actual application scenarios. Small thresholds might affect the Internet or webpage access speed. Large thresholds might make your network vulnerable to attacks.
# Create attack defense policy atk-policy-1 and enter its view.
Use attack-defense signature log non-aggregate to enable log non-aggregation for single-packet attack events.
Use undo attack-defense signature log non-aggregate to restore the default.
Log non-aggregation is disabled for single-packet attack events.
Log aggregation aggregates multiple logs generated during a period of time and sends one log. Logs that are aggregated must have the following attributes in common:
·     Location where the attacks are detected: device or interface.
·     Attack type.
·     Attack prevention action.
·     Source and destination IP addresses.
·     VPN instance to which the victim IP address belongs.
As a best practice, do not disable log aggregation. A large number of logs will consume the display resources of the console.
# Enable log non-aggregation for single-packet attack events.
[Sysname] attack-defense signature log non-aggregate
signature detect
Use attack-defense top-attack-statistics enable to enable the top attack statistics ranking feature.
Use undo attack-defense top-attack-statistics enable to disable the top attack statistics ranking feature.
The top attack statistics ranking feature is disabled.
System view.
This feature collects statistics about number of dropped attack packets based on attacker, victim, and attack type and ranks the statistics by attacker and victim.
To display the top attack statistics, use the display attack-defense top-attack-statistics command.
# Enable the top attack statistics ranking feature.
[Sysname] attack-defense top-attack-statistics enable
Use blacklist destination-ip to add a destination IPv4 blacklist entry.
Use undo blacklist destination-ip to delete a destination IPv4 blacklist entry.
blacklist destination-ip destination-ip-address [ vpn-instance vpn-instance-name ] [ timeout minutes ]
undo blacklist destination-ip destination-ip-address [ vpn-instance vpn-instance-name ]
No destination IPv4 blacklist entries exist.
destination-ip-address Specifies an IPv4 address for the destination blacklist entry. Packets destined for this address will be dropped.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the blacklist belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. Do not specify this option if the blacklist is on the public network.
timeout minutes: Specifies the aging time for the destination blacklist entry, in the range of 1 to 10080 minutes. If you do not specify this option, the blacklist entry never ages out. You must delete it manually.
The undo blacklist destination-ip command deletes only manually added destination IPv4 blacklist entries. To delete dynamically added destination IPv4 blacklist entries, use the reset blacklist destination-ip command.
A destination blacklist entry with an aging time is not saved to the configuration file and cannot survive a reboot.
You can use the display blacklist destination-ip command to display all effective destination IPv4 blacklist entries.
# Add a destination blacklist entry for IPv4 address 192.168.1.2 and set the aging time to 20 minutes for the entry.
[Sysname] blacklist ip 192.168.1.2 timeout 20
blacklist enable
Use blacklist destination-ipv6 to add a destination IPv6 blacklist entry.
Use undo blacklist destination-ipv6 to delete a destination IPv6 blacklist entry.
blacklist destination-ipv6 destination-ipv6-address [ vpn-instance vpn-instance-name ] [ timeout minutes ]
undo blacklist destination-ipv6 destination-ipv6-address [ vpn-instance vpn-instance-name ]
No destination IPv6 blacklist entries exist.
destination-ipv6-address: Specifies an IPv6 address for the blacklist entry. Packets destined for this address will be dropped.
timeout minutes: Specifies the aging time for the blacklist entry, in the range of 1 to 10080 minutes. If you do not specify this option, the blacklist entry never ages out. You must delete it manually.
The undo blacklist destination-ipv6 command deletes only manually added destination IPv6 blacklist entries. To delete dynamically added destination IPv6 blacklist entries, use the reset blacklist ipv6 command.
You can use the display blacklist destination-ipv6 command to display all effective destination IPv6 blacklist entries.
# Add a destination blacklist entry for IPv6 address 2012::12:25 and set the aging time to 10 minutes for the entry.
[Sysname] blacklist ipv6 2012::12:25 timeout 10
blacklist enable
blacklist enable
Use blacklist enable to enable the blacklist feature on an interface.
Use undo blacklist enable to disable the blacklist feature on an interface.
blacklist enable
The blacklist feature is disabled on an interface.
Interface view
If the global blacklist feature is enabled, the blacklist feature is enabled on all interfaces. If the global blacklist feature is disabled, you can use this command to enable the blacklist feature on individual interfaces.
# Enable the blacklist feature on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] blacklist enable
blacklist ip
blacklist ipv6
Use blacklist global enable to enable the global blacklist feature.
Use undo blacklist global enable to disable the global blacklist feature.
The global blacklist feature is disabled.
If you enable the global blacklist feature, the blacklist feature is enabled on all interfaces.
# Enable the global blacklist feature.
[Sysname] blacklist global enable
blacklist enable
blacklist ip
blacklist ip
Use blacklist ip to add a source IPv4 blacklist entry.
Use undo blacklist ip to delete a source IPv4 blacklist entry.
blacklist ip source-ip-address [ vpn-instance vpn-instance-name ] [ ds-lite-peer ds-lite-peer-address ] [ timeout minutes ]
undo blacklist ip source-ip-address [ vpn-instance vpn-instance-name ] [ ds-lite-peer ds-lite-peer-address ]
No source IPv4 blacklist entries exist.
source-ip-address: Specifies an IPv4 address for the source blacklist entry. Packets sourced from this address will be dropped.
ds-lite-peer ds-lite-peer-address: Specifies the IPv6 address of the B4 element of the DS-Lite tunnel that transmits packets from the blacklisted IPv4 address.
timeout minutes: Specifies the aging time in minutes for the source blacklist entry, in the range of 1 to 10080. If you do not specify this option, the blacklist entry never ages out. You must delete it manually.
The undo blacklist ip command deletes only manually added source IPv4 blacklist entries. To delete dynamically added source IPv4 blacklist entries, use the reset blacklist ip command.
A source blacklist entry with an aging time is not saved to the configuration file and cannot survive a reboot.
You can use the display blacklist ip command to display all effective source IPv4 blacklist entries.
# Add a source blacklist entry for IPv4 address 192.168.1.2 and set the aging time to 20 minutes for the entry.
blacklist enable
blacklist ipv6
Use blacklist ipv6 to add a source IPv6 blacklist entry.
Use undo blacklist ipv6 to delete a source IPv6 blacklist entry.
blacklist ipv6 source-ipv6-address [ vpn-instance vpn-instance-name ] [ timeout minutes ]
undo blacklist ipv6 source-ipv6-address [ vpn-instance vpn-instance-name ]
No source IPv6 blacklist entries exist.
source-ipv6-address: Specifies an IPv6 address for the source blacklist entry. Packets sourced from this address will be dropped.
The undo blacklist ipv6 command deletes only manually added source IPv6 blacklist entries. To delete dynamically added source IPv6 blacklist entries, use the reset blacklist ipv6 command.
You can use the display blacklist ipv6 command to display all effective source IPv6 blacklist entries.
# Add a source blacklist entry for IPv6 address 2012::12:25 and set the aging time to 10 minutes for the entry.
blacklist enable
blacklist ip
Use blacklist logging enable to enable logging for the blacklist feature.
Use undo blacklist logging enable to disable logging for the blacklist feature.
Logging is disabled for the blacklist feature.
With logging enabled for the blacklist feature, the system outputs logs in the following situations:
·     A blacklist entry is manually added.
·     A blacklist entry is dynamically added by the scanning attack detection feature.
·     A blacklist entry is manually deleted.
·     A blacklist entry ages out.
A blacklist log records the following information:
·     Source IP address of the blacklist entry.
·     Remote IP address of the DS-Lite tunnel.
·     VPN instance name.
·     Reason for adding or deleting the blacklist entry.
·     Aging time for the blacklist entry.
This command enables the attack detection and prevention module to log blacklist events and send log messages to the information center.
The information center can output blacklist logs to any destinations except the console and the monitor terminal. If you configure the console or monitor terminal as an output destination, the output destination setting will not take effect.
To view blacklist logs stored on the device, use the display logbuffer command. Make sure you do not disable log output to the log buffer, which is enabled by default.
# Enable logging for the blacklist feature.
[Sysname] blacklist logging enable
# Add 192.168.1.2 to the blacklist. A log is output for the adding event.
[Sysname] blacklist ip 192.168.100.12
%Mar 13 03:47:49:736 2013 Sysname BLS/5/BLS_ENTRY_ADD:SrcIPAddr(1003)=192.168.100.12; DSLiteTunnelPeer(1040)=--; RcvVPNInstance(1041)=--; TTL(1051)=; Reason(1052)=Configuration.
# Delete 192.168.1.2 from the blacklist. A log is output for the deletion event.
[Sysname] undo blacklist ip 192.168.100.12
%Mar 13 03:49:52:737 2013 Sysname BLS/5/BLS_ENTRY_DEL:SrcIPAddr(1003)=192.168.100.12; DSLiteTunnelPeer(1040)=--; RcvVPNInstance(1041)=--; Reason(1052)=Configuration.
blacklist ip
blacklist ipv6
Use blacklist object-group to add an address object group to the blacklist.
Use undo blacklist object-group to restore the default.
blacklist object-group object-group-name
No address object group is on the blacklist.
object-group-name: Specifies an address object group by its name, a case-insensitive string of 1 to 63 characters.
This command must be used together with the address object group feature. For more information about address object groups, see object group configuration in Security Configuration Guide.
# Add address object group object-group1 to the blacklist.
[Sysname] blacklist object-group object-group1
Use client-verify dns enable to enable DNS client verification on an interface.
Use undo client-verify dns enable to disable DNS client verification on an interface.
DNS client verification is disabled on an interface.
Interface view
Enable DNS client verification on the interface that is connected to the external network. This feature protects internal DNS servers against DNS flood attacks.
For the DNS client verification to collaborate with DNS flood attack prevention, specify client-verify as the DNS flood attack prevention action. During collaboration, the device adds the victim IP address to the protected IP list and verifies the untrusted sources if it detects a DNS flood attack. You can use the display client-verify dns protected ip command to display the protected IP list for DNS client verification.
# Enable DNS client verification on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] client-verify dns enable
Use client-verify dns-reply enable to enable DNS response verification on an interface.
Use undo client-verify dns-reply enable to disable DNS response verification on an interface.
DNS response verification is disabled on an interface.
Interface view
Enable DNS response verification on the interface that is connected to the external network. This feature protects internal DNS clients against DNS response flood attacks.
For the DNS response verification to collaborate with DNS response flood attack prevention, specify client-verify as the DNS response flood attack prevention action. During collaboration, the device adds the victim IP address to the protected IP list and verifies the untrusted servers if it detects a DNS response flood attack. You can use the display client-verify dns-reply protected ip command to display the protected IP list for DNS response verification.
# Enable DNS response verification on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] client-verify dns-reply enable
Use client-verify http enable to enable HTTP client verification on an interface.
Use undo client-verify http enable to disable HTTP client verification on an interface.
HTTP client verification is disabled on an interface.
Interface view
Enable HTTP client verification on the interface that is connected to the external network. This feature protects internal servers against HTTP flood attacks.
For the HTTP client verification to collaborate with HTTP flood attack prevention, specify client-verify as the HTTP flood attack prevention action. During collaboration, the device adds the victim IP address to the protected IP list and verifies the untrusted sources if it detects an HTTP flood attack. You can use the display client-verify http protected ip command to display the protected IP list for HTTP client verification.
# Enable HTTP client verification on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] client-verify http enable
Use client-verify sip enable to enable SIP client verification on an interface.
Use undo client-verify sip enable to disable SIP client verification on an interface.
SIP client verification is disabled on an interface.
Interface view
Enable SIP client verification on the interface that is connected to the external network. This feature protects internal servers against SIP flood attacks.
For the SIP client verification to collaborate with SIP flood attack prevention, specify client-verify as the SIP flood attack prevention action. During collaboration, the device adds the victim IP address to the protected IP list and verifies the untrusted sources if it detects an SIP flood attack. You can use the display client-verify sip protected ip command to display the protected IP list for SIP client verification.
# Enable SIP client verification on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] client-verify sip enable
Use client-verify protected ip to specify an IPv4 address to be protected by the client verification feature.
Use undo client-verify protected ip to remove an IPv4 address protected by the client verification feature.
client-verify { dns | dns-reply | http | sip | tcp } protected ip destination-ip-address [ vpn-instance vpn-instance-name ] [ port port-number ]
undo client-verify { dns | dns-reply | http | sip | tcp } protected ip destination-ip-address [ vpn-instance vpn-instance-name ] [ port port-number ]
The client verification feature does not protect any IPv4 addresses.
dns: Specifies the DNS client verification feature.
dns-reply: Specifies the DNS response verification feature.
http: Specifies the HTTP client verification feature.
sip: Specifies the SIP client verification feature.
tcp: Specifies the TCP client verification feature.
destination-ip-address: Specifies the IPv4 address to be protected. All connection requests destined for this address are verified by the client verification feature.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the specified IPv4 address belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. Do not specify this option if the IPv4 address is on the public network.
port port-number: Specifies the port to be protected, in the range of 1 to 65535. If you do not specify this option, the verification feature protects ports for different protocols as follows:
·     DNS client or DNS response verification protects port 53.
·     HTTP client verification protects port 80.
·     SIP client verification protects port 5060.
·     TCP client verification protects all ports.
You can specify multiple protected IP addresses by using this command multiple times.
# Configure TCP client verification to protect IPv4 address 2.2.2.5 and port 25.
[Sysname] client-verify tcp protected ip 2.2.2.5 port 25
# Configure DNS client verification to protect IPv4 address 2.2.2.5 and port 50.
[Sysname] client-verify dns protected ip 2.2.2.5 port 50
Use client-verify protected ipv6 to specify an IPv6 address to be protected by the client verification feature.
Use undo client-verify protected ipv6 to remove an IPv6 address protected by the client verification feature.
client-verify { dns | dns-reply | http | sip | tcp } protected ipv6 destination-ipv6-address [ vpn-instance vpn-instance-name ] [ port port-number ]
undo client-verify { dns | dns-reply | http | sip | tcp } protected ipv6 destination-ipv6-address [ vpn-instance vpn-instance-name ] [ port port-number ]
The client verification feature does not protect any IPv6 addresses.
destination-ipv6-address: Specifies the IPv6 address to be protected. All connection requests destined for this address are verified by the client verification feature.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the specified IPv6 address belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. Do not specify this option if the IPv6 address is on the public network.
port port-number: Specifies the port to be protected, in the range of 1 to 65535. If you do not specify this option, the verification feature for different protocols protects ports as follows:
You can specify multiple protected IPv6 addresses by using this command multiple times.
# Configure TCP client verification to protect IPv6 address 2013::12 and port 23.
[Sysname] client-verify tcp protected ipv6 2013::12 port 23
# Configure HTTP client verification to protect IPv6 address 2013::12.
[Sysname] client-verify http protected ipv6 2013::12
Use client-verify tcp enable to enable TCP client verification on an interface.
Use undo client-verify tcp enable to disable TCP client verification on an interface.
client-verify tcp enable [ mode { syn-cookie | safe-reset } ]
TCP client verification is disabled on an interface.
Interface view
mode: Specifies a working mode for TCP client verification. If you do not specify this keyword, the SYN cookie mode is used.
syn-cookie: Specifies the SYN cookie mode. In this mode, bidirectional TCP proxy is enabled.
safe-reset: Specifies the safe reset mode. In this mode, unidirectional TCP proxy is enabled.
Enable TCP client verification on the interface that is connected to the external network. This feature protects internal servers against TCP flood attacks, including SYN flood attacks, SYN-ACK flood attacks, RST flood attacks, FIN flood attacks, and ACK flood attacks.
For TCP client verification to collaborate with TCP flood attack prevention, specify client-verify as the TCP flood attack prevention action. During collaboration, the device adds the victim IP address to the protected IP list and verifies the untrusted sources if it detects a TCP flood attack. You can use the display client-verify tcp protected ip command to display the protected IP list for TCP client verification.
TCP client verification supports the following modes:
·     Safe reset—Enables unidirectional TCP proxy for packets only from TCP connection initiators.
·     SYN cookie—Enables bidirectional TCP proxy for packets from both TCP clients and TCP servers.
Choose a TCP proxy mode according to the network scenarios. If packets from clients pass through the TCP proxy device, but packets from servers do not, specify the safe reset mode. If packets from clients and servers both pass through the TCP proxy device, specify either safe reset or SYN cookie. TCP proxy must be enabled on input interfaces. Otherwise, TCP connections cannot be established correctly.
# Enable TCP client verification in SYN cookie mode on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] client-verify tcp enable mode syn-cookie
Use display attack-defense flood statistics ip to display IPv4 flood attack detection and prevention statistics.
In standalone mode:
display attack-defense { ack-flood | dns-flood | dns-reply-flood | fin-flood | flood | http-flood | icmp-flood | rst-flood | sip-flood | syn-ack-flood | syn-flood | udp-flood } statistics ip [ ip-address [ vpn vpn-instance-name ] ] [ [ interface interface-type interface-number | local ] [ slot slot-number ] ] [ count ]
In IRF mode:
display attack-defense { ack-flood | dns-flood | dns-reply-flood | fin-flood | flood | http-flood | icmp-flood | rst-flood | sip-flood | syn-ack-flood | syn-flood | udp-flood } statistics ip [ ip-address [ vpn vpn-instance-name ] ] [ [ interface interface-type interface-number | local ] [ chassis chassis-number slot slot-number ] ] [ count ]
ack-flood: Specifies ACK flood attack.
dns-flood: Specifies DNS flood attack.
dns-reply-flood: Specifies DNS response flood attack.
fin-flood: Specifies FIN flood attack.
flood: Specifies all IPv4 flood attacks.
http-flood: Specifies HTTP flood attack.
icmp-flood: Specifies ICMP flood attack.
rst-flood: Specifies RST flood attack.
sip-flood: Specifies SIP flood attack.
syn-ack-flood: Specifies SYN-ACK flood attack.
syn-flood: Specifies SYN flood attack.
udp-flood: Specifies UDP flood attack.
ip-address: Specifies a protected IPv4 address. If you do not specify an IPv4 address, this command displays flood attack detection and prevention statistics for all protected IPv4 addresses.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the protected IPv4 address belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. Do not specify this option if the protected IPv4 address is on the public network.
local: Specifies the local device.
slot slot-number: Specifies a card by its slot number. This option is available only when you specify the local device or a global interface, such as a VLAN interface or tunnel interface. If you do not specify a card, this command displays IPv4 flood attack detection and prevention statistics for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. This option is available only when you specify the local device or a global interface, such as a VLAN interface or tunnel interface. If you do not specify a card, this command displays IPv4 flood attack detection and prevention statistics for all cards. (In IRF mode.)
count: Displays the number of flood attack prevention entries.
The device collects statistics about protected IP addresses for flood attack detection and prevention. The attackers' IP addresses are not recorded.
If you do not specify the interface or local parameter, this command displays IPv4 flood attack detection and prevention statistics for all interfaces and the local device.
# (In standalone mode.) Display all IPv4 flood attack detection and prevention statistics.
<Sysname> display attack-defense flood statistics ip
Slot 1:
Dest IP         VPN         Detected on  Detect type   State    PPS    Dropped
192.168.100.221 --          GE1/0/1      SYN-ACK-FLOOD Normal   1000   4294967295
192.168.11.5    --          GE1/0/2      ACK-FLOOD     Normal   1000   222222222
Src IP          VPN         Detected on  Detect type   State    PPS    Dropped
201.55.7.44     --          Local        DNS-FLOOD     Normal   1000   111111111
192.168.11.4    --          Local        ACK-FLOOD     Normal   1000   22222222
192.168.8.41    --          Local        SIP-FLOOD     Normal   1000   125623489
Slot 2:
201.55.1.10     --          GE2/0/1      ACK-FLOOD     Normal   1000   222222222
192.168.100.30  --          GE2/0/2      DNS-FLOOD     Normal   1000   333333333
192.168.100.66  --          Local        SYN-ACK-FLOOD Normal   1000   165467998
# (In standalone mode.) Display the number of flood attack prevention entries.
<Sysname> display attack-defense flood statistics ip count
Slot 1:
Totally 2 flood destination entries.
Totally 3 flood source entries.
Slot 2:
Totally 1 flood source entries.
Dest IP
Destination IPv4 address in attack packets.
Src IP
Source IPv4 address in attack packets.
VPN
MPLS L3VPN instance to which the protected IPv4 address belongs. If the protected IPv4 address is on the public network, this field displays hyphens (--).
Detected on
Where the attack is detected: the device (Local) or an interface.
Detect type
Type of the detected flood attack:
·     ACK flood.
·     DNS flood.
·     DNS reply flood.
·     FIN flood.
·     ICMP flood.
·     ICMPv6 flood.
·     SYN flood.
·     SYN-ACK flood.
·     UDP flood.
·     RST flood.
·     HTTP flood.
·     SIP flood.
Whether the interface or device is attacked:
·     Attacked—It is being attacked.
·     Normal—It is not attacked.
PPS
Number of packets sent to the IPv4 address per second.
Dropped
Number of attack packets dropped by the interface or the device.
Total number of IPv4 destination-based flood attack prevention entries.
Totally 2 flood source entries
Total number of IPv4 source-based flood attack prevention entries.
Use display attack-defense flood statistics ipv6 to display IPv6 flood attack detection and prevention statistics.
In standalone mode:
display attack-defense { ack-flood | dns-flood | dns-reply-flood | fin-flood | flood | http-flood | icmpv6-flood | rst-flood | sip-flood | syn-flood | syn-ack-flood | udp-flood } statistics ipv6 [ ipv6-address [ vpn vpn-instance-name ] ] [ [ interface interface-type interface-number | local ] [ slot slot-number ] ] [ count ]
In IRF mode:
display attack-defense { ack-flood | dns-flood | dns-reply-flood | fin-flood | flood | http-flood | icmpv6-flood | rst-flood | sip-flood | syn-flood | syn-ack-flood | udp-flood } statistics ipv6 [ ipv6-address [ vpn vpn-instance-name ] ] [ [ interface interface-type interface-number | local ] [ chassis chassis-number slot slot-number ] ] [ count ]
flood: Specifies all IPv6 flood attacks.
icmpv6-flood: Specifies ICMPv6 flood attack.
ipv6-address: Specifies a protected IPv6 address. If you do not specify an IPv6 address, this command displays flood attack detection and prevention statistics for all protected IPv6 addresses.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the protected IPv6 address belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. Do not specify this option if the protected IPv6 address is on the public network.
slot slot-number: Specifies a card by its slot number. This option is available only when you specify the local device or a global interface, such as a VLAN interface or tunnel interface. If you do not specify a card, this command displays IPv6 flood attack detection and prevention statistics for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. This option is available only when you specify the local device or a global interface, such as a VLAN interface or tunnel interface. If you do not specify a card, this command displays IPv6 flood attack detection and prevention statistics for all cards. (In IRF mode.)
If you do not specify the interface or local parameter, this command displays IPv6 flood attack detection and prevention statistics for all interfaces and the local device.
# (In standalone mode.) Display all IPv6 flood attack detection and prevention statistics.
<Sysname> display attack-defense flood statistics ipv6
Slot 1:
Dest IPv6       VPN         Detected on  Detect type   State    PPS    Dropped
1::2            --          GE1/0/1      DNS-FLOOD     Normal   1000   111111111
1::3            --          GE1/0/2      SYN-ACK-FLOOD Normal   1000   222222222
Src IPv6        VPN         Detected on  Detect type   State    PPS    Dropped
1::4            --          Local        ACK-FLOOD     Normal   1000   111111111
1::5            --          Local        SYN-FLOOD     Normal   1000   22222222
17::14          --          Local        SIP-FLOOD     Normal   1000   264549789
Slot 2:
1::2            --          GE2/0/1      SYN-FLOOD     Normal   1000   468792363
1::5            --          GE2/0/2      ACK-FLOOD     Normal   1000   452213396
1::6            --          Local        DNS-FLOOD     Normal   1000   12569985
<Sysname> display attack-defense flood statistics ipv6 count
Slot 1:
Totally 4 flood destination entries.
Slot 2:
Totally 3 flood destination entries.
Totally 2 flood source entries.
Dest IPv6
Destination IPv6 address in attack packets.
Src IPv6
Source IPv6 address in attack packets.
VPN
MPLS L3VPN instance to which the protected IPv6 address belongs. If the protected IPv6 address is on the public network, this field displays hyphens (--).
Detected on
Detect type
·     ACK flood.
·     DNS flood.
·     DNS reply flood.
·     FIN flood.
·     ICMPv6 flood.
·     SYN flood.
·     SYN-ACK flood.
·     UDP flood.
·     RST flood.
·     HTTP flood.
·     SIP flood.
PPS
Number of packets sent to the IPv6 address per second.
Dropped
Total number of IPv6 destination-based flood attack prevention entries.
Total number of IPv6 source-based flood attack prevention entries.
Use display attack-defense http-slow-attack statistics ip to display statistics about IPv4 HTTP slow attack detection and prevention.
In standalone mode:
display attack-defense http-slow-attack statistics ip [ ip-address [ vpn-instance vpn-instance-name ] ] [ [ interface { interface-type interface-number | interface-name } | local ] [ slot slot-number ] ] [ count ]
In IRF mode:
display attack-defense http-slow-attack statistics ip [ ip-address [ vpn-instance vpn-instance-name ] ] [ [ interface { interface-type interface-number | interface-name } | local ] [ chassis chassis-number slot slot-number ] ] [ count ]
ip-address: Specifies a destination IPv4 address.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the destination IPv4 address belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. Do not specify this option if the destination IPv4 address is on the public network.
interface { interface-type interface-number | interface-name }: Specifies an interface. The interface-type argument specifies the interface type. The interface-number argument specifies the interface number, and the interface-name argument specifies the interface name.
slot slot-number: Specifies a card by its slot number. This option is available only when you specify the local device or a global interface, such as a VLAN interface or tunnel interface. If you do not specify a card, this command displays statistics about IPv4 HTTP slow attack detection and prevention for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. This option is available only when you specify the local device or a global interface, such as a VLAN interface or tunnel interface. If you do not specify a card, this command displays statistics about IPv4 HTTP slow attack detection and prevention for all cards. (In IRF mode.)
count: Displays the number of IPv4 HTTP slow attack prevention entries for matching protected IPv4 addresses.
If you do not specify the interface or local parameter, this command displays statistics about IPv4 HTTP slow attack detection and prevention for all interfaces and the local device.
# (In standalone mode.) Display statistics about IPv4 HTTP slow attack detection and prevention.
<Sysname> display attack-defense http-slow-attack statistics ip
Slot 1:
IP address       VPN              Detected on           State
192.168.11.4     asd              Local                 Normal
201.55.7.44      --               GE1/0/1               Normal
Slot 2:
# (In IRF mode.) Display statistics about IPv4 HTTP slow attack detection and prevention.
Slot 1 in chassis 1:
slot 2 in chassis 2:
# (In standalone mode.) Display the number of IPv4 HTTP slow attack prevention entries for protected IPv4 addresses.
<Sysname> display attack-defense http-slow-attack statistics ip count
Slot 1:
Totally 2 HTTP slow attack entries.
Slot 2:
Totally 1 HTTP slow attack entries.
# (In IRF mode.) Display the number of IPv4 HTTP slow attack prevention entries for protected IPv4 addresses.
Slot 2 in chassis 2:
CPU 0 on slot 1:
CPU 1 on slot 2:
Totally 3 HTTP slow attack entries.
CPU 0 on slot 1 in chassis 1:
CPU 1 on slot 2 in chassis 2:
IP address
Destination IPv4 address.
VPN
MPLS L3VPN instance to which the destination IPv6 address belongs. If the destination IPv6 address is on the public network, this field displays hyphens (--).
Detected on
Totally 2 http slow attack entries
Total number of IPv4 HTTP slow attack prevention entries.
Use display attack-defense http-slow-attack statistics ipv6 to display statistics about IPv6 HTTP slow attack detection and prevention.
In standalone mode:
display attack-defense http-slow-attack statistics ipv6 [ ipv6-address [ vpn-instance vpn-instance-name ] ] [ [ interface { interface-type interface-number | interface-name } | local ] [ slot slot-number ] ] [ count ]
In IRF mode:
display attack-defense http-slow-attack statistics ipv6 [ ipv6-address [ vpn-instance vpn-instance-name ] ] [ [ interface { interface-type interface-number | interface-name } | local ] [ chassis chassis-number slot slot-number ] ] [ count ]
ipv6-address: Specifies a destination IPv6 address.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the destination IPv6 address belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. Do not specify this option if the destination IPv6 address is on the public network.
slot slot-number: Specifies a card by its slot number. This option is available only when you specify the local device or a global interface, such as a VLAN interface or tunnel interface. If you do not specify a card, this command displays statistics about IPv6 HTTP slow attack detection and prevention for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. This option is available only when you specify the local device or a global interface, such as a VLAN interface or tunnel interface. If you do not specify a card, this command displays statistics about IPv6 HTTP slow attack detection and prevention for all cards. (In IRF mode.)
count: Displays the number of IPv6 HTTP slow attack prevention entries for matching protected IPv6 addresses.
If you do not specify the interface or local parameter, this command displays statistics about IPv6 HTTP slow attack detection and prevention for all interfaces and the local device.
# (In standalone mode.) Display statistics about IPv6 HTTP slow attack detection and prevention.
<Sysname> display attack-defense http-slow-attack statistics ipv6
Slot 1:
IPv6 address     VPN              Detected on           State
1::5             asd              Local                 Normal
17::14           --               GE1/0/1               Normal
Slot 2:
# (In IRF mode.) Display statistics about IPv6 HTTP slow attack detection and prevention.
# (In standalone mode.) Display the number of IPv6 HTTP slow attack prevention entries for protected IPv6 addresses.
<Sysname> display attack-defense http-slow-attack statistics ipv6 count
Slot 1:
Totally 5 HTTP slow attack entries.
Slot 2:
# (In IRF mode.) Display the number of IPv6 HTTP slow attack prevention entries for protected IPv6 addresses.
IPv6 address
Destination IPv6 address.
VPN
Detected on
Whether the interface or local device is attacked:
Total number of IPv6 HTTP slow attack prevention entries.
Use display attack-defense policy to display attack defense policy configuration.
display attack-defense policy [ policy-name ]
policy-name: Specifies an attack defense policy by its name. The policy name is a case-insensitive string of 1 to 31 characters. Valid characters include uppercase and lowercase letters, digits, underscores (_), and hyphens (-). If no attack defense policy is specified, this command displays brief information about all attack defense policies.
This command output includes the following configuration information about an attack defense policy:
·     Whether attack detection is enabled.
·     Attack prevention actions.
·     Attack prevention trigger thresholds.
# Display the configuration of attack defense policy abc.
<Sysname> display attack-defense policy abc
          Attack-defense Policy Information
Policy name                        : abc
Applied list                       : Local
                                     GE1/0/1
                                     Vlan1
Exempt IPv4 ACL:                  : Not configured
Exempt IPv6 ACL:                  : vip
  Actions: CV-Client verify  BS-Block source  L-Logging  D-Drop  N-None
Signature attack defense configuration:
Signature name                     Defense      Level             Actions
Fragment                           Enabled      Info              L
Impossible                         Enabled      Info              L
Teardrop                           Disabled     Info              L
Tiny fragment                      Disabled     Info              L
IP option abnormal                 Disabled     Info              L
Smurf                              Disabled     Info              N
Traceroute                         Disabled     Medium            L,D
Ping of death                      Disabled     Low               L
Large ICMP                         Disabled     Medium            L,D
  Max length                       4000 bytes
Large ICMPv6                       Disabled     Low               L
TCP invalid flags                  Disabled     medium            L,D
TCP null flag                      Disabled     Low               L
TCP all flags                      Enabled      Info              L
TCP SYN-FIN flags                  Disabled     Info              L
TCP FIN only flag                  Enabled      Info              L
TCP Land                           Disabled     Info              L
Winnuke                            Disabled     Info              L
UDP Bomb                           Disabled     Info              L
UDP Snork                          Disabled     Info              L
UDP Fraggle                        Enabled      Info              L
IP option record route             Disabled     Info              L
IP option internet timestamp       Enabled      Info              L
IP option security                 Disabled     Info              L
IP option loose source routing     Enabled      Info              L
IP option stream ID                Disabled     Info              L
IP option strict source routing    Disabled     Info              L
IP option route alert              Disabled     Info              L
ICMP echo request                  Disabled     Info              L
ICMP echo reply                    Disabled     Info              L
ICMP source quench                 Disabled     Info              L
ICMP destination unreachable       Enabled      Info              L
ICMP redirect                      Enabled      Info              L
ICMP time exceeded                 Enabled      Info              L
ICMP parameter problem             Disabled     Info              L
ICMP timestamp request             Disabled     Info              L
ICMP timestamp reply               Disabled     Info              L
ICMP information request           Disabled     Info              L
ICMP information reply             Disabled     Medium            L,D
ICMP address mask request          Disabled     Medium            L,D
ICMP address mask reply            Disabled     Medium            L,D
ICMPv6 echo request                Enabled      Medium            L,D
ICMPv6 echo reply                  Disabled     Medium            L,D
ICMPv6 group membership query      Disabled     Medium            L,D
ICMPv6 group membership report     Disabled     Medium            L,D
ICMPv6 group membership reduction  Disabled     Medium            L,D
ICMPv6 destination unreachable     Enabled      Medium            L,D
ICMPv6 time exceeded               Enabled      Medium            L,D
ICMPv6 parameter problem           Disabled     Medium            L,D
ICMPv6 packet too big              Disabled     Medium            L,D
IPv6 extension header abnormal     Disabled     Info              L
IPv6 extension header exceeded     Disabled     Info              L
  Limit                            7
Scan attack defense configuration:
  Preset defense:
  Defense: Disabled
  User-defined defense:
    Port scan defense: Enabled
    Port scan defense threshold: 5000 packets
    IP sweep defense: Enabled
    IP sweep defense threshold: 8000 packets
    Period: 100s
    Actions: L
Flood type  Global dest/src thres(pps)  Global actions Service ports  Non-specific
DNS flood         1000/1000             -              53             Disabled
DNS reply flood   1000/1000             -              -              Disabled
HTTP flood        1000/1000             80             -              Disabled
SIP flood         1000/1000             50             -              Enabled
SYN flood         1000/1000             -              -              Disabled
ACK flood         1000/1000             -              -              Disabled
SYN-ACK flood     1000/1000             -              -              Disabled
RST flood         1000/1000             -              -              Disabled
FIN flood         1000/1000             -              -              Disabled
UDP flood         1000/1000             -              -              Disabled
ICMP flood        1000/1000             -              -              Disabled
ICMPv6 flood      1000/1000             -              -              Enabled
Flood attack defense for protected IP addresses:
 Address                 VPN instance Flood type    Thres(pps)  Actions Ports
 1::1                    --           FIN-FLOOD     10          L,D     -
 192.168.1.1             --           SYN-ACK-FLOOD 10          -       -
 1::1                    --           FIN-FLOOD     -           L       -
 2013:2013:2013:2013:    --           DNS-FLOOD     100         L,CV    53
 2013:2013:2013:2013
 10::13:                 A0123458589  SIP-FLOOD     100         L,CV    5060
HTTP slow attack defense configuration:
  Non-specific: Enabled
  Global threshold:
    Alert-number: 1200000
    Content-length: 100000000
    Payload-length: 1000
    Packet-number: 1000
  Global period: 1200 seconds
  Global action: L, BS (1000)
  Ports: 80, 8000 to 8001
Threshold: AN-Alert number, CL-Content length, PL-Payload length, PN-Packet number
HTTP slow attack defense configuration for protected IP addresses:
Address          VPN instance  Threshold (AN/CL/PL/PN)      Period  Actions  Ports
1111:2222:3333:4 abcdefghigkl 1200000,100000000,1000,1000  1000    L,BS(10) 80
444::8888        mnopqrstuvwx
                 yz
Table 5 Command output
Policy name
Name of the attack defense policy.
Applied list
Locations to which the attack defense policy is applied: interfaces and Local (Local indicates that the policy is applied to the device).
Exempt IPv4 ACL
IPv4 ACL used for attack detection exemption.
Exempt IPv6 ACL
IPv6 ACL used for attack detection exemption.
Actions
Attack prevention actions:
·     CV—Client verification.
·     BS—Blocking sources.
·     L—Logging.
·     D—Dropping packets.
·     N—No action.
Configuration information about single-packet attack detection and prevention.
Signature name
Type of the single-packet attack.
Defense
Level
Level of the single-packet attack, info, low, medium, or high.
Currently, no high-level single-packet attacks exist.
Actions
Prevention actions against the scanning attack:
·     L—Logging.
·     N—No action.
Large ICMPv6
Large ICMPv6 attack.
ICMPv6 echo request
ICMPv6 echo request attack.
ICMPv6 echo reply
ICMPv6 echo reply attack.
ICMPv6 group membership query attack.
ICMPv6 group membership report attack.
ICMPv6 group membership reduction attack.
ICMPv6 destination unreachable attack.
ICMPv6 time exceeded attack.
ICMPv6 parameter problem attack.
ICMPv6 packet too big attack.
Abnormal IPv6 extension header attack.
IPv6 extension header exceeded attack.
Limit
Upper limit of IPv6 extension headers.
Configuration information about scanning attack detection and prevention.
Preset defense
Configuration information about predefined scanning attack detection and prevention.
Defense
Whether scanning attack detection is enabled.
Level
Level of the scanning attack detection, low, medium, or high.
Configuration information about user-defined scanning attack detection and prevention.
Port scan defense
Status of port scan attack prevention, which can be Enabled or Disabled.
Threshold for triggering port scan attack prevention.
IP sweep defense
Status of IP sweep attack prevention, which can be Enabled or Disabled.
Threshold for triggering IP sweep attack prevention.
Period
Scanning attack detection cycle in seconds.
Actions
Scanning attack prevention actions:
·     L—Logging.
Flood attack defense configuration
Configuration information about flood attack detection and prevention.
Flood type
Type of the flood attack:
·     ACK flood.
·     DNS flood.
·     DNS reply flood.
·     FIN flood.
·     ICMP flood.
·     ICMPv6 flood.
·     SYN flood.
·     SYN-ACK flood.
·     UDP flood.
·     RST flood.
·     HTTP flood.
·     SIP flood.
Global thresholds for triggering the destination-based and source-based flood attack prevention. The default is 1000 pps.
Global actions
Global prevention actions against the flood attack:
·     L—Logging.
If no actions are configured, this field displays a hyphen (-).
Service ports
Ports that are protected against the flood attack. This field displays port numbers only for the DNS and HTTP flood attacks. For other flood attacks, this field displays a hyphen (-).
Non-specific
Whether the global flood attack detection is enabled.
Configuration of the IP address-specific flood attack detection and prevention.
Address
Protected IP address.
VPN instance
MPLS L3VPN instance to which the protected IP address belongs. This field is empty if no MPLS L3VPN instance is specified.
Thres(pps)
Threshold for triggering the flood attack prevention, in units of packets sent to the IP address per second. If no threshold is specified, this field displays 1000.
Actions
Flood attack prevention actions:
·     L—Logging.
·     N—No action.
Ports
Configuration information about the global HTTP slow attack detection and prevention.
Non-specific
Whether global HTTP slow attack detection is enabled.
Global threshold
Global threshold settings:
·     Alert-number—HTTP concurrent connection threshold. If this threshold is not specified, the field displays 5000.
·     Content-length—Threshold for the Content-Length field value. If this threshold is not specified, the field displays 10000.
·     Payload-length—Payload size threshold. If this threshold is not specified, the field displays 50.
·     Packet-number—Threshold of abnormal packets. If this threshold is not specified, the field displays 10.
Global period
Global HTTP slow attack detection period.
Global action
Global HTTP slow attack prevention actions:
·     L—Logging.
Ports
Ports protected by the global HTTP slow attack prevention. If protected no ports are specified, the field displays 80.
Configuration of the IP address-specific HTTP slow attack detection and prevention.
Address
VPN instance
VPN instance to which the protected IP address belongs. This field is empty if no VPN instance is specified.
Threshold parameter settings for IP address-specific HTTP slow attack detection. Full spellings for threshold parameters are as follows:
·     AN—Alert number.
·     CL—Content length.
·     PL—Payload length.
·     PN—Packet number.
If a parameter threshold is not specified, the global threshold for this parameter is displayed.
Period
IP address-specific HTTP slow attack detection period. If this period is not specified, the field displays the global detection period.
Actions
IP address-specific HTTP slow attack prevention actions:
·     L—Logging.
If no actions are specified, this field displays the global prevention actions.
Ports
Ports protected by the IP address-specific HTTP slow attack prevention. If no ports are specified, the field displays ports protected by the global HTTP slow attack prevention.
# Display brief information about all attack defense policies.
           Attack-defense Policy Brief Information
Policy Name                        Applied list
Atk-policy-1                       GigabitEthernet1/0/1
                                   GigabitEthernet1/0/2
P123                               GigabitEthernet1/0/2
p1                                 Local
p12                                Local
Table 6 Command output
Policy name
Applied list
display attack-defense policy ip
Use display attack-defense policy ip to display information about IPv4 addresses protected by flood attack detection and prevention.
In standalone mode:
display attack-defense policy policy-name { ack-flood | dns-flood | dns-reply-flood | fin-flood | flood | http-flood | icmp-flood | rst-flood | sip-flood | syn-ack-flood | syn-flood | udp-flood } ip [ ip-address [ vpn vpn-instance-name ] ] [ slot slot-number ] [ count ]
In IRF mode:
display attack-defense policy policy-name { ack-flood | dns-flood | dns-reply-flood | fin-flood | flood | http-flood | icmp-flood | rst-flood | sip-flood | syn-ack-flood | syn-flood | udp-flood } ip [ ip-address [ vpn vpn-instance-name ] ] [ chassis chassis-number slot slot-number ] [ count ]
ip-address: Specifies a protected IPv4 address. If you do not specify an IPv4 address, this command displays information about all protected IPv4 addresses.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the IPv4 address belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. Do not specify this option if the IPv4 address is on the public network.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays information about IPv4 addresses protected by flood attack detection and prevention for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays information about IPv4 addresses protected by flood attack detection and prevention for all cards. (In IRF mode.)
count: Displays the number of matching IPv4 addresses protected by flood attack detection and prevention.
# (In standalone mode.) Display information about all IPv4 addresses protected by flood attack detection and prevention in attack defense policy abc.
<Sysname> display attack-defense policy abc flood ip
Slot 1:
IP address      VPN instance     Type          Rate threshold(PPS) Dropped
123.123.123.123 --               SYN-ACK-FLOOD 100                 4294967295
201.55.7.45     --               ICMP-FLOOD    100                 10
192.168.11.5    --               DNS-FLOOD     23                  100
10.168.200.5    --               SIP-FLOOD     100                 102556
Slot 2:
123.123.123.123 --               SYN-ACK-FLOOD 100                 2543
201.55.7.45     --               ICMP-FLOOD    100                 122
192.168.11.5    --               DNS-FLOOD     23                  0
# (In standalone mode.) Display the number of IPv4 addresses protected by flood attack detection and prevention in attack defense policy abc.
<Sysname> display attack-defense policy abc flood ip count
Slot 1:
Totally 3 flood protected IP addresses.
Slot 2:
Totally 0 flood protected IP addresses.
Table 7 Command output
Total number of the IPv4 addresses protected by flood attack detection and prevention.
IP address
Protected IPv4 address.
VPN instance
MPLS L3VPN instance to which the protected IPv4 address belongs. This field is empty if the protected IPv4 address is on the public network.
Type of the flood attack.
Rate threshold(PPS)
Threshold for triggering the flood attack prevention, in units of packets sent to the IP address per second. If no rate threshold is set, this field displays 1000.
Dropped
Number of dropped attack packets. If the prevention action is logging, this field displays 0.
display attack-defense policy ipv6
Use display attack-defense policy ipv6 to display information about IPv6 addresses protected by flood attack detection and prevention.
In standalone mode:
display attack-defense policy policy-name { ack-flood | dns-flood | dns-reply-flood | fin-flood | flood | http-flood | icmpv6-flood | rst-flood | sip-flood | syn-ack-flood | syn-flood | udp-flood } ipv6 [ ipv6-address [ vpn vpn-instance-name ] ] [ slot slot-number ] ] [ count ]
In IRF mode:
display attack-defense policy policy-name { ack-flood | dns-flood | dns-reply-flood | fin-flood | flood | http-flood | icmpv6-flood | rst-flood | sip-flood | syn-ack-flood | syn-flood | udp-flood } ipv6 [ ipv6-address [ vpn vpn-instance-name ] ] [ chassis chassis-number slot slot-number ] [ count ]
ipv6-address: Specifies a protected IPv6 address. If you do not specify an IPv6 address, this command displays information about all protected IPv6 addresses.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the IPv6 address belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. Do not specify this option if the IPv6 address is on the public network.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays information about IPv6 addresses protected by flood attack detection and prevention for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays information about IPv6 addresses protected by flood attack detection and prevention for all cards. (In IRF mode.)
count: Displays the number of matching IPv6 addresses protected by flood attack detection and prevention.
# (In standalone mode.) Display information about all IPv6 addresses protected by flood attack detection and prevention in attack defense policy abc.
<Sysname> display attack-defense policy abc flood ipv6
Slot 1:
IPv6 address    VPN instance     Type          Rate threshold(PPS) Dropped
2013::127f      --               SYN-ACK-FLOOD 100                 4294967295
2::5            --               ACK-FLOOD     100                 10
1::5            --               ACK-FLOOD     100                 23
10::15          --               SIP-FLOOD     100                 1002
Slot 2:
2013::127f      --               SYN-ACK-FLOOD 100                 5465
2::5            --               ACK-FLOOD     100                 0
1::5            --               ACK-FLOOD     100                 122
# (In standalone mode.) Display the number of IPv6 addresses protected by flood attack detection and prevention in attack defense policy abc.
<Sysname> display attack-defense policy abc flood ipv6 count
Slot 1:
Slot 2:
Table 8 Command output
Total number of the IPv6 addresses protected by flood attack detection and prevention.
IPv6 address
Protected IPv6 address.
VPN instance
MPLS L3VPN instance to which the protected IPv6 address belongs. This field is empty if the protected IPv6 address is on the public network.
Rate threshold(PPS)
Threshold for triggering the flood attack prevention, in units of packets sent to the IPv6 address per second. If no rate threshold is set, this field displays 1000.
Dropped
display attack-defense scan attacker ip
Use display attack-defense scan attacker ip to display information about IPv4 scanning attackers.
In standalone mode:
display attack-defense scan attacker ip [ [ interface interface-type interface-number | local ] [ slot slot-number ] ] [ count ]
In IRF mode:
display attack-defense scan attacker ip [ [ interface interface-type interface-number | local ] [ chassis chassis-number slot slot-number ] ] [ count ]
slot slot-number: Specifies a card by its slot number. This option is available only when you specify the local device or a global interface, such as a VLAN interface or tunnel interface. If you do not specify a card, this command displays information about IPv4 scanning attackers for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. This option is available only when you specify the local device or a global interface, such as a VLAN interface or tunnel interface. If you do not specify a card, this command displays information about IPv4 scanning attackers for all cards. (In IRF mode.)
count: Displays the number of matching IPv4 scanning attackers.
If you do not specify any parameters, this command displays information about all IPv4 scanning attackers.
# (In standalone mode.) Display information about all IPv4 scanning attackers.
<Sysname> display attack-defense scan attacker ip
Slot 1:
IP addr(DslitePeer) VPN instance     Protocol      Detected on  Duration(min)
192.168.31.2(--)    --               TCP           GE1/0/2      1284
2.2.2.3(--)         --               UDP           GE1/0/2      23
192.68.11.2(--)     --               TCP           Local        782
2.2.2.1(--)         --               UDP           Local        23
Slot 2:
192.168.1.100(--)   --               TCP           GE2/0/1      1586
202.2.1.172(--)     --               UDP           GE2/0/1      258
192.168.1.200(--)   --               TCP           Local        1284
202.2.1.1(--)       --               UDP           Local        23
# (In standalone mode.) Display the number of IPv4 scanning attackers.
<Sysname> display attack-defense scan attacker ip count
Slot 1:
Totally 3 attackers.
Slot 2:
Totally 2 attackers.
Table 9 Command output
Totally 3 attackers
Total number of IPv4 scanning attackers.
IP addr(DslitePeer)
The IP addr field displays the IPv4 address of the attacker.
The DslitePeer field displays the DS-Lite tunnel source IPv6 address of the attacker in a DS-Lite network. In other situations, this field is empty.
VPN instance
MPLS L3VPN instance to which the attacker's IPv4 address belongs. If the IPv4 address is on the public network, this field displays hyphens (--).
Protocol
Name of the protocol.
Detected on
Duration(min)
The amount of time the attack lasts, in minutes.
scan detect
display attack-defense scan attacker ipv6
Use display attack-defense scan attacker ipv6 to display information about IPv6 scanning attackers.
In standalone mode:
display attack-defense scan attacker ipv6 [ [ interface interface-type interface-number | local ] [ slot slot-number ] ] [ count ]
In IRF mode:
display attack-defense scan attacker ipv6 [ [ interface interface-type interface-number | local ] [ chassis chassis-number slot slot-number ] ] [ count ]
slot slot-number: Specifies a card by its slot number. This option is available only when you specify the local device or a global interface, such as a VLAN interface or tunnel interface. If you do not specify a card, this command displays information about IPv6 scanning attackers for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. This option is available only when you specify the local device or a global interface, such as a VLAN interface or tunnel interface. If you do not specify a card, this command displays information about IPv6 scanning attackers for all cards. (In IRF mode.)
count: Displays the number of matching IPv6 scanning attackers.
If you do not specify any parameters, this command displays information about all IPv6 scanning attackers.
# (In standalone mode.) Display information about all IPv6 scanning attackers.
<Sysname> display attack-defense scan attacker ipv6
Slot 1:
IPv6 address       VPN instance     Protocol     Detected on      Duration(min)
2013::2            --               TCP          GE1/0/1          1234
1230::22           --               UDP          GE1/0/2          10
1002::20           --               TCP          Local            782
1230::1            --               UDP          Local            10
Slot 2:
2004::4            --               TCP         GE2/0/2           1122
1042::2            --               UDP         GE2/0/2           24
2004::1            --               TCP         Local             1122
1042::1            --               UDP         Local             24
# (In standalone mode.) Display the number of IPv6 scanning attackers.
<Sysname> display attack-defense scan attacker ipv6 count
Slot 1:
Slot 2:
Totally 0 attackers.
Table 10 Command output
Totally 3 attackers
Total number of IPv6 scanning attackers.
IPv6 address
IPv6 address of the attacker.
VPN instance
MPLS L3VPN instance to which the attacker IPv6 address belongs. This field is empty if the attacker IPv6 address is on the public network.
Protocol
Detected on
Duration(min)
scan detect
display attack-defense statistics interface
Use display attack-defense statistics interface to display attack detection and prevention statistics on an interface.
In standalone mode:
display attack-defense statistics interface interface-type interface-number [ slot slot-number ]
In IRF mode:
display attack-defense statistics interface interface-type interface-number [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. This option is available only when you specify a global interface, such as a VLAN interface or tunnel interface. If you do not specify a card, this commands displays attack detection and prevention statistics for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. This option is available only when you specify a global interface, such as a VLAN interface or tunnel interface. If you do not specify a card, this commands displays attack detection and prevention statistics for all cards. (In IRF mode.)
# (In standalone mode.) Display attack detection and prevention statistics on GigabitEthernet 1/0/1.
<Sysname> display attack-defense statistics interface gigabitethernet 1/0/1
Attack policy name: abc
Slot 1:
Scan attack defense statistics:
 AttackType                          AttackTimes Dropped
 Port scan                           2           23
 IP sweep                            3           33
 Distribute port scan                1           10
Flood attack defense statistics:
 SYN flood                           1           0
 ACK flood                           1           0
 SYN-ACK flood                       3           5000
 RST flood                           2           0
 FIN flood                           2           0
 UDP flood                           1           0
 ICMP flood                          1           0
 ICMPv6 flood                        1           0
 DNS flood                           1           0
 DNS reply flood                     1           0
 HTTP flood                          1           0
 SIP flood                           1           1000
Signature attack defense statistics:
 IP option record route              1           100
 IP option security                  2           0
 IP option stream ID                 3           0
 IP option internet timestamp        4           1
 IP option loose source routing      5           0
 IP option strict source routing     6           0
 IP option route alert               3           0
 Fragment                            1           0
 Impossible                          1           1
 Teardrop                            1           1
 Tiny fragment                       1           0
 IP options abnormal                 3           0
 Smurf                               1           0
 Ping of death                       1           0
 Traceroute                          1           0
 Large ICMP                          1           0
 TCP NULL flag                       1           0
 TCP all flags                       1           0
 TCP SYN-FIN flags                   1           0
 TCP FIN only flag                   1           0
 TCP invalid flag                    1           0
 TCP Land                            1           0
 Winnuke                             1           0
 UDP Bomb                            1           0
 Snork                               1           0
 Fraggle                             1           0
 Large ICMPv6                        1           0
 ICMP echo request                   1           0
 ICMP echo reply                     1           0
 ICMP source quench                  1           0
 ICMP destination unreachable        1           0
 ICMP redirect                       2           0
 ICMP time exceeded                  3           0
 ICMP parameter problem              4           0
 ICMP timestamp request              5           0
 ICMP timestamp reply                6           0
 ICMP information request            7           0
 ICMP information reply              4           0
 ICMP address mask request           2           0
 ICMP address mask reply             1           0
 ICMPv6 echo request                 1           1
 ICMPv6 echo reply                   1           1
 ICMPv6 group membership query       1           0
 ICMPv6 group membership report      1           0
 ICMPv6 group membership reduction   1           0
 ICMPv6 destination unreachable      1           0
 ICMPv6 time exceeded                1           0
 ICMPv6 parameter problem            1           0
 ICMPv6 packet too big               1           0
 IPv6 extension header abnormal      1           0
 IPv6 extension header exceeded      1           0
Slot 2:
 Port scan                           1           12
 IP sweep                            2           35
 Distribute port scan                5           48
 SYN flood                           1           0
 ACK flood                           1           0
 SYN-ACK flood                       3           4200
 RST flood                           2           0
 FIN flood                           2           0
 UDP flood                           1           0
 ICMP flood                          1           0
 ICMPv6 flood                        1           0
 DNS flood                           1           0
 DNS reply flood                     1           0
 HTTP flood                          1           0
 SIP flood                           1           1000
 Fragment                            1           0
 Impossible                          1           1
 Teardrop                            1           1
 Tiny fragment                       1           0
 Smurf                               3           0
 Ping of death                       1           0
 Traceroute                          1           2
 Large ICMP                          2           0
 TCP NULL flag                       1           0
 TCP all flags                       1           0
 TCP Land                            1           0
 Winnuke                             1           0
 UDP Bomb                            1           0
 Snork                               1           0
 Fraggle                             1           0
 Large ICMPv6                        1           0
 ICMP echo reply                     1           0
 ICMP redirect                       2           0
Table 11 Command output
AttackType
Type of the attack.
AttackTimes
Number of times that the attack occurred.
This command output displays only attacks that are detected.
Dropped
Number of dropped packets.
ICMPv6 flood
ICMPv6 flood attack. This field is not displayed when no ICMPv6 flood attack is detected.
Large ICMPv6
Large ICMPv6 attack. This field is not displayed when no large ICMPv6 attack is detected.
ICMPv6 echo request
ICMPv6 echo request attack. This field is not displayed when no ICMPv6 echo request attack is detected.
ICMPv6 echo reply
ICMPv6 echo reply attack. This field is not displayed when no ICMPv6 echo reply attack is detected.
ICMPv6 group membership query attack. This field is not displayed when no ICMPv6 group membership query attack is detected.
ICMPv6 group membership report attack. This field is not displayed when no ICMPv6 group membership report attack is detected.
ICMPv6 group membership reduction attack. This field is not displayed when no ICMPv6 group membership reduction attack is detected.
ICMPv6 destination unreachable attack. This field is not displayed when no ICMPv6 destination unreachable attack is detected.
ICMPv6 time exceeded attack. This field is not displayed when no ICMPv6 time exceeded attack is detected.
ICMPv6 parameter problem attack. This field is not displayed when no ICMPv6 parameter problem attack is detected.
ICMPv6 packet too big attack. This field is not displayed when no ICMPv6 packet too big attack is detected.
Abnormal IPv6 extension header attack. This field is not displayed when no abnormal IPv6 extension header attack is detected.
IPv6 extension header exceeded attack. This field is not displayed when no IPv6 extension header exceeded attack is detected.
reset attack-defense statistics interface
display attack-defense statistics local
Use display attack-defense statistics local to display attack detection and prevention statistics for the device.
In standalone mode:
display attack-defense statistics local [ slot slot-number ]
In IRF mode:
display attack-defense statistics local [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays attack detection and prevention statistics for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays attack detection and prevention statistics for all cards. (In IRF mode.)
# (In standalone mode.) Display attack detection and prevention statistics for the device.
<Sysname> display attack-defense statistics local
Slot 1:
 Port scan                           2           23
 IP sweep                            3           33
 SYN flood                           1           0
 ACK flood                           1           0
 RST flood                           2           0
 FIN flood                           2           0
 UDP flood                           1           0
 ICMP flood                          1           0
 ICMPv6 flood                        1           0
 DNS flood                           1           0
 DNS reply flood                     1           0
 HTTP flood                          1           0
 SIP flood                           1           1000
HTTP slow attack defense statistics:
HTTP slow attack                    1
 Fragment                            1           0
 Impossible                          1           1
 Teardrop                            1           1
 Tiny fragment                       1           0
 Smurf                               1           0
 Ping of death                       1           0
 Traceroute                          1           0
 Large ICMP                          1           0
 TCP NULL flag                       1           0
 TCP all flags                       1           0
 TCP Land                            1           0
 Winnuke                             1           0
 UDP Bomb                            1           0
 Snork                               1           0
 Fraggle                             1           0
 Large ICMPv6                        1           0
 ICMP echo reply                     1           0
 ICMP redirect                       2           0
Slot 2:
 Port scan                           4           46
 IP sweep                            2           28
 SYN flood                           1           0
 ACK flood                           1           0
 SYN-ACK flood                       2           4200
 RST flood                           2           0
 FIN flood                           2           20
 UDP flood                           1           0
 ICMP flood                          1           0
 ICMPv6 flood                        1           0
 DNS flood                           1           0
 DNS reply flood                     1           0
 HTTP flood                          1           0
 SIP flood                           1           1000
 IP option record route              2           230
 IP option strict source routing     2           0
 IP option route alert               3           12
 Fragment                            1           0
 Impossible                          1           1
 Teardrop                            1           1
 Tiny fragment                       1           0
 Smurf                               1           0
 Ping of death                       1           0
 Traceroute                          1           0
 Large ICMP                          1           0
 TCP NULL flag                       1           0
 TCP all flags                       1           0
 TCP Land                            1           0
 Winnuke                             1           0
 UDP Bomb                            1           0
 Snork                               1           0
 Fraggle                             1           0
 Large ICMPv6                        1           0
 ICMP echo reply                     1           0
 ICMP redirect                       2           3
Table 12 Command output
AttackType
Type of the attack.
AttackTimes
Dropped
ICMPv6 flood
Large ICMPv6
ICMPv6 echo request
ICMPv6 echo reply
reset attack-defense statistics local
display attack-defense top-attack-statistics
Use display attack-defense top-attack-statistics to display top 10 attack statistics.
display attack-defense top-attack-statistics { last-1-hour | last-24-hours | last-30-days } [ by-attacker | by-type | by-victim ]
last-1-hour: Specifies the most recent 1 hour.
last-24-hours: Specifies the most recent 24 hours.
last-30-days: Specifies the most recent 30 days.
by-attacker: Displays top 10 attack statistics by attacker.
by-type: Displays all attack statistics by attack type.
by-victim: Displays top 10 attack statistics by victim.
If you do not specify the by-attacker, by-type, or by-victim keyword, this command displays attack statistics by attacker, victim, attack type.
# Display top 10 attack statistics in the most recent 1 hour.
<Sysname> display attack-defense top-attack-statistics last-1-hour
Top attackers:
No.     VPN instance   Attacker IP         Attacks
1                      200.200.200.55      21
2                      200.200.200.21      16
3                      200.200.200.133     12
4                      200.200.200.19      10
5                      200.200.200.4       8
6                      200.200.200.155     8
7                      200.200.200.93      5
8                      200.200.200.67      3
9                      200.200.200.70      1
10                     200.200.200.23      1
Top victims:
No.     VPN instance   Victim IP            Attacks
1       --             201.200.200.12       21
2       --             201.200.200.32       16
3       --             201.200.200.14       12
4       --             201.200.200.251      12
5       --             201.200.200.10       7
6       --             201.200.200.77       6
7       --             201.200.200.96       2
8       --             201.200.200.22       2
9       --             201.200.200.154      2
10      --             201.200.200.18       1
Top attack types:
Attack type       Attacks
Scan              155
Syn               155
Table 13 Command output
Top attackers
Top 10 attack statistics by attacker.
No.
Rank on the list.
VPN instance
VPN instance to which the attacker or victim belongs. This field is empty if the attacker or victim belongs to the public network.
Attacks
Number of attacks.
Top victims
Top 10 attack statistics by victim.
Top attack types
Attack statistics by attack type.
attack-defense top-attack-statistics enable
display blacklist destination-ip
Use display blacklist destination-ip to display destination IPv4 blacklist entries.
In standalone mode:
display blacklist destination-ip [ destination-ip-address [ vpn-instance vpn-instance-name ] ] [ slot slot-number ] [ count ]
In IRF mode:
display blacklist destination-ip [ destination-ip-address [ vpn-instance vpn-instance-name ] ] [ chassis chassis-number slot slot-number ] [ count ]
destination-ip-address: Specifies a destination IPv4 address.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays destination IPv4 blacklist entries for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays destination IPv4 blacklist entries for all cards. (In IRF mode.)
count: Displays the number of matching destination IPv4 blacklist entries.
If you do not specify any parameters, this command displays all destination IPv4 blacklist entries.
# (In standalone mode.) Display all destination IPv4 blacklist entries.
<Sysname> display blacklist destination-ip
Slot 1:
IP address      VPN instance   Type    Aging (sec)  Dropped
192.168.11.5    --             Dynamic 10           353452
123.123.123.123 --             Dynamic 123          4294967295
201.55.7.45     --             Manual  Never        14478
Slot 2:
123.55.123.7    --             Dynamic 123       164698
201.55.7.33     --             Manual  Never     845969
# (In standalone mode.) Display the total number of destination IPv4 blacklist entries.
<Sysname> display blacklist destination-ip count
Slot 1:
Totally 3 blacklist entries.
Slot 2:
Totally 2 blacklist entries.
Table 14 Command output
IP address
IPv4 address in the destination blacklist entry.
VPN instance
MPLS L3VPN instance to which the blacklisted IPv4 address belongs. This field is empty if the blacklisted IPv4 address is on the public network.
Type of the destination IPv4 blacklist entry:
·     Dynamic—Dynamically generated.
·     Manual—Manually configured.
Aging (sec)
Remaining aging time of the destination IPv4 blacklist entry, in seconds. If no aging time is set for the entry, this field displays Never.
Dropped
Number of dropped packets that are destined for the IPv4 address.
Total number of destination IPv4 blacklist entries.
display blacklist destination-ipv6
Use display blacklist destination-ipv6 to display destination IPv6 blacklist entries.
In standalone mode:
display blacklist destination-ipv6 [ destination-ipv6-address [ vpn-instance vpn-instance-name ] ] [ slot slot-number ] [ count ]
In IRF mode:
display blacklist destination-ipv6 [ destination-ipv6-address [ vpn-instance vpn-instance-name ] ] [ chassis chassis-number slot slot-number ] [ count ]
destination-ipv6-address: Specifies a destination IPv6 address.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays destination IPv6 blacklist entries for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays destination IPv6 blacklist entries for all cards. (In IRF mode.)
count: Displays the number of matching destination IPv6 blacklist entries.
If you do not specify any parameters, this command displays all destination IPv6 blacklist entries.
# (In standalone mode.) Display all destination IPv6 blacklist entries.
<Sysname> display blacklist destination-ipv6
Slot 1:
IPv6 address         VPN instance      Type    Aging (sec)  Dropped
1::4                 --                Manual  Never        14478
1::5                 --                Dynamic 10           353452
2013:fe07:221a:4011: --                Dynamic 123          4294967295
2013:fe07:221a:4011
Slot 2:
1::3                 --                Manual  Never        74679
20::33               --                Dynamic 10           1697898
# (In standalone mode.) Display the total number of destination IPv6 blacklist entries.
<Sysname> display blacklist destination-ipv6 count
Slot 1:
Slot 2:
Table 15 Command output
IPv6 address
IPv6 address in the destination blacklist entry.
VPN instance
MPLS L3VPN instance to which the blacklisted IPv6 address belongs. This field is empty if the blacklisted IPv6 address is on the public network.
Type of the destination IPv6 blacklist entry:
Aging (sec)
Remaining aging time of the destination IPv6 blacklist entry, in seconds. If no aging time is set for the entry, this field displays Never.
Dropped
Number of dropped packets that are destined for the IPv6 address.
Total number of destination IPv6 blacklist entries.
display blacklist ip
Use display blacklist ip to display source IPv4 blacklist entries.
In standalone mode:
display blacklist ip [ source-ip-address [ vpn-instance vpn-instance-name ] [ ds-lite-peer ds-lite-peer-address ] ] [ slot slot-number  ] [ count ]
In IRF mode:
display blacklist ip [ source-ip-address [ vpn-instance vpn-instance-name ] [ ds-lite-peer ds-lite-peer-address ] ] [ chassis chassis-number slot slot-number ] [ count ]
source-ip-address: Specifies a source IPv4 address.
ds-lite-peer ds-lite-peer-address: Specifies the IPv6 address of the B4 element of the DS-Lite tunnel that transmits packets from the blacklisted IPv4 address.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays source IPv4 blacklist entries for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays source IPv4 blacklist entries for all cards. (In IRF mode.)
count: Displays the number of matching source IPv4 blacklist entries.
If you do not specify any parameters, this command displays all source IPv4 blacklist entries.
# (In standalone mode.) Display all source IPv4 blacklist entries.
<Sysname> display blacklist ip
Slot 1:
IP address      VPN instance   DS-Lite tunnel peer  Type    TTL(sec) Dropped
192.168.11.5    --             --                   Dynamic 10       353452
123.123.123.123 --             2013::fe07:221a:4011 Dynamic 123      4294967295
201.55.7.45     --             2013::1              Manual  Never    14478
Slot 2:
123.55.123.7    --             --                   Dynamic 123      164698
201.55.7.33     --             --                   Manual  Never    845969
# (In standalone mode.) Display the total number of source IPv4 blacklist entries.
<Sysname> display blacklist ip count
Slot 1:
Slot 2:
Table 16 Command output
IP address
IPv4 address in the source blacklist entry.
VPN instance
DS-Lite tunnel peer
IPv6 address of the DS-Lite tunnel peer.
If the device is the AFTR of a DS-Lite tunnel, this field displays the IPv6 address of the B4 element from which the packet comes.
In other situations, this field displays hyphens (--).
Type of the source IPv4 blacklist entry:
TTL(sec)
Remaining aging time of the source IPv4 blacklist entry, in seconds. If no aging time is set for the entry, this field displays Never.
Total number of source IPv4 blacklist entries.
blacklist ip
display blacklist ipv6
Use display blacklist ipv6 to display source IPv6 blacklist entries.
In standalone mode:
display blacklist ipv6 [ source-ipv6-address [ vpn-instance vpn-instance-name ] ] [ slot slot-number ] [ count ]
In IRF mode:
display blacklist ipv6 [ source-ipv6-address [ vpn-instance vpn-instance-name ] ] [ chassis chassis-number slot slot-number ] [ count ]
source-ipv6-address: Specifies a source IPv6 address.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays source IPv6 blacklist entries for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays source IPv6 blacklist entries for all cards. (In IRF mode.)
count: Displays the number of matching source IPv6 blacklist entries.
If you do not specify any parameters, this command displays all source IPv6 blacklist entries.
# (In standalone mode.) Display all source IPv6 blacklist entries.
<Sysname> display blacklist ipv6
Slot 1:
IPv6 address         VPN instance      Type    TTL(sec) Dropped
2013:fe07:221a:4011
Slot 2:
# (In standalone mode.) Display the total number of source IPv6 blacklist entries.
<Sysname> display blacklist ipv6 slot 1 count
Slot 1:
Slot 2:
Table 17 Command output
IPv6 address
IPv6 address in the source blacklist entry.
VPN instance
Type of the source IPv6 blacklist entry:
TTL(sec)
Remaining aging time of the source IPv6 blacklist entry, in seconds. If no aging time is set for the entry, this field displays Never.
Total number of source IPv6 blacklist entries.
blacklist ipv6
display client-verify protected ip
Use display client-verify protected ip to display protected IPv4 addresses for client verification.
In standalone mode:
display client-verify { dns | dns-reply | http | sip | tcp } protected ip [ ip-address [ vpn vpn-instance-name ] ] [ port port-number ] [ slot slot-number ] [ count ]
In IRF mode:
display client-verify { dns | dns-reply | http | sip | tcp } protected ip [ ip-address [ vpn vpn-instance-name ] ] [ port port-number ] [ chassis chassis-number slot slot-number ] [ count ]
dns: Specifies the DNS client verification feature.
dns-reply: Specifies the DNS response verification feature.
http: Specifies the HTTP client verification feature.
sip: Specifies the SIP client verification feature.
tcp: Specifies the TCP client verification feature.
ip-address: Specifies a protected IPv4 address. If you do not specify an IPv4 address, this command displays all protected IPv4 addresses.
port port-number: Specifies a protected port in the range of 1 to 65535. If you do not specify a port, this command displays protected IPv4 addresses with default ports. The default port for DNS client verification is port 53, the default port for HTTP client verification is port 80, and the default port for TCP client verification is all ports.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays protected IPv4 addresses for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays protected IPv4 addresses for all cards. (In IRF mode.)
count: Displays the number of matching protected IPv4 addresses.
# (In standalone mode.) Display the protected IPv4 addresses for TCP client verification.
<Sysname> display client-verify tcp protected ip
Slot 1:
IP address           VPN instance     Port  Type    Requested   Trusted
192.168.11.5         --               23    Dynamic 353452      555
123.123.123.123      --               65535 Dynamic 4294967295  15151
201.55.7.45          --               10    Manual  15000       222
Slot 2:
192.168.11.5         --               23    Dynamic 46790       78578
201.55.7.45          --               10    Dynamic 2368        7237
123.123.123.123      --               65535 Manual  24587       1385
# (In standalone mode.) Display the number of protected IPv4 addresses for TCP client verification.
<Sysname> display client-verify tcp protected ip count
Slot 1:
Totally 3 protected IP addresses.
Slot 2:
Totally 0 protected IP addresses.
Table 18 Command output
Total number of protected IPv4 addresses.
IP address
VPN instance
Port
Port protected by TCP client verification. If TCP client verification protects all ports, this field displays any.
Type of the protected IPv4 address, Manual or Dynamic.
Requested
Number of packets destined for the protected IPv4 address.
Trusted
Number of packets that passed the client verification.
display client-verify protected ipv6
Use display client-verify protected ipv6 to display protected IPv6 addresses for client verification.
In standalone mode:
display client-verify { dns | dns-reply | http | sip | tcp } protected ipv6 [ ipv6-address [ vpn vpn-instance-name ] ] [ port port-number ] [ slot slot-number ] [ count ]
In IRF mode:
display client-verify { dns | dns-reply | http | sip | tcp } protected ipv6 [ ipv6-address [ vpn vpn-instance-name ] ] [ port port-number ] [ chassis chassis-number slot slot-number ] [ count ]
ipv6-address: Specifies a protected IPv6 address. If you do not specify an IPv6 address, this command displays all protected IPv6 addresses.
port port-number: Specifies a protected port in the range of 1 to 65535. If you do not specify a port, this command displays protected IPv6 addresses with default ports. The default port for DNS client verification is port 53, the default port for HTTP client verification is port 80, and the default port for TCP client verification is all ports.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays protected IPv6 addresses for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays protected IPv6 addresses for all cards. (In IRF mode.)
count: Displays the number of matching protected IPv6 addresses.
# (In standalone mode.) Display the protected IPv6 addresses for TCP client verification.
<Sysname> display client-verify tcp protected ipv6
Slot 1:
IPv6 address         VPN instance     Port  Type    Requested   Trusted
1:2:3:4:5:6:7:8      --               100   Manual  14478       5501
1023::1123           --               65535 Dynamic 4294967295  15151
Slot 2:
1:2:3:4:5:6:7:8      --               100   Manual  4568        8798
1023::1123           --               65535 Dynamic 15969       4679
# (In standalone mode.) Display the number of protected IPv6 addresses for TCP client verification.
Slot 1:
Totally 3 protected IPv6 addresses.
Slot 2:
Totally 0 protected IPv6 addresses.
Table 19 Command output
Total number of protected IPv6 addresses.
IPv6 address
VPN instance
Port
Type of the protected IPv6 address, Manual or Dynamic.
Requested
Number of packets destined for the protected IPv6 address.
Trusted
display client-verify trusted ip
Use display client-verify trusted ip to display trusted IPv4 addresses for client verification.
In standalone mode:
display client-verify { dns | dns-reply | http | sip | tcp } trusted ip [ ip-address [ vpn vpn-instance-name ] ] [ slot slot-number ] [ count ]
In IRF mode:
display client-verify { dns | dns-reply | http | sip | tcp } trusted ip [ ip-address [ vpn vpn-instance-name ] ] [ chassis chassis-number slot slot-number ] [ count ]
ip-address: Specifies a trusted IPv4 address. If you do not specify an IPv4 address, this command displays all trusted IPv4 addresses.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the trusted IPv4 address belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. Do not specify this option if the trusted IPv4 address is on the public network.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays trusted IPv4 addresses for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays trusted IPv4 addresses for all cards. (In IRF mode.)
count: Displays the number of matching trusted IPv4 addresses.
# (In standalone mode.) Display the trusted IPv4 addresses for DNS client verification.
<Sysname> display client-verify dns trusted ip
Slot 1:
IP address      VPN instance        DS-Lite tunnel peer    TTL(sec)
11.1.1.2        --                  --                     3600
123.123.123.123 --                  --                     3550
Slot 2:
11.1.1.3        --                  --                     1200
# (In standalone mode.) Display the number of trusted IPv4 addresses for DNS client verification.
<Sysname> display client-verify dns trusted ip count
Slot 1:
Totally 3 trusted IP addresses.
Slot 2:
Totally 0 trusted IP addresses.
Table 20 Command output
Total number of trusted IPv4 addresses.
IP address
Trusted IPv4 address.
VPN instance
MPLS L3VPN instance to which the trusted IPv4 address belongs. This field is empty if the trusted IPv4 address is on the public network.
DS-Lite tunnel peer
TTL(sec)
Remaining aging time of the trusted IPv4 address, in seconds.
display client-verify trusted ipv6
Use display client-verify trusted ipv6 to display trusted IPv6 addresses for client verification.
In standalone mode:
display client-verify { dns | dns-reply | http | sip | tcp } trusted ipv6 [ ipv6-address [ vpn vpn-instance-name ] ] [ slot slot-number ] ] [ count ]
In IRF mode:
display client-verify { dns | dns-reply | http | sip | tcp } trusted ipv6 [ ipv6-address [ vpn vpn-instance-name ] ] [ chassis chassis-number slot slot-number ] [ count ]
ipv6-address: Specifies a trusted IPv6 address. If you do not specify an IPv6 address, this command displays all trusted IPv6 addresses.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the trusted IPv6 address belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. Do not specify this option if the trusted IPv6 address is on the public network.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays trusted IPv6 addresses for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays trusted IPv6 addresses for all cards. (In IRF mode.)
count: Displays the number of matching trusted IPv6 addresses.
# (In standalone mode.) Display the trusted IPv6 addresses for DNS client verification.
<Sysname> display client-verify dns trusted ipv6
Slot 1:
IPv6 address                            VPN instance     TTL(sec)
1::3                                    --               1643
1234::1234                              --               1234
Slot 2:
1::3                                    --               1643
# (In standalone mode.) Display the number of trusted IPv6 list for DNS client verification.
<Sysname> display client-verify dns trusted ipv6 count
Slot 1:
Totally 3 trusted IPv6 addresses.
Slot 2:
Totally 0 trusted IPv6 addresses.
Table 21 Command output
Number of trusted IPv6 addresses.
IPv6 address
Trusted IPv6 address.
VPN instance
MPLS L3VPN instance to which the trusted IPv6 address belongs. This field is empty if the trusted IPv6 address is on the public network.
TTL(sec)
Remaining aging time of the trusted IPv6 address, in seconds.
display whitelist object-group
Use display whitelist object-group to display statistics about packets that match the address object groups on the whitelist.
In standalone mode:
display whitelist object-group [ object-group-name ] [ slot slot-number ]
In IRF mode:
display whitelist object-group [ object-group-name ] [ chassis chassis-number slot slot-number ]
object-group-name: Specifies an address object group by its name, a case-insensitive string of 1 to 63 characters. If you do not specify an address object group, this command displays statistics about packets that match all address object groups on the whitelist.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays statistics for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays statistics for all cards. (In IRF mode.)
If you do not specify any parameters, this command displays statistics about packets that match all address object groups on the whitelist.
# (In standalone mode.) Display statistics about packets that match all address object groups on the whitelist.
<Sysname> display whitelist object-group
Slot 1:
Object group               Type          Matching Packets
objgrp-1                   IPv4          15696
objgrp-2                   IPv4          855864455
Slot 2:
objgrp-1                   IPv4          353452
Table 22 Command output
Object group
Name of the address object group.
Type of the address object group.
Matching packets
Number of packets that match the address object group.
reset whitelist statistics
dns-flood action
Use dns-flood action to specify global actions against DNS flood attacks.
Use undo dns-flood action to restore the default.
dns-flood action { client-verify | drop | logging } *
No global action is specified for DNS flood attacks.
Attack defense policy view
client-verify: Adds the victim IP addresses to the protected IP list for DNS client verification. If DNS client verification is enabled, the device provides proxy services for protected servers. This keyword does not take effect on source-based flood attack prevention.
drop: Drops subsequent DNS packets destined for the victim IP addresses in destination-based flood attack prevention, or drops subsequent DNS packets originating from the attacker IP addresses in source-based flood attack prevention.
logging: Enables logging for DNS flood attack events. The log messages will be sent to the log system.
For the DNS flood attack detection to collaborate with the DNS client verification, make sure the client-verify keyword is specified and the DNS client verification is enabled. To enable DNS client verification, use the client-verify dns enable command.
The logging keyword enables the attack detection and prevention module to log DNS flood attack events and send log messages to the information center.
With the information center, you can set log message filtering and output rules, including output destinations.
The information center can output DNS flood attack logs to any destinations except the console and the monitor terminal. If you configure the console or monitor terminal as an output destination, the output destination setting will not take effect.
To view DNS flood attack logs stored on the device, use the display logbuffer command. Make sure you do not disable log output to the log buffer, which is enabled by default.
For more information about configuring the information center, see Network Management and Monitoring Configuration Guide.
# Specify drop as the global action against DNS flood attacks in attack defense policy atk-policy-1.
[Sysname] attack-defense policy atk-policy-1
[Sysname-attack-defense-policy-atk-policy-1] dns-flood action drop
dns-flood detect
dns-flood detect non-specific
dns-flood port
dns-flood source-threshold
dns-flood threshold
dns-flood detect
Use dns-flood detect to configure IP address-specific DNS flood attack detection.
Use undo dns-flood detect to remove the IP address-specific DNS flood attack detection configuration.
dns-flood detect { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] [ port port-list ] [ threshold threshold-value ] [ action { { client-verify | drop | logging } * | none } ]
undo dns-flood detect { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
IP address-specific DNS flood attack detection is not configured.
ip ipv4-address: Specifies the IPv4 address to be protected. The ip-address argument cannot be 255.255.255.255 or 0.0.0.0.
ipv6 ipv6-address: Specifies the IPv6 address to be protected. The IPv6 address cannot be a multicast address or ::.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the protected IP address belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. Do not specify this option if the protected IP address is on the public network.
port port-list: Specifies a space-separated list of up to 24 port number items. Each item specifies a port by its port number or a range of ports in the form of start-port-number to end-port-number. The end-port-number cannot be smaller than the start-port-number. If you do not specify this option, the global ports apply.
threshold threshold-value: Specifies the maximum receiving rate in pps for DNS packets that are destined for the protected IP address. The value range is 1 to 1000000.
action: Specifies the actions against a detected DNS flood attack. If no action is specified, the global actions set by the dns-flood action command apply.
drop: Drops subsequent DNS packets destined for the protected IP address.
none: Takes no action.
With DNS flood attack detection configured for an IP address, the device is in attack detection state. When the receiving rate of DNS packets destined for the IP address keeps reaching or exceeding the threshold, the device enters prevention state and takes the specified actions. When the rate drops below the silence threshold (three-fourths of the threshold), the device returns to the attack detection state.
You can configure DNS flood attack detection for multiple IP addresses in one attack defense policy.
# Configure DNS flood attack detection for 192.168.1.2 in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] dns-flood detect ip 192.168.1.2 port 53 threshold 2000
dns-flood action
dns-flood port
dns-flood threshold
Use dns-flood detect non-specific to enable global DNS flood attack detection.
Use undo dns-flood detect non-specific to disable global DNS flood attack detection.
Global DNS flood attack detection is disabled.
The device supports the following DNS flood attack prevention types:
·     Source-based DNS flood attack prevention—Monitors the receiving rate of DNS packets on a per-source IP basis.
·     Destination-based DNS flood attack prevention—Monitors the receiving rate of DNS packets on a per-destination IP basis.
The global DNS flood attack detection applies to all IP addresses except for those specified by the dns-flood detect command. The global detection uses the global trigger threshold set by the dns-flood threshold or dns-flood source-threshold command and global actions specified by the dns-flood action command.
# Enable global DNS flood attack detection in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] dns-flood detect non-specific
dns-flood action
dns-flood detect
dns-flood port
dns-flood threshold
dns-flood port
Use dns-flood port to specify the global ports to be protected against DNS flood attacks.
Use undo dns-flood port to restore the default.
dns-flood port port-list
undo dns-flood port
The global DNS flood attack prevention protects port 53.
port-list: Specifies a space-separated list of up to 32 port number items. Each item specifies a port by its port number or a range of ports in the form of start-port-number to end-port-number. The end-port-number cannot be smaller than the start-port-number.
The device detects only DNS packets destined for the specified ports.
The global ports apply to global DNS flood attack detection and IP address-specific DNS flood attack detection with no port specified.
# Specify the ports 53 and 61000 as the global ports to be protected against DNS flood attacks in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] dns-flood port 53 61000
dns-flood action
dns-flood detect
dns-flood threshold
dns-flood threshold
Use dns-flood threshold to set the global threshold for triggering destination-based DNS flood attack prevention.
Use undo dns-flood threshold to restore the default.
dns-flood threshold threshold-value
The global threshold is 10000 for triggering destination-based DNS flood attack prevention.
threshold-value: Specifies the maximum receiving rate in pps for DNS packets that are destined for an IP address. The value range is 0 to 1000000. If you set the threshold value to 0, the destination-based DNS flood attack prevention is disabled.
With global DNS flood attack detection configured, the device is in attack detection state. When the receiving rate of DNS packets destined for an IP address keeps reaching or exceeding the threshold, the device enters prevention state and takes the specified actions. When the rate drops below the silence threshold (three-fourths of the threshold), the device returns to the attack detection state.
The global threshold applies to global DNS flood attack detection. Adjust the threshold according to the application scenarios.
·     If the number of DNS packets sent to a protected DNS server is normally large, set a high threshold. A low threshold might affect the server services.
·     For a network that is unstable or susceptible to attacks, set a low threshold.
# Set the global threshold to 100 for triggering destination-based DNS flood attack prevention in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] dns-flood threshold 100
dns-flood action
dns-flood detect
dns-flood port
Use dns-flood source-threshold to set the global threshold for triggering source-based DNS flood attack prevention.
Use undo dns-flood source-threshold to restore the default.
dns-flood source-threshold threshold-value
The global threshold is 10000 for triggering source-based DNS flood attack prevention.
threshold-value: Specifies the maximum receiving rate in pps for DNS packets that originate from an IP address. The value range is 0 to 1000000. If you set the threshold value to 0, the source-based DNS flood attack prevention is disabled.
With global DNS flood attack detection configured, the device is in attack detection state. When the receiving rate of DNS packets originating from an IP address keeps reaching or exceeding the threshold, the device enters prevention state and takes the specified actions. When the rate drops below the silence threshold (three-fourths of the threshold), the device returns to the attack detection state.
# Set the global threshold to 100 for triggering source-based DNS flood attack prevention in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] dns-flood source-threshold 100
dns-flood action
dns-flood detect ip
dns-flood port
dns-reply-flood action
Use dns-reply-flood action to specify global actions against DNS response flood attacks.
Use undo dns-reply-flood action to restore the default.
dns-reply-flood action { client-verify | drop | logging } *
No global action is specified for DNS response flood attacks.
client-verify: Adds the victim IP addresses to the protected IP list for DNS response verification. If DNS response verification is enabled, the device provides proxy services for protected clients. This keyword does not take effect on source-based flood attack prevention.
drop: Drops subsequent DNS responses destined for the victim IP addresses in destination-based flood attack prevention, or drops subsequent DNS responses originating from the attacker IP addresses in source-based flood attack prevention.
logging: Enables logging for DNS response flood attack events. The log messages will be sent to the log system.
For the DNS response flood attack detection to collaborate with the DNS response verification, make sure the client-verify keyword is specified and the DNS response verification is enabled. To enable DNS response verification, use the client-verify dns-reply enable command.
The logging keyword enables the attack detection and prevention module to log DNS response flood attack events and send log messages to the information center.
The information center can output DNS response flood attack logs to any destinations except the console and the monitor terminal. If you configure the console or monitor terminal as an output destination, the output destination setting will not take effect.
To view DNS response flood attack logs stored on the device, use the display logbuffer command. Make sure you do not disable log output to the log buffer, which is enabled by default.
# Specify drop as the global action against DNS response flood attacks in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] dns-reply-flood action drop
dns-reply-flood detect
dns-reply-flood detect non-specific
dns-reply-flood source-threshold
dns-reply-flood threshold
Use dns-reply-flood detect to configure IP address-specific DNS response flood attack detection.
Use undo dns-reply-flood detect to remove the IP address-specific DNS response flood attack detection configuration.
dns-reply-flood detect { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] [ port port-list ] [ threshold threshold-value ] [ action { { client-verify | drop | logging } * | none } ]
undo dns-reply-flood detect { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
IP address-specific DNS response flood attack detection is not configured.
threshold threshold-value: Specifies the maximum receiving rate in pps for DNS responses that are destined for the protected IP address. The value range is 1 to 1000000, and the default value is 1000.
action: Specifies the actions against a detected DNS response flood attack.
drop: Drops subsequent DNS responses destined for the protected IP address.
You can configure DNS response flood attack detection for multiple IP addresses in one attack defense policy.
With DNS response flood attack detection configured for an IP address, the device is in attack detection state. When the receiving rate of DNS responses destined for the IP address keeps reaching or exceeding the threshold, the device enters prevention state and takes the specified actions. When the rate drops below the silence threshold (three-fourths of the threshold), the device returns to the attack detection state.
# Configure DNS response flood attack detection for 192.168.1.2 in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] dns-reply-flood detect ip 192.168.1.2 port 53 threshold 2000
dns-reply-flood port
Use dns-reply-flood detect non-specific to enable global DNS response flood attack detection.
Use undo dns-reply-flood detect non-specific to disable global DNS response flood attack detection.
Global DNS response flood attack detection is disabled.
The device supports the following DNS response flood attack prevention types:
·     Source-based DNS response flood attack prevention—Monitors the receiving rate of DNS responses on a per-source IP basis.
·     Destination-based DNS response flood attack prevention—Monitors the receiving rate of DNS responses on a per-destination IP basis.
The global DNS response flood attack detection applies to all IP addresses except for those specified by the dns-reply-flood detect or dns-reply-flood source-threshold command. The global detection uses the global trigger threshold set by the dns-reply-flood threshold command and global actions specified by the dns-flood action command.
# Enable global DNS response flood attack detection in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] dns-reply-flood detect non-specific
Use dns-reply-flood port to specify the global ports to be protected against DNS response flood attacks.
Use undo dns-reply-flood port to restore the default.
dns-reply-flood port port-list
The global DNS response flood attack prevention protects port 53.
The device detects only DNS response packets destined for the specified ports.
The global ports apply to global DNS response flood attack detection and IP address-specific DNS response flood attack detection with no port specified.
# Specify the ports 53 and 61000 as the global ports to be protected against DNS response flood attacks in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] dns-reply-flood port 53 61000
Use dns-reply-flood threshold to set the global threshold for triggering destination-based DNS response flood attack prevention.
Use undo dns-reply-flood threshold to restore the default.
dns-reply-flood threshold threshold-value
The global threshold is 10000 for triggering destination-based DNS response flood attack prevention.
threshold-value: Specifies the maximum receiving rate in pps for DNS responses that are destined for an IP address. The value range is 0 to 1000000. If you set the threshold value to 0, the destination-based DNS response flood attack prevention is disabled.
With global DNS response flood attack detection configured, the device is in attack detection state. When the receiving rate of DNS responses destined for an IP address keeps reaching or exceeding the threshold, the device enters prevention state and takes the specified actions. When the rate drops below the silence threshold (three-fourths of the threshold), the device returns to the attack detection state.
The global threshold applies to global DNS response flood attack detection. Adjust the threshold according to the application scenarios.
·     If the number of DNS responses sent to a protected DNS client is normally large, set a high threshold. A low threshold might affect the client services.
# Set the global threshold to 100 for triggering destination-based DNS response flood attack prevention in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] dns-reply-flood threshold 100
Use dns-reply-flood source-threshold to set the global threshold for triggering source-based DNS response flood attack prevention.
Use undo dns-reply-flood source-threshold to restore the default.
dns-reply-flood source-threshold threshold-value
The global threshold is 10000 for triggering source-based DNS response flood attack prevention.
threshold-value: Specifies the maximum receiving rate in pps for DNS responses that originate from an IP address. The value range is 0 to 1000000. If you set the threshold value to 0, the source-based DNS response flood attack prevention is disabled.
With global DNS response flood attack detection configured, the device is in attack detection state. When the receiving rate of DNS responses originating from an IP address keeps reaching or exceeding the threshold, the device enters prevention state and takes the specified actions. When the rate drops below the silence threshold (three-fourths of the threshold), the device returns to the attack detection state.
# Set the global threshold to 100 for triggering source-based DNS response flood attack prevention in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] dns-reply-flood source-threshold 100
exempt acl
Use exempt acl to configure attack detection exemption.
Use undo exempt acl to restore the default.
exempt acl [ ipv6 ] { acl-number | name acl-name }
undo exempt acl [ ipv6 ]
Attack detection exemption is not configured.
ipv6: Specifies an IPv6 ACL. To specify an IPv4 ACL, do not use this keyword.
acl-number: Specifies an ACL by its number:
·     2000 to 2999 for basic ACLs.
·     3000 to 3999 for advanced ACLs.
name acl-name: Specifies an ACL by its name. The acl-name argument is a case-insensitive string of 1 to 63 characters. It must start with an English letter and to avoid confusion, it cannot be all.
The attack defense policy uses an ACL to identify exempted packets. The policy does not check the packets permitted by the ACL. You can configure the ACL to identify packets from trusted hosts. The exemption feature reduces the false alarm rate and improves packet processing efficiency.
If an ACL is used for attack detection exemption, only the following match criteria in the ACL permit rules take effect:
·     Source IP address.
·     Destination IP address.
·     Source port.
·     Destination port.
·     Protocol.
·     L3VPN instance.
·     The fragment keyword for matching non-first fragments.
If the specified ACL does not exist or does not contain a rule, attack detection exemption does not take effect.
# Configure an ACL to permit packets sourced from 1.1.1.1. Configure attack detection exemption for packets matching the ACL in attack defense policy atk-policy-1.
[Sysname] acl basic 2001
[attack-defense-policy-atk-policy-1] exempt acl 2001
fin-flood action
Use fin-flood action to specify global actions against FIN flood attacks.
Use undo fin-flood action to restore the default.
fin-flood action { client-verify | drop | logging } *
No global action is specified for FIN flood attacks.
client-verify: Adds the victim IP addresses to the protected IP list for TCP client verification. If TCP client verification is enabled, the device provides proxy services for protected servers. This keyword does not take effect on source-based flood attack prevention.
drop: Drops subsequent FIN packets destined for the victim IP addresses in destination-based flood attack prevention, or drops subsequent FIN packets originating from the attacker IP addresses in source-based flood attack prevention.
logging: Enables logging for FIN flood attack events. The log messages will be sent to the log system.
For the FIN flood attack detection to collaborate with the TCP client verification, make sure the client-verify keyword is specified and the TCP client verification is enabled. To enable TCP client verification, use the client-verify tcp enable command.
The logging keyword enables the attack detection and prevention module to log FIN flood attack events and send log messages to the information center.
The information center can output FIN flood attack logs to any destinations except the console and the monitor terminal. If you configure the console or monitor terminal as an output destination, the output destination setting will not take effect.
To view FIN flood attack logs stored on the device, use the display logbuffer command. Make sure you do not disable log output to the log buffer, which is enabled by default.
# Specify drop as the global action against FIN flood attacks in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] fin-flood action drop
fin-flood detect
fin-flood detect non-specific
fin-flood source-threshold
fin-flood threshold
fin-flood detect
Use fin-flood detect to configure IP address-specific FIN flood attack detection.
Use undo fin-flood detect to remove the IP address-specific FIN flood attack detection configuration.
fin-flood detect { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] [ threshold threshold-value ] [ action { { client-verify | drop | logging } * | none } ]
undo fin-flood detect { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
IP address-specific FIN flood attack detection is not configured.
threshold threshold-value: Specifies the maximum receiving rate in pps for FIN packets that are destined for the protected IP address. The value range is 1 to 1000000.
action: Specifies the actions against a detected FIN flood attack. If no action is specified, the global actions set by the fin-flood action command apply.
drop: Drops subsequent FIN packets destined for the protected IP address.
With FIN flood attack detection configured for an IP address, the device is in attack detection state. When the receiving rate of FIN packets destined for the IP address keeps reaching or exceeding the threshold, the device enters prevention state and takes the specified actions. When the rate drops below the silence threshold (three-fourths of the threshold), the device returns to the attack detection state.
You can configure FIN flood attack detection for multiple IP addresses in one attack defense policy.
# Configure FIN flood attack detection for 192.168.1.2 in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] fin-flood detect ip 192.168.1.2 threshold 2000
fin-flood action
fin-flood threshold
Use fin-flood detect non-specific to enable global FIN flood attack detection.
Use undo fin-flood detect non-specific to disable global FIN flood attack detection.
Global FIN flood attack detection is disabled.
The device supports the following FIN flood attack prevention types:
·     Source-based FIN flood attack prevention—Monitors the receiving rate of FIN packets on a per-source IP basis.
·     Destination-based FIN flood attack prevention—Monitors the receiving rate of FIN packets on a per-destination IP basis.
The global FIN flood attack detection applies to all IP addresses except for those specified by the fin-flood detect command. The global detection uses the global trigger threshold set by the fin-flood threshold or fin-flood source-threshold command and global actions specified by the fin-flood action command.
# Enable global FIN flood attack detection in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] fin-flood detect non-specific
fin-flood action
fin-flood detect
fin-flood threshold
fin-flood threshold
Use fin-flood threshold to set the global threshold for triggering destination-based FIN flood attack prevention.
Use undo fin-flood threshold to restore the default.
fin-flood threshold threshold-value
The global threshold is 10000 for triggering destination-based FIN flood attack prevention.
threshold-value: Specifies the maximum receiving rate in pps for FIN packets that are destined for an IP address. The value range is 0 to 1000000. If you set the threshold value to 0, the destination-based FIN flood attack prevention is disabled.
With global FIN flood attack detection configured, the device is in attack detection state. When the receiving rate of FIN packets destined for an IP address keeps reaching or exceeding the threshold, the device enters prevention state and takes the specified actions. When the rate drops below the silence threshold (three-fourths of the threshold), the device returns to the attack detection state.
The global threshold applies to global FIN flood attack detection. Adjust the threshold according to the application scenarios.
·     If the number of FIN packets sent to a protected server, such as an HTTP or FTP server, is normally large, set a high threshold. A low threshold might affect the server services.
# Set the global threshold to 100 for triggering destination-based FIN flood attack prevention in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] fin-flood threshold 100
fin-flood action
fin-flood detect
Use fin-flood source-threshold to set the global threshold for triggering source-based FIN flood attack prevention.
Use undo fin-flood source-threshold to restore the default.
fin-flood source-threshold threshold-value
The global threshold is 10000 for triggering source-based FIN flood attack prevention.
threshold-value: Specifies the maximum receiving rate in pps for FIN packets that originate from an IP address. The value range is 0 to 1000000. If you set the threshold value to 0, the source-based FIN flood attack prevention is disabled.
With global FIN flood attack detection configured, the device is in attack detection state. When the receiving rate of FIN packets originating from an IP address keeps reaching or exceeding the threshold, the device enters prevention state and takes the specified actions. When the rate drops below the silence threshold (three-fourths of the threshold), the device returns to the attack detection state.
# Set the global threshold to 100 for triggering source-based FIN flood attack prevention in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] fin-flood source-threshold 100
fin-flood action
fin-flood detect
http-flood action
Use http-flood action to specify global actions against HTTP flood attacks.
Use undo http-flood action to restore the default.
http-flood action { client-verify | drop | logging } *
No global action is specified for HTTP flood attacks.
client-verify: Adds the victim IP addresses to the protected IP list for HTTP client verification. If HTTP client verification is enabled, the device provides proxy services for protected servers. This keyword does not take effect on source-based flood attack prevention.
drop: Drops subsequent HTTP packets destined for the victim IP addresses in destination-based flood attack prevention, or drops subsequent HTTP packets originating from the attacker IP addresses in source-based flood attack prevention.
logging: Enables logging for HTTP flood attack events. The log messages will be sent to the log system.
For the HTTP flood attack detection to collaborate with the HTTP client verification, make sure the client-verify keyword is specified and the HTTP client verification is enabled. To enable HTTP client verification, use the client-verify http enable command.
The logging keyword enables the attack detection and prevention module to log HTTP flood attack events and send log messages to the information center.
The information center can output HTTP flood attack logs to any destinations except the console and the monitor terminal. If you configure the console or monitor terminal as an output destination, the output destination setting will not take effect.
To view HTTP flood attack logs stored on the device, use the display logbuffer command. Make sure you do not disable log output to the log buffer, which is enabled by default.
# Specify drop as the global action against HTTP flood attacks in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] http-flood action drop
http-flood detect
http-flood detect non-specific
http-flood source-threshold
http-flood threshold
http-flood detect
Use http-flood detect to configure IP address-specific HTTP flood attack detection.
Use undo http-flood detect to remove the IP address-specific HTTP flood attack detection configuration.
http-flood detect { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] [ port port-list ] [ threshold threshold-value ] [ action { { client-verify | drop | logging } * | none } ]
undo http-flood detect { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
IP address-specific HTTP flood attack detection is not configured.
threshold threshold-value: Specifies the maximum receiving rate in pps for HTTP packets that are destined for the protected IP address. The value range is 1 to 1000000.
action: Specifies the actions against a detected HTTP flood attack. If no action is specified, the global actions set by the http-flood action command apply.
drop: Drops subsequent HTTP packets destined for the protected IP address.
With HTTP flood attack detection configured for an IP address, the device is in attack detection state. When the receiving rate of HTTP packets destined for the IP address keeps reaching or exceeding the threshold, the device enters prevention state and takes the specified actions. When the rate drops below the silence threshold (three-fourths of the threshold), the device returns to the attack detection state.
You can configure HTTP flood attack detection for multiple IP addresses in one attack defense policy.
# Configure HTTP flood attack detection for 192.168.1.2 in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] http-flood detect ip 192.168.1.2 port 80 8080 threshold 2000
http-flood action
http-flood port
Use http-flood detect non-specific to enable global HTTP flood attack detection.
Use undo http-flood detect non-specific to disable global HTTP flood attack detection.
Global HTTP flood attack detection is disabled.
The device supports the following HTTP flood attack prevention types:
·     Source-based HTTP response flood attack prevention—Monitors the receiving rate of HTTP packets on a per-source IP basis.
·     Destination-based HTTP response flood attack prevention—Monitors the receiving rate of HTTP packets on a per-destination IP basis.
The global HTTP flood attack detection applies to all IP addresses except for those specified by the http-flood detect command. The global detection uses the global trigger threshold set by the http-flood threshold or http-flood source-threshold command and global actions specified by the http-flood action command.
# Enable global HTTP flood attack detection in attack defense policy atk-policy-1.
http-flood action
http-flood detect
http-flood port
Use http-flood port to specify the global ports to be protected against HTTP flood attacks.
Use undo http-flood port to restore the default.
http-flood port port-list
The global HTTP flood attack prevention protects port 80.
The device detects only HTTP packets destined for the specified ports.
The global ports apply to global HTTP flood attack detection and IP address-specific HTTP flood attack detection with no port specified.
# Specify the ports 80 and 8080 as the global ports to be protected against HTTP flood attacks in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] http-flood port 80 8080
http-flood action
http-flood detect
Use http-flood threshold to set the global threshold for triggering destination-based HTTP flood attack prevention.
Use undo http-flood threshold to restore the default.
http-flood threshold threshold-value
The global threshold is 10000 for triggering destination-based HTTP flood attack prevention.
threshold-value: Specifies the maximum receiving rate in pps for HTTP packets that are destined for an IP address. The value range is 0 to 1000000. If you set the threshold value to 0, the destination-based HTTP flood attack prevention is disabled.
With global HTTP flood attack detection configured, the device is in attack detection state. When the receiving rate of HTTP packets destined for an IP address keeps reaching or exceeding the threshold, the device enters prevention state and takes the specified actions. When the rate drops below the silence threshold (three-fourths of the threshold), the device returns to the attack detection state.
The global threshold applies to global HTTP flood attack detection. Adjust the threshold according to the application scenarios.
·     If the number of HTTP packets sent to a protected HTTP server is normally large, set a high threshold. A low threshold might affect the server services.
# Set the global threshold to 100 for triggering HTTP flood attack prevention in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] http-flood threshold 100
http-flood action
http-flood detect
http-flood port
Use http-flood source-threshold to set the global threshold for triggering source-based HTTP flood attack prevention.
Use undo http-flood source-threshold to restore the default.
http-flood source-threshold threshold-value
The global threshold is 10000 for triggering source-based HTTP flood attack prevention.
threshold-value: Specifies the maximum receiving rate in pps for HTTP packets that originate from an IP address. The value range is 0 to 1000000. If you set the threshold value to 0, the source-based HTTP flood attack prevention is disabled.
With global HTTP flood attack detection configured, the device is in attack detection state. When the receiving rate of HTTP packets originating from an IP address keeps reaching or exceeding the threshold, the device enters prevention state and takes the specified actions. When the rate drops below the silence threshold (three-fourths of the threshold), the device returns to the attack detection state.
# Set the global threshold to 100 for triggering source-based HTTP flood attack prevention in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] http-flood source-threshold 100
http-flood action
http-flood detect
http-flood port
http-slow-attack action
Use http-slow-attack action to specify the global actions against HTTP slow attacks.
Use undo http-slow-attack action to restore the default.
http-slow-attack action { block-source [ timeout minutes ] | logging } *
No global actions are specified for HTTP slow attacks.
block-source: Drops subsequent packets from IP addresses that launch HTTP slow attacks. When the device detects an HTTP slow attack, it adds the IP address of the attack source as a dynamic IP blacklist entry. If the blacklist feature is enabled on the interface or in the security zone to which the attack defense policy applies, the device drops packets originating from this IP address. Support for this keyword depends on the device model.
timeout minutes: Specifies the aging time in minutes for dynamically added blacklist entries. The value range is 1 to 10080, and the default is 10.
logging: Enables logging for HTTP slow attack events. The log messages will be sent to the log system.
# In attack defense policy atk-policy-1, specify block-source and logging as the global actions against HTTP slow attacks, and set the aging time to 10 minutes for dynamic blacklist entries.
[Sysname-attack-defense-policy-atk-policy-1] http-slow-attack action logging block-source timeout 10
blacklist enable
blacklist global enable
http-slow-attack detect
http-slow-attack detect non-specific
http-slow-attack period
http-slow-attack port
http-slow-attack threshold
Use http-slow-attack detect to configure IP address-specific HTTP slow attack detection.
Use undo http-slow-attack detect to remove the IP address-specific HTTP slow attack detection configuration.
http-slow-attack detect { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] [ port { start-port-number [ to end-port-number ] } &<1-16> ] [ threshold { alert-number alert-number | content-length content-length | payload-length payload-length | packet-number packet-number }* ] [ period period ] [ action { block-source [ timeout minutes ] | logging }* ]
undo http-slow-attack detect { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
IP address-specific HTTP slow attack detection is not configured.
port port-list: Specifies a space-separated list of up to 16 port number items. Each item specifies a port by its port number or a range of ports in the form of start-port-number to end-port-number. The end-port-number cannot be smaller than the start-port-number. If you do not specify this option, the global ports apply.
threshold: Specifies the threshold for triggering HTTP slow attack prevention. If you do not specify this argument, the global threshold settings for triggering HTTP slow attack prevention apply.
alert-number alert-number: Specifies a threshold for HTTP concurrent connections. The value range is 1 to 1200000, and the default is 5000.
content-length content-length: Specifies a threshold for the Content-Length field value in an HTTP packet. The value range is 100 to 100000000, and the default is 10000.
payload-length payload-length: Specifies a threshold for the payload size in an HTTP packet. The value range is 1 to 1000, and the default is 50.
packet-number packet-number: Specifies a threshold for abnormal packets. The value range is 1 to 1000, and the default is 10.
period period: Specifies a detection period in the range of 1 to 1200 seconds. If you do not specify this option, the global detection period applies.
action: Specifies actions against HTTP slow attacks. If you do not specify an action, the global defensive actions apply.
block-source: Drops subsequent packets from IP addresses that launch HTTP slow attacks. When the device detects an HTTP slow attack, it adds the IP address of the attack source as a dynamic IP blacklist entry. If the blacklist feature is enabled on the interface or in the security zone to which the attack defense policy applies, the device drops packets from this IP address.
timeout minutes: Specifies the aging time in minutes for dynamically added blacklist entries. The value range is 1 to 10080, and the default is 10. If you do not specify this option, the global setting applies.
For the dynamically added IP blacklist entries to take effect, make sure the blacklist feature is enabled on the interface or in the security zone to which the attack defense policy applies.
If you specify part of threshold parameters for IP address-specific HTTP slow attack detection, the default settings rather than the global settings apply to the unspecified threshold parameters.
# Configure HTTP slow attack detection for 1.1.1.1 in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] http-slow-attack detect ip 1.1.1.1 port 80 8080 threshold alert-number 3000 content-length 10000 payload-length 20 packet-number 10 action block-source
blacklist enable
Use http-slow-attack detect non-specific to enable global HTTP slow attack detection.
Use undo http-slow-attack detect non-specific to disable global HTTP slow attack detection.
Global HTTP slow attack detection is disabled.
After you enable global HTTP slow attack detection, the device uses the following global settings to protect IP addresses:
·     Threshold settings set by using the http-slow-attack threshold command.
·     Detection period set by using the http-slow-attack period command.
·     Ports set by using the http-slow-attack port command.
·     Defensive actions set by using the http-slow-attack action command.
# Enable global HTTP slow attack detection in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] http-slow-attack detect non-specific
Use http-slow-attack period to set the global HTTP slow attack detection period.
Use undo http-slow-attack period to restore the default.
http-slow-attack period period
The global HTTP slow attack detection period is 60 seconds.
period period: Specifies the detection period in seconds. The value range is 1 to 1200, and the default is 60.
# Set the HTTP slow attack detection period to 10 seconds in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] http-slow-attack period 10
Use http-slow-attack port to specify global ports to be protected against HTTP slow attacks.
Use undo http-slow-attack port to restore the default.
http-slow-attack port port-list &<1-32>
The global HTTP slow attack prevention protects port 80.
port-list &<1-32>: Specifies a space-separated list of up to 32 port number items. Each item specifies a port by its port number or a range of ports in the form of start-port-number to end-port-number. The end-port-number cannot be smaller than the start-port-number.
The global ports are used in global HTTP slow attack detection and IP address-specific HTTP slow attack detection with no protected ports specified.
As a best practice, specify port 80 as the global protected port against HTTP slow attacks. If you specify other ports, make sure these ports are used for HTTP communication. If the specified ports are not used for HTTP communication, the device resources will be wasted in inspecting non-HTTP slow attack packets.
# Specify ports 80 and 8080 as the global ports to be protected against HTTP slow attacks in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] http-slow-attack port 80 8000
Use http-slow-attack threshold to set global thresholds for triggering HTTP slow attack prevention.
Use undo http-slow-attack threshold to restore the default.
http-slow-attack threshold [ alert-number alert-number | content-length content-length | payload-length payload-length | packet-number packet-number ]*
The device enters HTTP slow attack detection state when the number of HTTP concurrent connections exceeds 5000. An HTTP packet is a slow attack packet if its Content-Length field value is greater than 10000 and its payload is less than 50 bytes. When the device receives more than 10 slow attack packets within the detection period, it takes defensive actions.
packet-number packet-number: Specifies a threshold for HTTP slow attack packets. The value range is 1 to 1000, and the default is 10.
The device enters the HTTP slow attack detection state when the number of HTTP concurrent connections exceeds the threshold. An HTTP packet is a slow attack packet if its Content-Length field value is greater than the content-length value and its payload is less than the payload-length value. When the number of attack packets received within the detection period exceeds the threshold, the device takes defensive actions.
If you do not specify a threshold for a parameter, the default value for the parameter applies.
# Configure global HTTP slow attack detection thresholds in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] http-slow-attack threshold alert-number 3000 content-length 10000 payload-length 20 packet-number 10
icmp-flood action
Use icmp-flood action to specify global actions against ICMP flood attacks.
Use undo icmp-flood action to restore the default.
icmp-flood action { drop | logging } *
No global action is specified for ICMP flood attacks.
drop: Drops subsequent ICMP packets destined for the victim IP addresses in destination-based flood attack prevention, or drops subsequent ICMP packets originating from the attacker IP addresses in source-based flood attack prevention.
logging: Enables logging for ICMP flood attack events. The log messages will be sent to the log system.
The logging keyword enables the attack detection and prevention module to log ICMP flood attack events and send log messages to the information center.
The information center can output ICMP flood attack logs to any destinations except the console and the monitor terminal. If you configure the console or monitor terminal as an output destination, the output destination setting will not take effect.
To view ICMP flood attack logs stored on the device, use the display logbuffer command. Make sure you do not disable log output to the log buffer, which is enabled by default.
# Specify drop as the global action against ICMP flood attacks in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] icmp-flood action drop
icmp-flood detect non-specific
icmp-flood detect ip
icmp-flood source-threshold
icmp-flood threshold
Use icmp-flood detect ip to configure IP address-specific ICMP flood attack detection.
Use undo icmp-flood detect ip to remove the IP address-specific ICMP flood attack detection configuration.
icmp-flood detect ip ip-address [ vpn-instance vpn-instance-name ] [ threshold threshold-value ] [ action { { drop | logging } * | none } ]
undo icmp-flood detect ip ip-address [ vpn-instance vpn-instance-name ]
IP address-specific ICMP flood attack detection is not configured.
ip-address: Specifies the IPv4 address to be protected. The ip-address argument cannot be 255.255.255.255 or 0.0.0.0.
threshold threshold-value: Specifies the maximum receiving rate in pps for ICMP packets that are destined for the protected IP address. The value range is 1 to 1000000.
action: Specifies the actions against a detected ICMP flood attack. If no action is specified, the global actions set by the icmp-flood action command apply.
drop: Drops subsequent ICMP packets destined for the protected IP address.
With ICMP flood attack detection configured for an IP address, the device is in attack detection state. When the receiving rate of ICMP packets destined for the IP address keeps reaching or exceeding the threshold, the device enters prevention state and takes the specified actions. When the rate drops below the silence threshold (three-fourths of the threshold), the device returns to the attack detection state.
You can configure ICMP flood attack detection for multiple IP addresses in one attack defense policy.
# Configure ICMP flood attack detection for 192.168.1.2 in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] icmp-flood detect ip 192.168.1.2 threshold 2000
icmp-flood action
Use icmp-flood detect non-specific to enable global ICMP flood attack detection.
Use undo icmp-flood detect non-specific to disable global ICMP flood attack detection.
Global ICMP flood attack detection is disabled.
The device supports the following ICMP flood attack prevention types:
·     Source-based ICMP flood attack prevention—Monitors the receiving rate of ICMP packets on a per-source IP basis.
·     Destination-based ICMP flood attack prevention—Monitors the receiving rate of ICMP packets on a per-destination IP basis.
The global ICMP flood attack detection applies to all IP addresses except for those specified by the icmp-flood detect ip command. The global detection uses the global trigger threshold set by the icmp-flood threshold or icmp-flood source-threshold command and global actions specified by the icmp-flood action command.
# Enable global ICMP flood attack detection in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] icmp-flood detect non-specific
icmp-flood action
Use icmp-flood threshold to set the global threshold for triggering destination-based ICMP flood attack prevention.
Use undo icmp-flood threshold to restore the default.
icmp-flood threshold threshold-value
The global threshold is 10000 for triggering destination-based ICMP flood attack prevention.
threshold-value: Specifies the maximum receiving rate in pps for ICMP packets that are destined for an IP address. The value range is 0 to 1000000. If you set the threshold value to 0, the destination-based ICMP flood attack prevention is disabled.
With global ICMP flood attack detection configured, the device is in attack detection state. When the receiving rate of ICMP packets destined for an IP address keeps reaching or exceeding the threshold, the device enters prevention state and takes the specified actions. When the rate drops below the silence threshold (three-fourths of the threshold), the device returns to the attack detection state.
The global threshold applies to global ICMP flood attack detection. Adjust the threshold according to the application scenarios.
·     If the number of ICMP packets sent to a protected server, such as an HTTP or FTP server, is normally large, set a high threshold. A low threshold might affect the server services.
# Set the global threshold to 100 for triggering destination-based ICMP flood attack prevention in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] icmp-flood threshold 100
icmp-flood action
Use icmp-flood source-threshold to set the global threshold for triggering source-based ICMP flood attack prevention.
Use undo icmp-flood source-threshold to restore the default.
icmp-flood source-threshold threshold-value
The global threshold is 10000 for triggering source-based ICMP flood attack prevention.
threshold-value: Specifies the maximum receiving rate in pps for ICMP packets that originate from an IP address. The value range is 0 to 1000000. If you set the threshold value to 0, the source-based ICMP flood attack prevention is disabled.
With global ICMP flood attack detection configured, the device is in attack detection state. When the receiving rate of ICMP packets originating from an IP address keeps reaching or exceeding the threshold, the device enters prevention state and takes the specified actions. When the rate drops below the silence threshold (three-fourths of the threshold), the device returns to the attack detection state.
# Set the global threshold to 100 for triggering source-based ICMP flood attack prevention in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] icmp-flood source-threshold 100
icmp-flood action
icmp-flood detect
icmpv6-flood action
Use icmpv6-flood action to specify global actions against ICMPv6 flood attacks.
Use undo icmpv6-flood action to restore the default.
icmpv6-flood action { drop | logging } *
No global action is specified for ICMPv6 flood attacks.
drop: Drops subsequent ICMPv6 packets destined for the victim IP addresses in destination-based flood attack prevention, or drops subsequent ICMPv6 packets originating from the attacker IPv6 addresses in source-based flood attack prevention.
logging: Enables logging for ICMPv6 flood attack events. The log messages will be sent to the log system.
The logging keyword enables the attack detection and prevention module to log ICMPv6 flood attack events and send log messages to the information center.
The information center can output ICMPv6 flood attack logs to any destinations except the console and the monitor terminal. If you configure the console or monitor terminal as an output destination, the output destination setting will not take effect.
To view ICMPv6 flood attack logs stored on the device, use the display logbuffer command. Make sure you do not disable log output to the log buffer, which is enabled by default.
# Specify drop as the global action against ICMPv6 flood attacks in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] icmpv6-flood action drop
icmpv6-flood detect ipv6
icmpv6-flood detect non-specific
icmpv6-flood source-threshold
icmpv6-flood threshold
Use icmpv6-flood detect ipv6 to configure IPv6 address-specific ICMPv6 flood attack detection.
Use undo icmpv6-flood detect ipv6 to remove the IPv6 address-specific ICMPv6 flood attack detection configuration.
icmpv6-flood detect ipv6 ipv6-address [ vpn-instance vpn-instance-name ] [ threshold threshold-value ] [ action { { drop | logging } * | none } ]
undo icmpv6-flood detect ipv6 ipv6-address [ vpn-instance vpn-instance-name ]
IPv6 address-specific ICMPv6 flood attack detection is not configured.
Ipv6-address: Specifies the IPv6 address to be protected. The IPv6 address cannot be a multicast address or ::.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the protected IPv6 address belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. Do not specify this option if the protected IPv6 address is on the public network.
threshold threshold-value: Specifies the maximum receiving rate in pps for ICMPv6 packets that are destined for the protected IP address. The value range is 1 to 1000000.
action: Specifies the actions against a detected ICMPv6 flood attack. If no action is specified, the global actions set by the icmpv6-flood action command apply.
drop: Drops subsequent ICMPv6 packets destined for the protected IPv6 address.
With ICMPv6 flood attack detection configured for an IPv6 address, the device is in attack detection state. When the receiving rate of ICMPv6 packets to the IPv6 address keeps reaching or exceeding the threshold, the device enters prevention state and takes the specified actions. When the rate drops below the silence threshold (three-fourths of the threshold), the device returns to the attack detection state.
You can configure ICMPv6 flood attack detection for multiple IPv6 addresses in one attack defense policy.
# Configure ICMPv6 flood attack detection for 2012::12 in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] icmpv6-flood detect ipv6 2012::12 threshold 2000
icmpv6-flood action
Use icmpv6-flood detect non-specific to enable global ICMPv6 flood attack detection.
Use undo icmpv6-flood detect non-specific to disable global ICMPv6 flood attack detection.
Global ICMPv6 flood attack detection is disabled.
The device supports the following ICMPv6 flood attack prevention types:
·     Source-based ICMPv6 flood attack prevention—Monitors the receiving rate of ICMPv6 messages on a per-source IP basis.
·     Destination-based ICMPv6 flood attack prevention—Monitors the receiving rate of ICMPv6 messages on a per-destination IP basis.
The global ICMPv6 flood attack detection applies to all IPv6 addresses except for those specified by the icmpv6-flood detect ipv6 command. The global detection uses the global trigger threshold set by the icmpv6-flood threshold or icmpv6-flood source-threshold command and global actions specified by the icmpv6-flood action command.
# Enable global ICMPv6 flood attack detection in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] icmpv6-flood detect non-specific
icmpv6-flood action
Use icmpv6-flood threshold to set the global threshold for triggering destination-based ICMPv6 flood attack prevention.
Use undo icmpv6-flood threshold to restore the default.
icmpv6-flood threshold threshold-value
The global threshold is 10000 for triggering destination-based ICMPv6 flood attack prevention.
threshold-value: Specifies the maximum receiving rate in pps for ICMPv6 packets that are destined for an IP address. The value range is 0 to 1000000. If you set the threshold value to 0, the destination-based ICMPv6 flood attack prevention is disabled.
With global ICMPv6 flood attack detection configured, the device is in attack detection state. When the receiving rate of ICMPv6 packets destined for an IPv6 address keeps reaching or exceeding the threshold, the device enters prevention state and takes the specified actions. When the rate drops below the silence threshold (three-fourths of the threshold), the device returns to the attack detection state.
The global threshold applies to global ICMPv6 flood attack detection. Adjust the threshold according to the application scenarios.
·     If the number of ICMPv6 packets sent to a protected server, such as an HTTP or FTP server, is normally large, set a high threshold. A low threshold might affect the server services.
# Set the global threshold to 100 for triggering destination-based ICMPv6 flood attack prevention in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] icmpv6-flood threshold 100
icmpv6-flood action
Use icmpv6-flood source-threshold to set the global threshold for triggering source-based ICMPv6 flood attack prevention.
Use undo icmpv6-flood source-source-threshold to restore the default.
icmpv6-flood source-threshold threshold-value
undo icmpv6-flood source-threshold
The global threshold is 10000 for triggering source-based ICMPv6 flood attack prevention.
Attack defense policy view
threshold-value: Specifies the maximum receiving rate in pps for ICMPv6 packets that originate from an IPv6 address. The value range is 0 to 1000000. If you set the threshold value to 0, the source-based ICMPv6 flood attack prevention is disabled.
With global ICMPv6 flood attack detection configured, the device is in attack detection state. When the receiving rate of ICMPv6 packets originating from an IPv6 address keeps reaching or exceeding the threshold, the device enters prevention state and takes the specified actions. When the rate drops below the silence threshold (three-fourths of the threshold), the device returns to the attack detection state.
# Set the global threshold to 100 for triggering source-based ICMPv6 flood attack prevention in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] icmpv6-flood source-threshold 100
icmpv6-flood action
icmpv6-flood detect
reset attack-defense policy flood
Use reset attack-defense policy flood statistics to clear flood attack detection and prevention statistics for protected IP addresses.
reset attack-defense policy policy-name flood protected { ip | ipv6 } statistics
policy-name: Specifies an attack defense policy by its name. The policy name is a case-insensitive string of 1 to 31 characters. Valid characters include uppercase and lowercase letters, digits, underscores (_), and hyphens (-).
ip: Specifies protected IPv4 addresses.
ipv6: Specifies protected IPv6 addresses.
statistics: Clears flood attack detection and prevention statistics.
# Clear flood attack detection and prevention statistics for protected IPv4 addresses in attack defense policy abc.
<Sysname> reset attack-defense policy abc flood protected ip statistics
# Clear flood attack detection and prevention statistics for protected IPv6 addresses in attack defense policy abc.
<Sysname> reset attack-defense policy abc flood protected ipv6 statistics
display attack-defense policy ip
display attack-defense policy ipv6
reset attack-defense statistics interface
Use reset attack-defense statistics interface to clear attack detection and prevention statistics for an interface.
reset attack-defense statistics interface interface-type interface-number
# Clear attack detection and prevention statistics for GigabitEthernet 1/0/1.
<Sysname> reset attack-defense statistics interface gigabitethernet 1/0/1
display attack defense policy
reset attack-defense statistics local
Use reset attack-defense statistics local to clear attack detection and prevention statistics for the device.
# Clear attack detection and prevention statistics for the device.
<Sysname> reset attack-defense statistics local
display attack-defense statistics local
reset attack-defense top-attack-statistics
Use reset attack-defense top-attack-statistics to clear top 10 attack statistics.
# Clear top 10 attack statistics.
<Sysname> reset attack-defense top-attack-statistics
attack-defense top-attack-statistics enable
display attack-defense top-attack-statistics
reset blacklist destination-ip
Use reset blacklist destination-ip to delete dynamic destination IPv4 blacklist entries.
reset blacklist destination-ip { destination-ip-address [ vpn-instance vpn-instance-name ]| all }
destination-ip-address: Specifies an IPv4 address.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the IPv4 address belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. Do not specify this option if the IPv4 address is on the public network.
all: Specifies all dynamic destination IPv4 blacklist entries.
This command deletes only dynamic destination IPv4 blacklist entries. To delete manual destination IPv4 blacklist entries, use the undo blacklist destination-ip command.
# Delete all dynamic destination IPv4 blacklist entries.
<Sysname> reset blacklist destination-ip all
display blacklist destination-ip
reset blacklist destination-ipv6
Use reset blacklist destination-ipv6 to delete dynamic destination IPv6 blacklist entries.
reset blacklist destination-ipv6{ destination-ipv6-address [ vpn-instance vpn-instance-name ]| all }
destination-ipv6-address : Specifies an IPv6 address.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the IPv6 address belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. Do not specify this option if the IPv6 address is on the public network.
This command deletes only dynamic destination IPv6 blacklist entries. To delete manual destination IPv6 blacklist entries, use the undo blacklist destination-ipv6 command.
# Delete all dynamic destination IPv6 blacklist entries.
<Sysname> reset blacklist destination-ipv6 all
display blacklist ipv6
reset blacklist ip
Use reset blacklist ip to delete dynamic IPv4 blacklist entries.
reset blacklist ip { source-ip-address [ vpn-instance vpn-instance-name ] [ ds-lite-peer ds-lite-peer-address ] | all }
source-ip-address: Specifies the IPv4 address for a blacklist entry.
ds-lite-peer ds-lite-peer-address: Specifies the IPv6 address of the B4 element of the DS-Lite tunnel that transmits packets from the blacklisted IPv4 address. Do not specify this option if the IPv4 address is on the public network.
all: Specifies all dynamic IPv4 blacklist entries.
This command deletes only dynamic IPv4 blacklist entries. To delete manual IPv4 blacklist entries, use the undo blacklist ip command.
# Delete all dynamic IPv4 blacklist entries.
<Sysname> reset blacklist ip all
reset blacklist ipv6
Use reset blacklist ipv6 to delete dynamic IPv6 blacklist entries.
reset blacklist ipv6 { source-ipv6-address [ vpn-instance vpn-instance-name ] | all }
source-ipv6-address: Specifies the IPv6 address for a blacklist entry.
all: Specifies all dynamic IPv6 blacklist entries.
This command deletes only dynamic IPv6 blacklist entries. To delete manual IPv6 blacklist entries, use the undo blacklist ipv6 command.
# Delete all dynamic IPv6 blacklist entries.
<Sysname> reset blacklist ipv6 all
reset blacklist statistics
Use reset blacklist statistics to clear blacklist statistics.
This command resets the counter for dropped packets for all blacklist entries.
# Clear blacklist statistics.
<Sysname> reset blacklist statistics
reset client-verify protected statistics
Use reset client-verify protected statistics to clear protected IP statistics for client verification.
reset client-verify { dns| dns-reply | http | sip | tcp } protected { ip | ipv6 } statistics
dns: Specifies the DNS client verification feature.
dns-reply: Specifies the DNS response verification feature.
http: Specifies the HTTP client verification feature.
sip: Specifies the SIP client verification feature.
tcp: Specifies the TCP client verification feature.
ip: Specifies the protected IPv4 list.
ipv6: Specifies the protected IPv6 list.
# Clear the protected IPv4 statistics for TCP client verification.
<Sysname> reset client-verify tcp protected ip statistics
display client-verify protected ip
display client-verify protected ipv6
reset client-verify trusted
Use reset client-verify trusted to clear the trusted IP list for client verification.
reset client-verify { dns| dns-reply | http | sip | tcp } trusted { ip | ipv6 }
ip: Specifies the trusted IPv4 list.
ipv6: Specifies the trusted IPv6 list.
# Clear the trusted IPv4 list for DNS client verification.
<Sysname> reset client-verify dns trusted ip
display client-verify trusted ip
display client-verify trusted ipv6
reset whitelist statistics
Use reset whitelist statistics to clear statistics about packets that match the address object groups on the whitelist.
This command clears statistics about packets that match all address object groups on the whitelist.
# Clear statistics about packets that match the address object groups on the whitelist.
<Sysname> reset whitelist statistics
display whitelist object-group
rst-flood action
Use rst-flood action to specify global actions against RST flood attacks.
Use undo rst-flood action to restore the default.
rst-flood action { client-verify | drop | logging } *
No global action is specified for RST flood attacks.
drop: Drops subsequent RST packets destined for the victim IP addresses in destination-based flood attack prevention, or drops subsequent RST packets originating from the attacker IP addresses in source-based flood attack prevention.
logging: Enables logging for RST flood attack events. The log messages will be sent to the log system.
For the RST flood attack detection to collaborate with the TCP client verification, make sure the client-verify keyword is specified and the TCP client verification is enabled. To enable TCP client verification, use the client-verify tcp enable command.
The logging keyword enables the attack detection and prevention module to log RST flood attack events and send log messages to the information center.
With the information center, you can set log message filtering and output rules, including output destinations.
The information center can output RST flood attack logs to any destinations except the console and the monitor terminal. If you configure the console or monitor terminal as an output destination, the output destination setting will not take effect.
To view RST flood attack logs stored on the device, use the display logbuffer command. Make sure you do not disable log output to the log buffer, which is enabled by default.
For more information about configuring the information center, see Network Management and Monitoring Configuration Guide.
# Specify drop as the global action against RST flood attacks in attack defense policy atk-policy-1.
[Sysname] attack-defense policy atk-policy-1
[Sysname-attack-defense-policy-atk-policy-1] rst-flood action drop
rst-flood detect
rst-flood detect non-specific
rst-flood source-threshold
rst-flood threshold
rst-flood detect
Use rst-flood detect to configure IP address-specific RST flood attack detection.
Use undo rst-flood detect to remove the IP address-specific RST flood attack detection configuration.
rst-flood detect { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] [ threshold threshold-value ] [ action { { client-verify | drop | logging } * | none } ]
undo rst-flood detect { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
IP address-specific RST flood attack detection is not configured.
ip ipv4-address: Specifies the IPv4 address to be protected. The ip-address argument cannot be 255.255.255.255 or 0.0.0.0.
ipv6 ipv6-address: Specifies the IPv6 address to be protected. The IPv6 address cannot be a multicast address or ::.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the protected IP address belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. Do not specify this option if the protected IP address is on the public network.
threshold threshold-value: Specifies the maximum receiving rate in pps for RST packets that are destined for the protected IP address. The value range is 1 to 1000000.
action: Specifies the actions against a detected RST flood attack. If no action is specified, the global actions set by the rst-flood action command apply.
drop: Drops subsequent RST packets destined for the protected IP address.
none: Takes no action.
With RST flood attack detection configured for an IP address, the device is in attack detection state. When the receiving rate of RST packets destined for the IP address keeps reaching or exceeding the threshold, the device enters prevention state and takes the specified actions. When the rate drops below the silence threshold (three-fourths of the threshold), the device considers returns to the attack detection state.
You can configure RST flood attack detection for multiple IP addresses in one attack defense policy.
# Configure RST flood attack detection for 192.168.1.2 in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] rst-flood detect ip 192.168.1.2 threshold 2000
rst-flood action
rst-flood threshold
Use rst-flood detect non-specific to enable global RST flood attack detection.
Use undo rst-flood detect non-specific to disable global RST flood attack detection.
Global RST flood attack detection is disabled.
The device supports the following RST flood attack prevention types:
·     Source-based RST flood attack prevention—Monitors the receiving rate of RST packets on a per-source IP basis.
·     Destination-based RST flood attack prevention—Monitors the receiving rate of RST packets on a per-destination IP basis.
The global RST flood attack detection applies to all IP addresses except for those specified by the rst-flood detect command. The global detection uses the global trigger threshold set by the rst-flood threshold or rst-flood source-threshold command and global actions specified by the rst-flood action command.
# Enable global RST flood attack detection in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] rst-flood detect non-specific
rst-flood action
rst-flood detect
rst-flood threshold
rst-flood threshold
Use rst-flood threshold to set the global threshold for triggering destination-based RST flood attack prevention.
Use undo rst-flood threshold to restore the default.
rst-flood threshold threshold-value
The global threshold is 10000 for triggering destination-based RST flood attack prevention.
threshold-value: Specifies the maximum receiving rate in pps for RST packets that are destined for an IP address. The value range is 0 to 1000000. If you set the threshold value to 0, the destination-based RST flood attack prevention is disabled.
With global RST flood attack detection configured, the device is in attack detection state. When the receiving rate of RST packets destined for an IP address keeps reaching or exceeding the threshold, the device enters prevention state and takes the specified actions. When the rate drops below the silence threshold (three-fourths of the threshold), the device returns to the attack detection state.
The global threshold applies to global RST flood attack detection. Adjust the threshold according to the application scenarios.
·     If the number of RST packets sent to a protected server, such as an HTTP or FTP server, is normally large, set a high threshold. A low threshold might affect the server services.
·     For a network that is unstable or susceptible to attacks, set a low threshold.
# Set the global threshold to 100 for triggering destination-based RST flood attack prevention in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] rst-flood threshold 100
rst-flood action
rst-flood detect
Use rst-flood source-threshold to set the global threshold for triggering source-based RST flood attack prevention.
Use undo rst-flood source-threshold to restore the default.
rst-flood source-threshold threshold-value
The global threshold is 10000 for triggering source-based RST flood attack prevention.
threshold-value: Specifies the maximum receiving rate in pps for RST packets that originate from an IP address. The value range is 0 to 1000000. If you set the threshold value to 0, the source-based RST flood attack prevention is disabled.
With global RST flood attack detection configured, the device is in attack detection state. When the receiving rate of RST packets originating from to an IP address keeps reaching or exceeding the threshold, the device enters prevention state and takes the specified actions. When the rate drops below the silence threshold (three-fourths of the threshold), the device returns to the attack detection state.
# Set the global threshold to 100 for triggering source-based RST flood attack prevention in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] rst-flood source-threshold 100
rst-flood action
rst-flood detect
scan detect
Use scan detect to configure scanning attack detection.
Use undo scan detect to remove the scanning attack detection configuration.
scan detect level { { high | low | medium } | user-defined { port-scan-threshold threshold-value | ip-sweep-threshold threshold-value } * [ period period-value ] } action { { block-source [ timeout minutes ] | drop } | logging } *
undo scan detect
No scanning attack detection is configured.
level: Specifies the level of the scanning attack detection.
high: Specifies the high level. This level can detect most of the scanning attacks, but has a high false alarm rate. Some packets from active hosts might be considered as attack packets. For high level detection, the detection cycle is 10 seconds. The threshold for triggering port scan attack prevention is 5000 packets in a detection cycle. The threshold for triggering IP sweep attack prevention is 5000 packets in a detection cycle.
low: Specifies the low level. This level provides basic scanning attack detection. It has a low false alarm rate but many scanning attacks cannot be detected. For low level detection, the detection cycle is 10 seconds. The threshold for triggering port scan attack prevention is 100000 packets in a detection cycle. The threshold for triggering IP sweep attack prevention is 100000 packets in a detection cycle.
medium: Specifies the medium level. Compared with the high and low levels, this level has medium false alarm rate and attack detection accuracy. For medium level detection, the detection cycle is 10 seconds. The threshold for triggering port scan attack prevention is 40000 packets. The threshold for triggering IP sweep attack prevention is 40000 packets.
user-defined: Specifies the user-defined level. This level allows you to set the thresholds and detection cycle for port scan and IP sweep attacks on demand.
port-scan-threshold threshold-value: Specifies the maximum number of packets sent from an IP address to different ports within a detection cycle. The value range is 1 to 1000000000.
ip-sweep-threshold threshold-value: Specifies the maximum number of packets sent from an IP address to different IP addresses within a detection cycle. The value range is 1 to 1000000000.
period period-value: Sets the scanning attack detection cycle in the range of 1 to 1000000000 seconds. The default value is 10.
action: Specifies the actions against scanning attacks.
block-source: Adds the attackers' IP addresses to the IP blacklist. If the blacklist feature is enabled on the receiving interface, the device drops subsequent packets from the blacklisted IP addresses.
timeout minutes: Specifies the aging timer in minutes for the dynamically added blacklist entries, in the range of 1 to 10080. The default aging timer is 10 minutes.
drop: Drops subsequent packets from detected scanning attack sources. The log messages will be sent to the log system.
logging: Enables logging for scanning attack events.
To collaborate with the IP blacklist feature, make sure the blacklist feature is enabled on the interface to which the attack defense policy is applied.
The aging timer set by the timeout minutes option must be longer than the statistics collection interval.
The information center can output scanning attack logs to any destinations except the console and the monitor terminal. If you configure the console or monitor terminal as an output destination, the output destination setting will not take effect.
To view scanning attack logs stored on the device, use the display logbuffer command. Make sure you do not disable log output to the log buffer, which is enabled by default.
# Configure low level scanning attack detection and specify the prevention action as drop in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] scan detect level low action drop
# Configure scanning attack detection in attack defense policy atk-policy-1. Specify the detection level as low and the prevention actions as block-source and logging. Set the aging time for the dynamically added IP blacklist entries to 10 minutes.
[Sysname-attack-defense-policy-atk-policy-1] scan detect level low action logging block-source timeout 10
# Configure scanning attack detection in the attack defense policy atk-policy-1. Specify the detection level as user-defined and detection cycle as 30 seconds. Set the port scan attack prevention threshold and IP sweep attack prevention threshold to 6000 packets and 80000 packets, respectively. Specify the prevention action as block-source and logging. Set the aging time for the dynamically added IP blacklist entries to 10 minutes.
[Sysname-attack-defense-policy-atk-policy-1] scan detect level user-defined port-scan-threshold 6000 ip-sweep-threshold 80000 period 30 action logging block-source timeout 10
blacklist enable
signature { large-icmp | large-icmpv6 } max-length
Use signature { large-icmp | large-icmpv6 } max-length to set the maximum length of safe ICMP or ICMPv6 packets. A large ICMP or ICMPv6 attack occurs if an ICMP or ICMPv6 packet larger than the specified length is detected.
Use undo signature { large-icmp | large-icmpv6 } max-length to restore the default.
signature { large-icmp | large-icmpv6 } max-length length
The maximum length of safe ICMP or ICMPv6 packets is 4000 bytes.
large-icmp: Specifies large ICMP packet attack signature.
large-icmpv6: Specifies large ICMPv6 packet attack signature.
length: Specifies the maximum length of safe ICMP or ICMPv6 packets, in bytes. The value range for ICMP packets is 28 to 65534. The value range for ICMPv6 packets is 48 to 65534.
# Set the maximum length of safe ICMP packets for large ICMP attack to 50000 bytes in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] signature large-icmp max-length 50000
signature detect
signature detect
Use signature detect to enable signature detection for single-packet attacks and specify the prevention actions.
Use undo signature detect to disable signature detection for single-packet attacks.
signature detect { fraggle | fragment | impossible | land | large-icmp | large-icmpv6 | smurf | snork | tcp-all-flags | tcp-fin-only | tcp-invalid-flags | tcp-null-flag | tcp-syn-fin | tiny-fragment | traceroute | udp-bomb | winnuke } [ action { { drop | logging } * | none } ]
undo signature detect { fraggle | fragment | impossible | land | large-icmp | large-icmpv6 | smurf | snork | tcp-all-flags | tcp-fin-only | tcp-invalid-flags | tcp-null-flag | tcp-syn-fin | tiny-fragment | traceroute | udp-bomb | winnuke }
signature detect { ip-option-abnormal | ping-of-death | teardrop } action { drop | logging } *
undo signature detect { ip-option-abnormal | ping-of-death | teardrop }
signature detect icmp-type { icmp-type-value | address-mask-reply | address-mask-request | destination-unreachable | echo-reply | echo-request | information-reply | information-request | parameter-problem | redirect | source-quench | time-exceeded | timestamp-reply | timestamp-request } [ action { { drop | logging } * | none } ]
undo signature detect icmp-type { icmp-type-value | address-mask-reply | address-mask-request | destination-unreachable | echo-reply | echo-request | information-reply | information-request | parameter-problem | redirect | source-quench | time-exceeded | timestamp-reply | timestamp-request }
signature detect icmpv6-type { icmpv6-type-value | destination-unreachable | echo-reply | echo-request | group-query | group-reduction | group-report | packet-too-big | parameter-problem | time-exceeded } [ action { { drop | logging } * | none } ]
undo signature detect icmpv6-type { icmpv6-type-value | destination-unreachable | echo-reply | echo-request | group-query | group-reduction | group-report | packet-too-big | parameter-problem | time-exceeded }
signature detect ip-option { option-code | internet-timestamp | loose-source-routing | record-route | route-alert | security | stream-id | strict-source-routing } [ action { { drop | logging } * | none } ]
undo signature detect ip-option { option-code | internet-timestamp | loose-source-routing | record-route | route-alert | security | stream-id | strict-source-routing }
signature detect ipv6-ext-header ext-header-value [ action { { drop | logging } * | none } ]
undo signature detect ipv6-ext-header next-header-value
signature detect ipv6-ext-header-abnormal [ action { { drop | logging } * | none } ]
undo signature detect ipv6-ext-header-abnormal
signature detect ipv6-ext-header-exceed [ limit limit-value ] [ action { { drop | logging } * | none } ]
undo signature detect ipv6-ext-header-exceed
Signature detection is disabled for all single-packet attacks.
fraggle: Specifies the fraggle attack.
fragment: Specifies the IP fragment attack.
icmp-type: Specifies an ICMP packet attack by the packet type. You can specify the packet type by a number or a keyword:
·     icmp-type-value: Specifies the ICMP packet type in the range of 0 to 255.
·     address-mask-reply: Specifies the ICMP address mask reply type.
·     address-mask-request: Specifies the ICMP address mask request type.
·     destination-unreachable: Specifies the ICMP destination unreachable type.
·     echo-reply: Specifies the ICMP echo reply type.
·     echo-request: Specifies the ICMP echo request type.
·     information-reply: Specifies the ICMP information reply type.
·     information-request: Specifies the ICMP information request type.
·     parameter-problem: Specifies the ICMP parameter problem type.
·     redirect: Specifies the ICMP redirect type.
·     source-quench: Specifies the ICMP source quench type.
·     time-exceeded: Specifies the ICMP time exceeded type.
·     timestamp-reply: Specifies the ICMP timestamp reply type.
·     timestamp-request: Specifies the ICMP timestamp request type.
icmpv6-type: Specifies an ICMPv6 packet attack by the packet type. You can specify the packet type by a number or a keyword:
·     icmpv6-type-value: Specifies the ICMPv6 packet type in the range of 0 to 255.
·     destination-unreachable: Specifies the ICMPv6 destination unreachable type.
·     echo-reply: Specifies the ICMPv6 echo reply type.
·     echo-request: Specifies the ICMPv6 echo request type.
·     group-query: Specifies the ICMPv6 group query type.
·     group-reduction: Specifies the ICMPv6 group reduction type.
·     group-report: Specifies the ICMPv6 group report type.
·     packet-too-big: Specifies the ICMPv6 packet too big type.
·     parameter-problem: Specifies the ICMPv6 parameter problem type.
·     time-exceeded: Specifies the ICMPv6 time exceeded type.
impossible: Specifies the IP impossible packet attack.
ip-option: Specifies an IP option. You can specify the IP option by a number or a keyword:
·     option-code: Specifies the IP option in the range of 1 to 255.
·     internet-timestamp: Specifies the timestamp option.
·     loose-source-routing: Specifies the loose source routing option.
·     record-route: Specifies the record route option.
·     route-alert: Specifies the route alert option.
·     security: Specifies the security option.
·     stream-id: Specifies the stream identifier option.
·     strict-source-routing: Specifies the strict source route option.
ip-option-abnormal: Specifies the abnormal IP option attack.
ipv6-ext-header ext-header-value: Specifies an IPv6 extension header by its value in the range of 0 to 255.
ipv6-ext-header-abnormal: Specifies the abnormal IPv6 extension header attack.
ipv6-ext-header-exceed: Specifies the IPv6 extension header exceeded attack.
land: Specifies the Land attack.
large-icmp: Specifies the large ICMP packet attack.
large-icmpv6: Specifies the large ICMPv6 packet attack.
limit limit-value: Specifies the upper limit of IPv6 extension headers. The value range is 0 to 7, and the default is 0. An IPv6 packet is an IPv6 extension header exceeded attack packet if the number of its IPv6 extension headers exceeds the upper limit.
ping-of-death: Specifies the ping-of-death attack.
smurf: Specifies the smurf attack.
snork: Specifies the UDP snork attack.
tcp-all-flags: Specifies the attack where the TCP packet has all flags set.
tcp-fin-only: Specifies the attack where the TCP packet has only the FIN flag set.
tcp-invalid-flags: Specifies the attack that uses TCP packets with invalid flags.
tcp-null-flag: Specifies the attack where the TCP packet has no flags set.
tcp-syn-fin: Specifies the attack where the TCP packet has both SYN and FIN flags set.
teardrop: Specifies the teardrop attack.
tiny-fragment: Specifies the tiny fragment attack.
traceroute: Specifies the traceroute attack.
udp-bomb: Specifies the UDP bomb attack.
winnuke: Specifies the WinNuke attack.
action: Specifies the actions against the single-packet attack. If you do not specify this keyword, the default action of the attack level to which the single-packet attack belongs is used.
drop: Drops packets that match the specified signature.
logging: Enables logging for the specified single-packet attack.
You can use this command multiple times to enable signature detection for multiple single-packet attack types.
When you specify a packet type by a number, if the packet type has a corresponding keyword, the keyword is displayed in command output. If the packet type does not have a corresponding keyword, the number is displayed.
In abnormal IPv6 extension header and IPv6 extension header exceeded attack detection, the device examines the ESP header and headers before it. Headers after the ESP header are not examined.
The logging keyword enables the attack detection and prevention module to log single-packet attack events and send log messages to the information center.
The information center can output single-packet attack logs to any destinations except the console and the monitor terminal. If you configure the console or monitor terminal as an output destination, the output destination setting will not take effect.
To view single-packet attack logs stored on the device, use the display logbuffer command. Make sure you do not disable log output to the log buffer, which is enabled by default.
# Enable signature detection for the IP fragment attack and specify the prevention action as drop in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] signature detect fragment action drop
signature level action
Use signature level action to specify the actions against single-packet attacks on a specific level.
Use undo signature level action to restore the default.
signature level { high | info | low | medium } action { { drop | logging } * | none }
undo signature level { high | info | low | medium } action
For informational-level and low-level single-packet attacks, the action is logging.
For medium-level and high-level single-packet attacks, the actions are logging and drop.
high: Specifies the high level. None of the currently supported single-packet attacks belongs to this level.
info: Specifies the informational level. For example, large ICMP packet attack is on this level.
low: Specifies the low level. For example, the traceroute attack is on this level.
medium: Specifies the medium level. For example, the WinNuke attack is on this level.
drop: Drops packets that match the specified level.
logging: Enable logging for single-packet attacks on the specified level.
According to their severity, single-packet attacks are divided into four levels: info, low, medium, and high. Enabling signature detection for a specific level enables signature detection for all single-packet attacks on that level.
If you enable signature detection for a single-packet attack also by using the signature detect command, action parameters in the signature detect command take effect.
# Specify the action against informational-level single-packet attacks as drop in attack defense policy atk-policy-1.
[Sysname] attack-defense policy 1
[Sysname-attack-defense-policy-1] signature level info action drop
signature detect
signature level detect
Use signature level detect to enable signature detection for single-packet attacks on a specific level.
Use undo signature level detect to disable signature detection for single-packet attacks on a specific level.
signature level { high | info | low | medium } detect
undo signature level { high | info | low | medium } detect
Signature detection is disabled for all levels of single-packet attacks.
According to their severity, single-packet attacks are divided into four levels: info, low, medium, and high. Enabling signature detection for a specific level enables signature detection for all single-packet attacks on that level. Use the signature level action command to specify the actions against single-packet attacks on a specific level. If you enable signature detection for a single-packet attack also by using the signature detect command, action parameters in the signature detect command take effect.
To display the level to which a single-packet attack belongs, use the display attack-defense policy command.
# Enable signature detection for informational-level single-packet attacks in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-1] signature level info detect
signature detect
sip-flood action
Use sip-flood action to specify global actions against SIP flood attacks.
Use undo sip-flood action to restore the default.
sip-flood action { client-verify | drop | logging } *
No global action is specified for SIP flood attacks.
client-verify: Adds the victim IP addresses to the protected IP list for SIP client verification. If SIP client verification is enabled, the device provides proxy services for protected servers. This keyword does not take effect on source-based flood attack prevention.
drop: Drops subsequent SIP packets destined for the victim IP addresses in destination-based flood attack prevention, or drops subsequent SIP packets originating from the attacker IP addresses in source-based flood attack prevention.
logging: Enables logging for SIP flood attack events. The log messages will be sent to the log system.
For the SIP flood attack detection to collaborate with the SIP client verification, make sure the client-verify keyword is specified and the SIP client verification is enabled. To enable SIP client verification, use the client-verify sip enable command.
The logging keyword enables the attack detection and prevention module to log SIP flood attack events and send log messages to the information center.
The information center can output SIP flood attack logs to any destinations except the console and the monitor terminal. If you configure the console or monitor terminal as an output destination, the output destination setting will not take effect.
To view SIP flood attack logs stored on the device, use the display logbuffer command. Make sure you do not disable log output to the log buffer, which is enabled by default.
# Specify drop as the global action against SIP flood attacks in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] sip-flood action drop
sip-flood detect
sip-flood detect non-specific
sip-flood port
sip-flood source-threshold
sip-flood threshold
sip-flood detect
Use sip-flood detect to configure IP address-specific SIP flood attack detection.
Use undo sip-flood detect to remove IP address-specific SIP flood attack detection configuration.
sip-flood detect { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] [ port port-list ] [ threshold threshold-value ] [ action { { client-verify | drop | logging } * | none } ]
undo sip-flood detect { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
IP address-specific SIP flood attack detection is not configured.
port port-list: Specifies a space-separated list of up to 32 port number items. Each item specifies a port by its port number or a range of ports in the form of start-port-number to end-port-number. The end-port-number cannot be smaller than the start-port-number. If you do not specify this option, the global ports apply.
threshold threshold-value: Specifies the maximum receiving rate in pps for SIP packets that are destined for the protected IP address. The value range is 1 to 1000000, and the default value is 1000.
action: Specifies the actions against a detected SIP flood attack. If no action is specified, the global actions set by the sip-flood action command apply.
drop: Drops subsequent SIP packets destined for the protected IP address.
With SIP flood attack detection configured for an IP address, the device is in attack detection state. When the receiving rate of SIP packets destined for the IP address keeps reaching or exceeding the threshold, the device enters prevention state and takes the specified actions. When the rate drops below the silence threshold (three-fourths of the threshold), the device returns to the attack detection state.
You can configure SIP flood attack detection for multiple IP addresses in one attack defense policy.
# Configure SIP flood attack detection for 192.168.1.2 in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] sip-flood detect ip 192.168.1.2 threshold 2000
sip-flood action
sip-flood port
sip-flood threshold
Use sip-flood detect non-specific to enable global SIP flood attack detection.
Use undo sip-flood detect non-specific to disable global SIP flood attack detection.
Global SIP flood attack detection is disabled.
The device supports the following SIP flood attack prevention types:
·     Source-based SIP flood attack prevention—Monitors the receiving rate of SIP packets on a per-source IP basis.
·     Destination-based SIP flood attack prevention—Monitors the receiving rate of SIP packets on a per-destination IP basis.
The global SIP flood attack detection applies to all IP addresses except those specified by the sip-flood detect command. The global detection is configured by using the following commands:
·     Global ports set by using the sip-flood port command.
·     Global trigger threshold set by using the sip-flood threshold or sip-flood source-threshold command.
·     Global actions specified by using the sip-flood action command.
# Enable global SIP flood attack detection in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] sip-flood detect non-specific
sip-flood action
sip-flood detect
sip-flood port
sip-flood threshold
sip-flood port
Use sip-flood port to specify the global ports to be protected against SIP flood attacks.
Use undo sip-flood port to restore the default.
sip-flood port port-list
undo sip-flood port
The global SIP flood attack prevention protects port 5060.
The device detects only SIP packets destined for the specified ports.
The global ports apply to global SIP flood attack detection and IP address-specific SIP flood attack detection with no port specified.
# Specify ports 5060 and 65530 as the global ports to be protected against SIP flood attacks in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] sip-flood port 5060 65530
sip-flood action
sip-flood detect
sip-flood threshold
sip-flood threshold
Use sip-flood threshold to set the global threshold for triggering destination-based SIP flood attack prevention.
Use undo sip-flood threshold to restore the default.
sip-flood threshold threshold-value
The global threshold is 10000 for triggering destination-based SIP flood attack prevention.
threshold-value: Specifies the maximum receiving rate in pps for SIP packets that are destined for an IP address. The value range is 0 to 1000000. If you set the threshold value to 0, the destination-based SIP flood attack prevention is disabled.
With global SIP flood attack detection configured, the device is in attack detection state. When the receiving rate of SIP packets destined for an IP address keeps reaching or exceeding the threshold, the device enters prevention state and takes the specified actions. When the rate drops below the silence threshold (three-fourths of the threshold), the device returns to the attack detection state.
The global threshold applies to global SIP flood attack detection. Adjust the threshold according to the application scenarios.
·     If the number of SIP packets sent to a protected SIP server is normally large, set a high threshold. A low threshold might affect the server services.
# Set the global threshold to 100 for triggering destination-based SIP flood attack prevention in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] sip-flood threshold 100
sip-flood action
sip-flood detect
Use sip-flood source-threshold to set the global threshold for triggering source-based SIP flood attack prevention.
Use undo sip-flood source-threshold to restore the default.
sip-flood source-threshold threshold-value
The global threshold is 10000 for triggering source-based SIP flood attack prevention.
threshold-value: Specifies the maximum receiving rate in pps for SIP packets that originate from an IP address. The value range is 0 to 1000000. If you set the threshold value to 0, the source-based SIP flood attack prevention is disabled.
With global SIP flood attack detection configured, the device is in attack detection state. When the receiving rate of SIP packets originating from an IP address keeps reaching or exceeding the threshold, the device enters prevention state and takes the specified actions. When the rate drops below the silence threshold (three-fourths of the threshold), the device returns to the attack detection state.
# Set the global threshold to 100 for triggering source-based SIP flood attack prevention in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] sip-flood source-threshold 100
sip-flood action
sip-flood detect
sip-flood port
syn-ack-flood action
Use syn-ack-flood action to specify global actions against SYN-ACK flood attacks.
Use undo syn-ack-flood action to restore the default.
syn-ack-flood action { client-verify | drop | logging }*
No global action is specified for SYN-ACK flood attacks.
client-verify: Adds the victim IP addresses to the protected IP list for TCP client verification. If TCP client verification is enabled, the device provides proxy services for protected servers. This keyword does not take effect on source-based flood attack prevention.
drop: Drops subsequent SYN-ACK packets destined for the victim IP addresses in destination-based flood attack prevention, or drops subsequent SYN-ACK packets originating from the attacker IP addresses in source-based flood attack prevention..
logging: Enables logging for SYN-ACK flood attack events. The log messages will be sent to the log system.
For the SYN-ACK flood attack detection to collaborate with the TCP client verification, make sure the client-verify keyword is specified and the TCP client verification is enabled. To enable TCP client verification, use the client-verify tcp enable command.
The logging keyword enables the attack detection and prevention module to log SYN-ACK flood attack events and send log messages to the information center.
The information center can output SYN-ACK flood attack logs to any destinations except the console and the monitor terminal. If you configure the console or monitor terminal as an output destination, the output destination setting will not take effect.
To view SYN-ACK flood attack logs stored on the device, use the display logbuffer command. Make sure you do not disable log output to the log buffer, which is enabled by default.
# Specify drop as the global action against SYN-ACK flood attacks in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] syn-ack-flood action drop
syn-ack-flood detect
syn-ack-flood detect non-specific
syn-ack-flood source-threshold
syn-ack-flood threshold
Use syn-ack-flood detect to configure IP address-specific SYN-ACK flood attack detection.
Use undo syn-ack-flood detect to remove the IP address-specific SYN-ACK flood attack detection configuration.
syn-ack-flood detect { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] [ threshold threshold-value ] [ action { { client-verify | drop | logging } * | none } ]
undo syn-ack-flood detect { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
IP address-specific SYN-ACK flood attack detection is not configured.
threshold threshold-value: Specifies the maximum receiving rate in pps for SYN-ACK packets that are destined for the protected IP address. The value range is 1 to 1000000.
action: Specifies the actions against a detected SYN-ACK flood attack. If no action is specified, the global actions set by the syn-ack-flood action command apply.
drop: Drops subsequent SYN-ACK packets destined for the protected IP address.
With SYN-ACK flood attack detection configured for an IP address, the device is in attack detection state. When the receiving rate of SYN-ACK packets destined for the IP address keeps reaching or exceeding the threshold, the device enters prevention state and takes the specified actions. When the rate drops below the silence threshold (three-fourths of the threshold), the device returns to the attack detection state.
You can configure SYN-ACK flood attack detection for multiple IP addresses in one attack defense policy.
# Configure SYN-ACK flood attack detection for 192.168.1.2 in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] syn-ack-flood detect ip 192.168.1.2 threshold 2000
Use syn-ack-flood detect non-specific to enable global SYN-ACK flood attack detection.
Use undo syn-ack-flood detect non-specific to disable global SYN-ACK flood attack detection.
Global SYN-ACK flood attack detection is disabled.
The device supports the following SYN-ACK flood attack prevention types:
·     Source-based SYN-ACK flood attack prevention—Monitors the receiving rate of SYN-ACK packets on a per-source IP basis.
·     Destination-based SYN-ACK flood attack prevention—Monitors the receiving rate of SYN-ACK packets on a per-destination IP basis.
The global SYN-ACK flood attack detection applies to all IP addresses except for those specified by the syn-ack-flood detect command. The global detection uses the global trigger threshold set by the syn-ack-flood threshold or syn-ack-flood source-threshold command and global actions specified by the syn-ack-flood action command.
# Enable global SYN-ACK flood attack detection in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] syn-ack-flood detect non-specific
Use syn-ack-flood threshold to set the global threshold for triggering destination-based SYN-ACK flood attack prevention.
Use undo syn-ack-flood threshold to restore the default.
syn-ack-flood threshold threshold-value
The global threshold is 10000 for triggering destination-based SYN-ACK flood attack prevention.
threshold-value: Specifies the maximum receiving rate in pps for SYN-ACK packets that are destined for an IP address. The value range is 0 to 1000000. If you set the threshold value to 0, the destination-based SYN-ACK flood attack prevention is disabled.
With global SYN-ACK flood attack detection configured, the device is in attack detection state. When the receiving rate of SYN-ACK packets destined for an IP address keeps reaching or exceeding the threshold, the device enters prevention state and takes the specified actions. When the rate drops below the silence threshold (three-fourths of the threshold), the device returns to the attack detection state.
The global threshold applies to global SYN-ACK flood attack detection. Adjust the threshold according to the application scenarios.
·     If the number of SYN-ACK packets sent to a protected server, such as an HTTP or FTP server, is normally large, set a high threshold. A low threshold might affect the server services.
# Set the global threshold to 100 for triggering destination-based SYN-ACK flood attack prevention in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] syn-ack-flood threshold 100
Use syn-ack-flood source-threshold to set the global threshold for triggering source-based SYN-ACK flood attack prevention.
Use undo syn-ack-flood source-threshold to restore the default.
syn-ack-flood source-threshold threshold-value
The global threshold is 10000 for triggering source-based SYN-ACK flood attack prevention.
threshold-value: Specifies the maximum receiving rate in pps for SYN-ACK packets that originate from an IP address. The value range is 0 to 1000000. If you set the threshold value to 0, the source-based SYN-ACK flood attack prevention is disabled.
With global SYN-ACK flood attack detection configured, the device is in attack detection state. When the receiving rate of SYN-ACK packets originating from an IP address keeps reaching or exceeding the threshold, the device enters prevention state and takes the specified actions. When the rate drops below the silence threshold (three-fourths of the threshold), the device returns to the attack detection state.
# Set the global threshold to 100 for triggering source-based SYN-ACK flood attack prevention in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] syn-ack-flood source-threshold 100
syn-flood action
Use syn-flood action to specify global actions against SYN flood attacks.
Use undo syn-flood action to restore the default.
syn-flood action { client-verify | drop | logging } *
No global action is specified for SYN flood attacks.
drop: Drops subsequent SYN packets destined for the victim IP addresses in destination-based flood attack prevention, or drops subsequent SYN packets originating from the attacker IP addresses in source-based flood attack prevention.
logging: Enables logging for SYN flood attack events. The log messages will be sent to the log system.
For the SYN flood attack detection to collaborate with the TCP client verification, make sure the client-verify keyword is specified and the TCP client verification is enabled. To enable TCP client verification, use the client-verify tcp enable command.
The logging keyword enables the attack detection and prevention module to log SYN flood attack events and send log messages to the information center.
The information center can output SYN flood attack logs to any destinations except the console and the monitor terminal. If you configure the console or monitor terminal as an output destination, the output destination setting will not take effect.
To view SYN flood attack logs stored on the device, use the display logbuffer command. Make sure you do not disable log output to the log buffer, which is enabled by default.
# Specify drop as the global action against SYN flood attacks in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] syn-flood action drop
syn-flood detect
syn-flood detect non-specific
syn-flood source-threshold
syn-flood threshold
syn-flood detect
Use syn-flood detect to configure IP address-specific SYN flood attack detection.
Use undo syn-flood detect to remove the IP address-specific SYN flood attack detection configuration.
syn-flood detect { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] [ threshold threshold-value ] [ action { { client-verify | drop | logging } * | none } ]
undo syn-flood detect { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
IP address-specific SYN flood attack detection is not configured.
threshold threshold-value: Specifies the maximum receiving rate in pps for SYN packets that are destined for the protected IP address. The value range is 1 to 1000000.
action: Specifies the actions against a detected SYN flood attack. If no action is specified, the global actions set by the syn-flood action command apply.
drop: Drops subsequent SYN packets destined for the protected IP address.
With SYN flood attack detection configured for an IP address, the device is in attack detection state. When the receiving rate of SYN packets destined for the IP address keeps reaching or exceeding the threshold, the device enters prevention state and takes the specified actions. When the rate drops below the silence threshold (three-fourths of the threshold), the device returns to the attack detection state.
You can configure SYN flood attack detection for multiple IP addresses in one attack defense policy.
# Configure SYN flood attack detection for 192.168.1.2 in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] syn-flood detect ip 192.168.1.2 threshold 2000
syn-flood action
syn-flood threshold
Use syn-flood detect non-specific to enable global SYN flood attack detection.
Use undo syn-flood detect non-specific to disable global SYN flood attack detection.
Global SYN flood attack detection is disabled.
The device supports the following SYN flood attack prevention types:
·     Source-based SYN flood attack prevention—Monitors the receiving rate of SYN packets on a per-source IP basis.
·     Destination-based SYN flood attack prevention—Monitors the receiving rate of SYN packets on a per-destination IP basis.
The global SYN flood attack detection applies to all IP addresses except for those specified by the syn-flood detect command. The global detection uses the global trigger threshold set by the syn-flood threshold or syn-flood source-threshold command and global actions specified by the syn-flood action command.
# Enable global SYN flood attack detection in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] syn-flood detect non-specific
syn-flood action
syn-flood detect
syn-flood threshold
syn-flood threshold
Use syn-flood threshold to set the global threshold for triggering destination-based SYN flood attack prevention.
Use undo syn-flood threshold to restore the default.
syn-flood threshold threshold-value
The global threshold is 10000 for triggering destination-based SYN flood attack prevention.
threshold-value: Specifies the maximum receiving rate in pps for SYN packets that are destined for an IP address. The value range is 0 to 1000000. If you set the threshold value to 0, the destination-based SYN flood attack prevention is disabled.
With global SYN flood attack detection configured, the device is in attack detection state. When the receiving rate of SYN packets destined for an IP address keeps reaching or exceeding the threshold, the device enters prevention state and takes the specified actions. When the rate drops below the silence threshold (three-fourths of the threshold), the device returns to the attack detection state.
The global threshold applies to global SYN flood attack detection. Adjust the threshold according to the application scenarios.
·     If the number of SYN packets sent to a protected server, such as an HTTP or FTP server, is normally large, set a high threshold. A low threshold might affect the server services.
# Set the global threshold to 100 for triggering destination-based SYN flood attack prevention in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] syn-flood threshold 100
syn-flood action
syn-flood detect
Use syn-flood source-threshold to set the global threshold for triggering source-based SYN flood attack prevention.
Use undo syn-flood source-threshold to restore the default.
syn-flood source-threshold threshold-value
The global threshold is 10000 for triggering source-based SYN flood attack prevention.
threshold-value: Specifies the maximum receiving rate in pps for SYN packets that originate from an IP address. The value range is 0 to 1000000. If you set the threshold value to 0, the source-based SYN flood attack prevention is disabled.
With global SYN flood attack detection configured, the device is in attack detection state. When the receiving rate of SYN packets originating from an IP address keeps reaching or exceeding the threshold, the device enters prevention state and takes the specified actions. When the rate drops below the silence threshold (three-fourths of the threshold), the device returns to the attack detection state.
# Set the global threshold to 100 for triggering source-based SYN flood attack prevention in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] syn-flood source-threshold 100
syn-flood action
syn-flood detect
threshold-learn apply
Use threshold-learn apply to apply the most recent threshold that the device has learned.
You can configure this command to apply the most recent threshold that the device has learned to a flood attack defense policy that meets the following requirements:
·     The threshold learning feature is enabled for the policy.
·     Auto applying the learned threshold is disabled for the policy.
The learned threshold is set as the global threshold for triggering flood attack prevention. The command does not take effect when auto application of the learned threshold is enabled for the policy. If you execute this command multiple times, the most recent configuration takes effect.
Before you apply the most recently learned threshold to a flood attack defense policy, make sure global attack detection is enabled for all existing flood types in this policy.
# Apply the most recent threshold that the device has learned to attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] threshold-learn apply
threshold-learn enable
threshold-learn auto-apply enable
Use threshold-learn auto-apply enable to enable auto application of the learned threshold.
Use undo threshold-learn auto-apply enable to disable auto application of the learned threshold.
Auto application of the learned threshold is disabled.
Attack defense policy view
This command applies to only flood attack defense policies that are enabled with the threshold learning feature (set with the threshold-learn enable command). Each time the device learns a threshold, it uses the learned value to update the global threshold for triggering flood attack prevention. The formula for calculating the new global threshold is learned threshold × (1 + tolerance value). The learned threshold equals the peak packet receiving rate that the device has learned within the learning duration.
To set a tolerance value, execute the threshold-learn tolerance-value command. Setting a tolerance value can prevent packet loss when the network experiences a traffic spike without being attacked.
# Enable auto application of the learned threshold for attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] threshold-learn auto-apply enable
threshold-learn duration
Use threshold-learn duration to set the threshold learning duration.
Use undo threshold-learn duration to restore the default.
threshold-learn duration duration
The threshold learning duration is 1440 minutes.
duration: Specifies the threshold learning duration in the range of 1 to 1200000 minutes.
The device starts threshold learning when you apply an attack defense policy enabled with the threshold learning feature. The learned threshold equals the peak packet receiving rate learned within the duration. To ensure that the device learns the peak rate in a whole day, set a learning duration longer than 1440 minutes (24 hours). If you change the learning duration during the learning process, the device will restart threshold learning.
# Set the threshold learning duration to 2880 minutes (48 hours) for attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] threshold-learn duration 2880
threshold-learn loop
Use threshold-learn enable to enable the threshold learning feature for flood attack prevention.
Use undo threshold-learn enable to disable the threshold learning feature for flood attack prevention.
The threshold learning feature for flood attack prevention is disabled.
An appropriate threshold can effectively prevent attacks. If the global threshold for triggering flood attack prevention is too low, false positives might occur, causing performance degradation or packet loss. If the global threshold is too high, false negatives might occur, making the network defenseless. Therefore, it is a good practice to enable the threshold learning feature. This feature allows the device to automatically learn the global threshold based on the traffic flows in the network.
# Enable the threshold learning feature for attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] threshold-learn enable
threshold-learn interval
Use threshold-learn interval to set the threshold learning interval.
Use undo threshold-learn interval to restore the default.
threshold-learn interval interval
The threshold learning interval is 1440 minutes.
interval: Specifies a threshold learning interval in the range of 1 to 1200000 minutes.
The device performs periodic threshold learning when you apply an attack defense policy that meets the following requirements:
·     The threshold learning feature is enabled for the policy by using the threshold-learn enable command.
·     The periodic learning mode is set by using the threshold-learn mode periodic command.
# Set the threshold learning interval to 120 minutes for attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] threshold-learn interval 120
Use threshold-learn mode to set the threshold learning mode.
Use undo threshold-learn mode to restore the default.
threshold-learn mode { once | periodic }
The one-time learning mode is set.
once: Specifies the one-time learning mode.
periodic: Specifies the periodic learning mode.
This command allows you to set the following threshold learning modes:
·     One-time learning—The device performs threshold learning only once. This mode is applicable to stable networks.
·     Periodic learning—The device performs threshold learning at intervals. The most recent learned threshold always takes effect. This mode is applicable to unstable networks. To set the threshold learning duration, use the threshold-learn duration command. To set the threshold learning interval, use the threshold-learn interval command.
# Set the periodic learning mode for attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] threshold-learn mode periodic
Use threshold-learn tolerance-value to set the threshold learning tolerance value.
Use undo threshold-learn tolerance-value to restore the default.
threshold-learn tolerance-value tolerance-value
The threshold learning tolerance value is 50.
tolerance-value: Specifies the threshold learning tolerance value in percentage, in the range of 0 to 4000.
When auto applying the learned threshold is enabled, the device uses the learned threshold and tolerance value to calculate the global threshold for triggering flood attack prevention. The formula for calculating the global threshold is learned threshold × (1 + tolerance value). Therefore, the calculated global threshold is larger than the learned threshold. This can prevent packet loss when the network experiences a traffic spike without being attacked.
The tolerance value takes effect only when auto applying the learned threshold is enabled.
# Set the threshold learning tolerance value to 100 for attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] threshold-learn tolerance-value 100
udp-flood action
Use udp-flood action to specify global actions against UDP flood attacks.
Use undo udp-flood action to restore the default.
udp-flood action { drop | logging } *
No global action is specified for UDP flood attacks.
drop: Drops subsequent UDP packets destined for the victim IP addresses in destination-based flood attack prevention, or drops subsequent UDP packets originating from the attacker IP addresses in source-based flood attack prevention.
logging: Enables logging for UDP flood attack events. The log messages will be sent to the log system.
The logging keyword enables the attack detection and prevention module to log UDP flood attack events and send log messages to the information center.
The information center can output UDP flood attack logs to any destinations except the console and the monitor terminal. If you configure the console or monitor terminal as an output destination, the output destination setting will not take effect.
To view UDP flood attack logs stored on the device, use the display logbuffer command. Make sure you do not disable log output to the log buffer, which is enabled by default.
# Specify drop as the global action against UDP flood attacks in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] udp-flood action drop
udp-flood detect
udp-flood detect non-specific
udp-flood source-threshold
udp-flood threshold
udp-flood detect
Use udp-flood detect to configure IP address-specific UDP flood attack detection.
Use undo udp-flood detect to remove the IP address-specific UDP flood attack detection configuration.
udp-flood detect { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] [ threshold threshold-value ] [ action { { drop | logging } * | none } ]
undo udp-flood detect { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
IP address-specific UDP flood attack detection is not configured.
threshold threshold-value: Specifies the maximum receiving rate in pps for UDP packets that are destined for the protected IP address. The value range is 1 to 1000000.
action: Specifies the actions against a detected UDP flood attack. If no action is specified, the global actions set by the udp-flood action command apply.
drop: Drops subsequent UDP packets destined for the protected IP address.
With UDP flood attack detection configured for an IP address, the device is in attack detection state. When the receiving rate of UDP packets destined for the IP address keeps reaching or exceeding the threshold, the device enters prevention state and takes the specified actions. When the rate drops below the silence threshold (three-fourths of the threshold), the device returns to the attack detection state.
You can configure UDP flood attack detection for multiple IP addresses in one attack defense policy.
With the information center, you can set log message filtering and output rules, including output destinations.
# Configure UDP flood attack detection for 192.168.1.2 in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] udp-flood detect ip 192.168.1.2 threshold 2000
udp-flood action
udp-flood threshold
Use udp-flood detect non-specific to enable global UDP flood attack detection.
Use undo udp-flood detect non-specific to disable global UDP flood attack detection.
Global UDP flood attack detection is disabled.
The device supports the following UDP flood attack prevention types:
·     Source-based UDP flood attack prevention—Monitors the receiving rate of UDP packets on a per-source IP basis.
·     Destination-based UDP flood attack prevention—Monitors the receiving rate of UDP packets on a per-destination IP basis.
The global UDP flood attack detection applies to all IP addresses except for those specified by the udp-flood detect command. The global detection uses the global trigger threshold set by the udp-flood threshold or udp-flood source-threshold command and global actions specified by the udp-flood action command.
# Enable global UDP flood attack detection in attack defense policy atk-policy-1.
[Sysname] attack-defense policy atk-policy-1
[Sysname-attack-defense-policy-atk-policy-1] udp-flood detect non-specific
udp-flood action
udp-flood detect
udp-flood threshold
udp-flood threshold
Use udp-flood threshold to set the global threshold for triggering destination-based UDP flood attack prevention.
Use undo udp-flood threshold to restore the default.
udp-flood threshold threshold-value
The global threshold is 10000 for triggering destination-based UDP flood attack prevention.
threshold-value: Specifies the maximum receiving rate in pps for UDP packets that are destined for an IP address. The value range is 0 to 1000000. If you set the threshold value to 0, the destination-based UDP flood attack prevention is disabled.
With global UDP flood attack detection configured, the device is in attack detection state. When the receiving rate of UDP packets destined for an IP address keeps reaching or exceeding the threshold, the device enters prevention state and takes the specified actions. When the rate drops below the silence threshold (three-fourths of the threshold), the device returns to the attack detection state.
The global threshold applies to global UDP flood attack detection. Adjust the threshold according to the application scenarios.
·     If the number of UDP packets sent to a protected server, such as an HTTP or FTP server, is normally large, set a high threshold. A low threshold might affect the server services.
# Set the global threshold to 100 for triggering destination-based UDP flood attack prevention in attack defense policy atk-policy-1.
udp-flood action
udp-flood detect
Use udp-flood source-threshold to set the global threshold for triggering source-based UDP flood attack prevention.
Use undo udp-flood source-threshold to restore the default.
udp-flood source-threshold threshold-value
The global threshold is 10000 for triggering source-based UDP flood attack prevention.
threshold-value: Specifies the maximum receiving rate in pps for UDP packets that originate from an IP address. The value range is 0 to 1000000. If you set the threshold value to 0, the source-based UDP flood attack prevention is disabled.
With global UDP flood attack detection configured, the device is in attack detection state. When the receiving rate of UDP packets originating from an IP address keeps reaching or exceeding the threshold, the device enters prevention state and takes the specified actions. When the rate drops below the silence threshold (three-fourths of the threshold), the device returns to the attack detection state.
# Set the global threshold to 100 for triggering source-based UDP flood attack prevention in attack defense policy atk-policy-1.
[Sysname-attack-defense-policy-atk-policy-1] udp-flood source-threshold 100
udp-flood action
udp-flood detect
whitelist enable
Use whitelist enable to enable the whitelist feature on an interface.
Use undo whitelist enable to disable the whitelist feature on an interface.
whitelist enable
The whitelist feature is disabled on an interface.
Interface view
If the global whitelist feature is enabled, the whitelist feature is enabled on all interfaces. If the global whitelist feature is disabled, you can use this command to enable the whitelist feature on individual interfaces.
# Enable the whitelist feature on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] whitelist enable
whitelist global enable
Use whitelist global enable to enable the global whitelist feature.
Use undo whitelist global enable to disable the global whitelist feature.
The global whitelist feature is disabled.
If you enable the global whitelist feature, the whitelist feature is enabled on all interfaces.
# Enable the global whitelist feature.
[Sysname] whitelist global enable
whitelist object-group
Use whitelist object-group to add an address object group to the whitelist.
Use undo whitelist object-group to restore the default.
whitelist object-group object-group-name
No address object group is added to the whitelist.
object-group-name: Specifies an address object group by its name, a case-insensitive string of 1 to 63 characters.
This command must be used together with the address object group feature. For more information about address object groups, see object group configuration in Security Configuration Guide.
# Add address object group object-group1 to the whitelist.
[Sysname] whitelist object-group object-group1
